server file extensions .css
Participant ,
Feb 22, 2016 Feb 22, 2016
Working with coldfusion developer edition.
Any file extension, such as .html or .css, throws a 404 error.
Of course, I need to be able to read a .css file into a template, so how do I do that?
952
Participant , Feb 27, 2016 Feb 27, 2016
For those who find this thread trying to solve the same issue, use the link above, when you get to where you need to run wsconfig
../ColdFusion/cfusion/runtime/bin/wsconfig
Guide ,
Are you working on a local development environment, and using the ColdFusion built-in web server?
Participant ,
Yes.
Guide ,
I think serving static assets from the built-in server has been problematic in the past. Where are you placing the static files (html or css)?  Are they in subfolders under C:\ColdFusion10\cfusion\wwwroot?
Participant ,
Feb 23, 2016 Feb 23, 2016
The index.cfm file and the style.css file are both in the same folder, which is in a folder, which is in wwwroot.
Guide ,
Can you provide a code sample showing how you are reading it into the template?
Participant ,
<link rel="stylesheet" type="text/css" href="style.css">
And if I HTTP to the correct path ... localhost:8500/path/path/style.css I get a 404 error.
If I put an html file under localhost:8500, I get a 404 error.
Guide ,
Feb 24, 2016 Feb 24, 2016
I generally don't use the built-in web server on my development environment, so I can't say whether this is normal behavior or not.  I generally use IIS, which is very easy to integrate (using the Web Server Configuration Tool or WSCONFIG).  Maybe someone else who is using the built-in server can chime in?
Participant ,
IIS is windows, correct?
Mac comes preinstalled with Apache, which I tried starting, but it's a different directory path and I haven't figured out how to fix that.
Irritates me that Adobe wouldn't have instructions on proper configuration and integration.
Guide ,
There should be a Web Server Configuration Tool on Mac too, and that should allow you to connect to Apache. I have zero Mac experience, so hopefully someone else can chime in.
Participant ,
Based on that comment, I found this article
https://helpx.adobe.com/coldfusion/installing/configuring-your-system.html
with this note:
Note: Configuring Apache is not supported on Mac 10.10.5.
I'll try searching around some more to see if there's any hope here ...
Guide ,
Are you running Mac OS 10.10.5?  I think they are saying it isn't supported on that particular release.  Also, that page is for ColdFusion 2016 - is that the version you are using?
This pretty much means (I think) that Adobe hasn't created a script for automatically configuring Apache on OSx.  Which isn't surprising, considering that the later versions of OSx are really an Apple GUI over a FreeBSD OS, and not a native Apple OS.
Find instructions for configuring CF under Ubuntu via terminal (not desktop GUI).  These instructions should get you pointed in the right direction.  I've configured CF11 (Java 8) on Ubuntu Server (Trusty Tahr), and it's just modifying a few config files, point to the CF /bin folder, and a few other easily done commands, and VOILA!  You'll be up and running in no time.
HTH,
^_^
Participant ,
I tried finding the Ubuntu instructions and had no luck.
I did find this
http://www.trunkful.com/index.cfm/2012/12/26/Installing-ColdFusion-10-on-OS-X-Mountain-Lion
And was making good progress, I thought, until I got to these instructions:
Once you have terminal running execute these commands:
1>$ cd /Applications/ColdFusion10/cfdev/runtime/bin
2>$ sudo ./wsconfig
This will launch the Java based GUI for wsconfig.
Which doesn't match any kind of reality I'm dealing with on OS 10.11 with CF 11.
I'm going to poke around in google some more to see if I can find better instructions, but I'm stuck at this point ... but at least I've got Apache pointing to my working root directory.  It's just not passing CFML commands to CF.
Participant ,
Success.
Finally found the right path to wsconfig and am all set.
Participant ,
Documentation
