I get the following result when using the certify operation on the SignatureService (SOAP)
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<soapenv:Body>
<soapenv:Fault>
<faultcode>soapenv:Server.generalException</faultcode>
<faultstring>Caused by: com.adobe.livecycle.signatures.client.types.exceptions.PDFOperationException: ALC-DSS-303-002 Could not certify Signature Field signing_slip[0].#subform[0].signature[0] (in the operation : certify)
Caused By: ALC-DSS-303-014 Subject name and the subject alt name missing. (in the operation : getSignerName); nested exception is:
Caused By: ALC-DSS-303-014 Subject name and the subject alt name missing. (in the operation : getSignerName)</faultstring>
<detail>
<faultData>
<ns1:message xmlns:ns1="http://adobe.com/idp/services">ALC-DSS-303-002 Could not certify Signature Field signing_slip[0].#subform[0].signature[0] (in the operation : certify)
Caused By: ALC-DSS-303-014 Subject name and the subject alt name missing. (in the operation : getSignerName)</ns1:message>
</faultData>
<ns2:hostname xmlns:ns2="http://xml.apache.org/axis/">LP00350</ns2:hostname>
</detail>
</soapenv:Fault>
</soapenv:Body>
</soapenv:Envelope>
The certificate used has already been used by an older version of our application. We are now using ES4 and calling the SOAP services directly using Spring-WS. All the other operations work ok, including ReaderExtensions (Reader extensions uses a different certificate, of course).
Thank you.
