I'm trying to get a simple perl script to run via CFEXECUTE
on a Unix box running CFMX 7.02 and have not been successful. I
have spent considerable time searching and have not found a working
solution.
I have full control of the box and it's in a development
environment behind a firewall. I've set permissions wide-open,
moved the file, etc. and have not been able to get the cfexecute to
work. The output file is blank. The file works on our CF5 instance
(also unix).
Any help would be appreciated.
This is a simple perl script that simply inserts a record in
an Oracle database - and works fine from the command line as the
user the runs CF on the box. This is a basic test script I wrote to
debug this issue.
Here is the command:
<CFEXECUTE name="/disk1/cnav0/bin/it_tools/test_script.pl"
outputfile="/tmp/test_script.txt"
timeout="30">
</CFEXECUTE>
I have tried:
<CFEXECUTE
name="/usr/local/bin/perl"
arguments="/disk1/cnav0/bin/it_tools/test_script.pl"
timeout="30">
</CFEXECUTE>
