1 2 Previous Next 79 Replies Latest reply on Jan 3, 2017 1:03 AM by Matt Peter Waltt
    Bridge CC keeps crashing when viewing folder
    Digital Halftones Level 1
      I just thought I'd post this here for anyone else that was having this same problem. I recently updated from Bridge CS6 to CC and kept experiencing crashes with CC after viewing one particular folder. I thought it was an issue with CC as CS6 didn't crash with the folder, so I went into problem solving mode to figure it out. First thing I did was go to edit - preferences - cache and purged the cache folder. I then went to the folder that caused the crash and watched the filter - label in the bottom left to see what number it was counting down as it extracted each thumbnail to be cached. Once it crashed I made note of the last number I saw, which was 33. I then went into the folder outside of bridge, counted down 33 files and removed the file from the folder which solved the problem. It appears that the file had become corrupted at some point, so that is why the new CC couldn't make a thumbnail, but CS6 could as it was already on file. So if you are experiencing crashes while viewing certain folders in Bridge, you might want to try this out.
        • 1. Re: Bridge CC keeps crashing when viewing folder
          goonerang
          I am experiencing the same issues with files that I have created using video editing in Photoshop CC. After rendering the files from PSD to Mp4's, and previewing within the folder, Bridge hangs and crashes. This is happening consistently whenever there's an Mp4 in the folder I've viewing, so I know they're not corrupted. I'm actually now creating a folder within the folder to "hide" the Mp4's thumbnail preview. This is the only solution I could come up with for the moment.
          Can someone in Adobe-land offer some feedback or a fix for this?
          • 2. Re: Bridge CC keeps crashing when viewing folder
            Level 5
            Use a proper video program to edit video files.
            • 3. Re: Bridge CC keeps crashing when viewing folder
              tingleguts23
              I'm having the same issue. Bridge crashes whenever I navigate to certain folders. It seems to be related to the generation of particular thumbnails but I'm not sure why that should be. It's a bug that needs fixing, pronto.
              • 4. Re: Bridge CC keeps crashing when viewing folder
                pammm56
                I'm having a similar problem. I can't right click to do something with collections without it crashing.
                • 5. Re: Bridge CC keeps crashing when viewing folder
                  PaulieDC Level 2
                  "Use a proper video program to edit video files."
                  Nonsense. That has nothing to do with this. I have the SAME issue, when I try to view a folder of MP4 files (that were converted from native using the beloved Adobe Media Encoder), Bridge crashes. The video editing program is irrelevant, an MP4 with the correct meta data will work. Photoshop is video editing capable, Bridge has a serious MP4 thumbnail-viewing bug.
                  • 6. Re: Bridge CC keeps crashing when viewing folder
                    coreyb67190545 Level 1
                    Happens to me too.  It usually happens after i update some programs.  Most recently the different 2015 apps.  Last time i uninstalled it and reinstalled but its kind of a POA since I have the folders navigated how i like now.
                    • 7. Re: Bridge CC keeps crashing when viewing folder
                      uninstall and reinstall fixed the issue for me again.  It doesnt like trying to have the old apps open your thumbnails after you update them.
                      • 8. Re: Bridge CC keeps crashing when viewing folder
                        sm-jw
                        Bridge is still crashing when viewing a folder that contains video-files like .mov or .mp4 - even after reinstalling bridge. Are there any other workarounds that may solve the problem?
                        • 9. Re: Bridge CC keeps crashing when viewing folder
                          PaulieDC Level 2
                          Two things you can try and they are both shot-in-the-dark, but let's see what happens.
                          First and as mentioned earlier by someone, Bridge doesn't play nice when dealing with a networked drives and I'm starting to believe that includes a DropBox or OneDrive folders. Here's why I mention that, because I never navigated to either of those folders directly, BUT, I did make a Library in Win8 and called it "Cloud" and I pointed that Library to DropBox and OneDrive. WELL, in Bridge Preferences on the General settings page you can check/uncheck the Favorites locations for Bridge to monitor, such as Desktop, User Folder, etc, and one of the choices is Libraries. I unchecked that and it solved my issues including the video file thing you're battling. But there's another thing to check... the other issue is Bridge's attempt to make thumbnails and I think that's the biggest reason why video files bomb. Go to the Cache page and make sure that "Keep 100% Previews in Cache" is UNCHECKED. Then go to the Advanced page and UNCHECK "Generate Monitor-size previews". Restart Bridge and see what happens, and let me know.
                          1 person found this helpful
                          • 10. Re: Bridge CC keeps crashing when viewing folder
                            BIPC Jeff Sydor Level 1
                            Thanks PaulieDC, that made sense to me but for some reason it still doesn't work for me. I wish there would be a temporary fix that would not generate thumbnails for video files.
                            • 11. Re: Bridge CC keeps crashing when viewing folder
                              Driver265
                              Uninstall from the CC app, including all preferences. Reinstall through the app. You should be good to go.
                              • 12. Re: Bridge CC keeps crashing when viewing folder
                                beni
                                Experiencing same repeated crashes upon viewing folders...
                                Uninstall and reinstall didn't help.
                                Please can someone provide a workaround?
                                Thanks.
                                • 13. Re: Bridge CC keeps crashing when viewing folder
                                  VikramSethi Adobe Employee
                                  Hello,
                                  Please go through this link and try the workaround suggested:
                                  Workaround to fix Bridge CC 6.1.1 and 6.2 crashing on Mac OS X El Capitan
                                  Vikram Sethi
                                  • 14. Re: Bridge CC keeps crashing when viewing folder
                                    ShaneH Level 1
                                    I'm having the same problem. Bridge is CONSTANTLY crashing. It's getting to the point that I'm having to use Mac OS to search and sort photos. I've tried rebuilding, deleting preferences, etc. But it just goes back to crashing after all these attempts. It seems to have happened with the latest update.
                                    • 15. Re: Bridge CC keeps crashing when viewing folder
                                      beni Level 1
                                      Hello,
                                      Vikram Sethi
                                      this procedure didn't work too...
                                      Bridge is still crashing on me...
                                      • 16. Re: Bridge CC keeps crashing when viewing folder
                                        ShaneH Level 1
                                        I tried this, restarted, and same thing.  InDesign is crashing over and over again as well. It seems to have happened with the latests updates. My colleague has not upgraded since 11.1.0, and she is not having any of these issues.
                                        • 17. Re: Bridge CC keeps crashing when viewing folder
                                          LibbieCStagers Level 1
                                          The workaround worked for me, but I actually quite like using my second monitor as a space, it means I have menu bars on both screens which is useful. Is there a fix coming for this so I can keep using my display as a space?
                                          • 18. Re: Bridge CC keeps crashing when viewing folder
                                            beni Level 1
                                            So still no solution for those infamous bugs?
                                            While we pay our fee each month, Photoshop and Illustrator CC2015 are awfully lagging and beachballing, inDesign CC2015 is full of interface glitches, and Bridge keeps crashing and crashing...
                                            We have a big performance problem here, is someone aware of that here?
                                            Please dont bother me with known troubleshooting procedures... I tried all available troubleshooting recommandations, and no one is effective...
                                            And the best i can say, is that CS 5.5 is still working like a charm
                                            Please, we are wasting a lot of time and therefore a lot of money.
                                            Thank you.
                                            • 19. Re: Bridge CC keeps crashing when viewing folder
                                              Hello,
                                              Can you please share the crash stack?
                                              Vikram Sethi
                                              • 20. Re: Bridge CC keeps crashing when viewing folder
                                                beni Level 1
                                                Process:               Adobe Bridge CC [24679]
                                                Path:                  /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/MacOS/Adobe Bridge CC
                                                Identifier:            com.adobe.bridge6
                                                Version:               6.2.0.179 (6.2.0.179)
                                                Code Type:             X86-64 (Native)
                                                Parent Process:        ??? [1]
                                                Responsible:           Adobe Bridge CC [24679]
                                                User ID:               501
                                                Date/Time:             2016-03-09 13:37:44.830 +0100
                                                OS Version:            Mac OS X 10.10.5 (14F1605)
                                                Report Version:        11
                                                Anonymous UUID:        EBAAC328-2AA9-49C8-9B1D-D98D340032C4
                                                Time Awake Since Boot: 24000 seconds
                                                Crashed Thread:        0  Dispatch queue: com.apple.main-thread
                                                Exception Type:        EXC_BAD_INSTRUCTION (SIGILL)
                                                Exception Codes:       0x0000000000000001, 0x0000000000000000
                                                Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
                                                0   MMXCore                       0x000000011b7be360 X2_ResampleV + 2928
                                                1   MultiProcessor Support         0x000000011b701cc3 MPResampleV(unsigned char const*, unsigned char*, int, int, int const*, unsigned char const*, int, int, short, short const*) + 195
                                                2   com.adobe.bridge6             0x000000010d01a14c ThumbMetaLib::ResizeThumbImage(boost::shared_ptr<ThumbMetaLib::Pixels>, int, int, short, bool) + 3740
                                                3   com.adobe.bridge6             0x000000010d017d3f ThumbMetaLib::ResizeThumbImagePS(boost::shared_ptr<ThumbMetaLib::Pixels>, int, int, short, bool) + 1951
