Hi, I've been trying to download and install photoshop cc for a number of times now. the first time I installed it, it can't be opened. It says some application components are missing and needs to be reinstalled. So I did that by uninstalling and reinstalling it. but the problem remains. So, I did the same process for a couple of times. Finally I tried using the CC Cleaner Tool and uninstalled the previous versions. Once again I install photoshop cc and this time it got stuck at 74%. So I looked into the installation log and this is what I found, Error DW001
02/18/16 09:24:13:369 | [INFO] | | OOBE | DE | | | | 7396 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:24:13:369 | [INFO] | | OOBE | DE | | | | 7396 | START - Installer Session
02/18/16 09:24:13:370 | [INFO] | | OOBE | DE | | | | 7396 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:24:13:395 | [INFO] | | OOBE | DE | | | | 7396 | RIBS version: 9.0.0.61
02/18/16 09:24:13:397 | [INFO] | | OOBE | DE | | | | 7396 | Win OS version: 6.1.0.0 64 bit Type: 1
02/18/16 09:24:13:397 | [INFO] | | OOBE | DE | | | | 7396 | ::START TIMER:: [Total Timer]
02/18/16 09:24:13:397 | [INFO] | | OOBE | DE | | | | 7396 | CHECK: Single instance running
02/18/16 09:24:13:397 | [INFO] | | OOBE | DE | | | | 7396 | CHECK : Credentials
02/18/16 09:24:13:397 | [INFO] | | OOBE | DE | | | | 7396 | Load Deployment File
02/18/16 09:24:13:397 | [INFO] | | OOBE | DE | | | | 7396 | CHECK : Another Native OS installer already running
02/18/16 09:24:13:397 | [INFO] | | OOBE | DE | | | | 7396 | Create Required Folders
02/18/16 09:24:13:397 | [INFO] | | OOBE | DE | | | | 7396 | Assuming uninstall mode
02/18/16 09:24:13:397 | [INFO] | | OOBE | DE | | | | 7396 | Lookup for master payload
02/18/16 09:24:13:397 | [INFO] | | OOBE | DE | | | | 7396 | Ready to initialize session to start with ...
02/18/16 09:24:13:397 | [INFO] | | OOBE | DE | | | | 7396 | ::START TIMER:: [CreatePayloadSession]
02/18/16 09:24:13:642 | [INFO] | | OOBE | DE | | | | 7396 | Supported RIBS version range: [0.0.0.0,9.0.0.61]
02/18/16 09:24:13:645 | [INFO] | | OOBE | DE | | | | 7396 | ----------------- CreatePayloadSession: machine is x64 ---------------
02/18/16 09:24:14:377 | [INFO] | | OOBE | DE | | | | 7396 | ______ Verify Dependency Subscribers ______
02/18/16 09:24:14:378 | [INFO] | | OOBE | DE | | | | 7396 | BEGIN Operation order for all session payloads: mediaGroup (requires,satisfies)
02/18/16 09:24:14:378 | [INFO] | | OOBE | DE | | | | 7396 | Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}: 1 (0,2)
02/18/16 09:24:14:378 | [INFO] | | OOBE | DE | | | | 7396 | Camera Profiles Installer_9.4_AdobeCameraRawProfile8.0All 9.4.0.0 {03B147C3-2412-4DE8-80F9-3EB977421EF2}: 2 (0,0)
02/18/16 09:24:14:378 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}: 3 (0,1)
02/18/16 09:24:14:378 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Support_16.1.2_AdobePhotoshop16-Support 16.1.2.0 {4A117739-A3A4-4E1A-8F5A-82CB1958794F}: 4 (0,0)
02/18/16 09:24:14:378 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}: 5 (0,1)
02/18/16 09:24:14:380 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Preview CC_1.1.3_AdobePreview1.0All-win64 1.1.3.0 {27B8946D-664A-4877-A3C9-CE8249CA1D7A}: 6 (0,0)
02/18/16 09:24:14:380 | [INFO] | | OOBE | DE | | | | 7396 | AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}: 7 (0,1)
02/18/16 09:24:14:380 | [INFO] | | OOBE | DE | | | | 7396 | AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}: 7 (0,1)
02/18/16 09:24:14:380 | [INFO] | | OOBE | DE | | | | 7396 | AdobeColorEU CC 5.0.0.0 {9E9EB9FD-FDE8-487A-A41C-7713DA91AC89}: 7 (0,1)
02/18/16 09:24:14:380 | [INFO] | | OOBE | DE | | | | 7396 | AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}: 7 (0,1)
02/18/16 09:24:14:380 | [INFO] | | OOBE | DE | | | | 7396 | AdobeColorJA CC 5.0.0.0 {52D57F95-000A-4922-BB31-C6A936F4FD7D}: 7 (0,1)
02/18/16 09:24:14:380 | [INFO] | | OOBE | DE | | | | 7396 | AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}: 7 (0,1)
02/18/16 09:24:14:380 | [INFO] | | OOBE | DE | | | | 7396 | AdobeColorNA CC 5.0.0.0 {72405B80-A3DD-4BB2-A8C4-A90BC7BA50FF}: 7 (0,1)
02/18/16 09:24:14:380 | [INFO] | | OOBE | DE | | | | 7396 | AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}: 7 (0,1)
02/18/16 09:24:14:380 | [INFO] | | OOBE | DE | | | | 7396 | AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}: 7 (0,1)
02/18/16 09:24:14:380 | [INFO] | | OOBE | DE | | | | 7396 | AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}: 7 (0,1)
02/18/16 09:24:14:380 | [INFO] | | OOBE | DE | | | | 7396 | Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}: 7 (0,1)
02/18/16 09:24:14:380 | [INFO] | | OOBE | DE | | | | 7396 | Export Assets 2 (64 bit)_2.4_AdobeExportAssets2.0All-x64 2.4.0.0 {3C285B12-AFED-4136-B575-1D6CA2B71D29}: 8 (0,0)
02/18/16 09:24:14:380 | [INFO] | | OOBE | DE | | | | 7396 | Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}: 9 (0,1)
02/18/16 09:24:14:380 | [INFO] | | OOBE | DE | | | | 7396 | Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9}: 9 (0,1)
02/18/16 09:24:14:380 | [INFO] | | OOBE | DE | | | | 7396 | Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20}: 9 (0,1)
02/18/16 09:24:14:380 | [INFO] | | OOBE | DE | | | | 7396 | Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC}: 9 (0,1)
02/18/16 09:24:14:380 | [INFO] | | OOBE | DE | | | | 7396 | Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}: 9 (0,1)
02/18/16 09:24:14:380 | [INFO] | | OOBE | DE | | | | 7396 | Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}: 9 (0,1)
02/18/16 09:24:14:380 | [INFO] | | OOBE | DE | | | | 7396 | Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}: 9 (0,1)
02/18/16 09:24:14:380 | [INFO] | | OOBE | DE | | | | 7396 | Photoshop Camera Raw 8 (64 bit)_9.4_AdobeCameraRaw8.0All-x64 9.4.0.0 {BE4895E5-6517-4CED-B62A-A5A046ADBFCF}: 10 (0,0)
02/18/16 09:24:14:380 | [INFO] | | OOBE | DE | | | | 7396 | Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}: 11 (1,1)
02/18/16 09:24:14:380 | [INFO] | | OOBE | DE | | | | 7396 | Photoshop Camera Raw 8_9.4_AdobeCameraRaw8.0All 9.4.0.0 {8B793E8B-07C8-4865-A698-FE003249A576}: 12 (0,0)
02/18/16 09:24:14:380 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}: 13 (22,0)
02/18/16 09:24:14:380 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Core_16.1.2_AdobePhotoshop16-Core_x64 16.1.2.0 {F217525B-30EB-42F2-A730-F61139264DB5}: 14 (0,0)
02/18/16 09:24:14:380 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Russian Language Pack_AdobePhotoshop16-ru_RU_x64 16.0.0.0 {6E14FFAB-83F4-4CB7-87A2-703F6F20487A}: 14 (0,0)
02/18/16 09:24:14:380 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 AE English Language Pack_AdobePhotoshop16-en_AE_x64 16.0.0.0 {6E7A3076-3056-492F-966F-1EA4FDCE5FA8}: 14 (0,0)
02/18/16 09:24:14:380 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Ukrainian Language Pack_AdobePhotoshop16-uk_UA_x64 16.0.0.0 {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA}: 14 (0,0)
02/18/16 09:24:14:380 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Canadian French Language Pack_AdobePhotoshop16-fr_CA_x64 16.0.0.0 {7433F860-160E-4024-8218-892D796972A6}: 14 (0,0)
02/18/16 09:24:14:380 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Czech Language Pack_AdobePhotoshop16-cs_CZ_x64 16.0.0.0 {7787331E-D646-4CA4-ADCB-B264CC156D7D}: 14 (0,0)
02/18/16 09:24:14:380 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Japanese Language Pack_AdobePhotoshop16-ja_JP_x64 16.0.0.0 {778CE554-471C-4605-A600-852C976A4DC5}: 14 (0,0)
02/18/16 09:24:14:381 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 IL English Language Pack_AdobePhotoshop16-en_IL_x64 16.0.0.0 {0CA9067E-B7E0-4C7A-BA40-987AF967A05D}: 14 (0,0)
02/18/16 09:24:14:381 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 MA French Language Pack_AdobePhotoshop16-fr_MA_x64 16.0.0.0 {0D30F03E-27D9-41F8-AF26-9F1801C2AE28}: 14 (0,0)
02/18/16 09:24:14:381 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Chinese (traditional) Language Pack_AdobePhotoshop16-zh_TW_x64 16.0.0.0 {18844AF8-051C-4227-9BE1-CA06F4364F9C}: 14 (0,0)
02/18/16 09:24:14:381 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Polish Language Pack_AdobePhotoshop16-pl_PL_x64 16.0.0.0 {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0}: 14 (0,0)
02/18/16 09:24:14:381 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Italian Language Pack_AdobePhotoshop16-it_IT_x64 16.0.0.0 {960F21E4-EBDC-4A3E-80E9-C28D8A593F66}: 14 (0,0)
02/18/16 09:24:14:381 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Hungarian Language Pack_AdobePhotoshop16-hu_HU_x64 16.0.0.0 {98D6FC60-7908-474A-A598-0D7A7BFEF2C2}: 14 (0,0)
02/18/16 09:24:14:381 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Swedish Language Pack_AdobePhotoshop16-sv_SE_x64 16.0.0.0 {1B7AE611-4C93-47FC-951F-0BD9839AB72B}: 14 (0,0)
02/18/16 09:24:14:381 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 North American Spanish Language Pack_AdobePhotoshop16-es_MX_x64 16.0.0.0 {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4}: 14 (0,0)
02/18/16 09:24:14:381 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Chinese Language Pack_AdobePhotoshop16-zh_CN_x64 16.0.0.0 {3875BF24-5D9A-494A-A4FA-7AC70F56EC88}: 14 (0,0)
02/18/16 09:24:14:381 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Dutch Language Pack_AdobePhotoshop16-nl_NL_x64 16.0.0.0 {2060E7ED-C473-4A38-877F-C844E81B64F3}: 14 (0,0)
02/18/16 09:24:14:381 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 French Language Pack_AdobePhotoshop16-fr_FR_x64 16.0.0.0 {B75FB41B-E3E2-4B9F-93F7-62D982857374}: 14 (0,0)
02/18/16 09:24:14:381 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Brazilian Portugese Language Pack_AdobePhotoshop16-pt_BR_x64 16.0.0.0 {4A0115A5-CA14-4EA1-9896-2F161B5144B9}: 14 (0,0)
02/18/16 09:24:14:381 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Turkish Language Pack_AdobePhotoshop16-tr_TR_x64 16.0.0.0 {BED85F42-B42C-4A91-946B-A928824C48A1}: 14 (0,0)
02/18/16 09:24:14:381 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Spanish Language Pack_AdobePhotoshop16-es_ES_x64 16.0.0.0 {644DC0CB-E8C9-4508-B99D-8747C6172621}: 14 (0,0)
02/18/16 09:24:14:381 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860}: 14 (0,0)
02/18/16 09:24:14:381 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 International English Language Pack_AdobePhotoshop16-en_GB_x64 16.0.0.0 {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4}: 14 (0,0)
02/18/16 09:24:14:381 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Korean Language Pack_AdobePhotoshop16-ko_KR_x64 16.0.0.0 {5309436A-D12F-437D-B7A4-BF136E17139C}: 14 (0,0)
02/18/16 09:24:14:381 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Norwegian Language Pack_AdobePhotoshop16-nb_NO_x64 16.0.0.0 {00F35A9A-C859-4F6E-8C4F-70A7239207FF}: 14 (0,0)
02/18/16 09:24:14:381 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Danish Language Pack_AdobePhotoshop16-da_DK_x64 16.0.0.0 {F5D14B6C-DA16-4031-9EB8-AF0728550AFC}: 14 (0,0)
02/18/16 09:24:14:381 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 German Language Pack_AdobePhotoshop16-de_DE_x64 16.0.0.0 {69C13F4A-83B3-42F4-912C-C99F1442F439}: 14 (0,0)
02/18/16 09:24:14:381 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Finnish Language Pack_AdobePhotoshop16-fi_FI_x64 16.0.0.0 {FD8B8694-1044-4481-A5D9-4740A46BBC3B}: 14 (0,0)
02/18/16 09:24:14:381 | [INFO] | | OOBE | DE | | | | 7396 | END Operation order for all session payloads: mediaGroup (requires,satisfies)
02/18/16 09:24:14:717 | [INFO] | | OOBE | DE | | | | 7396 | Setting property "deploymentFile" to: C:\Users\Lenovo\AppData\Local\Temp\{436FC5D0-C7A8-4075-B2C8-2D7384E4B18A}\deploy.xml
02/18/16 09:24:14:717 | [INFO] | | OOBE | DE | | | | 7396 | Setting property "driverAdobeCode" to: {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:24:14:717 | [INFO] | | OOBE | DE | | | | 7396 | Setting property "mediaSignature" to: {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:24:14:717 | [INFO] | | OOBE | DE | | | | 7396 | Setting property "userASUPath" to: C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\core\..\D6
02/18/16 09:24:14:717 | [INFO] | | OOBE | DE | | | | 7396 | Overwrite property "mediaSignature" to: {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:24:14:717 | [INFO] | | OOBE | DE | | | | 7396 | Overwrite property "userASUPath" to: C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\core\..\D6
02/18/16 09:24:14:717 | [INFO] | | OOBE | DE | | | | 7396 | Found payload actions:
02/18/16 09:24:14:717 | [INFO] | | OOBE | DE | | | | 7396 | Deciding what installer mode to use...
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Finnish Language Pack_AdobePhotoshop16-fi_FI_x64 16.0.0.0 {FD8B8694-1044-4481-A5D9-4740A46BBC3B} not installed
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 German Language Pack_AdobePhotoshop16-de_DE_x64 16.0.0.0 {69C13F4A-83B3-42F4-912C-C99F1442F439} not installed
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Danish Language Pack_AdobePhotoshop16-da_DK_x64 16.0.0.0 {F5D14B6C-DA16-4031-9EB8-AF0728550AFC} not installed
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Norwegian Language Pack_AdobePhotoshop16-nb_NO_x64 16.0.0.0 {00F35A9A-C859-4F6E-8C4F-70A7239207FF} not installed
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Korean Language Pack_AdobePhotoshop16-ko_KR_x64 16.0.0.0 {5309436A-D12F-437D-B7A4-BF136E17139C} not installed
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 International English Language Pack_AdobePhotoshop16-en_GB_x64 16.0.0.0 {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4} not installed
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860} not installed
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Spanish Language Pack_AdobePhotoshop16-es_ES_x64 16.0.0.0 {644DC0CB-E8C9-4508-B99D-8747C6172621} not installed
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Turkish Language Pack_AdobePhotoshop16-tr_TR_x64 16.0.0.0 {BED85F42-B42C-4A91-946B-A928824C48A1} not installed
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Brazilian Portugese Language Pack_AdobePhotoshop16-pt_BR_x64 16.0.0.0 {4A0115A5-CA14-4EA1-9896-2F161B5144B9} not installed
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 French Language Pack_AdobePhotoshop16-fr_FR_x64 16.0.0.0 {B75FB41B-E3E2-4B9F-93F7-62D982857374} not installed
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Dutch Language Pack_AdobePhotoshop16-nl_NL_x64 16.0.0.0 {2060E7ED-C473-4A38-877F-C844E81B64F3} not installed
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Chinese Language Pack_AdobePhotoshop16-zh_CN_x64 16.0.0.0 {3875BF24-5D9A-494A-A4FA-7AC70F56EC88} not installed
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 North American Spanish Language Pack_AdobePhotoshop16-es_MX_x64 16.0.0.0 {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4} not installed
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Swedish Language Pack_AdobePhotoshop16-sv_SE_x64 16.0.0.0 {1B7AE611-4C93-47FC-951F-0BD9839AB72B} not installed
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Hungarian Language Pack_AdobePhotoshop16-hu_HU_x64 16.0.0.0 {98D6FC60-7908-474A-A598-0D7A7BFEF2C2} not installed
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Italian Language Pack_AdobePhotoshop16-it_IT_x64 16.0.0.0 {960F21E4-EBDC-4A3E-80E9-C28D8A593F66} not installed
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Polish Language Pack_AdobePhotoshop16-pl_PL_x64 16.0.0.0 {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0} not installed
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Chinese (traditional) Language Pack_AdobePhotoshop16-zh_TW_x64 16.0.0.0 {18844AF8-051C-4227-9BE1-CA06F4364F9C} not installed
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 MA French Language Pack_AdobePhotoshop16-fr_MA_x64 16.0.0.0 {0D30F03E-27D9-41F8-AF26-9F1801C2AE28} not installed
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 IL English Language Pack_AdobePhotoshop16-en_IL_x64 16.0.0.0 {0CA9067E-B7E0-4C7A-BA40-987AF967A05D} not installed
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Japanese Language Pack_AdobePhotoshop16-ja_JP_x64 16.0.0.0 {778CE554-471C-4605-A600-852C976A4DC5} not installed
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Czech Language Pack_AdobePhotoshop16-cs_CZ_x64 16.0.0.0 {7787331E-D646-4CA4-ADCB-B264CC156D7D} not installed
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Canadian French Language Pack_AdobePhotoshop16-fr_CA_x64 16.0.0.0 {7433F860-160E-4024-8218-892D796972A6} not installed
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Ukrainian Language Pack_AdobePhotoshop16-uk_UA_x64 16.0.0.0 {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA} not installed
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 AE English Language Pack_AdobePhotoshop16-en_AE_x64 16.0.0.0 {6E7A3076-3056-492F-966F-1EA4FDCE5FA8} not installed
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Russian Language Pack_AdobePhotoshop16-ru_RU_x64 16.0.0.0 {6E14FFAB-83F4-4CB7-87A2-703F6F20487A} not installed
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | AdobeColorNA CC 5.0.0.0 {72405B80-A3DD-4BB2-A8C4-A90BC7BA50FF} not installed
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | AdobeColorJA CC 5.0.0.0 {52D57F95-000A-4922-BB31-C6A936F4FD7D} not installed
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | AdobeColorEU CC 5.0.0.0 {9E9EB9FD-FDE8-487A-A41C-7713DA91AC89} not installed
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | BEGIN Setting requested payload actions
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Finnish Language Pack_AdobePhotoshop16-fi_FI_x64 16.0.0.0 {FD8B8694-1044-4481-A5D9-4740A46BBC3B} is: false
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Adobe Photoshop CC 2015 Finnish Language Pack_AdobePhotoshop16-fi_FI_x64 16.0.0.0 {FD8B8694-1044-4481-A5D9-4740A46BBC3B} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Payload Adobe Photoshop CC 2015 Finnish Language Pack_AdobePhotoshop16-fi_FI_x64 16.0.0.0 {FD8B8694-1044-4481-A5D9-4740A46BBC3B} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Adobe Photoshop CC 2015 German Language Pack_AdobePhotoshop16-de_DE_x64 16.0.0.0 {69C13F4A-83B3-42F4-912C-C99F1442F439} is: false
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Adobe Photoshop CC 2015 German Language Pack_AdobePhotoshop16-de_DE_x64 16.0.0.0 {69C13F4A-83B3-42F4-912C-C99F1442F439} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Payload Adobe Photoshop CC 2015 German Language Pack_AdobePhotoshop16-de_DE_x64 16.0.0.0 {69C13F4A-83B3-42F4-912C-C99F1442F439} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Danish Language Pack_AdobePhotoshop16-da_DK_x64 16.0.0.0 {F5D14B6C-DA16-4031-9EB8-AF0728550AFC} is: false
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Adobe Photoshop CC 2015 Danish Language Pack_AdobePhotoshop16-da_DK_x64 16.0.0.0 {F5D14B6C-DA16-4031-9EB8-AF0728550AFC} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Payload Adobe Photoshop CC 2015 Danish Language Pack_AdobePhotoshop16-da_DK_x64 16.0.0.0 {F5D14B6C-DA16-4031-9EB8-AF0728550AFC} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Norwegian Language Pack_AdobePhotoshop16-nb_NO_x64 16.0.0.0 {00F35A9A-C859-4F6E-8C4F-70A7239207FF} is: false
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Adobe Photoshop CC 2015 Norwegian Language Pack_AdobePhotoshop16-nb_NO_x64 16.0.0.0 {00F35A9A-C859-4F6E-8C4F-70A7239207FF} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Payload Adobe Photoshop CC 2015 Norwegian Language Pack_AdobePhotoshop16-nb_NO_x64 16.0.0.0 {00F35A9A-C859-4F6E-8C4F-70A7239207FF} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Korean Language Pack_AdobePhotoshop16-ko_KR_x64 16.0.0.0 {5309436A-D12F-437D-B7A4-BF136E17139C} is: false
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Adobe Photoshop CC 2015 Korean Language Pack_AdobePhotoshop16-ko_KR_x64 16.0.0.0 {5309436A-D12F-437D-B7A4-BF136E17139C} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Payload Adobe Photoshop CC 2015 Korean Language Pack_AdobePhotoshop16-ko_KR_x64 16.0.0.0 {5309436A-D12F-437D-B7A4-BF136E17139C} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Adobe Photoshop CC 2015 International English Language Pack_AdobePhotoshop16-en_GB_x64 16.0.0.0 {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4} is: false
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Adobe Photoshop CC 2015 International English Language Pack_AdobePhotoshop16-en_GB_x64 16.0.0.0 {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Payload Adobe Photoshop CC 2015 International English Language Pack_AdobePhotoshop16-en_GB_x64 16.0.0.0 {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860} is: false
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Payload Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Spanish Language Pack_AdobePhotoshop16-es_ES_x64 16.0.0.0 {644DC0CB-E8C9-4508-B99D-8747C6172621} is: false
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Adobe Photoshop CC 2015 Spanish Language Pack_AdobePhotoshop16-es_ES_x64 16.0.0.0 {644DC0CB-E8C9-4508-B99D-8747C6172621} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Payload Adobe Photoshop CC 2015 Spanish Language Pack_AdobePhotoshop16-es_ES_x64 16.0.0.0 {644DC0CB-E8C9-4508-B99D-8747C6172621} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Turkish Language Pack_AdobePhotoshop16-tr_TR_x64 16.0.0.0 {BED85F42-B42C-4A91-946B-A928824C48A1} is: false
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Adobe Photoshop CC 2015 Turkish Language Pack_AdobePhotoshop16-tr_TR_x64 16.0.0.0 {BED85F42-B42C-4A91-946B-A928824C48A1} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Payload Adobe Photoshop CC 2015 Turkish Language Pack_AdobePhotoshop16-tr_TR_x64 16.0.0.0 {BED85F42-B42C-4A91-946B-A928824C48A1} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Brazilian Portugese Language Pack_AdobePhotoshop16-pt_BR_x64 16.0.0.0 {4A0115A5-CA14-4EA1-9896-2F161B5144B9} is: false
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Adobe Photoshop CC 2015 Brazilian Portugese Language Pack_AdobePhotoshop16-pt_BR_x64 16.0.0.0 {4A0115A5-CA14-4EA1-9896-2F161B5144B9} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Payload Adobe Photoshop CC 2015 Brazilian Portugese Language Pack_AdobePhotoshop16-pt_BR_x64 16.0.0.0 {4A0115A5-CA14-4EA1-9896-2F161B5144B9} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Adobe Photoshop CC 2015 French Language Pack_AdobePhotoshop16-fr_FR_x64 16.0.0.0 {B75FB41B-E3E2-4B9F-93F7-62D982857374} is: false
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Adobe Photoshop CC 2015 French Language Pack_AdobePhotoshop16-fr_FR_x64 16.0.0.0 {B75FB41B-E3E2-4B9F-93F7-62D982857374} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Payload Adobe Photoshop CC 2015 French Language Pack_AdobePhotoshop16-fr_FR_x64 16.0.0.0 {B75FB41B-E3E2-4B9F-93F7-62D982857374} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Dutch Language Pack_AdobePhotoshop16-nl_NL_x64 16.0.0.0 {2060E7ED-C473-4A38-877F-C844E81B64F3} is: false
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Adobe Photoshop CC 2015 Dutch Language Pack_AdobePhotoshop16-nl_NL_x64 16.0.0.0 {2060E7ED-C473-4A38-877F-C844E81B64F3} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Payload Adobe Photoshop CC 2015 Dutch Language Pack_AdobePhotoshop16-nl_NL_x64 16.0.0.0 {2060E7ED-C473-4A38-877F-C844E81B64F3} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Chinese Language Pack_AdobePhotoshop16-zh_CN_x64 16.0.0.0 {3875BF24-5D9A-494A-A4FA-7AC70F56EC88} is: false
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Adobe Photoshop CC 2015 Chinese Language Pack_AdobePhotoshop16-zh_CN_x64 16.0.0.0 {3875BF24-5D9A-494A-A4FA-7AC70F56EC88} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Payload Adobe Photoshop CC 2015 Chinese Language Pack_AdobePhotoshop16-zh_CN_x64 16.0.0.0 {3875BF24-5D9A-494A-A4FA-7AC70F56EC88} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Adobe Photoshop CC 2015 North American Spanish Language Pack_AdobePhotoshop16-es_MX_x64 16.0.0.0 {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4} is: false
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Adobe Photoshop CC 2015 North American Spanish Language Pack_AdobePhotoshop16-es_MX_x64 16.0.0.0 {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Payload Adobe Photoshop CC 2015 North American Spanish Language Pack_AdobePhotoshop16-es_MX_x64 16.0.0.0 {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Swedish Language Pack_AdobePhotoshop16-sv_SE_x64 16.0.0.0 {1B7AE611-4C93-47FC-951F-0BD9839AB72B} is: false
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Adobe Photoshop CC 2015 Swedish Language Pack_AdobePhotoshop16-sv_SE_x64 16.0.0.0 {1B7AE611-4C93-47FC-951F-0BD9839AB72B} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Payload Adobe Photoshop CC 2015 Swedish Language Pack_AdobePhotoshop16-sv_SE_x64 16.0.0.0 {1B7AE611-4C93-47FC-951F-0BD9839AB72B} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Hungarian Language Pack_AdobePhotoshop16-hu_HU_x64 16.0.0.0 {98D6FC60-7908-474A-A598-0D7A7BFEF2C2} is: false
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Adobe Photoshop CC 2015 Hungarian Language Pack_AdobePhotoshop16-hu_HU_x64 16.0.0.0 {98D6FC60-7908-474A-A598-0D7A7BFEF2C2} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Payload Adobe Photoshop CC 2015 Hungarian Language Pack_AdobePhotoshop16-hu_HU_x64 16.0.0.0 {98D6FC60-7908-474A-A598-0D7A7BFEF2C2} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Italian Language Pack_AdobePhotoshop16-it_IT_x64 16.0.0.0 {960F21E4-EBDC-4A3E-80E9-C28D8A593F66} is: false
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Adobe Photoshop CC 2015 Italian Language Pack_AdobePhotoshop16-it_IT_x64 16.0.0.0 {960F21E4-EBDC-4A3E-80E9-C28D8A593F66} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Payload Adobe Photoshop CC 2015 Italian Language Pack_AdobePhotoshop16-it_IT_x64 16.0.0.0 {960F21E4-EBDC-4A3E-80E9-C28D8A593F66} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Polish Language Pack_AdobePhotoshop16-pl_PL_x64 16.0.0.0 {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0} is: false
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Adobe Photoshop CC 2015 Polish Language Pack_AdobePhotoshop16-pl_PL_x64 16.0.0.0 {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Payload Adobe Photoshop CC 2015 Polish Language Pack_AdobePhotoshop16-pl_PL_x64 16.0.0.0 {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Chinese (traditional) Language Pack_AdobePhotoshop16-zh_TW_x64 16.0.0.0 {18844AF8-051C-4227-9BE1-CA06F4364F9C} is: false
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Adobe Photoshop CC 2015 Chinese (traditional) Language Pack_AdobePhotoshop16-zh_TW_x64 16.0.0.0 {18844AF8-051C-4227-9BE1-CA06F4364F9C} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Payload Adobe Photoshop CC 2015 Chinese (traditional) Language Pack_AdobePhotoshop16-zh_TW_x64 16.0.0.0 {18844AF8-051C-4227-9BE1-CA06F4364F9C} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Adobe Photoshop CC 2015 MA French Language Pack_AdobePhotoshop16-fr_MA_x64 16.0.0.0 {0D30F03E-27D9-41F8-AF26-9F1801C2AE28} is: false
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Adobe Photoshop CC 2015 MA French Language Pack_AdobePhotoshop16-fr_MA_x64 16.0.0.0 {0D30F03E-27D9-41F8-AF26-9F1801C2AE28} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Payload Adobe Photoshop CC 2015 MA French Language Pack_AdobePhotoshop16-fr_MA_x64 16.0.0.0 {0D30F03E-27D9-41F8-AF26-9F1801C2AE28} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Adobe Photoshop CC 2015 IL English Language Pack_AdobePhotoshop16-en_IL_x64 16.0.0.0 {0CA9067E-B7E0-4C7A-BA40-987AF967A05D} is: false
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Adobe Photoshop CC 2015 IL English Language Pack_AdobePhotoshop16-en_IL_x64 16.0.0.0 {0CA9067E-B7E0-4C7A-BA40-987AF967A05D} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Payload Adobe Photoshop CC 2015 IL English Language Pack_AdobePhotoshop16-en_IL_x64 16.0.0.0 {0CA9067E-B7E0-4C7A-BA40-987AF967A05D} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Japanese Language Pack_AdobePhotoshop16-ja_JP_x64 16.0.0.0 {778CE554-471C-4605-A600-852C976A4DC5} is: false
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Adobe Photoshop CC 2015 Japanese Language Pack_AdobePhotoshop16-ja_JP_x64 16.0.0.0 {778CE554-471C-4605-A600-852C976A4DC5} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Payload Adobe Photoshop CC 2015 Japanese Language Pack_AdobePhotoshop16-ja_JP_x64 16.0.0.0 {778CE554-471C-4605-A600-852C976A4DC5} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Czech Language Pack_AdobePhotoshop16-cs_CZ_x64 16.0.0.0 {7787331E-D646-4CA4-ADCB-B264CC156D7D} is: false
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Adobe Photoshop CC 2015 Czech Language Pack_AdobePhotoshop16-cs_CZ_x64 16.0.0.0 {7787331E-D646-4CA4-ADCB-B264CC156D7D} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Payload Adobe Photoshop CC 2015 Czech Language Pack_AdobePhotoshop16-cs_CZ_x64 16.0.0.0 {7787331E-D646-4CA4-ADCB-B264CC156D7D} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Canadian French Language Pack_AdobePhotoshop16-fr_CA_x64 16.0.0.0 {7433F860-160E-4024-8218-892D796972A6} is: false
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Adobe Photoshop CC 2015 Canadian French Language Pack_AdobePhotoshop16-fr_CA_x64 16.0.0.0 {7433F860-160E-4024-8218-892D796972A6} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Payload Adobe Photoshop CC 2015 Canadian French Language Pack_AdobePhotoshop16-fr_CA_x64 16.0.0.0 {7433F860-160E-4024-8218-892D796972A6} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Ukrainian Language Pack_AdobePhotoshop16-uk_UA_x64 16.0.0.0 {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA} is: false
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Adobe Photoshop CC 2015 Ukrainian Language Pack_AdobePhotoshop16-uk_UA_x64 16.0.0.0 {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Payload Adobe Photoshop CC 2015 Ukrainian Language Pack_AdobePhotoshop16-uk_UA_x64 16.0.0.0 {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Adobe Photoshop CC 2015 AE English Language Pack_AdobePhotoshop16-en_AE_x64 16.0.0.0 {6E7A3076-3056-492F-966F-1EA4FDCE5FA8} is: false
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Adobe Photoshop CC 2015 AE English Language Pack_AdobePhotoshop16-en_AE_x64 16.0.0.0 {6E7A3076-3056-492F-966F-1EA4FDCE5FA8} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Payload Adobe Photoshop CC 2015 AE English Language Pack_AdobePhotoshop16-en_AE_x64 16.0.0.0 {6E7A3076-3056-492F-966F-1EA4FDCE5FA8} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Russian Language Pack_AdobePhotoshop16-ru_RU_x64 16.0.0.0 {6E14FFAB-83F4-4CB7-87A2-703F6F20487A} is: false
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Adobe Photoshop CC 2015 Russian Language Pack_AdobePhotoshop16-ru_RU_x64 16.0.0.0 {6E14FFAB-83F4-4CB7-87A2-703F6F20487A} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Payload Adobe Photoshop CC 2015 Russian Language Pack_AdobePhotoshop16-ru_RU_x64 16.0.0.0 {6E14FFAB-83F4-4CB7-87A2-703F6F20487A} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Core_16.1.2_AdobePhotoshop16-Core_x64 16.1.2.0 {F217525B-30EB-42F2-A730-F61139264DB5} is: true
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Adobe Photoshop CC 2015 Core_16.1.2_AdobePhotoshop16-Core_x64 16.1.2.0 {F217525B-30EB-42F2-A730-F61139264DB5} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Payload Adobe Photoshop CC 2015 Core_16.1.2_AdobePhotoshop16-Core_x64 16.1.2.0 {F217525B-30EB-42F2-A730-F61139264DB5} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21} is: true
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21} is remove
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Selection of payload Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21} is forbidden by the policy. Reason: Free payload
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Photoshop Camera Raw 8_9.4_AdobeCameraRaw8.0All 9.4.0.0 {8B793E8B-07C8-4865-A698-FE003249A576} is: true
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Photoshop Camera Raw 8_9.4_AdobeCameraRaw8.0All 9.4.0.0 {8B793E8B-07C8-4865-A698-FE003249A576} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Payload Photoshop Camera Raw 8_9.4_AdobeCameraRaw8.0All 9.4.0.0 {8B793E8B-07C8-4865-A698-FE003249A576} is extension payload. Aligning its action according to parent Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85} is: true
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Photoshop Camera Raw 8 (64 bit)_9.4_AdobeCameraRaw8.0All-x64 9.4.0.0 {BE4895E5-6517-4CED-B62A-A5A046ADBFCF} is: true
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Photoshop Camera Raw 8 (64 bit)_9.4_AdobeCameraRaw8.0All-x64 9.4.0.0 {BE4895E5-6517-4CED-B62A-A5A046ADBFCF} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Payload Photoshop Camera Raw 8 (64 bit)_9.4_AdobeCameraRaw8.0All-x64 9.4.0.0 {BE4895E5-6517-4CED-B62A-A5A046ADBFCF} is extension payload. Aligning its action according to parent Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA} is: true
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446} is: true
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613} is: true
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC} is: true
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20} is: true
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9} is: true
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9} is: true
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9} is none
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Export Assets 2 (64 bit)_2.4_AdobeExportAssets2.0All-x64 2.4.0.0 {3C285B12-AFED-4136-B575-1D6CA2B71D29} is: true
02/18/16 09:24:14:957 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Export Assets 2 (64 bit)_2.4_AdobeExportAssets2.0All-x64 2.4.0.0 {3C285B12-AFED-4136-B575-1D6CA2B71D29} is none
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Payload Export Assets 2 (64 bit)_2.4_AdobeExportAssets2.0All-x64 2.4.0.0 {3C285B12-AFED-4136-B575-1D6CA2B71D29} is extension payload. Aligning its action according to parent Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140} is: true
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140} is none
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94} is: true
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Action string for AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94} is none
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66} is: true
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Action string for AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66} is none
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44} is: true
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Action string for AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44} is none
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: AdobeColorNA CC 5.0.0.0 {72405B80-A3DD-4BB2-A8C4-A90BC7BA50FF} is: false
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Action string for AdobeColorNA CC 5.0.0.0 {72405B80-A3DD-4BB2-A8C4-A90BC7BA50FF} is none
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB} is: true
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Action string for AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB} is none
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: AdobeColorJA CC 5.0.0.0 {52D57F95-000A-4922-BB31-C6A936F4FD7D} is: false
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Action string for AdobeColorJA CC 5.0.0.0 {52D57F95-000A-4922-BB31-C6A936F4FD7D} is none
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28} is: true
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Action string for AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28} is none
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: AdobeColorEU CC 5.0.0.0 {9E9EB9FD-FDE8-487A-A41C-7713DA91AC89} is: false
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Action string for AdobeColorEU CC 5.0.0.0 {9E9EB9FD-FDE8-487A-A41C-7713DA91AC89} is none
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC} is: true
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Action string for AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC} is none
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95} is: true
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Action string for AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95} is none
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Adobe Preview CC_1.1.3_AdobePreview1.0All-win64 1.1.3.0 {27B8946D-664A-4877-A3C9-CE8249CA1D7A} is: true
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Adobe Preview CC_1.1.3_AdobePreview1.0All-win64 1.1.3.0 {27B8946D-664A-4877-A3C9-CE8249CA1D7A} is none
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Payload Adobe Preview CC_1.1.3_AdobePreview1.0All-win64 1.1.3.0 {27B8946D-664A-4877-A3C9-CE8249CA1D7A} is extension payload. Aligning its action according to parent Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3} is: true
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3} is none
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Support_16.1.2_AdobePhotoshop16-Support 16.1.2.0 {4A117739-A3A4-4E1A-8F5A-82CB1958794F} is: true
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Adobe Photoshop CC 2015 Support_16.1.2_AdobePhotoshop16-Support 16.1.2.0 {4A117739-A3A4-4E1A-8F5A-82CB1958794F} is none
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Payload Adobe Photoshop CC 2015 Support_16.1.2_AdobePhotoshop16-Support 16.1.2.0 {4A117739-A3A4-4E1A-8F5A-82CB1958794F} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457} is: true
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457} is none
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Camera Profiles Installer_9.4_AdobeCameraRawProfile8.0All 9.4.0.0 {03B147C3-2412-4DE8-80F9-3EB977421EF2} is: true
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Camera Profiles Installer_9.4_AdobeCameraRawProfile8.0All 9.4.0.0 {03B147C3-2412-4DE8-80F9-3EB977421EF2} is none
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Payload Camera Profiles Installer_9.4_AdobeCameraRawProfile8.0All 9.4.0.0 {03B147C3-2412-4DE8-80F9-3EB977421EF2} is extension payload. Aligning its action according to parent Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Value returned on lookup of payload: Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10} is: true
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | Action string for Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10} is none
02/18/16 09:24:14:972 | [INFO] | | OOBE | DE | | | | 7396 | END Setting requested payload actions
02/18/16 09:24:14:988 | [INFO] | | OOBE | DE | | | | 7396 | INSTALLDIR passed path basic path validation: C:\Program Files\Adobe
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | BEGIN InstallOperationsQueue Unordered operations
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Norwegian Language Pack_AdobePhotoshop16-nb_NO_x64 16.0.0.0 {00F35A9A-C859-4F6E-8C4F-70A7239207FF}: with operation none
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Camera Profiles Installer_9.4_AdobeCameraRawProfile8.0All 9.4.0.0 {03B147C3-2412-4DE8-80F9-3EB977421EF2}: with operation remove
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Ukrainian Language Pack_AdobePhotoshop16-uk_UA_x64 16.0.0.0 {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA}: with operation none
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 IL English Language Pack_AdobePhotoshop16-en_IL_x64 16.0.0.0 {0CA9067E-B7E0-4C7A-BA40-987AF967A05D}: with operation none
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 MA French Language Pack_AdobePhotoshop16-fr_MA_x64 16.0.0.0 {0D30F03E-27D9-41F8-AF26-9F1801C2AE28}: with operation none
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Chinese (traditional) Language Pack_AdobePhotoshop16-zh_TW_x64 16.0.0.0 {18844AF8-051C-4227-9BE1-CA06F4364F9C}: with operation none
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Swedish Language Pack_AdobePhotoshop16-sv_SE_x64 16.0.0.0 {1B7AE611-4C93-47FC-951F-0BD9839AB72B}: with operation none
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Dutch Language Pack_AdobePhotoshop16-nl_NL_x64 16.0.0.0 {2060E7ED-C473-4A38-877F-C844E81B64F3}: with operation none
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 North American Spanish Language Pack_AdobePhotoshop16-es_MX_x64 16.0.0.0 {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4}: with operation none
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}: with operation remove
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Preview CC_1.1.3_AdobePreview1.0All-win64 1.1.3.0 {27B8946D-664A-4877-A3C9-CE8249CA1D7A}: with operation remove
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Chinese Language Pack_AdobePhotoshop16-zh_CN_x64 16.0.0.0 {3875BF24-5D9A-494A-A4FA-7AC70F56EC88}: with operation none
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Export Assets 2 (64 bit)_2.4_AdobeExportAssets2.0All-x64 2.4.0.0 {3C285B12-AFED-4136-B575-1D6CA2B71D29}: with operation remove
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20}: with operation remove
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}: with operation remove
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}: with operation remove
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Brazilian Portugese Language Pack_AdobePhotoshop16-pt_BR_x64 16.0.0.0 {4A0115A5-CA14-4EA1-9896-2F161B5144B9}: with operation none
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Support_16.1.2_AdobePhotoshop16-Support 16.1.2.0 {4A117739-A3A4-4E1A-8F5A-82CB1958794F}: with operation remove
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}: with operation remove
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 International English Language Pack_AdobePhotoshop16-en_GB_x64 16.0.0.0 {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4}: with operation none
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | AdobeColorJA CC 5.0.0.0 {52D57F95-000A-4922-BB31-C6A936F4FD7D}: with operation none
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Korean Language Pack_AdobePhotoshop16-ko_KR_x64 16.0.0.0 {5309436A-D12F-437D-B7A4-BF136E17139C}: with operation none
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}: with operation remove
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9}: with operation remove
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}: with operation remove
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}: with operation remove
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}: with operation remove
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}: with operation remove
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Spanish Language Pack_AdobePhotoshop16-es_ES_x64 16.0.0.0 {644DC0CB-E8C9-4508-B99D-8747C6172621}: with operation none
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 German Language Pack_AdobePhotoshop16-de_DE_x64 16.0.0.0 {69C13F4A-83B3-42F4-912C-C99F1442F439}: with operation none
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Russian Language Pack_AdobePhotoshop16-ru_RU_x64 16.0.0.0 {6E14FFAB-83F4-4CB7-87A2-703F6F20487A}: with operation none
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 AE English Language Pack_AdobePhotoshop16-en_AE_x64 16.0.0.0 {6E7A3076-3056-492F-966F-1EA4FDCE5FA8}: with operation none
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | AdobeColorNA CC 5.0.0.0 {72405B80-A3DD-4BB2-A8C4-A90BC7BA50FF}: with operation none
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Canadian French Language Pack_AdobePhotoshop16-fr_CA_x64 16.0.0.0 {7433F860-160E-4024-8218-892D796972A6}: with operation none
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Czech Language Pack_AdobePhotoshop16-cs_CZ_x64 16.0.0.0 {7787331E-D646-4CA4-ADCB-B264CC156D7D}: with operation none
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Japanese Language Pack_AdobePhotoshop16-ja_JP_x64 16.0.0.0 {778CE554-471C-4605-A600-852C976A4DC5}: with operation none
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}: with operation remove
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC}: with operation remove
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Photoshop Camera Raw 8_9.4_AdobeCameraRaw8.0All 9.4.0.0 {8B793E8B-07C8-4865-A698-FE003249A576}: with operation remove
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Polish Language Pack_AdobePhotoshop16-pl_PL_x64 16.0.0.0 {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0}: with operation none
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Italian Language Pack_AdobePhotoshop16-it_IT_x64 16.0.0.0 {960F21E4-EBDC-4A3E-80E9-C28D8A593F66}: with operation none
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Hungarian Language Pack_AdobePhotoshop16-hu_HU_x64 16.0.0.0 {98D6FC60-7908-474A-A598-0D7A7BFEF2C2}: with operation none
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | AdobeColorEU CC 5.0.0.0 {9E9EB9FD-FDE8-487A-A41C-7713DA91AC89}: with operation none
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}: with operation remove
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}: with operation remove
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}: with operation remove
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 French Language Pack_AdobePhotoshop16-fr_FR_x64 16.0.0.0 {B75FB41B-E3E2-4B9F-93F7-62D982857374}: with operation none
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Photoshop Camera Raw 8 (64 bit)_9.4_AdobeCameraRaw8.0All-x64 9.4.0.0 {BE4895E5-6517-4CED-B62A-A5A046ADBFCF}: with operation remove
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Turkish Language Pack_AdobePhotoshop16-tr_TR_x64 16.0.0.0 {BED85F42-B42C-4A91-946B-A928824C48A1}: with operation none
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}: with operation remove
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860}: with operation none
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}: with operation remove
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}: with operation remove
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Core_16.1.2_AdobePhotoshop16-Core_x64 16.1.2.0 {F217525B-30EB-42F2-A730-F61139264DB5}: with operation remove
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Danish Language Pack_AdobePhotoshop16-da_DK_x64 16.0.0.0 {F5D14B6C-DA16-4031-9EB8-AF0728550AFC}: with operation none
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}: with operation remove
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Finnish Language Pack_AdobePhotoshop16-fi_FI_x64 16.0.0.0 {FD8B8694-1044-4481-A5D9-4740A46BBC3B}: with operation none
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | END InstallOperationsQueue Unordered operations
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | BEGIN InstallOperationsQueue Ordered operations
02/18/16 09:24:18:758 | [INFO] | | OOBE | DE | | | | 7396 | END InstallOperationsQueue Ordered operations
02/18/16 09:24:18:914 | [INFO] | | OOBE | DE | | | | 7396 | Payloads passed preflight validation.
02/18/16 09:24:18:914 | [INFO] | | OOBE | DE | | | | 7396 | Call PreSession Custom Hook
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | BEGIN InstallOperationsQueue Unordered operations
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Norwegian Language Pack_AdobePhotoshop16-nb_NO_x64 16.0.0.0 {00F35A9A-C859-4F6E-8C4F-70A7239207FF}: with operation none
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Camera Profiles Installer_9.4_AdobeCameraRawProfile8.0All 9.4.0.0 {03B147C3-2412-4DE8-80F9-3EB977421EF2}: with operation remove
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Ukrainian Language Pack_AdobePhotoshop16-uk_UA_x64 16.0.0.0 {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA}: with operation none
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 IL English Language Pack_AdobePhotoshop16-en_IL_x64 16.0.0.0 {0CA9067E-B7E0-4C7A-BA40-987AF967A05D}: with operation none
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 MA French Language Pack_AdobePhotoshop16-fr_MA_x64 16.0.0.0 {0D30F03E-27D9-41F8-AF26-9F1801C2AE28}: with operation none
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Chinese (traditional) Language Pack_AdobePhotoshop16-zh_TW_x64 16.0.0.0 {18844AF8-051C-4227-9BE1-CA06F4364F9C}: with operation none
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Swedish Language Pack_AdobePhotoshop16-sv_SE_x64 16.0.0.0 {1B7AE611-4C93-47FC-951F-0BD9839AB72B}: with operation none
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Dutch Language Pack_AdobePhotoshop16-nl_NL_x64 16.0.0.0 {2060E7ED-C473-4A38-877F-C844E81B64F3}: with operation none
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 North American Spanish Language Pack_AdobePhotoshop16-es_MX_x64 16.0.0.0 {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4}: with operation none
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}: with operation remove
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Preview CC_1.1.3_AdobePreview1.0All-win64 1.1.3.0 {27B8946D-664A-4877-A3C9-CE8249CA1D7A}: with operation remove
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Chinese Language Pack_AdobePhotoshop16-zh_CN_x64 16.0.0.0 {3875BF24-5D9A-494A-A4FA-7AC70F56EC88}: with operation none
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Export Assets 2 (64 bit)_2.4_AdobeExportAssets2.0All-x64 2.4.0.0 {3C285B12-AFED-4136-B575-1D6CA2B71D29}: with operation remove
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20}: with operation remove
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}: with operation remove
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}: with operation remove
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Brazilian Portugese Language Pack_AdobePhotoshop16-pt_BR_x64 16.0.0.0 {4A0115A5-CA14-4EA1-9896-2F161B5144B9}: with operation none
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Support_16.1.2_AdobePhotoshop16-Support 16.1.2.0 {4A117739-A3A4-4E1A-8F5A-82CB1958794F}: with operation remove
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}: with operation remove
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 International English Language Pack_AdobePhotoshop16-en_GB_x64 16.0.0.0 {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4}: with operation none
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | AdobeColorJA CC 5.0.0.0 {52D57F95-000A-4922-BB31-C6A936F4FD7D}: with operation none
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Korean Language Pack_AdobePhotoshop16-ko_KR_x64 16.0.0.0 {5309436A-D12F-437D-B7A4-BF136E17139C}: with operation none
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}: with operation remove
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9}: with operation remove
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}: with operation remove
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}: with operation remove
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}: with operation remove
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}: with operation remove
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Spanish Language Pack_AdobePhotoshop16-es_ES_x64 16.0.0.0 {644DC0CB-E8C9-4508-B99D-8747C6172621}: with operation none
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 German Language Pack_AdobePhotoshop16-de_DE_x64 16.0.0.0 {69C13F4A-83B3-42F4-912C-C99F1442F439}: with operation none
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Russian Language Pack_AdobePhotoshop16-ru_RU_x64 16.0.0.0 {6E14FFAB-83F4-4CB7-87A2-703F6F20487A}: with operation none
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 AE English Language Pack_AdobePhotoshop16-en_AE_x64 16.0.0.0 {6E7A3076-3056-492F-966F-1EA4FDCE5FA8}: with operation none
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | AdobeColorNA CC 5.0.0.0 {72405B80-A3DD-4BB2-A8C4-A90BC7BA50FF}: with operation none
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Canadian French Language Pack_AdobePhotoshop16-fr_CA_x64 16.0.0.0 {7433F860-160E-4024-8218-892D796972A6}: with operation none
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Czech Language Pack_AdobePhotoshop16-cs_CZ_x64 16.0.0.0 {7787331E-D646-4CA4-ADCB-B264CC156D7D}: with operation none
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Japanese Language Pack_AdobePhotoshop16-ja_JP_x64 16.0.0.0 {778CE554-471C-4605-A600-852C976A4DC5}: with operation none
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}: with operation remove
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC}: with operation remove
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Photoshop Camera Raw 8_9.4_AdobeCameraRaw8.0All 9.4.0.0 {8B793E8B-07C8-4865-A698-FE003249A576}: with operation remove
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Polish Language Pack_AdobePhotoshop16-pl_PL_x64 16.0.0.0 {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0}: with operation none
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Italian Language Pack_AdobePhotoshop16-it_IT_x64 16.0.0.0 {960F21E4-EBDC-4A3E-80E9-C28D8A593F66}: with operation none
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Hungarian Language Pack_AdobePhotoshop16-hu_HU_x64 16.0.0.0 {98D6FC60-7908-474A-A598-0D7A7BFEF2C2}: with operation none
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | AdobeColorEU CC 5.0.0.0 {9E9EB9FD-FDE8-487A-A41C-7713DA91AC89}: with operation none
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}: with operation remove
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}: with operation remove
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}: with operation remove
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 French Language Pack_AdobePhotoshop16-fr_FR_x64 16.0.0.0 {B75FB41B-E3E2-4B9F-93F7-62D982857374}: with operation none
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Photoshop Camera Raw 8 (64 bit)_9.4_AdobeCameraRaw8.0All-x64 9.4.0.0 {BE4895E5-6517-4CED-B62A-A5A046ADBFCF}: with operation remove
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Turkish Language Pack_AdobePhotoshop16-tr_TR_x64 16.0.0.0 {BED85F42-B42C-4A91-946B-A928824C48A1}: with operation none
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}: with operation remove
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860}: with operation none
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}: with operation remove
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}: with operation remove
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Core_16.1.2_AdobePhotoshop16-Core_x64 16.1.2.0 {F217525B-30EB-42F2-A730-F61139264DB5}: with operation remove
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Danish Language Pack_AdobePhotoshop16-da_DK_x64 16.0.0.0 {F5D14B6C-DA16-4031-9EB8-AF0728550AFC}: with operation none
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}: with operation remove
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | Adobe Photoshop CC 2015 Finnish Language Pack_AdobePhotoshop16-fi_FI_x64 16.0.0.0 {FD8B8694-1044-4481-A5D9-4740A46BBC3B}: with operation none
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | END InstallOperationsQueue Unordered operations
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | BEGIN InstallOperationsQueue Ordered operations
02/18/16 09:24:18:929 | [INFO] | | OOBE | DE | | | | 7396 | END InstallOperationsQueue Ordered operations
02/18/16 09:24:18:945 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for pre-remove for payload Adobe Photoshop CC 2015 Core_16.1.2_AdobePhotoshop16-Core_x64 16.1.2.0 {F217525B-30EB-42F2-A730-F61139264DB5}
02/18/16 09:24:18:961 | [INFO] | | OOBE | DE | | | | 7396 | ::START TIMER:: [Payload Operation :{F217525B-30EB-42F2-A730-F61139264DB5}]
02/18/16 09:24:18:992 | [INFO] | | OOBE | DE | | | | 2272 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:24:18:992 | [INFO] | | OOBE | DE | | | | 2272 | Installer Operation: PayloadUninstaller
02/18/16 09:24:18:992 | [INFO] | | OOBE | DE | | | | 2272 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {F217525B-30EB-42F2-A730-F61139264DB5}
02/18/16 09:24:19:179 | [INFO] | | OOBE | DE | | | | 2272 | Effective AdobeCode for: {F217525B-30EB-42F2-A730-F61139264DB5} is {F217525B-30EB-42F2-A730-F61139264DB5}
02/18/16 09:24:19:195 | [INFO] | | OOBE | DE | | | | 2272 | Uninstalling payload
02/18/16 09:24:19:226 | [INFO] | | OOBE | DE | | | | 2272 | Payload Adobe Photoshop CC 2015 Core_16.1.2_AdobePhotoshop16-Core_x64 16.1.2.0 {F217525B-30EB-42F2-A730-F61139264DB5}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 09:24:19:332 | [INFO] | | OOBE | DE | | | | 2272 | Setting file open option to false in the unzipper
02/18/16 09:25:19:824 | [INFO] | | OOBE | DE | | | | 2272 | CustomizedPatch property not found in database
02/18/16 09:25:19:824 | [INFO] | | OOBE | DE | | | | 2272 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{F217525B-30EB-42F2-A730-F61139264DB5}.db
02/18/16 09:30:20:927 | [INFO] | | OOBE | DE | | | | 2272 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{F217525B-30EB-42F2-A730-F61139264DB5}.db
02/18/16 09:30:27:126 | [INFO] | | OOBE | DE | | | | 2272 | Physical payload uninstall result:0
02/18/16 09:30:27:235 | [INFO] | | OOBE | DE | | | | 7396 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:30:27:235 | [INFO] | | OOBE | DE | | | | 7396 | :: END TIMER :: [Payload Operation :{F217525B-30EB-42F2-A730-F61139264DB5}] took 368262 milliseconds (368.262 seconds) DTR = 1292.14 KBPS (1.26185 MBPS)
02/18/16 09:30:28:408 | [INFO] | | OOBE | DE | | | | 7396 | User specified overrideFile:
02/18/16 09:30:42:650 | [INFO] | | OOBE | DE | | | | 7396 | Successfully updated the csu inventory for Adobe Photoshop CC 2015 Core_16.1.2_AdobePhotoshop16-Core_x64 16.1.2.0 {F217525B-30EB-42F2-A730-F61139264DB5} return values 0:0
02/18/16 09:30:42:650 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for post-remove for payload Adobe Photoshop CC 2015 Core_16.1.2_AdobePhotoshop16-Core_x64 16.1.2.0 {F217525B-30EB-42F2-A730-F61139264DB5}
02/18/16 09:30:42:728 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for pre-remove for payload Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:30:42:744 | [INFO] | | OOBE | DE | | | | 7396 | ::START TIMER:: [Payload Operation :{793C2BF7-A4FE-4608-91C9-9282C5801C21}]
02/18/16 09:30:42:759 | [INFO] | | OOBE | DE | | | | 7704 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:30:42:759 | [INFO] | | OOBE | DE | | | | 7704 | Installer Operation: PayloadUninstaller
02/18/16 09:30:42:759 | [INFO] | | OOBE | DE | | | | 7704 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:30:43:273 | [INFO] | | OOBE | DE | | | | 7704 | Effective AdobeCode for: {793C2BF7-A4FE-4608-91C9-9282C5801C21} is {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:30:43:288 | [INFO] | | OOBE | DE | | | | 7704 | Uninstalling payload
02/18/16 09:30:43:304 | [INFO] | | OOBE | DE | | | | 7704 | Payload Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 09:30:43:351 | [INFO] | | OOBE | DE | | | | 7704 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{793C2BF7-A4FE-4608-91C9-9282C5801C21}.db
02/18/16 09:31:44:832 | [INFO] | | OOBE | DE | | | | 7704 | Evaluating condition# 1(Seq 3385)
02/18/16 09:31:44:832 | [INFO] | | OOBE | DE | | | | 7704 | Condition failed(Seq 3385)
02/18/16 09:34:32:684 | [INFO] | | OOBE | DE | | | | 7704 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{793C2BF7-A4FE-4608-91C9-9282C5801C21}.db
02/18/16 09:34:43:317 | [INFO] | | OOBE | DE | | | | 7704 | Physical payload uninstall result:0
02/18/16 09:34:43:404 | [INFO] | | OOBE | DE | | | | 7396 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:34:43:404 | [INFO] | | OOBE | DE | | | | 7396 | :: END TIMER :: [Payload Operation :{793C2BF7-A4FE-4608-91C9-9282C5801C21}] took 240651 milliseconds (240.651 seconds) DTR = 5490.43 KBPS (5.36175 MBPS)
02/18/16 09:34:43:404 | [INFO] | | OOBE | DE | | | | 7396 | Updating driver data - Action: Add driver entry
02/18/16 09:34:43:404 | [INFO] | | OOBE | DE | | | | 7396 | Updating driver data successful. Driver entry was added. ARP estimated size 0KB
02/18/16 09:34:44:565 | [INFO] | | OOBE | DE | | | | 7396 | User specified overrideFile:
02/18/16 09:34:51:216 | [INFO] | | OOBE | DE | | | | 7396 | Successfully updated the csu inventory for Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21} return values 0:0
02/18/16 09:34:51:216 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for post-remove for payload Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 09:34:51:247 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for pre-remove for payload Photoshop Camera Raw 8_9.4_AdobeCameraRaw8.0All 9.4.0.0 {8B793E8B-07C8-4865-A698-FE003249A576}
02/18/16 09:34:51:263 | [INFO] | | OOBE | DE | | | | 7396 | ::START TIMER:: [Payload Operation :{8B793E8B-07C8-4865-A698-FE003249A576}]
02/18/16 09:34:51:279 | [INFO] | | OOBE | DE | | | | 7524 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:34:51:279 | [INFO] | | OOBE | DE | | | | 7524 | Installer Operation: PayloadUninstaller
02/18/16 09:34:51:279 | [INFO] | | OOBE | DE | | | | 7524 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {8B793E8B-07C8-4865-A698-FE003249A576}
02/18/16 09:34:51:450 | [INFO] | | OOBE | DE | | | | 7524 | Effective AdobeCode for: {8B793E8B-07C8-4865-A698-FE003249A576} is {8B793E8B-07C8-4865-A698-FE003249A576}
02/18/16 09:34:51:450 | [INFO] | | OOBE | DE | | | | 7524 | Uninstalling payload
02/18/16 09:34:51:466 | [INFO] | | OOBE | DE | | | | 7524 | Payload Photoshop Camera Raw 8_9.4_AdobeCameraRaw8.0All 9.4.0.0 {8B793E8B-07C8-4865-A698-FE003249A576}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 09:34:51:481 | [INFO] | | OOBE | DE | | | | 7524 | Setting file open option to false in the unzipper
02/18/16 09:34:51:902 | [INFO] | | OOBE | DE | | | | 7524 | CustomizedPatch property not found in database
02/18/16 09:34:51:902 | [INFO] | | OOBE | DE | | | | 7524 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{8B793E8B-07C8-4865-A698-FE003249A576}.db
02/18/16 09:34:51:998 | [INFO] | | OOBE | DE | | | | 7524 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{8B793E8B-07C8-4865-A698-FE003249A576}.db
02/18/16 09:34:52:007 | [INFO] | | OOBE | DE | | | | 7524 | Physical payload uninstall result:0
02/18/16 09:34:52:034 | [INFO] | | OOBE | DE | | | | 7396 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:34:52:034 | [INFO] | | OOBE | DE | | | | 7396 | :: END TIMER :: [Payload Operation :{8B793E8B-07C8-4865-A698-FE003249A576}] took 757.636 milliseconds (0.757636 seconds) DTR = 60863 KBPS (59.4365 MBPS)
02/18/16 09:34:52:476 | [INFO] | | OOBE | DE | | | | 7396 | User specified overrideFile:
02/18/16 09:34:52:660 | [INFO] | | OOBE | DE | | | | 7396 | Successfully updated the csu inventory for Photoshop Camera Raw 8_9.4_AdobeCameraRaw8.0All 9.4.0.0 {8B793E8B-07C8-4865-A698-FE003249A576} return values 0:0
02/18/16 09:34:52:670 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for post-remove for payload Photoshop Camera Raw 8_9.4_AdobeCameraRaw8.0All 9.4.0.0 {8B793E8B-07C8-4865-A698-FE003249A576}
02/18/16 09:34:52:710 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for pre-remove for payload Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}
02/18/16 09:34:52:730 | [INFO] | | OOBE | DE | | | | 7396 | ::START TIMER:: [Payload Operation :{3E7FC757-D497-4C89-A935-7D38E2164E85}]
02/18/16 09:34:52:740 | [INFO] | | OOBE | DE | | | | 7288 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:34:52:740 | [INFO] | | OOBE | DE | | | | 7288 | Installer Operation: PayloadUninstaller
02/18/16 09:34:52:740 | [INFO] | | OOBE | DE | | | | 7288 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {3E7FC757-D497-4C89-A935-7D38E2164E85}
02/18/16 09:34:52:985 | [INFO] | | OOBE | DE | | | | 7288 | Effective AdobeCode for: {3E7FC757-D497-4C89-A935-7D38E2164E85} is {3E7FC757-D497-4C89-A935-7D38E2164E85}
02/18/16 09:34:52:995 | [INFO] | | OOBE | DE | | | | 7288 | Uninstalling payload
02/18/16 09:34:53:010 | [INFO] | | OOBE | DE | | | | 7288 | Payload Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 09:34:53:029 | [INFO] | | OOBE | DE | | | | 7288 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{3E7FC757-D497-4C89-A935-7D38E2164E85}.db
02/18/16 09:34:53:197 | [INFO] | | OOBE | DE | | | | 7288 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{3E7FC757-D497-4C89-A935-7D38E2164E85}.db
02/18/16 09:34:53:202 | [INFO] | | OOBE | DE | | | | 7288 | Physical payload uninstall result:0
02/18/16 09:34:53:242 | [INFO] | | OOBE | DE | | | | 7396 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:34:53:242 | [INFO] | | OOBE | DE | | | | 7396 | :: END TIMER :: [Payload Operation :{3E7FC757-D497-4C89-A935-7D38E2164E85}] took 511.139 milliseconds (0.511139 seconds) DTR = 49012.1 KBPS (47.8634 MBPS)
02/18/16 09:34:54:342 | [INFO] | | OOBE | DE | | | | 7396 | User specified overrideFile:
02/18/16 09:34:54:879 | [INFO] | | OOBE | DE | | | | 7396 | Successfully updated the csu inventory for Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85} return values 0:0
02/18/16 09:34:54:889 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for post-remove for payload Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}
02/18/16 09:34:54:911 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for pre-remove for payload Photoshop Camera Raw 8 (64 bit)_9.4_AdobeCameraRaw8.0All-x64 9.4.0.0 {BE4895E5-6517-4CED-B62A-A5A046ADBFCF}
02/18/16 09:34:54:939 | [INFO] | | OOBE | DE | | | | 7396 | ::START TIMER:: [Payload Operation :{BE4895E5-6517-4CED-B62A-A5A046ADBFCF}]
02/18/16 09:34:54:951 | [INFO] | | OOBE | DE | | | | 7004 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:34:54:951 | [INFO] | | OOBE | DE | | | | 7004 | Installer Operation: PayloadUninstaller
02/18/16 09:34:54:951 | [INFO] | | OOBE | DE | | | | 7004 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {BE4895E5-6517-4CED-B62A-A5A046ADBFCF}
02/18/16 09:34:55:258 | [INFO] | | OOBE | DE | | | | 7004 | Effective AdobeCode for: {BE4895E5-6517-4CED-B62A-A5A046ADBFCF} is {BE4895E5-6517-4CED-B62A-A5A046ADBFCF}
02/18/16 09:34:55:258 | [INFO] | | OOBE | DE | | | | 7004 | Uninstalling payload
02/18/16 09:34:55:274 | [INFO] | | OOBE | DE | | | | 7004 | Payload Photoshop Camera Raw 8 (64 bit)_9.4_AdobeCameraRaw8.0All-x64 9.4.0.0 {BE4895E5-6517-4CED-B62A-A5A046ADBFCF}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 09:34:55:274 | [INFO] | | OOBE | DE | | | | 7004 | Setting file open option to false in the unzipper
02/18/16 09:34:57:284 | [INFO] | | OOBE | DE | | | | 7004 | CustomizedPatch property not found in database
02/18/16 09:34:57:284 | [INFO] | | OOBE | DE | | | | 7004 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{BE4895E5-6517-4CED-B62A-A5A046ADBFCF}.db
02/18/16 09:34:57:362 | [INFO] | | OOBE | DE | | | | 7004 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{BE4895E5-6517-4CED-B62A-A5A046ADBFCF}.db
02/18/16 09:34:57:378 | [INFO] | | OOBE | DE | | | | 7004 | Physical payload uninstall result:0
02/18/16 09:34:57:394 | [INFO] | | OOBE | DE | | | | 7396 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:34:57:394 | [INFO] | | OOBE | DE | | | | 7396 | :: END TIMER :: [Payload Operation :{BE4895E5-6517-4CED-B62A-A5A046ADBFCF}] took 2455.38 milliseconds (2.45538 seconds) DTR = 20870.1 KBPS (20.381 MBPS)
02/18/16 09:34:57:782 | [INFO] | | OOBE | DE | | | | 7396 | User specified overrideFile:
02/18/16 09:34:57:977 | [INFO] | | OOBE | DE | | | | 7396 | Successfully updated the csu inventory for Photoshop Camera Raw 8 (64 bit)_9.4_AdobeCameraRaw8.0All-x64 9.4.0.0 {BE4895E5-6517-4CED-B62A-A5A046ADBFCF} return values 0:0
02/18/16 09:34:57:987 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for post-remove for payload Photoshop Camera Raw 8 (64 bit)_9.4_AdobeCameraRaw8.0All-x64 9.4.0.0 {BE4895E5-6517-4CED-B62A-A5A046ADBFCF}
02/18/16 09:34:58:027 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for pre-remove for payload Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}
02/18/16 09:34:58:042 | [INFO] | | OOBE | DE | | | | 7396 | ::START TIMER:: [Payload Operation :{5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}]
02/18/16 09:34:58:057 | [INFO] | | OOBE | DE | | | | 6436 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:34:58:057 | [INFO] | | OOBE | DE | | | | 6436 | Installer Operation: PayloadUninstaller
02/18/16 09:34:58:057 | [INFO] | | OOBE | DE | | | | 6436 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}
02/18/16 09:34:58:294 | [INFO] | | OOBE | DE | | | | 6436 | Effective AdobeCode for: {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA} is {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}
02/18/16 09:34:58:304 | [INFO] | | OOBE | DE | | | | 6436 | Uninstalling payload
02/18/16 09:34:58:319 | [INFO] | | OOBE | DE | | | | 6436 | Payload Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 09:34:58:344 | [INFO] | | OOBE | DE | | | | 6436 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}.db
02/18/16 09:34:58:464 | [INFO] | | OOBE | DE | | | | 6436 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}.db
02/18/16 09:34:58:469 | [INFO] | | OOBE | DE | | | | 6436 | Physical payload uninstall result:0
02/18/16 09:34:58:564 | [INFO] | | OOBE | DE | | | | 7396 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:34:58:564 | [INFO] | | OOBE | DE | | | | 7396 | :: END TIMER :: [Payload Operation :{5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}] took 518.777 milliseconds (0.518777 seconds) DTR = 53125 KBPS (51.8799 MBPS)
02/18/16 09:34:59:052 | [INFO] | | OOBE | DE | | | | 7396 | User specified overrideFile:
02/18/16 09:34:59:373 | [INFO] | | OOBE | DE | | | | 7396 | Successfully updated the csu inventory for Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA} return values 0:0
02/18/16 09:34:59:388 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for post-remove for payload Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}
02/18/16 09:34:59:408 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for pre-remove for payload Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}
02/18/16 09:34:59:423 | [INFO] | | OOBE | DE | | | | 7396 | ::START TIMER:: [Payload Operation :{636D196A-789E-455D-825E-3FA79F67D446}]
02/18/16 09:34:59:433 | [INFO] | | OOBE | DE | | | | 7416 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:34:59:433 | [INFO] | | OOBE | DE | | | | 7416 | Installer Operation: ModifyThirdPartyPayloadOperation
02/18/16 09:34:59:433 | [INFO] | | OOBE | DE | | | | 7416 | Modify Thirdparty payload
02/18/16 09:34:59:433 | [INFO] | | OOBE | DE | | | | 7416 | Unable to remove payload.
02/18/16 09:34:59:433 | [INFO] | | OOBE | DE | | | | 7416 | Third party payload completed. Testing return code: 0
02/18/16 09:34:59:739 | [INFO] | | OOBE | DE | | | | 7396 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:34:59:739 | [INFO] | | OOBE | DE | | | | 7396 | :: END TIMER :: [Payload Operation :{636D196A-789E-455D-825E-3FA79F67D446}] took 315.927 milliseconds (0.315927 seconds)
02/18/16 09:34:59:764 | [INFO] | | OOBE | DE | | | | 7396 | User specified overrideFile:
02/18/16 09:34:59:949 | [INFO] | | OOBE | DE | | | | 7396 | The csu inventory was not updated for payload Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}, value of local var is -1
02/18/16 09:34:59:959 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for post-remove for payload Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}
02/18/16 09:34:59:974 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for pre-remove for payload Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}
02/18/16 09:34:59:989 | [INFO] | | OOBE | DE | | | | 7396 | ::START TIMER:: [Payload Operation :{4CED09CB-0C96-4EAE-83C4-7D9B9456E613}]
02/18/16 09:35:00:004 | [INFO] | | OOBE | DE | | | | 3824 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:35:00:004 | [INFO] | | OOBE | DE | | | | 3824 | Installer Operation: ModifyThirdPartyPayloadOperation
02/18/16 09:35:00:004 | [INFO] | | OOBE | DE | | | | 3824 | Modify Thirdparty payload
02/18/16 09:35:00:004 | [INFO] | | OOBE | DE | | | | 3824 | Unable to remove payload.
02/18/16 09:35:00:004 | [INFO] | | OOBE | DE | | | | 3824 | Third party payload completed. Testing return code: 0
02/18/16 09:35:00:306 | [INFO] | | OOBE | DE | | | | 7396 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:35:00:306 | [INFO] | | OOBE | DE | | | | 7396 | :: END TIMER :: [Payload Operation :{4CED09CB-0C96-4EAE-83C4-7D9B9456E613}] took 312.718 milliseconds (0.312718 seconds)
02/18/16 09:35:00:331 | [INFO] | | OOBE | DE | | | | 7396 | User specified overrideFile:
02/18/16 09:35:00:561 | [INFO] | | OOBE | DE | | | | 7396 | The csu inventory was not updated for payload Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}, value of local var is -1
02/18/16 09:35:00:571 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for post-remove for payload Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}
02/18/16 09:35:00:586 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for pre-remove for payload Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC}
02/18/16 09:35:00:601 | [INFO] | | OOBE | DE | | | | 7396 | ::START TIMER:: [Payload Operation :{873BE68F-480F-49A6-9649-F98CAB056AFC}]
02/18/16 09:35:00:616 | [INFO] | | OOBE | DE | | | | 7208 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:35:00:616 | [INFO] | | OOBE | DE | | | | 7208 | Installer Operation: ModifyThirdPartyPayloadOperation
02/18/16 09:35:00:616 | [INFO] | | OOBE | DE | | | | 7208 | Modify Thirdparty payload
02/18/16 09:35:00:616 | [INFO] | | OOBE | DE | | | | 7208 | Unable to remove payload.
02/18/16 09:35:00:616 | [INFO] | | OOBE | DE | | | | 7208 | Third party payload completed. Testing return code: 0
02/18/16 09:35:00:716 | [INFO] | | OOBE | DE | | | | 7396 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:35:00:716 | [INFO] | | OOBE | DE | | | | 7396 | :: END TIMER :: [Payload Operation :{873BE68F-480F-49A6-9649-F98CAB056AFC}] took 111.031 milliseconds (0.111031 seconds)
02/18/16 09:35:00:745 | [INFO] | | OOBE | DE | | | | 7396 | User specified overrideFile:
02/18/16 09:35:00:768 | [INFO] | | OOBE | DE | | | | 7396 | The csu inventory was not updated for payload Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC}, value of local var is -1
02/18/16 09:35:00:773 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for post-remove for payload Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC}
02/18/16 09:35:00:793 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for pre-remove for payload Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20}
02/18/16 09:35:00:808 | [INFO] | | OOBE | DE | | | | 7396 | ::START TIMER:: [Payload Operation :{3E272A93-C06B-4206-AD02-0EBE02535E20}]
02/18/16 09:35:00:823 | [INFO] | | OOBE | DE | | | | 5288 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:35:00:823 | [INFO] | | OOBE | DE | | | | 5288 | Installer Operation: ModifyThirdPartyPayloadOperation
02/18/16 09:35:00:823 | [INFO] | | OOBE | DE | | | | 5288 | Modify Thirdparty payload
02/18/16 09:35:00:823 | [INFO] | | OOBE | DE | | | | 5288 | Unable to remove payload.
02/18/16 09:35:00:823 | [INFO] | | OOBE | DE | | | | 5288 | Third party payload completed. Testing return code: 0
02/18/16 09:35:00:923 | [INFO] | | OOBE | DE | | | | 7396 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:35:00:923 | [INFO] | | OOBE | DE | | | | 7396 | :: END TIMER :: [Payload Operation :{3E272A93-C06B-4206-AD02-0EBE02535E20}] took 110.606 milliseconds (0.110606 seconds)
02/18/16 09:35:00:952 | [INFO] | | OOBE | DE | | | | 7396 | User specified overrideFile:
02/18/16 09:35:00:976 | [INFO] | | OOBE | DE | | | | 7396 | The csu inventory was not updated for payload Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20}, value of local var is -1
02/18/16 09:35:00:984 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for post-remove for payload Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20}
02/18/16 09:35:01:003 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for pre-remove for payload Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9}
02/18/16 09:35:01:017 | [INFO] | | OOBE | DE | | | | 7396 | ::START TIMER:: [Payload Operation :{55B82130-18F9-11E2-8D43-00215AEA26C9}]
02/18/16 09:35:01:031 | [INFO] | | OOBE | DE | | | | 7444 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:35:01:031 | [INFO] | | OOBE | DE | | | | 7444 | Installer Operation: ModifyThirdPartyPayloadOperation
02/18/16 09:35:01:031 | [INFO] | | OOBE | DE | | | | 7444 | Modify Thirdparty payload
02/18/16 09:35:01:031 | [INFO] | | OOBE | DE | | | | 7444 | Unable to remove payload.
02/18/16 09:35:01:031 | [INFO] | | OOBE | DE | | | | 7444 | Third party payload completed. Testing return code: 0
02/18/16 09:35:01:131 | [INFO] | | OOBE | DE | | | | 7396 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:35:01:131 | [INFO] | | OOBE | DE | | | | 7396 | :: END TIMER :: [Payload Operation :{55B82130-18F9-11E2-8D43-00215AEA26C9}] took 113.175 milliseconds (0.113175 seconds) DTR = 565.498 KBPS (0.552244 MBPS)
02/18/16 09:35:01:159 | [INFO] | | OOBE | DE | | | | 7396 | User specified overrideFile:
02/18/16 09:35:01:183 | [INFO] | | OOBE | DE | | | | 7396 | The csu inventory was not updated for payload Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9}, value of local var is -1
02/18/16 09:35:01:193 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for post-remove for payload Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9}
02/18/16 09:35:01:213 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for pre-remove for payload Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}
02/18/16 09:35:01:228 | [INFO] | | OOBE | DE | | | | 7396 | ::START TIMER:: [Payload Operation :{54B0C34F-18F9-11E2-BC1D-00215AEA26C9}]
02/18/16 09:35:01:241 | [INFO] | | OOBE | DE | | | | 8048 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:35:01:241 | [INFO] | | OOBE | DE | | | | 8048 | Installer Operation: ModifyThirdPartyPayloadOperation
02/18/16 09:35:01:241 | [INFO] | | OOBE | DE | | | | 8048 | Modify Thirdparty payload
02/18/16 09:35:01:242 | [INFO] | | OOBE | DE | | | | 8048 | Unable to remove payload.
