Encrypt Decrypt Problem
Feb 22, 2016 Feb 22, 2016
I am suddenly getting an error in a script that has been working for years where I encrypt an html file so that is can't be accessed via a browser and then decrypt it for later reference
The encrypting scheme is very basic:
<cfset archivefile="<HTML><BODY>" & paynowbutton & invoiceheader & invoicebody & "</body></html>">
<cfset tempinvoice=encrypt(archivefile,session.key)><!---session.key is a 4 digit PIN number--->
<cffile    action = "write"  file = "#application.LocalRoot#\invoices\#brokerid#_invoice.html"  output = "#tempinvoice#">
THEN TO UNENCRYPT
<cffile action="read"    file = "#application.LocalRoot#\invoices\#form.brokerid2#_invoice.html"  variable="invoice">
<cfset invoice=decrypt(invoice,session.key)>
THEN THE ERROR WHICH HAS BEEN INCREASING IN FREQUENCY
An error occurred while trying to encrypt or decrypt your input string: The input and output encodings are not same
ANY IDEAS??
546
Guide ,
Did you upgrade to a newer ColdFusion version after some of the encrypted files were generated?
Negative. In fact the code above fails immediately. As soon as is encrypted and saved as a file I can not decrypt it. I can however decrypt the encrypted content while it is still a variable (before storing as a file)
Guide ,
"Encodings" might be the important bit.  I'm not well-versed in the subject, but it might be reading and writing using different character sets.  Try adding the "charset" attribute to both CFFILE calls.
Advocate ,
Feb 23, 2016 Feb 23, 2016
My vote for the most likely cause is what Carl said: encoding.
A second more remote guess might be malware modifying your .html file with spam links, corrupting your encrypted data. I ran into this a couple years back with an account I had on a shared hosting provider. They had malware adding spam to html files.
Feb 24, 2016 Feb 24, 2016
I appreciate the suggestions, and adding charset on both ends of the transaction is a sound idea.
What I ended up doing though is recreating the documents as PDF wherever the decrypting failed, and will use this process going forward.
Documentation