                                                4   com.adobe.bridge6             0x000000010d01729c ThumbMetaLib::ResizeWithQuality(boost::shared_ptr<ThumbMetaLib::Pixels>, int, int, ThumbMetaLib::ScaleQuality, bool) + 348
                                                5   com.adobe.bridge6             0x000000010d020d88 ThumbMetaLib::Pixels::ResizeAndAllowUpSampling(unsigned int, unsigned int, ThumbMetaLib::ScaleQuality) + 328
                                                6   com.adobe.bridge6             0x000000010cc07116 0x10caa2000 + 1462550
                                                7   com.adobe.bridge6             0x000000010cc075ed 0x10caa2000 + 1463789
                                                8   com.adobe.bridge6             0x000000010cc0cbfa 0x10caa2000 + 1485818
                                                9   com.adobe.bridge6             0x000000010ceb4a66 0x10caa2000 + 4270694
                                                10  com.adobe.bridge6             0x000000010ceb4581 0x10caa2000 + 4269441
                                                11  com.adobe.bridge6             0x000000010ceb6ad5 0x10caa2000 + 4278997
                                                12  com.adobe.bridge6             0x000000010ceb55af 0x10caa2000 + 4273583
                                                13  com.adobe.bridge6             0x000000010ceb5480 0x10caa2000 + 4273280
                                                14  com.apple.CoreFoundation       0x00007fff94406127 __CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION__ + 23
                                                15  com.apple.CoreFoundation       0x00007fff94406080 __CFRunLoopDoObservers + 368
                                                16  com.apple.CoreFoundation       0x00007fff943f82ba __CFRunLoopRun + 1178
                                                17  com.apple.CoreFoundation       0x00007fff943f7bd8 CFRunLoopRunSpecific + 296
                                                18  com.apple.HIToolbox           0x00007fff97b0156f RunCurrentEventLoopInMode + 235
                                                19  com.apple.HIToolbox           0x00007fff97b012ea ReceiveNextEventCommon + 431
                                                20  com.apple.HIToolbox           0x00007fff97b0112b _BlockUntilNextEventMatchingListInModeWithFilter + 71
                                                21  com.apple.AppKit               0x00007fff9368f8ab _DPSNextEvent + 978
                                                22  com.apple.AppKit               0x00007fff9368ee58 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 346
                                                23  com.apple.AppKit               0x00007fff93684af3 -[NSApplication run] + 594
                                                24  com.adobe.bridge6             0x000000010ceb6217 0x10caa2000 + 4276759
                                                25  com.adobe.bridge6             0x000000010ceaf119 0x10caa2000 + 4247833
                                                26  com.adobe.bridge6             0x000000010ceaf1ed 0x10caa2000 + 4248045
                                                27  com.adobe.bridge6             0x000000010cf8fa80 0x10caa2000 + 5167744
                                                28  com.adobe.bridge6             0x000000010cf90205 0x10caa2000 + 5169669
                                                29  libdyld.dylib                 0x00007fff8dd3f5c9 start + 1
                                                Thread 1:: Dispatch queue: com.apple.libdispatch-manager
                                                0   libsystem_kernel.dylib         0x00007fff91c51232 kevent64 + 10
                                                1   libdispatch.dylib             0x00007fff9c3fb26e _dispatch_mgr_thread + 52
                                                Thread 2:
                                                0   libsystem_kernel.dylib         0x00007fff91c5094a __workq_kernreturn + 10
                                                1   libsystem_pthread.dylib       0x00007fff90cb43dd start_wqthread + 13
                                                Thread 3:
                                                Thread 4:
                                                0   libsystem_kernel.dylib         0x00007fff91c5048a __semwait_signal + 10
                                                1   com.adobe.bridge6             0x000000010d3ce948 std::_Rb_tree<SPSUAS, std::pair<SPSUAS const, int>, std::_Select1st<std::pair<SPSUAS const, int> >, std::less<SPSUAS>, std::allocator<std::pair<SPSUAS const, int> > >::_M_erase(std::_Rb_tree_node<std::pair<SPSUAS const, int> >*) + 195376
                                                2   com.adobe.bridge6             0x000000010d3b260c std::_Rb_tree<SPSUAS, std::pair<SPSUAS const, int>, std::_Select1st<std::pair<SPSUAS const, int> >, std::less<SPSUAS>, std::allocator<std::pair<SPSUAS const, int> > >::_M_erase(std::_Rb_tree_node<std::pair<SPSUAS const, int> >*) + 79860
                                                3   com.adobe.bridge6             0x000000010d3ce4e2 std::_Rb_tree<SPSUAS, std::pair<SPSUAS const, int>, std::_Select1st<std::pair<SPSUAS const, int> >, std::less<SPSUAS>, std::allocator<std::pair<SPSUAS const, int> > >::_M_erase(std::_Rb_tree_node<std::pair<SPSUAS const, int> >*) + 194250
                                                4   libsystem_pthread.dylib       0x00007fff90cb705a _pthread_body + 131
                                                5   libsystem_pthread.dylib       0x00007fff90cb6fd7 _pthread_start + 176
                                                6   libsystem_pthread.dylib       0x00007fff90cb43ed thread_start + 13
                                                Thread 5:
                                                Thread 6:: cr_scratch
                                                0   libsystem_kernel.dylib         0x00007fff91c50136 __psynch_cvwait + 10
                                                1   com.adobe.CameraRaw           0x000000011c0e877b 0x11b853000 + 9000827
                                                2   com.adobe.CameraRaw           0x000000011c07484b 0x11b853000 + 8525899
                                                3   com.adobe.CameraRaw           0x000000011be023f1 0x11b853000 + 5960689
                                                Thread 7:
                                                Thread 8:
                                                1   com.adobe.bridge6             0x000000010d1603f6 sqlite3_test_control + 1012182
                                                2   com.adobe.bridge6             0x000000010d1634d5 sqlite3_test_control + 1024693
                                                3   com.adobe.bridge6             0x000000010d16337b sqlite3_test_control + 1024347
                                                4   com.adobe.bridge6             0x000000010cf9e569 0x10caa2000 + 5227881
                                                5   com.apple.CoreServices.CarbonCore 0x00007fff8e60f23c PrivateMPEntryPoint + 58
                                                6   libsystem_pthread.dylib       0x00007fff90cb705a _pthread_body + 131
                                                7   libsystem_pthread.dylib       0x00007fff90cb6fd7 _pthread_start + 176
                                                8   libsystem_pthread.dylib       0x00007fff90cb43ed thread_start + 13
                                                Thread 9:
                                                0   libsystem_kernel.dylib         0x00007fff91c4b51a semaphore_wait_trap + 10
                                                1   com.adobe.bridge6             0x000000010cb59ca7 0x10caa2000 + 752807
                                                2   com.adobe.bridge6             0x000000010cead462 0x10caa2000 + 4240482
                                                3   com.adobe.bridge6             0x000000010ceadc7f 0x10caa2000 + 4242559
                                                4   com.adobe.bridge6             0x000000010d38e030 CTJPEGDecodeOptionsInitDefault + 127136
                                                5   com.adobe.bridge6             0x000000010d33b9bb vsnprintf_safe + 14027
                                                6   com.adobe.bridge6             0x000000010d338e71 vsnprintf_safe + 2945
                                                7   com.adobe.bridge6             0x000000010d347430 vsnprintf_safe + 61760
                                                8   com.adobe.bridge6             0x000000010d36e735 CTJPEGDecoderReadContent + 325
                                                9   com.adobe.bridge6             0x000000010d049ddf CTJPEG::Decoder::ReadContent(CTJPEGColorSpace, CTJPEGImageContent const&) + 79
                                                10  com.adobe.bridge6             0x000000010d01273a ThumbMetaLib::FBJPEGStream::Decompress(Mondo::CContainer*, unsigned int, ThumbMetaLib::ThumbnailMetaInfo*, bool, bool) + 3162
                                                11  com.adobe.bridge6             0x000000010d022cfc ThumbMetaLib::Pixels::FromJPEGStream(Mondo::CContainer*, unsigned int, bool) + 92
                                                12  com.adobe.bridge6             0x000000010d020530 ThumbMetaLib::Pixels::CreateInMemoryPixels(bool, int*) const + 176
                                                13  com.adobe.bridge6             0x000000010d023c72 ThumbMetaLib::PixelsCache::Add(boost::shared_ptr<ThumbMetaLib::Pixels>&) + 146
                                                14  com.adobe.bridge6             0x000000010d1d2a45 sqlite3_test_control + 1480741
                                                15  com.adobe.bridge6             0x000000010d2765a4 sqlite3_test_control + 2151300
                                                16  com.adobe.bridge6             0x000000010d1633a4 sqlite3_test_control + 1024388
                                                17  com.adobe.bridge6             0x000000010cf9e569 0x10caa2000 + 5227881
                                                18  com.apple.CoreServices.CarbonCore 0x00007fff8e60f23c PrivateMPEntryPoint + 58
                                                19  libsystem_pthread.dylib       0x00007fff90cb705a _pthread_body + 131
                                                20  libsystem_pthread.dylib       0x00007fff90cb6fd7 _pthread_start + 176
                                                21  libsystem_pthread.dylib       0x00007fff90cb43ed thread_start + 13
                                                Thread 10:
                                                2   com.adobe.bridge6             0x000000010d1a420e sqlite3_test_control + 1290222
                                                3   com.adobe.bridge6             0x000000010cf9e569 0x10caa2000 + 5227881
                                                4   com.apple.CoreServices.CarbonCore 0x00007fff8e60f23c PrivateMPEntryPoint + 58
                                                5   libsystem_pthread.dylib       0x00007fff90cb705a _pthread_body + 131
                                                6   libsystem_pthread.dylib       0x00007fff90cb6fd7 _pthread_start + 176
                                                7   libsystem_pthread.dylib       0x00007fff90cb43ed thread_start + 13
                                                Thread 11:
                                                2   com.adobe.bridge6             0x000000010d159e33 sqlite3_test_control + 986131
                                                3   com.adobe.bridge6             0x000000010d159ad0 sqlite3_test_control + 985264
                                                Thread 12:
                                                1   com.adobe.switchboard-3.0     0x0000000122c734e6 void boost::condition_variable_any::wait<boost::unique_lock<boost::mutex> >(boost::unique_lock<boost::mutex>&) + 122
                                                2   com.adobe.switchboard-3.0     0x0000000122c5e6db adobe::switchboard::ConnectionQueue::run() + 481
                                                3   com.adobe.switchboard-3.0     0x0000000122c683af boost::_mfi::mf0<void, adobe::switchboard::ConnectionQueue>::operator()(adobe::switchboard::ConnectionQueue*) const + 125
