I plan to add scripts to Photoshop File->Scripts menu items. Or some other convenient mothed to invoke my script. How could I do it?
Just put the jsx-files into the Presets > Scripts-folder.
After restarting Photoshop the Script should be available under File > Scripts and can be assigned a Keyboard Shortcut directly, recorded into an Action or (in CS4 and CS5) be used in a Configurator-Panel.
Configurator buttons can either refer to a Script or contain its code.
worked like a charm. Thank you
I have just started using photoshop cc 2015 and now am getting an
error 1302 No Such Element
Line 21
->var doc = activeDocument
Worked great when I was using PS CS3
It can happen when no image is opened in Photoshop.
This may be a stupid question, but how do you download jsx files? Photoshop Tip by Stephen Di Donato - Dribbble this is the one I want
Right-click on the link, choose the option below and you will get the Save dialog.
That's the beauty of user to user forums, helpings others get to an answer fast so they can continue on.
Gene
If your on windows you can add a link(Windows Shortcut) to Adobe Photoshop Presets\script\ folder to your Phtoshop Scripts tree to link Photoshops script path with your script tree to keep your scripts sepreate from Adobe scripts. Photoshop will includ your Scripts, Plug-ins Scripts and Help in it File>Scripts> List, File>Automate>List and Help>About Plug-ins>List is like adding an additional Plug-in path to Photoshop Preferences.
Hello, I'm trying what you said. Should the Windows Shortcut be inside the C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Scripts folder?
David
yes
If you're on Windows 7, you can drag the script file over your Photoshop icon on the taskbar to "pin" the script to the right-click menu for Photoshop. Any time you would need to run it, just right-click the icon on the taskbar and select the script from the "Pin list".
Hi all,
I am on Windows 7. All my scripts are in the same folder (c:\Photoshop Scripts).
Every script begins as follow :
// MAC Finder or WINDOWS Explorer double clic enabled
#target photoshop
app.bringToFront();
I launch my scripts with links created in a desktop folder. JSX extension is associated to Photoshop. Nothing else to do. The scripts open Photoshop. I never use any browser.
Excuse my poor English.
Hello, please help! I'm trying to run a VBS script from within Photoshop! I know I should start the VBS script by a JSX script, but I can't find the right command for that! Thanks in advance,
David
var myvbs = new File ('/c/wherever/myvb.vbs');
myvbs.execute();
Thanks for the help. But it doesn't work. the jsx file executes itself, but then the vbs script is not launched.
Another question: if both scripts are in the same folder, is it necessary to write the full path of the vbs file inside the jsx code?
G
It might be best to add some check to the code to make sure you have the path and filename correct...
if(myvbs.exists){
myvbs.execute();
}else{
alert("vbs file does not exist!");
You can use the javascript path, if both files are in the same folder...
var myvbs = new File($.filename.parent + "/myvb.vbs");
if(myvbs.exists){
myvbs.execute();
}else{
Another option would be to use cscript via app.system
app.system('cscript //Nologo d:\\vbsfiles\\device.vbs');
Thanks a lot Merllin, you are a true magician!!
Your first code worked. The second code returned an error. I didn't try the 3d code.
I guess there was an error in the path I was using. This path seems strange by the way, but as long as it works it's OK
