When the WebHelp output for RoboHelp 9 is viewed in Internet Explorer 11, the following issues arise:
Tried to fix the issue with the patch available in the link (http://www.wvanweelden.eu/blog/2014/06/14/ie11-patch-robohelp-9)
The webhelp doesnt open after the patch is applied.
Thanks in advance.
Is it the same if you create a new project with just a couple of topics?
Hi Peter,
The webhelp doesn't open even after a new project is created after the patch is applied.
Mangai Sivakumar.
How did you apply the patch? Did you also install the IE10 patch? That fixes some different files and may be causing the issue.
If you install the 10 patch (IE10 patch for RoboHelp 9 installation | WvanWeelden.eu) and then the 11 patch, does it work then? - If it does, please post back so that I can update instructions on my site.