                                                4   com.adobe.switchboard-3.0     0x0000000122c68454 void boost::_bi::list1<boost::_bi::value<adobe::switchboard::ConnectionQueue*> >::operator()<boost::_mfi::mf0<void, adobe::switchboard::ConnectionQueue>, boost::_bi::list0>(boost::_bi::type<void>, boost::_mfi::mf0<void, adobe::switchboard::ConnectionQueue>&, boost::_bi::list0&, int) + 78
                                                5   com.adobe.switchboard-3.0     0x0000000122c684b6 boost::_bi::bind_t<void, boost::_mfi::mf0<void, adobe::switchboard::ConnectionQueue>, boost::_bi::list1<boost::_bi::value<adobe::switchboard::ConnectionQueue*> > >::operator()() + 92
                                                6   com.adobe.switchboard-3.0     0x0000000122c684e1 boost::detail::thread_data<boost::_bi::bind_t<void, boost::_mfi::mf0<void, adobe::switchboard::ConnectionQueue>, boost::_bi::list1<boost::_bi::value<adobe::switchboard::ConnectionQueue*> > > >::run() + 37
                                                7   com.adobe.switchboard-3.0     0x0000000122bc0e7f thread_proxy + 175
                                                8   libsystem_pthread.dylib       0x00007fff90cb705a _pthread_body + 131
                                                9   libsystem_pthread.dylib       0x00007fff90cb6fd7 _pthread_start + 176
                                                10  libsystem_pthread.dylib       0x00007fff90cb43ed thread_start + 13
                                                Thread 13:
                                                1   com.adobe.switchboard-3.0     0x0000000122c2d85e boost::condition_variable::wait(boost::unique_lock<boost::mutex>&) + 70
                                                2   com.adobe.switchboard-3.0     0x0000000122c02b6d adobe::switchboard::Client::run() + 123
                                                3   com.adobe.switchboard-3.0     0x0000000122c117a1 boost::_mfi::mf0<void, adobe::switchboard::Client>::operator()(adobe::switchboard::Client*) const + 125
                                                4   com.adobe.switchboard-3.0     0x0000000122c117f6 void boost::_bi::list1<boost::_bi::value<adobe::switchboard::Client*> >::operator()<boost::_mfi::mf0<void, adobe::switchboard::Client>, boost::_bi::list0>(boost::_bi::type<void>, boost::_mfi::mf0<void, adobe::switchboard::Client>&, boost::_bi::list0&, int) + 78
                                                5   com.adobe.switchboard-3.0     0x0000000122c11858 boost::_bi::bind_t<void, boost::_mfi::mf0<void, adobe::switchboard::Client>, boost::_bi::list1<boost::_bi::value<adobe::switchboard::Client*> > >::operator()() + 92
                                                6   com.adobe.switchboard-3.0     0x0000000122c11883 boost::detail::thread_data<boost::_bi::bind_t<void, boost::_mfi::mf0<void, adobe::switchboard::Client>, boost::_bi::list1<boost::_bi::value<adobe::switchboard::Client*> > > >::run() + 37
                                                Thread 14:
                                                Thread 15:
                                                Thread 16:
                                                Thread 17:
                                                0   libsystem_kernel.dylib         0x00007fff91c4b4de mach_msg_trap + 10
                                                1   libsystem_kernel.dylib         0x00007fff91c4a64f mach_msg + 55
                                                2   com.apple.CoreFoundation       0x00007fff943f8eb4 __CFRunLoopServiceMachPort + 212
                                                3   com.apple.CoreFoundation       0x00007fff943f837b __CFRunLoopRun + 1371
                                                4   com.apple.CoreFoundation       0x00007fff943f7bd8 CFRunLoopRunSpecific + 296
                                                5   com.apple.AppKit               0x00007fff9375756b _NSEventThread + 137
                                                Thread 18:: MPSupport Worker
                                                1   MultiProcessor Support         0x000000011b70b4bb boost::condition_variable::wait(boost::unique_lock<boost::mutex>&) + 59
                                                2   MultiProcessor Support         0x000000011b70b3bb ThreadFunctor::operator()() + 139
                                                3   MultiProcessor Support         0x000000011b72b6e2 boost::(anonymous namespace)::thread_proxy(void*) + 130
                                                Thread 19:: MPSupport Worker
                                                Thread 20:: MPSupport Worker
                                                Thread 21:
                                                0   libsystem_kernel.dylib         0x00007fff91c5036a __recvmsg + 10
                                                1   com.adobe.switchboard-3.0     0x0000000122c2af94 unsigned long boost::asio::detail::reactive_socket_service<boost::asio::ip::tcp, boost::asio::detail::kqueue_reactor<false> >::receive<boost::asio::mutable_buffers_1>(boost::asio::detail::reactive_socket_service<b oost::asio::ip::tcp, boost::asio::detail::kqueue_reactor<false> >::implementation_type&, boost::asio::mutable_buffers_1 const&, int, boost::system::error_code&) + 738
                                                2   com.adobe.switchboard-3.0     0x0000000122c2b173 unsigned long boost::asio::stream_socket_service<boost::asio::ip::tcp>::receive<boost::asio::mutable_bu ffers_1>(boost::asio::detail::reactive_socket_service<boost::asio::ip::tcp, boost::asio::detail::kqueue_reactor<false> >::implementation_type&, boost::asio::mutable_buffers_1 const&, int, boost::system::error_code&) + 75
                                                3   com.adobe.switchboard-3.0     0x0000000122c2b1e0 unsigned long boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> >::read_some<boost::asio::mutable_buffers_1>(boost::asio::mutable_buffers_1 const&, boost::system::error_code&) + 86
                                                4   com.adobe.switchboard-3.0     0x0000000122c2c746 adobe::switchboard::Connection<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > >::runOne(boost::shared_ptr<adobe::switchboard::Connection<boost::asio::basic_stream_sock et<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > > >&) + 106
                                                5   com.adobe.switchboard-3.0     0x0000000122c2ca73 adobe::switchboard::Connection<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > >::run() + 87
                                                6   com.adobe.switchboard-3.0     0x0000000122c115e3 boost::_mfi::mf0<void, adobe::switchboard::Connection<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > > >::operator()(adobe::switchboard::Connection<boost::asio::basic_stream_socket<boost::asio ::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > >*) const + 125
                                                7   com.adobe.switchboard-3.0     0x0000000122c11638 void boost::_bi::list1<boost::_bi::value<adobe::switchboard::Connection<boost::asio::basic_str eam_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > >*> >::operator()<boost::_mfi::mf0<void, adobe::switchboard::Connection<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > > >, boost::_bi::list0>(boost::_bi::type<void>, boost::_mfi::mf0<void, adobe::switchboard::Connection<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > > >&, boost::_bi::list0&, int) + 78
                                                8   com.adobe.switchboard-3.0     0x0000000122c1169a boost::_bi::bind_t<void, boost::_mfi::mf0<void, adobe::switchboard::Connection<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > > >, boost::_bi::list1<boost::_bi::value<adobe::switchboard::Connection<boost::asio::basic_str eam_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > >*> > >::operator()() + 92
                                                9   com.adobe.switchboard-3.0     0x0000000122c116c5 boost::detail::thread_data<boost::_bi::bind_t<void, boost::_mfi::mf0<void, adobe::switchboard::Connection<boost::asio::basic_stream_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > > >, boost::_bi::list1<boost::_bi::value<adobe::switchboard::Connection<boost::asio::basic_str eam_socket<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp> > >*> > > >::run() + 37
                                                10  com.adobe.switchboard-3.0     0x0000000122bc0e7f thread_proxy + 175
                                                11  libsystem_pthread.dylib       0x00007fff90cb705a _pthread_body + 131
                                                12  libsystem_pthread.dylib       0x00007fff90cb6fd7 _pthread_start + 176
                                                13  libsystem_pthread.dylib       0x00007fff90cb43ed thread_start + 13
                                                Thread 22:
                                                Thread 23:
                                                2   com.adobe.bridge6             0x000000010ceadb80 0x10caa2000 + 4242304
                                                3   com.adobe.bridge6             0x000000010cead65e 0x10caa2000 + 4240990
                                                Thread 24:
                                                Thread 25:
                                                Thread 26:
                                                Thread 0 crashed with X86 Thread State (64-bit):
                                                  rax: 0x0000000000000004  rbx: 0x00000000000000ad  rcx: 0x00007f819a5828a8  rdx: 0x00000000000000a8
                                                  rdi: 0x00007f819a58e8dc  rsi: 0x00000000000000ac  rbp: 0x00007fff5315bc30  rsp: 0x00007fff5315b930
                                                   r8: 0x00007f819a58e8d8   r9: 0x0000000000000210  r10: 0x00007f819a582800  r11: 0x0000000000000004
                                                  r12: 0x0000000000000160  r13: 0x00000000000000a8  r14: 0x00000000000000b0  r15: 0x00000000000000b0
                                                  rip: 0x000000011b7be360  rfl: 0x0000000000010202  cr2: 0x000000011b7be000
                                                Logical CPU:     2
                                                Error Code:      0x00000000
                                                Trap Number:     6
                                                Binary Images:
                                                       0x10caa2000 -        0x10d9b7fff +com.adobe.bridge6 (6.2.0.179 - 6.2.0.179) <C63DEB1D-CFA0-336A-A386-62F1D980DF73> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/MacOS/Adobe Bridge CC
                                                       0x10deeb000 -        0x10deeffff  com.apple.agl (3.3.0 - AGL-3.3.0) <4E8F579B-A2E2-3A27-96D7-02A9465A78D8> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
                                                       0x10def6000 -        0x10defcfff  org.twain.dsm (1.9.5 - 1.9.5) <6D13A0B6-113D-335A-8E7B-366A0CFE1CD6> /System/Library/Frameworks/TWAIN.framework/Versions/A/TWAIN
                                                       0x10df09000 -        0x10e233fff +com.adobe.AGM (AdobeAGM 4.30.60.35269 - 4.30.60.35269) <7B00FE6F-5B1E-31C0-9ED0-599F1EC1EC37> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
                                                       0x10e2a4000 -        0x10e669ff7 +com.adobe.MPS (AdobeMPS 5.8.1.35138 - 5.8.1.35138) <809BAAB6-9F24-39D8-9101-B6D65FB1F7FC> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
                                                       0x10e6de000 -        0x10e71afff +com.adobe.ARE (AdobeARE 1.5.02.35269 - 1.5.02.35269) <54AA8EE4-A877-31A5-A089-835F4F144217> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
                                                       0x10e727000 -        0x10f46cfff +com.adobe.ICUData (4.0 - 3.61) <B9864D01-126E-3C56-B04C-993F9890F6AD> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData
                                                       0x10f484000 -        0x10f52bff7 +com.adobe.AdobeExtendScript (ExtendScript 4.5.6 - 4.5.6.2) <EE4DF0D0-2670-38C9-B42A-8388F6F731DD> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
                                                       0x10f57b000 -        0x10f615ff7 +com.adobe.AdobeScCore (ScCore 4.5.6 - 4.5.6.2) <0A6A5E1D-4C34-3C52-B73B-394C25029ABE> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
                                                       0x10f65c000 -        0x10f9b9fff +com.adobe.CoolType (AdobeCoolType 5.15.00.35269 - 5.15.00.35269) <38CD3612-A57D-35E5-B5D8-CBD5F6DDC920> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
