blazeDS
Avatar
Level 1
i want to create one simple application using blazeDs with
Flex3 can anyone give me basic tutorial which i can use to create
one application, am too confuse with tomcat installation
Avatar
Level 1
Could you tell me what specific problem are you getting with
tomcat installation? I am not a guru but may be I can help you out
with running simple blazeDS application.
If you have tomcat installed just put blazeds.war file into
/webapps directory, and while creating flex project check "use
remote object service " and select "Live Cycle Data Service"
Option. your server would be J2EE in case of tomcat. then you can
provide root Folder location pointing to blazeds installation
"C:\Apache\tomcat 5.5\webapps\blazeds" (my tomcat is installed in
this location). root url would be "
http://localhost:8080/blazeds".
This would create project. then there are tutorial available to
configure different services. The simplest one for remoting is:
http://western-skies.blogspot.com/2006/07/flex-worlds-simplest-example-of.html
Pelase let me know if this is what you looking for.
Avatar
Level 1
here am giving details what i done plz rectify:
1) download blazeds with integrated tomcat server (blazeds
turnkey)
2) extracted it in C:\setups
3) created Java Class to
C:\setups\blazeds\tomcat\webapps\blazeds\WEB-INF\classes\
4) Using Flex Builder 3 i create Flex Project with
application Server typed J2EE
5) using below values to configure project:
root Folder: C:\setups\blazeds\tomcat\webapps\blazeds
root URL :
http://localhost:8080/blazeds/
context root: blazeds
outPut folder:
C:\setups\blazeds\tomcat\webapps\blazeds\tempApplication-debug
6) and here start my mxml code
when i click on run the project: but it displayed "The page
cannot be displayed"
I followed the above steps from:
http://sujitreddyg.wordpress.com/2008/01/14/invoking-java-methods-from-adobe-flex/
plz tell me where i am wrong,
Avatar
Level 1
To me these steps are looking fine, did you change the server
port for tomcat? as by default turnkey tomcat runs on 8400 and you
are using 8080? another thing is context root is "/blaseds", it
might be a typo just wanted to make sure though. because I get this
error when either my server is not running or application is not
deployed in the directory.
You could check in output folder location that you have
required code to run your application there.
