3
Paint bucket tool not working
Feb 22, 2016 Feb 22, 2016
Ever since the "Animate" update it's broken. I drew my frames as usual and when tring to fill in the character with the paint bucket tool nothing happened. All my lines are closed, I've redrawn them countless times, nothing. If I just draw a stupid simple circle though, I can fill that in just fine.
Product issue
86.4K
Community Expert , Feb 22, 2016 Feb 22, 2016
Okay so I got it to work. It appears the drawing - all segments of it - are inside a Drawing Object. Just double-click one of the lines to enter this object. Now you can fill.
Make sure you do not have Object Drawing turned on (J). If you click all of your separate strokes are inside an object, select them all and break apart to fill them or select them all and then select  Modify > Combine Objects > Union to combine them into a single object and then fill.
Animator and content creator for Animate CC
Neither is working
Try this. Select the Paint Bucket tool, look at the tool's sub-selections below it in the Toolbar. There are 4 settings:
Don't Close Gaps
Close Small Gaps
Close Medium Gaps
Close Large Gaps
Play with those and let me know
Yeah, I'm aware of those and none of them are working either
The only thing I can think of is you have different line segments on different layers. Can you provide a screenshot of your character including maybe more specifics as to how the timeoine is setup?
all on the same layer. What's in white can be filled in but the rest can't
Everything looks fine to me. Try this: zoom out so that the stage and image are about half that size and try to fill.
tried zooming out and in, i got a few more parts filled in but the rest seem to still be a problem for some reason
I'm assuming lines outside the visible stage area are closed also correct? The stage boundary doesn't have anything to do with the lines. Turn on the Snap feature (magnet icon) and use the black arrow to make sure ends of lines literally snap to other segments. I'm sure this is not the solution because the Close Large Gaps would have worked.
One thing that seems odd is that you have the Lock Fill button turned on. That would normally only be used for gradients. Not sure why it would mess up the fill, but could be worth trying with it deselected.
Yeah I have tried toggling that but nothing changes
Yes, everything in and out of the stage area is closed completely
Can you send me the FLA? Or post it for download somewhere?
https://www.sendspace.com/file/42rora
there is just the problem frame
Okay, thank you that appears to work
I'm not sure if this is new? Never had to do it before but if there's a way to turn it off so i can just fill it in regularly that'd be great
It's a feature called Object Drawing and was introduced to Animate a couple of versions ago - carried over from Illustrator. Yes it can be turned off - or toggled on/off more accurately. Select the drawing tool of choice and you'll see Object Drawing as a sub-selection tool. Click the Object Drawing icon to toggle it on/off. Or hit J on your keyboard.
Sep 19, 2023 Sep 19, 2023
DANG you went through alot of trouble for one user. Props to you
Apr 06, 2024 Apr 06, 2024
I don't know how to thank you but thank you so much @UDESCO i though I was going to fail my exams but this worked🥰 much appreciated
Adobe Employee ,
Feb 23, 2016 Feb 23, 2016
There's another option to help you flatten out the shape that you wish to fill-
Select the shape that you wish to fill, then choose from either of the highlighted options shown above in the Properties panel.
One is called - Create Object and the other is Break Apart.
Dec 22, 2022 Dec 22, 2022
It still isn't working
Dec 23, 2022 Dec 23, 2022
@Matthew27683288ip8s
create a new fla
take the minimum steps needed to show the problem you see with the paint bucket tool
embed a screenshot in a reply here showing your stage and the animate history panel
i'll duplicate your steps and see if i can find a fix for what you're seeing.
Apr 17, 2016 Apr 17, 2016
I had the same problem too. What I did was to select the Paint Bucket Tool; on the top tool bar, I clicked the downward facing arrow attached to the paint bucket tool icon, I then selected the settings list by clicking the 'Cog' shaped icon, I then selected the Reset Tool text and this corrected the error.
Aug 10, 2018 Aug 10, 2018
help me please,i maded the object with line tool to be sure no gaps will appeared and it didnt worked,i tried but it didnt worked,i turned off object drawing , but nothing
only the darrywl solution i didnt thied but il try
if you k another method please tell me it
or make an update that will automatically solve this problem please