                                                       0x10fa06000 -        0x10fad0ff7 +com.adobe.JP2K (1.2.2 - 1.2.2.35138) <4205548A-573A-364B-93D0-F61996DD723A> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
                                                       0x10fb18000 -        0x112a2cf7f +com.adobe.psl (AdobePSL 15.1.0.35674 - 15.1.0.35674) <DD3CB5C2-4A75-37CC-99C8-18292C8B3BB5> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
                                                       0x112f22000 -        0x11305dfff +com.adobe.ICUInternationalization (4.0 - 3.61) <CEAE369B-B601-30D5-9563-6C2AB781AF27> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/ICUInternationalization.framework/Versions/4.0/ICUInternationa lization
                                                       0x1130e9000 -        0x113248ff7 +com.adobe.ACE (AdobeACE 2.20.02.35269 - 2.20.02.35269) <A8121E59-42A7-3F0E-9909-112A42DCDC64> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
                                                       0x11325d000 -        0x11325fff7  com.apple.textencoding.unicode (2.8 - 2.8) <A2CAC6A6-82CE-3929-94F8-538375EC3DF9> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
                                                       0x113264000 -        0x113367ff7 +com.adobe.ICUUnicode (4.0 - 3.61) <CE487901-E84A-3E54-95AB-91F2EAF57F6A> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/ICUUnicode
                                                       0x1133b2000 -        0x1134e9ff7 +com.winsoft.wrservices (WRServices 11.0.0 - 11.0.0) <A1AF94EB-8B13-305C-8B8C-8E420BA0DD0A> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
                                                       0x11354a000 -        0x1135f3ff7 +com.adobe.ICUConverter (4.0 - 3.61) <E20E390A-9BAF-3454-BA16-7B9CCD4CA8F0> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/ICUConverter
                                                       0x113623000 -        0x113626fff +com.adobe.AdobeCrashReporter (7.1 - 7.1.4) <A33546D9-3E26-38A2-88FE-C7C46B4CD989> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
                                                       0x113631000 -        0x1136a2fe7 +com.adobe.FileInfo.framework (Adobe XMP FileInfo 5 . 3 . 0 . 0 -i 3 - 79.151561) <380981FE-6528-37CC-9159-AB1892803BD4> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
                                                       0x1136bb000 -        0x113831fff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 111 - 79.158366) <01F03185-A123-3511-B739-A135591052E1> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
                                                       0x113918000 -        0x113a1afff +com.adobe.amtlib (9.0.0.89 - 9.0.0.89) <EBF9B7FD-5C40-31E1-976E-D5B5608080B9> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
                                                       0x113a2e000 -        0x113b8cff7 +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.6 -f 170 - 79.158366) <110630F4-A885-32D1-9463-1907443AC676> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
                                                       0x113c5e000 -        0x113c84fff +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.8.0.35348 - 3.8.0.35348) <A1F25502-8A55-3300-ACB8-66507CE1B6B9> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpat
                                                       0x113cae000 -        0x113cb2ff7 +com.adobe.ape.shim (3.4.0.29366 - 3.4.0.29366) <B9447EE8-6F91-9E85-C163-96600BF70764> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
                                                       0x113cbe000 -        0x113cd1ff7 +com.adobe.ahclientframework (1.8.0.31 - 1.8.0.31) <58BB943C-98EC-3812-AAAB-74F66630D1D4> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
                                                       0x113cdb000 -        0x113cfcfff +com.adobe.BIB (AdobeBIB 1.2.03.35269 - 1.2.03.35269) <11EBACBD-C7F8-3E80-A2BF-E87543B5CE11> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
                                                       0x113d04000 -        0x113d2aff7 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <6536192E-56D1-3EF0-97A9-04630B74CE0C> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
                                                       0x113d37000 -        0x113d77ff7 +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 9.0.0.15 - 9.0.0.15) <777D69DE-E701-3DAE-AF9C-7B7B48C0189C> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotifications
                                                       0x113d92000 -        0x113e84fff +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.8.0.35348 - 3.8.0.35348) <E5D037D0-B4D5-33F5-BE74-650C392C6514> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
                                                       0x113f29000 -        0x113f35fff +com.adobe.boost_signals.framework (8.0.0 - 8.0.0.0) <A2F88487-E0D4-35EB-A539-1B489EFFCB0F> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
                                                       0x113f56000 -        0x113f58fff +com.adobe.boost_system.framework (8.0.0 - 8.0.0.0) <02064CC7-B140-39BC-A327-63A16AC6C2A2> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
                                                       0x113f63000 -        0x113f71fff +com.adobe.boost_threads.framework (8.0.0 - 8.0.0.0) <833CB2CE-B4A4-36D4-A5AB-EAE92D82C8B7> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
                                                       0x113f91000 -        0x114023fff +com.adobe.dvaaudiodevice.framework (8.0.0 - 8.0.0.0) <3E16D9CD-330C-33EC-9702-69A94D941426> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/dvaaudiodevice.framework/Versions/A/dvaaudiodevice
                                                       0x1140e9000 -        0x114378fff +com.adobe.dvacore.framework (8.0.0 - 8.0.0.0) <3AAE70D1-F9C6-36B7-BB9A-47918646093D> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
                                                       0x1145ce000 -        0x1145f8fff +com.adobe.dvamarshal.framework (8.0.0 - 8.0.0.0) <761BE7FE-4D6C-3B7A-B516-DDC08E29BD43> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
                                                       0x11463a000 -        0x11463aff5 +cl_kernels (???) <85833899-1C29-4D0B-8C53-95999D6D2057> cl_kernels
                                                       0x11463e000 -        0x11466dff7 +com.adobe.dvamediatypes.framework (8.0.0 - 8.0.0.0) <4DD854D4-432C-3D79-92C2-282E66BF41D0> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
                                                       0x1146a1000 -        0x1146a1fff +cl_kernels (???) <5EADBAE5-0945-4F5F-AC6C-B854DB48EBC9> cl_kernels
                                                       0x1146a5000 -        0x1146abff7 +com.adobe.boost_date_time.framework (8.0.0 - 8.0.0.0) <3ED123F5-3173-3D7C-BC94-ECE0894CB193> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
                                                       0x1146c9000 -        0x114784fff +com.adobe.dvaplayer.framework (8.0.0 - 8.0.0.0) <5DB4EA3D-4A2A-3168-8907-CD02166AA792> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/dvaplayer.framework/Versions/A/dvaplayer
                                                       0x1148f3000 -        0x1148f4ff7  libCyrillicConverter.dylib (64) <91BE01AF-E364-3DF4-9968-05996B748FE0> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
                                                       0x1148f9000 -        0x11495dfff +com.adobe.dvatransport.framework (8.0.0 - 8.0.0.0) <2734D385-B67C-313D-A944-6B85B1DCCA05> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
                                                       0x1149f7000 -        0x114a1afff +com.adobe.dvaunittesting.framework (8.0.0 - 8.0.0.0) <46F0439B-7076-3603-B4E4-E998730529F2> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
                                                       0x114a5f000 -        0x114c97ff7 +com.adobe.dynamiclink.framework (8.0.0 - 8.0.0.0) <FB1BD993-11B4-308A-B0AE-1CCF810F5A97> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
                                                       0x114f0c000 -        0x115217ff7 +com.adobe.mediacoreif.framework (8.0.0 - 8.0.0.0) <7A399D0B-0C3D-3B1B-B277-85DD5038C71F> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/mediacoreif.framework/Versions/A/mediacoreif
                                                       0x1155bb000 -        0x1155f9fff +com.adobe.dvanet.framework (8.0.0 - 8.0.0.0) <8617818A-4402-33D5-9FD3-14725A148CB2> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/dvanet.framework/Versions/A/dvanet
                                                       0x11566a000 -        0x1163edfdf +com.adobe.alignmentlib (Copyright © 2013 Adobe Systems Incorporated - Copyright © 2013 Adobe Systems Incorporated) <F5BFD9E3-646B-3FF4-81DC-D5439EC6CC54> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AlignmentLib.framework/Versions/A/AlignmentLib
                                                       0x11650a000 -        0x116652ff7 +com.adobe.AIDE (1.5.0 - 1.5.0.35630) <F1E51661-3983-3BD7-AA23-4C36976753B5> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE
                                                       0x1166b3000 -        0x1166dfff7 +libtbb.dylib (0) <64B7013E-D548-3F7B-A2FB-28B7B932275C> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/libtbb.dylib
                                                       0x116700000 -        0x11671ffe7 +libtbbmalloc.dylib (0) <6887ED68-67ED-3748-82DA-B39A3EB210BB> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/libtbbmalloc.dylib
                                                       0x119940000 -        0x119a31fff +com.adobe.adobe_caps (adobe_caps 9.0.0.28 - 9.0.0.28) <5FA2F01A-0E75-3655-8CC0-C09088813A57> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
                                                       0x11b4e4000 -        0x11b560ff7 +Photoshop Adapter (0) <54ABA913-022C-37B7-8CE2-8C00E1E74A87> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Required/Photoshop Adapter.plugin/Contents/MacOS/Photoshop Adapter
                                                       0x11b6c2000 -        0x11b739fff +MultiProcessor Support (16.1 - 16.1) <A11C3D38-1E91-3312-9DD2-B5C7023EC0F5> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Plug-Ins/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
                                                       0x11b79d000 -        0x11b7d1fff +MMXCore (16.1 - 16.1) <9B4CEE6E-B511-3889-AF71-F84BDD9BE716> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Plug-Ins/MMXCore.plugin/Contents/MacOS/MMXCore
                                                       0x11b853000 -        0x11e757fef +com.adobe.CameraRaw (9.4 [548] - 9.4f548) <431110CA-B806-3014-9EA5-681267AAC627> /Library/Application Support/Adobe/*/Camera Raw.plugin/Contents/MacOS/Camera Raw
                                                       0x11ebb6000 -        0x11ee50fff  com.apple.AMDRadeonX3000GLDriver (1.32.25 - 1.3.2) <63E3A75A-1D1B-3013-B227-3CDF8C1EE95D> /System/Library/Extensions/AMDRadeonX3000GLDriver.bundle/Contents/MacOS/AMDRadeonX3000GLD river
                                                       0x11f3ff000 -        0x11f4abfff  ColorSyncDeprecated.dylib (442) <3518239D-60D5-39AF-A68C-E7B12564103C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/Resources/ColorSyncDeprecated.dylib
                                                       0x121e81000 -        0x121e9efff  libJapaneseConverter.dylib (64) <12325659-06A4-37C9-8A9C-DA7A3F8DB8A2> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
                                                       0x121ea3000 -        0x121eb2fff  libSimplifiedChineseConverter.dylib (64) <468DE6E1-42B9-3751-ACA5-7D16C550FF84> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
                                                       0x122b86000 -        0x122d13fef +com.adobe.switchboard-3.0 (SBCC 3.0.1 - 3.0.1.2) <5DAB4B93-55EC-A2FF-0F40-59D37ADE17F5> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/SwitchBoardClient.bundle/Contents/MacOS/SwitchBoardClient
                                                       0x122f25000 -        0x12300bfef  unorm8_bgra.dylib (2.4.5) <5F488C7E-2FB2-3C66-9764-28CF16B03E7A> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra .dylib