02/18/16 09:35:01:242 | [INFO] | | OOBE | DE | | | | 8048 | Third party payload completed. Testing return code: 0
02/18/16 09:35:01:341 | [INFO] | | OOBE | DE | | | | 7396 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:35:01:341 | [INFO] | | OOBE | DE | | | | 7396 | :: END TIMER :: [Payload Operation :{54B0C34F-18F9-11E2-BC1D-00215AEA26C9}] took 113.411 milliseconds (0.113411 seconds)
02/18/16 09:35:01:370 | [INFO] | | OOBE | DE | | | | 7396 | User specified overrideFile:
02/18/16 09:35:01:392 | [INFO] | | OOBE | DE | | | | 7396 | The csu inventory was not updated for payload Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}, value of local var is -1
02/18/16 09:35:01:402 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for post-remove for payload Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}
02/18/16 09:35:01:421 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for pre-remove for payload Export Assets 2 (64 bit)_2.4_AdobeExportAssets2.0All-x64 2.4.0.0 {3C285B12-AFED-4136-B575-1D6CA2B71D29}
02/18/16 09:35:01:437 | [INFO] | | OOBE | DE | | | | 7396 | ::START TIMER:: [Payload Operation :{3C285B12-AFED-4136-B575-1D6CA2B71D29}]
02/18/16 09:35:01:450 | [INFO] | | OOBE | DE | | | | 7228 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:35:01:450 | [INFO] | | OOBE | DE | | | | 7228 | Installer Operation: PayloadUninstaller
02/18/16 09:35:01:450 | [INFO] | | OOBE | DE | | | | 7228 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {3C285B12-AFED-4136-B575-1D6CA2B71D29}
02/18/16 09:35:01:686 | [INFO] | | OOBE | DE | | | | 7228 | Effective AdobeCode for: {3C285B12-AFED-4136-B575-1D6CA2B71D29} is {3C285B12-AFED-4136-B575-1D6CA2B71D29}
02/18/16 09:35:01:695 | [INFO] | | OOBE | DE | | | | 7228 | Uninstalling payload
02/18/16 09:35:01:712 | [INFO] | | OOBE | DE | | | | 7228 | Payload Export Assets 2 (64 bit)_2.4_AdobeExportAssets2.0All-x64 2.4.0.0 {3C285B12-AFED-4136-B575-1D6CA2B71D29}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 09:35:01:713 | [INFO] | | OOBE | DE | | | | 7228 | Setting file open option to false in the unzipper
02/18/16 09:35:05:092 | [INFO] | | OOBE | DE | | | | 7228 | CustomizedPatch property not found in database
02/18/16 09:35:05:093 | [INFO] | | OOBE | DE | | | | 7228 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{3C285B12-AFED-4136-B575-1D6CA2B71D29}.db
02/18/16 09:37:31:803 | [INFO] | | OOBE | DE | | | | 7228 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{3C285B12-AFED-4136-B575-1D6CA2B71D29}.db
02/18/16 09:37:32:385 | [INFO] | | OOBE | DE | | | | 7228 | Physical payload uninstall result:0
02/18/16 09:37:32:445 | [INFO] | | OOBE | DE | | | | 7396 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:37:32:445 | [INFO] | | OOBE | DE | | | | 7396 | :: END TIMER :: [Payload Operation :{3C285B12-AFED-4136-B575-1D6CA2B71D29}] took 151007 milliseconds (151.007 seconds) DTR = 28.3696 KBPS (0.0277047 MBPS)
02/18/16 09:37:32:982 | [INFO] | | OOBE | DE | | | | 7396 | User specified overrideFile:
02/18/16 09:37:33:222 | [INFO] | | OOBE | DE | | | | 7396 | Successfully updated the csu inventory for Export Assets 2 (64 bit)_2.4_AdobeExportAssets2.0All-x64 2.4.0.0 {3C285B12-AFED-4136-B575-1D6CA2B71D29} return values 0:0
02/18/16 09:37:33:233 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for post-remove for payload Export Assets 2 (64 bit)_2.4_AdobeExportAssets2.0All-x64 2.4.0.0 {3C285B12-AFED-4136-B575-1D6CA2B71D29}
02/18/16 09:37:33:269 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for pre-remove for payload Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}
02/18/16 09:37:33:285 | [INFO] | | OOBE | DE | | | | 7396 | ::START TIMER:: [Payload Operation :{27375F7C-0789-4FEA-889E-41BF12AC3140}]
02/18/16 09:37:33:298 | [INFO] | | OOBE | DE | | | | 7952 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:37:33:298 | [INFO] | | OOBE | DE | | | | 7952 | Installer Operation: PayloadUninstaller
02/18/16 09:37:33:298 | [INFO] | | OOBE | DE | | | | 7952 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {27375F7C-0789-4FEA-889E-41BF12AC3140}
02/18/16 09:37:33:737 | [INFO] | | OOBE | DE | | | | 7952 | Effective AdobeCode for: {27375F7C-0789-4FEA-889E-41BF12AC3140} is {27375F7C-0789-4FEA-889E-41BF12AC3140}
02/18/16 09:37:33:746 | [INFO] | | OOBE | DE | | | | 7952 | Uninstalling payload
02/18/16 09:37:33:760 | [INFO] | | OOBE | DE | | | | 7952 | Payload Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 09:37:33:816 | [INFO] | | OOBE | DE | | | | 7952 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{27375F7C-0789-4FEA-889E-41BF12AC3140}.db
02/18/16 09:39:38:325 | [INFO] | | OOBE | DE | | | | 7952 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{27375F7C-0789-4FEA-889E-41BF12AC3140}.db
02/18/16 09:39:40:322 | [INFO] | | OOBE | DE | | | | 7952 | Physical payload uninstall result:0
02/18/16 09:39:40:370 | [INFO] | | OOBE | DE | | | | 7396 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:39:40:370 | [INFO] | | OOBE | DE | | | | 7396 | :: END TIMER :: [Payload Operation :{27375F7C-0789-4FEA-889E-41BF12AC3140}] took 127083 milliseconds (127.083 seconds) DTR = 162.508 KBPS (0.158699 MBPS)
02/18/16 09:39:49:332 | [INFO] | | OOBE | DE | | | | 7396 | User specified overrideFile:
02/18/16 09:39:52:684 | [INFO] | | OOBE | DE | | | | 7396 | Successfully updated the csu inventory for Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140} return values 0:0
02/18/16 09:39:52:694 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for post-remove for payload Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}
02/18/16 09:39:52:714 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for pre-remove for payload AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}
02/18/16 09:39:52:729 | [INFO] | | OOBE | DE | | | | 7396 | ::START TIMER:: [Payload Operation :{CE9B1B00-0421-4701-9698-1C14646D6D94}]
02/18/16 09:39:52:759 | [INFO] | | OOBE | DE | | | | 6980 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:39:52:759 | [INFO] | | OOBE | DE | | | | 6980 | Installer Operation: PayloadUninstaller
02/18/16 09:39:52:759 | [INFO] | | OOBE | DE | | | | 6980 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {CE9B1B00-0421-4701-9698-1C14646D6D94}
02/18/16 09:39:54:153 | [INFO] | | OOBE | DE | | | | 6980 | Effective AdobeCode for: {CE9B1B00-0421-4701-9698-1C14646D6D94} is {CE9B1B00-0421-4701-9698-1C14646D6D94}
02/18/16 09:39:54:160 | [INFO] | | OOBE | DE | | | | 6980 | Uninstalling payload
02/18/16 09:39:54:171 | [INFO] | | OOBE | DE | | | | 6980 | Payload AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 09:39:54:211 | [INFO] | | OOBE | DE | | | | 6980 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{CE9B1B00-0421-4701-9698-1C14646D6D94}.db
02/18/16 09:39:54:213 | [INFO] | | OOBE | DE | | | | 6980 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{CE9B1B00-0421-4701-9698-1C14646D6D94}.db
02/18/16 09:39:54:214 | [INFO] | | OOBE | DE | | | | 6980 | Physical payload uninstall result:0
02/18/16 09:39:54:315 | [INFO] | | OOBE | DE | | | | 7396 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:39:54:315 | [INFO] | | OOBE | DE | | | | 7396 | :: END TIMER :: [Payload Operation :{CE9B1B00-0421-4701-9698-1C14646D6D94}] took 1582.24 milliseconds (1.58224 seconds) DTR = 32.8648 KBPS (0.0320945 MBPS)
02/18/16 09:39:55:572 | [INFO] | | OOBE | DE | | | | 7396 | User specified overrideFile:
02/18/16 09:39:56:717 | [INFO] | | OOBE | DE | | | | 7396 | Successfully updated the csu inventory for AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94} return values 0:0
02/18/16 09:39:56:787 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for post-remove for payload AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}
02/18/16 09:39:56:817 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for pre-remove for payload AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}
02/18/16 09:39:56:837 | [INFO] | | OOBE | DE | | | | 7396 | ::START TIMER:: [Payload Operation :{5C5D62C9-91C6-415E-857E-9130C0F52C66}]
02/18/16 09:39:56:847 | [INFO] | | OOBE | DE | | | | 8084 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:39:56:847 | [INFO] | | OOBE | DE | | | | 8084 | Installer Operation: PayloadUninstaller
02/18/16 09:39:56:847 | [INFO] | | OOBE | DE | | | | 8084 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {5C5D62C9-91C6-415E-857E-9130C0F52C66}
02/18/16 09:39:57:266 | [INFO] | | OOBE | DE | | | | 8084 | Effective AdobeCode for: {5C5D62C9-91C6-415E-857E-9130C0F52C66} is {5C5D62C9-91C6-415E-857E-9130C0F52C66}
02/18/16 09:39:57:273 | [INFO] | | OOBE | DE | | | | 8084 | Uninstalling payload
02/18/16 09:39:57:288 | [INFO] | | OOBE | DE | | | | 8084 | Payload AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 09:39:57:318 | [INFO] | | OOBE | DE | | | | 8084 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{5C5D62C9-91C6-415E-857E-9130C0F52C66}.db
02/18/16 09:39:57:318 | [INFO] | | OOBE | DE | | | | 8084 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{5C5D62C9-91C6-415E-857E-9130C0F52C66}.db
02/18/16 09:39:57:321 | [INFO] | | OOBE | DE | | | | 8084 | Physical payload uninstall result:0
02/18/16 09:39:57:366 | [INFO] | | OOBE | DE | | | | 7396 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:39:57:366 | [INFO] | | OOBE | DE | | | | 7396 | :: END TIMER :: [Payload Operation :{5C5D62C9-91C6-415E-857E-9130C0F52C66}] took 527.16 milliseconds (0.52716 seconds) DTR = 136.581 KBPS (0.13338 MBPS)
02/18/16 09:39:58:045 | [INFO] | | OOBE | DE | | | | 7396 | User specified overrideFile:
02/18/16 09:39:58:787 | [INFO] | | OOBE | DE | | | | 7396 | Successfully updated the csu inventory for AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66} return values 0:0
02/18/16 09:39:58:797 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for post-remove for payload AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}
02/18/16 09:39:58:817 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for pre-remove for payload AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}
02/18/16 09:39:58:832 | [INFO] | | OOBE | DE | | | | 7396 | ::START TIMER:: [Payload Operation :{AB955DCF-69CD-4840-B7FB-F318CDD0AE44}]
02/18/16 09:39:58:844 | [INFO] | | OOBE | DE | | | | 5720 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:39:58:844 | [INFO] | | OOBE | DE | | | | 5720 | Installer Operation: PayloadUninstaller
02/18/16 09:39:58:844 | [INFO] | | OOBE | DE | | | | 5720 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}
02/18/16 09:39:59:604 | [INFO] | | OOBE | DE | | | | 5720 | Effective AdobeCode for: {AB955DCF-69CD-4840-B7FB-F318CDD0AE44} is {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}
02/18/16 09:39:59:604 | [INFO] | | OOBE | DE | | | | 5720 | Uninstalling payload
02/18/16 09:39:59:619 | [INFO] | | OOBE | DE | | | | 5720 | Payload AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 09:39:59:658 | [INFO] | | OOBE | DE | | | | 5720 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{AB955DCF-69CD-4840-B7FB-F318CDD0AE44}.db
02/18/16 09:39:59:660 | [INFO] | | OOBE | DE | | | | 5720 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{AB955DCF-69CD-4840-B7FB-F318CDD0AE44}.db
02/18/16 09:39:59:661 | [INFO] | | OOBE | DE | | | | 5720 | Physical payload uninstall result:0
02/18/16 09:39:59:689 | [INFO] | | OOBE | DE | | | | 7396 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:39:59:689 | [INFO] | | OOBE | DE | | | | 7396 | :: END TIMER :: [Payload Operation :{AB955DCF-69CD-4840-B7FB-F318CDD0AE44}] took 857.557 milliseconds (0.857557 seconds) DTR = 9.32882 KBPS (0.00911018 MBPS)
02/18/16 09:40:00:333 | [INFO] | | OOBE | DE | | | | 7396 | User specified overrideFile:
02/18/16 09:40:01:741 | [INFO] | | OOBE | DE | | | | 7396 | Successfully updated the csu inventory for AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44} return values 0:0
02/18/16 09:40:01:752 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for post-remove for payload AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}
02/18/16 09:40:01:773 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for pre-remove for payload AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}
02/18/16 09:40:01:793 | [INFO] | | OOBE | DE | | | | 7396 | ::START TIMER:: [Payload Operation :{A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}]
02/18/16 09:40:01:803 | [INFO] | | OOBE | DE | | | | 6976 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:40:01:803 | [INFO] | | OOBE | DE | | | | 6976 | Installer Operation: PayloadUninstaller
02/18/16 09:40:01:803 | [INFO] | | OOBE | DE | | | | 6976 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}
02/18/16 09:40:02:349 | [INFO] | | OOBE | DE | | | | 6976 | Effective AdobeCode for: {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB} is {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}
02/18/16 09:40:02:359 | [INFO] | | OOBE | DE | | | | 6976 | Uninstalling payload
02/18/16 09:40:02:369 | [INFO] | | OOBE | DE | | | | 6976 | Payload AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 09:40:02:389 | [INFO] | | OOBE | DE | | | | 6976 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}.db
02/18/16 09:40:02:389 | [INFO] | | OOBE | DE | | | | 6976 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}.db
02/18/16 09:40:02:389 | [INFO] | | OOBE | DE | | | | 6976 | Physical payload uninstall result:0
02/18/16 09:40:02:419 | [INFO] | | OOBE | DE | | | | 7396 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:40:02:419 | [INFO] | | OOBE | DE | | | | 7396 | :: END TIMER :: [Payload Operation :{A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}] took 625.82 milliseconds (0.62582 seconds) DTR = 115.049 KBPS (0.112353 MBPS)
02/18/16 09:40:09:056 | [INFO] | | OOBE | DE | | | | 7396 | User specified overrideFile:
02/18/16 09:40:11:822 | [INFO] | | OOBE | DE | | | | 7396 | Successfully updated the csu inventory for AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB} return values 0:0
02/18/16 09:40:11:832 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for post-remove for payload AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}
02/18/16 09:40:11:857 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for pre-remove for payload AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}
02/18/16 09:40:11:872 | [INFO] | | OOBE | DE | | | | 7396 | ::START TIMER:: [Payload Operation :{F6DED2DA-1D20-497E-8810-E745B45DCD28}]
02/18/16 09:40:11:887 | [INFO] | | OOBE | DE | | | | 3548 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:40:11:887 | [INFO] | | OOBE | DE | | | | 3548 | Installer Operation: PayloadUninstaller
02/18/16 09:40:11:887 | [INFO] | | OOBE | DE | | | | 3548 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {F6DED2DA-1D20-497E-8810-E745B45DCD28}
02/18/16 09:40:12:354 | [INFO] | | OOBE | DE | | | | 3548 | Effective AdobeCode for: {F6DED2DA-1D20-497E-8810-E745B45DCD28} is {F6DED2DA-1D20-497E-8810-E745B45DCD28}
02/18/16 09:40:12:359 | [INFO] | | OOBE | DE | | | | 3548 | Uninstalling payload
02/18/16 09:40:12:374 | [INFO] | | OOBE | DE | | | | 3548 | Payload AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 09:40:12:438 | [INFO] | | OOBE | DE | | | | 3548 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{F6DED2DA-1D20-497E-8810-E745B45DCD28}.db
02/18/16 09:40:12:439 | [INFO] | | OOBE | DE | | | | 3548 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{F6DED2DA-1D20-497E-8810-E745B45DCD28}.db
02/18/16 09:40:12:441 | [INFO] | | OOBE | DE | | | | 3548 | Physical payload uninstall result:0
02/18/16 09:40:12:490 | [INFO] | | OOBE | DE | | | | 7396 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:40:12:537 | [INFO] | | OOBE | DE | | | | 7396 | :: END TIMER :: [Payload Operation :{F6DED2DA-1D20-497E-8810-E745B45DCD28}] took 660.306 milliseconds (0.660306 seconds) DTR = 109.04 KBPS (0.106485 MBPS)
02/18/16 09:40:13:512 | [INFO] | | OOBE | DE | | | | 7396 | User specified overrideFile:
02/18/16 09:40:13:719 | [INFO] | | OOBE | DE | | | | 7396 | Successfully updated the csu inventory for AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28} return values 0:0
02/18/16 09:40:13:719 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for post-remove for payload AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}
02/18/16 09:40:13:766 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for pre-remove for payload AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}
02/18/16 09:40:13:782 | [INFO] | | OOBE | DE | | | | 7396 | ::START TIMER:: [Payload Operation :{C8DEBB29-3EB0-4B97-B652-4DE482B111BC}]
02/18/16 09:40:13:797 | [INFO] | | OOBE | DE | | | | 8160 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:40:13:797 | [INFO] | | OOBE | DE | | | | 8160 | Installer Operation: PayloadUninstaller
02/18/16 09:40:13:797 | [INFO] | | OOBE | DE | | | | 8160 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}
02/18/16 09:40:14:031 | [INFO] | | OOBE | DE | | | | 8160 | Effective AdobeCode for: {C8DEBB29-3EB0-4B97-B652-4DE482B111BC} is {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}
02/18/16 09:40:14:040 | [INFO] | | OOBE | DE | | | | 8160 | Uninstalling payload
02/18/16 09:40:14:044 | [INFO] | | OOBE | DE | | | | 8160 | Payload AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 09:40:14:091 | [INFO] | | OOBE | DE | | | | 8160 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{C8DEBB29-3EB0-4B97-B652-4DE482B111BC}.db
02/18/16 09:40:14:091 | [INFO] | | OOBE | DE | | | | 8160 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{C8DEBB29-3EB0-4B97-B652-4DE482B111BC}.db
02/18/16 09:40:14:091 | [INFO] | | OOBE | DE | | | | 8160 | Physical payload uninstall result:0
02/18/16 09:40:14:107 | [INFO] | | OOBE | DE | | | | 7396 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:40:14:107 | [INFO] | | OOBE | DE | | | | 7396 | :: END TIMER :: [Payload Operation :{C8DEBB29-3EB0-4B97-B652-4DE482B111BC}] took 316.051 milliseconds (0.316051 seconds) DTR = 240.467 KBPS (0.234831 MBPS)
02/18/16 09:40:14:934 | [INFO] | | OOBE | DE | | | | 7396 | User specified overrideFile:
02/18/16 09:40:15:746 | [INFO] | | OOBE | DE | | | | 7396 | Successfully updated the csu inventory for AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC} return values 0:0
02/18/16 09:40:15:761 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for post-remove for payload AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}
02/18/16 09:40:15:777 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for pre-remove for payload AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}
02/18/16 09:40:15:792 | [INFO] | | OOBE | DE | | | | 7396 | ::START TIMER:: [Payload Operation :{C4196275-B11A-40A1-8727-3C145C8F7D95}]
02/18/16 09:40:15:808 | [INFO] | | OOBE | DE | | | | 7072 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:40:15:808 | [INFO] | | OOBE | DE | | | | 7072 | Installer Operation: PayloadUninstaller
02/18/16 09:40:15:808 | [INFO] | | OOBE | DE | | | | 7072 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {C4196275-B11A-40A1-8727-3C145C8F7D95}
02/18/16 09:40:16:287 | [INFO] | | OOBE | DE | | | | 7072 | Effective AdobeCode for: {C4196275-B11A-40A1-8727-3C145C8F7D95} is {C4196275-B11A-40A1-8727-3C145C8F7D95}
02/18/16 09:40:16:297 | [INFO] | | OOBE | DE | | | | 7072 | Uninstalling payload
02/18/16 09:40:16:307 | [INFO] | | OOBE | DE | | | | 7072 | Payload AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 09:40:16:392 | [INFO] | | OOBE | DE | | | | 7072 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{C4196275-B11A-40A1-8727-3C145C8F7D95}.db
02/18/16 09:40:16:397 | [INFO] | | OOBE | DE | | | | 7072 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{C4196275-B11A-40A1-8727-3C145C8F7D95}.db
02/18/16 09:40:16:397 | [INFO] | | OOBE | DE | | | | 7072 | Physical payload uninstall result:0
02/18/16 09:40:16:422 | [INFO] | | OOBE | DE | | | | 7396 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:40:16:422 | [INFO] | | OOBE | DE | | | | 7396 | :: END TIMER :: [Payload Operation :{C4196275-B11A-40A1-8727-3C145C8F7D95}] took 615.76 milliseconds (0.61576 seconds) DTR = 129.921 KBPS (0.126876 MBPS)
02/18/16 09:40:17:301 | [INFO] | | OOBE | DE | | | | 7396 | User specified overrideFile:
02/18/16 09:40:17:923 | [INFO] | | OOBE | DE | | | | 7396 | Successfully updated the csu inventory for AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95} return values 0:0
02/18/16 09:40:17:933 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for post-remove for payload AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}
02/18/16 09:40:17:953 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for pre-remove for payload Adobe Preview CC_1.1.3_AdobePreview1.0All-win64 1.1.3.0 {27B8946D-664A-4877-A3C9-CE8249CA1D7A}
02/18/16 09:40:17:963 | [INFO] | | OOBE | DE | | | | 7396 | ::START TIMER:: [Payload Operation :{27B8946D-664A-4877-A3C9-CE8249CA1D7A}]
02/18/16 09:40:17:978 | [INFO] | | OOBE | DE | | | | 7036 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:40:17:978 | [INFO] | | OOBE | DE | | | | 7036 | Installer Operation: PayloadUninstaller
02/18/16 09:40:17:978 | [INFO] | | OOBE | DE | | | | 7036 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {27B8946D-664A-4877-A3C9-CE8249CA1D7A}
02/18/16 09:40:18:537 | [INFO] | | OOBE | DE | | | | 7036 | Effective AdobeCode for: {27B8946D-664A-4877-A3C9-CE8249CA1D7A} is {27B8946D-664A-4877-A3C9-CE8249CA1D7A}
02/18/16 09:40:18:547 | [INFO] | | OOBE | DE | | | | 7036 | Uninstalling payload
02/18/16 09:40:18:561 | [INFO] | | OOBE | DE | | | | 7036 | Payload Adobe Preview CC_1.1.3_AdobePreview1.0All-win64 1.1.3.0 {27B8946D-664A-4877-A3C9-CE8249CA1D7A}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 09:40:18:561 | [INFO] | | OOBE | DE | | | | 7036 | Setting file open option to false in the unzipper
02/18/16 09:40:26:770 | [INFO] | | OOBE | DE | | | | 7036 | CustomizedPatch property not found in database
02/18/16 09:40:26:771 | [INFO] | | OOBE | DE | | | | 7036 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{27B8946D-664A-4877-A3C9-CE8249CA1D7A}.db
02/18/16 09:48:15:988 | [ERROR] | | OOBE | DE | | | | 7036 | DF022: New file checksum "㉡㘴ㄴ攷〰搹攲㍦ㅤ挷晡㜰㝥挷㕥挰⤀笠†††††绛䭃牥耀ܞ汬湩偁⁉呒慐捴䅨灰祬㈳潎慃汬匨煥ㄠ㘸⤴搀湯⡥络䭃†耀ܥ†⥽഻ †††眠獳漮⡮攧牲牯Ⱗ映湵瑣潩⡮ 絻㬩绕䭃†耀ܬ഻ഊ ††椠⡴挧楬湥⁴慣敢搠湥敩❤畦据楴湯绮䭃⥥耀ܳ††††慶獷‽敮⁷敗卢捯敫却牥敶⡲灻牯㩴⬠继䭃ⱴ耀ܺ晩䍹楬湥㩴映湵瑣潩⡮⥯笠†††††敲畴湲映污绸䭃 耀݁†素ⱽ映湵瑣潩⡮ ൻ ††††瘠牡漠瑰潩獮㴠笠绱䭃†耀݈††潰瑲›潰瑲ബ †††††栠獯㩴✠㈱⸷⸰⸰✱礊䭃†耀ݏ††栠慥敤獲›ൻ ††††††✠潃湮捥楴湯㨧✠礃䭃摡耀ݖ ††††††✠灕牧摡❥›圧扥潓正瑥Ⱗ†††礄䭃†耀ݝ捥圭扥潓正瑥䬭祥✱›㌧㙥㉢㌶†‴㜱㠠✰ബ ††礝䭃†耀ݤ敓ⵣ敗卢捯敫敋㉹㨧✠㜱†‹恇䑚‹†′戲㜠⁘″礖䭃ധ耀ݫ††††素†††††㭽†††††慶敲ⁱ‽礯䭃爮耀ݲ瑳漨瑰潩獮㬩†††††敲牷瑩⡥圧乪籽⡍✶㬩礠䭃†耀ݹ†敲湥⡤㬩†††††敲湯:sparkles:敲灳湯敳Ⱗ映湵礹䭃⡮耀ހ笠††††††敲瑳瑡獵潃敤献潨汵煥⡬〴⤱礲䭃†耀އ††瀠潲散獳渮硥呴捩⡫畦据楴湯⤨笠†††††祋䭃獷耀ގ獯⡥㬩†††††††潤敮⤨഻ †††††素㬩祌䭃†耀ޕ†⥽഻ †††素㬩††††獷湯:sparkles:潣湮捥楴湯祅䭃湵耀ޜ⡮獷 ൻ ††††搠湯⡥敮⁷牅潲⡲挧湯敮瑣潩神䭃渠耀ޣ獥慴汢獩敨❤⤩഻ †††素㬩††††獷湯祗䭃潲耀ު畦据楴湯⤨笠⥽഻ ††素㬩†††瑩:sparkles:汣敩瑮票䭃戠耀ޱ散瑰摥Ⱗ映湵瑣潩⡮潤敮 ൻ †††瘠牡眠獳㴠渠祡䭃扥耀瑥敓癲牥笨潰瑲›⬫潰瑲敶楲祦汃敩瑮›畦据楴湯祺䭃ൻ耀†††爠瑥牵牴敵഻ †††素ⱽ映湵瑣潩⡮ ൻ祳䭃†耀߆瘠牡漠瑰潩獮㴠笠††††††潰瑲›潰瑲ബ †祴䭃†耀ߍ獯㩴✠㈱⸷⸰⸰✱ബ †††††栠慥敤獲›ൻ †禍䭃†耀ߔ✠潃湮捥楴湯㨧✠灕牧摡❥ബ ††††††✠灕牧禆䭃›耀ߛ潓正瑥Ⱗ†††††††匧捥圭扥潓正瑥䬭祥✱›禟䭃㉢耀ߢ‴㜱㠠✰ബ ††††††✠敓ⵣ敗卢捯敫敋㉹㨧禐䭃†耀ߩ䑚‹†′戲㜠⁘″爯〹ധ †††††素††††禩䭃耀߰†††慶敲ⁱ‽瑨灴爮煥敵瑳漨瑰潩獮㬩†††禢䭃敲耀߷瑩⡥圧乪籽⡍✶㬩†††††敲湥⡤㬩†††离䭃഻耀߾††眠獳漮⡮挧湯敮瑣潩❮畦据楴湯眨⥳笠††禼䭃†耀ࠅ牥業慮整⤨഻ ††††眠獳挮潬敳⤨഻ ††††禵䭃⡥耀ࠌ††††⥽഻ †††眠獳漮⡮攧牲牯Ⱗ映湵瑣潩⡮秎䭃㬩耀ࠓ††⥽഻ഊ ††椠⡴瘧牥晩䍹楬湥⁴敧獴挠楬湥⁴秇䭃湩耀ࠚ湵瑣潩⡮潤敮 ൻ †††瘠牡瘠牥晩䍹楬湥䍴污敬秘䭃慦耀ࠡ††††慶獷‽敮⁷敗卢捯敫却牥敶⡲灻牯㩴科䭃牯耀ࠨ牥晩䍹楬湥㩴映湵瑣潩⡮湩潦 ൻ ††††椠普秪䭃湩耀汵煥⡬栧瑴㩰⼯潦扯牡慢潣❭㬩†††††敶秣䭃汃耀࠶慃汬摥㴠琠畲㭥†††††敲畴湲映污敳഻ ††秤䭃ⱽ耀࠽瑣潩⡮ ൻ ††††瘠牡漠瑰潩獮㴠笠††††秽䭃潰耀ࡄ潰瑲ബ †††††栠獯㩴✠㈱⸷⸰⸰✱ബ †††秶䭃栠耀ࡋ獲›ൻ ††††††✠潃湮捥楴湯㨧✠灕牧摡❥ബ砏䭃†耀ࡒ††✠灕牧摡❥›圧扥潓正瑥Ⱗ†††††††伧砀䭃❮耀࡙瑴㩰⼯潦扯牡慢潣❭ബ ††††††✠敓ⵣ敗卢砙䭃耀ࡠ㨧✠攳戶㘲″㐠ㄠ‷〸Ⱗ†††††††匧捥圭扥砒䭃瑥耀ࡧ✲›ㄧ‷㤠䜠婠㥄†㈠㈠堷㌠⼠㥲✰†††††砫䭃 耀††素഻ ††††瘠牡爠煥㴠栠瑴敲畱獥⡴灯楴砬䭃഻耀ࡵ†††爠煥眮楲整:sparkles:橗絎䵼㘨⤧഻ ††††爠煥攮砥䭃഻耀ࡼ†††爠煥漮⡮爧獥潰獮❥畦据楴湯爨獥 ൻ †砾䭃†耀ࢃ牥晩䍹楬湥䍴污敬桳畯摬戮歯഻ †††††眠砷䭃潬耀ࢊ഻ †††††搠湯⡥㬩†††††⥽഻ †††硈䭃耀††獷湯:sparkles:牥潲❲畦据楴湯⤨笠⥽഻ ††素㬩硁䭃†耀࢘瑩:sparkles:敶楲祦汃敩瑮朠瑥牯杩湩污爠煥敵瑳Ⱗ映湵瑣硚䭃潤耀࢟ൻ †††瘠牡瘠牥晩䍹楬湥䍴污敬‽慦獬㭥†硓䭃†耀ࢦ獷‽敮⁷敗卢捯敫却牥敶⡲灻牯㩴⬠瀫牯ⱴ瘠牥晩硔䭃湥耀ࢭ湵瑣潩⡮湩潦 ൻ ††††椠普敲敨摡牥孳猧硭䭃扥耀ࢴ瑥欭祥✱⹝桳畯摬攮汱:sparkles:攳戶㘲″㐠ㄠ‷〸⤧഻ †硦䭃†耀ࢻ晩䍹楬湥䍴污敬‽牴敵഻ ††††爠瑥牵慦獬硿䭃†耀ࣂ†絽畦据楴湯⤨笠†††††慶灯楴湯‽ൻ硰䭃†耀ࣉ†瀠牯㩴瀠牯ⱴ††††††潨瑳›ㄧ㜲〮〮ㄮⰧ碉䭃†耀࣐††敨摡牥㩳笠†††††††䌧湯敮瑣潩❮›唧碂䭃敤耀ࣗ†††††††唧杰慲敤㨧✠敗卢捯敫❴ബ †††碛䭃†耀ࣞ杩湩㨧✠瑨灴⼺是潯慢扲穡挮浯Ⱗ†††††††碜䭃圭耀ࣥ正瑥䬭祥✱›㌧㙥㉢㌶†‴㜱㠠✰ബ ††††††碕䭃ⵣ耀࣬捯敫敋㉹㨧✠㜱†‹恇䑚‹†′戲㜠⁘″爯〹ധ 碮䭃†耀ࣳ素†††††㭽†††††慶敲ⁱ‽瑨灴爮煥碧䭃漨耀ࣺ獮㬩†††††敲牷瑩⡥圧乪籽⡍✶㬩†††碸䭃敲耀ँ⡤㬩†††††敲湯:sparkles:敲灳湯敳Ⱗ映湵瑣潩⡮敲碱䭃耀ई††††敶楲祦汃敩瑮慃汬摥献潨汵敢漮㭫††磊䭃†耀ए汣獯⡥㬩††††††潤敮⤨഻ ††††素㬩磃䭃†耀ख⥽഻ †††眠獳漮⡮攧牲牯Ⱗ映湵瑣潩⡮ 絻㬩磄䭃†耀झഊ ††椠⡴挧楬湥⁴慣敢搠湥敩獡湹档潲潮獵磝䭃映耀त潩⡮潤敮 ൻ †††瘠牡眠獳㴠渠睥圠扥潓正瑥敓磖䭃笨耀फ›⬫潰瑲敶楲祦汃敩瑮›畦据楴湯漨扣 ൻ †磯䭃†耀ल慦獬⥥഻ †††素ⱽ映湵瑣潩⡮ ൻ ††††瘠磠䭃瑰耀ह㴠笠††††††潰瑲›潰瑲ബ †††††栠獯磹䭃㈱耀ी⸰✱ബ †††††栠慥敤獲›ൻ ††††††✠磲䭃捥耀े㨧✠灕牧摡❥ബ ††††††✠灕牧摡❥›圧扥潓笋䭃Ⱗ耀ॎ††††††伧楲楧❮›栧瑴㩰⼯潦扯牡慢潣❭ബ笌䭃†耀ॕ††✠敓ⵣ敗卢捯敫敋ㅹ㨧✠攳戶㘲″㐠ㄠ‷〸Ⱗ笅䭃†耀ड़†††匧捥圭扥潓正瑥䬭祥✲›ㄧ‷㤠䜠婠㥄†㈠㈠笞䭃㌠耀ॣ✰††††††ൽ ††††素഻ ††††瘠牡笗䭃㴠耀४敲畱獥⡴灯楴湯⥳഻ ††††爠煥眮楲整:sparkles:橗絎笨䭃⤧耀ॱ††††爠煥攮摮⤨഻ ††††爠煥漮⡮爧獥潰獮笡䭃畦耀ॸ湯爨獥 ൻ †††††爠獥献慴畴䍳摯桳畯摬攮笺䭃耀ॿ††††††牰捯獥敮瑸楔正昨湵瑣潩⡮ ൻ †笳䭃†耀আ眠獳挮潬敳⤨഻ ††††††搠湯⡥㬩††††笴䭃⥽耀††††素㬩††††⥽഻ †††眠獳漮⡮挧湯筍䭃潩耀ঔ畦据楴湯眨⥳笠†††††潤敮渨睥䔠牲牯:sparkles:潣湮筆䭃湯耀ছ⁴潮⁴敢攠瑳扡楬桳摥⤧㬩††††⥽഻ †††筟䭃漮耀ঢ牲牯Ⱗ映湵瑣潩⡮ 絻㬩†††⥽഻ഊ ††椠⡴筐䭃湥耀敢愠捣灥整獡湹档潲潮獵祬Ⱗ映湵瑣潩⡮潤敮 筩䭃†耀র瘠牡眠獳㴠渠睥圠扥潓正瑥敓癲牥笨潰瑲›⬫潰瑲筢䭃祦耀ষ瑮›畦据楴湯漨扣 ൻ ††††挠⡢牴敵㬩†筻䭃†耀া畦据楴湯⤨笠†††††慶灯楴湯‽ൻ ††筼䭃†耀㩴瀠牯ⱴ††††††潨瑳›ㄧ㜲〮〮ㄮⰧ††筵䭃†耀ৌ摡牥㩳笠†††††††䌧湯敮瑣潩❮›唧杰慲敤箎䭃†耀††††唧杰慲敤㨧✠敗卢捯敫❴ബ ††††††箇䭃杩耀✠瑨灴⼺是潯慢扲穡挮浯Ⱗ†††††††匧捥圭箘䭃正耀ৡ祥✱›㌧㙥㉢㌶†‴㜱㠠✰ബ ††††††✠敓ⵣ箑䭃捯耀২敋㉹㨧✠㜱†‹恇䑚‹†′戲㜠⁘″爯〹ധ †††箪䭃素耀৯††††㭽†††††慶敲ⁱ‽瑨灴爮煥敵瑳漨箣䭃獮耀৶†††††敲牷瑩⡥圧乪籽⡍✶㬩†††††敲箤䭃⡤耀৽††††⥽഻ †††眠獳漮⡮挧湯敮瑣潩❮畦据箽䭃眨耀†††††獷汣獯⡥㬩†††††潤敮⤨഻ 箶䭃†耀††††獷湯:sparkles:牥潲❲畦据楴湯⤨笠⥽഻ †篏䭃㬩耀†††瑩:sparkles:慨摮敬敭獳条獥瀠獡敳污湯楷桴琠節䭃杰耀ਙ爠煥敵瑳⠠灵牧摡敨摡✩畦据楴湯搨湯⥥笠†篙䭃†耀ਠ獷‽敮⁷敗卢捯敫却牥敶⡲灻牯㩴⬠瀫牯ⱴ瘠牥晩篒䭃湥耀ਧ湵瑣潩⡮⥯笠†††††敲畴湲琠畲㭥††††篫䭃畦耀ਮ湯⤨笠†††††慶灯楴湯‽ൻ †††††篬䭃㩴耀ਵⱴ††††††潨瑳›ㄧ㜲〮〮ㄮⰧ†††††篥䭃摡耀਼笠†††††††䌧湯敮瑣潩❮›唧杰慲敤Ⱗ†篾䭃†耀†唧杰慲敤㨧✠敗卢捯敫❴ബ ††††††✠敓ⵣ篷䭃捯耀敋ㅹ㨧✠攳戶㘲″㐠ㄠ‷〸Ⱗ†††††††匧捥稈䭃潓耀ੑ䬭祥✲›ㄧ‷㤠䜠婠㥄†㈠㈠堷㌠⼠㥲✰ബ ††稁䭃†耀牏杩湩㨧✠瑨灴⼺是潯慢潣❭††††††ൽ 稚䭃†耀഻ ††††瘠牡爠煥㴠栠瑴敲畱獥⡴灯楴湯⥳഻稓䭃†耀੦爠煥眮楲整:sparkles:橗絎䵼㘨⤧഻ ††††爠煥眮楲整渨稔䭃晵耀੭せへⰰ〠㑸ⰸ〠㙸ⰵ〠㙸Ᵽ〠㙸Ᵽ〠㙸ⱦ〠晸嵦戧稭䭃❹耀ੴ ††††爠煥攮摮⤨഻ †††素㬩††††獷稦䭃:sparkles:耀捥楴湯Ⱗ映湵瑣潩⡮獷 ൻ ††††眠湯:sparkles:敭獳稿䭃耀ં楴湯搨瑡⥡笠††††††慤慴献潨汵煥⡬䠧汥稰䭃഻耀ઉ††††眠整浲湩瑡⡥㬩††††††獷汣獯穉䭃耀ઐ††††潤敮⤨഻ ††††素㬩††††⥽഻ 穂䭃†耀ગ漮⡮攧牲牯Ⱗ映湵瑣潩⡮ 絻㬩†††⥽഻ †素穛䭃†耀ઞഊ 搠獥牣扩⡥挧楬湥⁴牰灯牥楴獥Ⱗ映湵瑣潩⡮ 穜䭃†耀થ瀧潲潴潣獩攠灸獯摥Ⱗ映湵瑣潩⡮潤敮 ൻ ††穕䭃眠耀બ渠睥圠扥潓正瑥敓癲牥笨潰瑲›⬫潰瑲ⱽ映湵瑣潩⡮穮䭃 耀ળ†瘠牡眠‽敮⁷敗卢捯敫⡴眧㩳⼯潬慣桬獯㩴‧穧䭃耀潴潣㩬✠楨紧㬩†††⥽഻ ††眠獳漮⡮挧湯敮穸䭃❮耀ુ据楴湯挨楬湥⥴笠††††汣敩瑮瀮潲潴潣桳畯穱䭃汱耀ૈ⤧഻ †††眠獳挮潬敳⤨഻ †††搠湯⡥㬩†窊䭃⥽耀†素㬩††瑩:sparkles:牰瑯捯汯敖獲潩獩攠灸獯摥Ⱗ窃䭃瑣耀潤敮 ൻ ††瘠牡眠獳㴠渠睥圠扥潓正瑥敓癲牥笨窄䭃›耀瑲ⱽ映湵瑣潩⡮ ൻ †††瘠牡眠‽敮⁷敗卢捯窝䭃眧耀潬慣桬獯㩴‧潰瑲灻潲潴潣噬牥楳湯›紸㬩†窖䭃⥽耀૫††眠獳漮⡮挧湯敮瑣潩❮畦据楴湯挨楬湥⥴笠窯䭃†耀敩瑮瀮潲潴潣噬牥楳湯献潨汵煥⡬⤸഻ †††眠窠䭃潬耀ૹ഻ †††搠湯⡥㬩†††⥽഻ †素㬩††窹䭃灵耀剥煥椠桴牯杩湩污爠煥敵瑳漠橢捥❴畦据楴湯窲䭃⥥耀ଇ†††慶獷‽敮⁷敗卢捯敫却牥敶⡲灻牯㩴⬠瀫立䭃耀楴湯⤨笠††††慶獷㴠渠睥(Seq 1864)
02/18/16 09:48:15:988 | [WARN] | | OOBE | DE | | | | 7036 | DW063: Command ARKPatchCommand failed.(Seq 1864)
02/18/16 09:48:33:532 | [INFO] | | OOBE | DE | | | | 7036 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{27B8946D-664A-4877-A3C9-CE8249CA1D7A}.db
02/18/16 09:48:35:187 | [INFO] | | OOBE | DE | | | | 7036 | Physical payload uninstall result:0
02/18/16 09:48:35:283 | [INFO] | | OOBE | DE | | | | 7396 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:48:35:283 | [INFO] | | OOBE | DE | | | | 7396 | :: END TIMER :: [Payload Operation :{27B8946D-664A-4877-A3C9-CE8249CA1D7A}] took 497302 milliseconds (497.302 seconds) DTR = 33.3801 KBPS (0.0325977 MBPS)
02/18/16 09:48:35:925 | [INFO] | | OOBE | DE | | | | 7396 | User specified overrideFile:
02/18/16 09:48:36:773 | [INFO] | | OOBE | DE | | | | 7396 | Successfully updated the csu inventory for Adobe Preview CC_1.1.3_AdobePreview1.0All-win64 1.1.3.0 {27B8946D-664A-4877-A3C9-CE8249CA1D7A} return values 0:0
02/18/16 09:48:36:783 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for post-remove for payload Adobe Preview CC_1.1.3_AdobePreview1.0All-win64 1.1.3.0 {27B8946D-664A-4877-A3C9-CE8249CA1D7A}
02/18/16 09:48:36:868 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for pre-remove for payload Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}
02/18/16 09:48:36:883 | [INFO] | | OOBE | DE | | | | 7396 | ::START TIMER:: [Payload Operation :{A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}]
02/18/16 09:48:36:896 | [INFO] | | OOBE | DE | | | | 3512 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:48:36:896 | [INFO] | | OOBE | DE | | | | 3512 | Installer Operation: PayloadUninstaller
02/18/16 09:48:36:896 | [INFO] | | OOBE | DE | | | | 3512 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}
02/18/16 09:48:38:018 | [INFO] | | OOBE | DE | | | | 3512 | Effective AdobeCode for: {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3} is {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}
02/18/16 09:48:38:027 | [INFO] | | OOBE | DE | | | | 3512 | Uninstalling payload
02/18/16 09:48:38:040 | [INFO] | | OOBE | DE | | | | 3512 | Payload Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 09:48:38:106 | [INFO] | | OOBE | DE | | | | 3512 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}.db
02/18/16 09:52:16:007 | [INFO] | | OOBE | DE | | | | 3512 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}.db
02/18/16 09:52:22:885 | [INFO] | | OOBE | DE | | | | 3512 | Physical payload uninstall result:0
02/18/16 09:52:22:901 | [INFO] | | OOBE | DE | | | | 7396 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:52:22:901 | [INFO] | | OOBE | DE | | | | 7396 | :: END TIMER :: [Payload Operation :{A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}] took 226015 milliseconds (226.015 seconds) DTR = 64.7746 KBPS (0.0632564 MBPS)
02/18/16 09:52:24:238 | [INFO] | | OOBE | DE | | | | 7396 | User specified overrideFile:
02/18/16 09:52:25:733 | [INFO] | | OOBE | DE | | | | 7396 | Successfully updated the csu inventory for Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3} return values 0:0
02/18/16 09:52:25:744 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for post-remove for payload Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}
02/18/16 09:52:25:764 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for pre-remove for payload Adobe Photoshop CC 2015 Support_16.1.2_AdobePhotoshop16-Support 16.1.2.0 {4A117739-A3A4-4E1A-8F5A-82CB1958794F}
02/18/16 09:52:25:781 | [INFO] | | OOBE | DE | | | | 7396 | ::START TIMER:: [Payload Operation :{4A117739-A3A4-4E1A-8F5A-82CB1958794F}]
02/18/16 09:52:25:794 | [INFO] | | OOBE | DE | | | | 7956 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:52:25:794 | [INFO] | | OOBE | DE | | | | 7956 | Installer Operation: PayloadUninstaller
02/18/16 09:52:25:795 | [INFO] | | OOBE | DE | | | | 7956 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:52:25:795 | [INFO] | | OOBE | DE | | | | 7956 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {4A117739-A3A4-4E1A-8F5A-82CB1958794F}
02/18/16 09:52:25:935 | [INFO] | | OOBE | DE | | | | 7956 | Effective AdobeCode for: {4A117739-A3A4-4E1A-8F5A-82CB1958794F} is {4A117739-A3A4-4E1A-8F5A-82CB1958794F}
02/18/16 09:52:25:944 | [INFO] | | OOBE | DE | | | | 7956 | Uninstalling payload
02/18/16 09:52:26:001 | [INFO] | | OOBE | DE | | | | 7956 | Payload Adobe Photoshop CC 2015 Support_16.1.2_AdobePhotoshop16-Support 16.1.2.0 {4A117739-A3A4-4E1A-8F5A-82CB1958794F}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 09:52:26:068 | [INFO] | | OOBE | DE | | | | 7956 | Setting file open option to false in the unzipper
02/18/16 09:52:26:178 | [INFO] | | OOBE | DE | | | | 7956 | CustomizedPatch property not found in database
02/18/16 09:52:26:179 | [INFO] | | OOBE | DE | | | | 7956 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{4A117739-A3A4-4E1A-8F5A-82CB1958794F}.db
02/18/16 09:52:26:592 | [INFO] | | OOBE | DE | | | | 7956 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{4A117739-A3A4-4E1A-8F5A-82CB1958794F}.db
02/18/16 09:52:26:595 | [INFO] | | OOBE | DE | | | | 7956 | Physical payload uninstall result:0
02/18/16 09:52:26:694 | [INFO] | | OOBE | DE | | | | 7396 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:52:26:694 | [INFO] | | OOBE | DE | | | | 7396 | :: END TIMER :: [Payload Operation :{4A117739-A3A4-4E1A-8F5A-82CB1958794F}] took 913.327 milliseconds (0.913327 seconds) DTR = 560.588 KBPS (0.547449 MBPS)
02/18/16 09:52:27:391 | [INFO] | | OOBE | DE | | | | 7396 | User specified overrideFile:
02/18/16 09:52:27:819 | [INFO] | | OOBE | DE | | | | 7396 | Successfully updated the csu inventory for Adobe Photoshop CC 2015 Support_16.1.2_AdobePhotoshop16-Support 16.1.2.0 {4A117739-A3A4-4E1A-8F5A-82CB1958794F} return values 0:0
02/18/16 09:52:27:829 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for post-remove for payload Adobe Photoshop CC 2015 Support_16.1.2_AdobePhotoshop16-Support 16.1.2.0 {4A117739-A3A4-4E1A-8F5A-82CB1958794F}
02/18/16 09:52:27:884 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for pre-remove for payload Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}
02/18/16 09:52:27:900 | [INFO] | | OOBE | DE | | | | 7396 | ::START TIMER:: [Payload Operation :{3FB7A108-368A-4849-A3F3-69571BAAC457}]
02/18/16 09:52:27:912 | [INFO] | | OOBE | DE | | | | 5280 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:52:27:912 | [INFO] | | OOBE | DE | | | | 5280 | Installer Operation: PayloadUninstaller
02/18/16 09:52:27:913 | [INFO] | | OOBE | DE | | | | 5280 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:52:27:913 | [INFO] | | OOBE | DE | | | | 5280 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {3FB7A108-368A-4849-A3F3-69571BAAC457}
02/18/16 09:52:28:366 | [INFO] | | OOBE | DE | | | | 5280 | Effective AdobeCode for: {3FB7A108-368A-4849-A3F3-69571BAAC457} is {3FB7A108-368A-4849-A3F3-69571BAAC457}
02/18/16 09:52:28:375 | [INFO] | | OOBE | DE | | | | 5280 | Uninstalling payload
02/18/16 09:52:28:388 | [INFO] | | OOBE | DE | | | | 5280 | Payload Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 09:52:28:495 | [INFO] | | OOBE | DE | | | | 5280 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{3FB7A108-368A-4849-A3F3-69571BAAC457}.db
02/18/16 09:52:36:289 | [INFO] | | OOBE | DE | | | | 5280 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{3FB7A108-368A-4849-A3F3-69571BAAC457}.db
02/18/16 09:52:36:463 | [INFO] | | OOBE | DE | | | | 5280 | Physical payload uninstall result:0
02/18/16 09:52:36:473 | [INFO] | | OOBE | DE | | | | 7396 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:52:36:473 | [INFO] | | OOBE | DE | | | | 7396 | :: END TIMER :: [Payload Operation :{3FB7A108-368A-4849-A3F3-69571BAAC457}] took 8573.77 milliseconds (8.57377 seconds) DTR = 756.26 KBPS (0.738535 MBPS)
02/18/16 09:52:37:578 | [INFO] | | OOBE | DE | | | | 7396 | User specified overrideFile:
02/18/16 09:52:38:188 | [INFO] | | OOBE | DE | | | | 7396 | Successfully updated the csu inventory for Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457} return values 0:0
02/18/16 09:52:38:198 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for post-remove for payload Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}
02/18/16 09:52:38:244 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for pre-remove for payload Camera Profiles Installer_9.4_AdobeCameraRawProfile8.0All 9.4.0.0 {03B147C3-2412-4DE8-80F9-3EB977421EF2}
02/18/16 09:52:38:284 | [INFO] | | OOBE | DE | | | | 7396 | ::START TIMER:: [Payload Operation :{03B147C3-2412-4DE8-80F9-3EB977421EF2}]
02/18/16 09:52:38:298 | [INFO] | | OOBE | DE | | | | 6444 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:52:38:298 | [INFO] | | OOBE | DE | | | | 6444 | Installer Operation: PayloadUninstaller
02/18/16 09:52:38:298 | [INFO] | | OOBE | DE | | | | 6444 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {03B147C3-2412-4DE8-80F9-3EB977421EF2}
02/18/16 09:52:38:467 | [INFO] | | OOBE | DE | | | | 6444 | Effective AdobeCode for: {03B147C3-2412-4DE8-80F9-3EB977421EF2} is {03B147C3-2412-4DE8-80F9-3EB977421EF2}
02/18/16 09:52:38:477 | [INFO] | | OOBE | DE | | | | 6444 | Uninstalling payload
02/18/16 09:52:38:684 | [INFO] | | OOBE | DE | | | | 6444 | Payload Camera Profiles Installer_9.4_AdobeCameraRawProfile8.0All 9.4.0.0 {03B147C3-2412-4DE8-80F9-3EB977421EF2}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 09:52:38:712 | [INFO] | | OOBE | DE | | | | 6444 | Setting file open option to false in the unzipper
02/18/16 09:52:40:249 | [INFO] | | OOBE | DE | | | | 6444 | CustomizedPatch property not found in database
02/18/16 09:52:40:250 | [INFO] | | OOBE | DE | | | | 6444 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{03B147C3-2412-4DE8-80F9-3EB977421EF2}.db
02/18/16 09:54:25:586 | [INFO] | | OOBE | DE | | | | 6444 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{03B147C3-2412-4DE8-80F9-3EB977421EF2}.db
02/18/16 09:54:27:506 | [INFO] | | OOBE | DE | | | | 6444 | Physical payload uninstall result:0
02/18/16 09:54:27:586 | [INFO] | | OOBE | DE | | | | 7396 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:54:27:586 | [INFO] | | OOBE | DE | | | | 7396 | :: END TIMER :: [Payload Operation :{03B147C3-2412-4DE8-80F9-3EB977421EF2}] took 109299 milliseconds (109.299 seconds) DTR = 2082.9 KBPS (2.03409 MBPS)
02/18/16 09:54:28:120 | [INFO] | | OOBE | DE | | | | 7396 | User specified overrideFile:
02/18/16 09:54:28:338 | [INFO] | | OOBE | DE | | | | 7396 | Successfully updated the csu inventory for Camera Profiles Installer_9.4_AdobeCameraRawProfile8.0All 9.4.0.0 {03B147C3-2412-4DE8-80F9-3EB977421EF2} return values 0:0
02/18/16 09:54:28:348 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for post-remove for payload Camera Profiles Installer_9.4_AdobeCameraRawProfile8.0All 9.4.0.0 {03B147C3-2412-4DE8-80F9-3EB977421EF2}
02/18/16 09:54:28:427 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for pre-remove for payload Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}
02/18/16 09:54:28:489 | [INFO] | | OOBE | DE | | | | 7396 | ::START TIMER:: [Payload Operation :{56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}]
02/18/16 09:54:28:687 | [INFO] | | OOBE | DE | | | | 2232 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:54:28:687 | [INFO] | | OOBE | DE | | | | 2232 | Installer Operation: PayloadUninstaller
02/18/16 09:54:28:687 | [INFO] | | OOBE | DE | | | | 2232 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}
02/18/16 09:54:29:168 | [INFO] | | OOBE | DE | | | | 2232 | Effective AdobeCode for: {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10} is {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}
02/18/16 09:54:29:177 | [INFO] | | OOBE | DE | | | | 2232 | Uninstalling payload
02/18/16 09:54:29:190 | [INFO] | | OOBE | DE | | | | 2232 | Payload Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 09:54:29:305 | [INFO] | | OOBE | DE | | | | 2232 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}.db
02/18/16 09:56:21:525 | [INFO] | | OOBE | DE | | | | 2232 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}.db
02/18/16 09:56:24:473 | [INFO] | | OOBE | DE | | | | 2232 | Physical payload uninstall result:0
02/18/16 09:56:24:519 | [INFO] | | OOBE | DE | | | | 7396 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:56:24:519 | [INFO] | | OOBE | DE | | | | 7396 | :: END TIMER :: [Payload Operation :{56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}] took 116029 milliseconds (116.029 seconds) DTR = 3053.07 KBPS (2.98151 MBPS)
02/18/16 09:56:25:060 | [INFO] | | OOBE | DE | | | | 7396 | User specified overrideFile:
02/18/16 09:56:25:657 | [INFO] | | OOBE | DE | | | | 7396 | Successfully updated the csu inventory for Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10} return values 0:0
02/18/16 09:56:25:667 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for post-remove for payload Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}
02/18/16 09:56:25:718 | [INFO] | | OOBE | DE | | | | 7396 | Calling the custom action code for pre-remove for payload 9.0.0.61 CommonUninstall
02/18/16 09:56:25:732 | [INFO] | | OOBE | DE | | | | 7396 | ::START TIMER:: [Payload Operation :CommonUninstall]
02/18/16 09:56:25:745 | [INFO] | | OOBE | DE | | | | 7096 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:56:25:745 | [INFO] | | OOBE | DE | | | | 7096 | Installer Operation: PayloadUninstaller
02/18/16 09:56:25:745 | [INFO] | | OOBE | DE | | | | 7096 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: CommonUninstall
02/18/16 09:56:25:749 | [INFO] | | OOBE | DE | | | | 7096 | Effective AdobeCode for: CommonUninstall is CommonUninstall
02/18/16 09:56:25:758 | [INFO] | | OOBE | DE | | | | 7096 | Uninstalling payload
02/18/16 09:56:25:770 | [INFO] | | OOBE | DE | | | | 7096 | Payload 9.0.0.61 CommonUninstall: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 09:56:25:812 | [INFO] | | OOBE | DE | | | | 7096 | INSTALLDIR property not found in database
02/18/16 09:56:25:813 | [INFO] | | OOBE | DE | | | | 7096 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\CommonUninstall.db
02/18/16 09:56:25:814 | [INFO] | | OOBE | DE | | | | 7096 | UninstallSeq property not found in database
02/18/16 09:56:25:826 | [ERROR] | | OOBE | DE | | | | 7096 | DF037: Unable to delete directory "C:\Users\Lenovo\AppData\Roaming\Adobe\Adobe Photoshop CC 2015". Error 145 The directory is not empty.. Check and correct folder & parent directory permissions and then try again.(Seq 1)
02/18/16 09:56:25:826 | [WARN] | | OOBE | DE | | | | 7096 | DW063: Command ARKDeleteDirectoryCommand failed.(Seq 1)
02/18/16 09:56:25:827 | [INFO] | | OOBE | DE | | | | 7096 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\CommonUninstall.db
02/18/16 09:56:25:827 | [INFO] | | OOBE | DE | | | | 7096 | Physical payload uninstall result:0
02/18/16 09:56:25:845 | [INFO] | | OOBE | DE | | | | 7396 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:56:25:845 | [INFO] | | OOBE | DE | | | | 7396 | :: END TIMER :: [Payload Operation :CommonUninstall] took 112.69 milliseconds (0.11269 seconds)
02/18/16 09:56:25:852 | [INFO] | | OOBE | DE | | | | 7396 | User specified overrideFile:
02/18/16 09:56:25:860 | [INFO] | | OOBE | DE | | | | 7396 | The csu inventory was not updated for payload 9.0.0.61 CommonUninstall, value of local var is -1
02/18/16 09:56:25:861 | [INFO] | | OOBE | DE | | | | 7396 | Calling the ROLLBACK custom action code for pre-remove for payload 9.0.0.61 CommonUninstall
02/18/16 09:56:25:874 | [INFO] | | OOBE | DE | | | | 7396 | No operation. We're done:
02/18/16 09:56:25:877 | [INFO] | | OOBE | DE | | | | 7396 | Updating driver data - Action: Remove driver entry
02/18/16 09:56:25:898 | [INFO] | | OOBE | DE | | | | 7396 | Updating driver data successful. Driver entry was removed. ARP estimated size 41368KB
02/18/16 09:56:28:568 | [INFO] | | OOBE | DE | | | | 7396 | Total components installed: 0
02/18/16 09:56:28:568 | [INFO] | | OOBE | DE | | | | 7396 | Total components repaired: 0
02/18/16 09:56:28:568 | [INFO] | | OOBE | DE | | | | 7396 | Successfully removed 23 components:
02/18/16 09:56:28:568 | [INFO] | | OOBE | DE | | | | 7396 | - Camera Profiles Installer_9.4_AdobeCameraRawProfile8.0All
02/18/16 09:56:28:568 | [INFO] | | OOBE | DE | | | | 7396 | - Export Assets 2 (64 bit)
02/18/16 09:56:28:568 | [INFO] | | OOBE | DE | | | | 7396 | - Adobe Preview CC_1.1.3_AdobePreview1.0All-win64
02/18/16 09:56:28:568 | [INFO] | | OOBE | DE | | | | 7396 | - Export Assets 2 (64 bit)_2.4_AdobeExportAssets2.0All-x64
02/18/16 09:56:28:568 | [INFO] | | OOBE | DE | | | | 7396 | - Photoshop Camera Raw 8
02/18/16 09:56:28:568 | [INFO] | | OOBE | DE | | | | 7396 | - Adobe Photoshop CC 2015 Support
02/18/16 09:56:28:568 | [INFO] | | OOBE | DE | | | | 7396 | - Adobe Photoshop CC 2015 Support_16.1.2_AdobePhotoshop16-Support
02/18/16 09:56:28:568 | [INFO] | | OOBE | DE | | | | 7396 | - Microsoft Visual C++ 2013 Redistributable Package (x64)
02/18/16 09:56:28:569 | [INFO] | | OOBE | DE | | | | 7396 | - AdobeColorPhotoshop CC
02/18/16 09:56:28:569 | [INFO] | | OOBE | DE | | | | 7396 | - Photoshop Camera Raw 8 (64 bit)
02/18/16 09:56:28:569 | [INFO] | | OOBE | DE | | | | 7396 | - Microsoft Visual C++ 2013 Redistributable Package (x86)
02/18/16 09:56:28:569 | [INFO] | | OOBE | DE | | | | 7396 | - Adobe Photoshop CC 2015 Core
02/18/16 09:56:28:569 | [INFO] | | OOBE | DE | | | | 7396 | - Photoshop Camera Raw 8_9.4_AdobeCameraRaw8.0All
02/18/16 09:56:28:569 | [INFO] | | OOBE | DE | | | | 7396 | - AdobeColorJA CC
02/18/16 09:56:28:569 | [INFO] | | OOBE | DE | | | | 7396 | - Adobe Preview CC
02/18/16 09:56:28:569 | [INFO] | | OOBE | DE | | | | 7396 | - AdobeColorNA CC
02/18/16 09:56:28:569 | [INFO] | | OOBE | DE | | | | 7396 | - Photoshop Camera Raw 8 (64 bit)_9.4_AdobeCameraRaw8.0All-x64
02/18/16 09:56:28:569 | [INFO] | | OOBE | DE | | | | 7396 | - AdobeColorCommonSetCMYK CC
02/18/16 09:56:28:569 | [INFO] | | OOBE | DE | | | | 7396 | - AdobeColorCommonSetRGB CC
02/18/16 09:56:28:569 | [INFO] | | OOBE | DE | | | | 7396 | - AdobeColorVideoProfilesCS CC
02/18/16 09:56:28:569 | [INFO] | | OOBE | DE | | | | 7396 | - Adobe Photoshop CC 2015 Core_16.1.2_AdobePhotoshop16-Core_x64
02/18/16 09:56:28:569 | [INFO] | | OOBE | DE | | | | 7396 | - AdobeColorEU CC
02/18/16 09:56:28:570 | [INFO] | | OOBE | DE | | | | 7396 | Call PostSession Custom Hook
02/18/16 09:56:28:600 | [INFO] | | OOBE | DE | | | | 7396 | Begin cleaning up local media db.
02/18/16 09:56:34:449 | [INFO] | | OOBE | DE | | | | 7396 | Done cleaning up local media db.
02/18/16 09:56:34:449 | [INFO] | | OOBE | DE | | | | 7396 | :: END TIMER :: [Total Timer] took 1.94183e+006 milliseconds (1941.83 seconds) DTR = 1320.36 KBPS (1.28941 MBPS)
02/18/16 09:56:35:449 | [INFO] | | OOBE | DE | | | | 7396 | Uninstalling AAM
02/18/16 09:56:35:767 | [INFO] | | OOBE | DE | | | | 7396 | AAM Uninstall Status: 1 and 0
02/18/16 09:56:35:767 | [INFO] | | OOBE | DE | | | | 7396 | Exit Code: 0 - No error.
02/18/16 09:56:35:797 | [INFO] | | OOBE | DE | | | | 7396 | Please see specific errors for troubleshooting. For example, ERROR: DF022, DF037 ...
02/18/16 09:56:35:800 | [INFO] | | OOBE | DE | | | | 7396 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 09:56:35:800 | [INFO] | | OOBE | DE | | | | 7396 | END - Installer Session
02/18/16 15:28:18:499 | [INFO] | | OOBE | DE | | | | 4836 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:28:18:499 | [INFO] | | OOBE | DE | | | | 4836 | START - Installer Session
02/18/16 15:28:18:521 | [INFO] | | OOBE | DE | | | | 4836 | RIBS version: 9.0.0.61
02/18/16 15:28:18:523 | [INFO] | | OOBE | DE | | | | 4836 | Win OS version: 6.1.0.0 64 bit Type: 1
02/18/16 15:28:18:524 | [INFO] | | OOBE | DE | | | | 4836 | ::START TIMER:: [Total Timer]
02/18/16 15:28:18:524 | [INFO] | | OOBE | DE | | | | 4836 | CHECK: Single instance running
02/18/16 15:28:18:524 | [INFO] | | OOBE | DE | | | | 4836 | CHECK : Credentials
02/18/16 15:28:18:524 | [INFO] | | OOBE | DE | | | | 4836 | Load Deployment File
02/18/16 15:28:18:524 | [INFO] | | OOBE | DE | | | | 4836 | CHECK : Another Native OS installer already running
02/18/16 15:28:18:524 | [INFO] | | OOBE | DE | | | | 4836 | Create Required Folders
02/18/16 15:28:18:524 | [INFO] | | OOBE | DE | | | | 4836 | Assuming install mode
02/18/16 15:28:18:524 | [INFO] | | OOBE | DE | | | | 4836 | Looking up install source path
02/18/16 15:28:18:524 | [INFO] | | OOBE | DE | | | | 4836 | Sync Media DB ...
02/18/16 15:28:18:524 | [INFO] | | OOBE | DE | | | | 4836 | ::START TIMER:: [Sync Media DB]
02/18/16 15:28:18:524 | [INFO] | | OOBE | DE | | | | 4836 | Pre check media db sync
02/18/16 15:28:18:524 | [INFO] | | OOBE | DE | | | | 4836 | End of Pre check media db sync. Exit code: 0
02/18/16 15:28:18:524 | [INFO] | | OOBE | DE | | | | 4836 | :: END TIMER :: [Sync Media DB] took 4743.56 milliseconds (4.74356 seconds) DTR = 880.352 KBPS (0.859719 MBPS)
02/18/16 15:28:18:524 | [INFO] | | OOBE | DE | | | | 4836 | Ready to initialize session to start with ...
02/18/16 15:28:18:525 | [INFO] | | OOBE | DE | | | | 4836 | ::START TIMER:: [CreatePayloadSession]
02/18/16 15:28:18:525 | [INFO] | | OOBE | DE | | | | 4836 | -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
02/18/16 15:28:18:525 | [INFO] | | OOBE | DE | | | | 4836 | Updated source path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015
02/18/16 15:28:18:541 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {00F35A9A-C859-4F6E-8C4F-70A7239207FF}
02/18/16 15:28:18:542 | [INFO] | | OOBE | DE | | | | 4836 | Ignoring original data since install source is local
02/18/16 15:28:18:542 | [INFO] | | OOBE | DE | | | | 4836 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-nb_NO_x64\Install.db
02/18/16 15:28:18:542 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA}
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-uk_UA_x64\Install.db
02/18/16 15:28:18:543 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {0CA9067E-B7E0-4C7A-BA40-987AF967A05D}
02/18/16 15:28:18:543 | [INFO] | | OOBE | DE | | | | 4836 | Ignoring original data since install source is local
02/18/16 15:28:18:543 | [INFO] | | OOBE | DE | | | | 4836 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-en_IL_x64\Install.db
02/18/16 15:28:18:543 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {0D30F03E-27D9-41F8-AF26-9F1801C2AE28}
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-fr_MA_x64\Install.db
02/18/16 15:28:18:544 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {18844AF8-051C-4227-9BE1-CA06F4364F9C}
02/18/16 15:28:18:544 | [INFO] | | OOBE | DE | | | | 4836 | Ignoring original data since install source is local
02/18/16 15:28:18:544 | [INFO] | | OOBE | DE | | | | 4836 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-zh_TW_x64\Install.db
02/18/16 15:28:18:544 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {1B7AE611-4C93-47FC-951F-0BD9839AB72B}
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-sv_SE_x64\Install.db
02/18/16 15:28:18:544 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {2060E7ED-C473-4A38-877F-C844E81B64F3}
02/18/16 15:28:18:545 | [INFO] | | OOBE | DE | | | | 4836 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-nl_NL_x64\Install.db
02/18/16 15:28:18:545 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4}
02/18/16 15:28:18:545 | [INFO] | | OOBE | DE | | | | 4836 | Ignoring original data since install source is local
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-es_MX_x64\Install.db
02/18/16 15:28:18:545 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {27375F7C-0789-4FEA-889E-41BF12AC3140}
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeExportAssets2.0All-x64\Install.db
02/18/16 15:28:18:545 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {3875BF24-5D9A-494A-A4FA-7AC70F56EC88}
02/18/16 15:28:18:546 | [INFO] | | OOBE | DE | | | | 4836 | Ignoring original data since install source is local
02/18/16 15:28:18:546 | [INFO] | | OOBE | DE | | | | 4836 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-zh_CN_x64\Install.db
02/18/16 15:28:18:546 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {3E272A93-C06B-4206-AD02-0EBE02535E20}
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\Microsoft VC 2012 Redist (x64)\vcredist_x64.exe
02/18/16 15:28:18:546 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {3E7FC757-D497-4C89-A935-7D38E2164E85}
02/18/16 15:28:18:547 | [INFO] | | OOBE | DE | | | | 4836 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeCameraRaw8.0All\Install.db
02/18/16 15:28:18:547 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {3FB7A108-368A-4849-A3F3-69571BAAC457}
02/18/16 15:28:18:547 | [INFO] | | OOBE | DE | | | | 4836 | Ignoring original data since install source is local
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-Support\Install.db
02/18/16 15:28:18:547 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {4A0115A5-CA14-4EA1-9896-2F161B5144B9}
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-pt_BR_x64\Install.db
02/18/16 15:28:18:547 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}
02/18/16 15:28:18:548 | [INFO] | | OOBE | DE | | | | 4836 | Ignoring original data since install source is local
02/18/16 15:28:18:548 | [INFO] | | OOBE | DE | | | | 4836 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\Microsoft VC 2013 Redist (x64)\vcredist_x64.exe
02/18/16 15:28:18:548 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4}
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-en_GB_x64\Install.db
02/18/16 15:28:18:548 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {52D57F95-000A-4922-BB31-C6A936F4FD7D}
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorJA_Recommended5_0-mul\Install.db
02/18/16 15:28:18:549 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {5309436A-D12F-437D-B7A4-BF136E17139C}
02/18/16 15:28:18:549 | [INFO] | | OOBE | DE | | | | 4836 | Ignoring original data since install source is local
02/18/16 15:28:18:549 | [INFO] | | OOBE | DE | | | | 4836 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-ko_KR_x64\Install.db
02/18/16 15:28:18:549 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\Microsoft VC 2010 Redist (x64)\vcredist_x64.exe
02/18/16 15:28:18:549 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {55B82130-18F9-11E2-8D43-00215AEA26C9}
02/18/16 15:28:18:550 | [INFO] | | OOBE | DE | | | | 4836 | Ignoring original data since install source is local
02/18/16 15:28:18:550 | [INFO] | | OOBE | DE | | | | 4836 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\Microsoft VC 2010 Redist (x86)\vcredist_x86.exe
02/18/16 15:28:18:550 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeCameraRawProfile8.0All\Install.db
02/18/16 15:28:18:550 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {5C5D62C9-91C6-415E-857E-9130C0F52C66}
02/18/16 15:28:18:551 | [INFO] | | OOBE | DE | | | | 4836 | Ignoring original data since install source is local
02/18/16 15:28:18:551 | [INFO] | | OOBE | DE | | | | 4836 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorPhotoshop5_0-mul\Install.db
02/18/16 15:28:18:551 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeCameraRaw8.0All-x64\Install.db
02/18/16 15:28:18:551 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {636D196A-789E-455D-825E-3FA79F67D446}
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\Microsoft VC 2013 Redist (x86)\vcredist_x86.exe
02/18/16 15:28:18:552 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {644DC0CB-E8C9-4508-B99D-8747C6172621}
02/18/16 15:28:18:552 | [INFO] | | OOBE | DE | | | | 4836 | Ignoring original data since install source is local
02/18/16 15:28:18:552 | [INFO] | | OOBE | DE | | | | 4836 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-es_ES_x64\Install.db
02/18/16 15:28:18:552 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {69C13F4A-83B3-42F4-912C-C99F1442F439}
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-de_DE_x64\Install.db
02/18/16 15:28:18:552 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {6E14FFAB-83F4-4CB7-87A2-703F6F20487A}
02/18/16 15:28:18:553 | [INFO] | | OOBE | DE | | | | 4836 | Ignoring original data since install source is local
02/18/16 15:28:18:553 | [INFO] | | OOBE | DE | | | | 4836 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-ru_RU_x64\Install.db
02/18/16 15:28:18:553 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {6E7A3076-3056-492F-966F-1EA4FDCE5FA8}
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-en_AE_x64\Install.db
02/18/16 15:28:18:553 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {72405B80-A3DD-4BB2-A8C4-A90BC7BA50FF}
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorNA_ExtraSettings5_0-mul\Install.db
02/18/16 15:28:18:553 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {7433F860-160E-4024-8218-892D796972A6}
02/18/16 15:28:18:554 | [INFO] | | OOBE | DE | | | | 4836 | Ignoring original data since install source is local
02/18/16 15:28:18:554 | [INFO] | | OOBE | DE | | | | 4836 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-fr_CA_x64\Install.db
02/18/16 15:28:18:554 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {7787331E-D646-4CA4-ADCB-B264CC156D7D}
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-cs_CZ_x64\Install.db
02/18/16 15:28:18:554 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {778CE554-471C-4605-A600-852C976A4DC5}
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-ja_JP_x64\Install.db
02/18/16 15:28:18:555 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 15:28:18:555 | [INFO] | | OOBE | DE | | | | 4836 | Ignoring original data since install source is local
02/18/16 15:28:18:555 | [INFO] | | OOBE | DE | | | | 4836 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-Core_x64\Install.db
02/18/16 15:28:18:555 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {873BE68F-480F-49A6-9649-F98CAB056AFC}
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\Microsoft VC 2012 Redist (x86)\vcredist_x86.exe
02/18/16 15:28:18:555 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0}
02/18/16 15:28:18:556 | [INFO] | | OOBE | DE | | | | 4836 | Ignoring original data since install source is local
02/18/16 15:28:18:556 | [INFO] | | OOBE | DE | | | | 4836 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-pl_PL_x64\Install.db
02/18/16 15:28:18:556 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {960F21E4-EBDC-4A3E-80E9-C28D8A593F66}
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-it_IT_x64\Install.db
02/18/16 15:28:18:556 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {98D6FC60-7908-474A-A598-0D7A7BFEF2C2}
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-hu_HU_x64\Install.db
02/18/16 15:28:18:556 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {9E9EB9FD-FDE8-487A-A41C-7713DA91AC89}
02/18/16 15:28:18:557 | [INFO] | | OOBE | DE | | | | 4836 | Ignoring original data since install source is local
02/18/16 15:28:18:557 | [INFO] | | OOBE | DE | | | | 4836 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorEU_Recommended5_0-mul\Install.db
02/18/16 15:28:18:557 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorJA_ExtraSettings5_0-mul\Install.db
02/18/16 15:28:18:557 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePreview1.0All-win64\Install.db
02/18/16 15:28:18:557 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}
02/18/16 15:28:18:558 | [INFO] | | OOBE | DE | | | | 4836 | Ignoring original data since install source is local
02/18/16 15:28:18:558 | [INFO] | | OOBE | DE | | | | 4836 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorNA_Recommended5_0-mul\Install.db
02/18/16 15:28:18:558 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {B75FB41B-E3E2-4B9F-93F7-62D982857374}
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-fr_FR_x64\Install.db
02/18/16 15:28:18:558 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {BED85F42-B42C-4A91-946B-A928824C48A1}
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-tr_TR_x64\Install.db
02/18/16 15:28:18:559 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {C4196275-B11A-40A1-8727-3C145C8F7D95}
02/18/16 15:28:18:559 | [INFO] | | OOBE | DE | | | | 4836 | Ignoring original data since install source is local
02/18/16 15:28:18:559 | [INFO] | | OOBE | DE | | | | 4836 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorCommonSetCMYK5_0-mul\Install.db
02/18/16 15:28:18:559 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {C43757D2-2F7F-41B4-9764-0FD8318DD860}
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-en_US_x64\Install.db
02/18/16 15:28:18:559 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorCommonSetRGB5_0-mul\Install.db
02/18/16 15:28:18:560 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {CE9B1B00-0421-4701-9698-1C14646D6D94}
02/18/16 15:28:18:560 | [INFO] | | OOBE | DE | | | | 4836 | Ignoring original data since install source is local
02/18/16 15:28:18:560 | [INFO] | | OOBE | DE | | | | 4836 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeVideoProfilesCS5_0-mul\Install.db
02/18/16 15:28:18:560 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {F5D14B6C-DA16-4031-9EB8-AF0728550AFC}
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-da_DK_x64\Install.db
02/18/16 15:28:18:560 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {F6DED2DA-1D20-497E-8810-E745B45DCD28}
02/18/16 15:28:18:561 | [INFO] | | OOBE | DE | | | | 4836 | Ignoring original data since install source is local
02/18/16 15:28:18:561 | [INFO] | | OOBE | DE | | | | 4836 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorEU_ExtraSettings5_0-mul\Install.db
02/18/16 15:28:18:561 | [INFO] | | OOBE | DE | | | | 4836 | Updating media info for: {FD8B8694-1044-4481-A5D9-4740A46BBC3B}
Path: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-fi_FI_x64\Install.db
02/18/16 15:28:18:561 | [INFO] | | OOBE | DE | | | | 4836 | -------------------- END - Updating Media Sources - END --------------------
02/18/16 15:28:18:781 | [INFO] | | OOBE | DE | | | | 4836 | Supported RIBS version range: [0.0.0.0,9.0.0.61]
02/18/16 15:28:18:782 | [INFO] | | OOBE | DE | | | | 4836 | ----------------- CreatePayloadSession: machine is x64 ---------------
02/18/16 15:28:18:874 | [INFO] | | OOBE | DE | | | | 4836 | ______ Verify Dependency Subscribers ______
02/18/16 15:28:18:876 | [INFO] | | OOBE | DE | | | | 4836 | BEGIN Operation order for all session payloads: mediaGroup (requires,satisfies)
02/18/16 15:28:18:876 | [INFO] | | OOBE | DE | | | | 4836 | Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}: 1 (0,2)
02/18/16 15:28:18:876 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}: 2 (0,1)
02/18/16 15:28:18:876 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}: 2 (0,1)
02/18/16 15:28:18:876 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}: 2 (0,1)
02/18/16 15:28:18:876 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}: 2 (0,1)
02/18/16 15:28:18:876 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorEU CC 5.0.0.0 {9E9EB9FD-FDE8-487A-A41C-7713DA91AC89}: 2 (0,1)
02/18/16 15:28:18:876 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}: 2 (0,1)
02/18/16 15:28:18:876 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorJA CC 5.0.0.0 {52D57F95-000A-4922-BB31-C6A936F4FD7D}: 2 (0,1)
02/18/16 15:28:18:876 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}: 2 (0,1)
02/18/16 15:28:18:876 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorNA CC 5.0.0.0 {72405B80-A3DD-4BB2-A8C4-A90BC7BA50FF}: 2 (0,1)
02/18/16 15:28:18:876 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}: 2 (0,1)
02/18/16 15:28:18:877 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}: 2 (0,1)
02/18/16 15:28:18:877 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}: 2 (0,1)
02/18/16 15:28:18:877 | [INFO] | | OOBE | DE | | | | 4836 | Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}: 2 (0,1)
02/18/16 15:28:18:877 | [INFO] | | OOBE | DE | | | | 4836 | Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}: 2 (0,1)
02/18/16 15:28:18:877 | [INFO] | | OOBE | DE | | | | 4836 | Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9}: 2 (0,1)
02/18/16 15:28:18:877 | [INFO] | | OOBE | DE | | | | 4836 | Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20}: 2 (0,1)
02/18/16 15:28:18:877 | [INFO] | | OOBE | DE | | | | 4836 | Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC}: 2 (0,1)
02/18/16 15:28:18:877 | [INFO] | | OOBE | DE | | | | 4836 | Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}: 2 (0,1)
02/18/16 15:28:18:877 | [INFO] | | OOBE | DE | | | | 4836 | Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}: 2 (0,1)
02/18/16 15:28:18:877 | [INFO] | | OOBE | DE | | | | 4836 | Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}: 2 (0,1)
02/18/16 15:28:18:877 | [INFO] | | OOBE | DE | | | | 4836 | Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}: 3 (1,1)
02/18/16 15:28:18:877 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}: 4 (22,0)
02/18/16 15:28:18:877 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Korean Language Pack_AdobePhotoshop16-ko_KR_x64 16.0.0.0 {5309436A-D12F-437D-B7A4-BF136E17139C}: 5 (0,0)
02/18/16 15:28:18:877 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Spanish Language Pack_AdobePhotoshop16-es_ES_x64 16.0.0.0 {644DC0CB-E8C9-4508-B99D-8747C6172621}: 5 (0,0)
02/18/16 15:28:18:877 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Norwegian Language Pack_AdobePhotoshop16-nb_NO_x64 16.0.0.0 {00F35A9A-C859-4F6E-8C4F-70A7239207FF}: 5 (0,0)
02/18/16 15:28:18:877 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Russian Language Pack_AdobePhotoshop16-ru_RU_x64 16.0.0.0 {6E14FFAB-83F4-4CB7-87A2-703F6F20487A}: 5 (0,0)
02/18/16 15:28:18:877 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 AE English Language Pack_AdobePhotoshop16-en_AE_x64 16.0.0.0 {6E7A3076-3056-492F-966F-1EA4FDCE5FA8}: 5 (0,0)
02/18/16 15:28:18:877 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Ukrainian Language Pack_AdobePhotoshop16-uk_UA_x64 16.0.0.0 {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA}: 5 (0,0)
02/18/16 15:28:18:877 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Canadian French Language Pack_AdobePhotoshop16-fr_CA_x64 16.0.0.0 {7433F860-160E-4024-8218-892D796972A6}: 5 (0,0)
02/18/16 15:28:18:877 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Czech Language Pack_AdobePhotoshop16-cs_CZ_x64 16.0.0.0 {7787331E-D646-4CA4-ADCB-B264CC156D7D}: 5 (0,0)
02/18/16 15:28:18:878 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Japanese Language Pack_AdobePhotoshop16-ja_JP_x64 16.0.0.0 {778CE554-471C-4605-A600-852C976A4DC5}: 5 (0,0)
02/18/16 15:28:18:878 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 IL English Language Pack_AdobePhotoshop16-en_IL_x64 16.0.0.0 {0CA9067E-B7E0-4C7A-BA40-987AF967A05D}: 5 (0,0)
02/18/16 15:28:18:878 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 MA French Language Pack_AdobePhotoshop16-fr_MA_x64 16.0.0.0 {0D30F03E-27D9-41F8-AF26-9F1801C2AE28}: 5 (0,0)
02/18/16 15:28:18:878 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Polish Language Pack_AdobePhotoshop16-pl_PL_x64 16.0.0.0 {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0}: 5 (0,0)
02/18/16 15:28:18:878 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Italian Language Pack_AdobePhotoshop16-it_IT_x64 16.0.0.0 {960F21E4-EBDC-4A3E-80E9-C28D8A593F66}: 5 (0,0)
02/18/16 15:28:18:878 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Hungarian Language Pack_AdobePhotoshop16-hu_HU_x64 16.0.0.0 {98D6FC60-7908-474A-A598-0D7A7BFEF2C2}: 5 (0,0)
02/18/16 15:28:18:878 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Chinese (traditional) Language Pack_AdobePhotoshop16-zh_TW_x64 16.0.0.0 {18844AF8-051C-4227-9BE1-CA06F4364F9C}: 5 (0,0)
02/18/16 15:28:18:878 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Swedish Language Pack_AdobePhotoshop16-sv_SE_x64 16.0.0.0 {1B7AE611-4C93-47FC-951F-0BD9839AB72B}: 5 (0,0)
02/18/16 15:28:18:878 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 North American Spanish Language Pack_AdobePhotoshop16-es_MX_x64 16.0.0.0 {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4}: 5 (0,0)
02/18/16 15:28:18:878 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Chinese Language Pack_AdobePhotoshop16-zh_CN_x64 16.0.0.0 {3875BF24-5D9A-494A-A4FA-7AC70F56EC88}: 5 (0,0)
02/18/16 15:28:18:878 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 French Language Pack_AdobePhotoshop16-fr_FR_x64 16.0.0.0 {B75FB41B-E3E2-4B9F-93F7-62D982857374}: 5 (0,0)
02/18/16 15:28:18:878 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Turkish Language Pack_AdobePhotoshop16-tr_TR_x64 16.0.0.0 {BED85F42-B42C-4A91-946B-A928824C48A1}: 5 (0,0)
02/18/16 15:28:18:878 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 German Language Pack_AdobePhotoshop16-de_DE_x64 16.0.0.0 {69C13F4A-83B3-42F4-912C-C99F1442F439}: 5 (0,0)
02/18/16 15:28:18:878 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860}: 5 (0,0)
02/18/16 15:28:18:878 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Dutch Language Pack_AdobePhotoshop16-nl_NL_x64 16.0.0.0 {2060E7ED-C473-4A38-877F-C844E81B64F3}: 5 (0,0)
02/18/16 15:28:18:878 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Brazilian Portugese Language Pack_AdobePhotoshop16-pt_BR_x64 16.0.0.0 {4A0115A5-CA14-4EA1-9896-2F161B5144B9}: 5 (0,0)
02/18/16 15:28:18:878 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Danish Language Pack_AdobePhotoshop16-da_DK_x64 16.0.0.0 {F5D14B6C-DA16-4031-9EB8-AF0728550AFC}: 5 (0,0)
02/18/16 15:28:18:878 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 International English Language Pack_AdobePhotoshop16-en_GB_x64 16.0.0.0 {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4}: 5 (0,0)
02/18/16 15:28:18:878 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Finnish Language Pack_AdobePhotoshop16-fi_FI_x64 16.0.0.0 {FD8B8694-1044-4481-A5D9-4740A46BBC3B}: 5 (0,0)
02/18/16 15:28:18:878 | [INFO] | | OOBE | DE | | | | 4836 | END Operation order for all session payloads: mediaGroup (requires,satisfies)
02/18/16 15:28:19:521 | [INFO] | | OOBE | DE | | | | 4836 | Setting property "analyticsFilePath" to: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\{2E0014BF-75A4-42D3-9121-0D5D2A5E9FC7}
02/18/16 15:28:19:521 | [INFO] | | OOBE | DE | | | | 4836 | Setting property "conflictingProcessInfo" to: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\{A41F6ABA-6252-4B82-BC2C-F34280C12615}
02/18/16 15:28:19:521 | [INFO] | | OOBE | DE | | | | 4836 | Setting property "deploymentFile" to: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\{2B3E7904-56FC-4BD0-905B-A2D312916FCB}
02/18/16 15:28:19:521 | [INFO] | | OOBE | DE | | | | 4836 | Setting property "installLanguage" to: en_US
02/18/16 15:28:19:521 | [INFO] | | OOBE | DE | | | | 4836 | Attempting to find the selected language in the set of available payload languages
02/18/16 15:28:19:521 | [INFO] | | OOBE | DE | | | | 4836 | Setting property "installSourcePath" to: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015
02/18/16 15:28:19:522 | [INFO] | | OOBE | DE | | | | 4836 | Setting property "prefMigration" to: FALSE
02/18/16 15:28:19:522 | [INFO] | | OOBE | DE | | | | 4836 | Setting property "skipSync" to: 1
02/18/16 15:28:19:522 | [INFO] | | OOBE | DE | | | | 4836 | Setting property "userASUPath" to:
02/18/16 15:28:19:522 | [INFO] | | OOBE | DE | | | | 4836 | Overwrite property "analyticsFilePath" to: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\{2E0014BF-75A4-42D3-9121-0D5D2A5E9FC7}
02/18/16 15:28:19:522 | [INFO] | | OOBE | DE | | | | 4836 | Overwrite property "conflictingProcessInfo" to: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\{A41F6ABA-6252-4B82-BC2C-F34280C12615}
02/18/16 15:28:19:522 | [INFO] | | OOBE | DE | | | | 4836 | Overwrite property "installLanguage" to: en_US
02/18/16 15:28:19:522 | [INFO] | | OOBE | DE | | | | 4836 | Overwrite property "prefMigration" to: FALSE
02/18/16 15:28:19:522 | [INFO] | | OOBE | DE | | | | 4836 | Overwrite property "skipSync" to: 1
02/18/16 15:28:19:522 | [INFO] | | OOBE | DE | | | | 4836 | Overwrite property "userASUPath" to:
02/18/16 15:28:19:522 | [INFO] | | OOBE | DE | | | | 4836 | Found payload actions:
02/18/16 15:28:19:522 | [INFO] | | OOBE | DE | | | | 4836 | Deciding what installer mode to use...
