13 Replies Latest reply on Mar 2, 2016 3:27 AM by Loic.Aigon
    Overflows property update process
    Loic.Aigon Adobe Community Professional
      Hi all,
      I am working on some process that produces unexpected results. It's a xml-based label production workflow and once the text is placed, I intend to fit it the best way. So basically I start setting a wide value and decrement through loop. My exit condition is that the story may not overflow.
      My main concern is that overflow value seems updated quite late. Given the picture, it stopped at 10pts like obvisously it should have stopped sooner like 11 or maybe 12pts. But looking at my log, the overflow returns true for those values. However if I apply them by hand it's perflecty ok.
      I also tried to call recompose and re-set reference for my story being tweaked (pointSize and leading) or using IDs but none of them changed anything.
      So I am really confused here. How reliable overflow is and what would be the best approach for you in this case ?
      //xe is a XMLElement Reference
      var main = function(xe) {
        var t = xe.texts[0].parentStory;
        t.pointSize = 36;
        t.leading = t.pointSize*1.2;
        while ( t.overflows ) {
        t.pointSize-=.5;
      Thanks in advance for your ideas.
      Loic
        • 1. Re: Overflows property update process
          Ronald63 Level 4
          Hi Loic,
          You can try with frame overflows ...
            var f = xe.texts[0].parentTextFrames[0];
            t.pointSize = 36;
            while ( f.overflows ) {
            t.pointSize-=.5;
          • 2. Re: Overflows property update process
            Alas, result is the same. The font size is reduced more than needed.
            Loic
            • 3. Re: Overflows property update process
              Ronald63 Level 4
              You write "However if I apply them by hand it's perflecty ok.", you change by hand pointSize and leading or just pointSize ?
              • 4. Re: Overflows property update process
                If I do manually set both leading and size I can set a bigger text. The script decreases more than it should. It like the point size/leading combination returns an overflows while it shoudln't at some point.
                • 5. Re: Overflows property update process
                  Ronald63 Level 4
                  Maybe a stupid idea ...
                    t.pointSize = 6;
                    while ( t.overflows == false ) {
                    t.pointSize+=.5;
                    t.pointSize-=.5;
                  • 6. Re: Overflows property update process
                    milligramme Level 3
                    Hi Loic
                    try following snippet I use sometimes.
                    but if `t.textContainers[0].recompose()` method didn't work well, it may not work.
                      t.pointSize = 36;
                      while ( t.lines.length !== t.textContainers[0].lines.length ) {
                        t.pointSize-=.5;
                    thank you
                    mg.
                    • 7. Re: Overflows property update process
                      Marc Autret Level 4
                      Hi Loic,
                      All suggested codes above (including yours) work for me, so your script probably undergoes some (of the many) latency issues.
                      EnableRedraw turned off? Working on a ghost document? Background tasks behind the scene? Obscure XML-wise problem? Etc.
                      Anyway I still suggest recompose() as a secure starting point, even if another problem is involved.
                      That aside, here is how I'd have implemented this routine:
                      var maximizePointSize = function(/*Story*/sto,  a,o,tx,mid)
                          // Settings
                          const MAX_SIZE = 36,
                                MIN_SIZE = 1,
                                LEADING_FACTOR = 1.2,
                                PRECISION = .1;
                          // Init.
                          a = [MIN_SIZE,MAX_SIZE];
                          o = { pointSize:MAX_SIZE, leading: MAX_SIZE*LEADING_FACTOR };
                          (tx = sto.texts)[0].properties = o;
                          if( !sto.overflows ) throw "You should increase MAX_SIZE";
                          // Dichotomy
                          while( a[1]-a[0] > PRECISION )
                              mid = (a[0]+a[1])/2;
                              o.pointSize = mid;
                              o.leading = mid*LEADING_FACTOR;
                              tx[0].properties = o;
                              sto.recompose();
                              a[+sto.overflows] = mid;
                          // Conclude
                          o.pointSize = a[0];
                          o.leading = a[0]*LEADING_FACTOR;
                      Marc
                      • 8. Re: Overflows property update process
                        Hi Marc,
                        Thanks a lot for the hint. I was on a break last week and couldn't reply sooner. I am clearly on a enableRedraw false mode and not showing documents while processed.
                        I will give your snippet a try and let you know.
                        See you soon my friend,
                        Loic
                        • 9. Re: Overflows property update process
                          Hi Marc,
                          That seems to work perfectly on a dummy sample. I will try it at my client's place and will let youy know. But I am quite certain it will be also functional
                          Loic
                          • 10. Re: Overflows property update process
                            Laubender Adobe Community Professional & MVP
                            Hm, couldn't that be an explanation for the strange behavior in your case?
                            enableRedraw set to false will speed things up for sure. Also not showing documents while processed.
                            But that comes with a price tag perhaps.
                            Uwe
                            • 11. Re: Overflows property update process
                              Obviously. However Marc's snippet is really promising.
                              Can't wait to test it in production.
                              • 12. Re: Overflows property update process
                                Bad news here, I think the latencies issues are unbreakable. It always end up with over-reduced texts.
                                I am thinking about using doing some geometry instead of looking at the overflowing property.
                                Thanks anyway,
                                Loic
                                • 13. Re: Overflows property update process
                                  Hello,
                                  Finally that worked once I moved the "recompose" method on top on the while loop.
                                  Thanks for your help all, I was getting crazy.
                                  Loic
