I would like to bulk edit the "Question Titles," "Questions," and the "Answers" text (not style) for each slide.
For example: I'm currently working on a 31 question quiz where the question title and answers are the same text and each question starts with "Select all that apply to:".
I've searched multiple times for this to no avail. More often than not, every slide of every quiz I make have the same title and such. I've been manually editing each slide and after about 52 quizzes, ranging from 20 - 90 questions each, I'm burned out and would really love if there is a way to do this.
Did you try Find and Replace from the Edit menu?
I knew I was going to face-palm. Thank you very much.
For any possible future readers, the way I came up with using this with multiple choice questions: Since we have to start with 2 questions both with the same text and such we have to individually edit the first question on each slide. Then use the Find and Replace tool before adding each question, one at a time--Unless... is there is an easier way?
A) Acid
B) default text
*find and replace "default test"*
*add new question*
A) Acid
B) Water
C) default text
*repeat*
