Trying to find out why the code below is not deleting all files from the target folder.
After some test it appears that only graphic files (jpg, png, gif) are being removed, skipping pdf, txt, eps, doc, docx, etc.
Have you seen this happening before? Thanks,
#target framemaker
var aGraphicFiles = [];
//Check for target folder existance, if not, create.
var myTargetFolder = new File("C:\\Basket2\\XML Tests\\BookFolder\\Resources\\DeleteMe");
if (!checkFolderExists(myTargetFolder)){ //target folder does not exist
myTargetFolder = new Folder("C:\\Basket2\\XML Tests\\BookFolder\\Resources\\DeleteMe");
myTargetFolder.create();
//Check if folder DeleteMe is empty
aGraphicFiles = myTargetFolder.getFiles();
if (aGraphicFiles.length != 0){
for (i=0; i<aGraphicFiles.length; i++){ //scan array
var sourceChild = aGraphicFiles;
if (sourceChild instanceof File){
sourceChild.remove();
if (sourceChild instanceof Folder){
alert("I found a folder");
function checkFolderExists(myObj){
var flagEx = false;
if (myObj.exists){
flagEx = true; //alert("myTargetFolder exists");
} else {
flagEx = false; //alert("myTargetFolder does NOT exist");
return flagEx;
Hi funsekon,
here an example, that works:
Unfortunately the editor doesn't accept code at the moment, so I have to put it here this way:
Just some notes to your code:
It's easier to check, if a file exists:
if (objfile.exists).......
The reason your code doesn't work
you have to define a File Object to delete/remove it. : sourceChild = new File(aGraphicFiles)
Your Line 3 :
should be
var myTarget
...Copy link to clipboard
Hi funsekon,
Your Line 3 :
should be
var myTargetFolder = new Folder("C:\\Basket2\\XML Tests\\BookFolder\\Resources\\DeleteMe");
BTW: BE CARFUL WITH THIS SCRIPT --- IT WILL ULTIMATELY DELETE ALL FILES !!!!!!!!!!!!!
var oFolder = new Folder("C:\\test\\deleteme"); |
var oStartFolder = oFolder.selectDlg ("Select Folder"); |
if (oStartFolder != null) | |
DeleteFilesInFolder(oStartFolder); | |
function DeleteFilesInFolder(foFolderName)
var locError = false; |
var DeleteFolder = new Folder(foFolderName) |
var foFolderContent = DeleteFolder.getFiles (""); |
for (var i = 0; i < foFolderContent.length; i++) | |
if (foFolderContent instanceof File) | |
var FileToDelete = new File (foFolderContent); | |
FileToDelete.remove(); | |
if (FileToDelete.error > "") | |
locError = true; | |
alert("Error deleting File: ") + FileToDelete.fsName; | |
Thanks Klaus. Was not aware of the fact that a new object was required in order to remove the actual files. Your script worked perfectly (thanks for the warning about deleting all files).