                                                       0x12429e000 -        0x1242c0fff  libKoreanConverter.dylib (64) <E51FCBAE-3886-32B7-B4F8-51B3CBF683ED> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
                                                       0x1242c4000 -        0x1242d6fff  libTraditionalChineseConverter.dylib (64) <DCA11C00-8F36-39E5-BD2A-B15183931E8B> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
                                                       0x1bdaf9000 -        0x1bdafdfff +com.stclairsoft.DefaultFolderX.osax (4.6.7 - 4.6.7) <B7779D81-E588-361D-A11F-B04783C54CC6> /Library/ScriptingAdditions/Default Folder X Addition.osax/Contents/MacOS/Default Folder X Addition
                                                       0x1bdb04000 -        0x1bdb2dfff +libSLCacheWrapper.dylib (1) <AB5FD9B1-D26B-3599-820A-6E1238597C86> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/LogSession.framework/Libraries/libSLCacheWrapper.dylib
                                                       0x1be034000 -        0x1be05eff7 +com.stclairsoft.DefaultFolderX.CocoaPatcher (4.7.4 - 4.7.4) <4EFED927-BB5E-3CEC-B3F0-BE646F8BE6F8> /Users/USER/Library/PreferencePanes/Default Folder X.prefPane/Contents/Resources/Default Folder X.bundle/Contents/Resources/Cocoa Patcher.bundle/Contents/MacOS/Cocoa Patcher
                                                       0x1be114000 -        0x1be14efff +com.adobe.pip (7.3.1.70) <62832BC3-E82F-3648-B0D2-67EFD1263C89> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
                                                       0x1be158000 -        0x1be297ff7 +com.adobe.headlights.LogSessionFramework (7.3.1.70) <408F19FE-B672-3E82-89B6-B782E000D2B0> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/LogSession.framework/LogSession
                                                    0x7fff6a132000 -     0x7fff6a168887  dyld (353.2.3) <D9967621-6378-381B-A47B-5085EE476B62> /usr/lib/dyld
                                                    0x7fff8c8a7000 -     0x7fff8c8a9fff  libsystem_sandbox.dylib (358.20.5) <3F5E973F-C702-31AC-97BC-05F5C195683C> /usr/lib/system/libsystem_sandbox.dylib
                                                    0x7fff8c8aa000 -     0x7fff8c8d2fff  libsystem_info.dylib (459.40.1) <2E16C4B3-A327-3957-9C41-143911979A1E> /usr/lib/system/libsystem_info.dylib
                                                    0x7fff8ca13000 -     0x7fff8cae9ff3  com.apple.DiskImagesFramework (10.10.5 - 398) <37291661-BCB2-3F95-B446-5E5DB1D1E472> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
                                                    0x7fff8caea000 -     0x7fff8cb91fff  com.apple.PDFKit (3.1 - 3.1) <D410CE57-6227-31D8-9F39-92583E552EA8> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
                                                    0x7fff8cbc8000 -     0x7fff8cc2fffb  com.apple.datadetectorscore (6.0 - 396.1.2) <D04A8016-B2AD-33A2-8A8E-5793968A8370> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
                                                    0x7fff8cc3b000 -     0x7fff8cc3bfff  com.apple.Carbon (154 - 157) <9BF51672-1684-3FDE-A561-FC59A2864EF8> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                                                    0x7fff8cc42000 -     0x7fff8cd34ff3  libxml2.2.dylib (26.2) <E1391BDB-D196-3B20-9B65-FABAF4698C75> /usr/lib/libxml2.2.dylib
                                                    0x7fff8cd8e000 -     0x7fff8cdbdff7  com.apple.CoreServicesInternal (221.7.2 - 221.7.2) <B93D4775-149C-3698-B38C-9C50673D455C> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
                                                    0x7fff8ce21000 -     0x7fff8ce29ff7  com.apple.AppleSRP (5.0 - 1) <68F0C577-ED96-34F2-B701-CE3023367D4D> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
                                                    0x7fff8ce40000 -     0x7fff8ce43fff  com.apple.xpc.ServiceManagement (1.0 - 1) <A95A15CD-3B21-3513-AFF8-1D7DE3DBFA12> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
                                                    0x7fff8ce44000 -     0x7fff8ce69ff7  libJPEG.dylib (1241) <A6635296-BCC9-35E5-A5AF-351B039B5087> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
                                                    0x7fff8d4d4000 -     0x7fff8d4ddfff  com.apple.DisplayServicesFW (2.9 - 372.1) <30E61754-D83C-330A-AE60-533F27BEBFF5> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
                                                    0x7fff8d4de000 -     0x7fff8d4deff7  libkeymgr.dylib (28) <77845842-DE70-3CC5-BD01-C3D14227CED5> /usr/lib/system/libkeymgr.dylib
                                                    0x7fff8d4df000 -     0x7fff8d8ecff7  libLAPACK.dylib (1128) <F9201AE7-B031-36DB-BCF8-971E994EF7C1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                                                    0x7fff8d92f000 -     0x7fff8d97cff7  com.apple.print.framework.PrintCore (10.3 - 451.1) <DE992474-0841-38A1-B4F6-46D653E454D5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                                                    0x7fff8d9be000 -     0x7fff8d9cffff  libcmph.dylib (1) <46EC3997-DB5E-38AE-BBBB-A035A54AD3C0> /usr/lib/libcmph.dylib
                                                    0x7fff8d9dc000 -     0x7fff8db1ffff  libsqlite3.dylib (168.2) <BCB1F77E-2484-3EC4-A1D5-1AE90A407A23> /usr/lib/libsqlite3.dylib
                                                    0x7fff8db80000 -     0x7fff8dbecfff  com.apple.framework.CoreWLAN (5.0 - 500.35.2) <03697149-1CDD-32FF-B564-1C1EF5E9E5C3> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
                                                    0x7fff8dc16000 -     0x7fff8dc8eff7  com.apple.SystemConfiguration (1.14.4 - 1.14) <3DFFD7F7-BD23-3F4C-A209-C4A0D99F6573> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                                                    0x7fff8dc8f000 -     0x7fff8dd23fff  com.apple.ink.framework (10.9 - 213) <8E029630-1530-3734-A446-13353F0E7AC5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                                                    0x7fff8dd24000 -     0x7fff8dd36ff7  com.apple.CoreDuetDaemonProtocol (1.0 - 1) <CE9FABB4-1C5D-3F9B-9BB8-5CC50C3E5E31> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDae monProtocol
                                                    0x7fff8dd37000 -     0x7fff8dd3bfff  libspindump.dylib (182.4) <929670EB-4963-3496-AD24-8B50E388803C> /usr/lib/libspindump.dylib
                                                    0x7fff8dd3c000 -     0x7fff8dd3fff7  libdyld.dylib (353.2.3) <CFBBE540-D503-3AFC-B5D6-644F1E69949B> /usr/lib/system/libdyld.dylib
                                                    0x7fff8ddcc000 -     0x7fff8ddf4fff  libRIP.A.dylib (788.3.2) <F0E03341-C608-3A49-AFE1-1E5736C5C989> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
                                                    0x7fff8ddf5000 -     0x7fff8dedfff7  com.apple.QuickLookUIFramework (5.0 - 675.43) <011DEB49-0FB3-3E44-9D99-D89ADD59A3CC> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
                                                    0x7fff8def9000 -     0x7fff8df29ff3  com.apple.CoreAVCHD (5.7.5 - 5750.4.1) <3E51287C-E97D-3886-BE88-8F6872400876> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
                                                    0x7fff8df2a000 -     0x7fff8df91ff7  com.apple.framework.CoreWiFi (3.0 - 300.4) <19269C1D-EB29-384A-83F3-7DDDEB7D9DAD> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
                                                    0x7fff8df92000 -     0x7fff8df93fff  com.apple.TrustEvaluationAgent (2.0 - 25) <2D61A2C3-C83E-3A3F-8EC1-736DBEC250AB> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                                                    0x7fff8df94000 -     0x7fff8e0c6ff7  com.apple.MediaControlSender (2.0 - 215.18) <88726256-A71E-33A8-A56C-ABA208951C92> /System/Library/PrivateFrameworks/MediaControlSender.framework/Versions/A/MediaControlSen der
                                                    0x7fff8e0c7000 -     0x7fff8e277ff3  com.apple.QuartzCore (1.10 - 361.19) <F815B60E-75E3-3263-BE93-27A49882CF58> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                                                    0x7fff8e28d000 -     0x7fff8e2d9fff  com.apple.corelocation (1486.17 - 1615.24) <8825B3E2-E053-3E01-AE31-793443962D06> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
                                                    0x7fff8e2da000 -     0x7fff8e32bff7  com.apple.AppleVAFramework (5.0.31 - 5.0.31) <17C35538-7C2B-3735-A1B3-E8487EED0668> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
                                                    0x7fff8e365000 -     0x7fff8e457ff7  libiconv.2.dylib (42) <2A06D02F-8B76-3864-8D96-64EF5B40BC6C> /usr/lib/libiconv.2.dylib
                                                    0x7fff8e458000 -     0x7fff8e53cfff  libcrypto.0.9.8.dylib (52.40.1) <D123FC57-E2EB-3E08-A51B-6C317EA83EB5> /usr/lib/libcrypto.0.9.8.dylib
                                                    0x7fff8e53d000 -     0x7fff8e577ffb  com.apple.DebugSymbols (115 - 115) <6F03761D-7C3A-3C80-8031-AA1C1AD7C706> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
                                                    0x7fff8e578000 -     0x7fff8e58dff7  com.apple.AppContainer (4.0 - 238.20.2) <2AA2EF49-9F38-31F6-8B08-8CC7C26F57F3> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
                                                    0x7fff8e58e000 -     0x7fff8e875ffb  com.apple.CoreServices.CarbonCore (1108.6 - 1108.6) <8953580E-7857-33B2-AA64-98296830D3A8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                                                    0x7fff8e8c3000 -     0x7fff8e8c4fff  libDiagnosticMessagesClient.dylib (100) <2EE8E436-5CDC-34C5-9959-5BA218D507FB> /usr/lib/libDiagnosticMessagesClient.dylib
                                                    0x7fff8e8c5000 -     0x7fff8e8d1ff7  com.apple.OpenDirectory (10.10 - 187) <22FF4721-03D8-381B-AA83-2B07D690C777> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                                                    0x7fff8e8d2000 -     0x7fff8eca9fe7  com.apple.CoreAUC (211.1.0 - 211.1.0) <12645629-E065-388E-A6B5-094A240578CE> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
                                                    0x7fff8ecaa000 -     0x7fff8ecd3ffb  libxslt.1.dylib (13.9) <F24E9202-470D-33F5-B3AE-FF90A9EA83F3> /usr/lib/libxslt.1.dylib
                                                    0x7fff8ecd4000 -     0x7fff8ed45ffb  com.apple.ApplicationServices.ATS (360 - 375.4) <A1BEBCF8-8FC8-345D-B91D-1DA5773AF5A3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                                                    0x7fff8ed53000 -     0x7fff8ed8bfff  libsystem_network.dylib (412.20.3) <6105C134-6722-3C0A-A4CE-5E1261E2E1CC> /usr/lib/system/libsystem_network.dylib
                                                    0x7fff8ed8c000 -     0x7fff8eda3ff7  libLinearAlgebra.dylib (1128) <E78CCBAA-A999-3B65-8EC9-06DB15E67C37> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLinearAlgebra.dylib
                                                    0x7fff8edbc000 -     0x7fff8edd6ff3  com.apple.Ubiquity (1.3 - 313) <DF56A657-CC6E-3BE2-86A0-71F07127724C> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
                                                    0x7fff8edd7000 -     0x7fff8ede4ff7  libbz2.1.0.dylib (36) <2DF83FBC-5C08-39E1-94F5-C28653791B5F> /usr/lib/libbz2.1.0.dylib
                                                    0x7fff8ee47000 -     0x7fff8ee5dff7  libsystem_asl.dylib (267) <F153AC5B-0542-356E-88C8-20A62CA704E2> /usr/lib/system/libsystem_asl.dylib
                                                    0x7fff8ee5e000 -     0x7fff8ee60fff  libRadiance.dylib (1241) <480E8A72-F5F9-31A4-BF63-28BAF3BB1F8E> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
                                                    0x7fff8eeb1000 -     0x7fff8eeb5fff  com.apple.IOAccelerator (156.16 - 156.16) <12DE1474-4B2A-3D7D-ACF9-DDAF66A6936A> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
                                                    0x7fff8eeb6000 -     0x7fff8eec3ff3  com.apple.ProtocolBuffer (1 - 228.0.1) <3429EB06-9F0E-355F-B9AB-F72879177398> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
