Hello there,
I just bought and downloaded Lightroom 6 LS11 (non CC) from the Adobe Shop. When I start the install.app this shows up:
Installer cannot be initialized. Security settings on my iMac 5K with 10.11.3 allow installations from anywhere.
What to do here?
Thank you for Feedback
Bernd
Please follow the below steps to remove every thing related to Creative Cloud from the machine:
Hi bikuler,
"Installer Failed to initialize" is a generic error and we need to figure out what is causing the trouble. Most of the time, its an issue with the download that it was not successful or downloaded properly. So, in such cases, download the software again and make sure to compare the file size of the downloaded file with the file on the server. Install Photoshop Lightroom
Lets check that in this case as well and make sure the download is complete, If the file size is correct, we need the install.log file.
Navigate to the log files in one of the following folder : Mac OS: /Library/Logs/Adobe/Installers/
The log filename includes the product name and install date, followed by ".log.gz." The extension .gz indicates a compressed format.
Use a decompression utility such as Winrar or StuffIt to decompress the .gz file. -: WinRAR download and support: Post-Download
Once uncompressed, the log file is a plain text file, Open the .log file using TextEdit (Mac OS).
Note: By default, log files open in Console on Mac OS. Select all of the text by pressing Command+A, and then copy and paste it into a text editor before continuing.
Scroll to the bottom of the log. Look in the - Summary - section for lines that start with ERROR or FATAL and indicate a failure during the installation process.
Copy and Paste that SUMMARY section in here so that we can check the errors. You might also analyze the logs yourself. http://helpx.adobe.com/creative-suite/kb/troubleshoot-install-logs-cs5-cs5.html
Let us know if this helps.
Hi Bani,
thank you quick response.
All I could find in the logfile "Adobe Lightroom 6.0 02-19-2016.log.gz" with error was this:
02/19/16 19:47:52:525 | [ERROR] | | OOBE | DE | | | | 736616 | ASU has quit unexpectedly.
In the meantime I tried this:
To exclude a corrupted volume:
- deleted P-Ram
- deleted all Files in User/Library/Caches
- rebuilt the volume with DiskWarrior
same error...
Then I did the same with my MacBook Pro 17 inch (2010) which has also 10.11.3. installed.
I could install Lightroom 6 (non CC) on it! The installer worked (it was the same dmg I had downloaded before) and I could update Lightroom to the last version.
One Difference between my iMac 5K and my MacBook Pro is that I had installed Adobe CC products for testing purposes on the iMac.
I deleted now all CC versions from the iMac with the Adobe CC Cleaner Tool and tried again to install Lightroom.
same error...
In my pain I tried to copy all the files which had been installed for Lightroom on my MacBook to the iMac. No way: Error 1, please install again.
It seems that Lightroom 6 (non CC) cannot be installed on an iMac 5K with 10.11.3.
Or there is something remaining from the CC installations which had not been removed by the Adobe CC Cleaner Tool.
Another tortured user with an iMac 5K: Lightroom 6: Having problems installing on MacOS 10.11 | Photoshop Family Customer Community
Confused and sad
Bernd
***** These above changes are temporary you can revert these changes after the installation is done, as these could be one of the reasons the app is not installing ******
1- Force Quit the below processes in the same sequence as mentioned below from Activity Monitor: see, Use Activity Monitor on your Mac - Apple Support
2- Go To: Finder > Applications > Utilities > Adobe Installer > Uninstall Adobe Creative cloud ( if having trouble uninstalling it Trash it )
3- Go To: Finder > Applications > Utilities > ( Delete these two folders - Adobe creative cloud and Adobe Application Manager )
4- Then run the cleaner tool to remove creative cloud and Adobe Application Manager ( if still left in machine )
5- Right click on Finder icon and select "Go-To" Folder option.
6- You will get a text box, type-in below command and then hit 'Return' key.( " Do not miss ~ symbol " )
~/library ( It will open User Library folder. )
7- Then navigate to Application Support>Adobe> trash OOBE folder and AAM Updater folder as well
8- Again > Right click on Finder icon and select "Go-To" Folder option > You will get a text box, type-in below command and then hit 'Return' key.
/library ( It will open System Library folder.)
9- Then navigate to Application Support>Adobe> trash OOBE folder and Adobe Application Manager / after this rename the file SL-STORE as SL-STORE_OLD
10- Run Adobe Cleaner tool. > If present Select the option "Adobe Application Manager for Mac OS X 10.6" and then click on "Clean up Selected" .
http://download.macromedia.com/SupportTools/Cleaner/mac/AdobeCreativeCloudCleanerTool.dmg
11- After this follow the steps of SOLUTION 3 in the following document to correct the HOSTS file : Adobe Creative Cloud apps revert to trial mode after CC 2015 update
12- Click on the below link and download Creative Cloud Installer file and use the same to install the Creative Cloud Desktop application.
https://creative.adobe.com/products/creative-cloud
Hi Bani,
these processes do not exist on my computer:
As I have Adobe CS Web & Design Premium 6 installed I am not sure if I should follow your advice from the next points, especially: Uninstall Adobe Application Manager
As you've mentioned that there was Creative Cloud trial installed on your so to make sure that nothing related it left i have provided you the above steps.
If those processes are not running please skip that step.
If you don't see a file, folder in machine skip that step.
Problem is point 3:
There is a folder Adobe Application Manager,
but I am not sure if it belongs to the working Adobe Extension Manager CS6.app
so I am scared to delete it and destroy my working CS6 installation
Apologies for the wrong download link instead of Creative cloud the download you'll have to do after performing these steps will be of Adobe Application Manager .
In order to remove Creative Cloud you'll have to remove the above folders and then you can download the Adobe Application Manager for MAC from here : Adobe - Adobe Application Manager : For Macintosh : Adobe Application Manager
Just click install and once installed it creates an icon in Applications " Do not double click on it, as will then try to update your Adobe Application Manager to Creative cloud desktop app "
Yippie! It worked
Thank you so much Bani!
After completing all the steps you mentioned above I had to activate my CS Web & Design Premium 6 again, but the Lightroom 6 installer worked!
Happy
Bernd
Glad to hear that, You're welcome
Hello,
after several try, I finally managed to install Lightroom. I have additionally deleted, after study your and Adobe's instructions, all files as Adobe AIR and Adobe Lightroom and so on from the Library folder. After that I installed at first the Adobe Application Manager new again and then it worked. Without your guidance in cooperation with Adobe, it would never ever work. Thank you very much for your support and thanks to Adobe.