02/18/16 15:28:19:611 | [INFO] | | OOBE | DE | | | | 4836 | BEGIN Setting requested payload actions
02/18/16 15:28:19:615 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10} is: false
02/18/16 15:28:19:615 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10} is none
02/18/16 15:28:19:615 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457} is: false
02/18/16 15:28:19:615 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457} is none
02/18/16 15:28:19:615 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3} is: false
02/18/16 15:28:19:615 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3} is none
02/18/16 15:28:19:615 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95} is: false
02/18/16 15:28:19:615 | [INFO] | | OOBE | DE | | | | 4836 | Action string for AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95} is none
02/18/16 15:28:19:615 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC} is: false
02/18/16 15:28:19:615 | [INFO] | | OOBE | DE | | | | 4836 | Action string for AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC} is none
02/18/16 15:28:19:615 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: AdobeColorEU CC 5.0.0.0 {9E9EB9FD-FDE8-487A-A41C-7713DA91AC89} is: false
02/18/16 15:28:19:615 | [INFO] | | OOBE | DE | | | | 4836 | Action string for AdobeColorEU CC 5.0.0.0 {9E9EB9FD-FDE8-487A-A41C-7713DA91AC89} is none
02/18/16 15:28:19:615 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28} is: false
02/18/16 15:28:19:615 | [INFO] | | OOBE | DE | | | | 4836 | Action string for AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28} is none
02/18/16 15:28:19:616 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: AdobeColorJA CC 5.0.0.0 {52D57F95-000A-4922-BB31-C6A936F4FD7D} is: false
02/18/16 15:28:19:616 | [INFO] | | OOBE | DE | | | | 4836 | Action string for AdobeColorJA CC 5.0.0.0 {52D57F95-000A-4922-BB31-C6A936F4FD7D} is none
02/18/16 15:28:19:616 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB} is: false
02/18/16 15:28:19:616 | [INFO] | | OOBE | DE | | | | 4836 | Action string for AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB} is none
02/18/16 15:28:19:616 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: AdobeColorNA CC 5.0.0.0 {72405B80-A3DD-4BB2-A8C4-A90BC7BA50FF} is: false
02/18/16 15:28:19:616 | [INFO] | | OOBE | DE | | | | 4836 | Action string for AdobeColorNA CC 5.0.0.0 {72405B80-A3DD-4BB2-A8C4-A90BC7BA50FF} is none
02/18/16 15:28:19:616 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44} is: false
02/18/16 15:28:19:616 | [INFO] | | OOBE | DE | | | | 4836 | Action string for AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44} is none
02/18/16 15:28:19:616 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66} is: false
02/18/16 15:28:19:616 | [INFO] | | OOBE | DE | | | | 4836 | Action string for AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66} is none
02/18/16 15:28:19:616 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94} is: false
02/18/16 15:28:19:616 | [INFO] | | OOBE | DE | | | | 4836 | Action string for AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94} is none
02/18/16 15:28:19:616 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140} is: false
02/18/16 15:28:19:616 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140} is none
02/18/16 15:28:19:616 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9} is: true
02/18/16 15:28:19:616 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9} is none
02/18/16 15:28:19:616 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9} is: true
02/18/16 15:28:19:616 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9} is none
02/18/16 15:28:19:616 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20} is: true
02/18/16 15:28:19:616 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20} is none
02/18/16 15:28:19:617 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC} is: true
02/18/16 15:28:19:617 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC} is none
02/18/16 15:28:19:617 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613} is: false
02/18/16 15:28:19:617 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613} is none
02/18/16 15:28:19:617 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446} is: false
02/18/16 15:28:19:617 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446} is none
02/18/16 15:28:19:617 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA} is: false
02/18/16 15:28:19:617 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA} is none
02/18/16 15:28:19:617 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85} is: false
02/18/16 15:28:19:617 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85} is none
02/18/16 15:28:19:617 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21} is: false
02/18/16 15:28:19:617 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21} is install
02/18/16 15:28:19:617 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Korean Language Pack_AdobePhotoshop16-ko_KR_x64 16.0.0.0 {5309436A-D12F-437D-B7A4-BF136E17139C} is: false
02/18/16 15:28:19:617 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Adobe Photoshop CC 2015 Korean Language Pack_AdobePhotoshop16-ko_KR_x64 16.0.0.0 {5309436A-D12F-437D-B7A4-BF136E17139C} is none
02/18/16 15:28:19:617 | [INFO] | | OOBE | DE | | | | 4836 | Payload Adobe Photoshop CC 2015 Korean Language Pack_AdobePhotoshop16-ko_KR_x64 16.0.0.0 {5309436A-D12F-437D-B7A4-BF136E17139C} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 15:28:19:617 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Spanish Language Pack_AdobePhotoshop16-es_ES_x64 16.0.0.0 {644DC0CB-E8C9-4508-B99D-8747C6172621} is: false
02/18/16 15:28:19:617 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Adobe Photoshop CC 2015 Spanish Language Pack_AdobePhotoshop16-es_ES_x64 16.0.0.0 {644DC0CB-E8C9-4508-B99D-8747C6172621} is none
02/18/16 15:28:19:617 | [INFO] | | OOBE | DE | | | | 4836 | Payload Adobe Photoshop CC 2015 Spanish Language Pack_AdobePhotoshop16-es_ES_x64 16.0.0.0 {644DC0CB-E8C9-4508-B99D-8747C6172621} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 15:28:19:618 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Norwegian Language Pack_AdobePhotoshop16-nb_NO_x64 16.0.0.0 {00F35A9A-C859-4F6E-8C4F-70A7239207FF} is: false
02/18/16 15:28:19:618 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Adobe Photoshop CC 2015 Norwegian Language Pack_AdobePhotoshop16-nb_NO_x64 16.0.0.0 {00F35A9A-C859-4F6E-8C4F-70A7239207FF} is none
02/18/16 15:28:19:618 | [INFO] | | OOBE | DE | | | | 4836 | Payload Adobe Photoshop CC 2015 Norwegian Language Pack_AdobePhotoshop16-nb_NO_x64 16.0.0.0 {00F35A9A-C859-4F6E-8C4F-70A7239207FF} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 15:28:19:618 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Russian Language Pack_AdobePhotoshop16-ru_RU_x64 16.0.0.0 {6E14FFAB-83F4-4CB7-87A2-703F6F20487A} is: false
02/18/16 15:28:19:618 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Adobe Photoshop CC 2015 Russian Language Pack_AdobePhotoshop16-ru_RU_x64 16.0.0.0 {6E14FFAB-83F4-4CB7-87A2-703F6F20487A} is none
02/18/16 15:28:19:618 | [INFO] | | OOBE | DE | | | | 4836 | Payload Adobe Photoshop CC 2015 Russian Language Pack_AdobePhotoshop16-ru_RU_x64 16.0.0.0 {6E14FFAB-83F4-4CB7-87A2-703F6F20487A} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 15:28:19:618 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Adobe Photoshop CC 2015 AE English Language Pack_AdobePhotoshop16-en_AE_x64 16.0.0.0 {6E7A3076-3056-492F-966F-1EA4FDCE5FA8} is: false
02/18/16 15:28:19:618 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Adobe Photoshop CC 2015 AE English Language Pack_AdobePhotoshop16-en_AE_x64 16.0.0.0 {6E7A3076-3056-492F-966F-1EA4FDCE5FA8} is none
02/18/16 15:28:19:618 | [INFO] | | OOBE | DE | | | | 4836 | Payload Adobe Photoshop CC 2015 AE English Language Pack_AdobePhotoshop16-en_AE_x64 16.0.0.0 {6E7A3076-3056-492F-966F-1EA4FDCE5FA8} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 15:28:19:618 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Ukrainian Language Pack_AdobePhotoshop16-uk_UA_x64 16.0.0.0 {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA} is: false
02/18/16 15:28:19:618 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Adobe Photoshop CC 2015 Ukrainian Language Pack_AdobePhotoshop16-uk_UA_x64 16.0.0.0 {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA} is none
02/18/16 15:28:19:618 | [INFO] | | OOBE | DE | | | | 4836 | Payload Adobe Photoshop CC 2015 Ukrainian Language Pack_AdobePhotoshop16-uk_UA_x64 16.0.0.0 {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 15:28:19:618 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Canadian French Language Pack_AdobePhotoshop16-fr_CA_x64 16.0.0.0 {7433F860-160E-4024-8218-892D796972A6} is: false
02/18/16 15:28:19:618 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Adobe Photoshop CC 2015 Canadian French Language Pack_AdobePhotoshop16-fr_CA_x64 16.0.0.0 {7433F860-160E-4024-8218-892D796972A6} is none
02/18/16 15:28:19:618 | [INFO] | | OOBE | DE | | | | 4836 | Payload Adobe Photoshop CC 2015 Canadian French Language Pack_AdobePhotoshop16-fr_CA_x64 16.0.0.0 {7433F860-160E-4024-8218-892D796972A6} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 15:28:19:618 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Czech Language Pack_AdobePhotoshop16-cs_CZ_x64 16.0.0.0 {7787331E-D646-4CA4-ADCB-B264CC156D7D} is: false
02/18/16 15:28:19:618 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Adobe Photoshop CC 2015 Czech Language Pack_AdobePhotoshop16-cs_CZ_x64 16.0.0.0 {7787331E-D646-4CA4-ADCB-B264CC156D7D} is none
02/18/16 15:28:19:618 | [INFO] | | OOBE | DE | | | | 4836 | Payload Adobe Photoshop CC 2015 Czech Language Pack_AdobePhotoshop16-cs_CZ_x64 16.0.0.0 {7787331E-D646-4CA4-ADCB-B264CC156D7D} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 15:28:19:618 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Japanese Language Pack_AdobePhotoshop16-ja_JP_x64 16.0.0.0 {778CE554-471C-4605-A600-852C976A4DC5} is: false
02/18/16 15:28:19:618 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Adobe Photoshop CC 2015 Japanese Language Pack_AdobePhotoshop16-ja_JP_x64 16.0.0.0 {778CE554-471C-4605-A600-852C976A4DC5} is none
02/18/16 15:28:19:619 | [INFO] | | OOBE | DE | | | | 4836 | Payload Adobe Photoshop CC 2015 Japanese Language Pack_AdobePhotoshop16-ja_JP_x64 16.0.0.0 {778CE554-471C-4605-A600-852C976A4DC5} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 15:28:19:619 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Adobe Photoshop CC 2015 IL English Language Pack_AdobePhotoshop16-en_IL_x64 16.0.0.0 {0CA9067E-B7E0-4C7A-BA40-987AF967A05D} is: false
02/18/16 15:28:19:619 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Adobe Photoshop CC 2015 IL English Language Pack_AdobePhotoshop16-en_IL_x64 16.0.0.0 {0CA9067E-B7E0-4C7A-BA40-987AF967A05D} is none
02/18/16 15:28:19:619 | [INFO] | | OOBE | DE | | | | 4836 | Payload Adobe Photoshop CC 2015 IL English Language Pack_AdobePhotoshop16-en_IL_x64 16.0.0.0 {0CA9067E-B7E0-4C7A-BA40-987AF967A05D} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 15:28:19:619 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Adobe Photoshop CC 2015 MA French Language Pack_AdobePhotoshop16-fr_MA_x64 16.0.0.0 {0D30F03E-27D9-41F8-AF26-9F1801C2AE28} is: false
02/18/16 15:28:19:619 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Adobe Photoshop CC 2015 MA French Language Pack_AdobePhotoshop16-fr_MA_x64 16.0.0.0 {0D30F03E-27D9-41F8-AF26-9F1801C2AE28} is none
02/18/16 15:28:19:619 | [INFO] | | OOBE | DE | | | | 4836 | Payload Adobe Photoshop CC 2015 MA French Language Pack_AdobePhotoshop16-fr_MA_x64 16.0.0.0 {0D30F03E-27D9-41F8-AF26-9F1801C2AE28} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 15:28:19:619 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Polish Language Pack_AdobePhotoshop16-pl_PL_x64 16.0.0.0 {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0} is: false
02/18/16 15:28:19:619 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Adobe Photoshop CC 2015 Polish Language Pack_AdobePhotoshop16-pl_PL_x64 16.0.0.0 {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0} is none
02/18/16 15:28:19:619 | [INFO] | | OOBE | DE | | | | 4836 | Payload Adobe Photoshop CC 2015 Polish Language Pack_AdobePhotoshop16-pl_PL_x64 16.0.0.0 {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 15:28:19:619 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Italian Language Pack_AdobePhotoshop16-it_IT_x64 16.0.0.0 {960F21E4-EBDC-4A3E-80E9-C28D8A593F66} is: false
02/18/16 15:28:19:619 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Adobe Photoshop CC 2015 Italian Language Pack_AdobePhotoshop16-it_IT_x64 16.0.0.0 {960F21E4-EBDC-4A3E-80E9-C28D8A593F66} is none
02/18/16 15:28:19:619 | [INFO] | | OOBE | DE | | | | 4836 | Payload Adobe Photoshop CC 2015 Italian Language Pack_AdobePhotoshop16-it_IT_x64 16.0.0.0 {960F21E4-EBDC-4A3E-80E9-C28D8A593F66} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 15:28:19:619 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Hungarian Language Pack_AdobePhotoshop16-hu_HU_x64 16.0.0.0 {98D6FC60-7908-474A-A598-0D7A7BFEF2C2} is: false
02/18/16 15:28:19:619 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Adobe Photoshop CC 2015 Hungarian Language Pack_AdobePhotoshop16-hu_HU_x64 16.0.0.0 {98D6FC60-7908-474A-A598-0D7A7BFEF2C2} is none
02/18/16 15:28:19:619 | [INFO] | | OOBE | DE | | | | 4836 | Payload Adobe Photoshop CC 2015 Hungarian Language Pack_AdobePhotoshop16-hu_HU_x64 16.0.0.0 {98D6FC60-7908-474A-A598-0D7A7BFEF2C2} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 15:28:19:619 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Chinese (traditional) Language Pack_AdobePhotoshop16-zh_TW_x64 16.0.0.0 {18844AF8-051C-4227-9BE1-CA06F4364F9C} is: false
02/18/16 15:28:19:619 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Adobe Photoshop CC 2015 Chinese (traditional) Language Pack_AdobePhotoshop16-zh_TW_x64 16.0.0.0 {18844AF8-051C-4227-9BE1-CA06F4364F9C} is none
02/18/16 15:28:19:619 | [INFO] | | OOBE | DE | | | | 4836 | Payload Adobe Photoshop CC 2015 Chinese (traditional) Language Pack_AdobePhotoshop16-zh_TW_x64 16.0.0.0 {18844AF8-051C-4227-9BE1-CA06F4364F9C} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 15:28:19:619 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Swedish Language Pack_AdobePhotoshop16-sv_SE_x64 16.0.0.0 {1B7AE611-4C93-47FC-951F-0BD9839AB72B} is: false
02/18/16 15:28:19:620 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Adobe Photoshop CC 2015 Swedish Language Pack_AdobePhotoshop16-sv_SE_x64 16.0.0.0 {1B7AE611-4C93-47FC-951F-0BD9839AB72B} is none
02/18/16 15:28:19:620 | [INFO] | | OOBE | DE | | | | 4836 | Payload Adobe Photoshop CC 2015 Swedish Language Pack_AdobePhotoshop16-sv_SE_x64 16.0.0.0 {1B7AE611-4C93-47FC-951F-0BD9839AB72B} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 15:28:19:620 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Adobe Photoshop CC 2015 North American Spanish Language Pack_AdobePhotoshop16-es_MX_x64 16.0.0.0 {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4} is: false
02/18/16 15:28:19:620 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Adobe Photoshop CC 2015 North American Spanish Language Pack_AdobePhotoshop16-es_MX_x64 16.0.0.0 {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4} is none
02/18/16 15:28:19:620 | [INFO] | | OOBE | DE | | | | 4836 | Payload Adobe Photoshop CC 2015 North American Spanish Language Pack_AdobePhotoshop16-es_MX_x64 16.0.0.0 {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 15:28:19:620 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Chinese Language Pack_AdobePhotoshop16-zh_CN_x64 16.0.0.0 {3875BF24-5D9A-494A-A4FA-7AC70F56EC88} is: false
02/18/16 15:28:19:620 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Adobe Photoshop CC 2015 Chinese Language Pack_AdobePhotoshop16-zh_CN_x64 16.0.0.0 {3875BF24-5D9A-494A-A4FA-7AC70F56EC88} is none
02/18/16 15:28:19:620 | [INFO] | | OOBE | DE | | | | 4836 | Payload Adobe Photoshop CC 2015 Chinese Language Pack_AdobePhotoshop16-zh_CN_x64 16.0.0.0 {3875BF24-5D9A-494A-A4FA-7AC70F56EC88} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 15:28:19:620 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Adobe Photoshop CC 2015 French Language Pack_AdobePhotoshop16-fr_FR_x64 16.0.0.0 {B75FB41B-E3E2-4B9F-93F7-62D982857374} is: false
02/18/16 15:28:19:620 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Adobe Photoshop CC 2015 French Language Pack_AdobePhotoshop16-fr_FR_x64 16.0.0.0 {B75FB41B-E3E2-4B9F-93F7-62D982857374} is none
02/18/16 15:28:19:620 | [INFO] | | OOBE | DE | | | | 4836 | Payload Adobe Photoshop CC 2015 French Language Pack_AdobePhotoshop16-fr_FR_x64 16.0.0.0 {B75FB41B-E3E2-4B9F-93F7-62D982857374} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 15:28:19:620 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Turkish Language Pack_AdobePhotoshop16-tr_TR_x64 16.0.0.0 {BED85F42-B42C-4A91-946B-A928824C48A1} is: false
02/18/16 15:28:19:620 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Adobe Photoshop CC 2015 Turkish Language Pack_AdobePhotoshop16-tr_TR_x64 16.0.0.0 {BED85F42-B42C-4A91-946B-A928824C48A1} is none
02/18/16 15:28:19:620 | [INFO] | | OOBE | DE | | | | 4836 | Payload Adobe Photoshop CC 2015 Turkish Language Pack_AdobePhotoshop16-tr_TR_x64 16.0.0.0 {BED85F42-B42C-4A91-946B-A928824C48A1} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 15:28:19:620 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Adobe Photoshop CC 2015 German Language Pack_AdobePhotoshop16-de_DE_x64 16.0.0.0 {69C13F4A-83B3-42F4-912C-C99F1442F439} is: false
02/18/16 15:28:19:620 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Adobe Photoshop CC 2015 German Language Pack_AdobePhotoshop16-de_DE_x64 16.0.0.0 {69C13F4A-83B3-42F4-912C-C99F1442F439} is none
02/18/16 15:28:19:620 | [INFO] | | OOBE | DE | | | | 4836 | Payload Adobe Photoshop CC 2015 German Language Pack_AdobePhotoshop16-de_DE_x64 16.0.0.0 {69C13F4A-83B3-42F4-912C-C99F1442F439} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 15:28:19:620 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860} is: false
02/18/16 15:28:19:621 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860} is none
02/18/16 15:28:19:621 | [INFO] | | OOBE | DE | | | | 4836 | Payload Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 15:28:19:621 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Dutch Language Pack_AdobePhotoshop16-nl_NL_x64 16.0.0.0 {2060E7ED-C473-4A38-877F-C844E81B64F3} is: false
02/18/16 15:28:19:621 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Adobe Photoshop CC 2015 Dutch Language Pack_AdobePhotoshop16-nl_NL_x64 16.0.0.0 {2060E7ED-C473-4A38-877F-C844E81B64F3} is none
02/18/16 15:28:19:621 | [INFO] | | OOBE | DE | | | | 4836 | Payload Adobe Photoshop CC 2015 Dutch Language Pack_AdobePhotoshop16-nl_NL_x64 16.0.0.0 {2060E7ED-C473-4A38-877F-C844E81B64F3} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 15:28:19:621 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Brazilian Portugese Language Pack_AdobePhotoshop16-pt_BR_x64 16.0.0.0 {4A0115A5-CA14-4EA1-9896-2F161B5144B9} is: false
02/18/16 15:28:19:621 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Adobe Photoshop CC 2015 Brazilian Portugese Language Pack_AdobePhotoshop16-pt_BR_x64 16.0.0.0 {4A0115A5-CA14-4EA1-9896-2F161B5144B9} is none
02/18/16 15:28:19:621 | [INFO] | | OOBE | DE | | | | 4836 | Payload Adobe Photoshop CC 2015 Brazilian Portugese Language Pack_AdobePhotoshop16-pt_BR_x64 16.0.0.0 {4A0115A5-CA14-4EA1-9896-2F161B5144B9} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 15:28:19:621 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Danish Language Pack_AdobePhotoshop16-da_DK_x64 16.0.0.0 {F5D14B6C-DA16-4031-9EB8-AF0728550AFC} is: false
02/18/16 15:28:19:621 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Adobe Photoshop CC 2015 Danish Language Pack_AdobePhotoshop16-da_DK_x64 16.0.0.0 {F5D14B6C-DA16-4031-9EB8-AF0728550AFC} is none
02/18/16 15:28:19:621 | [INFO] | | OOBE | DE | | | | 4836 | Payload Adobe Photoshop CC 2015 Danish Language Pack_AdobePhotoshop16-da_DK_x64 16.0.0.0 {F5D14B6C-DA16-4031-9EB8-AF0728550AFC} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 15:28:19:621 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Adobe Photoshop CC 2015 International English Language Pack_AdobePhotoshop16-en_GB_x64 16.0.0.0 {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4} is: false
02/18/16 15:28:19:621 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Adobe Photoshop CC 2015 International English Language Pack_AdobePhotoshop16-en_GB_x64 16.0.0.0 {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4} is none
02/18/16 15:28:19:621 | [INFO] | | OOBE | DE | | | | 4836 | Payload Adobe Photoshop CC 2015 International English Language Pack_AdobePhotoshop16-en_GB_x64 16.0.0.0 {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 15:28:19:621 | [INFO] | | OOBE | DE | | | | 4836 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Finnish Language Pack_AdobePhotoshop16-fi_FI_x64 16.0.0.0 {FD8B8694-1044-4481-A5D9-4740A46BBC3B} is: false
02/18/16 15:28:19:621 | [INFO] | | OOBE | DE | | | | 4836 | Action string for Adobe Photoshop CC 2015 Finnish Language Pack_AdobePhotoshop16-fi_FI_x64 16.0.0.0 {FD8B8694-1044-4481-A5D9-4740A46BBC3B} is none
02/18/16 15:28:19:621 | [INFO] | | OOBE | DE | | | | 4836 | Payload Adobe Photoshop CC 2015 Finnish Language Pack_AdobePhotoshop16-fi_FI_x64 16.0.0.0 {FD8B8694-1044-4481-A5D9-4740A46BBC3B} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 15:28:19:630 | [INFO] | | OOBE | DE | | | | 4836 | END Setting requested payload actions
02/18/16 15:28:19:782 | [INFO] | | OOBE | DE | | | | 4836 | Collected advanced path check information for INSTALLDIR
02/18/16 15:28:19:782 | [INFO] | | OOBE | DE | | | | 4836 | INSTALLDIR is a well-formed path
02/18/16 15:28:19:782 | [INFO] | | OOBE | DE | | | | 4836 | INSTALLDIR is not the root path
02/18/16 15:28:19:782 | [INFO] | | OOBE | DE | | | | 4836 | INSTALLDIR is on a local volume
02/18/16 15:28:19:782 | [INFO] | | OOBE | DE | | | | 4836 | INSTALLDIR is on a writable volume
02/18/16 15:28:19:782 | [INFO] | | OOBE | DE | | | | 4836 | INSTALLDIR is not on a case sensitive volume
02/18/16 15:28:19:782 | [INFO] | | OOBE | DE | | | | 4836 | INSTALLDIR passed path basic path validation: C:\Program Files\Adobe
02/18/16 15:28:24:418 | [INFO] | | OOBE | DE | | | | 4836 | BEGIN InstallOperationsQueue Unordered operations
02/18/16 15:28:24:418 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Norwegian Language Pack_AdobePhotoshop16-nb_NO_x64 16.0.0.0 {00F35A9A-C859-4F6E-8C4F-70A7239207FF}: with operation none
02/18/16 15:28:24:419 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Ukrainian Language Pack_AdobePhotoshop16-uk_UA_x64 16.0.0.0 {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA}: with operation none
02/18/16 15:28:24:419 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 IL English Language Pack_AdobePhotoshop16-en_IL_x64 16.0.0.0 {0CA9067E-B7E0-4C7A-BA40-987AF967A05D}: with operation none
02/18/16 15:28:24:419 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 MA French Language Pack_AdobePhotoshop16-fr_MA_x64 16.0.0.0 {0D30F03E-27D9-41F8-AF26-9F1801C2AE28}: with operation none
02/18/16 15:28:24:419 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Chinese (traditional) Language Pack_AdobePhotoshop16-zh_TW_x64 16.0.0.0 {18844AF8-051C-4227-9BE1-CA06F4364F9C}: with operation none
02/18/16 15:28:24:419 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Swedish Language Pack_AdobePhotoshop16-sv_SE_x64 16.0.0.0 {1B7AE611-4C93-47FC-951F-0BD9839AB72B}: with operation none
02/18/16 15:28:24:419 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Dutch Language Pack_AdobePhotoshop16-nl_NL_x64 16.0.0.0 {2060E7ED-C473-4A38-877F-C844E81B64F3}: with operation none
02/18/16 15:28:24:419 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 North American Spanish Language Pack_AdobePhotoshop16-es_MX_x64 16.0.0.0 {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4}: with operation none
02/18/16 15:28:24:419 | [INFO] | | OOBE | DE | | | | 4836 | Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}: with operation install
02/18/16 15:28:24:419 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Chinese Language Pack_AdobePhotoshop16-zh_CN_x64 16.0.0.0 {3875BF24-5D9A-494A-A4FA-7AC70F56EC88}: with operation none
02/18/16 15:28:24:419 | [INFO] | | OOBE | DE | | | | 4836 | Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20}: with operation repair
02/18/16 15:28:24:419 | [INFO] | | OOBE | DE | | | | 4836 | Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}: with operation install
02/18/16 15:28:24:419 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}: with operation install
02/18/16 15:28:24:419 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Brazilian Portugese Language Pack_AdobePhotoshop16-pt_BR_x64 16.0.0.0 {4A0115A5-CA14-4EA1-9896-2F161B5144B9}: with operation none
02/18/16 15:28:24:419 | [INFO] | | OOBE | DE | | | | 4836 | Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}: with operation install
02/18/16 15:28:24:419 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 International English Language Pack_AdobePhotoshop16-en_GB_x64 16.0.0.0 {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4}: with operation none
02/18/16 15:28:24:419 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorJA CC 5.0.0.0 {52D57F95-000A-4922-BB31-C6A936F4FD7D}: with operation none
02/18/16 15:28:24:420 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Korean Language Pack_AdobePhotoshop16-ko_KR_x64 16.0.0.0 {5309436A-D12F-437D-B7A4-BF136E17139C}: with operation none
02/18/16 15:28:24:420 | [INFO] | | OOBE | DE | | | | 4836 | Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}: with operation repair
02/18/16 15:28:24:420 | [INFO] | | OOBE | DE | | | | 4836 | Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9}: with operation repair
02/18/16 15:28:24:420 | [INFO] | | OOBE | DE | | | | 4836 | Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}: with operation install
02/18/16 15:28:24:420 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}: with operation install
02/18/16 15:28:24:420 | [INFO] | | OOBE | DE | | | | 4836 | Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}: with operation install
02/18/16 15:28:24:420 | [INFO] | | OOBE | DE | | | | 4836 | Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}: with operation install
02/18/16 15:28:24:420 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Spanish Language Pack_AdobePhotoshop16-es_ES_x64 16.0.0.0 {644DC0CB-E8C9-4508-B99D-8747C6172621}: with operation none
02/18/16 15:28:24:420 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 German Language Pack_AdobePhotoshop16-de_DE_x64 16.0.0.0 {69C13F4A-83B3-42F4-912C-C99F1442F439}: with operation none
02/18/16 15:28:24:420 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Russian Language Pack_AdobePhotoshop16-ru_RU_x64 16.0.0.0 {6E14FFAB-83F4-4CB7-87A2-703F6F20487A}: with operation none
02/18/16 15:28:24:420 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 AE English Language Pack_AdobePhotoshop16-en_AE_x64 16.0.0.0 {6E7A3076-3056-492F-966F-1EA4FDCE5FA8}: with operation none
02/18/16 15:28:24:420 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorNA CC 5.0.0.0 {72405B80-A3DD-4BB2-A8C4-A90BC7BA50FF}: with operation none
02/18/16 15:28:24:420 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Canadian French Language Pack_AdobePhotoshop16-fr_CA_x64 16.0.0.0 {7433F860-160E-4024-8218-892D796972A6}: with operation none
02/18/16 15:28:24:420 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Czech Language Pack_AdobePhotoshop16-cs_CZ_x64 16.0.0.0 {7787331E-D646-4CA4-ADCB-B264CC156D7D}: with operation none
02/18/16 15:28:24:420 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Japanese Language Pack_AdobePhotoshop16-ja_JP_x64 16.0.0.0 {778CE554-471C-4605-A600-852C976A4DC5}: with operation none
02/18/16 15:28:24:420 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}: with operation install
02/18/16 15:28:24:420 | [INFO] | | OOBE | DE | | | | 4836 | Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC}: with operation repair
02/18/16 15:28:24:421 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Polish Language Pack_AdobePhotoshop16-pl_PL_x64 16.0.0.0 {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0}: with operation none
02/18/16 15:28:24:421 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Italian Language Pack_AdobePhotoshop16-it_IT_x64 16.0.0.0 {960F21E4-EBDC-4A3E-80E9-C28D8A593F66}: with operation none
02/18/16 15:28:24:421 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Hungarian Language Pack_AdobePhotoshop16-hu_HU_x64 16.0.0.0 {98D6FC60-7908-474A-A598-0D7A7BFEF2C2}: with operation none
02/18/16 15:28:24:421 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorEU CC 5.0.0.0 {9E9EB9FD-FDE8-487A-A41C-7713DA91AC89}: with operation none
02/18/16 15:28:24:421 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}: with operation install
02/18/16 15:28:24:421 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}: with operation install
02/18/16 15:28:24:421 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}: with operation install
02/18/16 15:28:24:421 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 French Language Pack_AdobePhotoshop16-fr_FR_x64 16.0.0.0 {B75FB41B-E3E2-4B9F-93F7-62D982857374}: with operation none
02/18/16 15:28:24:421 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Turkish Language Pack_AdobePhotoshop16-tr_TR_x64 16.0.0.0 {BED85F42-B42C-4A91-946B-A928824C48A1}: with operation none
02/18/16 15:28:24:421 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}: with operation install
02/18/16 15:28:24:421 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860}: with operation install
02/18/16 15:28:24:421 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}: with operation install
02/18/16 15:28:24:421 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}: with operation install
02/18/16 15:28:24:421 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Danish Language Pack_AdobePhotoshop16-da_DK_x64 16.0.0.0 {F5D14B6C-DA16-4031-9EB8-AF0728550AFC}: with operation none
02/18/16 15:28:24:421 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}: with operation install
02/18/16 15:28:24:421 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Finnish Language Pack_AdobePhotoshop16-fi_FI_x64 16.0.0.0 {FD8B8694-1044-4481-A5D9-4740A46BBC3B}: with operation none
02/18/16 15:28:24:421 | [INFO] | | OOBE | DE | | | | 4836 | END InstallOperationsQueue Unordered operations
02/18/16 15:28:24:422 | [INFO] | | OOBE | DE | | | | 4836 | BEGIN InstallOperationsQueue Ordered operations
02/18/16 15:28:24:422 | [INFO] | | OOBE | DE | | | | 4836 | Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}: with operation install
02/18/16 15:28:24:422 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}: with operation install
02/18/16 15:28:24:422 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}: with operation install
02/18/16 15:28:24:422 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}: with operation install
02/18/16 15:28:24:422 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}: with operation install
02/18/16 15:28:24:422 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}: with operation install
02/18/16 15:28:24:422 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}: with operation install
02/18/16 15:28:24:422 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}: with operation install
02/18/16 15:28:24:422 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}: with operation install
02/18/16 15:28:24:422 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}: with operation install
02/18/16 15:28:24:422 | [INFO] | | OOBE | DE | | | | 4836 | Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}: with operation install
02/18/16 15:28:24:422 | [INFO] | | OOBE | DE | | | | 4836 | Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}: with operation repair
02/18/16 15:28:24:422 | [INFO] | | OOBE | DE | | | | 4836 | Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9}: with operation repair
02/18/16 15:28:24:422 | [INFO] | | OOBE | DE | | | | 4836 | Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20}: with operation repair
02/18/16 15:28:24:423 | [INFO] | | OOBE | DE | | | | 4836 | Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC}: with operation repair
02/18/16 15:28:24:423 | [INFO] | | OOBE | DE | | | | 4836 | Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}: with operation install
02/18/16 15:28:24:423 | [INFO] | | OOBE | DE | | | | 4836 | Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}: with operation install
02/18/16 15:28:24:423 | [INFO] | | OOBE | DE | | | | 4836 | Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}: with operation install
02/18/16 15:28:24:423 | [INFO] | | OOBE | DE | | | | 4836 | Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}: with operation install
02/18/16 15:28:24:423 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}: with operation install
02/18/16 15:28:24:423 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860}: with operation install
02/18/16 15:28:24:423 | [INFO] | | OOBE | DE | | | | 4836 | END InstallOperationsQueue Ordered operations
02/18/16 15:28:25:032 | [INFO] | | OOBE | DE | | | | 4836 | DW034: Warning: Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9} will not be repaired, due to updated patch of the payload and one of the top level payload is being installed.
02/18/16 15:28:25:032 | [INFO] | | OOBE | DE | | | | 4836 | DW034: Warning: Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9} will not be repaired, due to updated patch of the payload and one of the top level payload is being installed.
02/18/16 15:28:25:033 | [INFO] | | OOBE | DE | | | | 4836 | DW034: Warning: Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20} will not be repaired, due to updated patch of the payload and one of the top level payload is being installed.
02/18/16 15:28:25:033 | [INFO] | | OOBE | DE | | | | 4836 | DW034: Warning: Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC} will not be repaired, due to updated patch of the payload and one of the top level payload is being installed.
02/18/16 15:28:25:255 | [INFO] | | OOBE | DE | | | | 4836 | Payloads passed preflight validation.
02/18/16 15:28:25:297 | [INFO] | | OOBE | DE | | | | 4836 | Call PreSession Custom Hook
02/18/16 15:28:25:297 | [INFO] | | OOBE | DE | | | | 4836 | BEGIN InstallOperationsQueue Unordered operations
02/18/16 15:28:25:297 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Norwegian Language Pack_AdobePhotoshop16-nb_NO_x64 16.0.0.0 {00F35A9A-C859-4F6E-8C4F-70A7239207FF}: with operation none
02/18/16 15:28:25:298 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Ukrainian Language Pack_AdobePhotoshop16-uk_UA_x64 16.0.0.0 {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA}: with operation none
02/18/16 15:28:25:298 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 IL English Language Pack_AdobePhotoshop16-en_IL_x64 16.0.0.0 {0CA9067E-B7E0-4C7A-BA40-987AF967A05D}: with operation none
02/18/16 15:28:25:298 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 MA French Language Pack_AdobePhotoshop16-fr_MA_x64 16.0.0.0 {0D30F03E-27D9-41F8-AF26-9F1801C2AE28}: with operation none
02/18/16 15:28:25:298 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Chinese (traditional) Language Pack_AdobePhotoshop16-zh_TW_x64 16.0.0.0 {18844AF8-051C-4227-9BE1-CA06F4364F9C}: with operation none
02/18/16 15:28:25:298 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Swedish Language Pack_AdobePhotoshop16-sv_SE_x64 16.0.0.0 {1B7AE611-4C93-47FC-951F-0BD9839AB72B}: with operation none
02/18/16 15:28:25:298 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Dutch Language Pack_AdobePhotoshop16-nl_NL_x64 16.0.0.0 {2060E7ED-C473-4A38-877F-C844E81B64F3}: with operation none
02/18/16 15:28:25:298 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 North American Spanish Language Pack_AdobePhotoshop16-es_MX_x64 16.0.0.0 {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4}: with operation none
02/18/16 15:28:25:298 | [INFO] | | OOBE | DE | | | | 4836 | Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}: with operation install
02/18/16 15:28:25:298 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Chinese Language Pack_AdobePhotoshop16-zh_CN_x64 16.0.0.0 {3875BF24-5D9A-494A-A4FA-7AC70F56EC88}: with operation none
02/18/16 15:28:25:298 | [INFO] | | OOBE | DE | | | | 4836 | Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20}: with operation repair
02/18/16 15:28:25:298 | [INFO] | | OOBE | DE | | | | 4836 | Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}: with operation install
02/18/16 15:28:25:298 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}: with operation install
02/18/16 15:28:25:298 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Brazilian Portugese Language Pack_AdobePhotoshop16-pt_BR_x64 16.0.0.0 {4A0115A5-CA14-4EA1-9896-2F161B5144B9}: with operation none
02/18/16 15:28:25:298 | [INFO] | | OOBE | DE | | | | 4836 | Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}: with operation install
02/18/16 15:28:25:298 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 International English Language Pack_AdobePhotoshop16-en_GB_x64 16.0.0.0 {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4}: with operation none
02/18/16 15:28:25:298 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorJA CC 5.0.0.0 {52D57F95-000A-4922-BB31-C6A936F4FD7D}: with operation none
02/18/16 15:28:25:298 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Korean Language Pack_AdobePhotoshop16-ko_KR_x64 16.0.0.0 {5309436A-D12F-437D-B7A4-BF136E17139C}: with operation none
02/18/16 15:28:25:298 | [INFO] | | OOBE | DE | | | | 4836 | Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}: with operation repair
02/18/16 15:28:25:298 | [INFO] | | OOBE | DE | | | | 4836 | Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9}: with operation repair
02/18/16 15:28:25:298 | [INFO] | | OOBE | DE | | | | 4836 | Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}: with operation install
02/18/16 15:28:25:298 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}: with operation install
02/18/16 15:28:25:298 | [INFO] | | OOBE | DE | | | | 4836 | Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}: with operation install
02/18/16 15:28:25:299 | [INFO] | | OOBE | DE | | | | 4836 | Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}: with operation install
02/18/16 15:28:25:299 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Spanish Language Pack_AdobePhotoshop16-es_ES_x64 16.0.0.0 {644DC0CB-E8C9-4508-B99D-8747C6172621}: with operation none
02/18/16 15:28:25:299 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 German Language Pack_AdobePhotoshop16-de_DE_x64 16.0.0.0 {69C13F4A-83B3-42F4-912C-C99F1442F439}: with operation none
02/18/16 15:28:25:299 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Russian Language Pack_AdobePhotoshop16-ru_RU_x64 16.0.0.0 {6E14FFAB-83F4-4CB7-87A2-703F6F20487A}: with operation none
02/18/16 15:28:25:299 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 AE English Language Pack_AdobePhotoshop16-en_AE_x64 16.0.0.0 {6E7A3076-3056-492F-966F-1EA4FDCE5FA8}: with operation none
02/18/16 15:28:25:299 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorNA CC 5.0.0.0 {72405B80-A3DD-4BB2-A8C4-A90BC7BA50FF}: with operation none
02/18/16 15:28:25:299 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Canadian French Language Pack_AdobePhotoshop16-fr_CA_x64 16.0.0.0 {7433F860-160E-4024-8218-892D796972A6}: with operation none
02/18/16 15:28:25:299 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Czech Language Pack_AdobePhotoshop16-cs_CZ_x64 16.0.0.0 {7787331E-D646-4CA4-ADCB-B264CC156D7D}: with operation none
02/18/16 15:28:25:299 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Japanese Language Pack_AdobePhotoshop16-ja_JP_x64 16.0.0.0 {778CE554-471C-4605-A600-852C976A4DC5}: with operation none
02/18/16 15:28:25:299 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}: with operation install
02/18/16 15:28:25:299 | [INFO] | | OOBE | DE | | | | 4836 | Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC}: with operation repair
02/18/16 15:28:25:299 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Polish Language Pack_AdobePhotoshop16-pl_PL_x64 16.0.0.0 {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0}: with operation none
02/18/16 15:28:25:299 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Italian Language Pack_AdobePhotoshop16-it_IT_x64 16.0.0.0 {960F21E4-EBDC-4A3E-80E9-C28D8A593F66}: with operation none
02/18/16 15:28:25:299 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Hungarian Language Pack_AdobePhotoshop16-hu_HU_x64 16.0.0.0 {98D6FC60-7908-474A-A598-0D7A7BFEF2C2}: with operation none
02/18/16 15:28:25:299 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorEU CC 5.0.0.0 {9E9EB9FD-FDE8-487A-A41C-7713DA91AC89}: with operation none
02/18/16 15:28:25:299 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}: with operation install
02/18/16 15:28:25:299 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}: with operation install
02/18/16 15:28:25:299 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}: with operation install
02/18/16 15:28:25:299 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 French Language Pack_AdobePhotoshop16-fr_FR_x64 16.0.0.0 {B75FB41B-E3E2-4B9F-93F7-62D982857374}: with operation none
02/18/16 15:28:25:299 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Turkish Language Pack_AdobePhotoshop16-tr_TR_x64 16.0.0.0 {BED85F42-B42C-4A91-946B-A928824C48A1}: with operation none
02/18/16 15:28:25:299 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}: with operation install
02/18/16 15:28:25:299 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860}: with operation install
02/18/16 15:28:25:300 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}: with operation install
02/18/16 15:28:25:300 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}: with operation install
02/18/16 15:28:25:300 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Danish Language Pack_AdobePhotoshop16-da_DK_x64 16.0.0.0 {F5D14B6C-DA16-4031-9EB8-AF0728550AFC}: with operation none
02/18/16 15:28:25:300 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}: with operation install
02/18/16 15:28:25:300 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Finnish Language Pack_AdobePhotoshop16-fi_FI_x64 16.0.0.0 {FD8B8694-1044-4481-A5D9-4740A46BBC3B}: with operation none
02/18/16 15:28:25:300 | [INFO] | | OOBE | DE | | | | 4836 | END InstallOperationsQueue Unordered operations
02/18/16 15:28:25:300 | [INFO] | | OOBE | DE | | | | 4836 | BEGIN InstallOperationsQueue Ordered operations
02/18/16 15:28:25:300 | [INFO] | | OOBE | DE | | | | 4836 | Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}: with operation install
02/18/16 15:28:25:300 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}: with operation install
02/18/16 15:28:25:300 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}: with operation install
02/18/16 15:28:25:300 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}: with operation install
02/18/16 15:28:25:300 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}: with operation install
02/18/16 15:28:25:300 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}: with operation install
02/18/16 15:28:25:301 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}: with operation install
02/18/16 15:28:25:301 | [INFO] | | OOBE | DE | | | | 4836 | AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}: with operation install
02/18/16 15:28:25:301 | [INFO] | | OOBE | DE | | | | 4836 | Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}: with operation install
02/18/16 15:28:25:301 | [INFO] | | OOBE | DE | | | | 4836 | Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}: with operation repair
02/18/16 15:28:25:301 | [INFO] | | OOBE | DE | | | | 4836 | Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9}: with operation repair
02/18/16 15:28:25:301 | [INFO] | | OOBE | DE | | | | 4836 | Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20}: with operation repair
02/18/16 15:28:25:301 | [INFO] | | OOBE | DE | | | | 4836 | Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC}: with operation repair
02/18/16 15:28:25:301 | [INFO] | | OOBE | DE | | | | 4836 | Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}: with operation install
02/18/16 15:28:25:301 | [INFO] | | OOBE | DE | | | | 4836 | Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}: with operation install
02/18/16 15:28:25:301 | [INFO] | | OOBE | DE | | | | 4836 | Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}: with operation install
02/18/16 15:28:25:301 | [INFO] | | OOBE | DE | | | | 4836 | Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}: with operation install
02/18/16 15:28:25:301 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}: with operation install
02/18/16 15:28:25:301 | [INFO] | | OOBE | DE | | | | 4836 | Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860}: with operation install
02/18/16 15:28:25:301 | [INFO] | | OOBE | DE | | | | 4836 | END InstallOperationsQueue Ordered operations
02/18/16 15:28:28:710 | [INFO] | | OOBE | DE | | | | 4836 | Calling the custom action code for pre-install for payload Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}
02/18/16 15:28:28:710 | [INFO] | | OOBE | DE | | | | 4836 | ::START TIMER:: [Payload Operation :{56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}]
02/18/16 15:28:28:735 | [INFO] | | OOBE | DE | | | | 2156 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:28:28:736 | [INFO] | | OOBE | DE | | | | 2156 | Installer Operation: PayloadInstaller
02/18/16 15:28:28:736 | [INFO] | | OOBE | DE | | | | 2156 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:28:28:736 | [INFO] | | OOBE | DE | | | | 2156 | Request to install payload
02/18/16 15:28:28:770 | [INFO] | | OOBE | DE | | | | 2156 | Payload Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 15:28:29:005 | [INFO] | | OOBE | DE | | | | 2156 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeCameraRawProfile8.0All\Assets1_1.zip
02/18/16 15:28:29:006 | [INFO] | | OOBE | DE | | | | 2156 | Setting file open option to false in the unzipper
02/18/16 15:28:42:179 | [INFO] | | OOBE | DE | | | | 2156 | Extracting assets complete. Number assets: 1
02/18/16 15:28:42:179 | [INFO] | | OOBE | DE | | | | 2156 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeCameraRawProfile8.0All\Install.db
02/18/16 15:31:52:465 | [INFO] | | OOBE | DE | | | | 2156 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeCameraRawProfile8.0All\Install.db
02/18/16 15:31:52:687 | [INFO] | | OOBE | DE | | | | 2156 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}.db
02/18/16 15:31:53:225 | [INFO] | | OOBE | DE | | | | 4836 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:31:53:225 | [INFO] | | OOBE | DE | | | | 4836 | :: END TIMER :: [Payload Operation :{56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}] took 204511 milliseconds (204.511 seconds) DTR = 1750.55 KBPS (1.70952 MBPS)
02/18/16 15:31:54:227 | [INFO] | | OOBE | DE | | | | 4836 | Updating driver data - Action: Add driver entry
02/18/16 15:31:54:230 | [INFO] | | OOBE | DE | | | | 4836 | Updating driver data successful. Driver entry was added. ARP estimated size 0KB
02/18/16 15:31:54:493 | [INFO] | | OOBE | DE | | | | 4836 | User specified overrideFile:
02/18/16 15:31:54:823 | [INFO] | | OOBE | DE | | | | 4836 | Successfully updated the csu inventory for Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10} return values 0:0
02/18/16 15:31:54:824 | [INFO] | | OOBE | DE | | | | 4836 | Calling the custom action code for post-install for payload Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}
02/18/16 15:31:57:829 | [INFO] | | OOBE | DE | | | | 4836 | Calling the custom action code for pre-install for payload Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}
02/18/16 15:31:57:829 | [INFO] | | OOBE | DE | | | | 4836 | ::START TIMER:: [Payload Operation :{3FB7A108-368A-4849-A3F3-69571BAAC457}]
02/18/16 15:31:57:847 | [INFO] | | OOBE | DE | | | | 7388 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:31:57:888 | [INFO] | | OOBE | DE | | | | 7388 | Installer Operation: PayloadInstaller
02/18/16 15:31:57:888 | [INFO] | | OOBE | DE | | | | 7388 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:31:57:888 | [INFO] | | OOBE | DE | | | | 7388 | Request to install payload
02/18/16 15:31:57:931 | [INFO] | | OOBE | DE | | | | 7388 | Payload Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 15:31:57:949 | [INFO] | | OOBE | DE | | | | 7388 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-Support\Assets2_1.zip
02/18/16 15:31:57:949 | [INFO] | | OOBE | DE | | | | 7388 | Setting file open option to false in the unzipper
02/18/16 15:31:58:593 | [INFO] | | OOBE | DE | | | | 7388 | Extracting assets complete. Number assets: 1
02/18/16 15:31:58:594 | [INFO] | | OOBE | DE | | | | 7388 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-Support\Install.db
02/18/16 15:32:02:476 | [INFO] | | OOBE | DE | | | | 7388 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-Support\Install.db
02/18/16 15:32:02:699 | [INFO] | | OOBE | DE | | | | 7388 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{3FB7A108-368A-4849-A3F3-69571BAAC457}.db
02/18/16 15:32:03:067 | [INFO] | | OOBE | DE | | | | 4836 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:32:03:067 | [INFO] | | OOBE | DE | | | | 4836 | :: END TIMER :: [Payload Operation :{3FB7A108-368A-4849-A3F3-69571BAAC457}] took 5237.05 milliseconds (5.23705 seconds) DTR = 1238.1 KBPS (1.20908 MBPS)
02/18/16 15:32:03:593 | [INFO] | | OOBE | DE | | | | 4836 | User specified overrideFile:
02/18/16 15:32:03:876 | [INFO] | | OOBE | DE | | | | 4836 | Successfully updated the csu inventory for Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457} return values 0:0
02/18/16 15:32:03:877 | [INFO] | | OOBE | DE | | | | 4836 | Calling the custom action code for post-install for payload Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}
02/18/16 15:32:07:054 | [INFO] | | OOBE | DE | | | | 4836 | Calling the custom action code for pre-install for payload Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}
02/18/16 15:32:07:055 | [INFO] | | OOBE | DE | | | | 4836 | ::START TIMER:: [Payload Operation :{A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}]
02/18/16 15:32:07:067 | [INFO] | | OOBE | DE | | | | 5740 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:32:07:067 | [INFO] | | OOBE | DE | | | | 5740 | Installer Operation: PayloadInstaller
02/18/16 15:32:07:067 | [INFO] | | OOBE | DE | | | | 5740 | Request to install payload
02/18/16 15:32:07:081 | [INFO] | | OOBE | DE | | | | 5740 | Payload Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 15:32:07:186 | [INFO] | | OOBE | DE | | | | 5740 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePreview1.0All-win64\Assets2_1.zip
02/18/16 15:32:07:186 | [INFO] | | OOBE | DE | | | | 5740 | Setting file open option to false in the unzipper
02/18/16 15:32:15:187 | [INFO] | | OOBE | DE | | | | 5740 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePreview1.0All-win64\Assets1_1.zip
02/18/16 15:32:15:187 | [INFO] | | OOBE | DE | | | | 5740 | Setting file open option to false in the unzipper
02/18/16 15:32:18:923 | [INFO] | | OOBE | DE | | | | 5740 | Extracting assets complete. Number assets: 2
02/18/16 15:32:18:923 | [INFO] | | OOBE | DE | | | | 5740 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePreview1.0All-win64\Install.db
02/18/16 15:35:08:386 | [INFO] | | OOBE | DE | | | | 5740 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePreview1.0All-win64\Install.db
02/18/16 15:35:08:675 | [INFO] | | OOBE | DE | | | | 5740 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}.db
02/18/16 15:35:09:587 | [INFO] | | OOBE | DE | | | | 4836 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:35:09:587 | [INFO] | | OOBE | DE | | | | 4836 | :: END TIMER :: [Payload Operation :{A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}] took 182535 milliseconds (182.535 seconds) DTR = 114.126 KBPS (0.111451 MBPS)
02/18/16 15:35:09:836 | [INFO] | | OOBE | DE | | | | 4836 | User specified overrideFile:
02/18/16 15:35:10:076 | [INFO] | | OOBE | DE | | | | 4836 | Successfully updated the csu inventory for Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3} return values 0:0
02/18/16 15:35:10:077 | [INFO] | | OOBE | DE | | | | 4836 | Calling the custom action code for post-install for payload Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}
02/18/16 15:35:13:255 | [INFO] | | OOBE | DE | | | | 4836 | Calling the custom action code for pre-install for payload AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}
02/18/16 15:35:13:256 | [INFO] | | OOBE | DE | | | | 4836 | ::START TIMER:: [Payload Operation :{C4196275-B11A-40A1-8727-3C145C8F7D95}]
02/18/16 15:35:13:270 | [INFO] | | OOBE | DE | | | | 3484 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:35:13:270 | [INFO] | | OOBE | DE | | | | 3484 | Installer Operation: PayloadInstaller
02/18/16 15:35:13:270 | [INFO] | | OOBE | DE | | | | 3484 | Request to install payload
02/18/16 15:35:13:283 | [INFO] | | OOBE | DE | | | | 3484 | Payload AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 15:35:13:302 | [INFO] | | OOBE | DE | | | | 3484 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorCommonSetCMYK5_0-mul\Assets2_1.zip
02/18/16 15:35:13:302 | [INFO] | | OOBE | DE | | | | 3484 | Setting file open option to false in the unzipper
02/18/16 15:35:13:654 | [INFO] | | OOBE | DE | | | | 3484 | Extracting assets complete. Number assets: 1
02/18/16 15:35:13:654 | [INFO] | | OOBE | DE | | | | 3484 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorCommonSetCMYK5_0-mul\Install.db
02/18/16 15:35:16:285 | [INFO] | | OOBE | DE | | | | 3484 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorCommonSetCMYK5_0-mul\Install.db
02/18/16 15:35:16:453 | [INFO] | | OOBE | DE | | | | 3484 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{C4196275-B11A-40A1-8727-3C145C8F7D95}.db
02/18/16 15:35:16:776 | [INFO] | | OOBE | DE | | | | 4836 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:35:16:776 | [INFO] | | OOBE | DE | | | | 4836 | :: END TIMER :: [Payload Operation :{C4196275-B11A-40A1-8727-3C145C8F7D95}] took 3520.55 milliseconds (3.52055 seconds) DTR = 22.7237 KBPS (0.0221911 MBPS)
02/18/16 15:35:17:114 | [INFO] | | OOBE | DE | | | | 4836 | User specified overrideFile:
02/18/16 15:35:17:425 | [INFO] | | OOBE | DE | | | | 4836 | Successfully updated the csu inventory for AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95} return values 0:0
02/18/16 15:35:17:426 | [INFO] | | OOBE | DE | | | | 4836 | Calling the custom action code for post-install for payload AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}
02/18/16 15:35:20:569 | [INFO] | | OOBE | DE | | | | 4836 | Calling the custom action code for pre-install for payload AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}
02/18/16 15:35:20:570 | [INFO] | | OOBE | DE | | | | 4836 | ::START TIMER:: [Payload Operation :{C8DEBB29-3EB0-4B97-B652-4DE482B111BC}]
02/18/16 15:35:20:583 | [INFO] | | OOBE | DE | | | | 7972 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:35:20:583 | [INFO] | | OOBE | DE | | | | 7972 | Installer Operation: PayloadInstaller
02/18/16 15:35:20:583 | [INFO] | | OOBE | DE | | | | 7972 | Request to install payload
02/18/16 15:35:20:597 | [INFO] | | OOBE | DE | | | | 7972 | Payload AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 15:35:20:615 | [INFO] | | OOBE | DE | | | | 7972 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorCommonSetRGB5_0-mul\Assets2_1.zip
02/18/16 15:35:20:615 | [INFO] | | OOBE | DE | | | | 7972 | Setting file open option to false in the unzipper
02/18/16 15:35:20:681 | [INFO] | | OOBE | DE | | | | 7972 | Extracting assets complete. Number assets: 1
02/18/16 15:35:20:681 | [INFO] | | OOBE | DE | | | | 7972 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorCommonSetRGB5_0-mul\Install.db
02/18/16 15:35:20:775 | [INFO] | | OOBE | DE | | | | 7972 | Collection adbeadbeadbeadbeadbeadbeadbeadb already exists(Seq 1)
02/18/16 15:35:21:685 | [INFO] | | OOBE | DE | | | | 7972 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorCommonSetRGB5_0-mul\Install.db
02/18/16 15:35:21:863 | [INFO] | | OOBE | DE | | | | 7972 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{C8DEBB29-3EB0-4B97-B652-4DE482B111BC}.db
02/18/16 15:35:22:183 | [INFO] | | OOBE | DE | | | | 4836 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:35:22:183 | [INFO] | | OOBE | DE | | | | 4836 | :: END TIMER :: [Payload Operation :{C8DEBB29-3EB0-4B97-B652-4DE482B111BC}] took 1613.17 milliseconds (1.61317 seconds) DTR = 47.1122 KBPS (0.0460081 MBPS)
02/18/16 15:35:22:448 | [INFO] | | OOBE | DE | | | | 4836 | User specified overrideFile:
02/18/16 15:35:22:711 | [INFO] | | OOBE | DE | | | | 4836 | Successfully updated the csu inventory for AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC} return values 0:0
02/18/16 15:35:22:712 | [INFO] | | OOBE | DE | | | | 4836 | Calling the custom action code for post-install for payload AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}
02/18/16 15:35:26:138 | [INFO] | | OOBE | DE | | | | 4836 | Calling the custom action code for pre-install for payload AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}
02/18/16 15:35:26:138 | [INFO] | | OOBE | DE | | | | 4836 | ::START TIMER:: [Payload Operation :{F6DED2DA-1D20-497E-8810-E745B45DCD28}]
02/18/16 15:35:26:154 | [INFO] | | OOBE | DE | | | | 7256 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:35:26:154 | [INFO] | | OOBE | DE | | | | 7256 | Installer Operation: PayloadInstaller
02/18/16 15:35:26:154 | [INFO] | | OOBE | DE | | | | 7256 | Request to install payload
02/18/16 15:35:26:168 | [INFO] | | OOBE | DE | | | | 7256 | Payload AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 15:35:26:186 | [INFO] | | OOBE | DE | | | | 7256 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorEU_ExtraSettings5_0-mul\Assets2_1.zip
02/18/16 15:35:26:186 | [INFO] | | OOBE | DE | | | | 7256 | Setting file open option to false in the unzipper
02/18/16 15:35:26:270 | [INFO] | | OOBE | DE | | | | 7256 | Extracting assets complete. Number assets: 1
02/18/16 15:35:26:270 | [INFO] | | OOBE | DE | | | | 7256 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorEU_ExtraSettings5_0-mul\Install.db
02/18/16 15:35:26:662 | [INFO] | | OOBE | DE | | | | 7256 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorEU_ExtraSettings5_0-mul\Install.db
02/18/16 15:35:26:818 | [INFO] | | OOBE | DE | | | | 7256 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{F6DED2DA-1D20-497E-8810-E745B45DCD28}.db
02/18/16 15:35:27:254 | [INFO] | | OOBE | DE | | | | 4836 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:35:27:254 | [INFO] | | OOBE | DE | | | | 4836 | :: END TIMER :: [Payload Operation :{F6DED2DA-1D20-497E-8810-E745B45DCD28}] took 1115.7 milliseconds (1.1157 seconds) DTR = 64.5333 KBPS (0.0630208 MBPS)
02/18/16 15:35:27:535 | [INFO] | | OOBE | DE | | | | 4836 | User specified overrideFile:
02/18/16 15:35:27:739 | [INFO] | | OOBE | DE | | | | 4836 | Successfully updated the csu inventory for AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28} return values 0:0
02/18/16 15:35:27:740 | [INFO] | | OOBE | DE | | | | 4836 | Calling the custom action code for post-install for payload AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}
02/18/16 15:35:30:918 | [INFO] | | OOBE | DE | | | | 4836 | Calling the custom action code for pre-install for payload AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}
02/18/16 15:35:31:168 | [INFO] | | OOBE | DE | | | | 4836 | ::START TIMER:: [Payload Operation :{A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}]
02/18/16 15:35:31:184 | [INFO] | | OOBE | DE | | | | 2156 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:35:31:184 | [INFO] | | OOBE | DE | | | | 2156 | Installer Operation: PayloadInstaller
02/18/16 15:35:31:184 | [INFO] | | OOBE | DE | | | | 2156 | Request to install payload
02/18/16 15:35:31:201 | [INFO] | | OOBE | DE | | | | 2156 | Payload AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 15:35:31:220 | [INFO] | | OOBE | DE | | | | 2156 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorJA_ExtraSettings5_0-mul\Assets2_1.zip
02/18/16 15:35:31:220 | [INFO] | | OOBE | DE | | | | 2156 | Setting file open option to false in the unzipper
02/18/16 15:35:31:398 | [INFO] | | OOBE | DE | | | | 2156 | Extracting assets complete. Number assets: 1
02/18/16 15:35:31:398 | [INFO] | | OOBE | DE | | | | 2156 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorJA_ExtraSettings5_0-mul\Install.db
02/18/16 15:35:31:896 | [INFO] | | OOBE | DE | | | | 2156 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorJA_ExtraSettings5_0-mul\Install.db
02/18/16 15:35:32:046 | [INFO] | | OOBE | DE | | | | 2156 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}.db
02/18/16 15:35:32:300 | [INFO] | | OOBE | DE | | | | 4836 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:35:32:300 | [INFO] | | OOBE | DE | | | | 4836 | :: END TIMER :: [Payload Operation :{A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}] took 1132.46 milliseconds (1.13246 seconds) DTR = 63.5786 KBPS (0.0620885 MBPS)
02/18/16 15:35:32:683 | [INFO] | | OOBE | DE | | | | 4836 | User specified overrideFile:
02/18/16 15:35:33:145 | [INFO] | | OOBE | DE | | | | 4836 | Successfully updated the csu inventory for AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB} return values 0:0
02/18/16 15:35:33:176 | [INFO] | | OOBE | DE | | | | 4836 | Calling the custom action code for post-install for payload AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}
02/18/16 15:35:36:695 | [INFO] | | OOBE | DE | | | | 4836 | Calling the custom action code for pre-install for payload AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}
02/18/16 15:35:36:697 | [INFO] | | OOBE | DE | | | | 4836 | ::START TIMER:: [Payload Operation :{AB955DCF-69CD-4840-B7FB-F318CDD0AE44}]
02/18/16 15:35:36:711 | [INFO] | | OOBE | DE | | | | 5388 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:35:36:711 | [INFO] | | OOBE | DE | | | | 5388 | Installer Operation: PayloadInstaller
02/18/16 15:35:36:711 | [INFO] | | OOBE | DE | | | | 5388 | Request to install payload
02/18/16 15:35:36:727 | [INFO] | | OOBE | DE | | | | 5388 | Payload AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 15:35:36:752 | [INFO] | | OOBE | DE | | | | 5388 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorNA_Recommended5_0-mul\Assets2_1.zip
02/18/16 15:35:36:752 | [INFO] | | OOBE | DE | | | | 5388 | Setting file open option to false in the unzipper
02/18/16 15:35:36:840 | [INFO] | | OOBE | DE | | | | 5388 | Extracting assets complete. Number assets: 1
02/18/16 15:35:36:840 | [INFO] | | OOBE | DE | | | | 5388 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorNA_Recommended5_0-mul\Install.db
02/18/16 15:35:37:773 | [INFO] | | OOBE | DE | | | | 5388 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorNA_Recommended5_0-mul\Install.db
02/18/16 15:35:37:951 | [INFO] | | OOBE | DE | | | | 5388 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{AB955DCF-69CD-4840-B7FB-F318CDD0AE44}.db
02/18/16 15:35:38:211 | [INFO] | | OOBE | DE | | | | 4836 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:35:38:211 | [INFO] | | OOBE | DE | | | | 4836 | :: END TIMER :: [Payload Operation :{AB955DCF-69CD-4840-B7FB-F318CDD0AE44}] took 1514.52 milliseconds (1.51452 seconds) DTR = 47.5397 KBPS (0.0464255 MBPS)
02/18/16 15:35:38:535 | [INFO] | | OOBE | DE | | | | 4836 | User specified overrideFile:
02/18/16 15:35:38:843 | [INFO] | | OOBE | DE | | | | 4836 | Successfully updated the csu inventory for AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44} return values 0:0
02/18/16 15:35:38:843 | [INFO] | | OOBE | DE | | | | 4836 | Calling the custom action code for post-install for payload AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}
02/18/16 15:35:42:063 | [INFO] | | OOBE | DE | | | | 4836 | Calling the custom action code for pre-install for payload AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}
02/18/16 15:35:42:063 | [INFO] | | OOBE | DE | | | | 4836 | ::START TIMER:: [Payload Operation :{5C5D62C9-91C6-415E-857E-9130C0F52C66}]
02/18/16 15:35:42:077 | [INFO] | | OOBE | DE | | | | 3160 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:35:42:078 | [INFO] | | OOBE | DE | | | | 3160 | Installer Operation: PayloadInstaller
02/18/16 15:35:42:078 | [INFO] | | OOBE | DE | | | | 3160 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:35:42:078 | [INFO] | | OOBE | DE | | | | 3160 | Request to install payload
02/18/16 15:35:42:091 | [INFO] | | OOBE | DE | | | | 3160 | Payload AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 15:35:42:110 | [INFO] | | OOBE | DE | | | | 3160 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorPhotoshop5_0-mul\Assets2_1.zip
02/18/16 15:35:42:110 | [INFO] | | OOBE | DE | | | | 3160 | Setting file open option to false in the unzipper
02/18/16 15:35:42:149 | [INFO] | | OOBE | DE | | | | 3160 | Extracting assets complete. Number assets: 1
02/18/16 15:35:42:149 | [INFO] | | OOBE | DE | | | | 3160 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorPhotoshop5_0-mul\Install.db
02/18/16 15:35:42:306 | [INFO] | | OOBE | DE | | | | 3160 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorPhotoshop5_0-mul\Install.db
02/18/16 15:35:42:473 | [INFO] | | OOBE | DE | | | | 3160 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{5C5D62C9-91C6-415E-857E-9130C0F52C66}.db
02/18/16 15:35:42:677 | [INFO] | | OOBE | DE | | | | 4836 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:35:42:677 | [INFO] | | OOBE | DE | | | | 4836 | :: END TIMER :: [Payload Operation :{5C5D62C9-91C6-415E-857E-9130C0F52C66}] took 613.755 milliseconds (0.613755 seconds) DTR = 117.311 KBPS (0.114561 MBPS)
02/18/16 15:35:43:432 | [INFO] | | OOBE | DE | | | | 4836 | User specified overrideFile:
02/18/16 15:35:43:754 | [INFO] | | OOBE | DE | | | | 4836 | Successfully updated the csu inventory for AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66} return values 0:0
02/18/16 15:35:43:755 | [INFO] | | OOBE | DE | | | | 4836 | Calling the custom action code for post-install for payload AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}
02/18/16 15:35:46:974 | [INFO] | | OOBE | DE | | | | 4836 | Calling the custom action code for pre-install for payload AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}
02/18/16 15:35:47:042 | [INFO] | | OOBE | DE | | | | 4836 | ::START TIMER:: [Payload Operation :{CE9B1B00-0421-4701-9698-1C14646D6D94}]
02/18/16 15:35:47:059 | [INFO] | | OOBE | DE | | | | 5220 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:35:47:059 | [INFO] | | OOBE | DE | | | | 5220 | Installer Operation: PayloadInstaller
02/18/16 15:35:47:059 | [INFO] | | OOBE | DE | | | | 5220 | Request to install payload
02/18/16 15:35:47:074 | [INFO] | | OOBE | DE | | | | 5220 | Payload AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 15:35:47:093 | [INFO] | | OOBE | DE | | | | 5220 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeVideoProfilesCS5_0-mul\Assets2_1.zip
02/18/16 15:35:47:094 | [INFO] | | OOBE | DE | | | | 5220 | Setting file open option to false in the unzipper
02/18/16 15:35:47:136 | [INFO] | | OOBE | DE | | | | 5220 | Extracting assets complete. Number assets: 1
02/18/16 15:35:47:136 | [INFO] | | OOBE | DE | | | | 5220 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeVideoProfilesCS5_0-mul\Install.db
02/18/16 15:35:47:141 | [INFO] | | OOBE | DE | | | | 5220 | Collection adbeadbeadbeadbeadbeadbeadbeadb already exists(Seq 1)
02/18/16 15:35:47:296 | [INFO] | | OOBE | DE | | | | 5220 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeVideoProfilesCS5_0-mul\Install.db
02/18/16 15:35:47:589 | [INFO] | | OOBE | DE | | | | 5220 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{CE9B1B00-0421-4701-9698-1C14646D6D94}.db
02/18/16 15:35:47:787 | [INFO] | | OOBE | DE | | | | 4836 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:35:47:787 | [INFO] | | OOBE | DE | | | | 4836 | :: END TIMER :: [Payload Operation :{CE9B1B00-0421-4701-9698-1C14646D6D94}] took 744.729 milliseconds (0.744729 seconds) DTR = 182.617 KBPS (0.178337 MBPS)
02/18/16 15:35:48:157 | [INFO] | | OOBE | DE | | | | 4836 | User specified overrideFile:
02/18/16 15:35:48:376 | [INFO] | | OOBE | DE | | | | 4836 | Successfully updated the csu inventory for AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94} return values 0:0
02/18/16 15:35:48:377 | [INFO] | | OOBE | DE | | | | 4836 | Calling the custom action code for post-install for payload AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}
02/18/16 15:35:51:609 | [INFO] | | OOBE | DE | | | | 4836 | Calling the custom action code for pre-install for payload Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}
02/18/16 15:35:51:609 | [INFO] | | OOBE | DE | | | | 4836 | ::START TIMER:: [Payload Operation :{27375F7C-0789-4FEA-889E-41BF12AC3140}]
02/18/16 15:35:51:626 | [INFO] | | OOBE | DE | | | | 1512 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:35:51:626 | [INFO] | | OOBE | DE | | | | 1512 | Installer Operation: PayloadInstaller
02/18/16 15:35:51:626 | [INFO] | | OOBE | DE | | | | 1512 | Request to install payload
02/18/16 15:35:51:640 | [INFO] | | OOBE | DE | | | | 1512 | Payload Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 15:35:51:659 | [INFO] | | OOBE | DE | | | | 1512 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeExportAssets2.0All-x64\Assets2_1.zip
02/18/16 15:35:51:659 | [INFO] | | OOBE | DE | | | | 1512 | Setting file open option to false in the unzipper
02/18/16 15:35:56:467 | [INFO] | | OOBE | DE | | | | 1512 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeExportAssets2.0All-x64\Assets1_1.zip
02/18/16 15:35:56:467 | [INFO] | | OOBE | DE | | | | 1512 | Setting file open option to false in the unzipper
02/18/16 15:35:57:618 | [INFO] | | OOBE | DE | | | | 1512 | Extracting assets complete. Number assets: 2
02/18/16 15:35:57:619 | [INFO] | | OOBE | DE | | | | 1512 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeExportAssets2.0All-x64\Install.db
02/18/16 15:37:33:324 | [INFO] | | OOBE | DE | | | | 1512 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeExportAssets2.0All-x64\Install.db
02/18/16 15:37:33:514 | [INFO] | | OOBE | DE | | | | 1512 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{27375F7C-0789-4FEA-889E-41BF12AC3140}.db
02/18/16 15:37:34:093 | [INFO] | | OOBE | DE | | | | 4836 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:37:34:093 | [INFO] | | OOBE | DE | | | | 4836 | :: END TIMER :: [Payload Operation :{27375F7C-0789-4FEA-889E-41BF12AC3140}] took 102483 milliseconds (102.483 seconds) DTR = 241.407 KBPS (0.235749 MBPS)
02/18/16 15:37:34:398 | [INFO] | | OOBE | DE | | | | 4836 | User specified overrideFile:
02/18/16 15:37:34:594 | [INFO] | | OOBE | DE | | | | 4836 | Successfully updated the csu inventory for Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140} return values 0:0
02/18/16 15:37:34:594 | [INFO] | | OOBE | DE | | | | 4836 | Calling the custom action code for post-install for payload Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}
02/18/16 15:37:34:595 | [INFO] | | OOBE | DE | | | | 4836 | DW034: Warning: Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9} will not be repaired, due to updated patch of the payload and one of the top level payload is being installed.
02/18/16 15:37:34:595 | [INFO] | | OOBE | DE | | | | 4836 | DW034: Warning: Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9} will not be repaired, due to updated patch of the payload and one of the top level payload is being installed.
02/18/16 15:37:34:595 | [INFO] | | OOBE | DE | | | | 4836 | DW034: Warning: Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20} will not be repaired, due to updated patch of the payload and one of the top level payload is being installed.
02/18/16 15:37:34:595 | [INFO] | | OOBE | DE | | | | 4836 | DW034: Warning: Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC} will not be repaired, due to updated patch of the payload and one of the top level payload is being installed.
02/18/16 15:37:38:012 | [INFO] | | OOBE | DE | | | | 4836 | Calling the custom action code for pre-install for payload Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}
02/18/16 15:37:38:013 | [INFO] | | OOBE | DE | | | | 4836 | ::START TIMER:: [Payload Operation :{4CED09CB-0C96-4EAE-83C4-7D9B9456E613}]
02/18/16 15:37:38:028 | [INFO] | | OOBE | DE | | | | 5156 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:37:38:028 | [INFO] | | OOBE | DE | | | | 5156 | Installer Operation: InstallThirdPartyPayloadOperation
02/18/16 15:37:38:028 | [INFO] | | OOBE | DE | | | | 5156 | Installing third party payload
02/18/16 15:37:38:028 | [INFO] | | OOBE | DE | | | | 5156 | Third party application path:C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\Microsoft VC 2013 Redist (x64)\vcredist_x64.exe
02/18/16 15:37:38:029 | [INFO] | | OOBE | DE | | | | 5156 | CommandLine: /q /norestart
02/18/16 15:38:39:137 | [INFO] | | OOBE | DE | | | | 5156 | Third party payload completed. Testing return code: 0
02/18/16 15:38:57:428 | [INFO] | | OOBE | DE | | | | 4836 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:38:57:428 | [INFO] | | OOBE | DE | | | | 4836 | :: END TIMER :: [Payload Operation :{4CED09CB-0C96-4EAE-83C4-7D9B9456E613}] took 79418.3 milliseconds (79.4183 seconds) DTR = 4128.37 KBPS (4.03161 MBPS)
02/18/16 15:38:59:493 | [INFO] | | OOBE | DE | | | | 4836 | User specified overrideFile:
02/18/16 15:39:17:671 | [INFO] | | OOBE | DE | | | | 4836 | The csu inventory was not updated for payload Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}, value of local var is -1
02/18/16 15:39:17:671 | [INFO] | | OOBE | DE | | | | 4836 | Calling the custom action code for post-install for payload Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}
02/18/16 15:39:21:459 | [INFO] | | OOBE | DE | | | | 4836 | Calling the custom action code for pre-install for payload Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}
02/18/16 15:39:21:460 | [INFO] | | OOBE | DE | | | | 4836 | ::START TIMER:: [Payload Operation :{636D196A-789E-455D-825E-3FA79F67D446}]
02/18/16 15:39:21:531 | [INFO] | | OOBE | DE | | | | 7008 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:39:21:531 | [INFO] | | OOBE | DE | | | | 7008 | Installer Operation: InstallThirdPartyPayloadOperation
02/18/16 15:39:21:531 | [INFO] | | OOBE | DE | | | | 7008 | Installing third party payload
02/18/16 15:39:21:531 | [INFO] | | OOBE | DE | | | | 7008 | Third party application path:C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\Microsoft VC 2013 Redist (x86)\vcredist_x86.exe
02/18/16 15:39:21:531 | [INFO] | | OOBE | DE | | | | 7008 | CommandLine: /q /norestart
02/18/16 15:41:02:703 | [INFO] | | OOBE | DE | | | | 7008 | Third party payload completed. Testing return code: 0
02/18/16 15:41:24:177 | [INFO] | | OOBE | DE | | | | 4836 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:41:24:177 | [INFO] | | OOBE | DE | | | | 4836 | :: END TIMER :: [Payload Operation :{636D196A-789E-455D-825E-3FA79F67D446}] took 122715 milliseconds (122.715 seconds) DTR = 912.326 KBPS (0.890943 MBPS)
02/18/16 15:41:26:716 | [INFO] | | OOBE | DE | | | | 4836 | User specified overrideFile:
02/18/16 15:41:29:732 | [INFO] | | OOBE | DE | | | | 4836 | The csu inventory was not updated for payload Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}, value of local var is -1
02/18/16 15:41:29:733 | [INFO] | | OOBE | DE | | | | 4836 | Calling the custom action code for post-install for payload Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}
02/18/16 15:41:33:628 | [INFO] | | OOBE | DE | | | | 4836 | Calling the custom action code for pre-install for payload Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}
02/18/16 15:41:33:628 | [INFO] | | OOBE | DE | | | | 4836 | ::START TIMER:: [Payload Operation :{5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}]
02/18/16 15:41:33:640 | [INFO] | | OOBE | DE | | | | 6836 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:41:33:640 | [INFO] | | OOBE | DE | | | | 6836 | Installer Operation: PayloadInstaller
02/18/16 15:41:33:640 | [INFO] | | OOBE | DE | | | | 6836 | Request to install payload
02/18/16 15:41:33:654 | [INFO] | | OOBE | DE | | | | 6836 | Payload Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 15:41:33:674 | [INFO] | | OOBE | DE | | | | 6836 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeCameraRaw8.0All-x64\Assets1_1.zip
02/18/16 15:41:33:674 | [INFO] | | OOBE | DE | | | | 6836 | Setting file open option to false in the unzipper
02/18/16 15:41:34:982 | [INFO] | | OOBE | DE | | | | 6836 | Extracting assets complete. Number assets: 1
02/18/16 15:41:34:983 | [INFO] | | OOBE | DE | | | | 6836 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeCameraRaw8.0All-x64\Install.db
02/18/16 15:41:37:421 | [INFO] | | OOBE | DE | | | | 6836 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeCameraRaw8.0All-x64\Install.db
02/18/16 15:41:37:844 | [INFO] | | OOBE | DE | | | | 6836 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}.db
02/18/16 15:41:39:772 | [INFO] | | OOBE | DE | | | | 4836 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:41:39:772 | [INFO] | | OOBE | DE | | | | 4836 | :: END TIMER :: [Payload Operation :{5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}] took 6142.99 milliseconds (6.14299 seconds) DTR = 4485.76 KBPS (4.38063 MBPS)
02/18/16 15:41:44:559 | [INFO] | | OOBE | DE | | | | 4836 | User specified overrideFile:
02/18/16 15:41:50:304 | [INFO] | | OOBE | DE | | | | 4836 | Successfully updated the csu inventory for Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA} return values 0:0
02/18/16 15:41:50:305 | [INFO] | | OOBE | DE | | | | 4836 | Calling the custom action code for post-install for payload Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}
02/18/16 15:41:54:318 | [INFO] | | OOBE | DE | | | | 4836 | Calling the custom action code for pre-install for payload Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}
02/18/16 15:41:54:319 | [INFO] | | OOBE | DE | | | | 4836 | ::START TIMER:: [Payload Operation :{3E7FC757-D497-4C89-A935-7D38E2164E85}]
02/18/16 15:41:54:337 | [INFO] | | OOBE | DE | | | | 5088 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:41:54:337 | [INFO] | | OOBE | DE | | | | 5088 | Installer Operation: PayloadInstaller
02/18/16 15:41:54:337 | [INFO] | | OOBE | DE | | | | 5088 | Request to install payload
02/18/16 15:41:54:352 | [INFO] | | OOBE | DE | | | | 5088 | Payload Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 15:41:54:388 | [INFO] | | OOBE | DE | | | | 5088 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeCameraRaw8.0All\Assets1_1.zip
02/18/16 15:41:54:389 | [INFO] | | OOBE | DE | | | | 5088 | Setting file open option to false in the unzipper
02/18/16 15:41:55:841 | [INFO] | | OOBE | DE | | | | 5088 | Extracting assets complete. Number assets: 1
02/18/16 15:41:55:842 | [INFO] | | OOBE | DE | | | | 5088 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeCameraRaw8.0All\Install.db
02/18/16 15:41:56:579 | [INFO] | | OOBE | DE | | | | 5088 | Evaluating condition# 1(Seq 3)
02/18/16 15:41:56:580 | [INFO] | | OOBE | DE | | | | 5088 | Condition failed(Seq 3)
02/18/16 15:41:57:554 | [INFO] | | OOBE | DE | | | | 5088 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeCameraRaw8.0All\Install.db
02/18/16 15:41:59:154 | [INFO] | | OOBE | DE | | | | 5088 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{3E7FC757-D497-4C89-A935-7D38E2164E85}.db
02/18/16 15:42:01:038 | [INFO] | | OOBE | DE | | | | 4836 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:42:01:038 | [INFO] | | OOBE | DE | | | | 4836 | :: END TIMER :: [Payload Operation :{3E7FC757-D497-4C89-A935-7D38E2164E85}] took 6719.17 milliseconds (6.71917 seconds) DTR = 3727.84 KBPS (3.64047 MBPS)
02/18/16 15:42:04:862 | [INFO] | | OOBE | DE | | | | 4836 | User specified overrideFile:
02/18/16 15:42:11:476 | [INFO] | | OOBE | DE | | | | 4836 | Successfully updated the csu inventory for Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85} return values 0:0
02/18/16 15:42:11:476 | [INFO] | | OOBE | DE | | | | 4836 | Calling the custom action code for post-install for payload Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}
02/18/16 15:42:15:763 | [INFO] | | OOBE | DE | | | | 4836 | Calling the custom action code for pre-install for payload Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 15:42:15:764 | [INFO] | | OOBE | DE | | | | 4836 | ::START TIMER:: [Payload Operation :{793C2BF7-A4FE-4608-91C9-9282C5801C21}]
02/18/16 15:42:15:781 | [INFO] | | OOBE | DE | | | | 8104 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:42:15:781 | [INFO] | | OOBE | DE | | | | 8104 | Installer Operation: PayloadInstaller
02/18/16 15:42:15:781 | [INFO] | | OOBE | DE | | | | 8104 | Request to install payload
02/18/16 15:42:15:796 | [INFO] | | OOBE | DE | | | | 8104 | Payload Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 15:42:15:813 | [INFO] | | OOBE | DE | | | | 8104 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-Core_x64\Assets2_1.zip
02/18/16 15:42:15:813 | [INFO] | | OOBE | DE | | | | 8104 | Setting file open option to false in the unzipper
02/18/16 15:42:16:179 | [INFO] | | OOBE | DE | | | | 8104 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-Core_x64\Assets1_1.zip
02/18/16 15:42:16:179 | [INFO] | | OOBE | DE | | | | 8104 | Setting file open option to false in the unzipper
02/18/16 15:47:06:246 | [ERROR] | | OOBE | DE | | | | 3100 | ASU has quit unexpectedly.