                                                    0x7fff8eec4000 -     0x7fff8eec5ff3  libSystem.B.dylib (1213) <1866C519-C5F3-3D09-8C17-A8F703664521> /usr/lib/libSystem.B.dylib
                                                    0x7fff8eec6000 -     0x7fff8eecbffb  libheimdal-asn1.dylib (398.40.1) <7D2BE3DE-60F7-3A6E-A92E-DA0EF9D3417E> /usr/lib/libheimdal-asn1.dylib
                                                    0x7fff8efe3000 -     0x7fff8f2b2ff3  com.apple.CoreImage (10.3.4) <C1AE8252-A95D-3BF4-83B8-BE85E979F2CB> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework /Versions/A/CoreImage
                                                    0x7fff8f2e5000 -     0x7fff8f2eeff3  com.apple.CommonAuth (4.0 - 2.0) <9A484EE6-0003-3AB1-AE4F-AA543BBBF53F> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
                                                    0x7fff8f2ef000 -     0x7fff8f320ff7  com.apple.ProtectedCloudStorage (1.0 - 1) <9D76F2E0-C28A-3DBC-A91F-E87888D46BF0> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedClo udStorage
                                                    0x7fff8f36e000 -     0x7fff8f394fff  com.apple.ChunkingLibrary (2.1 - 163.6) <29D4CB95-42EF-34C6-8182-BDB6F7BB1E79> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
                                                    0x7fff8f3b2000 -     0x7fff8f3ccff7  libextension.dylib (55.2) <3BB019CA-199A-36AC-AA22-14B562138545> /usr/lib/libextension.dylib
                                                    0x7fff8f3cd000 -     0x7fff8f5c746f  libobjc.A.dylib (647) <759E155D-BC42-3D4E-869B-6F57D477177C> /usr/lib/libobjc.A.dylib
                                                    0x7fff8f5c8000 -     0x7fff8f656fff  com.apple.CorePDF (4.0 - 4) <19F4CB03-189E-3271-8F7A-A7D0DB3ACE49> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
                                                    0x7fff8f657000 -     0x7fff8f658ff7  libsystem_blocks.dylib (65) <9615D10A-FCA7-3BE4-AA1A-1B195DACE1A1> /usr/lib/system/libsystem_blocks.dylib
                                                    0x7fff8f678000 -     0x7fff8f683fff  com.apple.AppSandbox (4.0 - 238.20.2) <BEFAB7F2-B189-391B-9B2D-FFF3EE2B77B6> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
                                                    0x7fff8f684000 -     0x7fff8f69ffff  com.apple.AppleVPAFramework (1.4.5 - 1.4.5) <A6421B0B-6D4D-3E64-AC61-DDB04ED7CFF0> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
                                                    0x7fff8f6a0000 -     0x7fff8f6a7fff  com.apple.network.statistics.framework (1.2 - 1) <61B311D1-7F15-35B3-80D4-99B8BE90ACD9> /System/Library/PrivateFrameworks/NetworkStatistics.framework/Versions/A/NetworkStatistic s
                                                    0x7fff8f6a8000 -     0x7fff8f721fe7  libcorecrypto.dylib (233.30.1) <5779FFA0-4D9A-3AD4-B7F2-618227621DC8> /usr/lib/system/libcorecrypto.dylib
                                                    0x7fff8f722000 -     0x7fff8f8b0fff  libBLAS.dylib (1128) <497912C1-A98E-3281-BED7-E9C751552F61> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                                                    0x7fff8f8b1000 -     0x7fff8fa40fff  libGLProgrammability.dylib (11.1.6) <5A56E484-5A99-3BD7-99C0-B43D74F2C91C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
                                                    0x7fff8fadb000 -     0x7fff8fae6fff  libGL.dylib (11.1.6) <38B3FF9A-5660-3080-9DB8-1CAE0E8CD739> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                                                    0x7fff8fae7000 -     0x7fff8faf0fff  libGFXShared.dylib (11.1.6) <CB24B5DA-CB17-3A0B-94E1-5A58DADC3FBD> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                                                    0x7fff8fba6000 -     0x7fff900cfff7  com.apple.QuartzComposer (5.1 - 332.1) <64399385-0768-3590-B4EF-1BD0F8A35CB3> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
                                                    0x7fff90112000 -     0x7fff90117fff  libsystem_stats.dylib (163.30.2) <D0E96837-3CF6-323D-B711-6DF6F660E530> /usr/lib/system/libsystem_stats.dylib
                                                    0x7fff90400000 -     0x7fff9044fff7  libstdc++.6.dylib (104.1) <803F6AC8-87DC-3E24-9E80-729B551F6FFF> /usr/lib/libstdc++.6.dylib
                                                    0x7fff90450000 -     0x7fff90635ff7  libicucore.A.dylib (531.50) <CAA7ACE0-4012-3A13-864D-2B56B4B072FD> /usr/lib/libicucore.A.dylib
                                                    0x7fff90636000 -     0x7fff906cdfff  com.apple.CoreMedia (1.0 - 1562.240) <CCAF850F-B2E8-3F3B-9DE9-2BB469403EDF> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
                                                    0x7fff906cf000 -     0x7fff9076ee27  com.apple.AppleJPEG (1.0 - 1) <6627DDD9-A8FE-3968-B23A-B6A29AA3919A> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
                                                    0x7fff9077f000 -     0x7fff9079bff7  libsystem_malloc.dylib (53.30.1) <DDA8928B-CC0D-3255-BD8A-3FEA0982B890> /usr/lib/system/libsystem_malloc.dylib
                                                    0x7fff9079c000 -     0x7fff908fdfff  com.apple.avfoundation (2.0 - 889.210) <E1F0F203-6EA6-3CFA-BC6C-F372F273D6C5> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
                                                    0x7fff908fe000 -     0x7fff90970fff  com.apple.framework.IOKit (2.0.2 - 1050.20.2) <09C0518C-90DF-3FC3-96D6-34D35F72C8EF> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                                                    0x7fff90a2b000 -     0x7fff90a2ffff  libCoreVMClient.dylib (79.1) <201EF6DF-5074-3CB7-A361-398CF957A264> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                                                    0x7fff90a30000 -     0x7fff90c40ff7  com.apple.CFNetwork (720.5.7 - 720.5.7) <A47D7DD2-5903-39D0-8D27-5A7E2D119D84> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                                                    0x7fff90c41000 -     0x7fff90c4cff7  libcsfde.dylib (471.30.1) <A62AE3D8-E2A6-314A-BF45-804003BE0AC9> /usr/lib/libcsfde.dylib
                                                    0x7fff90ca1000 -     0x7fff90cb2ff7  libz.1.dylib (55) <88C7C7DE-04B8-316F-8B74-ACD9F3DE1AA1> /usr/lib/libz.1.dylib
                                                    0x7fff90cb3000 -     0x7fff90cbcfff  libsystem_pthread.dylib (105.40.1) <ACE90967-ECD0-3251-AEEB-461E3C6414F7> /usr/lib/system/libsystem_pthread.dylib
                                                    0x7fff90cbd000 -     0x7fff90cbdff7  liblaunch.dylib (559.40.1) <4F81CA3A-D2CE-3030-A89D-42F3DAD7BA8F> /usr/lib/system/liblaunch.dylib
                                                    0x7fff90d7b000 -     0x7fff90d7dff7  com.apple.securityhi (9.0 - 55006) <2B9C0BCB-7D82-39C2-A99F-7B9E1522CDD6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                                                    0x7fff916cf000 -     0x7fff916f7fff  libxpc.dylib (559.40.1) <5C829202-962E-3744-8B50-00D38CC88E84> /usr/lib/system/libxpc.dylib
                                                    0x7fff916f8000 -     0x7fff91733fff  com.apple.Symbolication (1.4 - 56045) <D64571B1-4483-3FE2-BD67-A91360F79727> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
                                                    0x7fff91734000 -     0x7fff9176bffb  com.apple.LDAPFramework (2.4.28 - 194.5) <CAFB9695-000F-34EA-8DF5-09996929C26A> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
                                                    0x7fff9176c000 -     0x7fff9177eff7  libsasl2.2.dylib (194.1) <35371406-75EF-304A-A073-956C40373555> /usr/lib/libsasl2.2.dylib
                                                    0x7fff91919000 -     0x7fff9191bfff  libquarantine.dylib (76.20.1) <7AF90041-2768-378A-925A-D83161863642> /usr/lib/system/libquarantine.dylib
                                                    0x7fff9191c000 -     0x7fff919b1ff7  com.apple.ColorSync (4.9.0 - 4.9.0) <9150C2B7-2E6E-3509-96EA-7B3F959F049E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                                                    0x7fff919b2000 -     0x7fff919c0ff7  com.apple.opengl (11.1.6 - 11.1.6) <DB9F2798-F31F-335E-90A9-992C3AA7ECA8> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                                                    0x7fff919c1000 -     0x7fff919ccfff  libcommonCrypto.dylib (60061.30.1) <E789748D-F9A7-3CFF-B317-90DF348B1E95> /usr/lib/system/libcommonCrypto.dylib
                                                    0x7fff919cd000 -     0x7fff919d2fff  com.apple.DiskArbitration (2.6 - 2.6) <0DFF4D9B-2AC3-3B82-B5C5-30F4EFBD2DB9> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                                                    0x7fff919d3000 -     0x7fff91a1eff7  com.apple.CloudDocs (1.0 - 321.10) <A8221290-A2A5-3767-BB26-CC57AC18D4DC> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
                                                    0x7fff91a1f000 -     0x7fff91a24ff7  com.apple.MediaAccessibility (1.0 - 61) <00A3E0B6-79AC-387E-B282-AADFBD5722F6> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
                                                    0x7fff91a25000 -     0x7fff91b19ff7  libFontParser.dylib (134.10) <6CF434A2-91CA-3477-BDE2-124508EDA05D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                                                    0x7fff91b36000 -     0x7fff91b50ff7  liblzma.5.dylib (7) <1D03E875-A7C0-3028-814C-3C27F7B7C079> /usr/lib/liblzma.5.dylib
                                                    0x7fff91c3a000 -     0x7fff91c57fff  libsystem_kernel.dylib (2782.50.1) <1EE815DA-FF1B-3A53-AE9B-C98BD8177A9D> /usr/lib/system/libsystem_kernel.dylib
                                                    0x7fff91f1a000 -     0x7fff91f79fff  com.apple.AE (681.5 - 681.7) <2BF39455-1CDD-392C-824A-9972C6B1FB57> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                                                    0x7fff91f7a000 -     0x7fff91fa5ffb  libarchive.2.dylib (30.50.1) <C140763F-5470-3302-B3E0-651B4B5930ED> /usr/lib/libarchive.2.dylib
                                                    0x7fff91fa6000 -     0x7fff92044fff  com.apple.Metadata (10.7.0 - 917.36) <00C4CB5D-E723-3612-84E0-439098392CDD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                                                    0x7fff92055000 -     0x7fff920c1ff3  com.apple.MMCS (1.3 - 327.5) <FC998246-ED60-334D-9E94-453F35EF9C78> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
                                                    0x7fff9210f000 -     0x7fff92118ff7  libsystem_notify.dylib (133.1.1) <61147800-F320-3DAA-850C-BADF33855F29> /usr/lib/system/libsystem_notify.dylib
                                                    0x7fff92141000 -     0x7fff92150fff  com.apple.LangAnalysis (1.7.0 - 1.7.0) <D1E527E4-C561-352F-9457-E8C50232793C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                                                    0x7fff9216b000 -     0x7fff92187fff  com.apple.GenerationalStorage (2.0 - 209.11) <9FF8DD11-25FB-3047-A5BF-9415339B3EEC> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
                                                    0x7fff92498000 -     0x7fff92498fff  com.apple.audio.units.AudioUnit (1.12 - 1.12) <E5335492-7EFE-31EA-BE72-4A9CEE68D58E> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                                                    0x7fff92499000 -     0x7fff9249fff7  com.apple.XPCService (2.0 - 1) <AA4A5393-1F5D-3465-A417-0414B95DC052> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
                                                    0x7fff924a0000 -     0x7fff924a8fe7  libcldcpuengine.dylib (2.4.5) <6CC680F9-0D13-333B-B151-F0D9C631A1E5> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
                                                    0x7fff924da000 -     0x7fff92527ff3  com.apple.CoreMediaIO (601.0 - 4760) <F3388B24-3498-3E91-8878-7CC87330AEC2> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
                                                    0x7fff92528000 -     0x7fff92597fff  com.apple.SearchKit (1.4.0 - 1.4.0) <80883BD1-C9BA-3794-A20E-476F94DD89A9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                                                    0x7fff925f5000 -     0x7fff92725fff  com.apple.UIFoundation (1.0 - 1) <466BDFA8-0B9F-3AB0-989D-F9779422926A> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
