HTML5 output does not start on iPad/ MacBook (Presenter 11)
Jan 19, 2016 Jan 19, 2016
Hi there,
all of my HTML5 outputs won't work on a MacBook (El Capitan) and/ or iPad and iPhone (iOS 9.2).
I uploaded the complete output folder and its subfolders to a regular webspace, e.g. http://www.example.com/html5test/index.htm, but all I see when opening that page are the 4 animated loading squares and the words "Adobe Presenter" - nothing will happen otherwise.
I tried outputs with or without video/ audio, but to no avails. The Adobe help pages wouldn't solve this problem as well.
What am I doing wrong?
Best regards,
Oliver
(I posted the same question on connectusers.com)
Presenter
912
Adobe Employee ,
Jan 20, 2016 Jan 20, 2016
Hi Blik,
Sorry to hear about your issue.
Does your published HTML5 output work fine for Windows?
Also request you to kindly share your published output folder with me using drop box (zhussain@adobe.com).
Zeeshan Hussain
Adobe Presenter Engineering Team
Feb 23, 2016 Feb 23, 2016
This sounds similar to the issue being described here: Problem with HTML5 output
It may be worth checking to see if there is a missing js file and possibly work with Zeeshan to see if there is a correlation between what is being done in all your presentations to cause this situation.
have got the same result.
My system: Windows 10, Office 2016, Chrome and Firefox, Presenter11; all packets are uptodate.
I created a simple PPT with only two slides, a publish to HTML leads to the same output Blik described.
Adobe Employee ,
Could you please zip your Projects's published output folder and send it to me using drop box. (zhussain@adobe.com)
Also go to "File" menu on your PowerPoint, select "Account" option and then click "About PowerPoint".
Share the screenshot of the dialog box which opens stating the PowerPoint version.
Zeeshan Hussain
Ok, link sent to you,
thanks
Adobe Employee ,
Hi Klaus,
I have got your mail.
Please give me some time to figure this out. I will try to get it resolved ASAP and get back to you.
Thanks for your Patience.
Zeeshan Hussain
Adobe Employee ,
Feb 24, 2016 Feb 24, 2016
Hi Klaus,
I have sent you a separate mail on your email id providing the fix details.
Kindly verify if the fix is working for you and please mark this answer as correct if it works fine.
Zeeshan Hussain
Jun 09, 2017 Jun 09, 2017
Can you tell everyone what the fix is?  We're having a similar problem.  Everything plays fine on windows or android products.  But some of the presentations will not play properly on an IPad.  The "play" button is invisible -- although, if you press in the middle of the screen where it should be -- sometimes the presentation will play.  We need help!
Adobe Employee ,
Hi Oliver,
Sorry for the delayed response.
I tried opening the link you provided but I am unable to launch the html5 output and hence, cannot debug it.
Could you please zip your published output folder and share it with me using drop box.(zhussain@adobe.com)
Also please provide below mentioned details-
  • Presenter Version used to create the project.
  • OS in use
  • PowerPoint version along with the architecture type (32-bit/64-bit)
Zeeshan Hussain
Help resources