02/18/16 15:47:33:033 | [INFO] | | OOBE | DE | | | | 8104 | Extracting assets complete. Number assets: 2
02/18/16 15:47:33:033 | [INFO] | | OOBE | DE | | | | 8104 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-Core_x64\Install.db
02/18/16 15:58:07:113 | [INFO] | | OOBE | DE | | | | 8104 | Evaluating condition# 2(Seq 3223)
02/18/16 15:58:07:120 | [INFO] | | OOBE | DE | | | | 8104 | Condition failed(Seq 3223)
02/18/16 15:58:10:218 | [INFO] | | OOBE | DE | | | | 8104 | Evaluating condition# 2(Seq 4549)
02/18/16 15:58:10:218 | [INFO] | | OOBE | DE | | | | 8104 | Condition failed(Seq 4549)
02/18/16 15:59:24:713 | [INFO] | | OOBE | DE | | | | 8104 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Brick Fill.jsx Group/User:BuiltinGuests Access:GENERIC_ALL(Seq 5286)
02/18/16 15:59:24:715 | [INFO] | | OOBE | DE | | | | 8104 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Brick Fill.jsx Group/User:BuiltinUsers Access:GENERIC_ALL(Seq 5287)
02/18/16 15:59:24:753 | [INFO] | | OOBE | DE | | | | 8104 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Cross Weave.jsx Group/User:BuiltinGuests Access:GENERIC_ALL(Seq 5289)
02/18/16 15:59:24:754 | [INFO] | | OOBE | DE | | | | 8104 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Cross Weave.jsx Group/User:BuiltinUsers Access:GENERIC_ALL(Seq 5290)
02/18/16 15:59:24:787 | [INFO] | | OOBE | DE | | | | 8104 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Flame.jsx Group/User:BuiltinGuests Access:GENERIC_ALL(Seq 5292)
02/18/16 15:59:24:788 | [INFO] | | OOBE | DE | | | | 8104 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Flame.jsx Group/User:BuiltinUsers Access:GENERIC_ALL(Seq 5293)
02/18/16 15:59:24:831 | [INFO] | | OOBE | DE | | | | 8104 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Picture Frame.jsx Group/User:BuiltinGuests Access:GENERIC_ALL(Seq 5295)
02/18/16 15:59:24:832 | [INFO] | | OOBE | DE | | | | 8104 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Picture Frame.jsx Group/User:BuiltinUsers Access:GENERIC_ALL(Seq 5296)
02/18/16 15:59:24:864 | [INFO] | | OOBE | DE | | | | 8104 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Place Along Path.jsx Group/User:BuiltinGuests Access:GENERIC_ALL(Seq 5298)
02/18/16 15:59:24:865 | [INFO] | | OOBE | DE | | | | 8104 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Place Along Path.jsx Group/User:BuiltinUsers Access:GENERIC_ALL(Seq 5299)
02/18/16 15:59:24:898 | [INFO] | | OOBE | DE | | | | 8104 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Random Fill.jsx Group/User:BuiltinGuests Access:GENERIC_ALL(Seq 5301)
02/18/16 15:59:24:899 | [INFO] | | OOBE | DE | | | | 8104 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Random Fill.jsx Group/User:BuiltinUsers Access:GENERIC_ALL(Seq 5302)
02/18/16 15:59:24:932 | [INFO] | | OOBE | DE | | | | 8104 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Spiral.jsx Group/User:BuiltinGuests Access:GENERIC_ALL(Seq 5304)
02/18/16 15:59:24:933 | [INFO] | | OOBE | DE | | | | 8104 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Spiral.jsx Group/User:BuiltinUsers Access:GENERIC_ALL(Seq 5305)
02/18/16 15:59:24:934 | [INFO] | | OOBE | DE | | | | 8104 | Setting permission for: C:\Program Files\Adobe/Adobe Photoshop CC 2015/Presets/Deco Group/User:Everyone Access:GENERIC_ALL(Seq 5306)
02/18/16 15:59:24:969 | [INFO] | | OOBE | DE | | | | 8104 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Symmetry Fill.jsx Group/User:BuiltinGuests Access:GENERIC_ALL(Seq 5308)
02/18/16 15:59:24:970 | [INFO] | | OOBE | DE | | | | 8104 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Symmetry Fill.jsx Group/User:BuiltinUsers Access:GENERIC_ALL(Seq 5309)
02/18/16 15:59:24:998 | [INFO] | | OOBE | DE | | | | 8104 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Tree.jsx Group/User:BuiltinGuests Access:GENERIC_ALL(Seq 5311)
02/18/16 15:59:24:999 | [INFO] | | OOBE | DE | | | | 8104 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Tree.jsx Group/User:BuiltinUsers Access:GENERIC_ALL(Seq 5312)
02/18/16 15:59:25:031 | [INFO] | | OOBE | DE | | | | 8104 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\_Deco Menu.jsx Group/User:BuiltinGuests Access:GENERIC_ALL(Seq 5314)
02/18/16 15:59:25:033 | [INFO] | | OOBE | DE | | | | 8104 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\_Deco Menu.jsx Group/User:BuiltinUsers Access:GENERIC_ALL(Seq 5315)
02/18/16 15:59:25:064 | [INFO] | | OOBE | DE | | | | 8104 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\_Deco Settings.jsx Group/User:BuiltinGuests Access:GENERIC_ALL(Seq 5317)
02/18/16 15:59:25:065 | [INFO] | | OOBE | DE | | | | 8104 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\_Deco Settings.jsx Group/User:BuiltinUsers Access:GENERIC_ALL(Seq 5318)
02/18/16 15:59:40:141 | [INFO] | | OOBE | DE | | | | 8104 | Evaluating condition# 1(Seq 5565)
02/18/16 15:59:40:141 | [INFO] | | OOBE | DE | | | | 8104 | Condition passed(Seq 5565)
02/18/16 15:59:42:274 | [INFO] | | OOBE | DE | | | | 8104 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-Core_x64\Install.db
02/18/16 15:59:44:196 | [INFO] | | OOBE | DE | | | | 8104 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{793C2BF7-A4FE-4608-91C9-9282C5801C21}.db
02/18/16 15:59:48:661 | [INFO] | | OOBE | DE | | | | 4836 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 15:59:48:661 | [INFO] | | OOBE | DE | | | | 4836 | :: END TIMER :: [Payload Operation :{793C2BF7-A4FE-4608-91C9-9282C5801C21}] took 1.05288e+006 milliseconds (1052.88 seconds) DTR = 2061.26 KBPS (2.01295 MBPS)
02/18/16 15:59:51:106 | [INFO] | | OOBE | DE | | | | 4836 | User specified overrideFile:
02/18/16 15:59:55:425 | [INFO] | | OOBE | DE | | | | 4836 | Successfully updated the csu inventory for Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21} return values 0:0
02/18/16 15:59:55:426 | [INFO] | | OOBE | DE | | | | 4836 | Calling the custom action code for post-install for payload Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 15:59:55:426 | [INFO] | | OOBE | DE | | | | 4836 | Running PreferenceMigration tool for Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 15:59:55:426 | [INFO] | | OOBE | DE | | | | 4836 | OOBEUtils|ProcessUtils|||Launching Process as DeElevated:C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-Core_x64\PhotoshopPrefsManager.exe
02/18/16 15:59:57:173 | [INFO] | | OOBE | DE | | | | 4836 | OOBEUtils|ProcessUtils|||Launching Process as DeElevated :C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-Core_x64\PhotoshopPrefsManager.exe : SUCCESSFUL
02/18/16 15:59:57:173 | [INFO] | | OOBE | DE | | | | 4836 | Finished running PreferenceMigration tool. Exit code: 0
02/18/16 15:59:57:174 | [ERROR] | | OOBE | DE | | | | 4836 | DW001: Set payload cancelled status
02/18/16 15:59:57:174 | [INFO] | | OOBE | DE | | | | 4836 | No operation. We're done:
02/18/16 15:59:57:178 | [INFO] | | OOBE | DE | | | | 4836 | Updating driver data - Action: Remove driver entry
02/18/16 15:59:57:264 | [INFO] | | OOBE | DE | | | | 4836 | Updating driver data successful. Driver entry was added. ARP estimated size 1997481KB
02/18/16 15:59:59:698 | [INFO] | | OOBE | DE | | | | 4836 | Successfully installed 15 components:
02/18/16 15:59:59:698 | [INFO] | | OOBE | DE | | | | 4836 | - Export Assets 2 (64 bit)
02/18/16 15:59:59:699 | [INFO] | | OOBE | DE | | | | 4836 | - Photoshop Camera Raw 8
02/18/16 15:59:59:699 | [INFO] | | OOBE | DE | | | | 4836 | - Adobe Photoshop CC 2015 Support
02/18/16 15:59:59:699 | [INFO] | | OOBE | DE | | | | 4836 | - Microsoft Visual C++ 2013 Redistributable Package (x64)
02/18/16 15:59:59:699 | [INFO] | | OOBE | DE | | | | 4836 | - Camera Profiles Installer
02/18/16 15:59:59:699 | [INFO] | | OOBE | DE | | | | 4836 | - AdobeColorPhotoshop CC
02/18/16 15:59:59:699 | [INFO] | | OOBE | DE | | | | 4836 | - Photoshop Camera Raw 8 (64 bit)
02/18/16 15:59:59:699 | [INFO] | | OOBE | DE | | | | 4836 | - Microsoft Visual C++ 2013 Redistributable Package (x86)
02/18/16 15:59:59:699 | [INFO] | | OOBE | DE | | | | 4836 | - AdobeColorJA CC
02/18/16 15:59:59:699 | [INFO] | | OOBE | DE | | | | 4836 | - Adobe Preview CC
02/18/16 15:59:59:699 | [INFO] | | OOBE | DE | | | | 4836 | - AdobeColorNA CC
02/18/16 15:59:59:699 | [INFO] | | OOBE | DE | | | | 4836 | - AdobeColorCommonSetCMYK CC
02/18/16 15:59:59:699 | [INFO] | | OOBE | DE | | | | 4836 | - AdobeColorCommonSetRGB CC
02/18/16 15:59:59:699 | [INFO] | | OOBE | DE | | | | 4836 | - AdobeColorVideoProfilesCS CC
02/18/16 15:59:59:699 | [INFO] | | OOBE | DE | | | | 4836 | - AdobeColorEU CC
02/18/16 15:59:59:699 | [INFO] | | OOBE | DE | | | | 4836 | Successfully repaired 4 components:
02/18/16 15:59:59:699 | [INFO] | | OOBE | DE | | | | 4836 | - Microsoft Visual C++ 2012 Redistributable Package (x64)
02/18/16 15:59:59:699 | [INFO] | | OOBE | DE | | | | 4836 | - Microsoft Visual C++ 2010 Redistributable Package (x64)
02/18/16 15:59:59:699 | [INFO] | | OOBE | DE | | | | 4836 | - Microsoft Visual C++ 2010 Redistributable Package (x86)
02/18/16 15:59:59:699 | [INFO] | | OOBE | DE | | | | 4836 | - Microsoft Visual C++ 2012 Redistributable Package (x86)
02/18/16 15:59:59:699 | [INFO] | | OOBE | DE | | | | 4836 | Total components removed: 0
02/18/16 15:59:59:699 | [WARN] | | OOBE | DE | | | | 4836 | DW050: The following payload errors were found during install:
02/18/16 15:59:59:699 | [WARN] | | OOBE | DE | | | | 4836 | DW050: - Adobe Photoshop CC 2015 Core: Installation was cancelled due to abnormal termination.
02/18/16 15:59:59:699 | [WARN] | | OOBE | DE | | | | 4836 | DW050: - Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64: Installation was cancelled due to abnormal termination.
02/18/16 15:59:59:700 | [INFO] | | OOBE | DE | | | | 4836 | Call PostSession Custom Hook
02/18/16 15:59:59:703 | [INFO] | | OOBE | DE | | | | 4836 | :: END TIMER :: [Total Timer] took 1.90676e+006 milliseconds (1906.76 seconds) DTR = 1616.18 KBPS (1.5783 MBPS)
02/18/16 16:00:00:704 | [INFO] | | OOBE | DE | | | | 4836 | -------------------------------------- Summary --------------------------------------
02/18/16 16:00:00:704 | [INFO] | | OOBE | DE | | | | 4836 | - 0 fatal error(s), 2 error(s)
02/18/16 16:00:00:704 | [INFO] | | OOBE | DE | | | | 4836 | Win OS version: 6.1.0.0 64 bit Type: 1
02/18/16 16:00:00:704 | [INFO] | | OOBE | DE | | | | 4836 | ----------- Payload: Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21} -----------
02/18/16 16:00:00:704 | [INFO] | | OOBE | DE | | | | 4836 | ERROR: ASU has quit unexpectedly.
02/18/16 16:00:00:704 | [INFO] | | OOBE | DE | | | | 4836 | ERROR: DW001: Set payload cancelled status
02/18/16 16:00:00:704 | [INFO] | | OOBE | DE | | | | 4836 | Please search the above error string(s) to find when the error occurred.
02/18/16 16:00:00:704 | [INFO] | | OOBE | DE | | | | 4836 | These errors resulted in installer Exit Code mentioned below.
02/18/16 16:00:00:704 | [INFO] | | OOBE | DE | | | | 4836 | -------------------------------------------------------------------------------------
02/18/16 16:00:00:704 | [INFO] | | OOBE | DE | | | | 4836 | Exit Code: 7 - Unable to complete Silent workflow.
02/18/16 16:00:00:707 | [INFO] | | OOBE | DE | | | | 4836 | Successfully dumped analytics data at: C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\{2E0014BF-75A4-42D3-9121-0D5D2A5E9FC7}
02/18/16 16:00:00:707 | [INFO] | | OOBE | DE | | | | 4836 | Please see specific errors for troubleshooting. For example, ERROR: DW001 ...
02/18/16 16:00:00:710 | [INFO] | | OOBE | DE | | | | 4836 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:00:00:710 | [INFO] | | OOBE | DE | | | | 4836 | END - Installer Session
02/18/16 16:20:00:404 | [INFO] | | OOBE | DE | | | | 1172 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:20:00:404 | [INFO] | | OOBE | DE | | | | 1172 | START - Installer Session
02/18/16 16:20:00:405 | [INFO] | | OOBE | DE | | | | 1172 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:20:00:405 | [INFO] | | OOBE | DE | | | | 1172 | RIBS version: 9.0.0.61
02/18/16 16:20:00:405 | [INFO] | | OOBE | DE | | | | 1172 | Win OS version: 6.1.0.0 64 bit Type: 1
02/18/16 16:20:00:405 | [INFO] | | OOBE | DE | | | | 1172 | ::START TIMER:: [Total Timer]
02/18/16 16:20:00:405 | [INFO] | | OOBE | DE | | | | 1172 | CHECK: Single instance running
02/18/16 16:20:00:405 | [INFO] | | OOBE | DE | | | | 1172 | CHECK : Credentials
02/18/16 16:20:00:405 | [INFO] | | OOBE | DE | | | | 1172 | Load Deployment File
02/18/16 16:20:00:405 | [INFO] | | OOBE | DE | | | | 1172 | CHECK : Another Native OS installer already running
02/18/16 16:20:00:405 | [INFO] | | OOBE | DE | | | | 1172 | Create Required Folders
02/18/16 16:20:00:405 | [INFO] | | OOBE | DE | | | | 1172 | Assuming install mode
02/18/16 16:20:00:405 | [INFO] | | OOBE | DE | | | | 1172 | Looking up install source path
02/18/16 16:20:00:405 | [INFO] | | OOBE | DE | | | | 1172 | Sync Media DB ...
02/18/16 16:20:00:405 | [INFO] | | OOBE | DE | | | | 1172 | ::START TIMER:: [Sync Media DB]
02/18/16 16:20:00:405 | [INFO] | | OOBE | DE | | | | 1172 | Pre check media db sync
02/18/16 16:20:00:405 | [INFO] | | OOBE | DE | | | | 1172 | End of Pre check media db sync. Exit code: 0
02/18/16 16:20:00:405 | [INFO] | | OOBE | DE | | | | 1172 | :: END TIMER :: [Sync Media DB] took 12176.9 milliseconds (12.1769 seconds)
02/18/16 16:20:00:405 | [INFO] | | OOBE | DE | | | | 1172 | Ready to initialize session to start with ...
02/18/16 16:20:00:405 | [INFO] | | OOBE | DE | | | | 1172 | ::START TIMER:: [CreatePayloadSession]
02/18/16 16:20:00:406 | [INFO] | | OOBE | DE | | | | 1172 | -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
02/18/16 16:20:00:406 | [INFO] | | OOBE | DE | | | | 1172 | Updated source path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015
02/18/16 16:20:00:406 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {00F35A9A-C859-4F6E-8C4F-70A7239207FF}
02/18/16 16:20:00:406 | [INFO] | | OOBE | DE | | | | 1172 | Ignoring original data since install source is local
02/18/16 16:20:00:406 | [INFO] | | OOBE | DE | | | | 1172 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-nb_NO_x64\Install.db
02/18/16 16:20:00:406 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA}
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-uk_UA_x64\Install.db
02/18/16 16:20:00:407 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {0CA9067E-B7E0-4C7A-BA40-987AF967A05D}
02/18/16 16:20:00:407 | [INFO] | | OOBE | DE | | | | 1172 | Ignoring original data since install source is local
02/18/16 16:20:00:407 | [INFO] | | OOBE | DE | | | | 1172 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-en_IL_x64\Install.db
02/18/16 16:20:00:407 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {0D30F03E-27D9-41F8-AF26-9F1801C2AE28}
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-fr_MA_x64\Install.db
02/18/16 16:20:00:407 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {18844AF8-051C-4227-9BE1-CA06F4364F9C}
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-zh_TW_x64\Install.db
02/18/16 16:20:00:408 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {1B7AE611-4C93-47FC-951F-0BD9839AB72B}
02/18/16 16:20:00:408 | [INFO] | | OOBE | DE | | | | 1172 | Ignoring original data since install source is local
02/18/16 16:20:00:408 | [INFO] | | OOBE | DE | | | | 1172 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-sv_SE_x64\Install.db
02/18/16 16:20:00:408 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {2060E7ED-C473-4A38-877F-C844E81B64F3}
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-nl_NL_x64\Install.db
02/18/16 16:20:00:408 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4}
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-es_MX_x64\Install.db
02/18/16 16:20:00:409 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {27375F7C-0789-4FEA-889E-41BF12AC3140}
02/18/16 16:20:00:409 | [INFO] | | OOBE | DE | | | | 1172 | Ignoring original data since install source is local
02/18/16 16:20:00:409 | [INFO] | | OOBE | DE | | | | 1172 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeExportAssets2.0All-x64\Install.db
02/18/16 16:20:00:409 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {3875BF24-5D9A-494A-A4FA-7AC70F56EC88}
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-zh_CN_x64\Install.db
02/18/16 16:20:00:409 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {3E272A93-C06B-4206-AD02-0EBE02535E20}
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\Microsoft VC 2012 Redist (x64)\vcredist_x64.exe
02/18/16 16:20:00:410 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {3E7FC757-D497-4C89-A935-7D38E2164E85}
02/18/16 16:20:00:410 | [INFO] | | OOBE | DE | | | | 1172 | Ignoring original data since install source is local
02/18/16 16:20:00:410 | [INFO] | | OOBE | DE | | | | 1172 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeCameraRaw8.0All\Install.db
02/18/16 16:20:00:410 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {3FB7A108-368A-4849-A3F3-69571BAAC457}
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-Support\Install.db
02/18/16 16:20:00:410 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {4A0115A5-CA14-4EA1-9896-2F161B5144B9}
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-pt_BR_x64\Install.db
02/18/16 16:20:00:411 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}
02/18/16 16:20:00:411 | [INFO] | | OOBE | DE | | | | 1172 | Ignoring original data since install source is local
02/18/16 16:20:00:411 | [INFO] | | OOBE | DE | | | | 1172 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\Microsoft VC 2013 Redist (x64)\vcredist_x64.exe
02/18/16 16:20:00:411 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4}
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-en_GB_x64\Install.db
02/18/16 16:20:00:411 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {52D57F95-000A-4922-BB31-C6A936F4FD7D}
02/18/16 16:20:00:412 | [INFO] | | OOBE | DE | | | | 1172 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorJA_Recommended5_0-mul\Install.db
02/18/16 16:20:00:412 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {5309436A-D12F-437D-B7A4-BF136E17139C}
02/18/16 16:20:00:412 | [INFO] | | OOBE | DE | | | | 1172 | Ignoring original data since install source is local
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-ko_KR_x64\Install.db
02/18/16 16:20:00:412 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\Microsoft VC 2010 Redist (x64)\vcredist_x64.exe
02/18/16 16:20:00:413 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {55B82130-18F9-11E2-8D43-00215AEA26C9}
02/18/16 16:20:00:503 | [INFO] | | OOBE | DE | | | | 1172 | Ignoring original data since install source is local
02/18/16 16:20:00:503 | [INFO] | | OOBE | DE | | | | 1172 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\Microsoft VC 2010 Redist (x86)\vcredist_x86.exe
02/18/16 16:20:00:503 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}
02/18/16 16:20:00:504 | [INFO] | | OOBE | DE | | | | 1172 | Ignoring original data since install source is local
02/18/16 16:20:00:504 | [INFO] | | OOBE | DE | | | | 1172 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeCameraRawProfile8.0All\Install.db
02/18/16 16:20:00:504 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {5C5D62C9-91C6-415E-857E-9130C0F52C66}
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorPhotoshop5_0-mul\Install.db
02/18/16 16:20:00:504 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeCameraRaw8.0All-x64\Install.db
02/18/16 16:20:00:505 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {636D196A-789E-455D-825E-3FA79F67D446}
02/18/16 16:20:00:505 | [INFO] | | OOBE | DE | | | | 1172 | Ignoring original data since install source is local
02/18/16 16:20:00:505 | [INFO] | | OOBE | DE | | | | 1172 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\Microsoft VC 2013 Redist (x86)\vcredist_x86.exe
02/18/16 16:20:00:505 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {644DC0CB-E8C9-4508-B99D-8747C6172621}
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-es_ES_x64\Install.db
02/18/16 16:20:00:505 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {69C13F4A-83B3-42F4-912C-C99F1442F439}
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-de_DE_x64\Install.db
02/18/16 16:20:00:506 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {6E14FFAB-83F4-4CB7-87A2-703F6F20487A}
02/18/16 16:20:00:506 | [INFO] | | OOBE | DE | | | | 1172 | Ignoring original data since install source is local
02/18/16 16:20:00:506 | [INFO] | | OOBE | DE | | | | 1172 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-ru_RU_x64\Install.db
02/18/16 16:20:00:506 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {6E7A3076-3056-492F-966F-1EA4FDCE5FA8}
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-en_AE_x64\Install.db
02/18/16 16:20:00:506 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {72405B80-A3DD-4BB2-A8C4-A90BC7BA50FF}
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorNA_ExtraSettings5_0-mul\Install.db
02/18/16 16:20:00:507 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {7433F860-160E-4024-8218-892D796972A6}
02/18/16 16:20:00:507 | [INFO] | | OOBE | DE | | | | 1172 | Ignoring original data since install source is local
02/18/16 16:20:00:507 | [INFO] | | OOBE | DE | | | | 1172 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-fr_CA_x64\Install.db
02/18/16 16:20:00:507 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {7787331E-D646-4CA4-ADCB-B264CC156D7D}
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-cs_CZ_x64\Install.db
02/18/16 16:20:00:507 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {778CE554-471C-4605-A600-852C976A4DC5}
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-ja_JP_x64\Install.db
02/18/16 16:20:00:508 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 16:20:00:508 | [INFO] | | OOBE | DE | | | | 1172 | Ignoring original data since install source is local
02/18/16 16:20:00:508 | [INFO] | | OOBE | DE | | | | 1172 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-Core_x64\Install.db
02/18/16 16:20:00:508 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {873BE68F-480F-49A6-9649-F98CAB056AFC}
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\Microsoft VC 2012 Redist (x86)\vcredist_x86.exe
02/18/16 16:20:00:508 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0}
02/18/16 16:20:00:509 | [INFO] | | OOBE | DE | | | | 1172 | Ignoring original data since install source is local
02/18/16 16:20:00:509 | [INFO] | | OOBE | DE | | | | 1172 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-pl_PL_x64\Install.db
02/18/16 16:20:00:509 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {960F21E4-EBDC-4A3E-80E9-C28D8A593F66}
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-it_IT_x64\Install.db
02/18/16 16:20:00:509 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {98D6FC60-7908-474A-A598-0D7A7BFEF2C2}
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-hu_HU_x64\Install.db
02/18/16 16:20:00:509 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {9E9EB9FD-FDE8-487A-A41C-7713DA91AC89}
02/18/16 16:20:00:510 | [INFO] | | OOBE | DE | | | | 1172 | Ignoring original data since install source is local
02/18/16 16:20:00:510 | [INFO] | | OOBE | DE | | | | 1172 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorEU_Recommended5_0-mul\Install.db
02/18/16 16:20:00:510 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorJA_ExtraSettings5_0-mul\Install.db
02/18/16 16:20:00:510 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePreview1.0All-win64\Install.db
02/18/16 16:20:00:510 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}
02/18/16 16:20:00:511 | [INFO] | | OOBE | DE | | | | 1172 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorNA_Recommended5_0-mul\Install.db
02/18/16 16:20:00:511 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {B75FB41B-E3E2-4B9F-93F7-62D982857374}
02/18/16 16:20:00:511 | [INFO] | | OOBE | DE | | | | 1172 | Ignoring original data since install source is local
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-fr_FR_x64\Install.db
02/18/16 16:20:00:511 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {BED85F42-B42C-4A91-946B-A928824C48A1}
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-tr_TR_x64\Install.db
02/18/16 16:20:00:511 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {C4196275-B11A-40A1-8727-3C145C8F7D95}
02/18/16 16:20:00:512 | [INFO] | | OOBE | DE | | | | 1172 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorCommonSetCMYK5_0-mul\Install.db
02/18/16 16:20:00:512 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {C43757D2-2F7F-41B4-9764-0FD8318DD860}
02/18/16 16:20:00:512 | [INFO] | | OOBE | DE | | | | 1172 | Ignoring original data since install source is local
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-en_US_x64\Install.db
02/18/16 16:20:00:512 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorCommonSetRGB5_0-mul\Install.db
02/18/16 16:20:00:512 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {CE9B1B00-0421-4701-9698-1C14646D6D94}
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeVideoProfilesCS5_0-mul\Install.db
02/18/16 16:20:00:513 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {F5D14B6C-DA16-4031-9EB8-AF0728550AFC}
02/18/16 16:20:00:513 | [INFO] | | OOBE | DE | | | | 1172 | Ignoring original data since install source is local
02/18/16 16:20:00:513 | [INFO] | | OOBE | DE | | | | 1172 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-da_DK_x64\Install.db
02/18/16 16:20:00:513 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {F6DED2DA-1D20-497E-8810-E745B45DCD28}
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorEU_ExtraSettings5_0-mul\Install.db
02/18/16 16:20:00:513 | [INFO] | | OOBE | DE | | | | 1172 | Updating media info for: {FD8B8694-1044-4481-A5D9-4740A46BBC3B}
Path: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-fi_FI_x64\Install.db
02/18/16 16:20:00:513 | [INFO] | | OOBE | DE | | | | 1172 | -------------------- END - Updating Media Sources - END --------------------
02/18/16 16:20:00:632 | [INFO] | | OOBE | DE | | | | 1172 | Supported RIBS version range: [0.0.0.0,9.0.0.61]
02/18/16 16:20:00:633 | [INFO] | | OOBE | DE | | | | 1172 | ----------------- CreatePayloadSession: machine is x64 ---------------
02/18/16 16:20:00:864 | [INFO] | | OOBE | DE | | | | 1172 | ______ Verify Dependency Subscribers ______
02/18/16 16:20:00:868 | [INFO] | | OOBE | DE | | | | 1172 | BEGIN Operation order for all session payloads: mediaGroup (requires,satisfies)
02/18/16 16:20:00:868 | [INFO] | | OOBE | DE | | | | 1172 | Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}: 1 (0,2)
02/18/16 16:20:00:868 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}: 2 (0,1)
02/18/16 16:20:00:868 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}: 2 (0,1)
02/18/16 16:20:00:868 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}: 2 (0,1)
02/18/16 16:20:00:868 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}: 2 (0,1)
02/18/16 16:20:00:868 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorEU CC 5.0.0.0 {9E9EB9FD-FDE8-487A-A41C-7713DA91AC89}: 2 (0,1)
02/18/16 16:20:00:868 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}: 2 (0,1)
02/18/16 16:20:00:868 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorJA CC 5.0.0.0 {52D57F95-000A-4922-BB31-C6A936F4FD7D}: 2 (0,1)
02/18/16 16:20:00:868 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}: 2 (0,1)
02/18/16 16:20:00:868 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorNA CC 5.0.0.0 {72405B80-A3DD-4BB2-A8C4-A90BC7BA50FF}: 2 (0,1)
02/18/16 16:20:00:869 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}: 2 (0,1)
02/18/16 16:20:00:869 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}: 2 (0,1)
02/18/16 16:20:00:869 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}: 2 (0,1)
02/18/16 16:20:00:869 | [INFO] | | OOBE | DE | | | | 1172 | Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}: 2 (0,1)
02/18/16 16:20:00:869 | [INFO] | | OOBE | DE | | | | 1172 | Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}: 2 (0,1)
02/18/16 16:20:00:869 | [INFO] | | OOBE | DE | | | | 1172 | Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9}: 2 (0,1)
02/18/16 16:20:00:869 | [INFO] | | OOBE | DE | | | | 1172 | Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20}: 2 (0,1)
02/18/16 16:20:00:869 | [INFO] | | OOBE | DE | | | | 1172 | Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC}: 2 (0,1)
02/18/16 16:20:00:869 | [INFO] | | OOBE | DE | | | | 1172 | Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}: 2 (0,1)
02/18/16 16:20:00:869 | [INFO] | | OOBE | DE | | | | 1172 | Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}: 2 (0,1)
02/18/16 16:20:00:869 | [INFO] | | OOBE | DE | | | | 1172 | Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}: 2 (0,1)
02/18/16 16:20:00:869 | [INFO] | | OOBE | DE | | | | 1172 | Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}: 3 (1,1)
02/18/16 16:20:00:870 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}: 4 (22,0)
02/18/16 16:20:00:870 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Korean Language Pack_AdobePhotoshop16-ko_KR_x64 16.0.0.0 {5309436A-D12F-437D-B7A4-BF136E17139C}: 5 (0,0)
02/18/16 16:20:00:870 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Spanish Language Pack_AdobePhotoshop16-es_ES_x64 16.0.0.0 {644DC0CB-E8C9-4508-B99D-8747C6172621}: 5 (0,0)
02/18/16 16:20:00:870 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Norwegian Language Pack_AdobePhotoshop16-nb_NO_x64 16.0.0.0 {00F35A9A-C859-4F6E-8C4F-70A7239207FF}: 5 (0,0)
02/18/16 16:20:00:870 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Russian Language Pack_AdobePhotoshop16-ru_RU_x64 16.0.0.0 {6E14FFAB-83F4-4CB7-87A2-703F6F20487A}: 5 (0,0)
02/18/16 16:20:00:870 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 AE English Language Pack_AdobePhotoshop16-en_AE_x64 16.0.0.0 {6E7A3076-3056-492F-966F-1EA4FDCE5FA8}: 5 (0,0)
02/18/16 16:20:00:870 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Ukrainian Language Pack_AdobePhotoshop16-uk_UA_x64 16.0.0.0 {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA}: 5 (0,0)
02/18/16 16:20:00:870 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Canadian French Language Pack_AdobePhotoshop16-fr_CA_x64 16.0.0.0 {7433F860-160E-4024-8218-892D796972A6}: 5 (0,0)
02/18/16 16:20:00:870 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Czech Language Pack_AdobePhotoshop16-cs_CZ_x64 16.0.0.0 {7787331E-D646-4CA4-ADCB-B264CC156D7D}: 5 (0,0)
02/18/16 16:20:00:870 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Japanese Language Pack_AdobePhotoshop16-ja_JP_x64 16.0.0.0 {778CE554-471C-4605-A600-852C976A4DC5}: 5 (0,0)
02/18/16 16:20:00:870 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 IL English Language Pack_AdobePhotoshop16-en_IL_x64 16.0.0.0 {0CA9067E-B7E0-4C7A-BA40-987AF967A05D}: 5 (0,0)
02/18/16 16:20:00:871 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 MA French Language Pack_AdobePhotoshop16-fr_MA_x64 16.0.0.0 {0D30F03E-27D9-41F8-AF26-9F1801C2AE28}: 5 (0,0)
02/18/16 16:20:00:871 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Polish Language Pack_AdobePhotoshop16-pl_PL_x64 16.0.0.0 {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0}: 5 (0,0)
02/18/16 16:20:00:871 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Italian Language Pack_AdobePhotoshop16-it_IT_x64 16.0.0.0 {960F21E4-EBDC-4A3E-80E9-C28D8A593F66}: 5 (0,0)
02/18/16 16:20:00:871 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Hungarian Language Pack_AdobePhotoshop16-hu_HU_x64 16.0.0.0 {98D6FC60-7908-474A-A598-0D7A7BFEF2C2}: 5 (0,0)
02/18/16 16:20:00:871 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Chinese (traditional) Language Pack_AdobePhotoshop16-zh_TW_x64 16.0.0.0 {18844AF8-051C-4227-9BE1-CA06F4364F9C}: 5 (0,0)
02/18/16 16:20:00:871 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Swedish Language Pack_AdobePhotoshop16-sv_SE_x64 16.0.0.0 {1B7AE611-4C93-47FC-951F-0BD9839AB72B}: 5 (0,0)
02/18/16 16:20:00:871 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 North American Spanish Language Pack_AdobePhotoshop16-es_MX_x64 16.0.0.0 {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4}: 5 (0,0)
02/18/16 16:20:00:871 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Chinese Language Pack_AdobePhotoshop16-zh_CN_x64 16.0.0.0 {3875BF24-5D9A-494A-A4FA-7AC70F56EC88}: 5 (0,0)
02/18/16 16:20:00:871 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 French Language Pack_AdobePhotoshop16-fr_FR_x64 16.0.0.0 {B75FB41B-E3E2-4B9F-93F7-62D982857374}: 5 (0,0)
02/18/16 16:20:00:871 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Turkish Language Pack_AdobePhotoshop16-tr_TR_x64 16.0.0.0 {BED85F42-B42C-4A91-946B-A928824C48A1}: 5 (0,0)
02/18/16 16:20:00:871 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 German Language Pack_AdobePhotoshop16-de_DE_x64 16.0.0.0 {69C13F4A-83B3-42F4-912C-C99F1442F439}: 5 (0,0)
02/18/16 16:20:00:871 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860}: 5 (0,0)
02/18/16 16:20:00:872 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Dutch Language Pack_AdobePhotoshop16-nl_NL_x64 16.0.0.0 {2060E7ED-C473-4A38-877F-C844E81B64F3}: 5 (0,0)
02/18/16 16:20:00:872 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Brazilian Portugese Language Pack_AdobePhotoshop16-pt_BR_x64 16.0.0.0 {4A0115A5-CA14-4EA1-9896-2F161B5144B9}: 5 (0,0)
02/18/16 16:20:00:872 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Danish Language Pack_AdobePhotoshop16-da_DK_x64 16.0.0.0 {F5D14B6C-DA16-4031-9EB8-AF0728550AFC}: 5 (0,0)
02/18/16 16:20:00:872 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 International English Language Pack_AdobePhotoshop16-en_GB_x64 16.0.0.0 {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4}: 5 (0,0)
02/18/16 16:20:00:872 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Finnish Language Pack_AdobePhotoshop16-fi_FI_x64 16.0.0.0 {FD8B8694-1044-4481-A5D9-4740A46BBC3B}: 5 (0,0)
02/18/16 16:20:00:872 | [INFO] | | OOBE | DE | | | | 1172 | END Operation order for all session payloads: mediaGroup (requires,satisfies)
02/18/16 16:20:01:497 | [INFO] | | OOBE | DE | | | | 1172 | Setting property "analyticsFilePath" to: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\{E492FCB1-CC53-427D-AAAD-C0044DA92E45}
02/18/16 16:20:01:498 | [INFO] | | OOBE | DE | | | | 1172 | Setting property "conflictingProcessInfo" to: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\{E25BB4CD-4072-4EC2-A2A7-7ADBD407E511}
02/18/16 16:20:01:498 | [INFO] | | OOBE | DE | | | | 1172 | Setting property "deploymentFile" to: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\{F382FCAF-5BCF-4BB7-BB74-FAC51CC41475}
02/18/16 16:20:01:498 | [INFO] | | OOBE | DE | | | | 1172 | Setting property "installLanguage" to: en_US
02/18/16 16:20:01:498 | [INFO] | | OOBE | DE | | | | 1172 | Attempting to find the selected language in the set of available payload languages
02/18/16 16:20:01:498 | [INFO] | | OOBE | DE | | | | 1172 | Setting property "installSourcePath" to: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015
02/18/16 16:20:01:498 | [INFO] | | OOBE | DE | | | | 1172 | Setting property "prefMigration" to: FALSE
02/18/16 16:20:01:498 | [INFO] | | OOBE | DE | | | | 1172 | Setting property "skipSync" to: 1
02/18/16 16:20:01:498 | [INFO] | | OOBE | DE | | | | 1172 | Setting property "userASUPath" to:
02/18/16 16:20:01:498 | [INFO] | | OOBE | DE | | | | 1172 | Overwrite property "analyticsFilePath" to: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\{E492FCB1-CC53-427D-AAAD-C0044DA92E45}
02/18/16 16:20:01:498 | [INFO] | | OOBE | DE | | | | 1172 | Overwrite property "conflictingProcessInfo" to: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\{E25BB4CD-4072-4EC2-A2A7-7ADBD407E511}
02/18/16 16:20:01:498 | [INFO] | | OOBE | DE | | | | 1172 | Overwrite property "installLanguage" to: en_US
02/18/16 16:20:01:498 | [INFO] | | OOBE | DE | | | | 1172 | Overwrite property "prefMigration" to: FALSE
02/18/16 16:20:01:499 | [INFO] | | OOBE | DE | | | | 1172 | Overwrite property "skipSync" to: 1
02/18/16 16:20:01:499 | [INFO] | | OOBE | DE | | | | 1172 | Overwrite property "userASUPath" to:
02/18/16 16:20:01:499 | [INFO] | | OOBE | DE | | | | 1172 | Found payload actions:
02/18/16 16:20:01:499 | [INFO] | | OOBE | DE | | | | 1172 | Deciding what installer mode to use...
02/18/16 16:20:01:618 | [INFO] | | OOBE | DE | | | | 1172 | BEGIN Setting requested payload actions
02/18/16 16:20:01:621 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10} is: true
02/18/16 16:20:01:621 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10} is none
02/18/16 16:20:01:621 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457} is: true
02/18/16 16:20:01:621 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457} is none
02/18/16 16:20:01:621 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3} is: true
02/18/16 16:20:01:622 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3} is none
02/18/16 16:20:01:622 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95} is: true
02/18/16 16:20:01:622 | [INFO] | | OOBE | DE | | | | 1172 | Action string for AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95} is none
02/18/16 16:20:01:622 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC} is: true
02/18/16 16:20:01:622 | [INFO] | | OOBE | DE | | | | 1172 | Action string for AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC} is none
02/18/16 16:20:01:622 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: AdobeColorEU CC 5.0.0.0 {9E9EB9FD-FDE8-487A-A41C-7713DA91AC89} is: false
02/18/16 16:20:01:623 | [INFO] | | OOBE | DE | | | | 1172 | Action string for AdobeColorEU CC 5.0.0.0 {9E9EB9FD-FDE8-487A-A41C-7713DA91AC89} is none
02/18/16 16:20:01:623 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28} is: true
02/18/16 16:20:01:623 | [INFO] | | OOBE | DE | | | | 1172 | Action string for AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28} is none
02/18/16 16:20:01:623 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: AdobeColorJA CC 5.0.0.0 {52D57F95-000A-4922-BB31-C6A936F4FD7D} is: false
02/18/16 16:20:01:623 | [INFO] | | OOBE | DE | | | | 1172 | Action string for AdobeColorJA CC 5.0.0.0 {52D57F95-000A-4922-BB31-C6A936F4FD7D} is none
02/18/16 16:20:01:623 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB} is: true
02/18/16 16:20:01:623 | [INFO] | | OOBE | DE | | | | 1172 | Action string for AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB} is none
02/18/16 16:20:01:623 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: AdobeColorNA CC 5.0.0.0 {72405B80-A3DD-4BB2-A8C4-A90BC7BA50FF} is: false
02/18/16 16:20:01:623 | [INFO] | | OOBE | DE | | | | 1172 | Action string for AdobeColorNA CC 5.0.0.0 {72405B80-A3DD-4BB2-A8C4-A90BC7BA50FF} is none
02/18/16 16:20:01:623 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44} is: true
02/18/16 16:20:01:623 | [INFO] | | OOBE | DE | | | | 1172 | Action string for AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44} is none
02/18/16 16:20:01:623 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66} is: true
02/18/16 16:20:01:623 | [INFO] | | OOBE | DE | | | | 1172 | Action string for AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66} is none
02/18/16 16:20:01:623 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94} is: true
02/18/16 16:20:01:623 | [INFO] | | OOBE | DE | | | | 1172 | Action string for AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94} is none
02/18/16 16:20:01:623 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140} is: true
02/18/16 16:20:01:623 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140} is none
02/18/16 16:20:01:623 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9} is: true
02/18/16 16:20:01:623 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9} is none
02/18/16 16:20:01:623 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9} is: true
02/18/16 16:20:01:623 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9} is none
02/18/16 16:20:01:623 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20} is: true
02/18/16 16:20:01:624 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20} is none
02/18/16 16:20:01:624 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC} is: true
02/18/16 16:20:01:624 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC} is none
02/18/16 16:20:01:624 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613} is: true
02/18/16 16:20:01:624 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613} is none
02/18/16 16:20:01:624 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446} is: true
02/18/16 16:20:01:624 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446} is none
02/18/16 16:20:01:624 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA} is: true
02/18/16 16:20:01:624 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA} is none
02/18/16 16:20:01:624 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85} is: true
02/18/16 16:20:01:624 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85} is none
02/18/16 16:20:01:624 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21} is: true
02/18/16 16:20:01:624 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21} is install
02/18/16 16:20:01:624 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Korean Language Pack_AdobePhotoshop16-ko_KR_x64 16.0.0.0 {5309436A-D12F-437D-B7A4-BF136E17139C} is: false
02/18/16 16:20:01:624 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Adobe Photoshop CC 2015 Korean Language Pack_AdobePhotoshop16-ko_KR_x64 16.0.0.0 {5309436A-D12F-437D-B7A4-BF136E17139C} is none
02/18/16 16:20:01:624 | [INFO] | | OOBE | DE | | | | 1172 | Payload Adobe Photoshop CC 2015 Korean Language Pack_AdobePhotoshop16-ko_KR_x64 16.0.0.0 {5309436A-D12F-437D-B7A4-BF136E17139C} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 16:20:01:624 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Spanish Language Pack_AdobePhotoshop16-es_ES_x64 16.0.0.0 {644DC0CB-E8C9-4508-B99D-8747C6172621} is: false
02/18/16 16:20:01:624 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Adobe Photoshop CC 2015 Spanish Language Pack_AdobePhotoshop16-es_ES_x64 16.0.0.0 {644DC0CB-E8C9-4508-B99D-8747C6172621} is none
02/18/16 16:20:01:624 | [INFO] | | OOBE | DE | | | | 1172 | Payload Adobe Photoshop CC 2015 Spanish Language Pack_AdobePhotoshop16-es_ES_x64 16.0.0.0 {644DC0CB-E8C9-4508-B99D-8747C6172621} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 16:20:01:625 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Norwegian Language Pack_AdobePhotoshop16-nb_NO_x64 16.0.0.0 {00F35A9A-C859-4F6E-8C4F-70A7239207FF} is: false
02/18/16 16:20:01:625 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Adobe Photoshop CC 2015 Norwegian Language Pack_AdobePhotoshop16-nb_NO_x64 16.0.0.0 {00F35A9A-C859-4F6E-8C4F-70A7239207FF} is none
02/18/16 16:20:01:625 | [INFO] | | OOBE | DE | | | | 1172 | Payload Adobe Photoshop CC 2015 Norwegian Language Pack_AdobePhotoshop16-nb_NO_x64 16.0.0.0 {00F35A9A-C859-4F6E-8C4F-70A7239207FF} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 16:20:01:625 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Russian Language Pack_AdobePhotoshop16-ru_RU_x64 16.0.0.0 {6E14FFAB-83F4-4CB7-87A2-703F6F20487A} is: false
02/18/16 16:20:01:625 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Adobe Photoshop CC 2015 Russian Language Pack_AdobePhotoshop16-ru_RU_x64 16.0.0.0 {6E14FFAB-83F4-4CB7-87A2-703F6F20487A} is none
02/18/16 16:20:01:625 | [INFO] | | OOBE | DE | | | | 1172 | Payload Adobe Photoshop CC 2015 Russian Language Pack_AdobePhotoshop16-ru_RU_x64 16.0.0.0 {6E14FFAB-83F4-4CB7-87A2-703F6F20487A} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 16:20:01:625 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Adobe Photoshop CC 2015 AE English Language Pack_AdobePhotoshop16-en_AE_x64 16.0.0.0 {6E7A3076-3056-492F-966F-1EA4FDCE5FA8} is: false
02/18/16 16:20:01:625 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Adobe Photoshop CC 2015 AE English Language Pack_AdobePhotoshop16-en_AE_x64 16.0.0.0 {6E7A3076-3056-492F-966F-1EA4FDCE5FA8} is none
02/18/16 16:20:01:625 | [INFO] | | OOBE | DE | | | | 1172 | Payload Adobe Photoshop CC 2015 AE English Language Pack_AdobePhotoshop16-en_AE_x64 16.0.0.0 {6E7A3076-3056-492F-966F-1EA4FDCE5FA8} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 16:20:01:625 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Ukrainian Language Pack_AdobePhotoshop16-uk_UA_x64 16.0.0.0 {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA} is: false
02/18/16 16:20:01:625 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Adobe Photoshop CC 2015 Ukrainian Language Pack_AdobePhotoshop16-uk_UA_x64 16.0.0.0 {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA} is none
02/18/16 16:20:01:625 | [INFO] | | OOBE | DE | | | | 1172 | Payload Adobe Photoshop CC 2015 Ukrainian Language Pack_AdobePhotoshop16-uk_UA_x64 16.0.0.0 {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 16:20:01:625 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Canadian French Language Pack_AdobePhotoshop16-fr_CA_x64 16.0.0.0 {7433F860-160E-4024-8218-892D796972A6} is: false
02/18/16 16:20:01:625 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Adobe Photoshop CC 2015 Canadian French Language Pack_AdobePhotoshop16-fr_CA_x64 16.0.0.0 {7433F860-160E-4024-8218-892D796972A6} is none
02/18/16 16:20:01:625 | [INFO] | | OOBE | DE | | | | 1172 | Payload Adobe Photoshop CC 2015 Canadian French Language Pack_AdobePhotoshop16-fr_CA_x64 16.0.0.0 {7433F860-160E-4024-8218-892D796972A6} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 16:20:01:625 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Czech Language Pack_AdobePhotoshop16-cs_CZ_x64 16.0.0.0 {7787331E-D646-4CA4-ADCB-B264CC156D7D} is: false
02/18/16 16:20:01:625 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Adobe Photoshop CC 2015 Czech Language Pack_AdobePhotoshop16-cs_CZ_x64 16.0.0.0 {7787331E-D646-4CA4-ADCB-B264CC156D7D} is none
02/18/16 16:20:01:625 | [INFO] | | OOBE | DE | | | | 1172 | Payload Adobe Photoshop CC 2015 Czech Language Pack_AdobePhotoshop16-cs_CZ_x64 16.0.0.0 {7787331E-D646-4CA4-ADCB-B264CC156D7D} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 16:20:01:626 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Japanese Language Pack_AdobePhotoshop16-ja_JP_x64 16.0.0.0 {778CE554-471C-4605-A600-852C976A4DC5} is: false
02/18/16 16:20:01:626 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Adobe Photoshop CC 2015 Japanese Language Pack_AdobePhotoshop16-ja_JP_x64 16.0.0.0 {778CE554-471C-4605-A600-852C976A4DC5} is none
02/18/16 16:20:01:626 | [INFO] | | OOBE | DE | | | | 1172 | Payload Adobe Photoshop CC 2015 Japanese Language Pack_AdobePhotoshop16-ja_JP_x64 16.0.0.0 {778CE554-471C-4605-A600-852C976A4DC5} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 16:20:01:626 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Adobe Photoshop CC 2015 IL English Language Pack_AdobePhotoshop16-en_IL_x64 16.0.0.0 {0CA9067E-B7E0-4C7A-BA40-987AF967A05D} is: false
02/18/16 16:20:01:626 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Adobe Photoshop CC 2015 IL English Language Pack_AdobePhotoshop16-en_IL_x64 16.0.0.0 {0CA9067E-B7E0-4C7A-BA40-987AF967A05D} is none
02/18/16 16:20:01:626 | [INFO] | | OOBE | DE | | | | 1172 | Payload Adobe Photoshop CC 2015 IL English Language Pack_AdobePhotoshop16-en_IL_x64 16.0.0.0 {0CA9067E-B7E0-4C7A-BA40-987AF967A05D} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 16:20:01:626 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Adobe Photoshop CC 2015 MA French Language Pack_AdobePhotoshop16-fr_MA_x64 16.0.0.0 {0D30F03E-27D9-41F8-AF26-9F1801C2AE28} is: false
02/18/16 16:20:01:626 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Adobe Photoshop CC 2015 MA French Language Pack_AdobePhotoshop16-fr_MA_x64 16.0.0.0 {0D30F03E-27D9-41F8-AF26-9F1801C2AE28} is none
02/18/16 16:20:01:626 | [INFO] | | OOBE | DE | | | | 1172 | Payload Adobe Photoshop CC 2015 MA French Language Pack_AdobePhotoshop16-fr_MA_x64 16.0.0.0 {0D30F03E-27D9-41F8-AF26-9F1801C2AE28} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 16:20:01:626 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Polish Language Pack_AdobePhotoshop16-pl_PL_x64 16.0.0.0 {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0} is: false
02/18/16 16:20:01:626 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Adobe Photoshop CC 2015 Polish Language Pack_AdobePhotoshop16-pl_PL_x64 16.0.0.0 {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0} is none
02/18/16 16:20:01:626 | [INFO] | | OOBE | DE | | | | 1172 | Payload Adobe Photoshop CC 2015 Polish Language Pack_AdobePhotoshop16-pl_PL_x64 16.0.0.0 {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 16:20:01:626 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Italian Language Pack_AdobePhotoshop16-it_IT_x64 16.0.0.0 {960F21E4-EBDC-4A3E-80E9-C28D8A593F66} is: false
02/18/16 16:20:01:626 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Adobe Photoshop CC 2015 Italian Language Pack_AdobePhotoshop16-it_IT_x64 16.0.0.0 {960F21E4-EBDC-4A3E-80E9-C28D8A593F66} is none
02/18/16 16:20:01:626 | [INFO] | | OOBE | DE | | | | 1172 | Payload Adobe Photoshop CC 2015 Italian Language Pack_AdobePhotoshop16-it_IT_x64 16.0.0.0 {960F21E4-EBDC-4A3E-80E9-C28D8A593F66} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 16:20:01:626 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Hungarian Language Pack_AdobePhotoshop16-hu_HU_x64 16.0.0.0 {98D6FC60-7908-474A-A598-0D7A7BFEF2C2} is: false
02/18/16 16:20:01:626 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Adobe Photoshop CC 2015 Hungarian Language Pack_AdobePhotoshop16-hu_HU_x64 16.0.0.0 {98D6FC60-7908-474A-A598-0D7A7BFEF2C2} is none
02/18/16 16:20:01:626 | [INFO] | | OOBE | DE | | | | 1172 | Payload Adobe Photoshop CC 2015 Hungarian Language Pack_AdobePhotoshop16-hu_HU_x64 16.0.0.0 {98D6FC60-7908-474A-A598-0D7A7BFEF2C2} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 16:20:01:626 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Chinese (traditional) Language Pack_AdobePhotoshop16-zh_TW_x64 16.0.0.0 {18844AF8-051C-4227-9BE1-CA06F4364F9C} is: false
02/18/16 16:20:01:627 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Adobe Photoshop CC 2015 Chinese (traditional) Language Pack_AdobePhotoshop16-zh_TW_x64 16.0.0.0 {18844AF8-051C-4227-9BE1-CA06F4364F9C} is none
02/18/16 16:20:01:627 | [INFO] | | OOBE | DE | | | | 1172 | Payload Adobe Photoshop CC 2015 Chinese (traditional) Language Pack_AdobePhotoshop16-zh_TW_x64 16.0.0.0 {18844AF8-051C-4227-9BE1-CA06F4364F9C} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 16:20:01:627 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Swedish Language Pack_AdobePhotoshop16-sv_SE_x64 16.0.0.0 {1B7AE611-4C93-47FC-951F-0BD9839AB72B} is: false
02/18/16 16:20:01:627 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Adobe Photoshop CC 2015 Swedish Language Pack_AdobePhotoshop16-sv_SE_x64 16.0.0.0 {1B7AE611-4C93-47FC-951F-0BD9839AB72B} is none
02/18/16 16:20:01:627 | [INFO] | | OOBE | DE | | | | 1172 | Payload Adobe Photoshop CC 2015 Swedish Language Pack_AdobePhotoshop16-sv_SE_x64 16.0.0.0 {1B7AE611-4C93-47FC-951F-0BD9839AB72B} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 16:20:01:627 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Adobe Photoshop CC 2015 North American Spanish Language Pack_AdobePhotoshop16-es_MX_x64 16.0.0.0 {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4} is: false
02/18/16 16:20:01:627 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Adobe Photoshop CC 2015 North American Spanish Language Pack_AdobePhotoshop16-es_MX_x64 16.0.0.0 {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4} is none
02/18/16 16:20:01:627 | [INFO] | | OOBE | DE | | | | 1172 | Payload Adobe Photoshop CC 2015 North American Spanish Language Pack_AdobePhotoshop16-es_MX_x64 16.0.0.0 {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 16:20:01:627 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Chinese Language Pack_AdobePhotoshop16-zh_CN_x64 16.0.0.0 {3875BF24-5D9A-494A-A4FA-7AC70F56EC88} is: false
02/18/16 16:20:01:627 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Adobe Photoshop CC 2015 Chinese Language Pack_AdobePhotoshop16-zh_CN_x64 16.0.0.0 {3875BF24-5D9A-494A-A4FA-7AC70F56EC88} is none
02/18/16 16:20:01:627 | [INFO] | | OOBE | DE | | | | 1172 | Payload Adobe Photoshop CC 2015 Chinese Language Pack_AdobePhotoshop16-zh_CN_x64 16.0.0.0 {3875BF24-5D9A-494A-A4FA-7AC70F56EC88} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 16:20:01:627 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Adobe Photoshop CC 2015 French Language Pack_AdobePhotoshop16-fr_FR_x64 16.0.0.0 {B75FB41B-E3E2-4B9F-93F7-62D982857374} is: false
02/18/16 16:20:01:627 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Adobe Photoshop CC 2015 French Language Pack_AdobePhotoshop16-fr_FR_x64 16.0.0.0 {B75FB41B-E3E2-4B9F-93F7-62D982857374} is none
02/18/16 16:20:01:627 | [INFO] | | OOBE | DE | | | | 1172 | Payload Adobe Photoshop CC 2015 French Language Pack_AdobePhotoshop16-fr_FR_x64 16.0.0.0 {B75FB41B-E3E2-4B9F-93F7-62D982857374} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 16:20:01:627 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Turkish Language Pack_AdobePhotoshop16-tr_TR_x64 16.0.0.0 {BED85F42-B42C-4A91-946B-A928824C48A1} is: false
02/18/16 16:20:01:627 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Adobe Photoshop CC 2015 Turkish Language Pack_AdobePhotoshop16-tr_TR_x64 16.0.0.0 {BED85F42-B42C-4A91-946B-A928824C48A1} is none
02/18/16 16:20:01:627 | [INFO] | | OOBE | DE | | | | 1172 | Payload Adobe Photoshop CC 2015 Turkish Language Pack_AdobePhotoshop16-tr_TR_x64 16.0.0.0 {BED85F42-B42C-4A91-946B-A928824C48A1} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 16:20:01:627 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Adobe Photoshop CC 2015 German Language Pack_AdobePhotoshop16-de_DE_x64 16.0.0.0 {69C13F4A-83B3-42F4-912C-C99F1442F439} is: false
02/18/16 16:20:01:628 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Adobe Photoshop CC 2015 German Language Pack_AdobePhotoshop16-de_DE_x64 16.0.0.0 {69C13F4A-83B3-42F4-912C-C99F1442F439} is none
02/18/16 16:20:01:628 | [INFO] | | OOBE | DE | | | | 1172 | Payload Adobe Photoshop CC 2015 German Language Pack_AdobePhotoshop16-de_DE_x64 16.0.0.0 {69C13F4A-83B3-42F4-912C-C99F1442F439} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 16:20:01:628 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860} is: false
02/18/16 16:20:01:628 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860} is none
02/18/16 16:20:01:628 | [INFO] | | OOBE | DE | | | | 1172 | Payload Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 16:20:01:628 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Dutch Language Pack_AdobePhotoshop16-nl_NL_x64 16.0.0.0 {2060E7ED-C473-4A38-877F-C844E81B64F3} is: false
02/18/16 16:20:01:628 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Adobe Photoshop CC 2015 Dutch Language Pack_AdobePhotoshop16-nl_NL_x64 16.0.0.0 {2060E7ED-C473-4A38-877F-C844E81B64F3} is none
02/18/16 16:20:01:628 | [INFO] | | OOBE | DE | | | | 1172 | Payload Adobe Photoshop CC 2015 Dutch Language Pack_AdobePhotoshop16-nl_NL_x64 16.0.0.0 {2060E7ED-C473-4A38-877F-C844E81B64F3} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 16:20:01:628 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Brazilian Portugese Language Pack_AdobePhotoshop16-pt_BR_x64 16.0.0.0 {4A0115A5-CA14-4EA1-9896-2F161B5144B9} is: false
02/18/16 16:20:01:628 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Adobe Photoshop CC 2015 Brazilian Portugese Language Pack_AdobePhotoshop16-pt_BR_x64 16.0.0.0 {4A0115A5-CA14-4EA1-9896-2F161B5144B9} is none
02/18/16 16:20:01:628 | [INFO] | | OOBE | DE | | | | 1172 | Payload Adobe Photoshop CC 2015 Brazilian Portugese Language Pack_AdobePhotoshop16-pt_BR_x64 16.0.0.0 {4A0115A5-CA14-4EA1-9896-2F161B5144B9} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 16:20:01:628 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Danish Language Pack_AdobePhotoshop16-da_DK_x64 16.0.0.0 {F5D14B6C-DA16-4031-9EB8-AF0728550AFC} is: false
02/18/16 16:20:01:628 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Adobe Photoshop CC 2015 Danish Language Pack_AdobePhotoshop16-da_DK_x64 16.0.0.0 {F5D14B6C-DA16-4031-9EB8-AF0728550AFC} is none
02/18/16 16:20:01:628 | [INFO] | | OOBE | DE | | | | 1172 | Payload Adobe Photoshop CC 2015 Danish Language Pack_AdobePhotoshop16-da_DK_x64 16.0.0.0 {F5D14B6C-DA16-4031-9EB8-AF0728550AFC} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 16:20:01:628 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Adobe Photoshop CC 2015 International English Language Pack_AdobePhotoshop16-en_GB_x64 16.0.0.0 {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4} is: false
02/18/16 16:20:01:628 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Adobe Photoshop CC 2015 International English Language Pack_AdobePhotoshop16-en_GB_x64 16.0.0.0 {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4} is none
02/18/16 16:20:01:628 | [INFO] | | OOBE | DE | | | | 1172 | Payload Adobe Photoshop CC 2015 International English Language Pack_AdobePhotoshop16-en_GB_x64 16.0.0.0 {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 16:20:01:628 | [INFO] | | OOBE | DE | | | | 1172 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Finnish Language Pack_AdobePhotoshop16-fi_FI_x64 16.0.0.0 {FD8B8694-1044-4481-A5D9-4740A46BBC3B} is: false
02/18/16 16:20:01:628 | [INFO] | | OOBE | DE | | | | 1172 | Action string for Adobe Photoshop CC 2015 Finnish Language Pack_AdobePhotoshop16-fi_FI_x64 16.0.0.0 {FD8B8694-1044-4481-A5D9-4740A46BBC3B} is none
02/18/16 16:20:01:628 | [INFO] | | OOBE | DE | | | | 1172 | Payload Adobe Photoshop CC 2015 Finnish Language Pack_AdobePhotoshop16-fi_FI_x64 16.0.0.0 {FD8B8694-1044-4481-A5D9-4740A46BBC3B} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 16:20:01:639 | [INFO] | | OOBE | DE | | | | 1172 | END Setting requested payload actions
02/18/16 16:20:01:726 | [INFO] | | OOBE | DE | | | | 1172 | Collected advanced path check information for INSTALLDIR
02/18/16 16:20:01:726 | [INFO] | | OOBE | DE | | | | 1172 | INSTALLDIR is a well-formed path
02/18/16 16:20:01:726 | [INFO] | | OOBE | DE | | | | 1172 | INSTALLDIR is not the root path
02/18/16 16:20:01:726 | [INFO] | | OOBE | DE | | | | 1172 | INSTALLDIR is on a local volume
02/18/16 16:20:01:726 | [INFO] | | OOBE | DE | | | | 1172 | INSTALLDIR is on a writable volume
02/18/16 16:20:01:726 | [INFO] | | OOBE | DE | | | | 1172 | INSTALLDIR is not on a case sensitive volume
02/18/16 16:20:01:726 | [INFO] | | OOBE | DE | | | | 1172 | INSTALLDIR passed path basic path validation: C:\Program Files\Adobe
02/18/16 16:20:08:932 | [INFO] | | OOBE | DE | | | | 1172 | BEGIN InstallOperationsQueue Unordered operations
02/18/16 16:20:08:932 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Norwegian Language Pack_AdobePhotoshop16-nb_NO_x64 16.0.0.0 {00F35A9A-C859-4F6E-8C4F-70A7239207FF}: with operation none
02/18/16 16:20:08:932 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Ukrainian Language Pack_AdobePhotoshop16-uk_UA_x64 16.0.0.0 {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA}: with operation none
02/18/16 16:20:08:932 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 IL English Language Pack_AdobePhotoshop16-en_IL_x64 16.0.0.0 {0CA9067E-B7E0-4C7A-BA40-987AF967A05D}: with operation none
02/18/16 16:20:08:932 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 MA French Language Pack_AdobePhotoshop16-fr_MA_x64 16.0.0.0 {0D30F03E-27D9-41F8-AF26-9F1801C2AE28}: with operation none
02/18/16 16:20:08:932 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Chinese (traditional) Language Pack_AdobePhotoshop16-zh_TW_x64 16.0.0.0 {18844AF8-051C-4227-9BE1-CA06F4364F9C}: with operation none
02/18/16 16:20:08:932 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Swedish Language Pack_AdobePhotoshop16-sv_SE_x64 16.0.0.0 {1B7AE611-4C93-47FC-951F-0BD9839AB72B}: with operation none
02/18/16 16:20:08:932 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Dutch Language Pack_AdobePhotoshop16-nl_NL_x64 16.0.0.0 {2060E7ED-C473-4A38-877F-C844E81B64F3}: with operation none
02/18/16 16:20:08:932 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 North American Spanish Language Pack_AdobePhotoshop16-es_MX_x64 16.0.0.0 {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4}: with operation none
02/18/16 16:20:08:932 | [INFO] | | OOBE | DE | | | | 1172 | Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}: with operation repair
02/18/16 16:20:08:932 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Chinese Language Pack_AdobePhotoshop16-zh_CN_x64 16.0.0.0 {3875BF24-5D9A-494A-A4FA-7AC70F56EC88}: with operation none
02/18/16 16:20:08:932 | [INFO] | | OOBE | DE | | | | 1172 | Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20}: with operation repair
02/18/16 16:20:08:932 | [INFO] | | OOBE | DE | | | | 1172 | Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}: with operation repair
02/18/16 16:20:08:932 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}: with operation repair
02/18/16 16:20:08:932 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Brazilian Portugese Language Pack_AdobePhotoshop16-pt_BR_x64 16.0.0.0 {4A0115A5-CA14-4EA1-9896-2F161B5144B9}: with operation none
02/18/16 16:20:08:932 | [INFO] | | OOBE | DE | | | | 1172 | Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}: with operation repair
02/18/16 16:20:08:932 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 International English Language Pack_AdobePhotoshop16-en_GB_x64 16.0.0.0 {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4}: with operation none
02/18/16 16:20:08:933 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorJA CC 5.0.0.0 {52D57F95-000A-4922-BB31-C6A936F4FD7D}: with operation none
02/18/16 16:20:08:933 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Korean Language Pack_AdobePhotoshop16-ko_KR_x64 16.0.0.0 {5309436A-D12F-437D-B7A4-BF136E17139C}: with operation none
02/18/16 16:20:08:933 | [INFO] | | OOBE | DE | | | | 1172 | Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}: with operation repair
02/18/16 16:20:08:933 | [INFO] | | OOBE | DE | | | | 1172 | Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9}: with operation repair
02/18/16 16:20:08:933 | [INFO] | | OOBE | DE | | | | 1172 | Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}: with operation repair
02/18/16 16:20:08:933 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}: with operation repair
02/18/16 16:20:08:933 | [INFO] | | OOBE | DE | | | | 1172 | Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}: with operation repair
02/18/16 16:20:08:933 | [INFO] | | OOBE | DE | | | | 1172 | Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}: with operation repair
02/18/16 16:20:08:933 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Spanish Language Pack_AdobePhotoshop16-es_ES_x64 16.0.0.0 {644DC0CB-E8C9-4508-B99D-8747C6172621}: with operation none
02/18/16 16:20:08:933 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 German Language Pack_AdobePhotoshop16-de_DE_x64 16.0.0.0 {69C13F4A-83B3-42F4-912C-C99F1442F439}: with operation none
02/18/16 16:20:08:933 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Russian Language Pack_AdobePhotoshop16-ru_RU_x64 16.0.0.0 {6E14FFAB-83F4-4CB7-87A2-703F6F20487A}: with operation none
02/18/16 16:20:08:933 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 AE English Language Pack_AdobePhotoshop16-en_AE_x64 16.0.0.0 {6E7A3076-3056-492F-966F-1EA4FDCE5FA8}: with operation none
02/18/16 16:20:08:933 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorNA CC 5.0.0.0 {72405B80-A3DD-4BB2-A8C4-A90BC7BA50FF}: with operation none
02/18/16 16:20:08:933 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Canadian French Language Pack_AdobePhotoshop16-fr_CA_x64 16.0.0.0 {7433F860-160E-4024-8218-892D796972A6}: with operation none
02/18/16 16:20:08:933 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Czech Language Pack_AdobePhotoshop16-cs_CZ_x64 16.0.0.0 {7787331E-D646-4CA4-ADCB-B264CC156D7D}: with operation none
02/18/16 16:20:08:933 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Japanese Language Pack_AdobePhotoshop16-ja_JP_x64 16.0.0.0 {778CE554-471C-4605-A600-852C976A4DC5}: with operation none
02/18/16 16:20:08:933 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}: with operation repair
02/18/16 16:20:08:933 | [INFO] | | OOBE | DE | | | | 1172 | Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC}: with operation repair
02/18/16 16:20:08:933 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Polish Language Pack_AdobePhotoshop16-pl_PL_x64 16.0.0.0 {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0}: with operation none
02/18/16 16:20:08:933 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Italian Language Pack_AdobePhotoshop16-it_IT_x64 16.0.0.0 {960F21E4-EBDC-4A3E-80E9-C28D8A593F66}: with operation none
02/18/16 16:20:08:933 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Hungarian Language Pack_AdobePhotoshop16-hu_HU_x64 16.0.0.0 {98D6FC60-7908-474A-A598-0D7A7BFEF2C2}: with operation none
02/18/16 16:20:08:933 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorEU CC 5.0.0.0 {9E9EB9FD-FDE8-487A-A41C-7713DA91AC89}: with operation none
02/18/16 16:20:08:933 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}: with operation repair
02/18/16 16:20:08:933 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}: with operation repair
02/18/16 16:20:08:933 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}: with operation repair
02/18/16 16:20:08:933 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 French Language Pack_AdobePhotoshop16-fr_FR_x64 16.0.0.0 {B75FB41B-E3E2-4B9F-93F7-62D982857374}: with operation none
02/18/16 16:20:08:934 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Turkish Language Pack_AdobePhotoshop16-tr_TR_x64 16.0.0.0 {BED85F42-B42C-4A91-946B-A928824C48A1}: with operation none
02/18/16 16:20:08:934 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}: with operation repair
02/18/16 16:20:08:934 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860}: with operation install
02/18/16 16:20:08:934 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}: with operation repair
02/18/16 16:20:08:934 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}: with operation repair
02/18/16 16:20:08:934 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Danish Language Pack_AdobePhotoshop16-da_DK_x64 16.0.0.0 {F5D14B6C-DA16-4031-9EB8-AF0728550AFC}: with operation none
02/18/16 16:20:08:934 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}: with operation repair
02/18/16 16:20:08:934 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Finnish Language Pack_AdobePhotoshop16-fi_FI_x64 16.0.0.0 {FD8B8694-1044-4481-A5D9-4740A46BBC3B}: with operation none
02/18/16 16:20:08:934 | [INFO] | | OOBE | DE | | | | 1172 | END InstallOperationsQueue Unordered operations
02/18/16 16:20:08:934 | [INFO] | | OOBE | DE | | | | 1172 | BEGIN InstallOperationsQueue Ordered operations
02/18/16 16:20:08:934 | [INFO] | | OOBE | DE | | | | 1172 | Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}: with operation repair
02/18/16 16:20:08:934 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}: with operation repair
02/18/16 16:20:08:934 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}: with operation repair
02/18/16 16:20:08:934 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}: with operation repair
02/18/16 16:20:08:934 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}: with operation repair
02/18/16 16:20:08:934 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}: with operation repair
02/18/16 16:20:08:935 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}: with operation repair
02/18/16 16:20:08:935 | [INFO] | | OOBE | DE | | | | 1172 | Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}: with operation repair
02/18/16 16:20:08:935 | [INFO] | | OOBE | DE | | | | 1172 | Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}: with operation repair
02/18/16 16:20:08:935 | [INFO] | | OOBE | DE | | | | 1172 | Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9}: with operation repair
02/18/16 16:20:08:935 | [INFO] | | OOBE | DE | | | | 1172 | Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20}: with operation repair
02/18/16 16:20:08:935 | [INFO] | | OOBE | DE | | | | 1172 | Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC}: with operation repair
02/18/16 16:20:08:935 | [INFO] | | OOBE | DE | | | | 1172 | Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}: with operation repair
02/18/16 16:20:08:935 | [INFO] | | OOBE | DE | | | | 1172 | Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}: with operation repair
02/18/16 16:20:08:935 | [INFO] | | OOBE | DE | | | | 1172 | Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}: with operation repair
02/18/16 16:20:08:935 | [INFO] | | OOBE | DE | | | | 1172 | Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}: with operation repair
02/18/16 16:20:08:935 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}: with operation repair
02/18/16 16:20:08:935 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860}: with operation install
02/18/16 16:20:08:935 | [INFO] | | OOBE | DE | | | | 1172 | END InstallOperationsQueue Ordered operations
02/18/16 16:20:09:018 | [INFO] | | OOBE | DE | | | | 1172 | Payloads passed preflight validation.