                                                    0x7fff92726000 -     0x7fff92756ff3  com.apple.GSS (4.0 - 2.0) <97F2A028-44CF-3188-B863-F4EEB39CBDBD> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
                                                    0x7fff928a0000 -     0x7fff928bffff  com.apple.CoreDuet (1.0 - 1) <36AA9FD5-2685-314D-B364-3FA4688D86BD> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
                                                    0x7fff92b06000 -     0x7fff92b0afff  com.apple.CommonPanels (1.2.6 - 96) <F9ECC8AF-D9CA-3350-AFB4-5113A9B789A5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                                                    0x7fff92b3e000 -     0x7fff92b41ff7  com.apple.Mangrove (1.0 - 1) <6326024D-5C8D-3F59-9468-ACA1E01BC70C> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
                                                    0x7fff92b42000 -     0x7fff92b74ff3  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <C6DB0A07-F8E4-3837-BCA9-225F460EDA81> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
                                                    0x7fff92b97000 -     0x7fff92bbbff7  com.apple.quartzfilters (1.10.0 - 1.10.0) <1AE50F4A-0098-34E7-B24D-DF7CB94073CE> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
                                                    0x7fff92bbc000 -     0x7fff92bd7ff7  libCRFSuite.dylib (34) <D64842BE-7BD4-3D0C-9842-1D202F7C2A51> /usr/lib/libCRFSuite.dylib
                                                    0x7fff92bd8000 -     0x7fff92cfcff7  com.apple.LaunchServices (644.56 - 644.56) <20AABB1C-9319-3E4D-A024-51B0DD5FCD3B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                                                    0x7fff92cfd000 -     0x7fff92d27fff  GLRendererFloat (11.1.6) <EB135987-0B93-393F-9139-CAB7F6FEBB12> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/G LRendererFloat
                                                    0x7fff92d28000 -     0x7fff92d35ff7  com.apple.SpeechRecognitionCore (2.1.2 - 2.1.2) <551322E2-C1E4-3378-A218-F362985E3E3C> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecogn itionCore
                                                    0x7fff92d36000 -     0x7fff92d61fff  libc++abi.dylib (125) <88A22A0F-87C6-3002-BFBA-AC0F2808B8B9> /usr/lib/libc++abi.dylib
                                                    0x7fff92d62000 -     0x7fff92d68ff7  libsystem_networkextension.dylib (167.40.3) <BA58B30B-8377-3B0A-8AE3-4F84021D9D4E> /usr/lib/system/libsystem_networkextension.dylib
                                                    0x7fff92d69000 -     0x7fff92fd3ff7  com.apple.imageKit (2.6.1 - 850) <612201FE-768E-386B-82E3-764038B40120> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
                                                    0x7fff92fd4000 -     0x7fff93001fff  com.apple.CoreVideo (1.8 - 145.1) <18DB07E0-B927-3260-A234-636F298D1917> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                                                    0x7fff93087000 -     0x7fff933f2fff  com.apple.VideoToolbox (1.0 - 1562.240) <BEBDEB83-618F-38BE-B7A7-5E096B428DFA> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
                                                    0x7fff933f3000 -     0x7fff934aeff7  com.apple.DiscRecording (9.0 - 9000.4.2) <4655B4B8-523D-3AE6-92A0-8486A2258B3B> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
                                                    0x7fff934cb000 -     0x7fff934d2ff7  libcompiler_rt.dylib (35) <BF8FC133-EE10-3DA6-9B90-92039E28678F> /usr/lib/system/libcompiler_rt.dylib
                                                    0x7fff934e9000 -     0x7fff93538ff7  com.apple.opencl (2.4.2 - 2.4.2) <EB365E68-9965-3596-A40A-D1E372F3A9B3> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                                                    0x7fff93551000 -     0x7fff935daff7  com.apple.CoreSymbolication (3.1 - 57020.2) <FDAF88F6-7D11-37BC-B758-4B835FA657BA> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
                                                    0x7fff935e7000 -     0x7fff935f4fff  libxar.1.dylib (255) <7CD69BB5-97BA-3858-8A8B-2F33F129E6E7> /usr/lib/libxar.1.dylib
                                                    0x7fff935f5000 -     0x7fff935f5ff7  libunc.dylib (29) <5676F7EA-C1DF-329F-B006-D2C3022B7D70> /usr/lib/system/libunc.dylib
                                                    0x7fff935fc000 -     0x7fff935fdffb  libremovefile.dylib (35) <3485B5F4-6CE8-3C62-8DFD-8736ED6E8531> /usr/lib/system/libremovefile.dylib
                                                    0x7fff935fe000 -     0x7fff9417fff7  com.apple.AppKit (6.9 - 1348.17) <E485D56D-3E72-34B7-99BB-BFDEE2D07BF5> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                                                    0x7fff94180000 -     0x7fff94193ff7  com.apple.CoreBluetooth (1.0 - 1) <8D7BA9BA-EB36-307A-9119-0B3D9732C953> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
                                                    0x7fff9432a000 -     0x7fff94385ff7  libTIFF.dylib (1241) <4FADAE48-44A5-351D-A33F-211A9544E5A9> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
                                                    0x7fff94386000 -     0x7fff9471eff7  com.apple.CoreFoundation (6.9 - 1153.18) <5C0892B8-9691-341F-9279-CA3A74D59AA0> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                                                    0x7fff94735000 -     0x7fff9473dfff  libsystem_dnssd.dylib (576.50.2) <9EC5AF92-D0D2-3BDE-92B6-D3730D3865C8> /usr/lib/system/libsystem_dnssd.dylib
                                                    0x7fff9483a000 -     0x7fff9483bfff  libsystem_secinit.dylib (18) <581DAD0F-6B63-3A48-B63B-917AF799ABAA> /usr/lib/system/libsystem_secinit.dylib
                                                    0x7fff9483c000 -     0x7fff9492fff7  libJP2.dylib (1241) <E3D08E10-9E4E-3C19-B107-233A567B20D8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
                                                    0x7fff94963000 -     0x7fff94984fff  com.apple.framework.Apple80211 (10.3 - 1030.71.6) <C0A17391-5C8B-34B1-BD46-8D644AB57DE0> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
                                                    0x7fff94985000 -     0x7fff9499bff7  com.apple.CoreMediaAuthoring (2.2 - 951) <C3E7D4C1-400D-34FA-9FE1-8C68C03CE969> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
                                                    0x7fff94d25000 -     0x7fff94d27fff  com.apple.loginsupport (1.0 - 1) <DAAD7013-A19D-3858-BFF7-DE1DAF664401> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.fram ework/Versions/A/loginsupport
                                                    0x7fff94d28000 -     0x7fff94d30ff7  com.apple.icloud.FindMyDevice (1.0 - 1) <9CE67F85-2BA8-3093-97BA-07BF5C04A5D6> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
                                                    0x7fff94d31000 -     0x7fff94d34fff  com.apple.IOSurface (97.4 - 97.4) <AE11CFBC-4D46-30F3-BEEC-4C8131079391> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                                                    0x7fff94d37000 -     0x7fff94d43fff  com.apple.speech.synthesis.framework (5.3.11 - 5.3.11) <DFC7FD85-F1B0-317C-8513-722570CB8FB9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                                                    0x7fff94d44000 -     0x7fff94e07ff7  libvMisc.dylib (516) <21497A28-8DCB-3EB8-BDAC-93C93382B0AA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                                                    0x7fff94e08000 -     0x7fff94e08fff  com.apple.Accelerate (1.10 - Accelerate 1.10) <F1B96A61-7E4B-31BD-A35B-BA7EF1F16EF4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                                                    0x7fff9576a000 -     0x7fff957bbfff  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <8E6AE326-9F3E-3182-BD9E-FDF561211E2E> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                                                    0x7fff957bc000 -     0x7fff95808ff7  libcups.2.dylib (408.2) <E8AD18F9-61E4-3791-B840-504468C25556> /usr/lib/libcups.2.dylib
                                                    0x7fff95809000 -     0x7fff95815ff7  libGPUSupportMercury.dylib (11.1.6) <C591F35C-AA0E-3145-8783-54276201C4B8> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport Mercury.dylib
                                                    0x7fff95816000 -     0x7fff96079ff7  com.apple.CoreGraphics (1.600.0 - 788.3.2) <025FF107-A972-38AE-B313-6F9129B50C75> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
                                                    0x7fff9607e000 -     0x7fff96081ff7  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <BCC15965-7869-34F4-9019-9D0A41DD6AFF> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
                                                    0x7fff96082000 -     0x7fff96086ff7  libGIF.dylib (1241) <8A3CB11A-5CB9-3008-A0E1-F8B56125F484> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
                                                    0x7fff96087000 -     0x7fff9608dfff  com.apple.speech.recognition.framework (5.0.9 - 5.0.9) <BB2D573F-0A01-379F-A2BA-3C454EDCB111> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                                                    0x7fff9608e000 -     0x7fff960d4ff7  libFontRegistry.dylib (134.1) <CE41D8C2-BEED-345C-BC4F-3775CC06C672> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                                                    0x7fff96157000 -     0x7fff9615bfff  libpam.2.dylib (20) <E805398D-9A92-31F8-8005-8DC188BD8B6E> /usr/lib/libpam.2.dylib
                                                    0x7fff9615c000 -     0x7fff9621cff7  com.apple.backup.framework (1.6.5 - 1.6.5) <86396038-33EA-3046-9F70-093A3D6407D4> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
                                                    0x7fff9621e000 -     0x7fff9632dff3  com.apple.desktopservices (1.9.3 - 1.9.3) <FEE11342-5BC4-37A7-8169-DA48BE17B9C9> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                                                    0x7fff9632e000 -     0x7fff9635afff  libsandbox.1.dylib (358.20.5) <533B9C4A-6C92-3658-95B9-D30BC135796B> /usr/lib/libsandbox.1.dylib
                                                    0x7fff97328000 -     0x7fff9732dff7  libunwind.dylib (35.3) <BE7E51A0-B6EA-3A54-9CCA-9D88F683A6D6> /usr/lib/system/libunwind.dylib
                                                    0x7fff97348000 -     0x7fff97362ff7  com.apple.Kerberos (3.0 - 1) <7760E0C2-A222-3709-B2A6-B692D900CEB1> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                                                    0x7fff97363000 -     0x7fff97367fff  libcache.dylib (69) <45E9A2E7-99C4-36B2-BEE3-0C4E11614AD1> /usr/lib/system/libcache.dylib
                                                    0x7fff9739e000 -     0x7fff9739efff  com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <B92888D0-ED3F-3430-8F3A-6E56FD16C5F1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                                                    0x7fff9739f000 -     0x7fff9754efff  GLEngine (11.1.6) <8AD12D78-85C6-3B9C-BB0A-153A66236A56> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
                                                    0x7fff9756c000 -     0x7fff9756efff  libCVMSPluginSupport.dylib (11.1.6) <F82BF8C4-12D3-3EAD-AEDE-533AC08AEB4A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
                                                    0x7fff9756f000 -     0x7fff97605ff7  com.apple.cloudkit.CloudKit (283.67.4 - 283.67.4) <EA6E4B2C-A3AA-3636-B9C3-F61D3EFFB82B> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
                                                    0x7fff97611000 -     0x7fff97613fff  com.apple.CoreDuetDebugLogging (1.0 - 1) <9A6E5710-EA99-366E-BF40-9A65EC1B46A1> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebug Logging
                                                    0x7fff9761a000 -     0x7fff9764afff  libsystem_m.dylib (3086.1) <1E12AB45-6D96-36D0-A226-F24D9FB0D9D6> /usr/lib/system/libsystem_m.dylib
