My computer has an authorized Adobe Digital Edition (v. 2.0), but when I try to download an e-book borrowed from the library, a “license key” problem prevents the download.
Feb 19, 2016 Feb 19, 2016
452
Feb 21, 2016 Feb 21, 2016
Which error message you get exactly?
Feb 23, 2016 Feb 23, 2016
Thank you for responding.
The verbatim message. The message box is from Digital Editions.
Unable to Download.
Error getting license. License Server Communication Problem:
E_AUTH_BAD_DEVICE_KEY_OR_PKCS12
I hope this info points toward a solution. Thanks again.
Macintosh:
  1. quit Adobe Digital Editions.
  2. Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
    If you are using 10.7, see Access hidden library files | Mac OS 10.7 and later.
  3. Open Adobe Digital Editions and reauthorize.
Windows:
  1. Close all applications.
  2. Choose Start > Run.
  3. In the Open text box, type regedit and then press Enter. The Registry Editor opens.
  4. In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
  5. Select the Adept key.
  6. Choose File > Export.
  7. In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
  8. Right-click the Adept key and choose Delete.
  9. In the Confirm Key Delete dialog, click OK.
  10. Close the Registry Editor.
  11. Open Adobe Digital Editions and reauthorize.
Feb 24, 2016 Feb 24, 2016
This looks promising but in my Registry Editor I couldn't find Software/Adobe.
HKEY_CURRENT_USER has hundreds of subfolders, but no “Software”.
My Registry Editor has four other folders. When I searched for Adobe, it only appears in the following location:
Folder: HKEY_CLASSES_ROOT
subfolder "acrobatsecuritysettings"
item Content Type RG_SZ. Data "application/vnd.adobe.acrobat-security-settings"
When I searched for adept, it appeared in the same folder, then subfolder "acsm"
Content Type RG_SZ, item "application/vnd.adobe.adept+xml"
Do you think these files can be used to proceed with your instructions 6 through 11?
Thank you again.
jt
Do used a normal user or a network user?
Feb 25, 2016 Feb 25, 2016
I'm a normal user.
Then you should have the registry. But you has install the software as admin?
Feb 28, 2016 Feb 28, 2016
Nanaky,
This is just to thank you for your efforts to help a stranger.
I'm giving up. I tried uninstalling ADE and installing it anew but that didn't help. I can still use my Nook for everything except borrowing library books.
jt hopeful
Digital Edition are by uninstall not remove the registry for the authorize. This can do only over the registry or the menue point.