02/18/16 16:20:09:024 | [INFO] | | OOBE | DE | | | | 1172 | Call PreSession Custom Hook
02/18/16 16:20:09:024 | [INFO] | | OOBE | DE | | | | 1172 | BEGIN InstallOperationsQueue Unordered operations
02/18/16 16:20:09:024 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Norwegian Language Pack_AdobePhotoshop16-nb_NO_x64 16.0.0.0 {00F35A9A-C859-4F6E-8C4F-70A7239207FF}: with operation none
02/18/16 16:20:09:024 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Ukrainian Language Pack_AdobePhotoshop16-uk_UA_x64 16.0.0.0 {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA}: with operation none
02/18/16 16:20:09:024 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 IL English Language Pack_AdobePhotoshop16-en_IL_x64 16.0.0.0 {0CA9067E-B7E0-4C7A-BA40-987AF967A05D}: with operation none
02/18/16 16:20:09:024 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 MA French Language Pack_AdobePhotoshop16-fr_MA_x64 16.0.0.0 {0D30F03E-27D9-41F8-AF26-9F1801C2AE28}: with operation none
02/18/16 16:20:09:024 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Chinese (traditional) Language Pack_AdobePhotoshop16-zh_TW_x64 16.0.0.0 {18844AF8-051C-4227-9BE1-CA06F4364F9C}: with operation none
02/18/16 16:20:09:024 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Swedish Language Pack_AdobePhotoshop16-sv_SE_x64 16.0.0.0 {1B7AE611-4C93-47FC-951F-0BD9839AB72B}: with operation none
02/18/16 16:20:09:025 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Dutch Language Pack_AdobePhotoshop16-nl_NL_x64 16.0.0.0 {2060E7ED-C473-4A38-877F-C844E81B64F3}: with operation none
02/18/16 16:20:09:025 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 North American Spanish Language Pack_AdobePhotoshop16-es_MX_x64 16.0.0.0 {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4}: with operation none
02/18/16 16:20:09:025 | [INFO] | | OOBE | DE | | | | 1172 | Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}: with operation repair
02/18/16 16:20:09:025 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Chinese Language Pack_AdobePhotoshop16-zh_CN_x64 16.0.0.0 {3875BF24-5D9A-494A-A4FA-7AC70F56EC88}: with operation none
02/18/16 16:20:09:025 | [INFO] | | OOBE | DE | | | | 1172 | Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20}: with operation repair
02/18/16 16:20:09:025 | [INFO] | | OOBE | DE | | | | 1172 | Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}: with operation repair
02/18/16 16:20:09:025 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}: with operation repair
02/18/16 16:20:09:025 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Brazilian Portugese Language Pack_AdobePhotoshop16-pt_BR_x64 16.0.0.0 {4A0115A5-CA14-4EA1-9896-2F161B5144B9}: with operation none
02/18/16 16:20:09:025 | [INFO] | | OOBE | DE | | | | 1172 | Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}: with operation repair
02/18/16 16:20:09:025 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 International English Language Pack_AdobePhotoshop16-en_GB_x64 16.0.0.0 {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4}: with operation none
02/18/16 16:20:09:025 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorJA CC 5.0.0.0 {52D57F95-000A-4922-BB31-C6A936F4FD7D}: with operation none
02/18/16 16:20:09:025 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Korean Language Pack_AdobePhotoshop16-ko_KR_x64 16.0.0.0 {5309436A-D12F-437D-B7A4-BF136E17139C}: with operation none
02/18/16 16:20:09:025 | [INFO] | | OOBE | DE | | | | 1172 | Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}: with operation repair
02/18/16 16:20:09:025 | [INFO] | | OOBE | DE | | | | 1172 | Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9}: with operation repair
02/18/16 16:20:09:025 | [INFO] | | OOBE | DE | | | | 1172 | Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}: with operation repair
02/18/16 16:20:09:025 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}: with operation repair
02/18/16 16:20:09:025 | [INFO] | | OOBE | DE | | | | 1172 | Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}: with operation repair
02/18/16 16:20:09:025 | [INFO] | | OOBE | DE | | | | 1172 | Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}: with operation repair
02/18/16 16:20:09:025 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Spanish Language Pack_AdobePhotoshop16-es_ES_x64 16.0.0.0 {644DC0CB-E8C9-4508-B99D-8747C6172621}: with operation none
02/18/16 16:20:09:025 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 German Language Pack_AdobePhotoshop16-de_DE_x64 16.0.0.0 {69C13F4A-83B3-42F4-912C-C99F1442F439}: with operation none
02/18/16 16:20:09:025 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Russian Language Pack_AdobePhotoshop16-ru_RU_x64 16.0.0.0 {6E14FFAB-83F4-4CB7-87A2-703F6F20487A}: with operation none
02/18/16 16:20:09:025 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 AE English Language Pack_AdobePhotoshop16-en_AE_x64 16.0.0.0 {6E7A3076-3056-492F-966F-1EA4FDCE5FA8}: with operation none
02/18/16 16:20:09:025 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorNA CC 5.0.0.0 {72405B80-A3DD-4BB2-A8C4-A90BC7BA50FF}: with operation none
02/18/16 16:20:09:026 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Canadian French Language Pack_AdobePhotoshop16-fr_CA_x64 16.0.0.0 {7433F860-160E-4024-8218-892D796972A6}: with operation none
02/18/16 16:20:09:026 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Czech Language Pack_AdobePhotoshop16-cs_CZ_x64 16.0.0.0 {7787331E-D646-4CA4-ADCB-B264CC156D7D}: with operation none
02/18/16 16:20:09:026 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Japanese Language Pack_AdobePhotoshop16-ja_JP_x64 16.0.0.0 {778CE554-471C-4605-A600-852C976A4DC5}: with operation none
02/18/16 16:20:09:026 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}: with operation repair
02/18/16 16:20:09:026 | [INFO] | | OOBE | DE | | | | 1172 | Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC}: with operation repair
02/18/16 16:20:09:026 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Polish Language Pack_AdobePhotoshop16-pl_PL_x64 16.0.0.0 {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0}: with operation none
02/18/16 16:20:09:026 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Italian Language Pack_AdobePhotoshop16-it_IT_x64 16.0.0.0 {960F21E4-EBDC-4A3E-80E9-C28D8A593F66}: with operation none
02/18/16 16:20:09:026 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Hungarian Language Pack_AdobePhotoshop16-hu_HU_x64 16.0.0.0 {98D6FC60-7908-474A-A598-0D7A7BFEF2C2}: with operation none
02/18/16 16:20:09:026 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorEU CC 5.0.0.0 {9E9EB9FD-FDE8-487A-A41C-7713DA91AC89}: with operation none
02/18/16 16:20:09:026 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}: with operation repair
02/18/16 16:20:09:026 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}: with operation repair
02/18/16 16:20:09:026 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}: with operation repair
02/18/16 16:20:09:026 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 French Language Pack_AdobePhotoshop16-fr_FR_x64 16.0.0.0 {B75FB41B-E3E2-4B9F-93F7-62D982857374}: with operation none
02/18/16 16:20:09:026 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Turkish Language Pack_AdobePhotoshop16-tr_TR_x64 16.0.0.0 {BED85F42-B42C-4A91-946B-A928824C48A1}: with operation none
02/18/16 16:20:09:026 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}: with operation repair
02/18/16 16:20:09:026 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860}: with operation install
02/18/16 16:20:09:026 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}: with operation repair
02/18/16 16:20:09:026 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}: with operation repair
02/18/16 16:20:09:026 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Danish Language Pack_AdobePhotoshop16-da_DK_x64 16.0.0.0 {F5D14B6C-DA16-4031-9EB8-AF0728550AFC}: with operation none
02/18/16 16:20:09:026 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}: with operation repair
02/18/16 16:20:09:026 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Finnish Language Pack_AdobePhotoshop16-fi_FI_x64 16.0.0.0 {FD8B8694-1044-4481-A5D9-4740A46BBC3B}: with operation none
02/18/16 16:20:09:026 | [INFO] | | OOBE | DE | | | | 1172 | END InstallOperationsQueue Unordered operations
02/18/16 16:20:09:027 | [INFO] | | OOBE | DE | | | | 1172 | BEGIN InstallOperationsQueue Ordered operations
02/18/16 16:20:09:027 | [INFO] | | OOBE | DE | | | | 1172 | Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}: with operation repair
02/18/16 16:20:09:027 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}: with operation repair
02/18/16 16:20:09:027 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}: with operation repair
02/18/16 16:20:09:027 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}: with operation repair
02/18/16 16:20:09:027 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}: with operation repair
02/18/16 16:20:09:027 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}: with operation repair
02/18/16 16:20:09:027 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}: with operation repair
02/18/16 16:20:09:027 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}: with operation repair
02/18/16 16:20:09:027 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}: with operation repair
02/18/16 16:20:09:027 | [INFO] | | OOBE | DE | | | | 1172 | AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}: with operation repair
02/18/16 16:20:09:027 | [INFO] | | OOBE | DE | | | | 1172 | Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}: with operation repair
02/18/16 16:20:09:027 | [INFO] | | OOBE | DE | | | | 1172 | Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}: with operation repair
02/18/16 16:20:09:027 | [INFO] | | OOBE | DE | | | | 1172 | Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9}: with operation repair
02/18/16 16:20:09:027 | [INFO] | | OOBE | DE | | | | 1172 | Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20}: with operation repair
02/18/16 16:20:09:027 | [INFO] | | OOBE | DE | | | | 1172 | Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC}: with operation repair
02/18/16 16:20:09:027 | [INFO] | | OOBE | DE | | | | 1172 | Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}: with operation repair
02/18/16 16:20:09:027 | [INFO] | | OOBE | DE | | | | 1172 | Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}: with operation repair
02/18/16 16:20:09:027 | [INFO] | | OOBE | DE | | | | 1172 | Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}: with operation repair
02/18/16 16:20:09:027 | [INFO] | | OOBE | DE | | | | 1172 | Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}: with operation repair
02/18/16 16:20:09:028 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}: with operation repair
02/18/16 16:20:09:028 | [INFO] | | OOBE | DE | | | | 1172 | Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860}: with operation install
02/18/16 16:20:09:028 | [INFO] | | OOBE | DE | | | | 1172 | END InstallOperationsQueue Ordered operations
02/18/16 16:20:12:944 | [INFO] | | OOBE | DE | | | | 1172 | Calling the custom action code for pre-repair for payload Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}
02/18/16 16:20:12:945 | [INFO] | | OOBE | DE | | | | 1172 | ::START TIMER:: [Payload Operation :{56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}]
02/18/16 16:20:12:972 | [INFO] | | OOBE | DE | | | | 8120 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:20:12:972 | [INFO] | | OOBE | DE | | | | 8120 | Installer Operation: PayloadUninstaller
02/18/16 16:20:12:972 | [INFO] | | OOBE | DE | | | | 8120 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}
02/18/16 16:20:13:215 | [INFO] | | OOBE | DE | | | | 8120 | Effective AdobeCode for: {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10} is {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}
02/18/16 16:20:13:230 | [INFO] | | OOBE | DE | | | | 8120 | Session includes local copy of payload for repair source
02/18/16 16:20:13:230 | [INFO] | | OOBE | DE | | | | 8120 | Repair payload source package: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeCameraRawProfile8.0All\Install.db
02/18/16 16:20:13:247 | [INFO] | | OOBE | DE | | | | 8120 | Payload Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 16:20:13:398 | [INFO] | | OOBE | DE | | | | 8120 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeCameraRawProfile8.0All\Assets1_1.zip
02/18/16 16:20:13:398 | [INFO] | | OOBE | DE | | | | 8120 | Setting file open option to false in the unzipper
02/18/16 16:20:30:888 | [INFO] | | OOBE | DE | | | | 8120 | Extracting assets complete. Number assets: 1
02/18/16 16:20:30:888 | [INFO] | | OOBE | DE | | | | 8120 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeCameraRawProfile8.0All\Install.db
02/18/16 16:25:38:668 | [INFO] | | OOBE | DE | | | | 8120 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeCameraRawProfile8.0All\Install.db
02/18/16 16:25:38:847 | [INFO] | | OOBE | DE | | | | 8120 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}.db
02/18/16 16:25:45:666 | [INFO] | | OOBE | DE | | | | 8120 | Physical payload repair result:0
02/18/16 16:25:45:930 | [INFO] | | OOBE | DE | | | | 1172 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:25:45:931 | [INFO] | | OOBE | DE | | | | 1172 | :: END TIMER :: [Payload Operation :{56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}] took 332985 milliseconds (332.985 seconds) DTR = 2155.86 KBPS (2.10533 MBPS)
02/18/16 16:25:46:422 | [INFO] | | OOBE | DE | | | | 1172 | Updating driver data - Action: Add driver entry
02/18/16 16:25:46:428 | [INFO] | | OOBE | DE | | | | 1172 | Updating driver data successful. Driver entry was added. ARP estimated size 0KB
02/18/16 16:25:47:305 | [INFO] | | OOBE | DE | | | | 1172 | User specified overrideFile:
02/18/16 16:25:48:318 | [INFO] | | OOBE | DE | | | | 1172 | Successfully updated the csu inventory for Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10} return values 0:0
02/18/16 16:25:48:319 | [INFO] | | OOBE | DE | | | | 1172 | Calling the custom action code for post-repair for payload Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}
02/18/16 16:25:52:481 | [INFO] | | OOBE | DE | | | | 1172 | Calling the custom action code for pre-repair for payload Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}
02/18/16 16:25:52:482 | [INFO] | | OOBE | DE | | | | 1172 | ::START TIMER:: [Payload Operation :{3FB7A108-368A-4849-A3F3-69571BAAC457}]
02/18/16 16:25:52:512 | [INFO] | | OOBE | DE | | | | 5088 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:25:52:512 | [INFO] | | OOBE | DE | | | | 5088 | Installer Operation: PayloadUninstaller
02/18/16 16:25:52:513 | [INFO] | | OOBE | DE | | | | 5088 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {3FB7A108-368A-4849-A3F3-69571BAAC457}
02/18/16 16:25:52:701 | [INFO] | | OOBE | DE | | | | 5088 | Effective AdobeCode for: {3FB7A108-368A-4849-A3F3-69571BAAC457} is {3FB7A108-368A-4849-A3F3-69571BAAC457}
02/18/16 16:25:52:716 | [INFO] | | OOBE | DE | | | | 5088 | Session includes local copy of payload for repair source
02/18/16 16:25:52:716 | [INFO] | | OOBE | DE | | | | 5088 | Repair payload source package: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-Support\Install.db
02/18/16 16:25:52:734 | [INFO] | | OOBE | DE | | | | 5088 | Payload Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 16:25:52:755 | [INFO] | | OOBE | DE | | | | 5088 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-Support\Assets2_1.zip
02/18/16 16:25:52:755 | [INFO] | | OOBE | DE | | | | 5088 | Setting file open option to false in the unzipper
02/18/16 16:25:53:669 | [INFO] | | OOBE | DE | | | | 5088 | Extracting assets complete. Number assets: 1
02/18/16 16:25:53:669 | [INFO] | | OOBE | DE | | | | 5088 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-Support\Install.db
02/18/16 16:26:13:853 | [INFO] | | OOBE | DE | | | | 5088 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-Support\Install.db
02/18/16 16:26:13:905 | [INFO] | | OOBE | DE | | | | 5088 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{3FB7A108-368A-4849-A3F3-69571BAAC457}.db
02/18/16 16:26:14:396 | [INFO] | | OOBE | DE | | | | 5088 | Physical payload repair result:0
02/18/16 16:26:14:467 | [INFO] | | OOBE | DE | | | | 1172 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:26:14:467 | [INFO] | | OOBE | DE | | | | 1172 | :: END TIMER :: [Payload Operation :{3FB7A108-368A-4849-A3F3-69571BAAC457}] took 21985.5 milliseconds (21.9855 seconds) DTR = 90.2411 KBPS (0.0881261 MBPS)
02/18/16 16:26:14:724 | [INFO] | | OOBE | DE | | | | 1172 | User specified overrideFile:
02/18/16 16:26:15:911 | [INFO] | | OOBE | DE | | | | 1172 | Successfully updated the csu inventory for Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457} return values 0:0
02/18/16 16:26:15:912 | [INFO] | | OOBE | DE | | | | 1172 | Calling the custom action code for post-repair for payload Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}
02/18/16 16:26:19:864 | [INFO] | | OOBE | DE | | | | 1172 | Calling the custom action code for pre-repair for payload Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}
02/18/16 16:26:19:865 | [INFO] | | OOBE | DE | | | | 1172 | ::START TIMER:: [Payload Operation :{A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}]
02/18/16 16:26:19:988 | [INFO] | | OOBE | DE | | | | 7776 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:26:19:988 | [INFO] | | OOBE | DE | | | | 7776 | Installer Operation: PayloadUninstaller
02/18/16 16:26:19:988 | [INFO] | | OOBE | DE | | | | 7776 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}
02/18/16 16:26:21:167 | [INFO] | | OOBE | DE | | | | 7776 | Effective AdobeCode for: {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3} is {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}
02/18/16 16:26:21:186 | [INFO] | | OOBE | DE | | | | 7776 | Session includes local copy of payload for repair source
02/18/16 16:26:21:186 | [INFO] | | OOBE | DE | | | | 7776 | Repair payload source package: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePreview1.0All-win64\Install.db
02/18/16 16:26:21:209 | [INFO] | | OOBE | DE | | | | 7776 | Payload Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 16:26:21:605 | [INFO] | | OOBE | DE | | | | 7776 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePreview1.0All-win64\Assets2_1.zip
02/18/16 16:26:21:605 | [INFO] | | OOBE | DE | | | | 7776 | Setting file open option to false in the unzipper
02/18/16 16:26:29:905 | [INFO] | | OOBE | DE | | | | 7776 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePreview1.0All-win64\Assets1_1.zip
02/18/16 16:26:29:905 | [INFO] | | OOBE | DE | | | | 7776 | Setting file open option to false in the unzipper
02/18/16 16:26:32:317 | [INFO] | | OOBE | DE | | | | 7776 | Extracting assets complete. Number assets: 2
02/18/16 16:26:32:317 | [INFO] | | OOBE | DE | | | | 7776 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePreview1.0All-win64\Install.db
02/18/16 16:31:51:451 | [INFO] | | OOBE | DE | | | | 7776 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePreview1.0All-win64\Install.db
02/18/16 16:31:51:763 | [INFO] | | OOBE | DE | | | | 7776 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}.db
02/18/16 16:32:00:408 | [INFO] | | OOBE | DE | | | | 7776 | Physical payload repair result:0
02/18/16 16:32:00:653 | [INFO] | | OOBE | DE | | | | 1172 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:32:00:653 | [INFO] | | OOBE | DE | | | | 1172 | :: END TIMER :: [Payload Operation :{A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}] took 340781 milliseconds (340.781 seconds) DTR = 6.63183 KBPS (0.00647639 MBPS)
02/18/16 16:32:01:397 | [INFO] | | OOBE | DE | | | | 1172 | User specified overrideFile:
02/18/16 16:32:01:810 | [INFO] | | OOBE | DE | | | | 1172 | Successfully updated the csu inventory for Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3} return values 0:0
02/18/16 16:32:01:811 | [INFO] | | OOBE | DE | | | | 1172 | Calling the custom action code for post-repair for payload Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}
02/18/16 16:32:05:467 | [INFO] | | OOBE | DE | | | | 1172 | Calling the custom action code for pre-repair for payload AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}
02/18/16 16:32:05:467 | [INFO] | | OOBE | DE | | | | 1172 | ::START TIMER:: [Payload Operation :{C4196275-B11A-40A1-8727-3C145C8F7D95}]
02/18/16 16:32:05:492 | [INFO] | | OOBE | DE | | | | 1336 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:32:05:493 | [INFO] | | OOBE | DE | | | | 1336 | Installer Operation: PayloadUninstaller
02/18/16 16:32:05:493 | [INFO] | | OOBE | DE | | | | 1336 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:32:05:493 | [INFO] | | OOBE | DE | | | | 1336 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {C4196275-B11A-40A1-8727-3C145C8F7D95}
02/18/16 16:32:06:117 | [INFO] | | OOBE | DE | | | | 1336 | Effective AdobeCode for: {C4196275-B11A-40A1-8727-3C145C8F7D95} is {C4196275-B11A-40A1-8727-3C145C8F7D95}
02/18/16 16:32:06:130 | [INFO] | | OOBE | DE | | | | 1336 | Session includes local copy of payload for repair source
02/18/16 16:32:06:130 | [INFO] | | OOBE | DE | | | | 1336 | Repair payload source package: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorCommonSetCMYK5_0-mul\Install.db
02/18/16 16:32:06:144 | [INFO] | | OOBE | DE | | | | 1336 | Payload AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 16:32:06:166 | [INFO] | | OOBE | DE | | | | 1336 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorCommonSetCMYK5_0-mul\Assets2_1.zip
02/18/16 16:32:06:166 | [INFO] | | OOBE | DE | | | | 1336 | Setting file open option to false in the unzipper
02/18/16 16:32:06:490 | [INFO] | | OOBE | DE | | | | 1336 | Extracting assets complete. Number assets: 1
02/18/16 16:32:06:490 | [INFO] | | OOBE | DE | | | | 1336 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorCommonSetCMYK5_0-mul\Install.db
02/18/16 16:32:09:105 | [INFO] | | OOBE | DE | | | | 1336 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorCommonSetCMYK5_0-mul\Install.db
02/18/16 16:32:09:134 | [INFO] | | OOBE | DE | | | | 1336 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{C4196275-B11A-40A1-8727-3C145C8F7D95}.db
02/18/16 16:32:09:336 | [INFO] | | OOBE | DE | | | | 1336 | Physical payload repair result:0
02/18/16 16:32:09:400 | [INFO] | | OOBE | DE | | | | 1172 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:32:09:400 | [INFO] | | OOBE | DE | | | | 1172 | :: END TIMER :: [Payload Operation :{C4196275-B11A-40A1-8727-3C145C8F7D95}] took 3932.73 milliseconds (3.93273 seconds) DTR = 48.821 KBPS (0.0476768 MBPS)
02/18/16 16:32:09:639 | [INFO] | | OOBE | DE | | | | 1172 | User specified overrideFile:
02/18/16 16:32:10:156 | [INFO] | | OOBE | DE | | | | 1172 | Successfully updated the csu inventory for AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95} return values 0:0
02/18/16 16:32:10:157 | [INFO] | | OOBE | DE | | | | 1172 | Calling the custom action code for post-repair for payload AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}
02/18/16 16:32:14:417 | [INFO] | | OOBE | DE | | | | 1172 | Calling the custom action code for pre-repair for payload AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}
02/18/16 16:32:14:418 | [INFO] | | OOBE | DE | | | | 1172 | ::START TIMER:: [Payload Operation :{C8DEBB29-3EB0-4B97-B652-4DE482B111BC}]
02/18/16 16:32:14:446 | [INFO] | | OOBE | DE | | | | 6264 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:32:14:446 | [INFO] | | OOBE | DE | | | | 6264 | Installer Operation: PayloadUninstaller
02/18/16 16:32:14:446 | [INFO] | | OOBE | DE | | | | 6264 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}
02/18/16 16:32:14:596 | [INFO] | | OOBE | DE | | | | 6264 | Effective AdobeCode for: {C8DEBB29-3EB0-4B97-B652-4DE482B111BC} is {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}
02/18/16 16:32:14:611 | [INFO] | | OOBE | DE | | | | 6264 | Session includes local copy of payload for repair source
02/18/16 16:32:14:612 | [INFO] | | OOBE | DE | | | | 6264 | Repair payload source package: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorCommonSetRGB5_0-mul\Install.db
02/18/16 16:32:14:630 | [INFO] | | OOBE | DE | | | | 6264 | Payload AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 16:32:14:678 | [INFO] | | OOBE | DE | | | | 6264 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorCommonSetRGB5_0-mul\Assets2_1.zip
02/18/16 16:32:14:678 | [INFO] | | OOBE | DE | | | | 6264 | Setting file open option to false in the unzipper
02/18/16 16:32:14:716 | [INFO] | | OOBE | DE | | | | 6264 | Extracting assets complete. Number assets: 1
02/18/16 16:32:14:716 | [INFO] | | OOBE | DE | | | | 6264 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorCommonSetRGB5_0-mul\Install.db
02/18/16 16:32:14:804 | [INFO] | | OOBE | DE | | | | 6264 | Collection adbeadbeadbeadbeadbeadbeadbeadb already exists(Seq 1)
02/18/16 16:32:15:627 | [INFO] | | OOBE | DE | | | | 6264 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorCommonSetRGB5_0-mul\Install.db
02/18/16 16:32:15:661 | [INFO] | | OOBE | DE | | | | 6264 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{C8DEBB29-3EB0-4B97-B652-4DE482B111BC}.db
02/18/16 16:32:16:153 | [INFO] | | OOBE | DE | | | | 6264 | Physical payload repair result:0
02/18/16 16:32:16:215 | [INFO] | | OOBE | DE | | | | 1172 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:32:16:215 | [INFO] | | OOBE | DE | | | | 1172 | :: END TIMER :: [Payload Operation :{C8DEBB29-3EB0-4B97-B652-4DE482B111BC}] took 1796.35 milliseconds (1.79635 seconds)
02/18/16 16:32:16:500 | [INFO] | | OOBE | DE | | | | 1172 | User specified overrideFile:
02/18/16 16:32:16:769 | [INFO] | | OOBE | DE | | | | 1172 | Successfully updated the csu inventory for AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC} return values 0:0
02/18/16 16:32:16:770 | [INFO] | | OOBE | DE | | | | 1172 | Calling the custom action code for post-repair for payload AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}
02/18/16 16:32:21:182 | [INFO] | | OOBE | DE | | | | 1172 | Calling the custom action code for pre-repair for payload AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}
02/18/16 16:32:21:182 | [INFO] | | OOBE | DE | | | | 1172 | ::START TIMER:: [Payload Operation :{F6DED2DA-1D20-497E-8810-E745B45DCD28}]
02/18/16 16:32:21:211 | [INFO] | | OOBE | DE | | | | 6412 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:32:21:211 | [INFO] | | OOBE | DE | | | | 6412 | Installer Operation: PayloadUninstaller
02/18/16 16:32:21:211 | [INFO] | | OOBE | DE | | | | 6412 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {F6DED2DA-1D20-497E-8810-E745B45DCD28}
02/18/16 16:32:21:360 | [INFO] | | OOBE | DE | | | | 6412 | Effective AdobeCode for: {F6DED2DA-1D20-497E-8810-E745B45DCD28} is {F6DED2DA-1D20-497E-8810-E745B45DCD28}
02/18/16 16:32:21:377 | [INFO] | | OOBE | DE | | | | 6412 | Session includes local copy of payload for repair source
02/18/16 16:32:21:377 | [INFO] | | OOBE | DE | | | | 6412 | Repair payload source package: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorEU_ExtraSettings5_0-mul\Install.db
02/18/16 16:32:21:391 | [INFO] | | OOBE | DE | | | | 6412 | Payload AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 16:32:21:414 | [INFO] | | OOBE | DE | | | | 6412 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorEU_ExtraSettings5_0-mul\Assets2_1.zip
02/18/16 16:32:21:415 | [INFO] | | OOBE | DE | | | | 6412 | Setting file open option to false in the unzipper
02/18/16 16:32:21:480 | [INFO] | | OOBE | DE | | | | 6412 | Extracting assets complete. Number assets: 1
02/18/16 16:32:21:480 | [INFO] | | OOBE | DE | | | | 6412 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorEU_ExtraSettings5_0-mul\Install.db
02/18/16 16:32:21:903 | [INFO] | | OOBE | DE | | | | 6412 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorEU_ExtraSettings5_0-mul\Install.db
02/18/16 16:32:21:930 | [INFO] | | OOBE | DE | | | | 6412 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{F6DED2DA-1D20-497E-8810-E745B45DCD28}.db
02/18/16 16:32:22:363 | [INFO] | | OOBE | DE | | | | 6412 | Physical payload repair result:0
02/18/16 16:32:22:454 | [INFO] | | OOBE | DE | | | | 1172 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:32:22:454 | [INFO] | | OOBE | DE | | | | 1172 | :: END TIMER :: [Payload Operation :{F6DED2DA-1D20-497E-8810-E745B45DCD28}] took 1271.79 milliseconds (1.27179 seconds)
02/18/16 16:32:22:675 | [INFO] | | OOBE | DE | | | | 1172 | User specified overrideFile:
02/18/16 16:32:23:013 | [INFO] | | OOBE | DE | | | | 1172 | Successfully updated the csu inventory for AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28} return values 0:0
02/18/16 16:32:23:014 | [INFO] | | OOBE | DE | | | | 1172 | Calling the custom action code for post-repair for payload AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}
02/18/16 16:32:27:165 | [INFO] | | OOBE | DE | | | | 1172 | Calling the custom action code for pre-repair for payload AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}
02/18/16 16:32:27:165 | [INFO] | | OOBE | DE | | | | 1172 | ::START TIMER:: [Payload Operation :{A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}]
02/18/16 16:32:27:190 | [INFO] | | OOBE | DE | | | | 2236 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:32:27:190 | [INFO] | | OOBE | DE | | | | 2236 | Installer Operation: PayloadUninstaller
02/18/16 16:32:27:190 | [INFO] | | OOBE | DE | | | | 2236 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}
02/18/16 16:32:27:359 | [INFO] | | OOBE | DE | | | | 2236 | Effective AdobeCode for: {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB} is {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}
02/18/16 16:32:27:373 | [INFO] | | OOBE | DE | | | | 2236 | Session includes local copy of payload for repair source
02/18/16 16:32:27:373 | [INFO] | | OOBE | DE | | | | 2236 | Repair payload source package: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorJA_ExtraSettings5_0-mul\Install.db
02/18/16 16:32:27:386 | [INFO] | | OOBE | DE | | | | 2236 | Payload AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 16:32:27:407 | [INFO] | | OOBE | DE | | | | 2236 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorJA_ExtraSettings5_0-mul\Assets2_1.zip
02/18/16 16:32:27:407 | [INFO] | | OOBE | DE | | | | 2236 | Setting file open option to false in the unzipper
02/18/16 16:32:27:500 | [INFO] | | OOBE | DE | | | | 2236 | Extracting assets complete. Number assets: 1
02/18/16 16:32:27:500 | [INFO] | | OOBE | DE | | | | 2236 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorJA_ExtraSettings5_0-mul\Install.db
02/18/16 16:32:28:158 | [INFO] | | OOBE | DE | | | | 2236 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorJA_ExtraSettings5_0-mul\Install.db
02/18/16 16:32:28:205 | [INFO] | | OOBE | DE | | | | 2236 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}.db
02/18/16 16:32:28:461 | [INFO] | | OOBE | DE | | | | 2236 | Physical payload repair result:0
02/18/16 16:32:28:491 | [INFO] | | OOBE | DE | | | | 1172 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:32:28:491 | [INFO] | | OOBE | DE | | | | 1172 | :: END TIMER :: [Payload Operation :{A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}] took 1325.7 milliseconds (1.3257 seconds)
02/18/16 16:32:28:709 | [INFO] | | OOBE | DE | | | | 1172 | User specified overrideFile:
02/18/16 16:32:28:967 | [INFO] | | OOBE | DE | | | | 1172 | Successfully updated the csu inventory for AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB} return values 0:0
02/18/16 16:32:28:968 | [INFO] | | OOBE | DE | | | | 1172 | Calling the custom action code for post-repair for payload AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}
02/18/16 16:32:32:836 | [INFO] | | OOBE | DE | | | | 1172 | Calling the custom action code for pre-repair for payload AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}
02/18/16 16:32:32:836 | [INFO] | | OOBE | DE | | | | 1172 | ::START TIMER:: [Payload Operation :{AB955DCF-69CD-4840-B7FB-F318CDD0AE44}]
02/18/16 16:32:32:863 | [INFO] | | OOBE | DE | | | | 7740 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:32:32:864 | [INFO] | | OOBE | DE | | | | 7740 | Installer Operation: PayloadUninstaller
02/18/16 16:32:32:864 | [INFO] | | OOBE | DE | | | | 7740 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:32:32:864 | [INFO] | | OOBE | DE | | | | 7740 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}
02/18/16 16:32:33:208 | [INFO] | | OOBE | DE | | | | 7740 | Effective AdobeCode for: {AB955DCF-69CD-4840-B7FB-F318CDD0AE44} is {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}
02/18/16 16:32:33:223 | [INFO] | | OOBE | DE | | | | 7740 | Session includes local copy of payload for repair source
02/18/16 16:32:33:223 | [INFO] | | OOBE | DE | | | | 7740 | Repair payload source package: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorNA_Recommended5_0-mul\Install.db
02/18/16 16:32:33:233 | [INFO] | | OOBE | DE | | | | 7740 | Payload AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 16:32:33:254 | [INFO] | | OOBE | DE | | | | 7740 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorNA_Recommended5_0-mul\Assets2_1.zip
02/18/16 16:32:33:254 | [INFO] | | OOBE | DE | | | | 7740 | Setting file open option to false in the unzipper
02/18/16 16:32:33:344 | [INFO] | | OOBE | DE | | | | 7740 | Extracting assets complete. Number assets: 1
02/18/16 16:32:33:344 | [INFO] | | OOBE | DE | | | | 7740 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorNA_Recommended5_0-mul\Install.db
02/18/16 16:32:35:502 | [INFO] | | OOBE | DE | | | | 7740 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorNA_Recommended5_0-mul\Install.db
02/18/16 16:32:35:537 | [INFO] | | OOBE | DE | | | | 7740 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{AB955DCF-69CD-4840-B7FB-F318CDD0AE44}.db
02/18/16 16:32:36:008 | [INFO] | | OOBE | DE | | | | 7740 | Physical payload repair result:0
02/18/16 16:32:36:071 | [INFO] | | OOBE | DE | | | | 1172 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:32:36:071 | [INFO] | | OOBE | DE | | | | 1172 | :: END TIMER :: [Payload Operation :{AB955DCF-69CD-4840-B7FB-F318CDD0AE44}] took 3234.62 milliseconds (3.23462 seconds) DTR = 76.6705 KBPS (0.0748736 MBPS)
02/18/16 16:32:36:378 | [INFO] | | OOBE | DE | | | | 1172 | User specified overrideFile:
02/18/16 16:32:36:709 | [INFO] | | OOBE | DE | | | | 1172 | Successfully updated the csu inventory for AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44} return values 0:0
02/18/16 16:32:36:710 | [INFO] | | OOBE | DE | | | | 1172 | Calling the custom action code for post-repair for payload AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}
02/18/16 16:32:39:690 | [INFO] | | OOBE | DE | | | | 1172 | Calling the custom action code for pre-repair for payload AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}
02/18/16 16:32:39:691 | [INFO] | | OOBE | DE | | | | 1172 | ::START TIMER:: [Payload Operation :{5C5D62C9-91C6-415E-857E-9130C0F52C66}]
02/18/16 16:32:39:709 | [INFO] | | OOBE | DE | | | | 6780 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:32:39:709 | [INFO] | | OOBE | DE | | | | 6780 | Installer Operation: PayloadUninstaller
02/18/16 16:32:39:709 | [INFO] | | OOBE | DE | | | | 6780 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {5C5D62C9-91C6-415E-857E-9130C0F52C66}
02/18/16 16:32:41:676 | [INFO] | | OOBE | DE | | | | 6780 | Effective AdobeCode for: {5C5D62C9-91C6-415E-857E-9130C0F52C66} is {5C5D62C9-91C6-415E-857E-9130C0F52C66}
02/18/16 16:32:41:743 | [INFO] | | OOBE | DE | | | | 6780 | Session includes local copy of payload for repair source
02/18/16 16:32:41:743 | [INFO] | | OOBE | DE | | | | 6780 | Repair payload source package: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorPhotoshop5_0-mul\Install.db
02/18/16 16:32:41:860 | [INFO] | | OOBE | DE | | | | 6780 | Payload AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 16:32:42:001 | [INFO] | | OOBE | DE | | | | 6780 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorPhotoshop5_0-mul\Assets2_1.zip
02/18/16 16:32:42:001 | [INFO] | | OOBE | DE | | | | 6780 | Setting file open option to false in the unzipper
02/18/16 16:32:42:394 | [INFO] | | OOBE | DE | | | | 6780 | Extracting assets complete. Number assets: 1
02/18/16 16:32:42:394 | [INFO] | | OOBE | DE | | | | 6780 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorPhotoshop5_0-mul\Install.db
02/18/16 16:32:42:692 | [INFO] | | OOBE | DE | | | | 6780 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorPhotoshop5_0-mul\Install.db
02/18/16 16:32:42:718 | [INFO] | | OOBE | DE | | | | 6780 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{5C5D62C9-91C6-415E-857E-9130C0F52C66}.db
02/18/16 16:32:42:895 | [INFO] | | OOBE | DE | | | | 6780 | Physical payload repair result:0
02/18/16 16:32:43:179 | [INFO] | | OOBE | DE | | | | 1172 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:32:43:180 | [INFO] | | OOBE | DE | | | | 1172 | :: END TIMER :: [Payload Operation :{5C5D62C9-91C6-415E-857E-9130C0F52C66}] took 3490.04 milliseconds (3.49004 seconds) DTR = 132.95 KBPS (0.129834 MBPS)
02/18/16 16:32:43:427 | [INFO] | | OOBE | DE | | | | 1172 | User specified overrideFile:
02/18/16 16:32:44:336 | [INFO] | | OOBE | DE | | | | 1172 | Successfully updated the csu inventory for AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66} return values 0:0
02/18/16 16:32:44:337 | [INFO] | | OOBE | DE | | | | 1172 | Calling the custom action code for post-repair for payload AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}
02/18/16 16:32:48:113 | [INFO] | | OOBE | DE | | | | 1172 | Calling the custom action code for pre-repair for payload AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}
02/18/16 16:32:48:114 | [INFO] | | OOBE | DE | | | | 1172 | ::START TIMER:: [Payload Operation :{CE9B1B00-0421-4701-9698-1C14646D6D94}]
02/18/16 16:32:48:149 | [INFO] | | OOBE | DE | | | | 6496 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:32:48:149 | [INFO] | | OOBE | DE | | | | 6496 | Installer Operation: PayloadUninstaller
02/18/16 16:32:48:149 | [INFO] | | OOBE | DE | | | | 6496 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {CE9B1B00-0421-4701-9698-1C14646D6D94}
02/18/16 16:32:49:162 | [INFO] | | OOBE | DE | | | | 6496 | Effective AdobeCode for: {CE9B1B00-0421-4701-9698-1C14646D6D94} is {CE9B1B00-0421-4701-9698-1C14646D6D94}
02/18/16 16:32:49:177 | [INFO] | | OOBE | DE | | | | 6496 | Session includes local copy of payload for repair source
02/18/16 16:32:49:178 | [INFO] | | OOBE | DE | | | | 6496 | Repair payload source package: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeVideoProfilesCS5_0-mul\Install.db
02/18/16 16:32:49:190 | [INFO] | | OOBE | DE | | | | 6496 | Payload AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 16:32:49:210 | [INFO] | | OOBE | DE | | | | 6496 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeVideoProfilesCS5_0-mul\Assets2_1.zip
02/18/16 16:32:49:210 | [INFO] | | OOBE | DE | | | | 6496 | Setting file open option to false in the unzipper
02/18/16 16:32:49:511 | [INFO] | | OOBE | DE | | | | 6496 | Extracting assets complete. Number assets: 1
02/18/16 16:32:49:511 | [INFO] | | OOBE | DE | | | | 6496 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeVideoProfilesCS5_0-mul\Install.db
02/18/16 16:32:49:521 | [INFO] | | OOBE | DE | | | | 6496 | Collection adbeadbeadbeadbeadbeadbeadbeadb already exists(Seq 1)
02/18/16 16:32:50:521 | [INFO] | | OOBE | DE | | | | 6496 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeVideoProfilesCS5_0-mul\Install.db
02/18/16 16:32:50:561 | [INFO] | | OOBE | DE | | | | 6496 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{CE9B1B00-0421-4701-9698-1C14646D6D94}.db
02/18/16 16:32:51:527 | [INFO] | | OOBE | DE | | | | 6496 | Physical payload repair result:0
02/18/16 16:32:51:607 | [INFO] | | OOBE | DE | | | | 1172 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:32:51:607 | [INFO] | | OOBE | DE | | | | 1172 | :: END TIMER :: [Payload Operation :{CE9B1B00-0421-4701-9698-1C14646D6D94}] took 3492.96 milliseconds (3.49296 seconds) DTR = 270.258 KBPS (0.263924 MBPS)
02/18/16 16:32:52:559 | [INFO] | | OOBE | DE | | | | 1172 | User specified overrideFile:
02/18/16 16:32:53:205 | [INFO] | | OOBE | DE | | | | 1172 | Successfully updated the csu inventory for AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94} return values 0:0
02/18/16 16:32:53:206 | [INFO] | | OOBE | DE | | | | 1172 | Calling the custom action code for post-repair for payload AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}
02/18/16 16:32:57:484 | [INFO] | | OOBE | DE | | | | 1172 | Calling the custom action code for pre-repair for payload Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}
02/18/16 16:32:57:484 | [INFO] | | OOBE | DE | | | | 1172 | ::START TIMER:: [Payload Operation :{27375F7C-0789-4FEA-889E-41BF12AC3140}]
02/18/16 16:32:57:514 | [INFO] | | OOBE | DE | | | | 7504 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:32:57:514 | [INFO] | | OOBE | DE | | | | 7504 | Installer Operation: PayloadUninstaller
02/18/16 16:32:57:514 | [INFO] | | OOBE | DE | | | | 7504 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {27375F7C-0789-4FEA-889E-41BF12AC3140}
02/18/16 16:32:57:723 | [INFO] | | OOBE | DE | | | | 7504 | Effective AdobeCode for: {27375F7C-0789-4FEA-889E-41BF12AC3140} is {27375F7C-0789-4FEA-889E-41BF12AC3140}
02/18/16 16:32:57:738 | [INFO] | | OOBE | DE | | | | 7504 | Session includes local copy of payload for repair source
02/18/16 16:32:57:738 | [INFO] | | OOBE | DE | | | | 7504 | Repair payload source package: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeExportAssets2.0All-x64\Install.db
02/18/16 16:32:57:753 | [INFO] | | OOBE | DE | | | | 7504 | Payload Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 16:32:57:772 | [INFO] | | OOBE | DE | | | | 7504 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeExportAssets2.0All-x64\Assets2_1.zip
02/18/16 16:32:57:772 | [INFO] | | OOBE | DE | | | | 7504 | Setting file open option to false in the unzipper
02/18/16 16:33:01:784 | [INFO] | | OOBE | DE | | | | 7504 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeExportAssets2.0All-x64\Assets1_1.zip
02/18/16 16:33:01:784 | [INFO] | | OOBE | DE | | | | 7504 | Setting file open option to false in the unzipper
02/18/16 16:33:02:671 | [INFO] | | OOBE | DE | | | | 7504 | Extracting assets complete. Number assets: 2
02/18/16 16:33:02:671 | [INFO] | | OOBE | DE | | | | 7504 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeExportAssets2.0All-x64\Install.db
02/18/16 16:36:22:116 | [INFO] | | OOBE | DE | | | | 7504 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeExportAssets2.0All-x64\Install.db
02/18/16 16:36:22:552 | [INFO] | | OOBE | DE | | | | 7504 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{27375F7C-0789-4FEA-889E-41BF12AC3140}.db
02/18/16 16:36:26:621 | [INFO] | | OOBE | DE | | | | 7504 | Physical payload repair result:0
02/18/16 16:36:26:716 | [INFO] | | OOBE | DE | | | | 1172 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:36:26:716 | [INFO] | | OOBE | DE | | | | 1172 | :: END TIMER :: [Payload Operation :{27375F7C-0789-4FEA-889E-41BF12AC3140}] took 209227 milliseconds (209.227 seconds) DTR = 2.38975 KBPS (0.00233374 MBPS)
02/18/16 16:36:27:218 | [INFO] | | OOBE | DE | | | | 1172 | User specified overrideFile:
02/18/16 16:36:27:634 | [INFO] | | OOBE | DE | | | | 1172 | Successfully updated the csu inventory for Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140} return values 0:0
02/18/16 16:36:27:635 | [INFO] | | OOBE | DE | | | | 1172 | Calling the custom action code for post-repair for payload Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}
02/18/16 16:36:31:891 | [INFO] | | OOBE | DE | | | | 1172 | Calling the custom action code for pre-repair for payload Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}
02/18/16 16:36:31:892 | [INFO] | | OOBE | DE | | | | 1172 | ::START TIMER:: [Payload Operation :{54B0C34F-18F9-11E2-BC1D-00215AEA26C9}]
02/18/16 16:36:31:919 | [INFO] | | OOBE | DE | | | | 1456 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:36:31:919 | [INFO] | | OOBE | DE | | | | 1456 | Installer Operation: ModifyThirdPartyPayloadOperation
02/18/16 16:36:31:919 | [INFO] | | OOBE | DE | | | | 1456 | Modify Thirdparty payload
02/18/16 16:36:32:137 | [INFO] | | OOBE | DE | | | | 1456 | Repairing third party payload with source: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\Microsoft VC 2010 Redist (x64)\vcredist_x64.exe
02/18/16 16:36:32:154 | [INFO] | | OOBE | DE | | | | 1456 | Repairing third party payload
02/18/16 16:36:32:154 | [INFO] | | OOBE | DE | | | | 1456 | Third party application path:C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\Microsoft VC 2010 Redist (x64)\vcredist_x64.exe
02/18/16 16:36:32:154 | [INFO] | | OOBE | DE | | | | 1456 | CommandLine: /q /norestart
02/18/16 16:36:55:121 | [INFO] | | OOBE | DE | | | | 1456 | Third party payload completed. Testing return code: 0
02/18/16 16:36:55:183 | [INFO] | | OOBE | DE | | | | 1172 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:36:55:183 | [INFO] | | OOBE | DE | | | | 1172 | :: END TIMER :: [Payload Operation :{54B0C34F-18F9-11E2-BC1D-00215AEA26C9}] took 23290.5 milliseconds (23.2905 seconds) DTR = 52.3819 KBPS (0.0511542 MBPS)
02/18/16 16:36:55:479 | [INFO] | | OOBE | DE | | | | 1172 | User specified overrideFile:
02/18/16 16:36:55:912 | [INFO] | | OOBE | DE | | | | 1172 | The csu inventory was not updated for payload Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}, value of local var is -1
02/18/16 16:36:55:913 | [INFO] | | OOBE | DE | | | | 1172 | Calling the custom action code for post-repair for payload Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}
02/18/16 16:37:00:274 | [INFO] | | OOBE | DE | | | | 1172 | Calling the custom action code for pre-repair for payload Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9}
02/18/16 16:37:00:275 | [INFO] | | OOBE | DE | | | | 1172 | ::START TIMER:: [Payload Operation :{55B82130-18F9-11E2-8D43-00215AEA26C9}]
02/18/16 16:37:00:307 | [INFO] | | OOBE | DE | | | | 7044 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:37:00:308 | [INFO] | | OOBE | DE | | | | 7044 | Installer Operation: ModifyThirdPartyPayloadOperation
02/18/16 16:37:00:308 | [INFO] | | OOBE | DE | | | | 7044 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:37:00:308 | [INFO] | | OOBE | DE | | | | 7044 | Modify Thirdparty payload
02/18/16 16:37:00:531 | [INFO] | | OOBE | DE | | | | 7044 | Repairing third party payload with source: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\Microsoft VC 2010 Redist (x86)\vcredist_x86.exe
02/18/16 16:37:00:545 | [INFO] | | OOBE | DE | | | | 7044 | Repairing third party payload
02/18/16 16:37:00:545 | [INFO] | | OOBE | DE | | | | 7044 | Third party application path:C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\Microsoft VC 2010 Redist (x86)\vcredist_x86.exe
02/18/16 16:37:00:545 | [INFO] | | OOBE | DE | | | | 7044 | CommandLine: /q /norestart
02/18/16 16:37:26:500 | [INFO] | | OOBE | DE | | | | 7044 | Third party payload completed. Testing return code: 0
02/18/16 16:37:26:576 | [INFO] | | OOBE | DE | | | | 1172 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:37:26:577 | [INFO] | | OOBE | DE | | | | 1172 | :: END TIMER :: [Payload Operation :{55B82130-18F9-11E2-8D43-00215AEA26C9}] took 26302.8 milliseconds (26.3028 seconds) DTR = 82.7289 KBPS (0.08079 MBPS)
02/18/16 16:37:26:822 | [INFO] | | OOBE | DE | | | | 1172 | User specified overrideFile:
02/18/16 16:37:27:566 | [INFO] | | OOBE | DE | | | | 1172 | The csu inventory was not updated for payload Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9}, value of local var is -1
02/18/16 16:37:27:567 | [INFO] | | OOBE | DE | | | | 1172 | Calling the custom action code for post-repair for payload Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9}
02/18/16 16:37:32:186 | [INFO] | | OOBE | DE | | | | 1172 | Calling the custom action code for pre-repair for payload Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20}
02/18/16 16:37:32:186 | [INFO] | | OOBE | DE | | | | 1172 | ::START TIMER:: [Payload Operation :{3E272A93-C06B-4206-AD02-0EBE02535E20}]
02/18/16 16:37:32:223 | [INFO] | | OOBE | DE | | | | 7796 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:37:32:223 | [INFO] | | OOBE | DE | | | | 7796 | Installer Operation: ModifyThirdPartyPayloadOperation
02/18/16 16:37:32:223 | [INFO] | | OOBE | DE | | | | 7796 | Modify Thirdparty payload
02/18/16 16:37:32:510 | [INFO] | | OOBE | DE | | | | 7796 | Repairing third party payload with source: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\Microsoft VC 2012 Redist (x64)\vcredist_x64.exe
02/18/16 16:37:32:523 | [INFO] | | OOBE | DE | | | | 7796 | Repairing third party payload
02/18/16 16:37:32:523 | [INFO] | | OOBE | DE | | | | 7796 | Third party application path:C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\Microsoft VC 2012 Redist (x64)\vcredist_x64.exe
02/18/16 16:37:32:523 | [INFO] | | OOBE | DE | | | | 7796 | CommandLine: /q /norestart
02/18/16 16:38:26:969 | [INFO] | | OOBE | DE | | | | 7796 | Third party payload completed. Testing return code: 0
02/18/16 16:38:41:617 | [INFO] | | OOBE | DE | | | | 1172 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:38:41:617 | [INFO] | | OOBE | DE | | | | 1172 | :: END TIMER :: [Payload Operation :{3E272A93-C06B-4206-AD02-0EBE02535E20}] took 69430.7 milliseconds (69.4307 seconds) DTR = 4720.79 KBPS (4.61015 MBPS)
02/18/16 16:38:54:464 | [INFO] | | OOBE | DE | | | | 1172 | User specified overrideFile:
02/18/16 16:39:00:690 | [INFO] | | OOBE | DE | | | | 1172 | The csu inventory was not updated for payload Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20}, value of local var is -1
02/18/16 16:39:00:691 | [INFO] | | OOBE | DE | | | | 1172 | Calling the custom action code for post-repair for payload Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20}
02/18/16 16:39:05:725 | [INFO] | | OOBE | DE | | | | 1172 | Calling the custom action code for pre-repair for payload Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC}
02/18/16 16:39:05:726 | [INFO] | | OOBE | DE | | | | 1172 | ::START TIMER:: [Payload Operation :{873BE68F-480F-49A6-9649-F98CAB056AFC}]
02/18/16 16:39:05:887 | [INFO] | | OOBE | DE | | | | 7692 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:39:05:887 | [INFO] | | OOBE | DE | | | | 7692 | Installer Operation: ModifyThirdPartyPayloadOperation
02/18/16 16:39:05:887 | [INFO] | | OOBE | DE | | | | 7692 | Modify Thirdparty payload
02/18/16 16:39:07:675 | [INFO] | | OOBE | DE | | | | 7692 | Repairing third party payload with source: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\Microsoft VC 2012 Redist (x86)\vcredist_x86.exe
02/18/16 16:39:07:709 | [INFO] | | OOBE | DE | | | | 7692 | Repairing third party payload
02/18/16 16:39:07:709 | [INFO] | | OOBE | DE | | | | 7692 | Third party application path:C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\Microsoft VC 2012 Redist (x86)\vcredist_x86.exe
02/18/16 16:39:07:709 | [INFO] | | OOBE | DE | | | | 7692 | CommandLine: /q /norestart
02/18/16 16:40:46:816 | [INFO] | | OOBE | DE | | | | 7692 | Third party payload completed. Testing return code: 0
02/18/16 16:40:46:941 | [INFO] | | OOBE | DE | | | | 1172 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:40:46:941 | [INFO] | | OOBE | DE | | | | 1172 | :: END TIMER :: [Payload Operation :{873BE68F-480F-49A6-9649-F98CAB056AFC}] took 101212 milliseconds (101.212 seconds) DTR = 879.617 KBPS (0.859001 MBPS)
02/18/16 16:40:51:135 | [INFO] | | OOBE | DE | | | | 1172 | User specified overrideFile:
02/18/16 16:41:07:801 | [INFO] | | OOBE | DE | | | | 1172 | The csu inventory was not updated for payload Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC}, value of local var is -1
02/18/16 16:41:07:802 | [INFO] | | OOBE | DE | | | | 1172 | Calling the custom action code for post-repair for payload Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC}
02/18/16 16:41:12:323 | [INFO] | | OOBE | DE | | | | 1172 | Calling the custom action code for pre-repair for payload Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}
02/18/16 16:41:12:324 | [INFO] | | OOBE | DE | | | | 1172 | ::START TIMER:: [Payload Operation :{4CED09CB-0C96-4EAE-83C4-7D9B9456E613}]
02/18/16 16:41:12:433 | [INFO] | | OOBE | DE | | | | 5256 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:41:12:434 | [INFO] | | OOBE | DE | | | | 5256 | Installer Operation: ModifyThirdPartyPayloadOperation
02/18/16 16:41:12:434 | [INFO] | | OOBE | DE | | | | 5256 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:41:12:434 | [INFO] | | OOBE | DE | | | | 5256 | Modify Thirdparty payload
02/18/16 16:41:15:341 | [INFO] | | OOBE | DE | | | | 5256 | Repairing third party payload with source: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\Microsoft VC 2013 Redist (x64)\vcredist_x64.exe
02/18/16 16:41:15:368 | [INFO] | | OOBE | DE | | | | 5256 | Repairing third party payload
02/18/16 16:41:15:368 | [INFO] | | OOBE | DE | | | | 5256 | Third party application path:C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\Microsoft VC 2013 Redist (x64)\vcredist_x64.exe
02/18/16 16:41:15:368 | [INFO] | | OOBE | DE | | | | 5256 | CommandLine: /q /norestart
02/18/16 16:43:19:285 | [ERROR] | | OOBE | DE | | | | 6184 | ASU has quit unexpectedly.
02/18/16 16:43:28:559 | [INFO] | | OOBE | DE | | | | 5256 | Third party payload completed. Testing return code: 0
02/18/16 16:43:29:354 | [INFO] | | OOBE | DE | | | | 1172 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:43:29:354 | [INFO] | | OOBE | DE | | | | 1172 | :: END TIMER :: [Payload Operation :{4CED09CB-0C96-4EAE-83C4-7D9B9456E613}] took 137028 milliseconds (137.028 seconds) DTR = 1377.12 KBPS (1.34484 MBPS)
02/18/16 16:43:56:593 | [INFO] | | OOBE | DE | | | | 1172 | User specified overrideFile:
02/18/16 16:44:02:540 | [INFO] | | OOBE | DE | | | | 1172 | The csu inventory was not updated for payload Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}, value of local var is -1
02/18/16 16:44:02:540 | [INFO] | | OOBE | DE | | | | 1172 | Calling the custom action code for post-repair for payload Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}
02/18/16 16:44:02:541 | [ERROR] | | OOBE | DE | | | | 1172 | DW001: Set payload cancelled status
02/18/16 16:44:02:541 | [INFO] | | OOBE | DE | | | | 1172 | No operation. We're done:
02/18/16 16:44:02:544 | [INFO] | | OOBE | DE | | | | 1172 | Updating driver data - Action: Remove driver entry
02/18/16 16:44:02:560 | [INFO] | | OOBE | DE | | | | 1172 | Updating driver data successful. Driver entry was added. ARP estimated size 1997481KB
02/18/16 16:44:06:959 | [WARN] | | OOBE | DE | | | | 1172 | DW049: Payload Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85} has an action "repair" but no resultState
02/18/16 16:44:06:961 | [WARN] | | OOBE | DE | | | | 1172 | DW049: Payload Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA} has an action "repair" but no resultState
02/18/16 16:44:06:961 | [WARN] | | OOBE | DE | | | | 1172 | DW049: Payload Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21} has an action "repair" but no resultState
02/18/16 16:44:06:962 | [WARN] | | OOBE | DE | | | | 1172 | DW049: Payload Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860} has an action "install" but no resultState
02/18/16 16:44:08:964 | [INFO] | | OOBE | DE | | | | 1172 | Total components installed: 0
02/18/16 16:44:08:965 | [INFO] | | OOBE | DE | | | | 1172 | Successfully repaired 16 components:
02/18/16 16:44:08:965 | [INFO] | | OOBE | DE | | | | 1172 | - Export Assets 2 (64 bit)
02/18/16 16:44:08:965 | [INFO] | | OOBE | DE | | | | 1172 | - Microsoft Visual C++ 2012 Redistributable Package (x64)
02/18/16 16:44:08:965 | [INFO] | | OOBE | DE | | | | 1172 | - Adobe Photoshop CC 2015 Support
02/18/16 16:44:08:965 | [INFO] | | OOBE | DE | | | | 1172 | - Microsoft Visual C++ 2013 Redistributable Package (x64)
02/18/16 16:44:08:965 | [INFO] | | OOBE | DE | | | | 1172 | - Microsoft Visual C++ 2010 Redistributable Package (x64)
02/18/16 16:44:08:965 | [INFO] | | OOBE | DE | | | | 1172 | - Microsoft Visual C++ 2010 Redistributable Package (x86)
02/18/16 16:44:08:965 | [INFO] | | OOBE | DE | | | | 1172 | - Camera Profiles Installer
02/18/16 16:44:08:965 | [INFO] | | OOBE | DE | | | | 1172 | - AdobeColorPhotoshop CC
02/18/16 16:44:08:965 | [INFO] | | OOBE | DE | | | | 1172 | - Microsoft Visual C++ 2012 Redistributable Package (x86)
02/18/16 16:44:08:965 | [INFO] | | OOBE | DE | | | | 1172 | - AdobeColorJA CC
02/18/16 16:44:08:965 | [INFO] | | OOBE | DE | | | | 1172 | - Adobe Preview CC
02/18/16 16:44:08:965 | [INFO] | | OOBE | DE | | | | 1172 | - AdobeColorNA CC
02/18/16 16:44:08:965 | [INFO] | | OOBE | DE | | | | 1172 | - AdobeColorCommonSetCMYK CC
02/18/16 16:44:08:965 | [INFO] | | OOBE | DE | | | | 1172 | - AdobeColorCommonSetRGB CC
02/18/16 16:44:08:965 | [INFO] | | OOBE | DE | | | | 1172 | - AdobeColorVideoProfilesCS CC
02/18/16 16:44:08:965 | [INFO] | | OOBE | DE | | | | 1172 | - AdobeColorEU CC
02/18/16 16:44:08:966 | [INFO] | | OOBE | DE | | | | 1172 | Total components removed: 0
02/18/16 16:44:08:966 | [WARN] | | OOBE | DE | | | | 1172 | DW050: The following payload errors were found during install:
02/18/16 16:44:08:966 | [WARN] | | OOBE | DE | | | | 1172 | DW050: - Microsoft Visual C++ 2013 Redistributable Package (x86): Installation was cancelled due to abnormal termination.
02/18/16 16:44:08:966 | [INFO] | | OOBE | DE | | | | 1172 | Call PostSession Custom Hook
02/18/16 16:44:08:969 | [INFO] | | OOBE | DE | | | | 1172 | :: END TIMER :: [Total Timer] took 1.46165e+006 milliseconds (1461.65 seconds) DTR = 71.0868 KBPS (0.0694207 MBPS)
02/18/16 16:44:09:969 | [INFO] | | OOBE | DE | | | | 1172 | -------------------------------------- Summary --------------------------------------
02/18/16 16:44:09:969 | [INFO] | | OOBE | DE | | | | 1172 | - 0 fatal error(s), 2 error(s)
02/18/16 16:44:09:969 | [INFO] | | OOBE | DE | | | | 1172 | Win OS version: 6.1.0.0 64 bit Type: 1
02/18/16 16:44:09:969 | [INFO] | | OOBE | DE | | | | 1172 | ----------- Payload: Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613} -----------
02/18/16 16:44:09:969 | [INFO] | | OOBE | DE | | | | 1172 | ERROR: ASU has quit unexpectedly.
02/18/16 16:44:09:969 | [INFO] | | OOBE | DE | | | | 1172 | ERROR: DW001: Set payload cancelled status
02/18/16 16:44:09:969 | [INFO] | | OOBE | DE | | | | 1172 | Please search the above error string(s) to find when the error occurred.
02/18/16 16:44:09:969 | [INFO] | | OOBE | DE | | | | 1172 | These errors resulted in installer Exit Code mentioned below.
02/18/16 16:44:09:969 | [INFO] | | OOBE | DE | | | | 1172 | -------------------------------------------------------------------------------------
02/18/16 16:44:09:969 | [INFO] | | OOBE | DE | | | | 1172 | Exit Code: 7 - Unable to complete Silent workflow.
02/18/16 16:44:09:972 | [INFO] | | OOBE | DE | | | | 1172 | Successfully dumped analytics data at: C:\Users\Lenovo\AppData\Local\Temp\{8132DFAB-60C7-4C93-99FE-17AF5FCA3E9C}\{E492FCB1-CC53-427D-AAAD-C0044DA92E45}
02/18/16 16:44:09:972 | [INFO] | | OOBE | DE | | | | 1172 | Please see specific errors for troubleshooting. For example, ERROR: DW001 ...
02/18/16 16:44:09:974 | [INFO] | | OOBE | DE | | | | 1172 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 16:44:09:974 | [INFO] | | OOBE | DE | | | | 1172 | END - Installer Session
02/18/16 18:23:16:455 | [INFO] | | OOBE | DE | | | | 4716 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:23:16:455 | [INFO] | | OOBE | DE | | | | 4716 | START - Installer Session
02/18/16 18:23:16:455 | [INFO] | | OOBE | DE | | | | 4716 | RIBS version: 9.0.0.61
02/18/16 18:23:16:455 | [INFO] | | OOBE | DE | | | | 4716 | Win OS version: 6.1.0.0 64 bit Type: 1
02/18/16 18:23:16:455 | [INFO] | | OOBE | DE | | | | 4716 | ::START TIMER:: [Total Timer]
02/18/16 18:23:16:455 | [INFO] | | OOBE | DE | | | | 4716 | CHECK: Single instance running
02/18/16 18:23:16:455 | [INFO] | | OOBE | DE | | | | 4716 | CHECK : Credentials
02/18/16 18:23:16:455 | [INFO] | | OOBE | DE | | | | 4716 | Load Deployment File
02/18/16 18:23:16:455 | [INFO] | | OOBE | DE | | | | 4716 | CHECK : Another Native OS installer already running
02/18/16 18:23:16:455 | [INFO] | | OOBE | DE | | | | 4716 | Create Required Folders
02/18/16 18:23:16:456 | [INFO] | | OOBE | DE | | | | 4716 | Assuming uninstall mode
02/18/16 18:23:16:456 | [INFO] | | OOBE | DE | | | | 4716 | Lookup for master payload
02/18/16 18:23:16:456 | [INFO] | | OOBE | DE | | | | 4716 | Ready to initialize session to start with ...
02/18/16 18:23:16:456 | [INFO] | | OOBE | DE | | | | 4716 | ::START TIMER:: [CreatePayloadSession]
02/18/16 18:23:16:646 | [INFO] | | OOBE | DE | | | | 4716 | Supported RIBS version range: [0.0.0.0,9.0.0.61]
02/18/16 18:23:16:648 | [INFO] | | OOBE | DE | | | | 4716 | ----------------- CreatePayloadSession: machine is x64 ---------------
02/18/16 18:23:17:593 | [INFO] | | OOBE | DE | | | | 4716 | ______ Verify Dependency Subscribers ______
02/18/16 18:23:17:595 | [INFO] | | OOBE | DE | | | | 4716 | BEGIN Operation order for all session payloads: mediaGroup (requires,satisfies)
02/18/16 18:23:17:595 | [INFO] | | OOBE | DE | | | | 4716 | Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}: 1 (0,2)
02/18/16 18:23:17:596 | [INFO] | | OOBE | DE | | | | 4716 | Camera Profiles Installer_9.4_AdobeCameraRawProfile8.0All 9.4.0.0 {03B147C3-2412-4DE8-80F9-3EB977421EF2}: 2 (0,0)
02/18/16 18:23:17:596 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}: 3 (0,1)
02/18/16 18:23:17:596 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Support_16.1.2_AdobePhotoshop16-Support 16.1.2.0 {4A117739-A3A4-4E1A-8F5A-82CB1958794F}: 4 (0,0)
02/18/16 18:23:17:596 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}: 5 (0,1)
02/18/16 18:23:17:596 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Preview CC_1.1.3_AdobePreview1.0All-win64 1.1.3.0 {27B8946D-664A-4877-A3C9-CE8249CA1D7A}: 6 (0,0)
02/18/16 18:23:17:596 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}: 7 (0,1)
02/18/16 18:23:17:596 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}: 7 (0,1)
02/18/16 18:23:17:596 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorEU CC 5.0.0.0 {9E9EB9FD-FDE8-487A-A41C-7713DA91AC89}: 7 (0,1)
02/18/16 18:23:17:596 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}: 7 (0,1)
02/18/16 18:23:17:596 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorJA CC 5.0.0.0 {52D57F95-000A-4922-BB31-C6A936F4FD7D}: 7 (0,1)
02/18/16 18:23:17:596 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}: 7 (0,1)
02/18/16 18:23:17:596 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorNA CC 5.0.0.0 {72405B80-A3DD-4BB2-A8C4-A90BC7BA50FF}: 7 (0,1)
02/18/16 18:23:17:596 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}: 7 (0,1)
02/18/16 18:23:17:596 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}: 7 (0,1)
02/18/16 18:23:17:596 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}: 7 (0,1)
02/18/16 18:23:17:596 | [INFO] | | OOBE | DE | | | | 4716 | Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}: 7 (0,1)
02/18/16 18:23:17:596 | [INFO] | | OOBE | DE | | | | 4716 | Export Assets 2 (64 bit)_2.4_AdobeExportAssets2.0All-x64 2.4.0.0 {3C285B12-AFED-4136-B575-1D6CA2B71D29}: 8 (0,0)
02/18/16 18:23:17:596 | [INFO] | | OOBE | DE | | | | 4716 | Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}: 9 (0,1)
02/18/16 18:23:17:596 | [INFO] | | OOBE | DE | | | | 4716 | Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9}: 9 (0,1)
02/18/16 18:23:17:596 | [INFO] | | OOBE | DE | | | | 4716 | Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20}: 9 (0,1)
02/18/16 18:23:17:596 | [INFO] | | OOBE | DE | | | | 4716 | Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC}: 9 (0,1)
02/18/16 18:23:17:597 | [INFO] | | OOBE | DE | | | | 4716 | Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}: 9 (0,1)
02/18/16 18:23:17:597 | [INFO] | | OOBE | DE | | | | 4716 | Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}: 9 (0,1)
02/18/16 18:23:17:597 | [INFO] | | OOBE | DE | | | | 4716 | Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}: 9 (0,1)
02/18/16 18:23:17:597 | [INFO] | | OOBE | DE | | | | 4716 | Photoshop Camera Raw 8 (64 bit)_9.4_AdobeCameraRaw8.0All-x64 9.4.0.0 {BE4895E5-6517-4CED-B62A-A5A046ADBFCF}: 10 (0,0)
02/18/16 18:23:17:597 | [INFO] | | OOBE | DE | | | | 4716 | Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}: 11 (1,1)
02/18/16 18:23:17:597 | [INFO] | | OOBE | DE | | | | 4716 | Photoshop Camera Raw 8_9.4_AdobeCameraRaw8.0All 9.4.0.0 {8B793E8B-07C8-4865-A698-FE003249A576}: 12 (0,0)
02/18/16 18:23:17:597 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}: 13 (22,0)
02/18/16 18:23:17:597 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Core_16.1.2_AdobePhotoshop16-Core_x64 16.1.2.0 {F217525B-30EB-42F2-A730-F61139264DB5}: 14 (0,0)
02/18/16 18:23:17:597 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Russian Language Pack_AdobePhotoshop16-ru_RU_x64 16.0.0.0 {6E14FFAB-83F4-4CB7-87A2-703F6F20487A}: 14 (0,0)
02/18/16 18:23:17:597 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 AE English Language Pack_AdobePhotoshop16-en_AE_x64 16.0.0.0 {6E7A3076-3056-492F-966F-1EA4FDCE5FA8}: 14 (0,0)
02/18/16 18:23:17:597 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Ukrainian Language Pack_AdobePhotoshop16-uk_UA_x64 16.0.0.0 {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA}: 14 (0,0)
02/18/16 18:23:17:597 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Canadian French Language Pack_AdobePhotoshop16-fr_CA_x64 16.0.0.0 {7433F860-160E-4024-8218-892D796972A6}: 14 (0,0)
02/18/16 18:23:17:597 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Czech Language Pack_AdobePhotoshop16-cs_CZ_x64 16.0.0.0 {7787331E-D646-4CA4-ADCB-B264CC156D7D}: 14 (0,0)
02/18/16 18:23:17:597 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Japanese Language Pack_AdobePhotoshop16-ja_JP_x64 16.0.0.0 {778CE554-471C-4605-A600-852C976A4DC5}: 14 (0,0)
02/18/16 18:23:17:597 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 IL English Language Pack_AdobePhotoshop16-en_IL_x64 16.0.0.0 {0CA9067E-B7E0-4C7A-BA40-987AF967A05D}: 14 (0,0)
02/18/16 18:23:17:597 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 MA French Language Pack_AdobePhotoshop16-fr_MA_x64 16.0.0.0 {0D30F03E-27D9-41F8-AF26-9F1801C2AE28}: 14 (0,0)
02/18/16 18:23:17:597 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Chinese (traditional) Language Pack_AdobePhotoshop16-zh_TW_x64 16.0.0.0 {18844AF8-051C-4227-9BE1-CA06F4364F9C}: 14 (0,0)
02/18/16 18:23:17:597 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Polish Language Pack_AdobePhotoshop16-pl_PL_x64 16.0.0.0 {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0}: 14 (0,0)
02/18/16 18:23:17:597 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Italian Language Pack_AdobePhotoshop16-it_IT_x64 16.0.0.0 {960F21E4-EBDC-4A3E-80E9-C28D8A593F66}: 14 (0,0)
02/18/16 18:23:17:597 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Hungarian Language Pack_AdobePhotoshop16-hu_HU_x64 16.0.0.0 {98D6FC60-7908-474A-A598-0D7A7BFEF2C2}: 14 (0,0)
02/18/16 18:23:17:597 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Swedish Language Pack_AdobePhotoshop16-sv_SE_x64 16.0.0.0 {1B7AE611-4C93-47FC-951F-0BD9839AB72B}: 14 (0,0)
02/18/16 18:23:17:597 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 North American Spanish Language Pack_AdobePhotoshop16-es_MX_x64 16.0.0.0 {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4}: 14 (0,0)
02/18/16 18:23:17:598 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Chinese Language Pack_AdobePhotoshop16-zh_CN_x64 16.0.0.0 {3875BF24-5D9A-494A-A4FA-7AC70F56EC88}: 14 (0,0)
02/18/16 18:23:17:598 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Dutch Language Pack_AdobePhotoshop16-nl_NL_x64 16.0.0.0 {2060E7ED-C473-4A38-877F-C844E81B64F3}: 14 (0,0)
02/18/16 18:23:17:598 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 French Language Pack_AdobePhotoshop16-fr_FR_x64 16.0.0.0 {B75FB41B-E3E2-4B9F-93F7-62D982857374}: 14 (0,0)
02/18/16 18:23:17:598 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Brazilian Portugese Language Pack_AdobePhotoshop16-pt_BR_x64 16.0.0.0 {4A0115A5-CA14-4EA1-9896-2F161B5144B9}: 14 (0,0)
02/18/16 18:23:17:598 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Turkish Language Pack_AdobePhotoshop16-tr_TR_x64 16.0.0.0 {BED85F42-B42C-4A91-946B-A928824C48A1}: 14 (0,0)
02/18/16 18:23:17:598 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Spanish Language Pack_AdobePhotoshop16-es_ES_x64 16.0.0.0 {644DC0CB-E8C9-4508-B99D-8747C6172621}: 14 (0,0)
02/18/16 18:23:17:598 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860}: 14 (0,0)
02/18/16 18:23:17:598 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 International English Language Pack_AdobePhotoshop16-en_GB_x64 16.0.0.0 {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4}: 14 (0,0)
02/18/16 18:23:17:598 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Korean Language Pack_AdobePhotoshop16-ko_KR_x64 16.0.0.0 {5309436A-D12F-437D-B7A4-BF136E17139C}: 14 (0,0)
02/18/16 18:23:17:598 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Norwegian Language Pack_AdobePhotoshop16-nb_NO_x64 16.0.0.0 {00F35A9A-C859-4F6E-8C4F-70A7239207FF}: 14 (0,0)
02/18/16 18:23:17:598 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Danish Language Pack_AdobePhotoshop16-da_DK_x64 16.0.0.0 {F5D14B6C-DA16-4031-9EB8-AF0728550AFC}: 14 (0,0)
02/18/16 18:23:17:598 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 German Language Pack_AdobePhotoshop16-de_DE_x64 16.0.0.0 {69C13F4A-83B3-42F4-912C-C99F1442F439}: 14 (0,0)
02/18/16 18:23:17:598 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Finnish Language Pack_AdobePhotoshop16-fi_FI_x64 16.0.0.0 {FD8B8694-1044-4481-A5D9-4740A46BBC3B}: 14 (0,0)
02/18/16 18:23:17:598 | [INFO] | | OOBE | DE | | | | 4716 | END Operation order for all session payloads: mediaGroup (requires,satisfies)
02/18/16 18:23:17:927 | [INFO] | | OOBE | DE | | | | 4716 | Setting property "conflictingProcessInfo" to: C:\Users\Lenovo\AppData\Local\Temp\{C8B996D4-B18E-461D-904B-E86CF4E0B2EE}\{26F9F097-97E7-480E-A15D-418B77FB8770}
02/18/16 18:23:17:927 | [INFO] | | OOBE | DE | | | | 4716 | Setting property "deploymentFile" to: C:\Users\Lenovo\AppData\Local\Temp\{C8B996D4-B18E-461D-904B-E86CF4E0B2EE}\{618E60A8-B46E-4385-8F1E-942816D4B5FD}
02/18/16 18:23:17:927 | [INFO] | | OOBE | DE | | | | 4716 | Setting property "driverAdobeCode" to: {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:23:17:927 | [INFO] | | OOBE | DE | | | | 4716 | Setting property "mediaSignature" to: {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:23:17:927 | [INFO] | | OOBE | DE | | | | 4716 | Setting property "removeUserPrefs" to: 1
02/18/16 18:23:17:927 | [INFO] | | OOBE | DE | | | | 4716 | Setting property "skipUninstallAAM" to: 1
02/18/16 18:23:17:927 | [INFO] | | OOBE | DE | | | | 4716 | Setting property "userASUPath" to:
02/18/16 18:23:17:927 | [INFO] | | OOBE | DE | | | | 4716 | Overwrite property "conflictingProcessInfo" to: C:\Users\Lenovo\AppData\Local\Temp\{C8B996D4-B18E-461D-904B-E86CF4E0B2EE}\{26F9F097-97E7-480E-A15D-418B77FB8770}
02/18/16 18:23:17:928 | [INFO] | | OOBE | DE | | | | 4716 | Overwrite property "mediaSignature" to: {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:23:17:928 | [INFO] | | OOBE | DE | | | | 4716 | Overwrite property "removeUserPrefs" to: 1
02/18/16 18:23:17:928 | [INFO] | | OOBE | DE | | | | 4716 | Overwrite property "skipUninstallAAM" to: 1
02/18/16 18:23:17:928 | [INFO] | | OOBE | DE | | | | 4716 | Overwrite property "userASUPath" to:
02/18/16 18:23:17:928 | [INFO] | | OOBE | DE | | | | 4716 | Found payload actions:
02/18/16 18:23:17:928 | [INFO] | | OOBE | DE | | | | 4716 | Deciding what installer mode to use...
