Bookmark Stored with Wrong Topic
Apr 30, 2008 Apr 30, 2008
I created a bookmark "AddFS" in a topic called "Funding Source." On the Hyperlink dialog box, I went to select the bookmark "AddFS" and it was not stored under "Funding Source" but under another, unrelated topic called "Funding Source Transfers." I tried deleting and re-entering the bookmark and hyperlink but problem was not fixed. I am using RoboHelp 7 and am a long time user of RoboHelp and have never seen this problem before.
Is there a file were bookmarks and their respective files can be edited? The only fixes I can think of is renaming the original file to something that is not similar to the existing file; i.e., change "Funding Source" to "System Funding Sources." The other is to delete the "Funding Source Transfers" topic and re-create it.
Is this a bug in RoboHelp 7?
Elizabeth
431
Community Beginner , Apr 30, 2008 Apr 30, 2008
Your solution did solve the problem: Use Project Manager set to View by File Name and then add the hyperlink. When I select View by Topic Title and add a hyperlink, I see the bookmark listed under the wrong file. When I select View by File Name and add a hyperlink, I see the bookmark under the right file. This is definitely a change or perhaps a bug that wasn't in versions prior to RH 6.
Thanks very much for the help.
Welcome to our community, Elizabeth!
This is a change that occurred with RoboHelp HTML 6 I think. If your topic is inside a folder it displays this way in the Hyperlink dialog. Try changing to the "All folders" view and it should look as you expect.
Cheers... Rick
Rick,
I will try to make the issue clearer: I added a bookmark to one file but the bookmark is now listed as part of another file, which is the wrong file.
Let's say I have a file called Funding Sources.htm. It has 2 bullets at the top: Add a Funding Source and Edit a Funding Source. In the same file are two corresponding tasks with the same names: Add a Funding Source and Edit a Funding Source. I put my cursor in front of the first task and insert a bookmark I call "AddFS." Then I select the bullet "Add a Funding Source" and try to add a hyperlink to "AddFS". What happens next is the problem: When I go to the Hyperlink dialog box and select the destination file, which is Funding Source, the bookmark "AddFS" is not there. It's under a different file with a different (but similar) name. So, when the user clicks on the bullet Add a Funding Source, the wrong file opens. I have tried deleting and re-inserting the bookmark but it still is getting saved to the wrong file. I hope the issue is clearer and you can help?
Elizabeth
Hi again Elizabeth
Are you up for a desktop sharing session so that I may see first hand what you are describing? If so, shoot me an E-Mail to rstone75 (at) kc (dot) rr (dot) com and I'll send a link where we might connect and I can watch it in action.
I'll be available for about another half hour to 40 minutes or so before I have to head out.
Cheers... Rick
Yes, I'd like to try a desktop connection. I emailed you. Let me know if you do not get the email. My email is :
istcerr (at) omh (dot) state (dot) ny (dot) us.
Elizabeth
Hi again
You should probably edit your post and remove your E-Mail address. If you leave it there, it's likely to become a spam magnet. :wiink;
Cheers... Rick
RoboHelp Documentation
Download Adobe RoboHelp
