1
Guides won't delete!
Jul 24, 2013 Jul 24, 2013
Hi, I know this sounds daft but i can't clear individual guides by simply dragging them into the ruler and they arent locked! is this a known issue?
Andy
Performance , Product issue
62.2K
Adobe Employee , Jul 25, 2013 Jul 25, 2013
Seems that the guide is not getting deleted by drag-drop on to the ruler area if the scroll bar is not at its top/left most position. To workaround this problem, please zoom out to a level where the scroll bars disappear to delete a specific guide by drag drop onto the ruler area.
Hope that helps.
Thansk!
Mohan
Yes. This is a new "feature" for Flash CC. The guides now act like those in Illustrator rather than those in Photoshop.
Dam you new feature! i'm still unable to remove them as they cannot be highlighted like in illustrator.
Nov 17, 2022 Nov 17, 2022
Sometimes you have an "artboard" in top of another one,  move it and erase the wrong one. What you see is the grid from the artboard in the back...
again, this is the animate forum.
Dec 01, 2022 Dec 01, 2022
THat was totally my issue with this. Thank you for that post! : )
Adobe Employee ,
Hi Andy,
Dragging out the unlocked guides into the ruler area should clear the guides.
Can you please clear your application preferences once and see if that helps?
To Delete preferences: hold down Ctrl+Shift+Alt keys [on Windows] / Cmd+Shift+Option keys [on Mac] while launching the application.
If it doesnt help, then can you please post your OS details.
Mohan
Deleting the preferences did not work.
Mac Pro OS X, 10.8.4, 14 GB DDR2 ram.
Adobe Employee ,
Hi Rob,
1. Are you able to select/move the guide?
2. Does Clear Guides works? (View>Guides>Clear Guides)
Mohan
Same here. i've deleted the preferences and still cant delete the guides. I can however clear all guides at ones using the menu command and move them. os as follows:
win7 64bit
creative cloud version of app
note: when prompted i selected sync settings
Adobe Employee ,
Hope that helps.
Thansk!
Mohan
Should this be reported as a bug?
Adobe Employee ,
You can use https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform to report the issue.
Mohan
Jul 30, 2013 Jul 30, 2013
Thanks Mohan, i have now reported this. Lets hope this is fixed in the next update of CC.
Adobe Employee ,
Thanks panvulcon!
Can you mark the post as Answered if you think you got an answer so that it will help people in the forum to find the solution/workarunds much easier.
Thansk!
Mohan
Nov 15, 2014 Nov 15, 2014
click on the guide and hit delete key...
Mar 11, 2015 Mar 11, 2015
Argh!! It's 2015 and I'm having the same problem!! Multiple guides in my file, and all deleted just fine except two, which won't delete at all. I tried every suggestion in this forum? Has anyone gotten an answer to this??
Mac OS 10.9.5
Ha ha, nevermind, the guides were on a locked layer, WOOPS!!
Apr 22, 2015 Apr 22, 2015
I didn't see anyone mention 'master pages' but I hunted around trying to solve my "guide won't delete" issue until I realized the guide was on my master page and it@ had to be deleted there.
Jun 05, 2015 Jun 05, 2015
I have the same problem. Layer is not locked, not on a master page. Using Lynda.com instructions to delete guide, and it does not delete.
Clear guides does work, but what if I don't want to delete them all?
This must be a bug. Adobe, please fix.
The technique is easier than Mohan was describing. No need to drag to the ruler. Click and drag on a guide and move the cursor outside of the pasteboard area. That can be into the rulers, into the timeline, really anywhere outside of that part of the window. You don't have to drag vertical guides left and right, or horizontal guides up and down. For example, to delete a vertical guide you can click and drag on it just above the timeline area (if the timeline is at the bottom), and drag down into the timeline. The guide will go away. This works even if the ruler isn't showing.
Aug 27, 2015 Aug 27, 2015
There are two type of guide in indesign.
First one is, as generally used, just GUIDE. This guide is created in the Layout > Create guides, and so on....
Second one is, I think this may be the main reason of many questions which saying "cann't delete guide!", DOCUMENT COLUMN GUIDE. This guide is created when you first initialize your document or you can setup this in the Layout > margin and columns. The minimum value is 1, because the whole page itself is a column.
So, when you struck in problem with guides, please check the document column guide number. If you wanna make your page clear, setup that value as 1.
JFYI, when you go to the View > Grid & Guides, there are two guide view options. "Lock guides" and "Lock column guides"  As I already mentioned, this lock options is for the each type of guide.
Jan 21, 2016 Jan 21, 2016
Hello,
I was having the same problem and land on this page. I know that I can clear the guides, but it is not what I want. I want to erase just one guide. Reading to the answers here I saw the word lock and tried with that. On View, scrolled down until "unlock guides". Then I was able to erase the one guide I wanted to erase. Then I went back and lock the guides again. This definitely solved the problem.
Feb 12, 2016 Feb 12, 2016
You must go to View>Guides>Lock Guides
By deselecting Lock Guides you can delete them.
Feb 14, 2016 Feb 14, 2016
The guide is applied on a layer, so you can delete a guide by deleting the layer.
Hope that helps