02/18/16 18:23:18:189 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Finnish Language Pack_AdobePhotoshop16-fi_FI_x64 16.0.0.0 {FD8B8694-1044-4481-A5D9-4740A46BBC3B} not installed
02/18/16 18:23:18:189 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 German Language Pack_AdobePhotoshop16-de_DE_x64 16.0.0.0 {69C13F4A-83B3-42F4-912C-C99F1442F439} not installed
02/18/16 18:23:18:189 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Danish Language Pack_AdobePhotoshop16-da_DK_x64 16.0.0.0 {F5D14B6C-DA16-4031-9EB8-AF0728550AFC} not installed
02/18/16 18:23:18:189 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Norwegian Language Pack_AdobePhotoshop16-nb_NO_x64 16.0.0.0 {00F35A9A-C859-4F6E-8C4F-70A7239207FF} not installed
02/18/16 18:23:18:189 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Korean Language Pack_AdobePhotoshop16-ko_KR_x64 16.0.0.0 {5309436A-D12F-437D-B7A4-BF136E17139C} not installed
02/18/16 18:23:18:189 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 International English Language Pack_AdobePhotoshop16-en_GB_x64 16.0.0.0 {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4} not installed
02/18/16 18:23:18:189 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860} not installed
02/18/16 18:23:18:189 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Spanish Language Pack_AdobePhotoshop16-es_ES_x64 16.0.0.0 {644DC0CB-E8C9-4508-B99D-8747C6172621} not installed
02/18/16 18:23:18:189 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Turkish Language Pack_AdobePhotoshop16-tr_TR_x64 16.0.0.0 {BED85F42-B42C-4A91-946B-A928824C48A1} not installed
02/18/16 18:23:18:189 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Brazilian Portugese Language Pack_AdobePhotoshop16-pt_BR_x64 16.0.0.0 {4A0115A5-CA14-4EA1-9896-2F161B5144B9} not installed
02/18/16 18:23:18:190 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 French Language Pack_AdobePhotoshop16-fr_FR_x64 16.0.0.0 {B75FB41B-E3E2-4B9F-93F7-62D982857374} not installed
02/18/16 18:23:18:190 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Dutch Language Pack_AdobePhotoshop16-nl_NL_x64 16.0.0.0 {2060E7ED-C473-4A38-877F-C844E81B64F3} not installed
02/18/16 18:23:18:190 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Chinese Language Pack_AdobePhotoshop16-zh_CN_x64 16.0.0.0 {3875BF24-5D9A-494A-A4FA-7AC70F56EC88} not installed
02/18/16 18:23:18:190 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 North American Spanish Language Pack_AdobePhotoshop16-es_MX_x64 16.0.0.0 {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4} not installed
02/18/16 18:23:18:190 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Swedish Language Pack_AdobePhotoshop16-sv_SE_x64 16.0.0.0 {1B7AE611-4C93-47FC-951F-0BD9839AB72B} not installed
02/18/16 18:23:18:190 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Hungarian Language Pack_AdobePhotoshop16-hu_HU_x64 16.0.0.0 {98D6FC60-7908-474A-A598-0D7A7BFEF2C2} not installed
02/18/16 18:23:18:190 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Italian Language Pack_AdobePhotoshop16-it_IT_x64 16.0.0.0 {960F21E4-EBDC-4A3E-80E9-C28D8A593F66} not installed
02/18/16 18:23:18:190 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Polish Language Pack_AdobePhotoshop16-pl_PL_x64 16.0.0.0 {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0} not installed
02/18/16 18:23:18:190 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Chinese (traditional) Language Pack_AdobePhotoshop16-zh_TW_x64 16.0.0.0 {18844AF8-051C-4227-9BE1-CA06F4364F9C} not installed
02/18/16 18:23:18:190 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 MA French Language Pack_AdobePhotoshop16-fr_MA_x64 16.0.0.0 {0D30F03E-27D9-41F8-AF26-9F1801C2AE28} not installed
02/18/16 18:23:18:190 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 IL English Language Pack_AdobePhotoshop16-en_IL_x64 16.0.0.0 {0CA9067E-B7E0-4C7A-BA40-987AF967A05D} not installed
02/18/16 18:23:18:190 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Japanese Language Pack_AdobePhotoshop16-ja_JP_x64 16.0.0.0 {778CE554-471C-4605-A600-852C976A4DC5} not installed
02/18/16 18:23:18:190 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Czech Language Pack_AdobePhotoshop16-cs_CZ_x64 16.0.0.0 {7787331E-D646-4CA4-ADCB-B264CC156D7D} not installed
02/18/16 18:23:18:190 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Canadian French Language Pack_AdobePhotoshop16-fr_CA_x64 16.0.0.0 {7433F860-160E-4024-8218-892D796972A6} not installed
02/18/16 18:23:18:190 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Ukrainian Language Pack_AdobePhotoshop16-uk_UA_x64 16.0.0.0 {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA} not installed
02/18/16 18:23:18:191 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 AE English Language Pack_AdobePhotoshop16-en_AE_x64 16.0.0.0 {6E7A3076-3056-492F-966F-1EA4FDCE5FA8} not installed
02/18/16 18:23:18:191 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Russian Language Pack_AdobePhotoshop16-ru_RU_x64 16.0.0.0 {6E14FFAB-83F4-4CB7-87A2-703F6F20487A} not installed
02/18/16 18:23:18:191 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorNA CC 5.0.0.0 {72405B80-A3DD-4BB2-A8C4-A90BC7BA50FF} not installed
02/18/16 18:23:18:191 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorJA CC 5.0.0.0 {52D57F95-000A-4922-BB31-C6A936F4FD7D} not installed
02/18/16 18:23:18:191 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorEU CC 5.0.0.0 {9E9EB9FD-FDE8-487A-A41C-7713DA91AC89} not installed
02/18/16 18:23:18:191 | [INFO] | | OOBE | DE | | | | 4716 | BEGIN Setting requested payload actions
02/18/16 18:23:18:195 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Finnish Language Pack_AdobePhotoshop16-fi_FI_x64 16.0.0.0 {FD8B8694-1044-4481-A5D9-4740A46BBC3B} is: false
02/18/16 18:23:18:195 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Adobe Photoshop CC 2015 Finnish Language Pack_AdobePhotoshop16-fi_FI_x64 16.0.0.0 {FD8B8694-1044-4481-A5D9-4740A46BBC3B} is none
02/18/16 18:23:18:195 | [INFO] | | OOBE | DE | | | | 4716 | Payload Adobe Photoshop CC 2015 Finnish Language Pack_AdobePhotoshop16-fi_FI_x64 16.0.0.0 {FD8B8694-1044-4481-A5D9-4740A46BBC3B} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:23:18:195 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Adobe Photoshop CC 2015 German Language Pack_AdobePhotoshop16-de_DE_x64 16.0.0.0 {69C13F4A-83B3-42F4-912C-C99F1442F439} is: false
02/18/16 18:23:18:195 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Adobe Photoshop CC 2015 German Language Pack_AdobePhotoshop16-de_DE_x64 16.0.0.0 {69C13F4A-83B3-42F4-912C-C99F1442F439} is none
02/18/16 18:23:18:195 | [INFO] | | OOBE | DE | | | | 4716 | Payload Adobe Photoshop CC 2015 German Language Pack_AdobePhotoshop16-de_DE_x64 16.0.0.0 {69C13F4A-83B3-42F4-912C-C99F1442F439} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:23:18:195 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Danish Language Pack_AdobePhotoshop16-da_DK_x64 16.0.0.0 {F5D14B6C-DA16-4031-9EB8-AF0728550AFC} is: false
02/18/16 18:23:18:195 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Adobe Photoshop CC 2015 Danish Language Pack_AdobePhotoshop16-da_DK_x64 16.0.0.0 {F5D14B6C-DA16-4031-9EB8-AF0728550AFC} is none
02/18/16 18:23:18:195 | [INFO] | | OOBE | DE | | | | 4716 | Payload Adobe Photoshop CC 2015 Danish Language Pack_AdobePhotoshop16-da_DK_x64 16.0.0.0 {F5D14B6C-DA16-4031-9EB8-AF0728550AFC} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:23:18:195 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Norwegian Language Pack_AdobePhotoshop16-nb_NO_x64 16.0.0.0 {00F35A9A-C859-4F6E-8C4F-70A7239207FF} is: false
02/18/16 18:23:18:195 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Adobe Photoshop CC 2015 Norwegian Language Pack_AdobePhotoshop16-nb_NO_x64 16.0.0.0 {00F35A9A-C859-4F6E-8C4F-70A7239207FF} is none
02/18/16 18:23:18:195 | [INFO] | | OOBE | DE | | | | 4716 | Payload Adobe Photoshop CC 2015 Norwegian Language Pack_AdobePhotoshop16-nb_NO_x64 16.0.0.0 {00F35A9A-C859-4F6E-8C4F-70A7239207FF} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:23:18:195 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Korean Language Pack_AdobePhotoshop16-ko_KR_x64 16.0.0.0 {5309436A-D12F-437D-B7A4-BF136E17139C} is: false
02/18/16 18:23:18:195 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Adobe Photoshop CC 2015 Korean Language Pack_AdobePhotoshop16-ko_KR_x64 16.0.0.0 {5309436A-D12F-437D-B7A4-BF136E17139C} is none
02/18/16 18:23:18:195 | [INFO] | | OOBE | DE | | | | 4716 | Payload Adobe Photoshop CC 2015 Korean Language Pack_AdobePhotoshop16-ko_KR_x64 16.0.0.0 {5309436A-D12F-437D-B7A4-BF136E17139C} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:23:18:195 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Adobe Photoshop CC 2015 International English Language Pack_AdobePhotoshop16-en_GB_x64 16.0.0.0 {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4} is: false
02/18/16 18:23:18:195 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Adobe Photoshop CC 2015 International English Language Pack_AdobePhotoshop16-en_GB_x64 16.0.0.0 {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4} is none
02/18/16 18:23:18:196 | [INFO] | | OOBE | DE | | | | 4716 | Payload Adobe Photoshop CC 2015 International English Language Pack_AdobePhotoshop16-en_GB_x64 16.0.0.0 {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:23:18:196 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860} is: false
02/18/16 18:23:18:196 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860} is none
02/18/16 18:23:18:196 | [INFO] | | OOBE | DE | | | | 4716 | Payload Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:23:18:196 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Spanish Language Pack_AdobePhotoshop16-es_ES_x64 16.0.0.0 {644DC0CB-E8C9-4508-B99D-8747C6172621} is: false
02/18/16 18:23:18:196 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Adobe Photoshop CC 2015 Spanish Language Pack_AdobePhotoshop16-es_ES_x64 16.0.0.0 {644DC0CB-E8C9-4508-B99D-8747C6172621} is none
02/18/16 18:23:18:196 | [INFO] | | OOBE | DE | | | | 4716 | Payload Adobe Photoshop CC 2015 Spanish Language Pack_AdobePhotoshop16-es_ES_x64 16.0.0.0 {644DC0CB-E8C9-4508-B99D-8747C6172621} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:23:18:196 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Turkish Language Pack_AdobePhotoshop16-tr_TR_x64 16.0.0.0 {BED85F42-B42C-4A91-946B-A928824C48A1} is: false
02/18/16 18:23:18:196 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Adobe Photoshop CC 2015 Turkish Language Pack_AdobePhotoshop16-tr_TR_x64 16.0.0.0 {BED85F42-B42C-4A91-946B-A928824C48A1} is none
02/18/16 18:23:18:196 | [INFO] | | OOBE | DE | | | | 4716 | Payload Adobe Photoshop CC 2015 Turkish Language Pack_AdobePhotoshop16-tr_TR_x64 16.0.0.0 {BED85F42-B42C-4A91-946B-A928824C48A1} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:23:18:196 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Brazilian Portugese Language Pack_AdobePhotoshop16-pt_BR_x64 16.0.0.0 {4A0115A5-CA14-4EA1-9896-2F161B5144B9} is: false
02/18/16 18:23:18:196 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Adobe Photoshop CC 2015 Brazilian Portugese Language Pack_AdobePhotoshop16-pt_BR_x64 16.0.0.0 {4A0115A5-CA14-4EA1-9896-2F161B5144B9} is none
02/18/16 18:23:18:196 | [INFO] | | OOBE | DE | | | | 4716 | Payload Adobe Photoshop CC 2015 Brazilian Portugese Language Pack_AdobePhotoshop16-pt_BR_x64 16.0.0.0 {4A0115A5-CA14-4EA1-9896-2F161B5144B9} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:23:18:196 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Adobe Photoshop CC 2015 French Language Pack_AdobePhotoshop16-fr_FR_x64 16.0.0.0 {B75FB41B-E3E2-4B9F-93F7-62D982857374} is: false
02/18/16 18:23:18:196 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Adobe Photoshop CC 2015 French Language Pack_AdobePhotoshop16-fr_FR_x64 16.0.0.0 {B75FB41B-E3E2-4B9F-93F7-62D982857374} is none
02/18/16 18:23:18:196 | [INFO] | | OOBE | DE | | | | 4716 | Payload Adobe Photoshop CC 2015 French Language Pack_AdobePhotoshop16-fr_FR_x64 16.0.0.0 {B75FB41B-E3E2-4B9F-93F7-62D982857374} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:23:18:196 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Dutch Language Pack_AdobePhotoshop16-nl_NL_x64 16.0.0.0 {2060E7ED-C473-4A38-877F-C844E81B64F3} is: false
02/18/16 18:23:18:196 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Adobe Photoshop CC 2015 Dutch Language Pack_AdobePhotoshop16-nl_NL_x64 16.0.0.0 {2060E7ED-C473-4A38-877F-C844E81B64F3} is none
02/18/16 18:23:18:196 | [INFO] | | OOBE | DE | | | | 4716 | Payload Adobe Photoshop CC 2015 Dutch Language Pack_AdobePhotoshop16-nl_NL_x64 16.0.0.0 {2060E7ED-C473-4A38-877F-C844E81B64F3} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:23:18:196 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Chinese Language Pack_AdobePhotoshop16-zh_CN_x64 16.0.0.0 {3875BF24-5D9A-494A-A4FA-7AC70F56EC88} is: false
02/18/16 18:23:18:196 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Adobe Photoshop CC 2015 Chinese Language Pack_AdobePhotoshop16-zh_CN_x64 16.0.0.0 {3875BF24-5D9A-494A-A4FA-7AC70F56EC88} is none
02/18/16 18:23:18:196 | [INFO] | | OOBE | DE | | | | 4716 | Payload Adobe Photoshop CC 2015 Chinese Language Pack_AdobePhotoshop16-zh_CN_x64 16.0.0.0 {3875BF24-5D9A-494A-A4FA-7AC70F56EC88} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:23:18:197 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Adobe Photoshop CC 2015 North American Spanish Language Pack_AdobePhotoshop16-es_MX_x64 16.0.0.0 {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4} is: false
02/18/16 18:23:18:197 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Adobe Photoshop CC 2015 North American Spanish Language Pack_AdobePhotoshop16-es_MX_x64 16.0.0.0 {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4} is none
02/18/16 18:23:18:197 | [INFO] | | OOBE | DE | | | | 4716 | Payload Adobe Photoshop CC 2015 North American Spanish Language Pack_AdobePhotoshop16-es_MX_x64 16.0.0.0 {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:23:18:197 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Swedish Language Pack_AdobePhotoshop16-sv_SE_x64 16.0.0.0 {1B7AE611-4C93-47FC-951F-0BD9839AB72B} is: false
02/18/16 18:23:18:197 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Adobe Photoshop CC 2015 Swedish Language Pack_AdobePhotoshop16-sv_SE_x64 16.0.0.0 {1B7AE611-4C93-47FC-951F-0BD9839AB72B} is none
02/18/16 18:23:18:197 | [INFO] | | OOBE | DE | | | | 4716 | Payload Adobe Photoshop CC 2015 Swedish Language Pack_AdobePhotoshop16-sv_SE_x64 16.0.0.0 {1B7AE611-4C93-47FC-951F-0BD9839AB72B} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:23:18:197 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Hungarian Language Pack_AdobePhotoshop16-hu_HU_x64 16.0.0.0 {98D6FC60-7908-474A-A598-0D7A7BFEF2C2} is: false
02/18/16 18:23:18:197 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Adobe Photoshop CC 2015 Hungarian Language Pack_AdobePhotoshop16-hu_HU_x64 16.0.0.0 {98D6FC60-7908-474A-A598-0D7A7BFEF2C2} is none
02/18/16 18:23:18:197 | [INFO] | | OOBE | DE | | | | 4716 | Payload Adobe Photoshop CC 2015 Hungarian Language Pack_AdobePhotoshop16-hu_HU_x64 16.0.0.0 {98D6FC60-7908-474A-A598-0D7A7BFEF2C2} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:23:18:197 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Italian Language Pack_AdobePhotoshop16-it_IT_x64 16.0.0.0 {960F21E4-EBDC-4A3E-80E9-C28D8A593F66} is: false
02/18/16 18:23:18:197 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Adobe Photoshop CC 2015 Italian Language Pack_AdobePhotoshop16-it_IT_x64 16.0.0.0 {960F21E4-EBDC-4A3E-80E9-C28D8A593F66} is none
02/18/16 18:23:18:197 | [INFO] | | OOBE | DE | | | | 4716 | Payload Adobe Photoshop CC 2015 Italian Language Pack_AdobePhotoshop16-it_IT_x64 16.0.0.0 {960F21E4-EBDC-4A3E-80E9-C28D8A593F66} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:23:18:197 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Polish Language Pack_AdobePhotoshop16-pl_PL_x64 16.0.0.0 {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0} is: false
02/18/16 18:23:18:197 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Adobe Photoshop CC 2015 Polish Language Pack_AdobePhotoshop16-pl_PL_x64 16.0.0.0 {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0} is none
02/18/16 18:23:18:197 | [INFO] | | OOBE | DE | | | | 4716 | Payload Adobe Photoshop CC 2015 Polish Language Pack_AdobePhotoshop16-pl_PL_x64 16.0.0.0 {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:23:18:197 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Chinese (traditional) Language Pack_AdobePhotoshop16-zh_TW_x64 16.0.0.0 {18844AF8-051C-4227-9BE1-CA06F4364F9C} is: false
02/18/16 18:23:18:197 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Adobe Photoshop CC 2015 Chinese (traditional) Language Pack_AdobePhotoshop16-zh_TW_x64 16.0.0.0 {18844AF8-051C-4227-9BE1-CA06F4364F9C} is none
02/18/16 18:23:18:197 | [INFO] | | OOBE | DE | | | | 4716 | Payload Adobe Photoshop CC 2015 Chinese (traditional) Language Pack_AdobePhotoshop16-zh_TW_x64 16.0.0.0 {18844AF8-051C-4227-9BE1-CA06F4364F9C} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:23:18:197 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Adobe Photoshop CC 2015 MA French Language Pack_AdobePhotoshop16-fr_MA_x64 16.0.0.0 {0D30F03E-27D9-41F8-AF26-9F1801C2AE28} is: false
02/18/16 18:23:18:197 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Adobe Photoshop CC 2015 MA French Language Pack_AdobePhotoshop16-fr_MA_x64 16.0.0.0 {0D30F03E-27D9-41F8-AF26-9F1801C2AE28} is none
02/18/16 18:23:18:197 | [INFO] | | OOBE | DE | | | | 4716 | Payload Adobe Photoshop CC 2015 MA French Language Pack_AdobePhotoshop16-fr_MA_x64 16.0.0.0 {0D30F03E-27D9-41F8-AF26-9F1801C2AE28} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:23:18:198 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Adobe Photoshop CC 2015 IL English Language Pack_AdobePhotoshop16-en_IL_x64 16.0.0.0 {0CA9067E-B7E0-4C7A-BA40-987AF967A05D} is: false
02/18/16 18:23:18:198 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Adobe Photoshop CC 2015 IL English Language Pack_AdobePhotoshop16-en_IL_x64 16.0.0.0 {0CA9067E-B7E0-4C7A-BA40-987AF967A05D} is none
02/18/16 18:23:18:198 | [INFO] | | OOBE | DE | | | | 4716 | Payload Adobe Photoshop CC 2015 IL English Language Pack_AdobePhotoshop16-en_IL_x64 16.0.0.0 {0CA9067E-B7E0-4C7A-BA40-987AF967A05D} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:23:18:198 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Japanese Language Pack_AdobePhotoshop16-ja_JP_x64 16.0.0.0 {778CE554-471C-4605-A600-852C976A4DC5} is: false
02/18/16 18:23:18:198 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Adobe Photoshop CC 2015 Japanese Language Pack_AdobePhotoshop16-ja_JP_x64 16.0.0.0 {778CE554-471C-4605-A600-852C976A4DC5} is none
02/18/16 18:23:18:198 | [INFO] | | OOBE | DE | | | | 4716 | Payload Adobe Photoshop CC 2015 Japanese Language Pack_AdobePhotoshop16-ja_JP_x64 16.0.0.0 {778CE554-471C-4605-A600-852C976A4DC5} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:23:18:198 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Czech Language Pack_AdobePhotoshop16-cs_CZ_x64 16.0.0.0 {7787331E-D646-4CA4-ADCB-B264CC156D7D} is: false
02/18/16 18:23:18:198 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Adobe Photoshop CC 2015 Czech Language Pack_AdobePhotoshop16-cs_CZ_x64 16.0.0.0 {7787331E-D646-4CA4-ADCB-B264CC156D7D} is none
02/18/16 18:23:18:198 | [INFO] | | OOBE | DE | | | | 4716 | Payload Adobe Photoshop CC 2015 Czech Language Pack_AdobePhotoshop16-cs_CZ_x64 16.0.0.0 {7787331E-D646-4CA4-ADCB-B264CC156D7D} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:23:18:198 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Canadian French Language Pack_AdobePhotoshop16-fr_CA_x64 16.0.0.0 {7433F860-160E-4024-8218-892D796972A6} is: false
02/18/16 18:23:18:198 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Adobe Photoshop CC 2015 Canadian French Language Pack_AdobePhotoshop16-fr_CA_x64 16.0.0.0 {7433F860-160E-4024-8218-892D796972A6} is none
02/18/16 18:23:18:198 | [INFO] | | OOBE | DE | | | | 4716 | Payload Adobe Photoshop CC 2015 Canadian French Language Pack_AdobePhotoshop16-fr_CA_x64 16.0.0.0 {7433F860-160E-4024-8218-892D796972A6} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:23:18:198 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Ukrainian Language Pack_AdobePhotoshop16-uk_UA_x64 16.0.0.0 {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA} is: false
02/18/16 18:23:18:198 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Adobe Photoshop CC 2015 Ukrainian Language Pack_AdobePhotoshop16-uk_UA_x64 16.0.0.0 {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA} is none
02/18/16 18:23:18:198 | [INFO] | | OOBE | DE | | | | 4716 | Payload Adobe Photoshop CC 2015 Ukrainian Language Pack_AdobePhotoshop16-uk_UA_x64 16.0.0.0 {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:23:18:198 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Adobe Photoshop CC 2015 AE English Language Pack_AdobePhotoshop16-en_AE_x64 16.0.0.0 {6E7A3076-3056-492F-966F-1EA4FDCE5FA8} is: false
02/18/16 18:23:18:198 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Adobe Photoshop CC 2015 AE English Language Pack_AdobePhotoshop16-en_AE_x64 16.0.0.0 {6E7A3076-3056-492F-966F-1EA4FDCE5FA8} is none
02/18/16 18:23:18:198 | [INFO] | | OOBE | DE | | | | 4716 | Payload Adobe Photoshop CC 2015 AE English Language Pack_AdobePhotoshop16-en_AE_x64 16.0.0.0 {6E7A3076-3056-492F-966F-1EA4FDCE5FA8} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:23:18:198 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Russian Language Pack_AdobePhotoshop16-ru_RU_x64 16.0.0.0 {6E14FFAB-83F4-4CB7-87A2-703F6F20487A} is: false
02/18/16 18:23:18:198 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Adobe Photoshop CC 2015 Russian Language Pack_AdobePhotoshop16-ru_RU_x64 16.0.0.0 {6E14FFAB-83F4-4CB7-87A2-703F6F20487A} is none
02/18/16 18:23:18:198 | [INFO] | | OOBE | DE | | | | 4716 | Payload Adobe Photoshop CC 2015 Russian Language Pack_AdobePhotoshop16-ru_RU_x64 16.0.0.0 {6E14FFAB-83F4-4CB7-87A2-703F6F20487A} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:23:18:198 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Core_16.1.2_AdobePhotoshop16-Core_x64 16.1.2.0 {F217525B-30EB-42F2-A730-F61139264DB5} is: true
02/18/16 18:23:18:199 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Adobe Photoshop CC 2015 Core_16.1.2_AdobePhotoshop16-Core_x64 16.1.2.0 {F217525B-30EB-42F2-A730-F61139264DB5} is none
02/18/16 18:23:18:199 | [INFO] | | OOBE | DE | | | | 4716 | Payload Adobe Photoshop CC 2015 Core_16.1.2_AdobePhotoshop16-Core_x64 16.1.2.0 {F217525B-30EB-42F2-A730-F61139264DB5} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:23:18:199 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21} is: true
02/18/16 18:23:18:199 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21} is remove
02/18/16 18:23:18:199 | [INFO] | | OOBE | DE | | | | 4716 | Selection of payload Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21} is forbidden by the policy. Reason: Free payload
02/18/16 18:23:18:199 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Photoshop Camera Raw 8_9.4_AdobeCameraRaw8.0All 9.4.0.0 {8B793E8B-07C8-4865-A698-FE003249A576} is: true
02/18/16 18:23:18:199 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Photoshop Camera Raw 8_9.4_AdobeCameraRaw8.0All 9.4.0.0 {8B793E8B-07C8-4865-A698-FE003249A576} is none
02/18/16 18:23:18:199 | [INFO] | | OOBE | DE | | | | 4716 | Payload Photoshop Camera Raw 8_9.4_AdobeCameraRaw8.0All 9.4.0.0 {8B793E8B-07C8-4865-A698-FE003249A576} is extension payload. Aligning its action according to parent Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}
02/18/16 18:23:18:199 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85} is: true
02/18/16 18:23:18:199 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85} is none
02/18/16 18:23:18:199 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Photoshop Camera Raw 8 (64 bit)_9.4_AdobeCameraRaw8.0All-x64 9.4.0.0 {BE4895E5-6517-4CED-B62A-A5A046ADBFCF} is: true
02/18/16 18:23:18:199 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Photoshop Camera Raw 8 (64 bit)_9.4_AdobeCameraRaw8.0All-x64 9.4.0.0 {BE4895E5-6517-4CED-B62A-A5A046ADBFCF} is none
02/18/16 18:23:18:199 | [INFO] | | OOBE | DE | | | | 4716 | Payload Photoshop Camera Raw 8 (64 bit)_9.4_AdobeCameraRaw8.0All-x64 9.4.0.0 {BE4895E5-6517-4CED-B62A-A5A046ADBFCF} is extension payload. Aligning its action according to parent Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}
02/18/16 18:23:18:199 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA} is: true
02/18/16 18:23:18:199 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA} is none
02/18/16 18:23:18:199 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446} is: true
02/18/16 18:23:18:199 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446} is none
02/18/16 18:23:18:199 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613} is: true
02/18/16 18:23:18:199 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613} is none
02/18/16 18:23:18:199 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC} is: true
02/18/16 18:23:18:199 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC} is none
02/18/16 18:23:18:199 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20} is: true
02/18/16 18:23:18:199 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20} is none
02/18/16 18:23:18:200 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9} is: true
02/18/16 18:23:18:200 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9} is none
02/18/16 18:23:18:200 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9} is: true
02/18/16 18:23:18:200 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9} is none
02/18/16 18:23:18:200 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Export Assets 2 (64 bit)_2.4_AdobeExportAssets2.0All-x64 2.4.0.0 {3C285B12-AFED-4136-B575-1D6CA2B71D29} is: true
02/18/16 18:23:18:200 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Export Assets 2 (64 bit)_2.4_AdobeExportAssets2.0All-x64 2.4.0.0 {3C285B12-AFED-4136-B575-1D6CA2B71D29} is none
02/18/16 18:23:18:200 | [INFO] | | OOBE | DE | | | | 4716 | Payload Export Assets 2 (64 bit)_2.4_AdobeExportAssets2.0All-x64 2.4.0.0 {3C285B12-AFED-4136-B575-1D6CA2B71D29} is extension payload. Aligning its action according to parent Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}
02/18/16 18:23:18:200 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140} is: true
02/18/16 18:23:18:200 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140} is none
02/18/16 18:23:18:200 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94} is: true
02/18/16 18:23:18:200 | [INFO] | | OOBE | DE | | | | 4716 | Action string for AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94} is none
02/18/16 18:23:18:200 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66} is: true
02/18/16 18:23:18:200 | [INFO] | | OOBE | DE | | | | 4716 | Action string for AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66} is none
02/18/16 18:23:18:200 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44} is: true
02/18/16 18:23:18:200 | [INFO] | | OOBE | DE | | | | 4716 | Action string for AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44} is none
02/18/16 18:23:18:200 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: AdobeColorNA CC 5.0.0.0 {72405B80-A3DD-4BB2-A8C4-A90BC7BA50FF} is: false
02/18/16 18:23:18:200 | [INFO] | | OOBE | DE | | | | 4716 | Action string for AdobeColorNA CC 5.0.0.0 {72405B80-A3DD-4BB2-A8C4-A90BC7BA50FF} is none
02/18/16 18:23:18:200 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB} is: true
02/18/16 18:23:18:200 | [INFO] | | OOBE | DE | | | | 4716 | Action string for AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB} is none
02/18/16 18:23:18:200 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: AdobeColorJA CC 5.0.0.0 {52D57F95-000A-4922-BB31-C6A936F4FD7D} is: false
02/18/16 18:23:18:200 | [INFO] | | OOBE | DE | | | | 4716 | Action string for AdobeColorJA CC 5.0.0.0 {52D57F95-000A-4922-BB31-C6A936F4FD7D} is none
02/18/16 18:23:18:200 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28} is: true
02/18/16 18:23:18:200 | [INFO] | | OOBE | DE | | | | 4716 | Action string for AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28} is none
02/18/16 18:23:18:200 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: AdobeColorEU CC 5.0.0.0 {9E9EB9FD-FDE8-487A-A41C-7713DA91AC89} is: false
02/18/16 18:23:18:201 | [INFO] | | OOBE | DE | | | | 4716 | Action string for AdobeColorEU CC 5.0.0.0 {9E9EB9FD-FDE8-487A-A41C-7713DA91AC89} is none
02/18/16 18:23:18:201 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC} is: true
02/18/16 18:23:18:201 | [INFO] | | OOBE | DE | | | | 4716 | Action string for AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC} is none
02/18/16 18:23:18:201 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95} is: true
02/18/16 18:23:18:201 | [INFO] | | OOBE | DE | | | | 4716 | Action string for AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95} is none
02/18/16 18:23:18:201 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Adobe Preview CC_1.1.3_AdobePreview1.0All-win64 1.1.3.0 {27B8946D-664A-4877-A3C9-CE8249CA1D7A} is: true
02/18/16 18:23:18:201 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Adobe Preview CC_1.1.3_AdobePreview1.0All-win64 1.1.3.0 {27B8946D-664A-4877-A3C9-CE8249CA1D7A} is none
02/18/16 18:23:18:201 | [INFO] | | OOBE | DE | | | | 4716 | Payload Adobe Preview CC_1.1.3_AdobePreview1.0All-win64 1.1.3.0 {27B8946D-664A-4877-A3C9-CE8249CA1D7A} is extension payload. Aligning its action according to parent Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}
02/18/16 18:23:18:201 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3} is: true
02/18/16 18:23:18:201 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3} is none
02/18/16 18:23:18:201 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Support_16.1.2_AdobePhotoshop16-Support 16.1.2.0 {4A117739-A3A4-4E1A-8F5A-82CB1958794F} is: true
02/18/16 18:23:18:201 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Adobe Photoshop CC 2015 Support_16.1.2_AdobePhotoshop16-Support 16.1.2.0 {4A117739-A3A4-4E1A-8F5A-82CB1958794F} is none
02/18/16 18:23:18:201 | [INFO] | | OOBE | DE | | | | 4716 | Payload Adobe Photoshop CC 2015 Support_16.1.2_AdobePhotoshop16-Support 16.1.2.0 {4A117739-A3A4-4E1A-8F5A-82CB1958794F} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}
02/18/16 18:23:18:201 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457} is: true
02/18/16 18:23:18:201 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457} is none
02/18/16 18:23:18:201 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Camera Profiles Installer_9.4_AdobeCameraRawProfile8.0All 9.4.0.0 {03B147C3-2412-4DE8-80F9-3EB977421EF2} is: true
02/18/16 18:23:18:201 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Camera Profiles Installer_9.4_AdobeCameraRawProfile8.0All 9.4.0.0 {03B147C3-2412-4DE8-80F9-3EB977421EF2} is none
02/18/16 18:23:18:201 | [INFO] | | OOBE | DE | | | | 4716 | Payload Camera Profiles Installer_9.4_AdobeCameraRawProfile8.0All 9.4.0.0 {03B147C3-2412-4DE8-80F9-3EB977421EF2} is extension payload. Aligning its action according to parent Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}
02/18/16 18:23:18:201 | [INFO] | | OOBE | DE | | | | 4716 | Value returned on lookup of payload: Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10} is: true
02/18/16 18:23:18:201 | [INFO] | | OOBE | DE | | | | 4716 | Action string for Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10} is none
02/18/16 18:23:18:210 | [INFO] | | OOBE | DE | | | | 4716 | END Setting requested payload actions
02/18/16 18:23:18:216 | [INFO] | | OOBE | DE | | | | 4716 | INSTALLDIR passed path basic path validation: C:\Program Files\Adobe
02/18/16 18:23:22:448 | [INFO] | | OOBE | DE | | | | 4716 | BEGIN InstallOperationsQueue Unordered operations
02/18/16 18:23:22:448 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Norwegian Language Pack_AdobePhotoshop16-nb_NO_x64 16.0.0.0 {00F35A9A-C859-4F6E-8C4F-70A7239207FF}: with operation none
02/18/16 18:23:22:448 | [INFO] | | OOBE | DE | | | | 4716 | Camera Profiles Installer_9.4_AdobeCameraRawProfile8.0All 9.4.0.0 {03B147C3-2412-4DE8-80F9-3EB977421EF2}: with operation remove
02/18/16 18:23:22:448 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Ukrainian Language Pack_AdobePhotoshop16-uk_UA_x64 16.0.0.0 {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA}: with operation none
02/18/16 18:23:22:448 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 IL English Language Pack_AdobePhotoshop16-en_IL_x64 16.0.0.0 {0CA9067E-B7E0-4C7A-BA40-987AF967A05D}: with operation none
02/18/16 18:23:22:448 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 MA French Language Pack_AdobePhotoshop16-fr_MA_x64 16.0.0.0 {0D30F03E-27D9-41F8-AF26-9F1801C2AE28}: with operation none
02/18/16 18:23:22:448 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Chinese (traditional) Language Pack_AdobePhotoshop16-zh_TW_x64 16.0.0.0 {18844AF8-051C-4227-9BE1-CA06F4364F9C}: with operation none
02/18/16 18:23:22:448 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Swedish Language Pack_AdobePhotoshop16-sv_SE_x64 16.0.0.0 {1B7AE611-4C93-47FC-951F-0BD9839AB72B}: with operation none
02/18/16 18:23:22:448 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Dutch Language Pack_AdobePhotoshop16-nl_NL_x64 16.0.0.0 {2060E7ED-C473-4A38-877F-C844E81B64F3}: with operation none
02/18/16 18:23:22:448 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 North American Spanish Language Pack_AdobePhotoshop16-es_MX_x64 16.0.0.0 {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4}: with operation none
02/18/16 18:23:22:448 | [INFO] | | OOBE | DE | | | | 4716 | Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}: with operation remove
02/18/16 18:23:22:448 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Preview CC_1.1.3_AdobePreview1.0All-win64 1.1.3.0 {27B8946D-664A-4877-A3C9-CE8249CA1D7A}: with operation remove
02/18/16 18:23:22:448 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Chinese Language Pack_AdobePhotoshop16-zh_CN_x64 16.0.0.0 {3875BF24-5D9A-494A-A4FA-7AC70F56EC88}: with operation none
02/18/16 18:23:22:448 | [INFO] | | OOBE | DE | | | | 4716 | Export Assets 2 (64 bit)_2.4_AdobeExportAssets2.0All-x64 2.4.0.0 {3C285B12-AFED-4136-B575-1D6CA2B71D29}: with operation remove
02/18/16 18:23:22:448 | [INFO] | | OOBE | DE | | | | 4716 | Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20}: with operation remove
02/18/16 18:23:22:448 | [INFO] | | OOBE | DE | | | | 4716 | Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}: with operation remove
02/18/16 18:23:22:448 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}: with operation remove
02/18/16 18:23:22:448 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Brazilian Portugese Language Pack_AdobePhotoshop16-pt_BR_x64 16.0.0.0 {4A0115A5-CA14-4EA1-9896-2F161B5144B9}: with operation none
02/18/16 18:23:22:449 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Support_16.1.2_AdobePhotoshop16-Support 16.1.2.0 {4A117739-A3A4-4E1A-8F5A-82CB1958794F}: with operation remove
02/18/16 18:23:22:449 | [INFO] | | OOBE | DE | | | | 4716 | Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}: with operation remove
02/18/16 18:23:22:449 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 International English Language Pack_AdobePhotoshop16-en_GB_x64 16.0.0.0 {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4}: with operation none
02/18/16 18:23:22:449 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorJA CC 5.0.0.0 {52D57F95-000A-4922-BB31-C6A936F4FD7D}: with operation none
02/18/16 18:23:22:449 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Korean Language Pack_AdobePhotoshop16-ko_KR_x64 16.0.0.0 {5309436A-D12F-437D-B7A4-BF136E17139C}: with operation none
02/18/16 18:23:22:449 | [INFO] | | OOBE | DE | | | | 4716 | Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}: with operation remove
02/18/16 18:23:22:449 | [INFO] | | OOBE | DE | | | | 4716 | Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9}: with operation remove
02/18/16 18:23:22:449 | [INFO] | | OOBE | DE | | | | 4716 | Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}: with operation remove
02/18/16 18:23:22:449 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}: with operation remove
02/18/16 18:23:22:449 | [INFO] | | OOBE | DE | | | | 4716 | Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}: with operation remove
02/18/16 18:23:22:449 | [INFO] | | OOBE | DE | | | | 4716 | Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}: with operation remove
02/18/16 18:23:22:449 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Spanish Language Pack_AdobePhotoshop16-es_ES_x64 16.0.0.0 {644DC0CB-E8C9-4508-B99D-8747C6172621}: with operation none
02/18/16 18:23:22:449 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 German Language Pack_AdobePhotoshop16-de_DE_x64 16.0.0.0 {69C13F4A-83B3-42F4-912C-C99F1442F439}: with operation none
02/18/16 18:23:22:449 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Russian Language Pack_AdobePhotoshop16-ru_RU_x64 16.0.0.0 {6E14FFAB-83F4-4CB7-87A2-703F6F20487A}: with operation none
02/18/16 18:23:22:449 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 AE English Language Pack_AdobePhotoshop16-en_AE_x64 16.0.0.0 {6E7A3076-3056-492F-966F-1EA4FDCE5FA8}: with operation none
02/18/16 18:23:22:449 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorNA CC 5.0.0.0 {72405B80-A3DD-4BB2-A8C4-A90BC7BA50FF}: with operation none
02/18/16 18:23:22:449 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Canadian French Language Pack_AdobePhotoshop16-fr_CA_x64 16.0.0.0 {7433F860-160E-4024-8218-892D796972A6}: with operation none
02/18/16 18:23:22:449 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Czech Language Pack_AdobePhotoshop16-cs_CZ_x64 16.0.0.0 {7787331E-D646-4CA4-ADCB-B264CC156D7D}: with operation none
02/18/16 18:23:22:449 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Japanese Language Pack_AdobePhotoshop16-ja_JP_x64 16.0.0.0 {778CE554-471C-4605-A600-852C976A4DC5}: with operation none
02/18/16 18:23:22:449 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}: with operation remove
02/18/16 18:23:22:449 | [INFO] | | OOBE | DE | | | | 4716 | Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC}: with operation remove
02/18/16 18:23:22:449 | [INFO] | | OOBE | DE | | | | 4716 | Photoshop Camera Raw 8_9.4_AdobeCameraRaw8.0All 9.4.0.0 {8B793E8B-07C8-4865-A698-FE003249A576}: with operation remove
02/18/16 18:23:22:449 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Polish Language Pack_AdobePhotoshop16-pl_PL_x64 16.0.0.0 {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0}: with operation none
02/18/16 18:23:22:450 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Italian Language Pack_AdobePhotoshop16-it_IT_x64 16.0.0.0 {960F21E4-EBDC-4A3E-80E9-C28D8A593F66}: with operation none
02/18/16 18:23:22:450 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Hungarian Language Pack_AdobePhotoshop16-hu_HU_x64 16.0.0.0 {98D6FC60-7908-474A-A598-0D7A7BFEF2C2}: with operation none
02/18/16 18:23:22:450 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorEU CC 5.0.0.0 {9E9EB9FD-FDE8-487A-A41C-7713DA91AC89}: with operation none
02/18/16 18:23:22:450 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}: with operation remove
02/18/16 18:23:22:450 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}: with operation remove
02/18/16 18:23:22:450 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}: with operation remove
02/18/16 18:23:22:450 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 French Language Pack_AdobePhotoshop16-fr_FR_x64 16.0.0.0 {B75FB41B-E3E2-4B9F-93F7-62D982857374}: with operation none
02/18/16 18:23:22:450 | [INFO] | | OOBE | DE | | | | 4716 | Photoshop Camera Raw 8 (64 bit)_9.4_AdobeCameraRaw8.0All-x64 9.4.0.0 {BE4895E5-6517-4CED-B62A-A5A046ADBFCF}: with operation remove
02/18/16 18:23:22:450 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Turkish Language Pack_AdobePhotoshop16-tr_TR_x64 16.0.0.0 {BED85F42-B42C-4A91-946B-A928824C48A1}: with operation none
02/18/16 18:23:22:450 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}: with operation remove
02/18/16 18:23:22:450 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860}: with operation none
02/18/16 18:23:22:450 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}: with operation remove
02/18/16 18:23:22:450 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}: with operation remove
02/18/16 18:23:22:450 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Core_16.1.2_AdobePhotoshop16-Core_x64 16.1.2.0 {F217525B-30EB-42F2-A730-F61139264DB5}: with operation remove
02/18/16 18:23:22:450 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Danish Language Pack_AdobePhotoshop16-da_DK_x64 16.0.0.0 {F5D14B6C-DA16-4031-9EB8-AF0728550AFC}: with operation none
02/18/16 18:23:22:450 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}: with operation remove
02/18/16 18:23:22:450 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Finnish Language Pack_AdobePhotoshop16-fi_FI_x64 16.0.0.0 {FD8B8694-1044-4481-A5D9-4740A46BBC3B}: with operation none
02/18/16 18:23:22:450 | [INFO] | | OOBE | DE | | | | 4716 | END InstallOperationsQueue Unordered operations
02/18/16 18:23:22:451 | [INFO] | | OOBE | DE | | | | 4716 | BEGIN InstallOperationsQueue Ordered operations
02/18/16 18:23:22:451 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Core_16.1.2_AdobePhotoshop16-Core_x64 16.1.2.0 {F217525B-30EB-42F2-A730-F61139264DB5}: with operation remove
02/18/16 18:23:22:451 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}: with operation remove
02/18/16 18:23:22:451 | [INFO] | | OOBE | DE | | | | 4716 | Photoshop Camera Raw 8_9.4_AdobeCameraRaw8.0All 9.4.0.0 {8B793E8B-07C8-4865-A698-FE003249A576}: with operation remove
02/18/16 18:23:22:451 | [INFO] | | OOBE | DE | | | | 4716 | Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}: with operation remove
02/18/16 18:23:22:451 | [INFO] | | OOBE | DE | | | | 4716 | Photoshop Camera Raw 8 (64 bit)_9.4_AdobeCameraRaw8.0All-x64 9.4.0.0 {BE4895E5-6517-4CED-B62A-A5A046ADBFCF}: with operation remove
02/18/16 18:23:22:451 | [INFO] | | OOBE | DE | | | | 4716 | Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}: with operation remove
02/18/16 18:23:22:451 | [INFO] | | OOBE | DE | | | | 4716 | Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}: with operation remove
02/18/16 18:23:22:451 | [INFO] | | OOBE | DE | | | | 4716 | Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}: with operation remove
02/18/16 18:23:22:451 | [INFO] | | OOBE | DE | | | | 4716 | Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC}: with operation remove
02/18/16 18:23:22:451 | [INFO] | | OOBE | DE | | | | 4716 | Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20}: with operation remove
02/18/16 18:23:22:451 | [INFO] | | OOBE | DE | | | | 4716 | Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9}: with operation remove
02/18/16 18:23:22:451 | [INFO] | | OOBE | DE | | | | 4716 | Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}: with operation remove
02/18/16 18:23:22:451 | [INFO] | | OOBE | DE | | | | 4716 | Export Assets 2 (64 bit)_2.4_AdobeExportAssets2.0All-x64 2.4.0.0 {3C285B12-AFED-4136-B575-1D6CA2B71D29}: with operation remove
02/18/16 18:23:22:451 | [INFO] | | OOBE | DE | | | | 4716 | Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}: with operation remove
02/18/16 18:23:22:451 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}: with operation remove
02/18/16 18:23:22:451 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}: with operation remove
02/18/16 18:23:22:451 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}: with operation remove
02/18/16 18:23:22:452 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}: with operation remove
02/18/16 18:23:22:452 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}: with operation remove
02/18/16 18:23:22:452 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}: with operation remove
02/18/16 18:23:22:452 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}: with operation remove
02/18/16 18:23:22:452 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Preview CC_1.1.3_AdobePreview1.0All-win64 1.1.3.0 {27B8946D-664A-4877-A3C9-CE8249CA1D7A}: with operation remove
02/18/16 18:23:22:452 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}: with operation remove
02/18/16 18:23:22:452 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Support_16.1.2_AdobePhotoshop16-Support 16.1.2.0 {4A117739-A3A4-4E1A-8F5A-82CB1958794F}: with operation remove
02/18/16 18:23:22:452 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}: with operation remove
02/18/16 18:23:22:452 | [INFO] | | OOBE | DE | | | | 4716 | Camera Profiles Installer_9.4_AdobeCameraRawProfile8.0All 9.4.0.0 {03B147C3-2412-4DE8-80F9-3EB977421EF2}: with operation remove
02/18/16 18:23:22:452 | [INFO] | | OOBE | DE | | | | 4716 | Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}: with operation remove
02/18/16 18:23:22:452 | [INFO] | | OOBE | DE | | | | 4716 | END InstallOperationsQueue Ordered operations
02/18/16 18:23:22:646 | [INFO] | | OOBE | DE | | | | 4716 | Payloads passed preflight validation.
02/18/16 18:23:22:647 | [INFO] | | OOBE | DE | | | | 4716 | Call PreSession Custom Hook
02/18/16 18:23:22:692 | [INFO] | | OOBE | DE | | | | 4716 | BEGIN InstallOperationsQueue Unordered operations
02/18/16 18:23:22:692 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Norwegian Language Pack_AdobePhotoshop16-nb_NO_x64 16.0.0.0 {00F35A9A-C859-4F6E-8C4F-70A7239207FF}: with operation none
02/18/16 18:23:22:692 | [INFO] | | OOBE | DE | | | | 4716 | Camera Profiles Installer_9.4_AdobeCameraRawProfile8.0All 9.4.0.0 {03B147C3-2412-4DE8-80F9-3EB977421EF2}: with operation remove
02/18/16 18:23:22:692 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Ukrainian Language Pack_AdobePhotoshop16-uk_UA_x64 16.0.0.0 {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA}: with operation none
02/18/16 18:23:22:692 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 IL English Language Pack_AdobePhotoshop16-en_IL_x64 16.0.0.0 {0CA9067E-B7E0-4C7A-BA40-987AF967A05D}: with operation none
02/18/16 18:23:22:692 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 MA French Language Pack_AdobePhotoshop16-fr_MA_x64 16.0.0.0 {0D30F03E-27D9-41F8-AF26-9F1801C2AE28}: with operation none
02/18/16 18:23:22:692 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Chinese (traditional) Language Pack_AdobePhotoshop16-zh_TW_x64 16.0.0.0 {18844AF8-051C-4227-9BE1-CA06F4364F9C}: with operation none
02/18/16 18:23:22:692 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Swedish Language Pack_AdobePhotoshop16-sv_SE_x64 16.0.0.0 {1B7AE611-4C93-47FC-951F-0BD9839AB72B}: with operation none
02/18/16 18:23:22:692 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Dutch Language Pack_AdobePhotoshop16-nl_NL_x64 16.0.0.0 {2060E7ED-C473-4A38-877F-C844E81B64F3}: with operation none
02/18/16 18:23:22:692 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 North American Spanish Language Pack_AdobePhotoshop16-es_MX_x64 16.0.0.0 {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4}: with operation none
02/18/16 18:23:22:692 | [INFO] | | OOBE | DE | | | | 4716 | Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}: with operation remove
02/18/16 18:23:22:692 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Preview CC_1.1.3_AdobePreview1.0All-win64 1.1.3.0 {27B8946D-664A-4877-A3C9-CE8249CA1D7A}: with operation remove
02/18/16 18:23:22:692 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Chinese Language Pack_AdobePhotoshop16-zh_CN_x64 16.0.0.0 {3875BF24-5D9A-494A-A4FA-7AC70F56EC88}: with operation none
02/18/16 18:23:22:692 | [INFO] | | OOBE | DE | | | | 4716 | Export Assets 2 (64 bit)_2.4_AdobeExportAssets2.0All-x64 2.4.0.0 {3C285B12-AFED-4136-B575-1D6CA2B71D29}: with operation remove
02/18/16 18:23:22:692 | [INFO] | | OOBE | DE | | | | 4716 | Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20}: with operation remove
02/18/16 18:23:22:692 | [INFO] | | OOBE | DE | | | | 4716 | Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}: with operation remove
02/18/16 18:23:22:692 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}: with operation remove
02/18/16 18:23:22:693 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Brazilian Portugese Language Pack_AdobePhotoshop16-pt_BR_x64 16.0.0.0 {4A0115A5-CA14-4EA1-9896-2F161B5144B9}: with operation none
02/18/16 18:23:22:693 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Support_16.1.2_AdobePhotoshop16-Support 16.1.2.0 {4A117739-A3A4-4E1A-8F5A-82CB1958794F}: with operation remove
02/18/16 18:23:22:693 | [INFO] | | OOBE | DE | | | | 4716 | Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}: with operation remove
02/18/16 18:23:22:693 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 International English Language Pack_AdobePhotoshop16-en_GB_x64 16.0.0.0 {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4}: with operation none
02/18/16 18:23:22:693 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorJA CC 5.0.0.0 {52D57F95-000A-4922-BB31-C6A936F4FD7D}: with operation none
02/18/16 18:23:22:693 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Korean Language Pack_AdobePhotoshop16-ko_KR_x64 16.0.0.0 {5309436A-D12F-437D-B7A4-BF136E17139C}: with operation none
02/18/16 18:23:22:693 | [INFO] | | OOBE | DE | | | | 4716 | Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}: with operation remove
02/18/16 18:23:22:693 | [INFO] | | OOBE | DE | | | | 4716 | Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9}: with operation remove
02/18/16 18:23:22:693 | [INFO] | | OOBE | DE | | | | 4716 | Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}: with operation remove
02/18/16 18:23:22:693 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}: with operation remove
02/18/16 18:23:22:693 | [INFO] | | OOBE | DE | | | | 4716 | Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}: with operation remove
02/18/16 18:23:22:693 | [INFO] | | OOBE | DE | | | | 4716 | Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}: with operation remove
02/18/16 18:23:22:693 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Spanish Language Pack_AdobePhotoshop16-es_ES_x64 16.0.0.0 {644DC0CB-E8C9-4508-B99D-8747C6172621}: with operation none
02/18/16 18:23:22:693 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 German Language Pack_AdobePhotoshop16-de_DE_x64 16.0.0.0 {69C13F4A-83B3-42F4-912C-C99F1442F439}: with operation none
02/18/16 18:23:22:693 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Russian Language Pack_AdobePhotoshop16-ru_RU_x64 16.0.0.0 {6E14FFAB-83F4-4CB7-87A2-703F6F20487A}: with operation none
02/18/16 18:23:22:693 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 AE English Language Pack_AdobePhotoshop16-en_AE_x64 16.0.0.0 {6E7A3076-3056-492F-966F-1EA4FDCE5FA8}: with operation none
02/18/16 18:23:22:693 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorNA CC 5.0.0.0 {72405B80-A3DD-4BB2-A8C4-A90BC7BA50FF}: with operation none
02/18/16 18:23:22:693 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Canadian French Language Pack_AdobePhotoshop16-fr_CA_x64 16.0.0.0 {7433F860-160E-4024-8218-892D796972A6}: with operation none
02/18/16 18:23:22:693 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Czech Language Pack_AdobePhotoshop16-cs_CZ_x64 16.0.0.0 {7787331E-D646-4CA4-ADCB-B264CC156D7D}: with operation none
02/18/16 18:23:22:693 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Japanese Language Pack_AdobePhotoshop16-ja_JP_x64 16.0.0.0 {778CE554-471C-4605-A600-852C976A4DC5}: with operation none
02/18/16 18:23:22:693 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}: with operation remove
02/18/16 18:23:22:693 | [INFO] | | OOBE | DE | | | | 4716 | Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC}: with operation remove
02/18/16 18:23:22:693 | [INFO] | | OOBE | DE | | | | 4716 | Photoshop Camera Raw 8_9.4_AdobeCameraRaw8.0All 9.4.0.0 {8B793E8B-07C8-4865-A698-FE003249A576}: with operation remove
02/18/16 18:23:22:694 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Polish Language Pack_AdobePhotoshop16-pl_PL_x64 16.0.0.0 {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0}: with operation none
02/18/16 18:23:22:694 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Italian Language Pack_AdobePhotoshop16-it_IT_x64 16.0.0.0 {960F21E4-EBDC-4A3E-80E9-C28D8A593F66}: with operation none
02/18/16 18:23:22:694 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Hungarian Language Pack_AdobePhotoshop16-hu_HU_x64 16.0.0.0 {98D6FC60-7908-474A-A598-0D7A7BFEF2C2}: with operation none
02/18/16 18:23:22:694 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorEU CC 5.0.0.0 {9E9EB9FD-FDE8-487A-A41C-7713DA91AC89}: with operation none
02/18/16 18:23:22:694 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}: with operation remove
02/18/16 18:23:22:694 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}: with operation remove
02/18/16 18:23:22:694 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}: with operation remove
02/18/16 18:23:22:694 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 French Language Pack_AdobePhotoshop16-fr_FR_x64 16.0.0.0 {B75FB41B-E3E2-4B9F-93F7-62D982857374}: with operation none
02/18/16 18:23:22:694 | [INFO] | | OOBE | DE | | | | 4716 | Photoshop Camera Raw 8 (64 bit)_9.4_AdobeCameraRaw8.0All-x64 9.4.0.0 {BE4895E5-6517-4CED-B62A-A5A046ADBFCF}: with operation remove
02/18/16 18:23:22:694 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Turkish Language Pack_AdobePhotoshop16-tr_TR_x64 16.0.0.0 {BED85F42-B42C-4A91-946B-A928824C48A1}: with operation none
02/18/16 18:23:22:694 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}: with operation remove
02/18/16 18:23:22:694 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860}: with operation none
02/18/16 18:23:22:694 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}: with operation remove
02/18/16 18:23:22:694 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}: with operation remove
02/18/16 18:23:22:694 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Core_16.1.2_AdobePhotoshop16-Core_x64 16.1.2.0 {F217525B-30EB-42F2-A730-F61139264DB5}: with operation remove
02/18/16 18:23:22:694 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Danish Language Pack_AdobePhotoshop16-da_DK_x64 16.0.0.0 {F5D14B6C-DA16-4031-9EB8-AF0728550AFC}: with operation none
02/18/16 18:23:22:694 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}: with operation remove
02/18/16 18:23:22:694 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Finnish Language Pack_AdobePhotoshop16-fi_FI_x64 16.0.0.0 {FD8B8694-1044-4481-A5D9-4740A46BBC3B}: with operation none
02/18/16 18:23:22:694 | [INFO] | | OOBE | DE | | | | 4716 | END InstallOperationsQueue Unordered operations
02/18/16 18:23:22:695 | [INFO] | | OOBE | DE | | | | 4716 | BEGIN InstallOperationsQueue Ordered operations
02/18/16 18:23:22:695 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Core_16.1.2_AdobePhotoshop16-Core_x64 16.1.2.0 {F217525B-30EB-42F2-A730-F61139264DB5}: with operation remove
02/18/16 18:23:22:695 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}: with operation remove
02/18/16 18:23:22:695 | [INFO] | | OOBE | DE | | | | 4716 | Photoshop Camera Raw 8_9.4_AdobeCameraRaw8.0All 9.4.0.0 {8B793E8B-07C8-4865-A698-FE003249A576}: with operation remove
02/18/16 18:23:22:695 | [INFO] | | OOBE | DE | | | | 4716 | Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}: with operation remove
02/18/16 18:23:22:695 | [INFO] | | OOBE | DE | | | | 4716 | Photoshop Camera Raw 8 (64 bit)_9.4_AdobeCameraRaw8.0All-x64 9.4.0.0 {BE4895E5-6517-4CED-B62A-A5A046ADBFCF}: with operation remove
02/18/16 18:23:22:695 | [INFO] | | OOBE | DE | | | | 4716 | Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}: with operation remove
02/18/16 18:23:22:695 | [INFO] | | OOBE | DE | | | | 4716 | Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}: with operation remove
02/18/16 18:23:22:695 | [INFO] | | OOBE | DE | | | | 4716 | Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}: with operation remove
02/18/16 18:23:22:695 | [INFO] | | OOBE | DE | | | | 4716 | Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC}: with operation remove
02/18/16 18:23:22:695 | [INFO] | | OOBE | DE | | | | 4716 | Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20}: with operation remove
02/18/16 18:23:22:695 | [INFO] | | OOBE | DE | | | | 4716 | Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9}: with operation remove
02/18/16 18:23:22:695 | [INFO] | | OOBE | DE | | | | 4716 | Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}: with operation remove
02/18/16 18:23:22:695 | [INFO] | | OOBE | DE | | | | 4716 | Export Assets 2 (64 bit)_2.4_AdobeExportAssets2.0All-x64 2.4.0.0 {3C285B12-AFED-4136-B575-1D6CA2B71D29}: with operation remove
02/18/16 18:23:22:695 | [INFO] | | OOBE | DE | | | | 4716 | Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}: with operation remove
02/18/16 18:23:22:695 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}: with operation remove
02/18/16 18:23:22:695 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}: with operation remove
02/18/16 18:23:22:695 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}: with operation remove
02/18/16 18:23:22:695 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}: with operation remove
02/18/16 18:23:22:695 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}: with operation remove
02/18/16 18:23:22:696 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}: with operation remove
02/18/16 18:23:22:696 | [INFO] | | OOBE | DE | | | | 4716 | AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}: with operation remove
02/18/16 18:23:22:696 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Preview CC_1.1.3_AdobePreview1.0All-win64 1.1.3.0 {27B8946D-664A-4877-A3C9-CE8249CA1D7A}: with operation remove
02/18/16 18:23:22:696 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}: with operation remove
02/18/16 18:23:22:696 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Support_16.1.2_AdobePhotoshop16-Support 16.1.2.0 {4A117739-A3A4-4E1A-8F5A-82CB1958794F}: with operation remove
02/18/16 18:23:22:696 | [INFO] | | OOBE | DE | | | | 4716 | Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}: with operation remove
02/18/16 18:23:22:696 | [INFO] | | OOBE | DE | | | | 4716 | Camera Profiles Installer_9.4_AdobeCameraRawProfile8.0All 9.4.0.0 {03B147C3-2412-4DE8-80F9-3EB977421EF2}: with operation remove
02/18/16 18:23:22:696 | [INFO] | | OOBE | DE | | | | 4716 | Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}: with operation remove
02/18/16 18:23:22:696 | [INFO] | | OOBE | DE | | | | 4716 | END InstallOperationsQueue Ordered operations
02/18/16 18:23:22:730 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for pre-remove for payload Adobe Photoshop CC 2015 Core_16.1.2_AdobePhotoshop16-Core_x64 16.1.2.0 {F217525B-30EB-42F2-A730-F61139264DB5}
02/18/16 18:23:22:751 | [INFO] | | OOBE | DE | | | | 4716 | ::START TIMER:: [Payload Operation :{F217525B-30EB-42F2-A730-F61139264DB5}]
02/18/16 18:23:22:857 | [INFO] | | OOBE | DE | | | | 6212 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:23:22:857 | [INFO] | | OOBE | DE | | | | 6212 | Installer Operation: PayloadUninstaller
02/18/16 18:23:22:859 | [INFO] | | OOBE | DE | | | | 6212 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {F217525B-30EB-42F2-A730-F61139264DB5}
02/18/16 18:23:23:376 | [INFO] | | OOBE | DE | | | | 6212 | Effective AdobeCode for: {F217525B-30EB-42F2-A730-F61139264DB5} is {F217525B-30EB-42F2-A730-F61139264DB5}
02/18/16 18:23:23:398 | [INFO] | | OOBE | DE | | | | 6212 | Uninstalling payload
02/18/16 18:23:23:433 | [INFO] | | OOBE | DE | | | | 6212 | Payload Adobe Photoshop CC 2015 Core_16.1.2_AdobePhotoshop16-Core_x64 16.1.2.0 {F217525B-30EB-42F2-A730-F61139264DB5}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 18:23:23:733 | [INFO] | | OOBE | DE | | | | 6212 | Setting file open option to false in the unzipper
02/18/16 18:23:54:559 | [INFO] | | OOBE | DE | | | | 6212 | CustomizedPatch property not found in database
02/18/16 18:23:54:560 | [INFO] | | OOBE | DE | | | | 6212 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{F217525B-30EB-42F2-A730-F61139264DB5}.db
02/18/16 18:32:22:258 | [INFO] | | OOBE | DE | | | | 6212 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{F217525B-30EB-42F2-A730-F61139264DB5}.db
02/18/16 18:32:29:692 | [INFO] | | OOBE | DE | | | | 6212 | Physical payload uninstall result:0
02/18/16 18:32:29:771 | [INFO] | | OOBE | DE | | | | 4716 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:32:29:812 | [INFO] | | OOBE | DE | | | | 4716 | :: END TIMER :: [Payload Operation :{F217525B-30EB-42F2-A730-F61139264DB5}] took 547021 milliseconds (547.021 seconds) DTR = 662.491 KBPS (0.646964 MBPS)
02/18/16 18:32:30:518 | [INFO] | | OOBE | DE | | | | 4716 | User specified overrideFile:
02/18/16 18:32:40:844 | [INFO] | | OOBE | DE | | | | 4716 | Successfully updated the csu inventory for Adobe Photoshop CC 2015 Core_16.1.2_AdobePhotoshop16-Core_x64 16.1.2.0 {F217525B-30EB-42F2-A730-F61139264DB5} return values 0:0
02/18/16 18:32:40:858 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for post-remove for payload Adobe Photoshop CC 2015 Core_16.1.2_AdobePhotoshop16-Core_x64 16.1.2.0 {F217525B-30EB-42F2-A730-F61139264DB5}
02/18/16 18:32:40:961 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for pre-remove for payload Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:32:40:978 | [INFO] | | OOBE | DE | | | | 4716 | ::START TIMER:: [Payload Operation :{793C2BF7-A4FE-4608-91C9-9282C5801C21}]
02/18/16 18:32:40:993 | [INFO] | | OOBE | DE | | | | 2624 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:32:40:993 | [INFO] | | OOBE | DE | | | | 2624 | Installer Operation: PayloadUninstaller
02/18/16 18:32:40:993 | [INFO] | | OOBE | DE | | | | 2624 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:32:41:148 | [INFO] | | OOBE | DE | | | | 2624 | Effective AdobeCode for: {793C2BF7-A4FE-4608-91C9-9282C5801C21} is {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:32:41:157 | [INFO] | | OOBE | DE | | | | 2624 | Uninstalling payload
02/18/16 18:32:41:170 | [INFO] | | OOBE | DE | | | | 2624 | Payload Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 18:32:41:191 | [INFO] | | OOBE | DE | | | | 2624 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{793C2BF7-A4FE-4608-91C9-9282C5801C21}.db
02/18/16 18:33:54:320 | [INFO] | | OOBE | DE | | | | 2624 | Evaluating condition# 1(Seq 3385)
02/18/16 18:33:54:321 | [INFO] | | OOBE | DE | | | | 2624 | Condition passed(Seq 3385)
02/18/16 18:37:41:226 | [INFO] | | OOBE | DE | | | | 2624 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{793C2BF7-A4FE-4608-91C9-9282C5801C21}.db
02/18/16 18:37:51:959 | [INFO] | | OOBE | DE | | | | 2624 | Physical payload uninstall result:0
02/18/16 18:37:51:963 | [INFO] | | OOBE | DE | | | | 4716 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:37:51:963 | [INFO] | | OOBE | DE | | | | 4716 | :: END TIMER :: [Payload Operation :{793C2BF7-A4FE-4608-91C9-9282C5801C21}] took 310974 milliseconds (310.974 seconds) DTR = 4586.35 KBPS (4.47886 MBPS)
02/18/16 18:37:52:077 | [INFO] | | OOBE | DE | | | | 4716 | Updating driver data - Action: Add driver entry
02/18/16 18:37:52:079 | [INFO] | | OOBE | DE | | | | 4716 | Updating driver data successful. Driver entry was added. ARP estimated size 0KB
02/18/16 18:37:52:888 | [INFO] | | OOBE | DE | | | | 4716 | User specified overrideFile:
02/18/16 18:38:04:742 | [INFO] | | OOBE | DE | | | | 4716 | Successfully updated the csu inventory for Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21} return values 0:0
02/18/16 18:38:04:752 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for post-remove for payload Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 18:38:04:843 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for pre-remove for payload Photoshop Camera Raw 8_9.4_AdobeCameraRaw8.0All 9.4.0.0 {8B793E8B-07C8-4865-A698-FE003249A576}
02/18/16 18:38:04:869 | [INFO] | | OOBE | DE | | | | 4716 | ::START TIMER:: [Payload Operation :{8B793E8B-07C8-4865-A698-FE003249A576}]
02/18/16 18:38:04:883 | [INFO] | | OOBE | DE | | | | 340 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:38:04:883 | [INFO] | | OOBE | DE | | | | 340 | Installer Operation: PayloadUninstaller
02/18/16 18:38:04:883 | [INFO] | | OOBE | DE | | | | 340 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {8B793E8B-07C8-4865-A698-FE003249A576}
02/18/16 18:38:05:059 | [INFO] | | OOBE | DE | | | | 340 | Effective AdobeCode for: {8B793E8B-07C8-4865-A698-FE003249A576} is {8B793E8B-07C8-4865-A698-FE003249A576}
02/18/16 18:38:05:069 | [INFO] | | OOBE | DE | | | | 340 | Uninstalling payload
02/18/16 18:38:05:141 | [INFO] | | OOBE | DE | | | | 340 | Payload Photoshop Camera Raw 8_9.4_AdobeCameraRaw8.0All 9.4.0.0 {8B793E8B-07C8-4865-A698-FE003249A576}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 18:38:05:195 | [INFO] | | OOBE | DE | | | | 340 | Setting file open option to false in the unzipper
02/18/16 18:38:07:783 | [INFO] | | OOBE | DE | | | | 340 | CustomizedPatch property not found in database
02/18/16 18:38:07:784 | [INFO] | | OOBE | DE | | | | 340 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{8B793E8B-07C8-4865-A698-FE003249A576}.db
02/18/16 18:38:08:927 | [INFO] | | OOBE | DE | | | | 340 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{8B793E8B-07C8-4865-A698-FE003249A576}.db
02/18/16 18:38:08:929 | [INFO] | | OOBE | DE | | | | 340 | Physical payload uninstall result:0
02/18/16 18:38:08:982 | [INFO] | | OOBE | DE | | | | 4716 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:38:08:982 | [INFO] | | OOBE | DE | | | | 4716 | :: END TIMER :: [Payload Operation :{8B793E8B-07C8-4865-A698-FE003249A576}] took 4113.22 milliseconds (4.11322 seconds) DTR = 11332.2 KBPS (11.0666 MBPS)
02/18/16 18:38:09:549 | [INFO] | | OOBE | DE | | | | 4716 | User specified overrideFile:
02/18/16 18:38:09:878 | [INFO] | | OOBE | DE | | | | 4716 | Successfully updated the csu inventory for Photoshop Camera Raw 8_9.4_AdobeCameraRaw8.0All 9.4.0.0 {8B793E8B-07C8-4865-A698-FE003249A576} return values 0:0
02/18/16 18:38:09:888 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for post-remove for payload Photoshop Camera Raw 8_9.4_AdobeCameraRaw8.0All 9.4.0.0 {8B793E8B-07C8-4865-A698-FE003249A576}
02/18/16 18:38:09:932 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for pre-remove for payload Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}
02/18/16 18:38:09:950 | [INFO] | | OOBE | DE | | | | 4716 | ::START TIMER:: [Payload Operation :{3E7FC757-D497-4C89-A935-7D38E2164E85}]
02/18/16 18:38:09:964 | [INFO] | | OOBE | DE | | | | 6576 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:38:09:964 | [INFO] | | OOBE | DE | | | | 6576 | Installer Operation: PayloadUninstaller
02/18/16 18:38:09:964 | [INFO] | | OOBE | DE | | | | 6576 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {3E7FC757-D497-4C89-A935-7D38E2164E85}
02/18/16 18:38:10:161 | [INFO] | | OOBE | DE | | | | 6576 | Effective AdobeCode for: {3E7FC757-D497-4C89-A935-7D38E2164E85} is {3E7FC757-D497-4C89-A935-7D38E2164E85}
02/18/16 18:38:10:171 | [INFO] | | OOBE | DE | | | | 6576 | Uninstalling payload
02/18/16 18:38:10:185 | [INFO] | | OOBE | DE | | | | 6576 | Payload Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 18:38:10:212 | [INFO] | | OOBE | DE | | | | 6576 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{3E7FC757-D497-4C89-A935-7D38E2164E85}.db
02/18/16 18:38:10:348 | [INFO] | | OOBE | DE | | | | 6576 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{3E7FC757-D497-4C89-A935-7D38E2164E85}.db
02/18/16 18:38:10:356 | [INFO] | | OOBE | DE | | | | 6576 | Physical payload uninstall result:0
02/18/16 18:38:10:363 | [INFO] | | OOBE | DE | | | | 4716 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:38:10:363 | [INFO] | | OOBE | DE | | | | 4716 | :: END TIMER :: [Payload Operation :{3E7FC757-D497-4C89-A935-7D38E2164E85}] took 412.711 milliseconds (0.412711 seconds) DTR = 60691.4 KBPS (59.269 MBPS)
02/18/16 18:38:11:262 | [INFO] | | OOBE | DE | | | | 4716 | User specified overrideFile:
02/18/16 18:38:12:191 | [INFO] | | OOBE | DE | | | | 4716 | Successfully updated the csu inventory for Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85} return values 0:0
02/18/16 18:38:12:201 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for post-remove for payload Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}
02/18/16 18:38:12:224 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for pre-remove for payload Photoshop Camera Raw 8 (64 bit)_9.4_AdobeCameraRaw8.0All-x64 9.4.0.0 {BE4895E5-6517-4CED-B62A-A5A046ADBFCF}
02/18/16 18:38:12:249 | [INFO] | | OOBE | DE | | | | 4716 | ::START TIMER:: [Payload Operation :{BE4895E5-6517-4CED-B62A-A5A046ADBFCF}]
02/18/16 18:38:12:278 | [INFO] | | OOBE | DE | | | | 6672 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:38:12:278 | [INFO] | | OOBE | DE | | | | 6672 | Installer Operation: PayloadUninstaller
02/18/16 18:38:12:278 | [INFO] | | OOBE | DE | | | | 6672 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {BE4895E5-6517-4CED-B62A-A5A046ADBFCF}
02/18/16 18:38:12:633 | [INFO] | | OOBE | DE | | | | 6672 | Effective AdobeCode for: {BE4895E5-6517-4CED-B62A-A5A046ADBFCF} is {BE4895E5-6517-4CED-B62A-A5A046ADBFCF}
02/18/16 18:38:12:642 | [INFO] | | OOBE | DE | | | | 6672 | Uninstalling payload
02/18/16 18:38:12:657 | [INFO] | | OOBE | DE | | | | 6672 | Payload Photoshop Camera Raw 8 (64 bit)_9.4_AdobeCameraRaw8.0All-x64 9.4.0.0 {BE4895E5-6517-4CED-B62A-A5A046ADBFCF}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 18:38:12:674 | [INFO] | | OOBE | DE | | | | 6672 | Setting file open option to false in the unzipper
02/18/16 18:38:14:934 | [INFO] | | OOBE | DE | | | | 6672 | CustomizedPatch property not found in database
02/18/16 18:38:14:935 | [INFO] | | OOBE | DE | | | | 6672 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{BE4895E5-6517-4CED-B62A-A5A046ADBFCF}.db
02/18/16 18:38:15:182 | [INFO] | | OOBE | DE | | | | 6672 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{BE4895E5-6517-4CED-B62A-A5A046ADBFCF}.db
02/18/16 18:38:15:184 | [INFO] | | OOBE | DE | | | | 6672 | Physical payload uninstall result:0
02/18/16 18:38:15:244 | [INFO] | | OOBE | DE | | | | 4716 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:38:15:244 | [INFO] | | OOBE | DE | | | | 4716 | :: END TIMER :: [Payload Operation :{BE4895E5-6517-4CED-B62A-A5A046ADBFCF}] took 2993.66 milliseconds (2.99366 seconds) DTR = 18456.3 KBPS (18.0237 MBPS)
02/18/16 18:38:15:994 | [INFO] | | OOBE | DE | | | | 4716 | User specified overrideFile:
02/18/16 18:38:16:230 | [INFO] | | OOBE | DE | | | | 4716 | Successfully updated the csu inventory for Photoshop Camera Raw 8 (64 bit)_9.4_AdobeCameraRaw8.0All-x64 9.4.0.0 {BE4895E5-6517-4CED-B62A-A5A046ADBFCF} return values 0:0
02/18/16 18:38:16:240 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for post-remove for payload Photoshop Camera Raw 8 (64 bit)_9.4_AdobeCameraRaw8.0All-x64 9.4.0.0 {BE4895E5-6517-4CED-B62A-A5A046ADBFCF}
02/18/16 18:38:16:318 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for pre-remove for payload Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}
02/18/16 18:38:16:334 | [INFO] | | OOBE | DE | | | | 4716 | ::START TIMER:: [Payload Operation :{5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}]
02/18/16 18:38:16:348 | [INFO] | | OOBE | DE | | | | 2576 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:38:16:348 | [INFO] | | OOBE | DE | | | | 2576 | Installer Operation: PayloadUninstaller
02/18/16 18:38:16:348 | [INFO] | | OOBE | DE | | | | 2576 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}
02/18/16 18:38:16:571 | [INFO] | | OOBE | DE | | | | 2576 | Effective AdobeCode for: {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA} is {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}
02/18/16 18:38:16:581 | [INFO] | | OOBE | DE | | | | 2576 | Uninstalling payload
02/18/16 18:38:16:594 | [INFO] | | OOBE | DE | | | | 2576 | Payload Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 18:38:16:638 | [INFO] | | OOBE | DE | | | | 2576 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}.db
02/18/16 18:38:16:805 | [INFO] | | OOBE | DE | | | | 2576 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}.db
02/18/16 18:38:16:814 | [INFO] | | OOBE | DE | | | | 2576 | Physical payload uninstall result:0
02/18/16 18:38:16:847 | [INFO] | | OOBE | DE | | | | 4716 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:38:16:847 | [INFO] | | OOBE | DE | | | | 4716 | :: END TIMER :: [Payload Operation :{5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}] took 512.654 milliseconds (0.512654 seconds) DTR = 53759.4 KBPS (52.4994 MBPS)
02/18/16 18:38:17:227 | [INFO] | | OOBE | DE | | | | 4716 | User specified overrideFile:
02/18/16 18:38:17:566 | [INFO] | | OOBE | DE | | | | 4716 | Successfully updated the csu inventory for Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA} return values 0:0
02/18/16 18:38:17:759 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for post-remove for payload Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}
02/18/16 18:38:17:812 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for pre-remove for payload Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}
02/18/16 18:38:17:827 | [INFO] | | OOBE | DE | | | | 4716 | ::START TIMER:: [Payload Operation :{636D196A-789E-455D-825E-3FA79F67D446}]
02/18/16 18:38:17:840 | [INFO] | | OOBE | DE | | | | 6152 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:38:17:840 | [INFO] | | OOBE | DE | | | | 6152 | Installer Operation: ModifyThirdPartyPayloadOperation
02/18/16 18:38:17:858 | [INFO] | | OOBE | DE | | | | 6152 | Modify Thirdparty payload
02/18/16 18:38:17:875 | [INFO] | | OOBE | DE | | | | 6152 | Unable to remove payload.
02/18/16 18:38:17:875 | [INFO] | | OOBE | DE | | | | 6152 | Third party payload completed. Testing return code: 0
02/18/16 18:38:18:539 | [INFO] | | OOBE | DE | | | | 4716 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:38:18:539 | [INFO] | | OOBE | DE | | | | 4716 | :: END TIMER :: [Payload Operation :{636D196A-789E-455D-825E-3FA79F67D446}] took 712.483 milliseconds (0.712483 seconds)
02/18/16 18:38:18:570 | [INFO] | | OOBE | DE | | | | 4716 | User specified overrideFile:
02/18/16 18:38:18:823 | [INFO] | | OOBE | DE | | | | 4716 | The csu inventory was not updated for payload Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}, value of local var is -1
02/18/16 18:38:18:834 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for post-remove for payload Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}
02/18/16 18:38:18:852 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for pre-remove for payload Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}
02/18/16 18:38:18:867 | [INFO] | | OOBE | DE | | | | 4716 | ::START TIMER:: [Payload Operation :{4CED09CB-0C96-4EAE-83C4-7D9B9456E613}]
02/18/16 18:38:18:880 | [INFO] | | OOBE | DE | | | | 6492 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:38:18:881 | [INFO] | | OOBE | DE | | | | 6492 | Installer Operation: ModifyThirdPartyPayloadOperation
02/18/16 18:38:18:881 | [INFO] | | OOBE | DE | | | | 6492 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:38:18:881 | [INFO] | | OOBE | DE | | | | 6492 | Modify Thirdparty payload
02/18/16 18:38:18:881 | [INFO] | | OOBE | DE | | | | 6492 | Unable to remove payload.
02/18/16 18:38:18:881 | [INFO] | | OOBE | DE | | | | 6492 | Third party payload completed. Testing return code: 0
02/18/16 18:38:19:280 | [INFO] | | OOBE | DE | | | | 4716 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:38:19:280 | [INFO] | | OOBE | DE | | | | 4716 | :: END TIMER :: [Payload Operation :{4CED09CB-0C96-4EAE-83C4-7D9B9456E613}] took 412.574 milliseconds (0.412574 seconds) DTR = 9.69523 KBPS (0.00946799 MBPS)
02/18/16 18:38:19:310 | [INFO] | | OOBE | DE | | | | 4716 | User specified overrideFile:
02/18/16 18:38:19:546 | [INFO] | | OOBE | DE | | | | 4716 | The csu inventory was not updated for payload Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}, value of local var is -1
02/18/16 18:38:19:555 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for post-remove for payload Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}
02/18/16 18:38:19:574 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for pre-remove for payload Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC}
02/18/16 18:38:19:590 | [INFO] | | OOBE | DE | | | | 4716 | ::START TIMER:: [Payload Operation :{873BE68F-480F-49A6-9649-F98CAB056AFC}]
02/18/16 18:38:19:603 | [INFO] | | OOBE | DE | | | | 6692 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:38:19:603 | [INFO] | | OOBE | DE | | | | 6692 | Installer Operation: ModifyThirdPartyPayloadOperation
02/18/16 18:38:19:603 | [INFO] | | OOBE | DE | | | | 6692 | Modify Thirdparty payload
02/18/16 18:38:19:603 | [INFO] | | OOBE | DE | | | | 6692 | Unable to remove payload.
02/18/16 18:38:19:603 | [INFO] | | OOBE | DE | | | | 6692 | Third party payload completed. Testing return code: 0
02/18/16 18:38:19:703 | [INFO] | | OOBE | DE | | | | 4716 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:38:19:703 | [INFO] | | OOBE | DE | | | | 4716 | :: END TIMER :: [Payload Operation :{873BE68F-480F-49A6-9649-F98CAB056AFC}] took 113.507 milliseconds (0.113507 seconds) DTR = 35.2402 KBPS (0.0344143 MBPS)
02/18/16 18:38:19:732 | [INFO] | | OOBE | DE | | | | 4716 | User specified overrideFile:
02/18/16 18:38:19:756 | [INFO] | | OOBE | DE | | | | 4716 | The csu inventory was not updated for payload Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC}, value of local var is -1
02/18/16 18:38:19:765 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for post-remove for payload Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC}
02/18/16 18:38:19:870 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for pre-remove for payload Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20}
02/18/16 18:38:19:886 | [INFO] | | OOBE | DE | | | | 4716 | ::START TIMER:: [Payload Operation :{3E272A93-C06B-4206-AD02-0EBE02535E20}]
02/18/16 18:38:19:899 | [INFO] | | OOBE | DE | | | | 2816 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:38:19:899 | [INFO] | | OOBE | DE | | | | 2816 | Installer Operation: ModifyThirdPartyPayloadOperation
02/18/16 18:38:19:899 | [INFO] | | OOBE | DE | | | | 2816 | Modify Thirdparty payload
02/18/16 18:38:19:899 | [INFO] | | OOBE | DE | | | | 2816 | Unable to remove payload.
02/18/16 18:38:19:899 | [INFO] | | OOBE | DE | | | | 2816 | Third party payload completed. Testing return code: 0
02/18/16 18:38:19:999 | [INFO] | | OOBE | DE | | | | 4716 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:38:19:999 | [INFO] | | OOBE | DE | | | | 4716 | :: END TIMER :: [Payload Operation :{3E272A93-C06B-4206-AD02-0EBE02535E20}] took 113.338 milliseconds (0.113338 seconds) DTR = 105.878 KBPS (0.103396 MBPS)
02/18/16 18:38:20:029 | [INFO] | | OOBE | DE | | | | 4716 | User specified overrideFile:
02/18/16 18:38:20:053 | [INFO] | | OOBE | DE | | | | 4716 | The csu inventory was not updated for payload Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20}, value of local var is -1
02/18/16 18:38:20:063 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for post-remove for payload Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20}
02/18/16 18:38:20:107 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for pre-remove for payload Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9}
02/18/16 18:38:20:122 | [INFO] | | OOBE | DE | | | | 4716 | ::START TIMER:: [Payload Operation :{55B82130-18F9-11E2-8D43-00215AEA26C9}]
02/18/16 18:38:20:136 | [INFO] | | OOBE | DE | | | | 5176 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:38:20:136 | [INFO] | | OOBE | DE | | | | 5176 | Installer Operation: ModifyThirdPartyPayloadOperation
02/18/16 18:38:20:136 | [INFO] | | OOBE | DE | | | | 5176 | Modify Thirdparty payload
02/18/16 18:38:20:136 | [INFO] | | OOBE | DE | | | | 5176 | Unable to remove payload.
02/18/16 18:38:20:136 | [INFO] | | OOBE | DE | | | | 5176 | Third party payload completed. Testing return code: 0
02/18/16 18:38:20:235 | [INFO] | | OOBE | DE | | | | 4716 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:38:20:235 | [INFO] | | OOBE | DE | | | | 4716 | :: END TIMER :: [Payload Operation :{55B82130-18F9-11E2-8D43-00215AEA26C9}] took 112.591 milliseconds (0.112591 seconds) DTR = 106.58 KBPS (0.104082 MBPS)
02/18/16 18:38:20:264 | [INFO] | | OOBE | DE | | | | 4716 | User specified overrideFile:
02/18/16 18:38:20:287 | [INFO] | | OOBE | DE | | | | 4716 | The csu inventory was not updated for payload Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9}, value of local var is -1
02/18/16 18:38:20:297 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for post-remove for payload Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9}
02/18/16 18:38:20:317 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for pre-remove for payload Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}
02/18/16 18:38:20:333 | [INFO] | | OOBE | DE | | | | 4716 | ::START TIMER:: [Payload Operation :{54B0C34F-18F9-11E2-BC1D-00215AEA26C9}]
02/18/16 18:38:20:346 | [INFO] | | OOBE | DE | | | | 584 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:38:20:346 | [INFO] | | OOBE | DE | | | | 584 | Installer Operation: ModifyThirdPartyPayloadOperation
02/18/16 18:38:20:347 | [INFO] | | OOBE | DE | | | | 584 | Modify Thirdparty payload
02/18/16 18:38:20:347 | [INFO] | | OOBE | DE | | | | 584 | Unable to remove payload.
