I have a server with an installation of ColdFusion 10 however the ODBC Services did not get installed with the initial installation. Is there a simple, manual method for installing ODBC Services without uninstalling CF and then reinstalling with that option selected? I have tried running the installation over the current one but with the Configure Installer window, it has Server Configuration greyed out as it has found a current installation. It then gives an option of either EAR file or WAR file in the JEE configuration. Not sure which to choose so that's why I ask the question of a manual install.
Thanks in advance. This is running on a Windows Server 2008 R2 64-bit box.
Dave
Here is the script to install ODBC services
<cfscript>
//login using admin
//createObject("component","cfide.adminapi.administrator").login("administrator_password");
createObject("component","cfide.adminapi.administrator").login("admin");
//instantiate datasource object
myObj = createObject("component","cfide.adminapi.datasource");
</cfscript>
To Install ODBC Services:
<cfscript>
writeOutput("Installing ODBC Services...<br>");
returnValue = myObj.installODBCservice();
writeOutput("ODBC Services installed");
</cfscript>
Anit Kumar
This issue has resurfaced. I try to run this script but all I get is a screen with a large blue circle with the word Error inside it.
Any advice?
Dave
Can you try to uninstall the corrupt service first, by using the below code.
<cfscript>
//login using admin
</cfscript>
NOW TO REMOVE ODBC SERVICES:
<cfscript>
writeOutput("Removing ODBC Services...<br>");
returnValue = myObj.removeODBCservice();
writeOutput("ODBC Services removed");
</cfscript>
Delete all the .trc files available at \cfusion\db\slserver54\tracing\ .
And then install using the below code.
<cfscript>
//login using admin
//createObject("component","cfide.adminapi.administrator").login("administrator_password" );
</cfscript>
<cfscript>
</cfscript>
Anit Kumar
