I downloaded Robohelp 2015 the other day. A company from which we receive some help projects is using RH 11 while we are at RH 9.
To stay in sync and to be able to work on their project (we have to extract some portions and build our own HTMLHelp project/files)
we need keep up to RH11.
I found that the project build window in the left column (to build a Microsoft HTMLHelp file) is not there. There seem to be an item Microsoft HTML Help in the ribbon bar though. But despite from rearrangements of elements in a new look and feel (possibly WPF or sth.) I cannot see any advantage of RH2015 over RH 11 or RH 9.
And I don't think any improvements have been made on MS HTML Help generation since it was an obsolescent model for years anyway (but still being used in many places).
Christoph
It is still available at Adobe, but they don't advertise it. If you want to download the trial, see: Adobe Direct Download Links Without Akamai Download Manager | TECHNOLUX There are links for RH9, but if you change the version in the file name, you can get RH11 as well.
As for licensing, Adobe doesn't sell the RH11 licenses anymore. A third party supplier might still have them around. But if you have a subscription plan for RoboHelp, you can also use that for your RoboHelp 11. In that case, you can run RH11 and 2015 side by side using the same license.
Hi William,
thanks for the tip. In principle that is nice, but it turns out to be difficult. I'm on the page of TECHNOLUX and I found the RoboHelp9 link. Editing the 9 to 11 leads to a "file not found" error. It seems to work if I change the 9 into 10. But not with the "11".
Or am I doing sth. wrong?
Christoph
It seems the URL changed. The correct one is: http://trials3.adobe.com/AdobeProducts/RBHP/11/win32/RoboHelp_11_LREFDJ.7z
Thanks. Looks like it is blocked now. I could downoad it two days ago. Now trying to do it again I'm getting an access denied although I'm logged in with my Adobe ID in the same browser session.
Well, I got it but still wondering...
Christoph
I'm coming back again to this topic: Having bought the RH2015 license now it turns out that I cannot use RH11 together with it.
It would be nice if I could though. Any means to ask Adobe support for granting this?
Christoph
Why can’t you use RH11 & RH2015 on the same machine? What are you seeing that’s stopping you?
Because I bought a license for RH2015. What I had licensed before, was RH9.During the trial period I had RH-11 (trial) and RH2015(trial) running on the same machine. That was indeed no problem.
My thought just is: since RH11 isn't officially available anymore (just through the above mentioned archives), why wouldn't allow Adobe me to use an "inferior" version (one lower) to be compatible with my partner (RH11).
I got an advice meanwhile how I could achieve interoperability by exchanging projects on the base of .HHP files with deleting the .cpd before importing.
Christoph
Ok, so you missed the part where you needed to buy the RH9 to RH11 upgrade license (which would have got you RH9 and RH11 on the same machine), then purchased the RH2015 license.
I'm no licensing expert nor did I stay at a Holiday Inn Express last night, but it's my own understanding that only a full license is really acceptable for allowing use of both an older and a newer version to coexist. At least, from the legal standpoint. Now practically speaking, I'm not sure it would really matter in the end and I don't believe anything exists that prevents it.
Cheers... Rick
LOL – I think the upgrade price just entitles you to the newer version (probably for less than a brand new license); and the upgrades don’t get installed overtop of prior versions – so at one point I had RH9, 10 & 11 all on my machine.
I was told by someone in Adobe, albeit not in the licensing section, that it was OK to buy an upgrade and leave the old version installed.
Whilst it is possible to mess about and be on different versions, it is not advisable. I have seen people report that on explaining the scenario to Adobe, they were able to get an earlier version download.
Thanks to all. I just learnt from our local distributor that there is a way to buy a "right to downgrade" for a low fee (50 $ or so)
and one would get a download link and a license key to use the inferior version in addition to the one one has bought the full license for.
Christoph
I don't think Adobe charge. Try going direct.