02/18/16 18:38:20:347 | [INFO] | | OOBE | DE | | | | 584 | Third party payload completed. Testing return code: 0
02/18/16 18:38:20:446 | [INFO] | | OOBE | DE | | | | 4716 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:38:20:446 | [INFO] | | OOBE | DE | | | | 4716 | :: END TIMER :: [Payload Operation :{54B0C34F-18F9-11E2-BC1D-00215AEA26C9}] took 113.026 milliseconds (0.113026 seconds) DTR = 141.561 KBPS (0.138243 MBPS)
02/18/16 18:38:20:478 | [INFO] | | OOBE | DE | | | | 4716 | User specified overrideFile:
02/18/16 18:38:20:502 | [INFO] | | OOBE | DE | | | | 4716 | The csu inventory was not updated for payload Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}, value of local var is -1
02/18/16 18:38:20:511 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for post-remove for payload Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}
02/18/16 18:38:20:531 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for pre-remove for payload Export Assets 2 (64 bit)_2.4_AdobeExportAssets2.0All-x64 2.4.0.0 {3C285B12-AFED-4136-B575-1D6CA2B71D29}
02/18/16 18:38:20:548 | [INFO] | | OOBE | DE | | | | 4716 | ::START TIMER:: [Payload Operation :{3C285B12-AFED-4136-B575-1D6CA2B71D29}]
02/18/16 18:38:20:561 | [INFO] | | OOBE | DE | | | | 6836 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:38:20:562 | [INFO] | | OOBE | DE | | | | 6836 | Installer Operation: PayloadUninstaller
02/18/16 18:38:20:562 | [INFO] | | OOBE | DE | | | | 6836 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:38:20:562 | [INFO] | | OOBE | DE | | | | 6836 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {3C285B12-AFED-4136-B575-1D6CA2B71D29}
02/18/16 18:38:20:816 | [INFO] | | OOBE | DE | | | | 6836 | Effective AdobeCode for: {3C285B12-AFED-4136-B575-1D6CA2B71D29} is {3C285B12-AFED-4136-B575-1D6CA2B71D29}
02/18/16 18:38:20:826 | [INFO] | | OOBE | DE | | | | 6836 | Uninstalling payload
02/18/16 18:38:20:869 | [INFO] | | OOBE | DE | | | | 6836 | Payload Export Assets 2 (64 bit)_2.4_AdobeExportAssets2.0All-x64 2.4.0.0 {3C285B12-AFED-4136-B575-1D6CA2B71D29}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 18:38:20:870 | [INFO] | | OOBE | DE | | | | 6836 | Setting file open option to false in the unzipper
02/18/16 18:38:23:521 | [INFO] | | OOBE | DE | | | | 6836 | CustomizedPatch property not found in database
02/18/16 18:38:23:522 | [INFO] | | OOBE | DE | | | | 6836 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{3C285B12-AFED-4136-B575-1D6CA2B71D29}.db
02/18/16 18:40:43:144 | [INFO] | | OOBE | DE | | | | 6836 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{3C285B12-AFED-4136-B575-1D6CA2B71D29}.db
02/18/16 18:40:43:606 | [INFO] | | OOBE | DE | | | | 6836 | Physical payload uninstall result:0
02/18/16 18:40:43:633 | [INFO] | | OOBE | DE | | | | 4716 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:40:43:633 | [INFO] | | OOBE | DE | | | | 4716 | :: END TIMER :: [Payload Operation :{3C285B12-AFED-4136-B575-1D6CA2B71D29}] took 143081 milliseconds (143.081 seconds) DTR = 32.4572 KBPS (0.0316965 MBPS)
02/18/16 18:40:43:978 | [INFO] | | OOBE | DE | | | | 4716 | User specified overrideFile:
02/18/16 18:40:44:309 | [INFO] | | OOBE | DE | | | | 4716 | Successfully updated the csu inventory for Export Assets 2 (64 bit)_2.4_AdobeExportAssets2.0All-x64 2.4.0.0 {3C285B12-AFED-4136-B575-1D6CA2B71D29} return values 0:0
02/18/16 18:40:44:353 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for post-remove for payload Export Assets 2 (64 bit)_2.4_AdobeExportAssets2.0All-x64 2.4.0.0 {3C285B12-AFED-4136-B575-1D6CA2B71D29}
02/18/16 18:40:44:391 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for pre-remove for payload Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}
02/18/16 18:40:44:406 | [INFO] | | OOBE | DE | | | | 4716 | ::START TIMER:: [Payload Operation :{27375F7C-0789-4FEA-889E-41BF12AC3140}]
02/18/16 18:40:44:420 | [INFO] | | OOBE | DE | | | | 4360 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:40:44:420 | [INFO] | | OOBE | DE | | | | 4360 | Installer Operation: PayloadUninstaller
02/18/16 18:40:44:420 | [INFO] | | OOBE | DE | | | | 4360 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {27375F7C-0789-4FEA-889E-41BF12AC3140}
02/18/16 18:40:45:268 | [INFO] | | OOBE | DE | | | | 4360 | Effective AdobeCode for: {27375F7C-0789-4FEA-889E-41BF12AC3140} is {27375F7C-0789-4FEA-889E-41BF12AC3140}
02/18/16 18:40:45:330 | [INFO] | | OOBE | DE | | | | 4360 | Uninstalling payload
02/18/16 18:40:45:343 | [INFO] | | OOBE | DE | | | | 4360 | Payload Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 18:40:45:368 | [INFO] | | OOBE | DE | | | | 4360 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{27375F7C-0789-4FEA-889E-41BF12AC3140}.db
02/18/16 18:42:04:993 | [INFO] | | OOBE | DE | | | | 4360 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{27375F7C-0789-4FEA-889E-41BF12AC3140}.db
02/18/16 18:42:07:066 | [INFO] | | OOBE | DE | | | | 4360 | Physical payload uninstall result:0
02/18/16 18:42:07:143 | [INFO] | | OOBE | DE | | | | 4716 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:42:07:143 | [INFO] | | OOBE | DE | | | | 4716 | :: END TIMER :: [Payload Operation :{27375F7C-0789-4FEA-889E-41BF12AC3140}] took 82734.4 milliseconds (82.7344 seconds) DTR = 213.116 KBPS (0.208121 MBPS)
02/18/16 18:42:07:477 | [INFO] | | OOBE | DE | | | | 4716 | User specified overrideFile:
02/18/16 18:42:08:279 | [INFO] | | OOBE | DE | | | | 4716 | Successfully updated the csu inventory for Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140} return values 0:0
02/18/16 18:42:08:289 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for post-remove for payload Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}
02/18/16 18:42:08:309 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for pre-remove for payload AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}
02/18/16 18:42:08:324 | [INFO] | | OOBE | DE | | | | 4716 | ::START TIMER:: [Payload Operation :{CE9B1B00-0421-4701-9698-1C14646D6D94}]
02/18/16 18:42:08:338 | [INFO] | | OOBE | DE | | | | 6980 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:42:08:338 | [INFO] | | OOBE | DE | | | | 6980 | Installer Operation: PayloadUninstaller
02/18/16 18:42:08:338 | [INFO] | | OOBE | DE | | | | 6980 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {CE9B1B00-0421-4701-9698-1C14646D6D94}
02/18/16 18:42:08:765 | [INFO] | | OOBE | DE | | | | 6980 | Effective AdobeCode for: {CE9B1B00-0421-4701-9698-1C14646D6D94} is {CE9B1B00-0421-4701-9698-1C14646D6D94}
02/18/16 18:42:08:774 | [INFO] | | OOBE | DE | | | | 6980 | Uninstalling payload
02/18/16 18:42:08:788 | [INFO] | | OOBE | DE | | | | 6980 | Payload AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 18:42:08:845 | [INFO] | | OOBE | DE | | | | 6980 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{CE9B1B00-0421-4701-9698-1C14646D6D94}.db
02/18/16 18:42:08:847 | [INFO] | | OOBE | DE | | | | 6980 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{CE9B1B00-0421-4701-9698-1C14646D6D94}.db
02/18/16 18:42:08:848 | [INFO] | | OOBE | DE | | | | 6980 | Physical payload uninstall result:0
02/18/16 18:42:08:937 | [INFO] | | OOBE | DE | | | | 4716 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:42:08:937 | [INFO] | | OOBE | DE | | | | 4716 | :: END TIMER :: [Payload Operation :{CE9B1B00-0421-4701-9698-1C14646D6D94}] took 612.972 milliseconds (0.612972 seconds) DTR = 117.46 KBPS (0.114707 MBPS)
02/18/16 18:42:09:698 | [INFO] | | OOBE | DE | | | | 4716 | User specified overrideFile:
02/18/16 18:42:10:150 | [INFO] | | OOBE | DE | | | | 4716 | Successfully updated the csu inventory for AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94} return values 0:0
02/18/16 18:42:10:161 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for post-remove for payload AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}
02/18/16 18:42:10:182 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for pre-remove for payload AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}
02/18/16 18:42:10:197 | [INFO] | | OOBE | DE | | | | 4716 | ::START TIMER:: [Payload Operation :{5C5D62C9-91C6-415E-857E-9130C0F52C66}]
02/18/16 18:42:10:211 | [INFO] | | OOBE | DE | | | | 4848 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:42:10:211 | [INFO] | | OOBE | DE | | | | 4848 | Installer Operation: PayloadUninstaller
02/18/16 18:42:10:211 | [INFO] | | OOBE | DE | | | | 4848 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {5C5D62C9-91C6-415E-857E-9130C0F52C66}
02/18/16 18:42:10:430 | [INFO] | | OOBE | DE | | | | 4848 | Effective AdobeCode for: {5C5D62C9-91C6-415E-857E-9130C0F52C66} is {5C5D62C9-91C6-415E-857E-9130C0F52C66}
02/18/16 18:42:10:440 | [INFO] | | OOBE | DE | | | | 4848 | Uninstalling payload
02/18/16 18:42:10:453 | [INFO] | | OOBE | DE | | | | 4848 | Payload AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 18:42:10:476 | [INFO] | | OOBE | DE | | | | 4848 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{5C5D62C9-91C6-415E-857E-9130C0F52C66}.db
02/18/16 18:42:10:478 | [INFO] | | OOBE | DE | | | | 4848 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{5C5D62C9-91C6-415E-857E-9130C0F52C66}.db
02/18/16 18:42:10:479 | [INFO] | | OOBE | DE | | | | 4848 | Physical payload uninstall result:0
02/18/16 18:42:10:511 | [INFO] | | OOBE | DE | | | | 4716 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:42:10:511 | [INFO] | | OOBE | DE | | | | 4716 | :: END TIMER :: [Payload Operation :{5C5D62C9-91C6-415E-857E-9130C0F52C66}] took 313.865 milliseconds (0.313865 seconds) DTR = 89.2102 KBPS (0.0871193 MBPS)
02/18/16 18:42:10:921 | [INFO] | | OOBE | DE | | | | 4716 | User specified overrideFile:
02/18/16 18:42:11:170 | [INFO] | | OOBE | DE | | | | 4716 | Successfully updated the csu inventory for AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66} return values 0:0
02/18/16 18:42:11:180 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for post-remove for payload AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}
02/18/16 18:42:11:216 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for pre-remove for payload AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}
02/18/16 18:42:11:231 | [INFO] | | OOBE | DE | | | | 4716 | ::START TIMER:: [Payload Operation :{AB955DCF-69CD-4840-B7FB-F318CDD0AE44}]
02/18/16 18:42:11:244 | [INFO] | | OOBE | DE | | | | 4732 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:42:11:244 | [INFO] | | OOBE | DE | | | | 4732 | Installer Operation: PayloadUninstaller
02/18/16 18:42:11:244 | [INFO] | | OOBE | DE | | | | 4732 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}
02/18/16 18:42:11:464 | [INFO] | | OOBE | DE | | | | 4732 | Effective AdobeCode for: {AB955DCF-69CD-4840-B7FB-F318CDD0AE44} is {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}
02/18/16 18:42:11:474 | [INFO] | | OOBE | DE | | | | 4732 | Uninstalling payload
02/18/16 18:42:11:487 | [INFO] | | OOBE | DE | | | | 4732 | Payload AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 18:42:11:532 | [INFO] | | OOBE | DE | | | | 4732 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{AB955DCF-69CD-4840-B7FB-F318CDD0AE44}.db
02/18/16 18:42:11:534 | [INFO] | | OOBE | DE | | | | 4732 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{AB955DCF-69CD-4840-B7FB-F318CDD0AE44}.db
02/18/16 18:42:11:535 | [INFO] | | OOBE | DE | | | | 4732 | Physical payload uninstall result:0
02/18/16 18:42:11:543 | [INFO] | | OOBE | DE | | | | 4716 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:42:11:543 | [INFO] | | OOBE | DE | | | | 4716 | :: END TIMER :: [Payload Operation :{AB955DCF-69CD-4840-B7FB-F318CDD0AE44}] took 312.308 milliseconds (0.312308 seconds) DTR = 25.6158 KBPS (0.0250154 MBPS)
02/18/16 18:42:12:298 | [INFO] | | OOBE | DE | | | | 4716 | User specified overrideFile:
02/18/16 18:42:12:795 | [INFO] | | OOBE | DE | | | | 4716 | Successfully updated the csu inventory for AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44} return values 0:0
02/18/16 18:42:12:805 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for post-remove for payload AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}
02/18/16 18:42:12:848 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for pre-remove for payload AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}
02/18/16 18:42:12:862 | [INFO] | | OOBE | DE | | | | 4716 | ::START TIMER:: [Payload Operation :{A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}]
02/18/16 18:42:12:876 | [INFO] | | OOBE | DE | | | | 1332 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:42:12:876 | [INFO] | | OOBE | DE | | | | 1332 | Installer Operation: PayloadUninstaller
02/18/16 18:42:12:876 | [INFO] | | OOBE | DE | | | | 1332 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}
02/18/16 18:42:13:207 | [INFO] | | OOBE | DE | | | | 1332 | Effective AdobeCode for: {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB} is {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}
02/18/16 18:42:13:217 | [INFO] | | OOBE | DE | | | | 1332 | Uninstalling payload
02/18/16 18:42:13:230 | [INFO] | | OOBE | DE | | | | 1332 | Payload AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 18:42:13:287 | [INFO] | | OOBE | DE | | | | 1332 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}.db
02/18/16 18:42:13:289 | [INFO] | | OOBE | DE | | | | 1332 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}.db
02/18/16 18:42:13:290 | [INFO] | | OOBE | DE | | | | 1332 | Physical payload uninstall result:0
02/18/16 18:42:13:375 | [INFO] | | OOBE | DE | | | | 4716 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:42:13:375 | [INFO] | | OOBE | DE | | | | 4716 | :: END TIMER :: [Payload Operation :{A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}] took 512.647 milliseconds (0.512647 seconds) DTR = 132.645 KBPS (0.129536 MBPS)
02/18/16 18:42:14:365 | [INFO] | | OOBE | DE | | | | 4716 | User specified overrideFile:
02/18/16 18:42:15:089 | [INFO] | | OOBE | DE | | | | 4716 | Successfully updated the csu inventory for AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB} return values 0:0
02/18/16 18:42:15:100 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for post-remove for payload AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}
02/18/16 18:42:15:140 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for pre-remove for payload AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}
02/18/16 18:42:15:154 | [INFO] | | OOBE | DE | | | | 4716 | ::START TIMER:: [Payload Operation :{F6DED2DA-1D20-497E-8810-E745B45DCD28}]
02/18/16 18:42:15:167 | [INFO] | | OOBE | DE | | | | 3008 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:42:15:167 | [INFO] | | OOBE | DE | | | | 3008 | Installer Operation: PayloadUninstaller
02/18/16 18:42:15:167 | [INFO] | | OOBE | DE | | | | 3008 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {F6DED2DA-1D20-497E-8810-E745B45DCD28}
02/18/16 18:42:15:374 | [INFO] | | OOBE | DE | | | | 3008 | Effective AdobeCode for: {F6DED2DA-1D20-497E-8810-E745B45DCD28} is {F6DED2DA-1D20-497E-8810-E745B45DCD28}
02/18/16 18:42:15:383 | [INFO] | | OOBE | DE | | | | 3008 | Uninstalling payload
02/18/16 18:42:15:396 | [INFO] | | OOBE | DE | | | | 3008 | Payload AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 18:42:15:433 | [INFO] | | OOBE | DE | | | | 3008 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{F6DED2DA-1D20-497E-8810-E745B45DCD28}.db
02/18/16 18:42:15:435 | [INFO] | | OOBE | DE | | | | 3008 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{F6DED2DA-1D20-497E-8810-E745B45DCD28}.db
02/18/16 18:42:15:436 | [INFO] | | OOBE | DE | | | | 3008 | Physical payload uninstall result:0
02/18/16 18:42:15:467 | [INFO] | | OOBE | DE | | | | 4716 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:42:15:467 | [INFO] | | OOBE | DE | | | | 4716 | :: END TIMER :: [Payload Operation :{F6DED2DA-1D20-497E-8810-E745B45DCD28}] took 312.553 milliseconds (0.312553 seconds) DTR = 217.563 KBPS (0.212464 MBPS)
02/18/16 18:42:16:242 | [INFO] | | OOBE | DE | | | | 4716 | User specified overrideFile:
02/18/16 18:42:16:685 | [INFO] | | OOBE | DE | | | | 4716 | Successfully updated the csu inventory for AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28} return values 0:0
02/18/16 18:42:16:695 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for post-remove for payload AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}
02/18/16 18:42:16:717 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for pre-remove for payload AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}
02/18/16 18:42:16:732 | [INFO] | | OOBE | DE | | | | 4716 | ::START TIMER:: [Payload Operation :{C8DEBB29-3EB0-4B97-B652-4DE482B111BC}]
02/18/16 18:42:16:747 | [INFO] | | OOBE | DE | | | | 1172 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:42:16:747 | [INFO] | | OOBE | DE | | | | 1172 | Installer Operation: PayloadUninstaller
02/18/16 18:42:16:747 | [INFO] | | OOBE | DE | | | | 1172 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}
02/18/16 18:42:17:030 | [INFO] | | OOBE | DE | | | | 1172 | Effective AdobeCode for: {C8DEBB29-3EB0-4B97-B652-4DE482B111BC} is {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}
02/18/16 18:42:17:040 | [INFO] | | OOBE | DE | | | | 1172 | Uninstalling payload
02/18/16 18:42:17:053 | [INFO] | | OOBE | DE | | | | 1172 | Payload AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 18:42:17:097 | [INFO] | | OOBE | DE | | | | 1172 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{C8DEBB29-3EB0-4B97-B652-4DE482B111BC}.db
02/18/16 18:42:17:099 | [INFO] | | OOBE | DE | | | | 1172 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{C8DEBB29-3EB0-4B97-B652-4DE482B111BC}.db
02/18/16 18:42:17:100 | [INFO] | | OOBE | DE | | | | 1172 | Physical payload uninstall result:0
02/18/16 18:42:17:147 | [INFO] | | OOBE | DE | | | | 4716 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:42:17:147 | [INFO] | | OOBE | DE | | | | 4716 | :: END TIMER :: [Payload Operation :{C8DEBB29-3EB0-4B97-B652-4DE482B111BC}] took 415.168 milliseconds (0.415168 seconds) DTR = 134.885 KBPS (0.131724 MBPS)
02/18/16 18:42:17:609 | [INFO] | | OOBE | DE | | | | 4716 | User specified overrideFile:
02/18/16 18:42:18:280 | [INFO] | | OOBE | DE | | | | 4716 | Successfully updated the csu inventory for AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC} return values 0:0
02/18/16 18:42:18:291 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for post-remove for payload AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}
02/18/16 18:42:18:321 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for pre-remove for payload AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}
02/18/16 18:42:18:336 | [INFO] | | OOBE | DE | | | | 4716 | ::START TIMER:: [Payload Operation :{C4196275-B11A-40A1-8727-3C145C8F7D95}]
02/18/16 18:42:18:349 | [INFO] | | OOBE | DE | | | | 6596 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:42:18:349 | [INFO] | | OOBE | DE | | | | 6596 | Installer Operation: PayloadUninstaller
02/18/16 18:42:18:349 | [INFO] | | OOBE | DE | | | | 6596 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {C4196275-B11A-40A1-8727-3C145C8F7D95}
02/18/16 18:42:18:585 | [INFO] | | OOBE | DE | | | | 6596 | Effective AdobeCode for: {C4196275-B11A-40A1-8727-3C145C8F7D95} is {C4196275-B11A-40A1-8727-3C145C8F7D95}
02/18/16 18:42:18:594 | [INFO] | | OOBE | DE | | | | 6596 | Uninstalling payload
02/18/16 18:42:18:609 | [INFO] | | OOBE | DE | | | | 6596 | Payload AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 18:42:18:635 | [INFO] | | OOBE | DE | | | | 6596 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{C4196275-B11A-40A1-8727-3C145C8F7D95}.db
02/18/16 18:42:18:638 | [INFO] | | OOBE | DE | | | | 6596 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{C4196275-B11A-40A1-8727-3C145C8F7D95}.db
02/18/16 18:42:18:639 | [INFO] | | OOBE | DE | | | | 6596 | Physical payload uninstall result:0
02/18/16 18:42:18:649 | [INFO] | | OOBE | DE | | | | 4716 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:42:18:649 | [INFO] | | OOBE | DE | | | | 4716 | :: END TIMER :: [Payload Operation :{C4196275-B11A-40A1-8727-3C145C8F7D95}] took 313.004 milliseconds (0.313004 seconds) DTR = 255.588 KBPS (0.249597 MBPS)
02/18/16 18:42:18:988 | [INFO] | | OOBE | DE | | | | 4716 | User specified overrideFile:
02/18/16 18:42:19:201 | [INFO] | | OOBE | DE | | | | 4716 | Successfully updated the csu inventory for AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95} return values 0:0
02/18/16 18:42:19:211 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for post-remove for payload AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}
02/18/16 18:42:19:233 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for pre-remove for payload Adobe Preview CC_1.1.3_AdobePreview1.0All-win64 1.1.3.0 {27B8946D-664A-4877-A3C9-CE8249CA1D7A}
02/18/16 18:42:19:251 | [INFO] | | OOBE | DE | | | | 4716 | ::START TIMER:: [Payload Operation :{27B8946D-664A-4877-A3C9-CE8249CA1D7A}]
02/18/16 18:42:19:264 | [INFO] | | OOBE | DE | | | | 5988 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:42:19:265 | [INFO] | | OOBE | DE | | | | 5988 | Installer Operation: PayloadUninstaller
02/18/16 18:42:19:265 | [INFO] | | OOBE | DE | | | | 5988 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:42:19:265 | [INFO] | | OOBE | DE | | | | 5988 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {27B8946D-664A-4877-A3C9-CE8249CA1D7A}
02/18/16 18:42:19:476 | [INFO] | | OOBE | DE | | | | 5988 | Effective AdobeCode for: {27B8946D-664A-4877-A3C9-CE8249CA1D7A} is {27B8946D-664A-4877-A3C9-CE8249CA1D7A}
02/18/16 18:42:19:485 | [INFO] | | OOBE | DE | | | | 5988 | Uninstalling payload
02/18/16 18:42:19:499 | [INFO] | | OOBE | DE | | | | 5988 | Payload Adobe Preview CC_1.1.3_AdobePreview1.0All-win64 1.1.3.0 {27B8946D-664A-4877-A3C9-CE8249CA1D7A}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 18:42:19:572 | [INFO] | | OOBE | DE | | | | 5988 | Setting file open option to false in the unzipper
02/18/16 18:42:22:303 | [INFO] | | OOBE | DE | | | | 5988 | CustomizedPatch property not found in database
02/18/16 18:42:22:304 | [INFO] | | OOBE | DE | | | | 5988 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{27B8946D-664A-4877-A3C9-CE8249CA1D7A}.db
02/18/16 18:46:25:070 | [ERROR] | | OOBE | DE | | | | 5988 | DF022: New file checksum "㉡㘴ㄴ攷〰搹攲㍦ㅤ挷晡㜰㝥挷㕥挰 爠煥攮摮⤨഻ 号†耀ܬ汬湩偁⁉呒慐捴䅨灰祬㈳潎慃汬匨煥ㄠ㘸⤴ ††号晩耀ܳ湥䍴污敬桳畯摬戮歯഻ †††††眠獳挮潬敳号 耀ܺ†††搠湯⡥㬩†††††⥽഻ †††素㬩†号†耀݁湯:sparkles:牥潲❲畦据楴湯⤨笠⥽഻ ††素㬩††号:sparkles:耀݈祦汃敩瑮朠瑥牯杩湩污爠煥敵瑳Ⱗ映湵瑣潩⡮潤敮号 耀ݏ†瘠牡瘠牥晩䍹楬湥䍴污敬‽慦獬㭥††††慶号耀ݖ⁷敗卢捯敫却牥敶⡲灻牯㩴⬠瀫牯ⱴ瘠牥晩䍹楬湥㩴号瑣耀ݝ湩潦 ൻ ††††椠普敲敨摡牥孳猧捥眭扥潳号欭耀ݤ⹝桳畯摬攮汱:sparkles:攳戶㘲″㐠ㄠ‷〸⤧഻ ††††瘠号䍹耀ݫ䍴污敬‽牴敵഻ ††††爠瑥牵慦獬㭥††号絽耀ݲ据楴湯⤨笠†††††慶灯楴湯‽ൻ †††号瀠耀ݹ瀠牯ⱴ††††††潨瑳›ㄧ㜲〮〮ㄮⰧ†††号†耀ހ牥㩳笠†††††††䌧湯敮瑣潩❮›唧杰慲敤Ⱗ号†耀އ†††唧杰慲敤㨧✠敗卢捯敫❴ബ ††††††✠号湩耀ގ瑨灴⼺是潯慢扲穡挮浯Ⱗ†††††††匧捥圭扥号瑥耀ޕ✱›㌧㙥㉢㌶†‴㜱㠠✰ബ ††††††✠敓ⵣ敗号敫耀ޜ㉹㨧✠㜱†‹恇䑚‹†′戲㜠⁘″爯〹ധ ††††号耀ޣ†††㭽†††††慶敲ⁱ‽瑨灴爮煥敵瑳漨瑰号㬩耀ު††††敲牷瑩⡥圧乪籽⡍✶㬩†††††敲号㬩耀ޱ††††敲湯:sparkles:敲灳湯敳Ⱗ映湵瑣潩⡮敲⥳笠†号†耀敶楲祦汃敩瑮慃汬摥献潨汵敢漮㭫††††††号汣耀㬩††††††潤敮⤨഻ ††††素㬩†††号഻耀߆††眠獳漮⡮攧牲牯Ⱗ映湵瑣潩⡮ 絻㬩†††⥽号 耀ߍ椠⡴挧楬湥⁴慣敢搠湥敩獡湹档潲潮獵祬Ⱗ映湵号⡮耀ߔ ൻ †††瘠牡眠獳㴠渠睥圠扥潓正瑥敓癲牥笨潰号⬫耀ߛ敶楲祦汃敩瑮›畦据楴湯漨扣 ൻ ††††挠号獬耀ߢ †††素ⱽ映湵瑣潩⡮ ൻ ††††瘠牡漠瑰潩号笠耀ߩ†††††潰瑲›潰瑲ബ †††††栠獯㩴✠㈱⸷号✱耀߰†††††栠慥敤獲›ൻ ††††††✠潃湮捥楴号✠耀߷摡❥ബ ††††††✠灕牧摡❥›圧扥潓正瑥Ⱗ号†耀߾††伧楲楧❮›栧瑴㩰⼯潦扯牡慢潣❭ബ †††号†耀ࠅⵣ敗卢捯敫敋ㅹ㨧✠攳戶㘲″㐠ㄠ‷〸Ⱗ†††号†耀ࠌ捥圭扥潓正瑥䬭祥✲›ㄧ‷㤠䜠婠㥄†㈠㈠堷㌠⼠号耀ࠓ††††ൽ ††††素഻ ††††瘠牡爠煥㴠栠号敲耀ࠚ⡴灯楴湯⥳഻ ††††爠煥眮楲整:sparkles:橗絎䵼㘨⤧഻号†耀ࠡ爠煥攮摮⤨഻ ††††爠煥漮⡮爧獥潰獮❥畦据号爨耀ࠨൻ †††††爠獥献慴畴䍳摯桳畯摬攮汱㐨㬩号†耀††牰捯獥敮瑸楔正昨湵瑣潩⡮ ൻ †††††号獳耀࠶敳⤨഻ ††††††搠湯⡥㬩††††††⥽഻号†耀࠽素㬩††††⥽഻ †††眠獳漮⡮挧湯敮瑣潩❮号据耀ࡄ眨⥳笠†††††潤敮渨睥䔠牲牯:sparkles:潣湮捥楴湯洠号潮耀ࡋ攠瑳扡楬桳摥⤧㬩††††⥽഻ †††眠獳漮⡮号牯耀ࡒ湵瑣潩⡮ 絻㬩†††⥽഻ഊ ††椠⡴挧楬湥⁴号敢耀࡙灥整獡湹档潲潮獵祬Ⱗ映湵瑣潩⡮潤敮 ൻ ††号牡耀ࡠ㴠渠睥圠扥潓正瑥敓癲牥笨潰瑲›⬫潰瑲敶楲祦汃号›耀ࡧ楴湯漨扣 ൻ ††††挠⡢牴敵㬩††††絽号据耀⤨笠†††††慶灯楴湯‽ൻ †††††瀠号瀠耀ࡵ††††††潨瑳›ㄧ㜲〮〮ㄮⰧ††††††号牥耀ࡼ†††††††䌧湯敮瑣潩❮›唧杰慲敤Ⱗ††号†耀ࢃ唧杰慲敤㨧✠敗卢捯敫❴ബ ††††††✠牏杩湩号瑨耀ࢊ是潯慢扲穡挮浯Ⱗ†††††††匧捥圭扥潓正瑥号✱耀㙥㉢㌶†‴㜱㠠✰ബ ††††††✠敓ⵣ敗卢捯敫号㉹耀࢘㜱†‹恇䑚‹†′戲㜠⁘″爯〹ധ †††††素号†耀࢟㭽†††††慶敲ⁱ‽瑨灴爮煥敵瑳漨瑰潩獮㬩号†耀ࢦ†敲牷瑩⡥圧乪籽⡍✶㬩†††††敲湥⡤㬩号†耀ࢭ⥽഻ †††眠獳漮⡮挧湯敮瑣潩❮畦据楴湯眨⥳号†耀ࢴ††獷汣獯⡥㬩†††††潤敮⤨഻ †††素号†耀ࢻ†獷湯:sparkles:牥潲❲畦据楴湯⤨笠⥽഻ ††素㬩号†耀ࣂ:sparkles:慨摮敬敭獳条獥瀠獡敳污湯楷桴琠敨甠杰慲号煥耀ࣉ⠠灵牧摡敨摡✩畦据楴湯搨湯⥥笠††††慶号耀࣐⁷敗卢捯敫却牥敶⡲灻牯㩴⬠瀫牯ⱴ瘠牥晩䍹楬湥㩴号瑣耀ࣗ⥯笠†††††敲畴湲琠畲㭥††††絽畦据号⤨耀ࣞ†††††慶灯楴湯‽ൻ †††††瀠牯㩴瀠号耀ࣥ††††潨瑳›ㄧ㜲〮〮ㄮⰧ††††††敨摡牥号耀࣬†††††䌧湯敮瑣潩❮›唧杰慲敤Ⱗ†††††号唧耀ࣳ敤㨧✠敗卢捯敫❴ബ ††††††✠敓ⵣ敗卢捯敫号ㅹ耀ࣺ攳戶㘲″㐠ㄠ‷〸Ⱗ†††††††匧捥圭扥潓正号祥耀ँㄧ‷㤠䜠婠㥄†㈠㈠堷㌠⼠㥲✰ബ ††††††号杩耀ई✠瑨灴⼺是潯慢潣❭††††††ൽ ††††号 耀ए††瘠牡爠煥㴠栠瑴敲畱獥⡴灯楴湯⥳഻ †††号煥耀ख整:sparkles:橗絎䵼㘨⤧഻ ††††爠煥眮楲整渨睥䈠晵敦号へ耀झ㑸ⰸ〠㙸ⰵ〠㙸Ᵽ〠㙸Ᵽ〠㙸ⱦ〠晸嵦戧湩牡❹⤩号†耀त†爠煥攮摮⤨഻ †††素㬩††††獷湯:sparkles:潣号楴耀फ映湵瑣潩⡮獷 ൻ ††††眠湯:sparkles:敭獳条❥畦号湯耀ल⥡笠††††††慤慴献潨汵煥⡬䠧汥潬⤧഻ 号†耀ह眠整浲湩瑡⡥㬩††††††獷汣獯⡥㬩†号†耀ी潤敮⤨഻ ††††素㬩††††⥽഻ †††眠号⡮耀े牯Ⱗ映湵瑣潩⡮ 絻㬩†††⥽഻ †素㬩†⥽号 耀ॎ牣扩⡥挧楬湥⁴牰灯牥楴獥Ⱗ映湵瑣潩⡮ ൻ †椠号潲耀ॕ獩攠灸獯摥Ⱗ映湵瑣潩⡮潤敮 ൻ ††瘠牡眠獳号睥耀ड़潓正瑥敓癲牥笨潰瑲›⬫潰瑲ⱽ映湵瑣潩⡮ ൻ †号瘠耀ॣ‽敮⁷敗卢捯敫⡴眧㩳⼯潬慣桬獯㩴‧潰瑲灻号潣耀४楨紧㬩†††⥽഻ ††眠獳漮⡮挧湯敮瑣潩❮号楴耀ॱ楬湥⥴笠††††汣敩瑮瀮潲潴潣桳畯摬攮汱:sparkles:号഻耀ॸ††眠獳挮潬敳⤨഻ †††搠湯⡥㬩†††⥽഻号素耀ॿ††瑩:sparkles:牰瑯捯汯敖獲潩獩攠灸獯摥Ⱗ映湵瑣潩号敮耀আ ††瘠牡眠獳㴠渠睥圠扥潓正瑥敓癲牥笨潰瑲›⬫号ⱽ耀瑣潩⡮ ൻ †††瘠牡眠‽敮⁷敗卢捯敫⡴眧㩳号慣耀ঔ㩴‧潰瑲灻潲潴潣噬牥楳湯›紸㬩†††⥽഻号†耀ছ漮⡮挧湯敮瑣潩❮畦据楴湯挨楬湥⥴笠††††号瑮耀ঢ潴潣噬牥楳湯献潨汵煥⡬⤸഻ †††眠獳挮潬敳号 耀†搠湯⡥㬩†††⥽഻ †素㬩††瑩:sparkles:灵牧号煥耀র桴牯杩湩污爠煥敵瑳漠橢捥❴畦据楴湯搨湯⥥笠号†耀ষ獷‽敮⁷敗卢捯敫却牥敶⡲灻牯㩴⬠瀫牯絴畦号湯耀া††††慶獷㴠渠睥圠扥潓正瑥:sparkles:獷⼺氯捯污潨号⬠耀ⱴ笠牰瑯捯汯敖獲潩㩮㠠⥽഻ ††素㬩†††獷号:sparkles:耀ৌ捥楴湯Ⱗ映湵瑣潩⡮汣敩瑮 ൻ †††挠楬湥灵号剥耀瑴噰牥楳湯献潨汵煥⡬ㄧㄮ⤧഻ †††眠獳挮潬号഻耀††搠湯⡥㬩†††⥽഻ †素㬩†⥽഻ഊ紊㬩号敲耀ৡ椀꺅 䀘Ρ聈͵⥥☠…慶畬㴡⬠慶畬㭥 †素ਊ†号ਪ耀২⨠䌠敨正晩怠慶畬恥椠慮楴敶映湵瑣潩 †号†耀৯䀠瑳瑡捩 ††浀浥敢佲††⨠䀠慣整潧祲䰠号†耀৶䀠慰慲⩻⁽慶畬桔慶畬潴挠敨正ਮ††⨠䀠号湲耀৽潯敬湡⁽敒畴湲瑠畲恥椠癠污敵獩愠渠瑡癩号楴耀汥敳怠慦獬恥ਮ††⨠䀠硥浡汰††⨠ ††号楴耀牲祡瀮潲潴祴数瀮獵⥨††⨠⼠ 㸽琠畲††⨠号†耀獩慎楴敶弨㬩 ††⼯㴠‾慦獬††⨠ਯ††畦号湯耀ਙ瑡癩⡥慶畬⥥笠 ††椠瘨污敵㴠‽畮汬 ††号敲耀ਠ映污敳††††††晩⠠獩畆据楴湯瘨污敵⤩笠号†耀ਧ瑥牵敲獉慎楴敶琮獥⡴湦潔瑓楲杮挮污⡬慶畬⥥㬩号†耀ਮ††爠瑥牵獩扏敪瑣楌敫瘨污敵 ☦爠䥥䡳獯䍴潴号瑳耀ਵ敵㬩 †素ਊ††⨯ਪ††⨠䌠敨正晩怠慶畬恥椠号汵耀਼††⨠ ††獀慴楴††⨠䀠敭扭牥晏张 ††号瑡耀⁹慌杮 ††灀牡浡笠紪瘠污敵吠敨瘠污敵琠档号 耀牀瑥牵獮笠潢汯慥絮删瑥牵獮怠牴敵晩怠慶畬恥号湠耀ੑ汥敳怠慦獬恥ਮ††⨠䀠硥浡汰††⨠ ††号畎耀汵⥬††⨠⼠ 㸽琠畲††⨠ ††獩畎汬号耀††⨠⼠ 㸽映污敳 ††⼪ †映湵瑣潩獩畎汬号敵耀੦†††敲畴湲瘠污敵㴠㴽渠汵㭬 †素ਊ††⨯ਪ†号䌠耀੭晩怠慶畬恥椠汣獡楳楦摥愠习浵敢恲瀠楲業号漠耀ੴ敪瑣ਮ††⨠ ††⨪潎整⨺潔攠捸畬敤怠湉楦号Ⱡ耀普湩瑩恹湡习乡Ⱡ眠楨档愠敲挠慬獳晩敩††号耀ં牥ⱳ甠敳琠敨怠獩楆楮整敭桴摯ਮ††⨠ ††号慴耀ઉ††⨠䀠敭扭牥晏张 ††捀瑡来牯⁹慌杮 ††号牡耀ઐ紪瘠污敵吠敨瘠污敵琠档捥 ††牀瑥牵獮笠号慥耀ગ瑥牵獮怠牴敵晩怠慶畬恥椠潣牲捥汴⁹汣獡楳楦号汥耀ઞ慦獬恥ਮ††⨠䀠硥浡汰††⨠ ††獩畎扭号㐮耀થ††⼯㴠‾牴敵 ††ਪ††⨠张椮乳浵敢⡲慎⥎号†耀બ 㸽琠畲††⨠ ††獩畎扭牥:sparkles:⸸✴㬩 †号⼯耀ળ慦獬††⨠ਯ††畦据楴湯椠乳浵敢⡲慶畬⥥笠 号爠耀祴数景瘠污敵㴠‽渧浵敢❲簠⁼椨佳橢捥䱴歩⡥慶号☠耀ુ呪卯牴湩慣汬瘨污敵 㴽渠浵敢呲条㬩 †素ਊ†号ਪ耀ૈ⨠䌠敨正晩怠慶畬恥椠汰楡扯敪瑣桴瑡椠号耀瑣挠敲瑡摥戠⁹桴††⨠怠扏敪瑣潣獮牴捵潴号敮耀孠偛潲潴祴数嵝景怠畮汬 ††ਪ††⨠⨠号㩥耀楨敭桴摯愠獳浵獥漠橢捥獴挠敲瑡摥戠⁹桴你橢号挠耀畲瑣牯 ††慨敶渠湩敨楲整湥浵牥扡敬瀠潲号敩耀૫††ਪ††⨠䀠瑳瑡捩 ††浀浥敢佲††⨠号整耀䰠湡੧††⨠䀠慰慲⩻⁽慶畬桔慶畬潴挠敨号†耀ૹ䀠敲畴湲扻潯敬湡⁽敒畴湲瑠畲恥椠癠污敵号瀠耀漠橢捥ⱴ攠獬晠污敳 ††敀慸灭敬 ††ਪ号⨠耀ଇ瑣潩潆⡯ ††⨠†琠楨‽㬱 †††号 耀獩汐楡佮橢捥⡴敮⁷潆⥯††⨠⼠ 㸽映污敳号†耀କ†⨠张椮偳慬湩扏敪瑣嬨ⰱ㈠崳㬩 ††⼯㴠‾号耀ଜ⨠ ††獩汐楡佮橢捥⡴⁻砧(Seq 1864)
02/18/16 18:46:25:071 | [WARN] | | OOBE | DE | | | | 5988 | DW063: Command ARKPatchCommand failed.(Seq 1864)
02/18/16 18:46:40:839 | [INFO] | | OOBE | DE | | | | 5988 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{27B8946D-664A-4877-A3C9-CE8249CA1D7A}.db
02/18/16 18:46:41:485 | [INFO] | | OOBE | DE | | | | 5988 | Physical payload uninstall result:0
02/18/16 18:46:41:487 | [INFO] | | OOBE | DE | | | | 4716 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:46:41:487 | [INFO] | | OOBE | DE | | | | 4716 | :: END TIMER :: [Payload Operation :{27B8946D-664A-4877-A3C9-CE8249CA1D7A}] took 262228 milliseconds (262.228 seconds) DTR = 13.4845 KBPS (0.0131684 MBPS)
02/18/16 18:46:42:080 | [INFO] | | OOBE | DE | | | | 4716 | User specified overrideFile:
02/18/16 18:46:42:705 | [INFO] | | OOBE | DE | | | | 4716 | Successfully updated the csu inventory for Adobe Preview CC_1.1.3_AdobePreview1.0All-win64 1.1.3.0 {27B8946D-664A-4877-A3C9-CE8249CA1D7A} return values 0:0
02/18/16 18:46:42:715 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for post-remove for payload Adobe Preview CC_1.1.3_AdobePreview1.0All-win64 1.1.3.0 {27B8946D-664A-4877-A3C9-CE8249CA1D7A}
02/18/16 18:46:42:752 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for pre-remove for payload Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}
02/18/16 18:46:42:768 | [INFO] | | OOBE | DE | | | | 4716 | ::START TIMER:: [Payload Operation :{A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}]
02/18/16 18:46:42:781 | [INFO] | | OOBE | DE | | | | 3824 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:46:42:781 | [INFO] | | OOBE | DE | | | | 3824 | Installer Operation: PayloadUninstaller
02/18/16 18:46:42:781 | [INFO] | | OOBE | DE | | | | 3824 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}
02/18/16 18:46:43:368 | [INFO] | | OOBE | DE | | | | 3824 | Effective AdobeCode for: {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3} is {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}
02/18/16 18:46:43:377 | [INFO] | | OOBE | DE | | | | 3824 | Uninstalling payload
02/18/16 18:46:43:390 | [INFO] | | OOBE | DE | | | | 3824 | Payload Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 18:46:43:453 | [INFO] | | OOBE | DE | | | | 3824 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}.db
02/18/16 18:49:47:823 | [INFO] | | OOBE | DE | | | | 3824 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}.db
02/18/16 18:49:50:726 | [INFO] | | OOBE | DE | | | | 3824 | Physical payload uninstall result:0
02/18/16 18:49:50:770 | [INFO] | | OOBE | DE | | | | 4716 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:49:50:770 | [INFO] | | OOBE | DE | | | | 4716 | :: END TIMER :: [Payload Operation :{A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}] took 187997 milliseconds (187.997 seconds) DTR = 182.982 KBPS (0.178693 MBPS)
02/18/16 18:49:51:110 | [INFO] | | OOBE | DE | | | | 4716 | User specified overrideFile:
02/18/16 18:49:51:344 | [INFO] | | OOBE | DE | | | | 4716 | Successfully updated the csu inventory for Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3} return values 0:0
02/18/16 18:49:51:354 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for post-remove for payload Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}
02/18/16 18:49:51:375 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for pre-remove for payload Adobe Photoshop CC 2015 Support_16.1.2_AdobePhotoshop16-Support 16.1.2.0 {4A117739-A3A4-4E1A-8F5A-82CB1958794F}
02/18/16 18:49:51:392 | [INFO] | | OOBE | DE | | | | 4716 | ::START TIMER:: [Payload Operation :{4A117739-A3A4-4E1A-8F5A-82CB1958794F}]
02/18/16 18:49:51:405 | [INFO] | | OOBE | DE | | | | 5756 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:49:51:405 | [INFO] | | OOBE | DE | | | | 5756 | Installer Operation: PayloadUninstaller
02/18/16 18:49:51:405 | [INFO] | | OOBE | DE | | | | 5756 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {4A117739-A3A4-4E1A-8F5A-82CB1958794F}
02/18/16 18:49:51:786 | [INFO] | | OOBE | DE | | | | 5756 | Effective AdobeCode for: {4A117739-A3A4-4E1A-8F5A-82CB1958794F} is {4A117739-A3A4-4E1A-8F5A-82CB1958794F}
02/18/16 18:49:51:795 | [INFO] | | OOBE | DE | | | | 5756 | Uninstalling payload
02/18/16 18:49:51:809 | [INFO] | | OOBE | DE | | | | 5756 | Payload Adobe Photoshop CC 2015 Support_16.1.2_AdobePhotoshop16-Support 16.1.2.0 {4A117739-A3A4-4E1A-8F5A-82CB1958794F}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 18:49:51:812 | [INFO] | | OOBE | DE | | | | 5756 | Setting file open option to false in the unzipper
02/18/16 18:49:52:208 | [INFO] | | OOBE | DE | | | | 5756 | CustomizedPatch property not found in database
02/18/16 18:49:52:209 | [INFO] | | OOBE | DE | | | | 5756 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{4A117739-A3A4-4E1A-8F5A-82CB1958794F}.db
02/18/16 18:49:52:829 | [INFO] | | OOBE | DE | | | | 5756 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{4A117739-A3A4-4E1A-8F5A-82CB1958794F}.db
02/18/16 18:49:52:832 | [INFO] | | OOBE | DE | | | | 5756 | Physical payload uninstall result:0
02/18/16 18:49:52:911 | [INFO] | | OOBE | DE | | | | 4716 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:49:52:911 | [INFO] | | OOBE | DE | | | | 4716 | :: END TIMER :: [Payload Operation :{4A117739-A3A4-4E1A-8F5A-82CB1958794F}] took 1519.3 milliseconds (1.5193 seconds) DTR = 336.997 KBPS (0.329098 MBPS)
02/18/16 18:49:53:408 | [INFO] | | OOBE | DE | | | | 4716 | User specified overrideFile:
02/18/16 18:50:02:054 | [INFO] | | OOBE | DE | | | | 4716 | Successfully updated the csu inventory for Adobe Photoshop CC 2015 Support_16.1.2_AdobePhotoshop16-Support 16.1.2.0 {4A117739-A3A4-4E1A-8F5A-82CB1958794F} return values 0:0
02/18/16 18:50:02:064 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for post-remove for payload Adobe Photoshop CC 2015 Support_16.1.2_AdobePhotoshop16-Support 16.1.2.0 {4A117739-A3A4-4E1A-8F5A-82CB1958794F}
02/18/16 18:50:02:101 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for pre-remove for payload Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}
02/18/16 18:50:02:116 | [INFO] | | OOBE | DE | | | | 4716 | ::START TIMER:: [Payload Operation :{3FB7A108-368A-4849-A3F3-69571BAAC457}]
02/18/16 18:50:02:130 | [INFO] | | OOBE | DE | | | | 6120 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:50:02:130 | [INFO] | | OOBE | DE | | | | 6120 | Installer Operation: PayloadUninstaller
02/18/16 18:50:02:130 | [INFO] | | OOBE | DE | | | | 6120 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {3FB7A108-368A-4849-A3F3-69571BAAC457}
02/18/16 18:50:02:329 | [INFO] | | OOBE | DE | | | | 6120 | Effective AdobeCode for: {3FB7A108-368A-4849-A3F3-69571BAAC457} is {3FB7A108-368A-4849-A3F3-69571BAAC457}
02/18/16 18:50:02:340 | [INFO] | | OOBE | DE | | | | 6120 | Uninstalling payload
02/18/16 18:50:02:353 | [INFO] | | OOBE | DE | | | | 6120 | Payload Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 18:50:02:424 | [INFO] | | OOBE | DE | | | | 6120 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{3FB7A108-368A-4849-A3F3-69571BAAC457}.db
02/18/16 18:50:06:840 | [INFO] | | OOBE | DE | | | | 6120 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{3FB7A108-368A-4849-A3F3-69571BAAC457}.db
02/18/16 18:50:07:000 | [INFO] | | OOBE | DE | | | | 6120 | Physical payload uninstall result:0
02/18/16 18:50:07:033 | [INFO] | | OOBE | DE | | | | 4716 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:50:07:033 | [INFO] | | OOBE | DE | | | | 4716 | :: END TIMER :: [Payload Operation :{3FB7A108-368A-4849-A3F3-69571BAAC457}] took 4916.82 milliseconds (4.91682 seconds) DTR = 1318.74 KBPS (1.28783 MBPS)
02/18/16 18:50:07:386 | [INFO] | | OOBE | DE | | | | 4716 | User specified overrideFile:
02/18/16 18:50:07:805 | [INFO] | | OOBE | DE | | | | 4716 | Successfully updated the csu inventory for Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457} return values 0:0
02/18/16 18:50:07:815 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for post-remove for payload Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}
02/18/16 18:50:07:863 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for pre-remove for payload Camera Profiles Installer_9.4_AdobeCameraRawProfile8.0All 9.4.0.0 {03B147C3-2412-4DE8-80F9-3EB977421EF2}
02/18/16 18:50:07:892 | [INFO] | | OOBE | DE | | | | 4716 | ::START TIMER:: [Payload Operation :{03B147C3-2412-4DE8-80F9-3EB977421EF2}]
02/18/16 18:50:07:905 | [INFO] | | OOBE | DE | | | | 6208 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:50:07:905 | [INFO] | | OOBE | DE | | | | 6208 | Installer Operation: PayloadUninstaller
02/18/16 18:50:07:905 | [INFO] | | OOBE | DE | | | | 6208 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {03B147C3-2412-4DE8-80F9-3EB977421EF2}
02/18/16 18:50:08:064 | [INFO] | | OOBE | DE | | | | 6208 | Effective AdobeCode for: {03B147C3-2412-4DE8-80F9-3EB977421EF2} is {03B147C3-2412-4DE8-80F9-3EB977421EF2}
02/18/16 18:50:08:073 | [INFO] | | OOBE | DE | | | | 6208 | Uninstalling payload
02/18/16 18:50:08:087 | [INFO] | | OOBE | DE | | | | 6208 | Payload Camera Profiles Installer_9.4_AdobeCameraRawProfile8.0All 9.4.0.0 {03B147C3-2412-4DE8-80F9-3EB977421EF2}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 18:50:08:121 | [INFO] | | OOBE | DE | | | | 6208 | Setting file open option to false in the unzipper
02/18/16 18:50:09:125 | [INFO] | | OOBE | DE | | | | 6208 | CustomizedPatch property not found in database
02/18/16 18:50:09:126 | [INFO] | | OOBE | DE | | | | 6208 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{03B147C3-2412-4DE8-80F9-3EB977421EF2}.db
02/18/16 18:51:50:461 | [INFO] | | OOBE | DE | | | | 6208 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{03B147C3-2412-4DE8-80F9-3EB977421EF2}.db
02/18/16 18:51:52:520 | [INFO] | | OOBE | DE | | | | 6208 | Physical payload uninstall result:0
02/18/16 18:51:52:602 | [INFO] | | OOBE | DE | | | | 4716 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:51:52:602 | [INFO] | | OOBE | DE | | | | 4716 | :: END TIMER :: [Payload Operation :{03B147C3-2412-4DE8-80F9-3EB977421EF2}] took 104707 milliseconds (104.707 seconds) DTR = 2014.08 KBPS (1.96687 MBPS)
02/18/16 18:51:53:161 | [INFO] | | OOBE | DE | | | | 4716 | User specified overrideFile:
02/18/16 18:51:53:458 | [INFO] | | OOBE | DE | | | | 4716 | Successfully updated the csu inventory for Camera Profiles Installer_9.4_AdobeCameraRawProfile8.0All 9.4.0.0 {03B147C3-2412-4DE8-80F9-3EB977421EF2} return values 0:0
02/18/16 18:51:53:468 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for post-remove for payload Camera Profiles Installer_9.4_AdobeCameraRawProfile8.0All 9.4.0.0 {03B147C3-2412-4DE8-80F9-3EB977421EF2}
02/18/16 18:51:53:514 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for pre-remove for payload Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}
02/18/16 18:51:53:700 | [INFO] | | OOBE | DE | | | | 4716 | ::START TIMER:: [Payload Operation :{56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}]
02/18/16 18:51:53:714 | [INFO] | | OOBE | DE | | | | 3988 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:51:53:714 | [INFO] | | OOBE | DE | | | | 3988 | Installer Operation: PayloadUninstaller
02/18/16 18:51:53:714 | [INFO] | | OOBE | DE | | | | 3988 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}
02/18/16 18:51:54:043 | [INFO] | | OOBE | DE | | | | 3988 | Effective AdobeCode for: {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10} is {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}
02/18/16 18:51:54:052 | [INFO] | | OOBE | DE | | | | 3988 | Uninstalling payload
02/18/16 18:51:54:065 | [INFO] | | OOBE | DE | | | | 3988 | Payload Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 18:51:54:122 | [INFO] | | OOBE | DE | | | | 3988 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}.db
02/18/16 18:53:44:323 | [INFO] | | OOBE | DE | | | | 3988 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}.db
02/18/16 18:53:47:610 | [INFO] | | OOBE | DE | | | | 3988 | Physical payload uninstall result:0
02/18/16 18:53:47:709 | [INFO] | | OOBE | DE | | | | 4716 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:53:47:709 | [INFO] | | OOBE | DE | | | | 4716 | :: END TIMER :: [Payload Operation :{56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}] took 114005 milliseconds (114.005 seconds) DTR = 3278.89 KBPS (3.20204 MBPS)
02/18/16 18:53:48:126 | [INFO] | | OOBE | DE | | | | 4716 | User specified overrideFile:
02/18/16 18:53:48:509 | [INFO] | | OOBE | DE | | | | 4716 | Successfully updated the csu inventory for Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10} return values 0:0
02/18/16 18:53:48:519 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for post-remove for payload Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}
02/18/16 18:53:48:560 | [INFO] | | OOBE | DE | | | | 4716 | Calling the custom action code for pre-remove for payload 9.0.0.61 CommonUninstall
02/18/16 18:53:48:574 | [INFO] | | OOBE | DE | | | | 4716 | ::START TIMER:: [Payload Operation :CommonUninstall]
02/18/16 18:53:48:644 | [INFO] | | OOBE | DE | | | | 4900 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:53:48:644 | [INFO] | | OOBE | DE | | | | 4900 | Installer Operation: PayloadUninstaller
02/18/16 18:53:48:644 | [INFO] | | OOBE | DE | | | | 4900 | Session {793C2BF7-A4FE-4608-91C9-9282C5801C21} modify request for AdobeCode: CommonUninstall
02/18/16 18:53:48:649 | [INFO] | | OOBE | DE | | | | 4900 | Effective AdobeCode for: CommonUninstall is CommonUninstall
02/18/16 18:53:48:660 | [INFO] | | OOBE | DE | | | | 4900 | Uninstalling payload
02/18/16 18:53:48:673 | [INFO] | | OOBE | DE | | | | 4900 | Payload 9.0.0.61 CommonUninstall: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 18:53:48:686 | [INFO] | | OOBE | DE | | | | 4900 | INSTALLDIR property not found in database
02/18/16 18:53:48:687 | [INFO] | | OOBE | DE | | | | 4900 | Beginning un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\CommonUninstall.db
02/18/16 18:53:48:688 | [INFO] | | OOBE | DE | | | | 4900 | UninstallSeq property not found in database
02/18/16 18:53:49:201 | [INFO] | | OOBE | DE | | | | 4900 | Completing un-installation for payload at C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\CommonUninstall.db
02/18/16 18:53:49:202 | [INFO] | | OOBE | DE | | | | 4900 | Physical payload uninstall result:0
02/18/16 18:53:49:244 | [INFO] | | OOBE | DE | | | | 4716 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:53:49:244 | [INFO] | | OOBE | DE | | | | 4716 | :: END TIMER :: [Payload Operation :CommonUninstall] took 669.661 milliseconds (0.669661 seconds) DTR = 107.517 KBPS (0.104997 MBPS)
02/18/16 18:53:49:250 | [INFO] | | OOBE | DE | | | | 4716 | User specified overrideFile:
02/18/16 18:53:49:259 | [INFO] | | OOBE | DE | | | | 4716 | The csu inventory was not updated for payload 9.0.0.61 CommonUninstall, value of local var is -1
02/18/16 18:53:49:260 | [INFO] | | OOBE | DE | | | | 4716 | Calling the ROLLBACK custom action code for pre-remove for payload 9.0.0.61 CommonUninstall
02/18/16 18:53:49:274 | [INFO] | | OOBE | DE | | | | 4716 | No operation. We're done:
02/18/16 18:53:49:277 | [INFO] | | OOBE | DE | | | | 4716 | Updating driver data - Action: Remove driver entry
02/18/16 18:53:49:295 | [INFO] | | OOBE | DE | | | | 4716 | Updating driver data successful. Driver entry was removed. ARP estimated size 41368KB
02/18/16 18:53:51:760 | [INFO] | | OOBE | DE | | | | 4716 | Total components installed: 0
02/18/16 18:53:51:760 | [INFO] | | OOBE | DE | | | | 4716 | Total components repaired: 0
02/18/16 18:53:51:760 | [INFO] | | OOBE | DE | | | | 4716 | Successfully removed 23 components:
02/18/16 18:53:51:760 | [INFO] | | OOBE | DE | | | | 4716 | - Camera Profiles Installer_9.4_AdobeCameraRawProfile8.0All
02/18/16 18:53:51:760 | [INFO] | | OOBE | DE | | | | 4716 | - Export Assets 2 (64 bit)
02/18/16 18:53:51:760 | [INFO] | | OOBE | DE | | | | 4716 | - Adobe Preview CC_1.1.3_AdobePreview1.0All-win64
02/18/16 18:53:51:760 | [INFO] | | OOBE | DE | | | | 4716 | - Export Assets 2 (64 bit)_2.4_AdobeExportAssets2.0All-x64
02/18/16 18:53:51:760 | [INFO] | | OOBE | DE | | | | 4716 | - Photoshop Camera Raw 8
02/18/16 18:53:51:760 | [INFO] | | OOBE | DE | | | | 4716 | - Adobe Photoshop CC 2015 Support
02/18/16 18:53:51:761 | [INFO] | | OOBE | DE | | | | 4716 | - Adobe Photoshop CC 2015 Support_16.1.2_AdobePhotoshop16-Support
02/18/16 18:53:51:761 | [INFO] | | OOBE | DE | | | | 4716 | - Microsoft Visual C++ 2013 Redistributable Package (x64)
02/18/16 18:53:51:761 | [INFO] | | OOBE | DE | | | | 4716 | - Camera Profiles Installer
02/18/16 18:53:51:761 | [INFO] | | OOBE | DE | | | | 4716 | - AdobeColorPhotoshop CC
02/18/16 18:53:51:761 | [INFO] | | OOBE | DE | | | | 4716 | - Photoshop Camera Raw 8 (64 bit)
02/18/16 18:53:51:761 | [INFO] | | OOBE | DE | | | | 4716 | - Microsoft Visual C++ 2013 Redistributable Package (x86)
02/18/16 18:53:51:761 | [INFO] | | OOBE | DE | | | | 4716 | - Adobe Photoshop CC 2015 Core
02/18/16 18:53:51:761 | [INFO] | | OOBE | DE | | | | 4716 | - Photoshop Camera Raw 8_9.4_AdobeCameraRaw8.0All
02/18/16 18:53:51:761 | [INFO] | | OOBE | DE | | | | 4716 | - AdobeColorJA CC
02/18/16 18:53:51:761 | [INFO] | | OOBE | DE | | | | 4716 | - Adobe Preview CC
02/18/16 18:53:51:761 | [INFO] | | OOBE | DE | | | | 4716 | - AdobeColorNA CC
02/18/16 18:53:51:761 | [INFO] | | OOBE | DE | | | | 4716 | - Photoshop Camera Raw 8 (64 bit)_9.4_AdobeCameraRaw8.0All-x64
02/18/16 18:53:51:761 | [INFO] | | OOBE | DE | | | | 4716 | - AdobeColorCommonSetCMYK CC
02/18/16 18:53:51:761 | [INFO] | | OOBE | DE | | | | 4716 | - AdobeColorCommonSetRGB CC
02/18/16 18:53:51:761 | [INFO] | | OOBE | DE | | | | 4716 | - AdobeColorVideoProfilesCS CC
02/18/16 18:53:51:761 | [INFO] | | OOBE | DE | | | | 4716 | - Adobe Photoshop CC 2015 Core_16.1.2_AdobePhotoshop16-Core_x64
02/18/16 18:53:51:761 | [INFO] | | OOBE | DE | | | | 4716 | - AdobeColorEU CC
02/18/16 18:53:51:766 | [INFO] | | OOBE | DE | | | | 4716 | Call PostSession Custom Hook
02/18/16 18:53:51:798 | [INFO] | | OOBE | DE | | | | 4716 | Begin cleaning up local media db.
02/18/16 18:53:56:844 | [INFO] | | OOBE | DE | | | | 4716 | Done cleaning up local media db.
02/18/16 18:53:56:845 | [INFO] | | OOBE | DE | | | | 4716 | :: END TIMER :: [Total Timer] took 1.84158e+006 milliseconds (1841.58 seconds) DTR = 1409.07 KBPS (1.37605 MBPS)
02/18/16 18:53:57:850 | [INFO] | | OOBE | DE | | | | 4716 | Exit Code: 0 - No error.
02/18/16 18:53:57:871 | [INFO] | | OOBE | DE | | | | 4716 | Please see specific errors for troubleshooting. For example, ERROR: DF022 ...
02/18/16 18:53:57:874 | [INFO] | | OOBE | DE | | | | 4716 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 18:53:57:874 | [INFO] | | OOBE | DE | | | | 4716 | END - Installer Session
02/18/16 22:56:02:184 | [INFO] | | OOBE | DE | | | | 6844 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 22:56:02:185 | [INFO] | | OOBE | DE | | | | 6844 | START - Installer Session
02/18/16 22:56:02:185 | [INFO] | | OOBE | DE | | | | 6844 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 22:56:02:185 | [INFO] | | OOBE | DE | | | | 6844 | RIBS version: 9.0.0.61
02/18/16 22:56:02:185 | [INFO] | | OOBE | DE | | | | 6844 | Win OS version: 6.1.0.0 64 bit Type: 1
02/18/16 22:56:02:185 | [INFO] | | OOBE | DE | | | | 6844 | ::START TIMER:: [Total Timer]
02/18/16 22:56:02:185 | [INFO] | | OOBE | DE | | | | 6844 | CHECK: Single instance running
02/18/16 22:56:02:185 | [INFO] | | OOBE | DE | | | | 6844 | CHECK : Credentials
02/18/16 22:56:02:185 | [INFO] | | OOBE | DE | | | | 6844 | Load Deployment File
02/18/16 22:56:02:185 | [INFO] | | OOBE | DE | | | | 6844 | CHECK : Another Native OS installer already running
02/18/16 22:56:02:185 | [INFO] | | OOBE | DE | | | | 6844 | Create Required Folders
02/18/16 22:56:02:185 | [INFO] | | OOBE | DE | | | | 6844 | Assuming install mode
02/18/16 22:56:02:185 | [INFO] | | OOBE | DE | | | | 6844 | Looking up install source path
02/18/16 22:56:02:185 | [INFO] | | OOBE | DE | | | | 6844 | Sync Media DB ...
02/18/16 22:56:02:185 | [INFO] | | OOBE | DE | | | | 6844 | ::START TIMER:: [Sync Media DB]
02/18/16 22:56:02:185 | [INFO] | | OOBE | DE | | | | 6844 | Pre check media db sync
02/18/16 22:56:02:185 | [INFO] | | OOBE | DE | | | | 6844 | End of Pre check media db sync. Exit code: 0
02/18/16 22:56:02:185 | [INFO] | | OOBE | DE | | | | 6844 | :: END TIMER :: [Sync Media DB] took 2512.46 milliseconds (2.51246 seconds) DTR = 1662.12 KBPS (1.62316 MBPS)
02/18/16 22:56:02:185 | [INFO] | | OOBE | DE | | | | 6844 | Ready to initialize session to start with ...
02/18/16 22:56:02:186 | [INFO] | | OOBE | DE | | | | 6844 | ::START TIMER:: [CreatePayloadSession]
02/18/16 22:56:02:186 | [INFO] | | OOBE | DE | | | | 6844 | -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
02/18/16 22:56:02:186 | [INFO] | | OOBE | DE | | | | 6844 | Updated source path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015
02/18/16 22:56:02:186 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {00F35A9A-C859-4F6E-8C4F-70A7239207FF}
02/18/16 22:56:02:186 | [INFO] | | OOBE | DE | | | | 6844 | Ignoring original data since install source is local
02/18/16 22:56:02:186 | [INFO] | | OOBE | DE | | | | 6844 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-nb_NO_x64\Install.db
02/18/16 22:56:02:186 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA}
02/18/16 22:56:02:187 | [INFO] | | OOBE | DE | | | | 6844 | Ignoring original data since install source is local
02/18/16 22:56:02:187 | [INFO] | | OOBE | DE | | | | 6844 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-uk_UA_x64\Install.db
02/18/16 22:56:02:187 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {0CA9067E-B7E0-4C7A-BA40-987AF967A05D}
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-en_IL_x64\Install.db
02/18/16 22:56:02:187 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {0D30F03E-27D9-41F8-AF26-9F1801C2AE28}
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-fr_MA_x64\Install.db
02/18/16 22:56:02:188 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {18844AF8-051C-4227-9BE1-CA06F4364F9C}
02/18/16 22:56:02:188 | [INFO] | | OOBE | DE | | | | 6844 | Ignoring original data since install source is local
02/18/16 22:56:02:188 | [INFO] | | OOBE | DE | | | | 6844 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-zh_TW_x64\Install.db
02/18/16 22:56:02:188 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {1B7AE611-4C93-47FC-951F-0BD9839AB72B}
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-sv_SE_x64\Install.db
02/18/16 22:56:02:188 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {2060E7ED-C473-4A38-877F-C844E81B64F3}
02/18/16 22:56:02:189 | [INFO] | | OOBE | DE | | | | 6844 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-nl_NL_x64\Install.db
02/18/16 22:56:02:189 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4}
02/18/16 22:56:02:189 | [INFO] | | OOBE | DE | | | | 6844 | Ignoring original data since install source is local
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-es_MX_x64\Install.db
02/18/16 22:56:02:189 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {27375F7C-0789-4FEA-889E-41BF12AC3140}
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeExportAssets2.0All-x64\Install.db
02/18/16 22:56:02:189 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {3875BF24-5D9A-494A-A4FA-7AC70F56EC88}
02/18/16 22:56:02:190 | [INFO] | | OOBE | DE | | | | 6844 | Ignoring original data since install source is local
02/18/16 22:56:02:190 | [INFO] | | OOBE | DE | | | | 6844 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-zh_CN_x64\Install.db
02/18/16 22:56:02:190 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {3E272A93-C06B-4206-AD02-0EBE02535E20}
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\Microsoft VC 2012 Redist (x64)\vcredist_x64.exe
02/18/16 22:56:02:190 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {3E7FC757-D497-4C89-A935-7D38E2164E85}
02/18/16 22:56:02:191 | [INFO] | | OOBE | DE | | | | 6844 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeCameraRaw8.0All\Install.db
02/18/16 22:56:02:191 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {3FB7A108-368A-4849-A3F3-69571BAAC457}
02/18/16 22:56:02:191 | [INFO] | | OOBE | DE | | | | 6844 | Ignoring original data since install source is local
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-Support\Install.db
02/18/16 22:56:02:191 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {4A0115A5-CA14-4EA1-9896-2F161B5144B9}
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-pt_BR_x64\Install.db
02/18/16 22:56:02:192 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}
02/18/16 22:56:02:192 | [INFO] | | OOBE | DE | | | | 6844 | Ignoring original data since install source is local
02/18/16 22:56:02:192 | [INFO] | | OOBE | DE | | | | 6844 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\Microsoft VC 2013 Redist (x64)\vcredist_x64.exe
02/18/16 22:56:02:192 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4}
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-en_GB_x64\Install.db
02/18/16 22:56:02:192 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {52D57F95-000A-4922-BB31-C6A936F4FD7D}
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorJA_Recommended5_0-mul\Install.db
02/18/16 22:56:02:193 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {5309436A-D12F-437D-B7A4-BF136E17139C}
02/18/16 22:56:02:193 | [INFO] | | OOBE | DE | | | | 6844 | Ignoring original data since install source is local
02/18/16 22:56:02:193 | [INFO] | | OOBE | DE | | | | 6844 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-ko_KR_x64\Install.db
02/18/16 22:56:02:193 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\Microsoft VC 2010 Redist (x64)\vcredist_x64.exe
02/18/16 22:56:02:194 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {55B82130-18F9-11E2-8D43-00215AEA26C9}
02/18/16 22:56:02:194 | [INFO] | | OOBE | DE | | | | 6844 | Ignoring original data since install source is local
02/18/16 22:56:02:194 | [INFO] | | OOBE | DE | | | | 6844 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\Microsoft VC 2010 Redist (x86)\vcredist_x86.exe
02/18/16 22:56:02:194 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeCameraRawProfile8.0All\Install.db
02/18/16 22:56:02:194 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {5C5D62C9-91C6-415E-857E-9130C0F52C66}
02/18/16 22:56:02:195 | [INFO] | | OOBE | DE | | | | 6844 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorPhotoshop5_0-mul\Install.db
02/18/16 22:56:02:195 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}
02/18/16 22:56:02:195 | [INFO] | | OOBE | DE | | | | 6844 | Ignoring original data since install source is local
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeCameraRaw8.0All-x64\Install.db
02/18/16 22:56:02:195 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {636D196A-789E-455D-825E-3FA79F67D446}
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\Microsoft VC 2013 Redist (x86)\vcredist_x86.exe
02/18/16 22:56:02:196 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {644DC0CB-E8C9-4508-B99D-8747C6172621}
02/18/16 22:56:02:196 | [INFO] | | OOBE | DE | | | | 6844 | Ignoring original data since install source is local
02/18/16 22:56:02:196 | [INFO] | | OOBE | DE | | | | 6844 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-es_ES_x64\Install.db
02/18/16 22:56:02:196 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {69C13F4A-83B3-42F4-912C-C99F1442F439}
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-de_DE_x64\Install.db
02/18/16 22:56:02:196 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {6E14FFAB-83F4-4CB7-87A2-703F6F20487A}
02/18/16 22:56:02:197 | [INFO] | | OOBE | DE | | | | 6844 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-ru_RU_x64\Install.db
02/18/16 22:56:02:197 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {6E7A3076-3056-492F-966F-1EA4FDCE5FA8}
02/18/16 22:56:02:197 | [INFO] | | OOBE | DE | | | | 6844 | Ignoring original data since install source is local
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-en_AE_x64\Install.db
02/18/16 22:56:02:197 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {72405B80-A3DD-4BB2-A8C4-A90BC7BA50FF}
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorNA_ExtraSettings5_0-mul\Install.db
02/18/16 22:56:02:197 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {7433F860-160E-4024-8218-892D796972A6}
02/18/16 22:56:02:198 | [INFO] | | OOBE | DE | | | | 6844 | Ignoring original data since install source is local
02/18/16 22:56:02:198 | [INFO] | | OOBE | DE | | | | 6844 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-fr_CA_x64\Install.db
02/18/16 22:56:02:198 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {7787331E-D646-4CA4-ADCB-B264CC156D7D}
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-cs_CZ_x64\Install.db
02/18/16 22:56:02:198 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {778CE554-471C-4605-A600-852C976A4DC5}
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-ja_JP_x64\Install.db
02/18/16 22:56:02:198 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 22:56:02:199 | [INFO] | | OOBE | DE | | | | 6844 | Ignoring original data since install source is local
02/18/16 22:56:02:199 | [INFO] | | OOBE | DE | | | | 6844 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-Core_x64\Install.db
02/18/16 22:56:02:199 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {873BE68F-480F-49A6-9649-F98CAB056AFC}
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\Microsoft VC 2012 Redist (x86)\vcredist_x86.exe
02/18/16 22:56:02:199 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0}
02/18/16 22:56:02:200 | [INFO] | | OOBE | DE | | | | 6844 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-pl_PL_x64\Install.db
02/18/16 22:56:02:200 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {960F21E4-EBDC-4A3E-80E9-C28D8A593F66}
02/18/16 22:56:02:200 | [INFO] | | OOBE | DE | | | | 6844 | Ignoring original data since install source is local
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-it_IT_x64\Install.db
02/18/16 22:56:02:200 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {98D6FC60-7908-474A-A598-0D7A7BFEF2C2}
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-hu_HU_x64\Install.db
02/18/16 22:56:02:200 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {9E9EB9FD-FDE8-487A-A41C-7713DA91AC89}
02/18/16 22:56:02:201 | [INFO] | | OOBE | DE | | | | 6844 | Ignoring original data since install source is local
02/18/16 22:56:02:201 | [INFO] | | OOBE | DE | | | | 6844 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorEU_Recommended5_0-mul\Install.db
02/18/16 22:56:02:201 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorJA_ExtraSettings5_0-mul\Install.db
02/18/16 22:56:02:201 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePreview1.0All-win64\Install.db
02/18/16 22:56:02:201 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}
02/18/16 22:56:02:202 | [INFO] | | OOBE | DE | | | | 6844 | Ignoring original data since install source is local
02/18/16 22:56:02:202 | [INFO] | | OOBE | DE | | | | 6844 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorNA_Recommended5_0-mul\Install.db
02/18/16 22:56:02:202 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {B75FB41B-E3E2-4B9F-93F7-62D982857374}
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-fr_FR_x64\Install.db
02/18/16 22:56:02:202 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {BED85F42-B42C-4A91-946B-A928824C48A1}
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-tr_TR_x64\Install.db
02/18/16 22:56:02:203 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {C4196275-B11A-40A1-8727-3C145C8F7D95}
02/18/16 22:56:02:203 | [INFO] | | OOBE | DE | | | | 6844 | Ignoring original data since install source is local
02/18/16 22:56:02:203 | [INFO] | | OOBE | DE | | | | 6844 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorCommonSetCMYK5_0-mul\Install.db
02/18/16 22:56:02:203 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {C43757D2-2F7F-41B4-9764-0FD8318DD860}
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-en_US_x64\Install.db
02/18/16 22:56:02:203 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorCommonSetRGB5_0-mul\Install.db
02/18/16 22:56:02:204 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {CE9B1B00-0421-4701-9698-1C14646D6D94}
02/18/16 22:56:02:204 | [INFO] | | OOBE | DE | | | | 6844 | Ignoring original data since install source is local
02/18/16 22:56:02:204 | [INFO] | | OOBE | DE | | | | 6844 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeVideoProfilesCS5_0-mul\Install.db
02/18/16 22:56:02:204 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {F5D14B6C-DA16-4031-9EB8-AF0728550AFC}
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-da_DK_x64\Install.db
02/18/16 22:56:02:204 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {F6DED2DA-1D20-497E-8810-E745B45DCD28}
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorEU_ExtraSettings5_0-mul\Install.db
02/18/16 22:56:02:205 | [INFO] | | OOBE | DE | | | | 6844 | Updating media info for: {FD8B8694-1044-4481-A5D9-4740A46BBC3B}
02/18/16 22:56:02:205 | [INFO] | | OOBE | DE | | | | 6844 | Ignoring original data since install source is local
02/18/16 22:56:02:205 | [INFO] | | OOBE | DE | | | | 6844 | Type: 0, Volume Order: 1, Media Name: Photoshop CC 2015_x64
Path: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-fi_FI_x64\Install.db
02/18/16 22:56:02:205 | [INFO] | | OOBE | DE | | | | 6844 | -------------------- END - Updating Media Sources - END --------------------
02/18/16 22:56:02:352 | [INFO] | | OOBE | DE | | | | 6844 | Supported RIBS version range: [0.0.0.0,9.0.0.61]
02/18/16 22:56:02:353 | [INFO] | | OOBE | DE | | | | 6844 | ----------------- CreatePayloadSession: machine is x64 ---------------
02/18/16 22:56:02:427 | [INFO] | | OOBE | DE | | | | 6844 | ______ Verify Dependency Subscribers ______
02/18/16 22:56:02:430 | [INFO] | | OOBE | DE | | | | 6844 | BEGIN Operation order for all session payloads: mediaGroup (requires,satisfies)
02/18/16 22:56:02:430 | [INFO] | | OOBE | DE | | | | 6844 | Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}: 1 (0,2)
02/18/16 22:56:02:430 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}: 2 (0,1)
02/18/16 22:56:02:430 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}: 2 (0,1)
02/18/16 22:56:02:430 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}: 2 (0,1)
02/18/16 22:56:02:430 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}: 2 (0,1)
02/18/16 22:56:02:430 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorEU CC 5.0.0.0 {9E9EB9FD-FDE8-487A-A41C-7713DA91AC89}: 2 (0,1)
02/18/16 22:56:02:430 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}: 2 (0,1)
02/18/16 22:56:02:430 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorJA CC 5.0.0.0 {52D57F95-000A-4922-BB31-C6A936F4FD7D}: 2 (0,1)
02/18/16 22:56:02:430 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}: 2 (0,1)
02/18/16 22:56:02:430 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorNA CC 5.0.0.0 {72405B80-A3DD-4BB2-A8C4-A90BC7BA50FF}: 2 (0,1)
02/18/16 22:56:02:430 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}: 2 (0,1)
02/18/16 22:56:02:430 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}: 2 (0,1)
02/18/16 22:56:02:430 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}: 2 (0,1)
02/18/16 22:56:02:430 | [INFO] | | OOBE | DE | | | | 6844 | Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}: 2 (0,1)
02/18/16 22:56:02:430 | [INFO] | | OOBE | DE | | | | 6844 | Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}: 2 (0,1)
02/18/16 22:56:02:430 | [INFO] | | OOBE | DE | | | | 6844 | Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9}: 2 (0,1)
02/18/16 22:56:02:430 | [INFO] | | OOBE | DE | | | | 6844 | Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20}: 2 (0,1)
02/18/16 22:56:02:430 | [INFO] | | OOBE | DE | | | | 6844 | Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC}: 2 (0,1)
02/18/16 22:56:02:431 | [INFO] | | OOBE | DE | | | | 6844 | Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}: 2 (0,1)
02/18/16 22:56:02:431 | [INFO] | | OOBE | DE | | | | 6844 | Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}: 2 (0,1)
02/18/16 22:56:02:431 | [INFO] | | OOBE | DE | | | | 6844 | Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}: 2 (0,1)
02/18/16 22:56:02:431 | [INFO] | | OOBE | DE | | | | 6844 | Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}: 3 (1,1)
02/18/16 22:56:02:431 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}: 4 (22,0)
02/18/16 22:56:02:431 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Korean Language Pack_AdobePhotoshop16-ko_KR_x64 16.0.0.0 {5309436A-D12F-437D-B7A4-BF136E17139C}: 5 (0,0)
02/18/16 22:56:02:431 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Spanish Language Pack_AdobePhotoshop16-es_ES_x64 16.0.0.0 {644DC0CB-E8C9-4508-B99D-8747C6172621}: 5 (0,0)
02/18/16 22:56:02:431 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Norwegian Language Pack_AdobePhotoshop16-nb_NO_x64 16.0.0.0 {00F35A9A-C859-4F6E-8C4F-70A7239207FF}: 5 (0,0)
02/18/16 22:56:02:431 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Russian Language Pack_AdobePhotoshop16-ru_RU_x64 16.0.0.0 {6E14FFAB-83F4-4CB7-87A2-703F6F20487A}: 5 (0,0)
02/18/16 22:56:02:431 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 AE English Language Pack_AdobePhotoshop16-en_AE_x64 16.0.0.0 {6E7A3076-3056-492F-966F-1EA4FDCE5FA8}: 5 (0,0)
02/18/16 22:56:02:431 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Ukrainian Language Pack_AdobePhotoshop16-uk_UA_x64 16.0.0.0 {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA}: 5 (0,0)
02/18/16 22:56:02:431 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Canadian French Language Pack_AdobePhotoshop16-fr_CA_x64 16.0.0.0 {7433F860-160E-4024-8218-892D796972A6}: 5 (0,0)
02/18/16 22:56:02:431 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Czech Language Pack_AdobePhotoshop16-cs_CZ_x64 16.0.0.0 {7787331E-D646-4CA4-ADCB-B264CC156D7D}: 5 (0,0)
02/18/16 22:56:02:431 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Japanese Language Pack_AdobePhotoshop16-ja_JP_x64 16.0.0.0 {778CE554-471C-4605-A600-852C976A4DC5}: 5 (0,0)
02/18/16 22:56:02:431 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 IL English Language Pack_AdobePhotoshop16-en_IL_x64 16.0.0.0 {0CA9067E-B7E0-4C7A-BA40-987AF967A05D}: 5 (0,0)
02/18/16 22:56:02:431 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 MA French Language Pack_AdobePhotoshop16-fr_MA_x64 16.0.0.0 {0D30F03E-27D9-41F8-AF26-9F1801C2AE28}: 5 (0,0)
02/18/16 22:56:02:431 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Polish Language Pack_AdobePhotoshop16-pl_PL_x64 16.0.0.0 {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0}: 5 (0,0)
02/18/16 22:56:02:431 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Italian Language Pack_AdobePhotoshop16-it_IT_x64 16.0.0.0 {960F21E4-EBDC-4A3E-80E9-C28D8A593F66}: 5 (0,0)
02/18/16 22:56:02:431 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Hungarian Language Pack_AdobePhotoshop16-hu_HU_x64 16.0.0.0 {98D6FC60-7908-474A-A598-0D7A7BFEF2C2}: 5 (0,0)
02/18/16 22:56:02:431 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Chinese (traditional) Language Pack_AdobePhotoshop16-zh_TW_x64 16.0.0.0 {18844AF8-051C-4227-9BE1-CA06F4364F9C}: 5 (0,0)
02/18/16 22:56:02:431 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Swedish Language Pack_AdobePhotoshop16-sv_SE_x64 16.0.0.0 {1B7AE611-4C93-47FC-951F-0BD9839AB72B}: 5 (0,0)
02/18/16 22:56:02:431 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 North American Spanish Language Pack_AdobePhotoshop16-es_MX_x64 16.0.0.0 {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4}: 5 (0,0)
02/18/16 22:56:02:432 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Chinese Language Pack_AdobePhotoshop16-zh_CN_x64 16.0.0.0 {3875BF24-5D9A-494A-A4FA-7AC70F56EC88}: 5 (0,0)
02/18/16 22:56:02:432 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 French Language Pack_AdobePhotoshop16-fr_FR_x64 16.0.0.0 {B75FB41B-E3E2-4B9F-93F7-62D982857374}: 5 (0,0)
02/18/16 22:56:02:432 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Turkish Language Pack_AdobePhotoshop16-tr_TR_x64 16.0.0.0 {BED85F42-B42C-4A91-946B-A928824C48A1}: 5 (0,0)
02/18/16 22:56:02:432 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 German Language Pack_AdobePhotoshop16-de_DE_x64 16.0.0.0 {69C13F4A-83B3-42F4-912C-C99F1442F439}: 5 (0,0)
02/18/16 22:56:02:432 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860}: 5 (0,0)
02/18/16 22:56:02:432 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Dutch Language Pack_AdobePhotoshop16-nl_NL_x64 16.0.0.0 {2060E7ED-C473-4A38-877F-C844E81B64F3}: 5 (0,0)
02/18/16 22:56:02:432 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Brazilian Portugese Language Pack_AdobePhotoshop16-pt_BR_x64 16.0.0.0 {4A0115A5-CA14-4EA1-9896-2F161B5144B9}: 5 (0,0)
02/18/16 22:56:02:432 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Danish Language Pack_AdobePhotoshop16-da_DK_x64 16.0.0.0 {F5D14B6C-DA16-4031-9EB8-AF0728550AFC}: 5 (0,0)
02/18/16 22:56:02:432 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 International English Language Pack_AdobePhotoshop16-en_GB_x64 16.0.0.0 {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4}: 5 (0,0)
02/18/16 22:56:02:432 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Finnish Language Pack_AdobePhotoshop16-fi_FI_x64 16.0.0.0 {FD8B8694-1044-4481-A5D9-4740A46BBC3B}: 5 (0,0)
02/18/16 22:56:02:432 | [INFO] | | OOBE | DE | | | | 6844 | END Operation order for all session payloads: mediaGroup (requires,satisfies)
02/18/16 22:56:03:109 | [INFO] | | OOBE | DE | | | | 6844 | Setting property "analyticsFilePath" to: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\{229E45D8-5E8F-49A2-87DA-D0EFB211F7A8}
02/18/16 22:56:03:109 | [INFO] | | OOBE | DE | | | | 6844 | Setting property "conflictingProcessInfo" to: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\{D9812A0A-CA28-4A79-BE41-5067739F7192}
02/18/16 22:56:03:109 | [INFO] | | OOBE | DE | | | | 6844 | Setting property "deploymentFile" to: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\{983C8C43-C1B8-4C9B-ABCD-394DAB089214}
02/18/16 22:56:03:109 | [INFO] | | OOBE | DE | | | | 6844 | Setting property "installLanguage" to: en_US
02/18/16 22:56:03:109 | [INFO] | | OOBE | DE | | | | 6844 | Attempting to find the selected language in the set of available payload languages
02/18/16 22:56:03:109 | [INFO] | | OOBE | DE | | | | 6844 | Setting property "installSourcePath" to: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015
02/18/16 22:56:03:109 | [INFO] | | OOBE | DE | | | | 6844 | Setting property "prefMigration" to: FALSE
02/18/16 22:56:03:110 | [INFO] | | OOBE | DE | | | | 6844 | Setting property "skipSync" to: 1
02/18/16 22:56:03:110 | [INFO] | | OOBE | DE | | | | 6844 | Setting property "userASUPath" to:
02/18/16 22:56:03:110 | [INFO] | | OOBE | DE | | | | 6844 | Overwrite property "analyticsFilePath" to: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\{229E45D8-5E8F-49A2-87DA-D0EFB211F7A8}
02/18/16 22:56:03:110 | [INFO] | | OOBE | DE | | | | 6844 | Overwrite property "conflictingProcessInfo" to: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\{D9812A0A-CA28-4A79-BE41-5067739F7192}
02/18/16 22:56:03:110 | [INFO] | | OOBE | DE | | | | 6844 | Overwrite property "installLanguage" to: en_US
02/18/16 22:56:03:110 | [INFO] | | OOBE | DE | | | | 6844 | Overwrite property "prefMigration" to: FALSE
02/18/16 22:56:03:110 | [INFO] | | OOBE | DE | | | | 6844 | Overwrite property "skipSync" to: 1
02/18/16 22:56:03:110 | [INFO] | | OOBE | DE | | | | 6844 | Overwrite property "userASUPath" to:
02/18/16 22:56:03:110 | [INFO] | | OOBE | DE | | | | 6844 | Found payload actions:
02/18/16 22:56:03:110 | [INFO] | | OOBE | DE | | | | 6844 | Deciding what installer mode to use...
02/18/16 22:56:03:161 | [INFO] | | OOBE | DE | | | | 6844 | BEGIN Setting requested payload actions
02/18/16 22:56:03:164 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10} is: false
02/18/16 22:56:03:164 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10} is none
02/18/16 22:56:03:164 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457} is: false
02/18/16 22:56:03:164 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457} is none
02/18/16 22:56:03:164 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3} is: false
02/18/16 22:56:03:164 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3} is none
02/18/16 22:56:03:164 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95} is: false
02/18/16 22:56:03:164 | [INFO] | | OOBE | DE | | | | 6844 | Action string for AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95} is none
02/18/16 22:56:03:164 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC} is: false
02/18/16 22:56:03:164 | [INFO] | | OOBE | DE | | | | 6844 | Action string for AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC} is none
02/18/16 22:56:03:164 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: AdobeColorEU CC 5.0.0.0 {9E9EB9FD-FDE8-487A-A41C-7713DA91AC89} is: false
02/18/16 22:56:03:164 | [INFO] | | OOBE | DE | | | | 6844 | Action string for AdobeColorEU CC 5.0.0.0 {9E9EB9FD-FDE8-487A-A41C-7713DA91AC89} is none
02/18/16 22:56:03:164 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28} is: false
02/18/16 22:56:03:165 | [INFO] | | OOBE | DE | | | | 6844 | Action string for AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28} is none
02/18/16 22:56:03:165 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: AdobeColorJA CC 5.0.0.0 {52D57F95-000A-4922-BB31-C6A936F4FD7D} is: false
02/18/16 22:56:03:165 | [INFO] | | OOBE | DE | | | | 6844 | Action string for AdobeColorJA CC 5.0.0.0 {52D57F95-000A-4922-BB31-C6A936F4FD7D} is none
02/18/16 22:56:03:165 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB} is: false
02/18/16 22:56:03:165 | [INFO] | | OOBE | DE | | | | 6844 | Action string for AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB} is none
02/18/16 22:56:03:165 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: AdobeColorNA CC 5.0.0.0 {72405B80-A3DD-4BB2-A8C4-A90BC7BA50FF} is: false
02/18/16 22:56:03:165 | [INFO] | | OOBE | DE | | | | 6844 | Action string for AdobeColorNA CC 5.0.0.0 {72405B80-A3DD-4BB2-A8C4-A90BC7BA50FF} is none
02/18/16 22:56:03:165 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44} is: false
02/18/16 22:56:03:165 | [INFO] | | OOBE | DE | | | | 6844 | Action string for AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44} is none
02/18/16 22:56:03:165 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66} is: false
02/18/16 22:56:03:165 | [INFO] | | OOBE | DE | | | | 6844 | Action string for AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66} is none
02/18/16 22:56:03:165 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94} is: false
02/18/16 22:56:03:165 | [INFO] | | OOBE | DE | | | | 6844 | Action string for AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94} is none
02/18/16 22:56:03:165 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140} is: false
02/18/16 22:56:03:165 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140} is none
02/18/16 22:56:03:165 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9} is: true
02/18/16 22:56:03:165 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9} is none
02/18/16 22:56:03:165 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9} is: true
02/18/16 22:56:03:165 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9} is none
02/18/16 22:56:03:165 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20} is: true
02/18/16 22:56:03:165 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20} is none
02/18/16 22:56:03:166 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC} is: true
02/18/16 22:56:03:166 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC} is none
02/18/16 22:56:03:166 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613} is: false
02/18/16 22:56:03:166 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613} is none
02/18/16 22:56:03:166 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446} is: false
02/18/16 22:56:03:166 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446} is none
02/18/16 22:56:03:166 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA} is: false
02/18/16 22:56:03:166 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA} is none
02/18/16 22:56:03:166 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85} is: false
02/18/16 22:56:03:166 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85} is none
02/18/16 22:56:03:166 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21} is: false
02/18/16 22:56:03:166 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21} is install
02/18/16 22:56:03:166 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Korean Language Pack_AdobePhotoshop16-ko_KR_x64 16.0.0.0 {5309436A-D12F-437D-B7A4-BF136E17139C} is: false
02/18/16 22:56:03:166 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Adobe Photoshop CC 2015 Korean Language Pack_AdobePhotoshop16-ko_KR_x64 16.0.0.0 {5309436A-D12F-437D-B7A4-BF136E17139C} is none
02/18/16 22:56:03:166 | [INFO] | | OOBE | DE | | | | 6844 | Payload Adobe Photoshop CC 2015 Korean Language Pack_AdobePhotoshop16-ko_KR_x64 16.0.0.0 {5309436A-D12F-437D-B7A4-BF136E17139C} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 22:56:03:166 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Spanish Language Pack_AdobePhotoshop16-es_ES_x64 16.0.0.0 {644DC0CB-E8C9-4508-B99D-8747C6172621} is: false
02/18/16 22:56:03:166 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Adobe Photoshop CC 2015 Spanish Language Pack_AdobePhotoshop16-es_ES_x64 16.0.0.0 {644DC0CB-E8C9-4508-B99D-8747C6172621} is none
02/18/16 22:56:03:166 | [INFO] | | OOBE | DE | | | | 6844 | Payload Adobe Photoshop CC 2015 Spanish Language Pack_AdobePhotoshop16-es_ES_x64 16.0.0.0 {644DC0CB-E8C9-4508-B99D-8747C6172621} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 22:56:03:167 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Norwegian Language Pack_AdobePhotoshop16-nb_NO_x64 16.0.0.0 {00F35A9A-C859-4F6E-8C4F-70A7239207FF} is: false
02/18/16 22:56:03:167 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Adobe Photoshop CC 2015 Norwegian Language Pack_AdobePhotoshop16-nb_NO_x64 16.0.0.0 {00F35A9A-C859-4F6E-8C4F-70A7239207FF} is none
02/18/16 22:56:03:167 | [INFO] | | OOBE | DE | | | | 6844 | Payload Adobe Photoshop CC 2015 Norwegian Language Pack_AdobePhotoshop16-nb_NO_x64 16.0.0.0 {00F35A9A-C859-4F6E-8C4F-70A7239207FF} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 22:56:03:167 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Russian Language Pack_AdobePhotoshop16-ru_RU_x64 16.0.0.0 {6E14FFAB-83F4-4CB7-87A2-703F6F20487A} is: false
02/18/16 22:56:03:167 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Adobe Photoshop CC 2015 Russian Language Pack_AdobePhotoshop16-ru_RU_x64 16.0.0.0 {6E14FFAB-83F4-4CB7-87A2-703F6F20487A} is none
02/18/16 22:56:03:167 | [INFO] | | OOBE | DE | | | | 6844 | Payload Adobe Photoshop CC 2015 Russian Language Pack_AdobePhotoshop16-ru_RU_x64 16.0.0.0 {6E14FFAB-83F4-4CB7-87A2-703F6F20487A} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 22:56:03:167 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Adobe Photoshop CC 2015 AE English Language Pack_AdobePhotoshop16-en_AE_x64 16.0.0.0 {6E7A3076-3056-492F-966F-1EA4FDCE5FA8} is: false
02/18/16 22:56:03:167 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Adobe Photoshop CC 2015 AE English Language Pack_AdobePhotoshop16-en_AE_x64 16.0.0.0 {6E7A3076-3056-492F-966F-1EA4FDCE5FA8} is none
02/18/16 22:56:03:167 | [INFO] | | OOBE | DE | | | | 6844 | Payload Adobe Photoshop CC 2015 AE English Language Pack_AdobePhotoshop16-en_AE_x64 16.0.0.0 {6E7A3076-3056-492F-966F-1EA4FDCE5FA8} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 22:56:03:167 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Ukrainian Language Pack_AdobePhotoshop16-uk_UA_x64 16.0.0.0 {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA} is: false
02/18/16 22:56:03:167 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Adobe Photoshop CC 2015 Ukrainian Language Pack_AdobePhotoshop16-uk_UA_x64 16.0.0.0 {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA} is none
02/18/16 22:56:03:167 | [INFO] | | OOBE | DE | | | | 6844 | Payload Adobe Photoshop CC 2015 Ukrainian Language Pack_AdobePhotoshop16-uk_UA_x64 16.0.0.0 {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 22:56:03:167 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Canadian French Language Pack_AdobePhotoshop16-fr_CA_x64 16.0.0.0 {7433F860-160E-4024-8218-892D796972A6} is: false
02/18/16 22:56:03:167 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Adobe Photoshop CC 2015 Canadian French Language Pack_AdobePhotoshop16-fr_CA_x64 16.0.0.0 {7433F860-160E-4024-8218-892D796972A6} is none
02/18/16 22:56:03:167 | [INFO] | | OOBE | DE | | | | 6844 | Payload Adobe Photoshop CC 2015 Canadian French Language Pack_AdobePhotoshop16-fr_CA_x64 16.0.0.0 {7433F860-160E-4024-8218-892D796972A6} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 22:56:03:167 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Czech Language Pack_AdobePhotoshop16-cs_CZ_x64 16.0.0.0 {7787331E-D646-4CA4-ADCB-B264CC156D7D} is: false
02/18/16 22:56:03:167 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Adobe Photoshop CC 2015 Czech Language Pack_AdobePhotoshop16-cs_CZ_x64 16.0.0.0 {7787331E-D646-4CA4-ADCB-B264CC156D7D} is none
02/18/16 22:56:03:167 | [INFO] | | OOBE | DE | | | | 6844 | Payload Adobe Photoshop CC 2015 Czech Language Pack_AdobePhotoshop16-cs_CZ_x64 16.0.0.0 {7787331E-D646-4CA4-ADCB-B264CC156D7D} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 22:56:03:167 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Japanese Language Pack_AdobePhotoshop16-ja_JP_x64 16.0.0.0 {778CE554-471C-4605-A600-852C976A4DC5} is: false
02/18/16 22:56:03:167 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Adobe Photoshop CC 2015 Japanese Language Pack_AdobePhotoshop16-ja_JP_x64 16.0.0.0 {778CE554-471C-4605-A600-852C976A4DC5} is none
02/18/16 22:56:03:168 | [INFO] | | OOBE | DE | | | | 6844 | Payload Adobe Photoshop CC 2015 Japanese Language Pack_AdobePhotoshop16-ja_JP_x64 16.0.0.0 {778CE554-471C-4605-A600-852C976A4DC5} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 22:56:03:168 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Adobe Photoshop CC 2015 IL English Language Pack_AdobePhotoshop16-en_IL_x64 16.0.0.0 {0CA9067E-B7E0-4C7A-BA40-987AF967A05D} is: false
02/18/16 22:56:03:168 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Adobe Photoshop CC 2015 IL English Language Pack_AdobePhotoshop16-en_IL_x64 16.0.0.0 {0CA9067E-B7E0-4C7A-BA40-987AF967A05D} is none
02/18/16 22:56:03:168 | [INFO] | | OOBE | DE | | | | 6844 | Payload Adobe Photoshop CC 2015 IL English Language Pack_AdobePhotoshop16-en_IL_x64 16.0.0.0 {0CA9067E-B7E0-4C7A-BA40-987AF967A05D} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 22:56:03:168 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Adobe Photoshop CC 2015 MA French Language Pack_AdobePhotoshop16-fr_MA_x64 16.0.0.0 {0D30F03E-27D9-41F8-AF26-9F1801C2AE28} is: false
02/18/16 22:56:03:168 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Adobe Photoshop CC 2015 MA French Language Pack_AdobePhotoshop16-fr_MA_x64 16.0.0.0 {0D30F03E-27D9-41F8-AF26-9F1801C2AE28} is none
02/18/16 22:56:03:168 | [INFO] | | OOBE | DE | | | | 6844 | Payload Adobe Photoshop CC 2015 MA French Language Pack_AdobePhotoshop16-fr_MA_x64 16.0.0.0 {0D30F03E-27D9-41F8-AF26-9F1801C2AE28} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 22:56:03:168 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Polish Language Pack_AdobePhotoshop16-pl_PL_x64 16.0.0.0 {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0} is: false
02/18/16 22:56:03:168 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Adobe Photoshop CC 2015 Polish Language Pack_AdobePhotoshop16-pl_PL_x64 16.0.0.0 {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0} is none
02/18/16 22:56:03:168 | [INFO] | | OOBE | DE | | | | 6844 | Payload Adobe Photoshop CC 2015 Polish Language Pack_AdobePhotoshop16-pl_PL_x64 16.0.0.0 {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 22:56:03:168 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Italian Language Pack_AdobePhotoshop16-it_IT_x64 16.0.0.0 {960F21E4-EBDC-4A3E-80E9-C28D8A593F66} is: false
02/18/16 22:56:03:168 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Adobe Photoshop CC 2015 Italian Language Pack_AdobePhotoshop16-it_IT_x64 16.0.0.0 {960F21E4-EBDC-4A3E-80E9-C28D8A593F66} is none
02/18/16 22:56:03:168 | [INFO] | | OOBE | DE | | | | 6844 | Payload Adobe Photoshop CC 2015 Italian Language Pack_AdobePhotoshop16-it_IT_x64 16.0.0.0 {960F21E4-EBDC-4A3E-80E9-C28D8A593F66} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 22:56:03:168 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Hungarian Language Pack_AdobePhotoshop16-hu_HU_x64 16.0.0.0 {98D6FC60-7908-474A-A598-0D7A7BFEF2C2} is: false
02/18/16 22:56:03:168 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Adobe Photoshop CC 2015 Hungarian Language Pack_AdobePhotoshop16-hu_HU_x64 16.0.0.0 {98D6FC60-7908-474A-A598-0D7A7BFEF2C2} is none
02/18/16 22:56:03:168 | [INFO] | | OOBE | DE | | | | 6844 | Payload Adobe Photoshop CC 2015 Hungarian Language Pack_AdobePhotoshop16-hu_HU_x64 16.0.0.0 {98D6FC60-7908-474A-A598-0D7A7BFEF2C2} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 22:56:03:168 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Chinese (traditional) Language Pack_AdobePhotoshop16-zh_TW_x64 16.0.0.0 {18844AF8-051C-4227-9BE1-CA06F4364F9C} is: false
02/18/16 22:56:03:168 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Adobe Photoshop CC 2015 Chinese (traditional) Language Pack_AdobePhotoshop16-zh_TW_x64 16.0.0.0 {18844AF8-051C-4227-9BE1-CA06F4364F9C} is none
02/18/16 22:56:03:168 | [INFO] | | OOBE | DE | | | | 6844 | Payload Adobe Photoshop CC 2015 Chinese (traditional) Language Pack_AdobePhotoshop16-zh_TW_x64 16.0.0.0 {18844AF8-051C-4227-9BE1-CA06F4364F9C} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 22:56:03:168 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Swedish Language Pack_AdobePhotoshop16-sv_SE_x64 16.0.0.0 {1B7AE611-4C93-47FC-951F-0BD9839AB72B} is: false
02/18/16 22:56:03:169 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Adobe Photoshop CC 2015 Swedish Language Pack_AdobePhotoshop16-sv_SE_x64 16.0.0.0 {1B7AE611-4C93-47FC-951F-0BD9839AB72B} is none
02/18/16 22:56:03:169 | [INFO] | | OOBE | DE | | | | 6844 | Payload Adobe Photoshop CC 2015 Swedish Language Pack_AdobePhotoshop16-sv_SE_x64 16.0.0.0 {1B7AE611-4C93-47FC-951F-0BD9839AB72B} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 22:56:03:169 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Adobe Photoshop CC 2015 North American Spanish Language Pack_AdobePhotoshop16-es_MX_x64 16.0.0.0 {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4} is: false
02/18/16 22:56:03:169 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Adobe Photoshop CC 2015 North American Spanish Language Pack_AdobePhotoshop16-es_MX_x64 16.0.0.0 {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4} is none
02/18/16 22:56:03:169 | [INFO] | | OOBE | DE | | | | 6844 | Payload Adobe Photoshop CC 2015 North American Spanish Language Pack_AdobePhotoshop16-es_MX_x64 16.0.0.0 {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 22:56:03:169 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Chinese Language Pack_AdobePhotoshop16-zh_CN_x64 16.0.0.0 {3875BF24-5D9A-494A-A4FA-7AC70F56EC88} is: false
02/18/16 22:56:03:169 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Adobe Photoshop CC 2015 Chinese Language Pack_AdobePhotoshop16-zh_CN_x64 16.0.0.0 {3875BF24-5D9A-494A-A4FA-7AC70F56EC88} is none
02/18/16 22:56:03:169 | [INFO] | | OOBE | DE | | | | 6844 | Payload Adobe Photoshop CC 2015 Chinese Language Pack_AdobePhotoshop16-zh_CN_x64 16.0.0.0 {3875BF24-5D9A-494A-A4FA-7AC70F56EC88} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 22:56:03:169 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Adobe Photoshop CC 2015 French Language Pack_AdobePhotoshop16-fr_FR_x64 16.0.0.0 {B75FB41B-E3E2-4B9F-93F7-62D982857374} is: false
02/18/16 22:56:03:169 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Adobe Photoshop CC 2015 French Language Pack_AdobePhotoshop16-fr_FR_x64 16.0.0.0 {B75FB41B-E3E2-4B9F-93F7-62D982857374} is none
02/18/16 22:56:03:169 | [INFO] | | OOBE | DE | | | | 6844 | Payload Adobe Photoshop CC 2015 French Language Pack_AdobePhotoshop16-fr_FR_x64 16.0.0.0 {B75FB41B-E3E2-4B9F-93F7-62D982857374} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 22:56:03:169 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Turkish Language Pack_AdobePhotoshop16-tr_TR_x64 16.0.0.0 {BED85F42-B42C-4A91-946B-A928824C48A1} is: false
02/18/16 22:56:03:169 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Adobe Photoshop CC 2015 Turkish Language Pack_AdobePhotoshop16-tr_TR_x64 16.0.0.0 {BED85F42-B42C-4A91-946B-A928824C48A1} is none
02/18/16 22:56:03:169 | [INFO] | | OOBE | DE | | | | 6844 | Payload Adobe Photoshop CC 2015 Turkish Language Pack_AdobePhotoshop16-tr_TR_x64 16.0.0.0 {BED85F42-B42C-4A91-946B-A928824C48A1} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 22:56:03:169 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Adobe Photoshop CC 2015 German Language Pack_AdobePhotoshop16-de_DE_x64 16.0.0.0 {69C13F4A-83B3-42F4-912C-C99F1442F439} is: false
02/18/16 22:56:03:169 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Adobe Photoshop CC 2015 German Language Pack_AdobePhotoshop16-de_DE_x64 16.0.0.0 {69C13F4A-83B3-42F4-912C-C99F1442F439} is none
02/18/16 22:56:03:169 | [INFO] | | OOBE | DE | | | | 6844 | Payload Adobe Photoshop CC 2015 German Language Pack_AdobePhotoshop16-de_DE_x64 16.0.0.0 {69C13F4A-83B3-42F4-912C-C99F1442F439} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 22:56:03:169 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860} is: false
02/18/16 22:56:03:170 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860} is none
02/18/16 22:56:03:170 | [INFO] | | OOBE | DE | | | | 6844 | Payload Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 22:56:03:170 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Dutch Language Pack_AdobePhotoshop16-nl_NL_x64 16.0.0.0 {2060E7ED-C473-4A38-877F-C844E81B64F3} is: false
02/18/16 22:56:03:170 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Adobe Photoshop CC 2015 Dutch Language Pack_AdobePhotoshop16-nl_NL_x64 16.0.0.0 {2060E7ED-C473-4A38-877F-C844E81B64F3} is none
02/18/16 22:56:03:170 | [INFO] | | OOBE | DE | | | | 6844 | Payload Adobe Photoshop CC 2015 Dutch Language Pack_AdobePhotoshop16-nl_NL_x64 16.0.0.0 {2060E7ED-C473-4A38-877F-C844E81B64F3} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 22:56:03:170 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Brazilian Portugese Language Pack_AdobePhotoshop16-pt_BR_x64 16.0.0.0 {4A0115A5-CA14-4EA1-9896-2F161B5144B9} is: false
02/18/16 22:56:03:170 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Adobe Photoshop CC 2015 Brazilian Portugese Language Pack_AdobePhotoshop16-pt_BR_x64 16.0.0.0 {4A0115A5-CA14-4EA1-9896-2F161B5144B9} is none
02/18/16 22:56:03:170 | [INFO] | | OOBE | DE | | | | 6844 | Payload Adobe Photoshop CC 2015 Brazilian Portugese Language Pack_AdobePhotoshop16-pt_BR_x64 16.0.0.0 {4A0115A5-CA14-4EA1-9896-2F161B5144B9} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 22:56:03:170 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Danish Language Pack_AdobePhotoshop16-da_DK_x64 16.0.0.0 {F5D14B6C-DA16-4031-9EB8-AF0728550AFC} is: false
02/18/16 22:56:03:170 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Adobe Photoshop CC 2015 Danish Language Pack_AdobePhotoshop16-da_DK_x64 16.0.0.0 {F5D14B6C-DA16-4031-9EB8-AF0728550AFC} is none
02/18/16 22:56:03:170 | [INFO] | | OOBE | DE | | | | 6844 | Payload Adobe Photoshop CC 2015 Danish Language Pack_AdobePhotoshop16-da_DK_x64 16.0.0.0 {F5D14B6C-DA16-4031-9EB8-AF0728550AFC} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 22:56:03:170 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Adobe Photoshop CC 2015 International English Language Pack_AdobePhotoshop16-en_GB_x64 16.0.0.0 {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4} is: false
02/18/16 22:56:03:170 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Adobe Photoshop CC 2015 International English Language Pack_AdobePhotoshop16-en_GB_x64 16.0.0.0 {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4} is none
02/18/16 22:56:03:170 | [INFO] | | OOBE | DE | | | | 6844 | Payload Adobe Photoshop CC 2015 International English Language Pack_AdobePhotoshop16-en_GB_x64 16.0.0.0 {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 22:56:03:170 | [INFO] | | OOBE | DE | | | | 6844 | Value returned on lookup of payload: Adobe Photoshop CC 2015 Finnish Language Pack_AdobePhotoshop16-fi_FI_x64 16.0.0.0 {FD8B8694-1044-4481-A5D9-4740A46BBC3B} is: false
02/18/16 22:56:03:170 | [INFO] | | OOBE | DE | | | | 6844 | Action string for Adobe Photoshop CC 2015 Finnish Language Pack_AdobePhotoshop16-fi_FI_x64 16.0.0.0 {FD8B8694-1044-4481-A5D9-4740A46BBC3B} is none
02/18/16 22:56:03:170 | [INFO] | | OOBE | DE | | | | 6844 | Payload Adobe Photoshop CC 2015 Finnish Language Pack_AdobePhotoshop16-fi_FI_x64 16.0.0.0 {FD8B8694-1044-4481-A5D9-4740A46BBC3B} is extension payload. Aligning its action according to parent Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 22:56:03:171 | [INFO] | | OOBE | DE | | | | 6844 | END Setting requested payload actions
02/18/16 22:56:03:251 | [INFO] | | OOBE | DE | | | | 6844 | Collected advanced path check information for INSTALLDIR
02/18/16 22:56:03:251 | [INFO] | | OOBE | DE | | | | 6844 | INSTALLDIR is a well-formed path
02/18/16 22:56:03:251 | [INFO] | | OOBE | DE | | | | 6844 | INSTALLDIR is not the root path
02/18/16 22:56:03:251 | [INFO] | | OOBE | DE | | | | 6844 | INSTALLDIR is on a local volume
02/18/16 22:56:03:251 | [INFO] | | OOBE | DE | | | | 6844 | INSTALLDIR is on a writable volume
02/18/16 22:56:03:251 | [INFO] | | OOBE | DE | | | | 6844 | INSTALLDIR is not on a case sensitive volume
02/18/16 22:56:03:251 | [INFO] | | OOBE | DE | | | | 6844 | INSTALLDIR passed path basic path validation: C:\Program Files\Adobe
02/18/16 22:56:09:324 | [INFO] | | OOBE | DE | | | | 6844 | BEGIN InstallOperationsQueue Unordered operations
02/18/16 22:56:09:324 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Norwegian Language Pack_AdobePhotoshop16-nb_NO_x64 16.0.0.0 {00F35A9A-C859-4F6E-8C4F-70A7239207FF}: with operation none
02/18/16 22:56:09:324 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Ukrainian Language Pack_AdobePhotoshop16-uk_UA_x64 16.0.0.0 {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA}: with operation none
02/18/16 22:56:09:324 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 IL English Language Pack_AdobePhotoshop16-en_IL_x64 16.0.0.0 {0CA9067E-B7E0-4C7A-BA40-987AF967A05D}: with operation none
02/18/16 22:56:09:324 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 MA French Language Pack_AdobePhotoshop16-fr_MA_x64 16.0.0.0 {0D30F03E-27D9-41F8-AF26-9F1801C2AE28}: with operation none
02/18/16 22:56:09:324 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Chinese (traditional) Language Pack_AdobePhotoshop16-zh_TW_x64 16.0.0.0 {18844AF8-051C-4227-9BE1-CA06F4364F9C}: with operation none
02/18/16 22:56:09:324 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Swedish Language Pack_AdobePhotoshop16-sv_SE_x64 16.0.0.0 {1B7AE611-4C93-47FC-951F-0BD9839AB72B}: with operation none
02/18/16 22:56:09:324 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Dutch Language Pack_AdobePhotoshop16-nl_NL_x64 16.0.0.0 {2060E7ED-C473-4A38-877F-C844E81B64F3}: with operation none
02/18/16 22:56:09:324 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 North American Spanish Language Pack_AdobePhotoshop16-es_MX_x64 16.0.0.0 {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4}: with operation none
02/18/16 22:56:09:324 | [INFO] | | OOBE | DE | | | | 6844 | Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}: with operation install
02/18/16 22:56:09:324 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Chinese Language Pack_AdobePhotoshop16-zh_CN_x64 16.0.0.0 {3875BF24-5D9A-494A-A4FA-7AC70F56EC88}: with operation none
02/18/16 22:56:09:324 | [INFO] | | OOBE | DE | | | | 6844 | Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20}: with operation repair
02/18/16 22:56:09:324 | [INFO] | | OOBE | DE | | | | 6844 | Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}: with operation install
02/18/16 22:56:09:324 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}: with operation install
02/18/16 22:56:09:324 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Brazilian Portugese Language Pack_AdobePhotoshop16-pt_BR_x64 16.0.0.0 {4A0115A5-CA14-4EA1-9896-2F161B5144B9}: with operation none
02/18/16 22:56:09:324 | [INFO] | | OOBE | DE | | | | 6844 | Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}: with operation install
02/18/16 22:56:09:325 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 International English Language Pack_AdobePhotoshop16-en_GB_x64 16.0.0.0 {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4}: with operation none
02/18/16 22:56:09:325 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorJA CC 5.0.0.0 {52D57F95-000A-4922-BB31-C6A936F4FD7D}: with operation none
02/18/16 22:56:09:325 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Korean Language Pack_AdobePhotoshop16-ko_KR_x64 16.0.0.0 {5309436A-D12F-437D-B7A4-BF136E17139C}: with operation none
02/18/16 22:56:09:325 | [INFO] | | OOBE | DE | | | | 6844 | Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}: with operation repair
02/18/16 22:56:09:325 | [INFO] | | OOBE | DE | | | | 6844 | Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9}: with operation repair
02/18/16 22:56:09:325 | [INFO] | | OOBE | DE | | | | 6844 | Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}: with operation install
02/18/16 22:56:09:325 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}: with operation install
02/18/16 22:56:09:325 | [INFO] | | OOBE | DE | | | | 6844 | Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}: with operation install
02/18/16 22:56:09:325 | [INFO] | | OOBE | DE | | | | 6844 | Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}: with operation install
02/18/16 22:56:09:325 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Spanish Language Pack_AdobePhotoshop16-es_ES_x64 16.0.0.0 {644DC0CB-E8C9-4508-B99D-8747C6172621}: with operation none
02/18/16 22:56:09:325 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 German Language Pack_AdobePhotoshop16-de_DE_x64 16.0.0.0 {69C13F4A-83B3-42F4-912C-C99F1442F439}: with operation none
02/18/16 22:56:09:325 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Russian Language Pack_AdobePhotoshop16-ru_RU_x64 16.0.0.0 {6E14FFAB-83F4-4CB7-87A2-703F6F20487A}: with operation none
02/18/16 22:56:09:325 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 AE English Language Pack_AdobePhotoshop16-en_AE_x64 16.0.0.0 {6E7A3076-3056-492F-966F-1EA4FDCE5FA8}: with operation none
02/18/16 22:56:09:325 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorNA CC 5.0.0.0 {72405B80-A3DD-4BB2-A8C4-A90BC7BA50FF}: with operation none
02/18/16 22:56:09:325 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Canadian French Language Pack_AdobePhotoshop16-fr_CA_x64 16.0.0.0 {7433F860-160E-4024-8218-892D796972A6}: with operation none
02/18/16 22:56:09:325 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Czech Language Pack_AdobePhotoshop16-cs_CZ_x64 16.0.0.0 {7787331E-D646-4CA4-ADCB-B264CC156D7D}: with operation none
02/18/16 22:56:09:325 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Japanese Language Pack_AdobePhotoshop16-ja_JP_x64 16.0.0.0 {778CE554-471C-4605-A600-852C976A4DC5}: with operation none
02/18/16 22:56:09:325 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}: with operation install
02/18/16 22:56:09:325 | [INFO] | | OOBE | DE | | | | 6844 | Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC}: with operation repair
02/18/16 22:56:09:325 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Polish Language Pack_AdobePhotoshop16-pl_PL_x64 16.0.0.0 {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0}: with operation none
02/18/16 22:56:09:325 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Italian Language Pack_AdobePhotoshop16-it_IT_x64 16.0.0.0 {960F21E4-EBDC-4A3E-80E9-C28D8A593F66}: with operation none
02/18/16 22:56:09:325 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Hungarian Language Pack_AdobePhotoshop16-hu_HU_x64 16.0.0.0 {98D6FC60-7908-474A-A598-0D7A7BFEF2C2}: with operation none
02/18/16 22:56:09:325 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorEU CC 5.0.0.0 {9E9EB9FD-FDE8-487A-A41C-7713DA91AC89}: with operation none
02/18/16 22:56:09:325 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}: with operation install
02/18/16 22:56:09:326 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}: with operation install
02/18/16 22:56:09:326 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}: with operation install
02/18/16 22:56:09:326 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 French Language Pack_AdobePhotoshop16-fr_FR_x64 16.0.0.0 {B75FB41B-E3E2-4B9F-93F7-62D982857374}: with operation none
02/18/16 22:56:09:326 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Turkish Language Pack_AdobePhotoshop16-tr_TR_x64 16.0.0.0 {BED85F42-B42C-4A91-946B-A928824C48A1}: with operation none
02/18/16 22:56:09:326 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}: with operation install
02/18/16 22:56:09:326 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860}: with operation install
02/18/16 22:56:09:326 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}: with operation install
02/18/16 22:56:09:326 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}: with operation install
02/18/16 22:56:09:326 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Danish Language Pack_AdobePhotoshop16-da_DK_x64 16.0.0.0 {F5D14B6C-DA16-4031-9EB8-AF0728550AFC}: with operation none
02/18/16 22:56:09:326 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}: with operation install
02/18/16 22:56:09:326 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Finnish Language Pack_AdobePhotoshop16-fi_FI_x64 16.0.0.0 {FD8B8694-1044-4481-A5D9-4740A46BBC3B}: with operation none
02/18/16 22:56:09:326 | [INFO] | | OOBE | DE | | | | 6844 | END InstallOperationsQueue Unordered operations
02/18/16 22:56:09:326 | [INFO] | | OOBE | DE | | | | 6844 | BEGIN InstallOperationsQueue Ordered operations
02/18/16 22:56:09:326 | [INFO] | | OOBE | DE | | | | 6844 | Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}: with operation install
02/18/16 22:56:09:326 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}: with operation install
02/18/16 22:56:09:327 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}: with operation install
02/18/16 22:56:09:327 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}: with operation install
02/18/16 22:56:09:327 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}: with operation install
02/18/16 22:56:09:327 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}: with operation install
02/18/16 22:56:09:327 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}: with operation install
02/18/16 22:56:09:327 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}: with operation install
02/18/16 22:56:09:327 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}: with operation install
02/18/16 22:56:09:327 | [INFO] | | OOBE | DE | | | | 6844 | Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}: with operation install
02/18/16 22:56:09:327 | [INFO] | | OOBE | DE | | | | 6844 | Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}: with operation repair
02/18/16 22:56:09:327 | [INFO] | | OOBE | DE | | | | 6844 | Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9}: with operation repair
02/18/16 22:56:09:327 | [INFO] | | OOBE | DE | | | | 6844 | Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20}: with operation repair
02/18/16 22:56:09:327 | [INFO] | | OOBE | DE | | | | 6844 | Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC}: with operation repair
02/18/16 22:56:09:327 | [INFO] | | OOBE | DE | | | | 6844 | Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}: with operation install
02/18/16 22:56:09:327 | [INFO] | | OOBE | DE | | | | 6844 | Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}: with operation install
02/18/16 22:56:09:327 | [INFO] | | OOBE | DE | | | | 6844 | Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}: with operation install
02/18/16 22:56:09:327 | [INFO] | | OOBE | DE | | | | 6844 | Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}: with operation install
02/18/16 22:56:09:327 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}: with operation install
02/18/16 22:56:09:327 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860}: with operation install
02/18/16 22:56:09:327 | [INFO] | | OOBE | DE | | | | 6844 | END InstallOperationsQueue Ordered operations
02/18/16 22:56:10:330 | [INFO] | | OOBE | DE | | | | 6844 | DW034: Warning: Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9} will not be repaired, due to updated patch of the payload and one of the top level payload is being installed.
