quote:
Are you saying that locally stored WebHelp will not open pdf files if you don't have Acrobat on the hard drive? Or are you referring to pdf files stored only on the network?
quote:
Originally posted by: MSCaroline
...Rather, they say that when they build an installation, they must specify each and every file that has changed. I can't really speak to their process, but if this is accurate, I can see how an uncompiled format would be daunting!
Has anyone ever run into this particular objection? ... Has anyone had any experience packaging WebHelp output into some single file, such as perhaps a self-extracting zip archive or ...?
A side note: GEWB, I'm interested by your comments about Flash. Is it common for companies/organizations to forbid or frown on its use? I actually am still making a decision between WebHelp and FlashHelp, so this could be very useful information for me.
quote:
You have the application and help files on the local machine, and the developers want to move just the help system, is that correct?
What benefit do they have in mind? Do you frequently update the help system between releases of the application? Are they just trying to separate the two installations?