02/18/16 22:56:10:330 | [INFO] | | OOBE | DE | | | | 6844 | DW034: Warning: Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9} will not be repaired, due to updated patch of the payload and one of the top level payload is being installed.
02/18/16 22:56:10:330 | [INFO] | | OOBE | DE | | | | 6844 | DW034: Warning: Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20} will not be repaired, due to updated patch of the payload and one of the top level payload is being installed.
02/18/16 22:56:10:330 | [INFO] | | OOBE | DE | | | | 6844 | DW034: Warning: Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC} will not be repaired, due to updated patch of the payload and one of the top level payload is being installed.
02/18/16 22:56:10:569 | [INFO] | | OOBE | DE | | | | 6844 | Payloads passed preflight validation.
02/18/16 22:56:10:633 | [INFO] | | OOBE | DE | | | | 6844 | Call PreSession Custom Hook
02/18/16 22:56:10:633 | [INFO] | | OOBE | DE | | | | 6844 | BEGIN InstallOperationsQueue Unordered operations
02/18/16 22:56:10:633 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Norwegian Language Pack_AdobePhotoshop16-nb_NO_x64 16.0.0.0 {00F35A9A-C859-4F6E-8C4F-70A7239207FF}: with operation none
02/18/16 22:56:10:633 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Ukrainian Language Pack_AdobePhotoshop16-uk_UA_x64 16.0.0.0 {0726C0DD-B6BB-4F92-AAEA-E067E7435CEA}: with operation none
02/18/16 22:56:10:633 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 IL English Language Pack_AdobePhotoshop16-en_IL_x64 16.0.0.0 {0CA9067E-B7E0-4C7A-BA40-987AF967A05D}: with operation none
02/18/16 22:56:10:633 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 MA French Language Pack_AdobePhotoshop16-fr_MA_x64 16.0.0.0 {0D30F03E-27D9-41F8-AF26-9F1801C2AE28}: with operation none
02/18/16 22:56:10:633 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Chinese (traditional) Language Pack_AdobePhotoshop16-zh_TW_x64 16.0.0.0 {18844AF8-051C-4227-9BE1-CA06F4364F9C}: with operation none
02/18/16 22:56:10:633 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Swedish Language Pack_AdobePhotoshop16-sv_SE_x64 16.0.0.0 {1B7AE611-4C93-47FC-951F-0BD9839AB72B}: with operation none
02/18/16 22:56:10:633 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Dutch Language Pack_AdobePhotoshop16-nl_NL_x64 16.0.0.0 {2060E7ED-C473-4A38-877F-C844E81B64F3}: with operation none
02/18/16 22:56:10:634 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 North American Spanish Language Pack_AdobePhotoshop16-es_MX_x64 16.0.0.0 {2329CD98-E0DC-4A4E-A6B7-980BC423A9D4}: with operation none
02/18/16 22:56:10:634 | [INFO] | | OOBE | DE | | | | 6844 | Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}: with operation install
02/18/16 22:56:10:634 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Chinese Language Pack_AdobePhotoshop16-zh_CN_x64 16.0.0.0 {3875BF24-5D9A-494A-A4FA-7AC70F56EC88}: with operation none
02/18/16 22:56:10:634 | [INFO] | | OOBE | DE | | | | 6844 | Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20}: with operation repair
02/18/16 22:56:10:634 | [INFO] | | OOBE | DE | | | | 6844 | Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}: with operation install
02/18/16 22:56:10:634 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}: with operation install
02/18/16 22:56:10:634 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Brazilian Portugese Language Pack_AdobePhotoshop16-pt_BR_x64 16.0.0.0 {4A0115A5-CA14-4EA1-9896-2F161B5144B9}: with operation none
02/18/16 22:56:10:634 | [INFO] | | OOBE | DE | | | | 6844 | Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}: with operation install
02/18/16 22:56:10:634 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 International English Language Pack_AdobePhotoshop16-en_GB_x64 16.0.0.0 {4E338E03-4EF5-41CB-B4F7-4AD512C3D0C4}: with operation none
02/18/16 22:56:10:634 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorJA CC 5.0.0.0 {52D57F95-000A-4922-BB31-C6A936F4FD7D}: with operation none
02/18/16 22:56:10:634 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Korean Language Pack_AdobePhotoshop16-ko_KR_x64 16.0.0.0 {5309436A-D12F-437D-B7A4-BF136E17139C}: with operation none
02/18/16 22:56:10:634 | [INFO] | | OOBE | DE | | | | 6844 | Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}: with operation repair
02/18/16 22:56:10:634 | [INFO] | | OOBE | DE | | | | 6844 | Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9}: with operation repair
02/18/16 22:56:10:634 | [INFO] | | OOBE | DE | | | | 6844 | Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}: with operation install
02/18/16 22:56:10:634 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}: with operation install
02/18/16 22:56:10:634 | [INFO] | | OOBE | DE | | | | 6844 | Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}: with operation install
02/18/16 22:56:10:634 | [INFO] | | OOBE | DE | | | | 6844 | Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}: with operation install
02/18/16 22:56:10:634 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Spanish Language Pack_AdobePhotoshop16-es_ES_x64 16.0.0.0 {644DC0CB-E8C9-4508-B99D-8747C6172621}: with operation none
02/18/16 22:56:10:634 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 German Language Pack_AdobePhotoshop16-de_DE_x64 16.0.0.0 {69C13F4A-83B3-42F4-912C-C99F1442F439}: with operation none
02/18/16 22:56:10:634 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Russian Language Pack_AdobePhotoshop16-ru_RU_x64 16.0.0.0 {6E14FFAB-83F4-4CB7-87A2-703F6F20487A}: with operation none
02/18/16 22:56:10:634 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 AE English Language Pack_AdobePhotoshop16-en_AE_x64 16.0.0.0 {6E7A3076-3056-492F-966F-1EA4FDCE5FA8}: with operation none
02/18/16 22:56:10:634 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorNA CC 5.0.0.0 {72405B80-A3DD-4BB2-A8C4-A90BC7BA50FF}: with operation none
02/18/16 22:56:10:634 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Canadian French Language Pack_AdobePhotoshop16-fr_CA_x64 16.0.0.0 {7433F860-160E-4024-8218-892D796972A6}: with operation none
02/18/16 22:56:10:635 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Czech Language Pack_AdobePhotoshop16-cs_CZ_x64 16.0.0.0 {7787331E-D646-4CA4-ADCB-B264CC156D7D}: with operation none
02/18/16 22:56:10:635 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Japanese Language Pack_AdobePhotoshop16-ja_JP_x64 16.0.0.0 {778CE554-471C-4605-A600-852C976A4DC5}: with operation none
02/18/16 22:56:10:635 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}: with operation install
02/18/16 22:56:10:635 | [INFO] | | OOBE | DE | | | | 6844 | Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC}: with operation repair
02/18/16 22:56:10:635 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Polish Language Pack_AdobePhotoshop16-pl_PL_x64 16.0.0.0 {8C711AD9-1C80-4458-9EC3-BAE6BB2B63A0}: with operation none
02/18/16 22:56:10:635 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Italian Language Pack_AdobePhotoshop16-it_IT_x64 16.0.0.0 {960F21E4-EBDC-4A3E-80E9-C28D8A593F66}: with operation none
02/18/16 22:56:10:635 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Hungarian Language Pack_AdobePhotoshop16-hu_HU_x64 16.0.0.0 {98D6FC60-7908-474A-A598-0D7A7BFEF2C2}: with operation none
02/18/16 22:56:10:635 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorEU CC 5.0.0.0 {9E9EB9FD-FDE8-487A-A41C-7713DA91AC89}: with operation none
02/18/16 22:56:10:635 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}: with operation install
02/18/16 22:56:10:635 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}: with operation install
02/18/16 22:56:10:635 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}: with operation install
02/18/16 22:56:10:635 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 French Language Pack_AdobePhotoshop16-fr_FR_x64 16.0.0.0 {B75FB41B-E3E2-4B9F-93F7-62D982857374}: with operation none
02/18/16 22:56:10:635 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Turkish Language Pack_AdobePhotoshop16-tr_TR_x64 16.0.0.0 {BED85F42-B42C-4A91-946B-A928824C48A1}: with operation none
02/18/16 22:56:10:635 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}: with operation install
02/18/16 22:56:10:635 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860}: with operation install
02/18/16 22:56:10:635 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}: with operation install
02/18/16 22:56:10:635 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}: with operation install
02/18/16 22:56:10:635 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Danish Language Pack_AdobePhotoshop16-da_DK_x64 16.0.0.0 {F5D14B6C-DA16-4031-9EB8-AF0728550AFC}: with operation none
02/18/16 22:56:10:635 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}: with operation install
02/18/16 22:56:10:635 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Finnish Language Pack_AdobePhotoshop16-fi_FI_x64 16.0.0.0 {FD8B8694-1044-4481-A5D9-4740A46BBC3B}: with operation none
02/18/16 22:56:10:635 | [INFO] | | OOBE | DE | | | | 6844 | END InstallOperationsQueue Unordered operations
02/18/16 22:56:10:636 | [INFO] | | OOBE | DE | | | | 6844 | BEGIN InstallOperationsQueue Ordered operations
02/18/16 22:56:10:636 | [INFO] | | OOBE | DE | | | | 6844 | Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}: with operation install
02/18/16 22:56:10:636 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}: with operation install
02/18/16 22:56:10:636 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}: with operation install
02/18/16 22:56:10:636 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}: with operation install
02/18/16 22:56:10:636 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}: with operation install
02/18/16 22:56:10:636 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}: with operation install
02/18/16 22:56:10:636 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}: with operation install
02/18/16 22:56:10:636 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}: with operation install
02/18/16 22:56:10:636 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}: with operation install
02/18/16 22:56:10:636 | [INFO] | | OOBE | DE | | | | 6844 | AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}: with operation install
02/18/16 22:56:10:636 | [INFO] | | OOBE | DE | | | | 6844 | Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}: with operation install
02/18/16 22:56:10:636 | [INFO] | | OOBE | DE | | | | 6844 | Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9}: with operation repair
02/18/16 22:56:10:636 | [INFO] | | OOBE | DE | | | | 6844 | Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9}: with operation repair
02/18/16 22:56:10:636 | [INFO] | | OOBE | DE | | | | 6844 | Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20}: with operation repair
02/18/16 22:56:10:636 | [INFO] | | OOBE | DE | | | | 6844 | Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC}: with operation repair
02/18/16 22:56:10:636 | [INFO] | | OOBE | DE | | | | 6844 | Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}: with operation install
02/18/16 22:56:10:636 | [INFO] | | OOBE | DE | | | | 6844 | Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}: with operation install
02/18/16 22:56:10:636 | [INFO] | | OOBE | DE | | | | 6844 | Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}: with operation install
02/18/16 22:56:10:637 | [INFO] | | OOBE | DE | | | | 6844 | Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}: with operation install
02/18/16 22:56:10:637 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}: with operation install
02/18/16 22:56:10:637 | [INFO] | | OOBE | DE | | | | 6844 | Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64 16.0.0.0 {C43757D2-2F7F-41B4-9764-0FD8318DD860}: with operation install
02/18/16 22:56:10:637 | [INFO] | | OOBE | DE | | | | 6844 | END InstallOperationsQueue Ordered operations
02/18/16 22:56:14:166 | [INFO] | | OOBE | DE | | | | 6844 | Calling the custom action code for pre-install for payload Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}
02/18/16 22:56:14:167 | [INFO] | | OOBE | DE | | | | 6844 | ::START TIMER:: [Payload Operation :{56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}]
02/18/16 22:56:14:183 | [INFO] | | OOBE | DE | | | | 6976 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 22:56:14:183 | [INFO] | | OOBE | DE | | | | 6976 | Installer Operation: PayloadInstaller
02/18/16 22:56:14:184 | [INFO] | | OOBE | DE | | | | 6976 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 22:56:14:184 | [INFO] | | OOBE | DE | | | | 6976 | Request to install payload
02/18/16 22:56:14:191 | [INFO] | | OOBE | DE | | | | 6976 | Payload Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 22:56:14:420 | [INFO] | | OOBE | DE | | | | 6976 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeCameraRawProfile8.0All\Assets1_1.zip
02/18/16 22:56:14:420 | [INFO] | | OOBE | DE | | | | 6976 | Setting file open option to false in the unzipper
02/18/16 22:56:36:055 | [INFO] | | OOBE | DE | | | | 6976 | Extracting assets complete. Number assets: 1
02/18/16 22:56:36:055 | [INFO] | | OOBE | DE | | | | 6976 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeCameraRawProfile8.0All\Install.db
02/18/16 22:58:54:600 | [INFO] | | OOBE | DE | | | | 6976 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeCameraRawProfile8.0All\Install.db
02/18/16 22:58:54:833 | [INFO] | | OOBE | DE | | | | 6976 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}.db
02/18/16 22:58:55:474 | [INFO] | | OOBE | DE | | | | 6844 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 22:58:55:474 | [INFO] | | OOBE | DE | | | | 6844 | :: END TIMER :: [Payload Operation :{56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}] took 161300 milliseconds (161.3 seconds) DTR = 2219.51 KBPS (2.16749 MBPS)
02/18/16 22:58:56:286 | [INFO] | | OOBE | DE | | | | 6844 | Updating driver data - Action: Add driver entry
02/18/16 22:58:56:290 | [INFO] | | OOBE | DE | | | | 6844 | Updating driver data successful. Driver entry was added. ARP estimated size 0KB
02/18/16 22:58:56:539 | [INFO] | | OOBE | DE | | | | 6844 | User specified overrideFile:
02/18/16 22:58:56:851 | [INFO] | | OOBE | DE | | | | 6844 | Successfully updated the csu inventory for Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10} return values 0:0
02/18/16 22:58:56:927 | [INFO] | | OOBE | DE | | | | 6844 | Calling the custom action code for post-install for payload Camera Profiles Installer 8.0.0.0 {56DCC6F4-322E-42DA-A5DA-26BAD28C1E10}
02/18/16 22:59:00:248 | [INFO] | | OOBE | DE | | | | 6844 | Calling the custom action code for pre-install for payload Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}
02/18/16 22:59:00:248 | [INFO] | | OOBE | DE | | | | 6844 | ::START TIMER:: [Payload Operation :{3FB7A108-368A-4849-A3F3-69571BAAC457}]
02/18/16 22:59:00:254 | [INFO] | | OOBE | DE | | | | 6788 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 22:59:00:255 | [INFO] | | OOBE | DE | | | | 6788 | Installer Operation: PayloadInstaller
02/18/16 22:59:00:255 | [INFO] | | OOBE | DE | | | | 6788 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 22:59:00:255 | [INFO] | | OOBE | DE | | | | 6788 | Request to install payload
02/18/16 22:59:00:262 | [INFO] | | OOBE | DE | | | | 6788 | Payload Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 22:59:00:273 | [INFO] | | OOBE | DE | | | | 6788 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-Support\Assets2_1.zip
02/18/16 22:59:00:273 | [INFO] | | OOBE | DE | | | | 6788 | Setting file open option to false in the unzipper
02/18/16 22:59:00:679 | [INFO] | | OOBE | DE | | | | 6788 | Extracting assets complete. Number assets: 1
02/18/16 22:59:00:679 | [INFO] | | OOBE | DE | | | | 6788 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-Support\Install.db
02/18/16 22:59:04:810 | [INFO] | | OOBE | DE | | | | 6788 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-Support\Install.db
02/18/16 22:59:05:266 | [INFO] | | OOBE | DE | | | | 6788 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{3FB7A108-368A-4849-A3F3-69571BAAC457}.db
02/18/16 22:59:05:487 | [INFO] | | OOBE | DE | | | | 6844 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 22:59:05:487 | [INFO] | | OOBE | DE | | | | 6844 | :: END TIMER :: [Payload Operation :{3FB7A108-368A-4849-A3F3-69571BAAC457}] took 5238.59 milliseconds (5.23859 seconds) DTR = 1335.47 KBPS (1.30417 MBPS)
02/18/16 22:59:05:919 | [INFO] | | OOBE | DE | | | | 6844 | User specified overrideFile:
02/18/16 22:59:06:136 | [INFO] | | OOBE | DE | | | | 6844 | Successfully updated the csu inventory for Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457} return values 0:0
02/18/16 22:59:06:137 | [INFO] | | OOBE | DE | | | | 6844 | Calling the custom action code for post-install for payload Adobe Photoshop CC 2015 Support 16.0.0.0 {3FB7A108-368A-4849-A3F3-69571BAAC457}
02/18/16 22:59:09:495 | [INFO] | | OOBE | DE | | | | 6844 | Calling the custom action code for pre-install for payload Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}
02/18/16 22:59:09:495 | [INFO] | | OOBE | DE | | | | 6844 | ::START TIMER:: [Payload Operation :{A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}]
02/18/16 22:59:09:500 | [INFO] | | OOBE | DE | | | | 4636 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 22:59:09:501 | [INFO] | | OOBE | DE | | | | 4636 | Installer Operation: PayloadInstaller
02/18/16 22:59:09:501 | [INFO] | | OOBE | DE | | | | 4636 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 22:59:09:501 | [INFO] | | OOBE | DE | | | | 4636 | Request to install payload
02/18/16 22:59:09:508 | [INFO] | | OOBE | DE | | | | 4636 | Payload Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 22:59:09:717 | [INFO] | | OOBE | DE | | | | 4636 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePreview1.0All-win64\Assets2_1.zip
02/18/16 22:59:09:717 | [INFO] | | OOBE | DE | | | | 4636 | Setting file open option to false in the unzipper
02/18/16 22:59:15:729 | [INFO] | | OOBE | DE | | | | 4636 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePreview1.0All-win64\Assets1_1.zip
02/18/16 22:59:15:729 | [INFO] | | OOBE | DE | | | | 4636 | Setting file open option to false in the unzipper
02/18/16 22:59:17:130 | [INFO] | | OOBE | DE | | | | 4636 | Extracting assets complete. Number assets: 2
02/18/16 22:59:17:130 | [INFO] | | OOBE | DE | | | | 4636 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePreview1.0All-win64\Install.db
02/18/16 23:02:03:216 | [INFO] | | OOBE | DE | | | | 4636 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePreview1.0All-win64\Install.db
02/18/16 23:02:03:394 | [INFO] | | OOBE | DE | | | | 4636 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}.db
02/18/16 23:02:04:369 | [INFO] | | OOBE | DE | | | | 6844 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 23:02:04:369 | [INFO] | | OOBE | DE | | | | 6844 | :: END TIMER :: [Payload Operation :{A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}] took 174867 milliseconds (174.867 seconds) DTR = 101.06 KBPS (0.0986909 MBPS)
02/18/16 23:02:04:614 | [INFO] | | OOBE | DE | | | | 6844 | User specified overrideFile:
02/18/16 23:02:04:786 | [INFO] | | OOBE | DE | | | | 6844 | Successfully updated the csu inventory for Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3} return values 0:0
02/18/16 23:02:04:787 | [INFO] | | OOBE | DE | | | | 6844 | Calling the custom action code for post-install for payload Adobe Preview CC 1.0.0.0 {A3B6E381-F2E8-47CD-87B4-96B1E3FF61D3}
02/18/16 23:02:07:703 | [INFO] | | OOBE | DE | | | | 6844 | Calling the custom action code for pre-install for payload AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}
02/18/16 23:02:07:704 | [INFO] | | OOBE | DE | | | | 6844 | ::START TIMER:: [Payload Operation :{C4196275-B11A-40A1-8727-3C145C8F7D95}]
02/18/16 23:02:07:708 | [INFO] | | OOBE | DE | | | | 2804 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 23:02:07:708 | [INFO] | | OOBE | DE | | | | 2804 | Installer Operation: PayloadInstaller
02/18/16 23:02:07:708 | [INFO] | | OOBE | DE | | | | 2804 | Request to install payload
02/18/16 23:02:07:712 | [INFO] | | OOBE | DE | | | | 2804 | Payload AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 23:02:07:721 | [INFO] | | OOBE | DE | | | | 2804 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorCommonSetCMYK5_0-mul\Assets2_1.zip
02/18/16 23:02:07:721 | [INFO] | | OOBE | DE | | | | 2804 | Setting file open option to false in the unzipper
02/18/16 23:02:08:001 | [INFO] | | OOBE | DE | | | | 2804 | Extracting assets complete. Number assets: 1
02/18/16 23:02:08:054 | [INFO] | | OOBE | DE | | | | 2804 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorCommonSetCMYK5_0-mul\Install.db
02/18/16 23:02:11:005 | [INFO] | | OOBE | DE | | | | 2804 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorCommonSetCMYK5_0-mul\Install.db
02/18/16 23:02:11:183 | [INFO] | | OOBE | DE | | | | 2804 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{C4196275-B11A-40A1-8727-3C145C8F7D95}.db
02/18/16 23:02:11:508 | [INFO] | | OOBE | DE | | | | 6844 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 23:02:11:508 | [INFO] | | OOBE | DE | | | | 6844 | :: END TIMER :: [Payload Operation :{C4196275-B11A-40A1-8727-3C145C8F7D95}] took 3804.28 milliseconds (3.80428 seconds) DTR = 21.0289 KBPS (0.0205361 MBPS)
02/18/16 23:02:11:848 | [INFO] | | OOBE | DE | | | | 6844 | User specified overrideFile:
02/18/16 23:02:12:220 | [INFO] | | OOBE | DE | | | | 6844 | Successfully updated the csu inventory for AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95} return values 0:0
02/18/16 23:02:12:221 | [INFO] | | OOBE | DE | | | | 6844 | Calling the custom action code for post-install for payload AdobeColorCommonSetCMYK CC 5.0.0.0 {C4196275-B11A-40A1-8727-3C145C8F7D95}
02/18/16 23:02:15:381 | [INFO] | | OOBE | DE | | | | 6844 | Calling the custom action code for pre-install for payload AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}
02/18/16 23:02:15:382 | [INFO] | | OOBE | DE | | | | 6844 | ::START TIMER:: [Payload Operation :{C8DEBB29-3EB0-4B97-B652-4DE482B111BC}]
02/18/16 23:02:15:387 | [INFO] | | OOBE | DE | | | | 7120 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 23:02:15:387 | [INFO] | | OOBE | DE | | | | 7120 | Installer Operation: PayloadInstaller
02/18/16 23:02:15:387 | [INFO] | | OOBE | DE | | | | 7120 | Request to install payload
02/18/16 23:02:15:392 | [INFO] | | OOBE | DE | | | | 7120 | Payload AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 23:02:15:402 | [INFO] | | OOBE | DE | | | | 7120 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorCommonSetRGB5_0-mul\Assets2_1.zip
02/18/16 23:02:15:402 | [INFO] | | OOBE | DE | | | | 7120 | Setting file open option to false in the unzipper
02/18/16 23:02:15:438 | [INFO] | | OOBE | DE | | | | 7120 | Extracting assets complete. Number assets: 1
02/18/16 23:02:15:438 | [INFO] | | OOBE | DE | | | | 7120 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorCommonSetRGB5_0-mul\Install.db
02/18/16 23:02:16:020 | [INFO] | | OOBE | DE | | | | 7120 | Successfully added payload {AB8E4534-C573-4CC9-BA6A-76DD14055510} to collection adbeadbeadbeadbeadbeadbeadbeadb(Seq 1)
02/18/16 23:02:16:021 | [INFO] | | OOBE | DE | | | | 7120 | Successfully set payload installState for payload {AB8E4534-C573-4CC9-BA6A-76DD14055510}(Seq 1)
02/18/16 23:02:16:647 | [INFO] | | OOBE | DE | | | | 7120 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorCommonSetRGB5_0-mul\Install.db
02/18/16 23:02:16:783 | [INFO] | | OOBE | DE | | | | 7120 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{C8DEBB29-3EB0-4B97-B652-4DE482B111BC}.db
02/18/16 23:02:17:189 | [INFO] | | OOBE | DE | | | | 6844 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 23:02:17:189 | [INFO] | | OOBE | DE | | | | 6844 | :: END TIMER :: [Payload Operation :{C8DEBB29-3EB0-4B97-B652-4DE482B111BC}] took 1807.17 milliseconds (1.80717 seconds) DTR = 57.5484 KBPS (0.0561996 MBPS)
02/18/16 23:02:17:435 | [INFO] | | OOBE | DE | | | | 6844 | User specified overrideFile:
02/18/16 23:02:17:643 | [INFO] | | OOBE | DE | | | | 6844 | Successfully updated the csu inventory for AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC} return values 0:0
02/18/16 23:02:17:643 | [INFO] | | OOBE | DE | | | | 6844 | Calling the custom action code for post-install for payload AdobeColorCommonSetRGB CC 5.0.0.0 {C8DEBB29-3EB0-4B97-B652-4DE482B111BC}
02/18/16 23:02:20:799 | [INFO] | | OOBE | DE | | | | 6844 | Calling the custom action code for pre-install for payload AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}
02/18/16 23:02:20:800 | [INFO] | | OOBE | DE | | | | 6844 | ::START TIMER:: [Payload Operation :{F6DED2DA-1D20-497E-8810-E745B45DCD28}]
02/18/16 23:02:20:807 | [INFO] | | OOBE | DE | | | | 1496 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 23:02:20:807 | [INFO] | | OOBE | DE | | | | 1496 | Installer Operation: PayloadInstaller
02/18/16 23:02:20:807 | [INFO] | | OOBE | DE | | | | 1496 | Request to install payload
02/18/16 23:02:20:813 | [INFO] | | OOBE | DE | | | | 1496 | Payload AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 23:02:20:825 | [INFO] | | OOBE | DE | | | | 1496 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorEU_ExtraSettings5_0-mul\Assets2_1.zip
02/18/16 23:02:20:825 | [INFO] | | OOBE | DE | | | | 1496 | Setting file open option to false in the unzipper
02/18/16 23:02:20:885 | [INFO] | | OOBE | DE | | | | 1496 | Extracting assets complete. Number assets: 1
02/18/16 23:02:20:885 | [INFO] | | OOBE | DE | | | | 1496 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorEU_ExtraSettings5_0-mul\Install.db
02/18/16 23:02:21:393 | [INFO] | | OOBE | DE | | | | 1496 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorEU_ExtraSettings5_0-mul\Install.db
02/18/16 23:02:21:560 | [INFO] | | OOBE | DE | | | | 1496 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{F6DED2DA-1D20-497E-8810-E745B45DCD28}.db
02/18/16 23:02:21:806 | [INFO] | | OOBE | DE | | | | 6844 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 23:02:21:806 | [INFO] | | OOBE | DE | | | | 6844 | :: END TIMER :: [Payload Operation :{F6DED2DA-1D20-497E-8810-E745B45DCD28}] took 1006.27 milliseconds (1.00627 seconds) DTR = 71.5514 KBPS (0.0698744 MBPS)
02/18/16 23:02:22:205 | [INFO] | | OOBE | DE | | | | 6844 | User specified overrideFile:
02/18/16 23:02:22:375 | [INFO] | | OOBE | DE | | | | 6844 | Successfully updated the csu inventory for AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28} return values 0:0
02/18/16 23:02:22:376 | [INFO] | | OOBE | DE | | | | 6844 | Calling the custom action code for post-install for payload AdobeColorEU CC 5.0.0.0 {F6DED2DA-1D20-497E-8810-E745B45DCD28}
02/18/16 23:02:25:582 | [INFO] | | OOBE | DE | | | | 6844 | Calling the custom action code for pre-install for payload AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}
02/18/16 23:02:25:583 | [INFO] | | OOBE | DE | | | | 6844 | ::START TIMER:: [Payload Operation :{A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}]
02/18/16 23:02:25:589 | [INFO] | | OOBE | DE | | | | 5944 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 23:02:25:590 | [INFO] | | OOBE | DE | | | | 5944 | Installer Operation: PayloadInstaller
02/18/16 23:02:25:590 | [INFO] | | OOBE | DE | | | | 5944 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 23:02:25:590 | [INFO] | | OOBE | DE | | | | 5944 | Request to install payload
02/18/16 23:02:25:596 | [INFO] | | OOBE | DE | | | | 5944 | Payload AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 23:02:25:608 | [INFO] | | OOBE | DE | | | | 5944 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorJA_ExtraSettings5_0-mul\Assets2_1.zip
02/18/16 23:02:25:608 | [INFO] | | OOBE | DE | | | | 5944 | Setting file open option to false in the unzipper
02/18/16 23:02:25:690 | [INFO] | | OOBE | DE | | | | 5944 | Extracting assets complete. Number assets: 1
02/18/16 23:02:25:691 | [INFO] | | OOBE | DE | | | | 5944 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorJA_ExtraSettings5_0-mul\Install.db
02/18/16 23:02:26:572 | [INFO] | | OOBE | DE | | | | 5944 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorJA_ExtraSettings5_0-mul\Install.db
02/18/16 23:02:26:716 | [INFO] | | OOBE | DE | | | | 5944 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}.db
02/18/16 23:02:26:904 | [INFO] | | OOBE | DE | | | | 6844 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 23:02:26:904 | [INFO] | | OOBE | DE | | | | 6844 | :: END TIMER :: [Payload Operation :{A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}] took 1321.4 milliseconds (1.3214 seconds) DTR = 54.4877 KBPS (0.0532107 MBPS)
02/18/16 23:02:27:249 | [INFO] | | OOBE | DE | | | | 6844 | User specified overrideFile:
02/18/16 23:02:27:471 | [INFO] | | OOBE | DE | | | | 6844 | Successfully updated the csu inventory for AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB} return values 0:0
02/18/16 23:02:27:472 | [INFO] | | OOBE | DE | | | | 6844 | Calling the custom action code for post-install for payload AdobeColorJA CC 5.0.0.0 {A032EB9D-B6EB-45BF-9F15-83B0755DC9AB}
02/18/16 23:02:30:632 | [INFO] | | OOBE | DE | | | | 6844 | Calling the custom action code for pre-install for payload AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}
02/18/16 23:02:30:633 | [INFO] | | OOBE | DE | | | | 6844 | ::START TIMER:: [Payload Operation :{AB955DCF-69CD-4840-B7FB-F318CDD0AE44}]
02/18/16 23:02:30:639 | [INFO] | | OOBE | DE | | | | 3172 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 23:02:30:639 | [INFO] | | OOBE | DE | | | | 3172 | Installer Operation: PayloadInstaller
02/18/16 23:02:30:639 | [INFO] | | OOBE | DE | | | | 3172 | Request to install payload
02/18/16 23:02:30:645 | [INFO] | | OOBE | DE | | | | 3172 | Payload AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 23:02:30:657 | [INFO] | | OOBE | DE | | | | 3172 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorNA_Recommended5_0-mul\Assets2_1.zip
02/18/16 23:02:30:658 | [INFO] | | OOBE | DE | | | | 3172 | Setting file open option to false in the unzipper
02/18/16 23:02:30:730 | [INFO] | | OOBE | DE | | | | 3172 | Extracting assets complete. Number assets: 1
02/18/16 23:02:30:730 | [INFO] | | OOBE | DE | | | | 3172 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorNA_Recommended5_0-mul\Install.db
02/18/16 23:02:31:093 | [INFO] | | OOBE | DE | | | | 3172 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorNA_Recommended5_0-mul\Install.db
02/18/16 23:02:31:249 | [INFO] | | OOBE | DE | | | | 3172 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{AB955DCF-69CD-4840-B7FB-F318CDD0AE44}.db
02/18/16 23:02:31:446 | [INFO] | | OOBE | DE | | | | 6844 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 23:02:31:446 | [INFO] | | OOBE | DE | | | | 6844 | :: END TIMER :: [Payload Operation :{AB955DCF-69CD-4840-B7FB-F318CDD0AE44}] took 813.425 milliseconds (0.813425 seconds) DTR = 88.5146 KBPS (0.08644 MBPS)
02/18/16 23:02:31:794 | [INFO] | | OOBE | DE | | | | 6844 | User specified overrideFile:
02/18/16 23:02:32:175 | [INFO] | | OOBE | DE | | | | 6844 | Successfully updated the csu inventory for AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44} return values 0:0
02/18/16 23:02:32:176 | [INFO] | | OOBE | DE | | | | 6844 | Calling the custom action code for post-install for payload AdobeColorNA CC 5.0.0.0 {AB955DCF-69CD-4840-B7FB-F318CDD0AE44}
02/18/16 23:02:35:356 | [INFO] | | OOBE | DE | | | | 6844 | Calling the custom action code for pre-install for payload AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}
02/18/16 23:02:35:356 | [INFO] | | OOBE | DE | | | | 6844 | ::START TIMER:: [Payload Operation :{5C5D62C9-91C6-415E-857E-9130C0F52C66}]
02/18/16 23:02:35:363 | [INFO] | | OOBE | DE | | | | 6616 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 23:02:35:363 | [INFO] | | OOBE | DE | | | | 6616 | Installer Operation: PayloadInstaller
02/18/16 23:02:35:363 | [INFO] | | OOBE | DE | | | | 6616 | Request to install payload
02/18/16 23:02:35:370 | [INFO] | | OOBE | DE | | | | 6616 | Payload AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 23:02:35:382 | [INFO] | | OOBE | DE | | | | 6616 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorPhotoshop5_0-mul\Assets2_1.zip
02/18/16 23:02:35:382 | [INFO] | | OOBE | DE | | | | 6616 | Setting file open option to false in the unzipper
02/18/16 23:02:35:429 | [INFO] | | OOBE | DE | | | | 6616 | Extracting assets complete. Number assets: 1
02/18/16 23:02:35:430 | [INFO] | | OOBE | DE | | | | 6616 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorPhotoshop5_0-mul\Install.db
02/18/16 23:02:35:593 | [INFO] | | OOBE | DE | | | | 6616 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeColorPhotoshop5_0-mul\Install.db
02/18/16 23:02:35:749 | [INFO] | | OOBE | DE | | | | 6616 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{5C5D62C9-91C6-415E-857E-9130C0F52C66}.db
02/18/16 23:02:36:063 | [INFO] | | OOBE | DE | | | | 6844 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 23:02:36:063 | [INFO] | | OOBE | DE | | | | 6844 | :: END TIMER :: [Payload Operation :{5C5D62C9-91C6-415E-857E-9130C0F52C66}] took 706.628 milliseconds (0.706628 seconds) DTR = 101.892 KBPS (0.0995042 MBPS)
02/18/16 23:02:36:760 | [INFO] | | OOBE | DE | | | | 6844 | User specified overrideFile:
02/18/16 23:02:37:019 | [INFO] | | OOBE | DE | | | | 6844 | Successfully updated the csu inventory for AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66} return values 0:0
02/18/16 23:02:37:020 | [INFO] | | OOBE | DE | | | | 6844 | Calling the custom action code for post-install for payload AdobeColorPhotoshop CC 5.0.0.0 {5C5D62C9-91C6-415E-857E-9130C0F52C66}
02/18/16 23:02:40:191 | [INFO] | | OOBE | DE | | | | 6844 | Calling the custom action code for pre-install for payload AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}
02/18/16 23:02:40:192 | [INFO] | | OOBE | DE | | | | 6844 | ::START TIMER:: [Payload Operation :{CE9B1B00-0421-4701-9698-1C14646D6D94}]
02/18/16 23:02:40:199 | [INFO] | | OOBE | DE | | | | 4276 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 23:02:40:199 | [INFO] | | OOBE | DE | | | | 4276 | Installer Operation: PayloadInstaller
02/18/16 23:02:40:199 | [INFO] | | OOBE | DE | | | | 4276 | Request to install payload
02/18/16 23:02:40:205 | [INFO] | | OOBE | DE | | | | 4276 | Payload AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 23:02:40:217 | [INFO] | | OOBE | DE | | | | 4276 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeVideoProfilesCS5_0-mul\Assets2_1.zip
02/18/16 23:02:40:217 | [INFO] | | OOBE | DE | | | | 4276 | Setting file open option to false in the unzipper
02/18/16 23:02:40:236 | [INFO] | | OOBE | DE | | | | 4276 | Extracting assets complete. Number assets: 1
02/18/16 23:02:40:236 | [INFO] | | OOBE | DE | | | | 4276 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeVideoProfilesCS5_0-mul\Install.db
02/18/16 23:02:40:241 | [INFO] | | OOBE | DE | | | | 4276 | Collection adbeadbeadbeadbeadbeadbeadbeadb already exists(Seq 1)
02/18/16 23:02:40:243 | [INFO] | | OOBE | DE | | | | 4276 | Successfully added payload {4F3CE025-D60B-4E6B-8D39-B04CD3769008} to collection adbeadbeadbeadbeadbeadbeadbeadb(Seq 1)
02/18/16 23:02:40:244 | [INFO] | | OOBE | DE | | | | 4276 | Successfully set payload installState for payload {4F3CE025-D60B-4E6B-8D39-B04CD3769008}(Seq 1)
02/18/16 23:02:40:638 | [INFO] | | OOBE | DE | | | | 4276 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeVideoProfilesCS5_0-mul\Install.db
02/18/16 23:02:40:883 | [INFO] | | OOBE | DE | | | | 4276 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{CE9B1B00-0421-4701-9698-1C14646D6D94}.db
02/18/16 23:02:41:298 | [INFO] | | OOBE | DE | | | | 6844 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 23:02:41:298 | [INFO] | | OOBE | DE | | | | 6844 | :: END TIMER :: [Payload Operation :{CE9B1B00-0421-4701-9698-1C14646D6D94}] took 1106.14 milliseconds (1.10614 seconds) DTR = 122.95 KBPS (0.120069 MBPS)
02/18/16 23:02:41:605 | [INFO] | | OOBE | DE | | | | 6844 | User specified overrideFile:
02/18/16 23:02:41:767 | [INFO] | | OOBE | DE | | | | 6844 | Successfully updated the csu inventory for AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94} return values 0:0
02/18/16 23:02:41:768 | [INFO] | | OOBE | DE | | | | 6844 | Calling the custom action code for post-install for payload AdobeColorVideoProfilesCS CC 5.0.0.0 {CE9B1B00-0421-4701-9698-1C14646D6D94}
02/18/16 23:02:44:961 | [INFO] | | OOBE | DE | | | | 6844 | Calling the custom action code for pre-install for payload Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}
02/18/16 23:02:44:962 | [INFO] | | OOBE | DE | | | | 6844 | ::START TIMER:: [Payload Operation :{27375F7C-0789-4FEA-889E-41BF12AC3140}]
02/18/16 23:02:44:969 | [INFO] | | OOBE | DE | | | | 500 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 23:02:44:969 | [INFO] | | OOBE | DE | | | | 500 | Installer Operation: PayloadInstaller
02/18/16 23:02:44:969 | [INFO] | | OOBE | DE | | | | 500 | Request to install payload
02/18/16 23:02:44:976 | [INFO] | | OOBE | DE | | | | 500 | Payload Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 23:02:44:986 | [INFO] | | OOBE | DE | | | | 500 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeExportAssets2.0All-x64\Assets2_1.zip
02/18/16 23:02:44:986 | [INFO] | | OOBE | DE | | | | 500 | Setting file open option to false in the unzipper
02/18/16 23:02:47:304 | [INFO] | | OOBE | DE | | | | 500 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeExportAssets2.0All-x64\Assets1_1.zip
02/18/16 23:02:47:304 | [INFO] | | OOBE | DE | | | | 500 | Setting file open option to false in the unzipper
02/18/16 23:02:47:919 | [INFO] | | OOBE | DE | | | | 500 | Extracting assets complete. Number assets: 2
02/18/16 23:02:47:919 | [INFO] | | OOBE | DE | | | | 500 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeExportAssets2.0All-x64\Install.db
02/18/16 23:04:51:723 | [INFO] | | OOBE | DE | | | | 500 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeExportAssets2.0All-x64\Install.db
02/18/16 23:04:51:901 | [INFO] | | OOBE | DE | | | | 500 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{27375F7C-0789-4FEA-889E-41BF12AC3140}.db
02/18/16 23:04:52:516 | [INFO] | | OOBE | DE | | | | 6844 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 23:04:52:516 | [INFO] | | OOBE | DE | | | | 6844 | :: END TIMER :: [Payload Operation :{27375F7C-0789-4FEA-889E-41BF12AC3140}] took 127549 milliseconds (127.549 seconds) DTR = 192.082 KBPS (0.187581 MBPS)
02/18/16 23:04:52:848 | [INFO] | | OOBE | DE | | | | 6844 | User specified overrideFile:
02/18/16 23:04:53:353 | [INFO] | | OOBE | DE | | | | 6844 | Successfully updated the csu inventory for Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140} return values 0:0
02/18/16 23:04:53:354 | [INFO] | | OOBE | DE | | | | 6844 | Calling the custom action code for post-install for payload Export Assets 2 (64 bit) 2.0.0.0 {27375F7C-0789-4FEA-889E-41BF12AC3140}
02/18/16 23:04:53:354 | [INFO] | | OOBE | DE | | | | 6844 | DW034: Warning: Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9} will not be repaired, due to updated patch of the payload and one of the top level payload is being installed.
02/18/16 23:04:53:354 | [INFO] | | OOBE | DE | | | | 6844 | DW034: Warning: Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9} will not be repaired, due to updated patch of the payload and one of the top level payload is being installed.
02/18/16 23:04:53:354 | [INFO] | | OOBE | DE | | | | 6844 | DW034: Warning: Microsoft Visual C++ 2012 Redistributable Package (x64) 11.0.61030.0 {3E272A93-C06B-4206-AD02-0EBE02535E20} will not be repaired, due to updated patch of the payload and one of the top level payload is being installed.
02/18/16 23:04:53:354 | [INFO] | | OOBE | DE | | | | 6844 | DW034: Warning: Microsoft Visual C++ 2012 Redistributable Package (x86) 11.0.61030.0 {873BE68F-480F-49A6-9649-F98CAB056AFC} will not be repaired, due to updated patch of the payload and one of the top level payload is being installed.
02/18/16 23:04:56:656 | [INFO] | | OOBE | DE | | | | 6844 | Calling the custom action code for pre-install for payload Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}
02/18/16 23:04:56:656 | [INFO] | | OOBE | DE | | | | 6844 | ::START TIMER:: [Payload Operation :{4CED09CB-0C96-4EAE-83C4-7D9B9456E613}]
02/18/16 23:04:56:662 | [INFO] | | OOBE | DE | | | | 6340 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 23:04:56:662 | [INFO] | | OOBE | DE | | | | 6340 | Installer Operation: InstallThirdPartyPayloadOperation
02/18/16 23:04:56:662 | [INFO] | | OOBE | DE | | | | 6340 | Installing third party payload
02/18/16 23:04:56:662 | [INFO] | | OOBE | DE | | | | 6340 | Third party application path:C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\Microsoft VC 2013 Redist (x64)\vcredist_x64.exe
02/18/16 23:04:56:662 | [INFO] | | OOBE | DE | | | | 6340 | CommandLine: /q /norestart
02/18/16 23:06:07:972 | [INFO] | | OOBE | DE | | | | 6340 | Third party payload completed. Testing return code: 0
02/18/16 23:06:51:691 | [INFO] | | OOBE | DE | | | | 6844 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 23:06:51:691 | [INFO] | | OOBE | DE | | | | 6844 | :: END TIMER :: [Payload Operation :{4CED09CB-0C96-4EAE-83C4-7D9B9456E613}] took 115030 milliseconds (115.03 seconds) DTR = 2938.01 KBPS (2.86915 MBPS)
02/18/16 23:07:08:322 | [INFO] | | OOBE | DE | | | | 6844 | User specified overrideFile:
02/18/16 23:07:14:646 | [INFO] | | OOBE | DE | | | | 6844 | The csu inventory was not updated for payload Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}, value of local var is -1
02/18/16 23:07:14:647 | [INFO] | | OOBE | DE | | | | 6844 | Calling the custom action code for post-install for payload Microsoft Visual C++ 2013 Redistributable Package (x64) 12.0.30501.0 {4CED09CB-0C96-4EAE-83C4-7D9B9456E613}
02/18/16 23:07:21:065 | [INFO] | | OOBE | DE | | | | 6844 | Calling the custom action code for pre-install for payload Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}
02/18/16 23:07:21:065 | [INFO] | | OOBE | DE | | | | 6844 | ::START TIMER:: [Payload Operation :{636D196A-789E-455D-825E-3FA79F67D446}]
02/18/16 23:07:21:071 | [INFO] | | OOBE | DE | | | | 5896 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 23:07:21:071 | [INFO] | | OOBE | DE | | | | 5896 | Installer Operation: InstallThirdPartyPayloadOperation
02/18/16 23:07:21:071 | [INFO] | | OOBE | DE | | | | 5896 | Installing third party payload
02/18/16 23:07:21:071 | [INFO] | | OOBE | DE | | | | 5896 | Third party application path:C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\Microsoft VC 2013 Redist (x86)\vcredist_x86.exe
02/18/16 23:07:21:071 | [INFO] | | OOBE | DE | | | | 5896 | CommandLine: /q /norestart
02/18/16 23:10:19:503 | [INFO] | | OOBE | DE | | | | 5896 | Third party payload completed. Testing return code: 0
02/18/16 23:10:24:865 | [INFO] | | OOBE | DE | | | | 6844 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 23:10:24:865 | [INFO] | | OOBE | DE | | | | 6844 | :: END TIMER :: [Payload Operation :{636D196A-789E-455D-825E-3FA79F67D446}] took 183793 milliseconds (183.793 seconds) DTR = 457.361 KBPS (0.446642 MBPS)
02/18/16 23:10:36:073 | [INFO] | | OOBE | DE | | | | 6844 | User specified overrideFile:
02/18/16 23:10:42:425 | [INFO] | | OOBE | DE | | | | 6844 | The csu inventory was not updated for payload Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}, value of local var is -1
02/18/16 23:10:42:426 | [INFO] | | OOBE | DE | | | | 6844 | Calling the custom action code for post-install for payload Microsoft Visual C++ 2013 Redistributable Package (x86) 12.0.30501.0 {636D196A-789E-455D-825E-3FA79F67D446}
02/18/16 23:10:47:129 | [INFO] | | OOBE | DE | | | | 6844 | Calling the custom action code for pre-install for payload Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}
02/18/16 23:10:47:130 | [INFO] | | OOBE | DE | | | | 6844 | ::START TIMER:: [Payload Operation :{5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}]
02/18/16 23:10:47:136 | [INFO] | | OOBE | DE | | | | 6024 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 23:10:47:137 | [INFO] | | OOBE | DE | | | | 6024 | Installer Operation: PayloadInstaller
02/18/16 23:10:47:137 | [INFO] | | OOBE | DE | | | | 6024 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 23:10:47:137 | [INFO] | | OOBE | DE | | | | 6024 | Request to install payload
02/18/16 23:10:47:141 | [INFO] | | OOBE | DE | | | | 6024 | Payload Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 23:10:47:149 | [INFO] | | OOBE | DE | | | | 6024 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeCameraRaw8.0All-x64\Assets1_1.zip
02/18/16 23:10:47:149 | [INFO] | | OOBE | DE | | | | 6024 | Setting file open option to false in the unzipper
02/18/16 23:10:47:883 | [INFO] | | OOBE | DE | | | | 6024 | Extracting assets complete. Number assets: 1
02/18/16 23:10:47:883 | [INFO] | | OOBE | DE | | | | 6024 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeCameraRaw8.0All-x64\Install.db
02/18/16 23:10:49:803 | [INFO] | | OOBE | DE | | | | 6024 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeCameraRaw8.0All-x64\Install.db
02/18/16 23:10:54:092 | [INFO] | | OOBE | DE | | | | 6024 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}.db
02/18/16 23:10:58:760 | [INFO] | | OOBE | DE | | | | 6844 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 23:10:58:760 | [INFO] | | OOBE | DE | | | | 6844 | :: END TIMER :: [Payload Operation :{5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}] took 11629.3 milliseconds (11.6293 seconds) DTR = 2369.53 KBPS (2.31399 MBPS)
02/18/16 23:11:05:093 | [INFO] | | OOBE | DE | | | | 6844 | User specified overrideFile:
02/18/16 23:11:11:183 | [INFO] | | OOBE | DE | | | | 6844 | Successfully updated the csu inventory for Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA} return values 0:0
02/18/16 23:11:11:184 | [INFO] | | OOBE | DE | | | | 6844 | Calling the custom action code for post-install for payload Photoshop Camera Raw 8 (64 bit) 8.0.0.0 {5CEA575D-1E1C-4A92-BEC1-3CADD429E4EA}
02/18/16 23:11:15:524 | [INFO] | | OOBE | DE | | | | 6844 | Calling the custom action code for pre-install for payload Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}
02/18/16 23:11:15:524 | [INFO] | | OOBE | DE | | | | 6844 | ::START TIMER:: [Payload Operation :{3E7FC757-D497-4C89-A935-7D38E2164E85}]
02/18/16 23:11:15:534 | [INFO] | | OOBE | DE | | | | 5548 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 23:11:15:534 | [INFO] | | OOBE | DE | | | | 5548 | Installer Operation: PayloadInstaller
02/18/16 23:11:15:534 | [INFO] | | OOBE | DE | | | | 5548 | Request to install payload
02/18/16 23:11:15:542 | [INFO] | | OOBE | DE | | | | 5548 | Payload Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 23:11:15:614 | [INFO] | | OOBE | DE | | | | 5548 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeCameraRaw8.0All\Assets1_1.zip
02/18/16 23:11:15:614 | [INFO] | | OOBE | DE | | | | 5548 | Setting file open option to false in the unzipper
02/18/16 23:11:17:143 | [INFO] | | OOBE | DE | | | | 5548 | Extracting assets complete. Number assets: 1
02/18/16 23:11:17:144 | [INFO] | | OOBE | DE | | | | 5548 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeCameraRaw8.0All\Install.db
02/18/16 23:11:17:481 | [INFO] | | OOBE | DE | | | | 5548 | Evaluating condition# 1(Seq 3)
02/18/16 23:11:17:481 | [INFO] | | OOBE | DE | | | | 5548 | Condition failed(Seq 3)
02/18/16 23:11:17:691 | [INFO] | | OOBE | DE | | | | 5548 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobeCameraRaw8.0All\Install.db
02/18/16 23:11:21:769 | [INFO] | | OOBE | DE | | | | 5548 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{3E7FC757-D497-4C89-A935-7D38E2164E85}.db
02/18/16 23:11:25:406 | [INFO] | | OOBE | DE | | | | 6844 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 23:11:25:406 | [INFO] | | OOBE | DE | | | | 6844 | :: END TIMER :: [Payload Operation :{3E7FC757-D497-4C89-A935-7D38E2164E85}] took 9880.67 milliseconds (9.88067 seconds) DTR = 2535.05 KBPS (2.47564 MBPS)
02/18/16 23:11:30:571 | [INFO] | | OOBE | DE | | | | 6844 | User specified overrideFile:
02/18/16 23:11:38:574 | [INFO] | | OOBE | DE | | | | 6844 | Successfully updated the csu inventory for Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85} return values 0:0
02/18/16 23:11:38:575 | [INFO] | | OOBE | DE | | | | 6844 | Calling the custom action code for post-install for payload Photoshop Camera Raw 8 8.0.0.0 {3E7FC757-D497-4C89-A935-7D38E2164E85}
02/18/16 23:11:43:110 | [INFO] | | OOBE | DE | | | | 6844 | Calling the custom action code for pre-install for payload Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 23:11:43:111 | [INFO] | | OOBE | DE | | | | 6844 | ::START TIMER:: [Payload Operation :{793C2BF7-A4FE-4608-91C9-9282C5801C21}]
02/18/16 23:11:43:119 | [INFO] | | OOBE | DE | | | | 5764 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 23:11:43:119 | [INFO] | | OOBE | DE | | | | 5764 | Installer Operation: PayloadInstaller
02/18/16 23:11:43:120 | [INFO] | | OOBE | DE | | | | 5764 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 23:11:43:120 | [INFO] | | OOBE | DE | | | | 5764 | Request to install payload
02/18/16 23:11:43:126 | [INFO] | | OOBE | DE | | | | 5764 | Payload Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}: Calling ARKEngine from path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\DE6\resources
02/18/16 23:11:43:138 | [INFO] | | OOBE | DE | | | | 5764 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-Core_x64\Assets2_1.zip
02/18/16 23:11:43:138 | [INFO] | | OOBE | DE | | | | 5764 | Setting file open option to false in the unzipper
02/18/16 23:11:45:664 | [INFO] | | OOBE | DE | | | | 5764 | Extracting asset:C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-Core_x64\Assets1_1.zip
02/18/16 23:11:45:664 | [INFO] | | OOBE | DE | | | | 5764 | Setting file open option to false in the unzipper
02/18/16 23:15:47:101 | [ERROR] | | OOBE | DE | | | | 6296 | ASU has quit unexpectedly.
02/18/16 23:16:15:181 | [INFO] | | OOBE | DE | | | | 5764 | Extracting assets complete. Number assets: 2
02/18/16 23:16:15:182 | [INFO] | | OOBE | DE | | | | 5764 | Beginning installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-Core_x64\Install.db
02/18/16 23:20:34:309 | [INFO] | | OOBE | DE | | | | 5764 | Evaluating condition# 2(Seq 3223)
02/18/16 23:20:34:310 | [INFO] | | OOBE | DE | | | | 5764 | Condition failed(Seq 3223)
02/18/16 23:20:44:009 | [INFO] | | OOBE | DE | | | | 5764 | Evaluating condition# 2(Seq 4549)
02/18/16 23:20:44:009 | [INFO] | | OOBE | DE | | | | 5764 | Condition failed(Seq 4549)
02/18/16 23:21:56:357 | [INFO] | | OOBE | DE | | | | 5764 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Brick Fill.jsx Group/User:BuiltinGuests Access:GENERIC_ALL(Seq 5286)
02/18/16 23:21:56:358 | [INFO] | | OOBE | DE | | | | 5764 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Brick Fill.jsx Group/User:BuiltinUsers Access:GENERIC_ALL(Seq 5287)
02/18/16 23:21:56:463 | [INFO] | | OOBE | DE | | | | 5764 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Cross Weave.jsx Group/User:BuiltinGuests Access:GENERIC_ALL(Seq 5289)
02/18/16 23:21:56:464 | [INFO] | | OOBE | DE | | | | 5764 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Cross Weave.jsx Group/User:BuiltinUsers Access:GENERIC_ALL(Seq 5290)
02/18/16 23:21:56:530 | [INFO] | | OOBE | DE | | | | 5764 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Flame.jsx Group/User:BuiltinGuests Access:GENERIC_ALL(Seq 5292)
02/18/16 23:21:56:531 | [INFO] | | OOBE | DE | | | | 5764 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Flame.jsx Group/User:BuiltinUsers Access:GENERIC_ALL(Seq 5293)
02/18/16 23:21:56:675 | [INFO] | | OOBE | DE | | | | 5764 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Picture Frame.jsx Group/User:BuiltinGuests Access:GENERIC_ALL(Seq 5295)
02/18/16 23:21:56:675 | [INFO] | | OOBE | DE | | | | 5764 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Picture Frame.jsx Group/User:BuiltinUsers Access:GENERIC_ALL(Seq 5296)
02/18/16 23:21:56:852 | [INFO] | | OOBE | DE | | | | 5764 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Place Along Path.jsx Group/User:BuiltinGuests Access:GENERIC_ALL(Seq 5298)
02/18/16 23:21:56:997 | [INFO] | | OOBE | DE | | | | 5764 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Place Along Path.jsx Group/User:BuiltinUsers Access:GENERIC_ALL(Seq 5299)
02/18/16 23:21:57:241 | [INFO] | | OOBE | DE | | | | 5764 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Random Fill.jsx Group/User:BuiltinGuests Access:GENERIC_ALL(Seq 5301)
02/18/16 23:21:57:242 | [INFO] | | OOBE | DE | | | | 5764 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Random Fill.jsx Group/User:BuiltinUsers Access:GENERIC_ALL(Seq 5302)
02/18/16 23:21:57:330 | [INFO] | | OOBE | DE | | | | 5764 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Spiral.jsx Group/User:BuiltinGuests Access:GENERIC_ALL(Seq 5304)
02/18/16 23:21:57:331 | [INFO] | | OOBE | DE | | | | 5764 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Spiral.jsx Group/User:BuiltinUsers Access:GENERIC_ALL(Seq 5305)
02/18/16 23:21:57:332 | [INFO] | | OOBE | DE | | | | 5764 | Setting permission for: C:\Program Files\Adobe/Adobe Photoshop CC 2015/Presets/Deco Group/User:Everyone Access:GENERIC_ALL(Seq 5306)
02/18/16 23:21:57:441 | [INFO] | | OOBE | DE | | | | 5764 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Symmetry Fill.jsx Group/User:BuiltinGuests Access:GENERIC_ALL(Seq 5308)
02/18/16 23:21:57:442 | [INFO] | | OOBE | DE | | | | 5764 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Symmetry Fill.jsx Group/User:BuiltinUsers Access:GENERIC_ALL(Seq 5309)
02/18/16 23:21:57:508 | [INFO] | | OOBE | DE | | | | 5764 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Tree.jsx Group/User:BuiltinGuests Access:GENERIC_ALL(Seq 5311)
02/18/16 23:21:57:509 | [INFO] | | OOBE | DE | | | | 5764 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\Tree.jsx Group/User:BuiltinUsers Access:GENERIC_ALL(Seq 5312)
02/18/16 23:21:57:937 | [INFO] | | OOBE | DE | | | | 5764 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\_Deco Menu.jsx Group/User:BuiltinGuests Access:GENERIC_ALL(Seq 5314)
02/18/16 23:21:57:938 | [INFO] | | OOBE | DE | | | | 5764 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\_Deco Menu.jsx Group/User:BuiltinUsers Access:GENERIC_ALL(Seq 5315)
02/18/16 23:21:58:063 | [INFO] | | OOBE | DE | | | | 5764 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\_Deco Settings.jsx Group/User:BuiltinGuests Access:GENERIC_ALL(Seq 5317)
02/18/16 23:21:58:064 | [INFO] | | OOBE | DE | | | | 5764 | Setting permission for: C:\Program Files\Adobe\Adobe Photoshop CC 2015\Presets\Deco\_Deco Settings.jsx Group/User:BuiltinUsers Access:GENERIC_ALL(Seq 5318)
02/18/16 23:22:12:774 | [INFO] | | OOBE | DE | | | | 5764 | Evaluating condition# 1(Seq 5565)
02/18/16 23:22:12:774 | [INFO] | | OOBE | DE | | | | 5764 | Condition passed(Seq 5565)
02/18/16 23:22:14:636 | [INFO] | | OOBE | DE | | | | 5764 | Completing installation for payload at C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-Core_x64\Install.db
02/18/16 23:22:18:352 | [INFO] | | OOBE | DE | | | | 5764 | UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{793C2BF7-A4FE-4608-91C9-9282C5801C21}.db
02/18/16 23:22:20:487 | [INFO] | | OOBE | DE | | | | 6844 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 23:22:20:487 | [INFO] | | OOBE | DE | | | | 6844 | :: END TIMER :: [Payload Operation :{793C2BF7-A4FE-4608-91C9-9282C5801C21}] took 637353 milliseconds (637.353 seconds) DTR = 2693.94 KBPS (2.6308 MBPS)
02/18/16 23:22:21:684 | [INFO] | | OOBE | DE | | | | 6844 | User specified overrideFile:
02/18/16 23:22:24:282 | [INFO] | | OOBE | DE | | | | 6844 | Successfully updated the csu inventory for Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21} return values 0:0
02/18/16 23:22:24:283 | [INFO] | | OOBE | DE | | | | 6844 | Calling the custom action code for post-install for payload Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 23:22:24:283 | [INFO] | | OOBE | DE | | | | 6844 | Running PreferenceMigration tool for Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21}
02/18/16 23:22:24:284 | [INFO] | | OOBE | DE | | | | 6844 | OOBEUtils|ProcessUtils|||Launching Process as DeElevated:C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-Core_x64\PhotoshopPrefsManager.exe
02/18/16 23:22:27:411 | [INFO] | | OOBE | DE | | | | 6844 | OOBEUtils|ProcessUtils|||Launching Process as DeElevated :C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\Photoshop_16_LS20_win64\Adobe CC 2015\payloads\AdobePhotoshop16-Core_x64\PhotoshopPrefsManager.exe : SUCCESSFUL
02/18/16 23:22:28:644 | [INFO] | | OOBE | DE | | | | 6844 | Finished running PreferenceMigration tool. Exit code: 0
02/18/16 23:22:28:645 | [ERROR] | | OOBE | DE | | | | 6844 | DW001: Set payload cancelled status
02/18/16 23:22:28:646 | [INFO] | | OOBE | DE | | | | 6844 | No operation. We're done:
02/18/16 23:22:28:649 | [INFO] | | OOBE | DE | | | | 6844 | Updating driver data - Action: Remove driver entry
02/18/16 23:22:28:733 | [INFO] | | OOBE | DE | | | | 6844 | Updating driver data successful. Driver entry was added. ARP estimated size 1997481KB
02/18/16 23:22:31:435 | [INFO] | | OOBE | DE | | | | 6844 | Successfully installed 15 components:
02/18/16 23:22:31:435 | [INFO] | | OOBE | DE | | | | 6844 | - Export Assets 2 (64 bit)
02/18/16 23:22:31:435 | [INFO] | | OOBE | DE | | | | 6844 | - Photoshop Camera Raw 8
02/18/16 23:22:31:435 | [INFO] | | OOBE | DE | | | | 6844 | - Adobe Photoshop CC 2015 Support
02/18/16 23:22:31:435 | [INFO] | | OOBE | DE | | | | 6844 | - Microsoft Visual C++ 2013 Redistributable Package (x64)
02/18/16 23:22:31:435 | [INFO] | | OOBE | DE | | | | 6844 | - Camera Profiles Installer
02/18/16 23:22:31:435 | [INFO] | | OOBE | DE | | | | 6844 | - AdobeColorPhotoshop CC
02/18/16 23:22:31:435 | [INFO] | | OOBE | DE | | | | 6844 | - Photoshop Camera Raw 8 (64 bit)
02/18/16 23:22:31:435 | [INFO] | | OOBE | DE | | | | 6844 | - Microsoft Visual C++ 2013 Redistributable Package (x86)
02/18/16 23:22:31:435 | [INFO] | | OOBE | DE | | | | 6844 | - AdobeColorJA CC
02/18/16 23:22:31:435 | [INFO] | | OOBE | DE | | | | 6844 | - Adobe Preview CC
02/18/16 23:22:31:436 | [INFO] | | OOBE | DE | | | | 6844 | - AdobeColorNA CC
02/18/16 23:22:31:436 | [INFO] | | OOBE | DE | | | | 6844 | - AdobeColorCommonSetCMYK CC
02/18/16 23:22:31:436 | [INFO] | | OOBE | DE | | | | 6844 | - AdobeColorCommonSetRGB CC
02/18/16 23:22:31:436 | [INFO] | | OOBE | DE | | | | 6844 | - AdobeColorVideoProfilesCS CC
02/18/16 23:22:31:436 | [INFO] | | OOBE | DE | | | | 6844 | - AdobeColorEU CC
02/18/16 23:22:31:436 | [INFO] | | OOBE | DE | | | | 6844 | Successfully repaired 4 components:
02/18/16 23:22:31:436 | [INFO] | | OOBE | DE | | | | 6844 | - Microsoft Visual C++ 2012 Redistributable Package (x64)
02/18/16 23:22:31:436 | [INFO] | | OOBE | DE | | | | 6844 | - Microsoft Visual C++ 2010 Redistributable Package (x64)
02/18/16 23:22:31:436 | [INFO] | | OOBE | DE | | | | 6844 | - Microsoft Visual C++ 2010 Redistributable Package (x86)
02/18/16 23:22:31:436 | [INFO] | | OOBE | DE | | | | 6844 | - Microsoft Visual C++ 2012 Redistributable Package (x86)
02/18/16 23:22:31:436 | [INFO] | | OOBE | DE | | | | 6844 | Total components removed: 0
02/18/16 23:22:31:436 | [WARN] | | OOBE | DE | | | | 6844 | DW050: The following payload errors were found during install:
02/18/16 23:22:31:436 | [WARN] | | OOBE | DE | | | | 6844 | DW050: - Adobe Photoshop CC 2015 Core: Installation was cancelled due to abnormal termination.
02/18/16 23:22:31:436 | [WARN] | | OOBE | DE | | | | 6844 | DW050: - Adobe Photoshop CC 2015 English Language Pack_AdobePhotoshop16-en_US_x64: Installation was cancelled due to abnormal termination.
02/18/16 23:22:31:437 | [INFO] | | OOBE | DE | | | | 6844 | Call PostSession Custom Hook
02/18/16 23:22:31:440 | [INFO] | | OOBE | DE | | | | 6844 | :: END TIMER :: [Total Timer] took 1.59214e+006 milliseconds (1592.14 seconds) DTR = 1637.35 KBPS (1.59898 MBPS)
02/18/16 23:22:32:440 | [INFO] | | OOBE | DE | | | | 6844 | -------------------------------------- Summary --------------------------------------
02/18/16 23:22:32:440 | [INFO] | | OOBE | DE | | | | 6844 | - 0 fatal error(s), 2 error(s)
02/18/16 23:22:32:440 | [INFO] | | OOBE | DE | | | | 6844 | Win OS version: 6.1.0.0 64 bit Type: 1
02/18/16 23:22:32:440 | [INFO] | | OOBE | DE | | | | 6844 | ----------- Payload: Adobe Photoshop CC 2015 Core 16.0.0.0 {793C2BF7-A4FE-4608-91C9-9282C5801C21} -----------
02/18/16 23:22:32:440 | [INFO] | | OOBE | DE | | | | 6844 | ERROR: ASU has quit unexpectedly.
02/18/16 23:22:32:440 | [INFO] | | OOBE | DE | | | | 6844 | ERROR: DW001: Set payload cancelled status
02/18/16 23:22:32:440 | [INFO] | | OOBE | DE | | | | 6844 | Please search the above error string(s) to find when the error occurred.
02/18/16 23:22:32:440 | [INFO] | | OOBE | DE | | | | 6844 | These errors resulted in installer Exit Code mentioned below.
02/18/16 23:22:32:440 | [INFO] | | OOBE | DE | | | | 6844 | -------------------------------------------------------------------------------------
02/18/16 23:22:32:440 | [INFO] | | OOBE | DE | | | | 6844 | Exit Code: 7 - Unable to complete Silent workflow.
02/18/16 23:22:32:469 | [INFO] | | OOBE | DE | | | | 6844 | Successfully dumped analytics data at: C:\Users\Lenovo\AppData\Local\Temp\{4DA499BC-91BB-4308-ADA5-1C6FFC9A0E36}\{229E45D8-5E8F-49A2-87DA-D0EFB211F7A8}
02/18/16 23:22:32:469 | [INFO] | | OOBE | DE | | | | 6844 | Please see specific errors for troubleshooting. For example, ERROR: DW001 ...
02/18/16 23:22:32:471 | [INFO] | | OOBE | DE | | | | 6844 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
02/18/16 23:22:32:471 | [INFO] | | OOBE | DE | | | | 6844 | END - Installer Session
My lightroom seems to be working just fine. Please help! I need to use photoshop this urgent. I have a project needs to be completed very soon
Hi azmi792002,
Please go to this location on your machine : C:\Users\Lenovo\AppData\Local\Temp\{D602CEF3-A1FF-4CAC-BCCC-DDDE556B4D19}\{2E0014BF-75A4- 42D3-9121-0D5D2A5E9FC7}
When you'll open this folder you should see a Photoshop folder open it and run the setup file from there.
If you don't find this folder then empty the %Temp% folder ( Don't worry if few files doesn't get removed you can skip them )
1- Please do End Process/ Task from Task Manager in the same sequence as mentioned below from ta
...Copy link to clipboard
Hi azmi792002,
1- Please do End Process/ Task from Task Manager in the same sequence as mentioned below from task manager. see, Open Task Manager
2- Go to C:\Users\Lenovo\AppData\Local\Adobe - delete OOBE & AAM UPDATER folders from here
3- Go to C:\Users\Lenovo\AppData\Roaming\Adobe - Delete any folder that is for Photoshop CC 2015
4- After this navigate to the below mentioned folders :
5- Go to Control Panel > Programs & Features > look for Microsoft Visual C++ Re-distributable 2012 x64 and x86 > right click Uninstall > a window will pop up select REPAIR after this restart your machine.
6- Now launch Creative cloud app again and try installing Photoshop CC 2015.
Let us know if this helps.
Bani Saini