                                                    0x7fff97748000 -     0x7fff9774bfff  com.apple.help (1.3.3 - 46) <CA4541F4-CEF5-355C-8F1F-EA65DC1B400F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                                                    0x7fff9774c000 -     0x7fff977a6ff7  com.apple.LanguageModeling (1.0 - 1) <ACA93FE0-A0E3-333E-AE3C-8EB7DE5F362F> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
                                                    0x7fff977a7000 -     0x7fff97849fff  com.apple.Bluetooth (4.3.6 - 4.3.6f3) <E5DC1699-2727-329C-A843-C80CE9A6CD7B> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
                                                    0x7fff9784a000 -     0x7fff978b8ff3  com.apple.Heimdal (4.0 - 2.0) <8D1667CF-D454-3E07-A58E-E15591B5A95E> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
                                                    0x7fff97979000 -     0x7fff97980ff7  libCGCMS.A.dylib (788.3.2) <76F72DC8-B7C7-377B-BDB4-DF2DAF757FE9> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGCMS.A.dylib
                                                    0x7fff97981000 -     0x7fff9798bff7  com.apple.NetAuth (5.2 - 5.2) <2BBD749A-8E18-35B8-8E48-A90347C1CCA7> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
                                                    0x7fff9798c000 -     0x7fff97991ff7  libmacho.dylib (862) <126CA2ED-DE91-308F-8881-B9DAEC3C63B6> /usr/lib/system/libmacho.dylib
                                                    0x7fff97992000 -     0x7fff97992fff  com.apple.ApplicationServices (48 - 48) <5BF7910B-C328-3BF8-BA4F-CE52B574CE01> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                                                    0x7fff97a1a000 -     0x7fff97a2cff7  com.apple.ImageCapture (9.0 - 9.0) <7FB65DD4-56B5-35C4-862C-7A2DED991D1F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                                                    0x7fff97a2d000 -     0x7fff97a68fff  com.apple.QD (301 - 301) <C4D2AD03-B839-350A-AAF0-B4A08F8BED77> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                                                    0x7fff97acf000 -     0x7fff97dd4ff3  com.apple.HIToolbox (2.1.1 - 758.7) <E3129A67-BDF9-333D-9C9C-A95C8F0EF71C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                                                    0x7fff97dd5000 -     0x7fff97de6ff3  libsystem_coretls.dylib (35.40.1) <155DA0A9-2046-332E-BFA3-D7974A51F731> /usr/lib/system/libsystem_coretls.dylib
                                                    0x7fff97dff000 -     0x7fff98130fff  com.apple.Foundation (6.9 - 1154) <49EE64E1-9F53-35D1-A481-2EFE2789B254> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                                                    0x7fff98140000 -     0x7fff98178fff  com.apple.RemoteViewServices (2.0 - 99) <C9A62691-B0D9-34B7-B71C-A48B5F4DC553> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
                                                    0x7fff981b4000 -     0x7fff98238fff  com.apple.PerformanceAnalysis (1.0 - 1) <4E934EE0-5CC6-3D54-8FA2-5B8AE669D775> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
                                                    0x7fff9825e000 -     0x7fff98260fff  com.apple.SecCodeWrapper (4.0 - 238.20.2) <C6C126F0-6BF4-3E29-A9B7-7BAD8D17EE4F> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
                                                    0x7fff98299000 -     0x7fff982a9ff7  libbsm.0.dylib (34) <A3A2E56C-2B65-37C7-B43A-A1F926E1A0BB> /usr/lib/libbsm.0.dylib
                                                    0x7fff982db000 -     0x7fff98300ff7  libPng.dylib (1241) <E4244E6E-60F4-3478-BD18-1DD52E42EFD9> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
                                                    0x7fff98301000 -     0x7fff98334fff  com.apple.MediaKit (16 - 757.2) <2912E5C2-085F-3FE2-8531-23B6E894B0F0> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
                                                    0x7fff98335000 -     0x7fff98389fff  libc++.1.dylib (120) <1B9530FD-989B-3174-BB1C-BDC159501710> /usr/lib/libc++.1.dylib
                                                    0x7fff9839a000 -     0x7fff983e0ff7  libauto.dylib (186) <A260789B-D4D8-316A-9490-254767B8A5F1> /usr/lib/libauto.dylib
                                                    0x7fff983e1000 -     0x7fff983e9fff  libsystem_platform.dylib (63) <64E34079-D712-3D66-9CE2-418624A5C040> /usr/lib/system/libsystem_platform.dylib
                                                    0x7fff983ea000 -     0x7fff9883dfc7  com.apple.vImage (8.0 - 8.0) <33BE7B31-72DB-3364-B37E-C322A32748C5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                                                    0x7fff9883e000 -     0x7fff98857ff3  com.apple.openscripting (1.6.4 - 162.2) <BF79207B-C762-346D-8FF0-3DDCECC9E9E2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                                                    0x7fff988b3000 -     0x7fff988b4fff  liblangid.dylib (117) <B54A4AA0-2E53-3671-90F5-AFF711C0EB9E> /usr/lib/liblangid.dylib
                                                    0x7fff988b5000 -     0x7fff988b5fff  com.apple.Cocoa (6.8 - 21) <EAC0EA1E-3C62-3B28-A941-5D8B1E085FF8> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                                                    0x7fff988c9000 -     0x7fff988cbfff  libsystem_configuration.dylib (699.40.2) <56F94DCE-DBDE-3615-8F07-DE6270D9F8BE> /usr/lib/system/libsystem_configuration.dylib
                                                    0x7fff988ef000 -     0x7fff988f7ffb  libcopyfile.dylib (118.1.2) <0C68D3A6-ACDD-3EF3-991A-CC82C32AB836> /usr/lib/system/libcopyfile.dylib
                                                    0x7fff988f8000 -     0x7fff988fcfff  com.apple.TCC (1.0 - 1) <CCA42EE2-3400-3444-9486-BC454E60D944> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
                                                    0x7fff988fd000 -     0x7fff98bffffb  com.apple.GeoServices (1.0 - 1077.0.18) <2BBF8B44-DD46-3432-8C84-6D6AA004C233> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
                                                    0x7fff98c48000 -     0x7fff98c4efff  libsystem_trace.dylib (72.20.1) <840F5301-B55A-3078-90B9-FEFFD6CD741A> /usr/lib/system/libsystem_trace.dylib
                                                    0x7fff98c7c000 -     0x7fff98d08fff  libsystem_c.dylib (1044.40.2) <69158EFA-8270-30A1-BA02-4F74A4498147> /usr/lib/system/libsystem_c.dylib
                                                    0x7fff98d09000 -     0x7fff98e70ffb  com.apple.audio.toolbox.AudioToolbox (1.12 - 1.12) <5678FC94-456A-3F5F-BA9A-10EB6E462997> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                                                    0x7fff99141000 -     0x7fff991b5ffb  com.apple.securityfoundation (6.0 - 55126) <344401F5-4016-3AEB-BFDC-CE8E5546D39F> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                                                    0x7fff991b6000 -     0x7fff994e9ff7  libmecabra.dylib (666.7) <0ED8AE5E-7A5B-34A6-A2EE-2B852E60E1E2> /usr/lib/libmecabra.dylib
                                                    0x7fff994ea000 -     0x7fff9952bfff  libGLU.dylib (11.1.6) <4BC6579D-A6D0-3A19-880E-E29FAEA698E7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                                                    0x7fff997ca000 -     0x7fff997ccff7  libsystem_coreservices.dylib (9) <41B7C578-5A53-31C8-A96F-C73E030B0938> /usr/lib/system/libsystem_coreservices.dylib
                                                    0x7fff99856000 -     0x7fff998a4ff7  com.apple.ImageCaptureCore (6.3 - 6.3) <75B5043C-9EF0-3CD2-875D-12813F0A73D3> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
                                                    0x7fff998aa000 -     0x7fff998aafff  com.apple.quartzframework (1.5 - 1.5) <26C982A3-2FC3-3F50-B5F4-3C545C3BAC10> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
                                                    0x7fff998ab000 -     0x7fff998b6ff7  libkxld.dylib (2782.50.1) <F346A631-20E3-3BA3-891F-FA95189CD7A9> /usr/lib/system/libkxld.dylib
                                                    0x7fff998b7000 -     0x7fff998f7ff7  libGLImage.dylib (11.1.6) <D6DDC014-2C74-34B3-970A-26F211FF76EF> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                                                    0x7fff998f8000 -     0x7fff99900ff3  com.apple.CoreServices.FSEvents (1210.20.1 - 1210.20.1) <84F79D3E-7B5E-3C93-8479-35794A3F125E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framewor k/Versions/A/FSEvents
                                                    0x7fff99901000 -     0x7fff99a1affb  com.apple.CoreText (454.11 - 454.11) <7E5228C8-8657-3B6C-B3A4-98B79A3041EA> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
                                                    0x7fff99a37000 -     0x7fff99a37fff  libOpenScriptingUtil.dylib (162.2) <D6A2216D-ADB2-3F24-AD30-F6D00829F545> /usr/lib/libOpenScriptingUtil.dylib
                                                    0x7fff99a38000 -     0x7fff99a58fff  com.apple.IconServices (47.1 - 47.1) <E83DFE3B-6541-3736-96BB-26DC5D0100F1> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
                                                    0x7fff99a59000 -     0x7fff99a5aff7  com.apple.print.framework.Print (10.0 - 265) <3BC4FE7F-78A0-3E57-8F4C-520E7EFD36FA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                                                    0x7fff99a5b000 -     0x7fff99a5dfff  com.apple.EFILogin (2.0 - 2) <3BA837D8-94F5-3240-9CF7-E40DC2808446> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
                                                    0x7fff99a5e000 -     0x7fff99e8efff  com.apple.vision.FaceCore (3.1.6 - 3.1.6) <C3B823AA-C261-37D3-B4AC-C59CE91C8241> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
                                                    0x7fff99f4b000 -     0x7fff99f4dff7  libutil.dylib (38) <471AD65E-B86E-3C4A-8ABD-B8665A2BCE3F> /usr/lib/libutil.dylib
                                                    0x7fff9a7d7000 -     0x7fff9acecffb  com.apple.JavaScriptCore (10600 - 10600.8.7) <480CDC12-5A1C-321C-B32F-673F0B3BA8F9> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
                                                    0x7fff9acf8000 -     0x7fff9ad4bffb  libAVFAudio.dylib (118.6) <2441D4C1-D8FB-3DA9-9DD7-914E03413882> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
                                                    0x7fff9ae44000 -     0x7fff9aec2fff  com.apple.CoreServices.OSServices (640.4 - 640.4) <BE8DF749-84BA-3029-AE1D-32F3993A78A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                                                    0x7fff9aec3000 -     0x7fff9b007ff7  com.apple.QTKit (7.7.3 - 2890.9) <993AF630-272B-3AE6-97A5-946C4283485A> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
                                                    0x7fff9b0e8000 -     0x7fff9b225fff  com.apple.ImageIO.framework (3.3.0 - 1241) <BCBBC66A-5028-3BA5-8087-C9E7BBC3A65B> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
                                                    0x7fff9b226000 -     0x7fff9b229ffb  libCGXType.A.dylib (788.3.2) <EA4E8436-FFE4-3D05-B7D7-7417987E4574> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
                                                    0x7fff9b22a000 -     0x7fff9b22afff  com.apple.CoreServices (62 - 62) <C69DA8A7-B536-34BF-A93F-1C170E2C6D58> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                                                    0x7fff9b22b000 -     0x7fff9b4aaff7  com.apple.CoreData (111 - 526.3) <5A27E0D8-5E5A-335B-B3F6-2601C7B976FA> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                                                    0x7fff9b4ab000 -     0x7fff9b4cbff7  com.apple.MultitouchSupport.framework (264.6 - 264.6) <1539F1F6-6334-37F3-9C52-02EFFBF4835D> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                                                    0x7fff9b564000 -     0x7fff9b581ffb  libresolv.9.dylib (57) <26B38E61-298A-3C3A-82C1-3B5E98AD5E29> /usr/lib/libresolv.9.dylib
                                                    0x7fff9b5ed000 -     0x7fff9b63cff7  libcurl.4.dylib (83.40.2) <AE97ED1E-A58F-3EF0-8E88-DDC6AD409BCE> /usr/lib/libcurl.4.dylib
                                                    0x7fff9b63d000 -     0x7fff9b63fff3  com.apple.SafariServices.framework (10601 - 10601.4.4) <82065DAF-DA17-3408-B809-11643DC9EC91> /System/Library/PrivateFrameworks/SafariServices.framework/Versions/A/SafariServices
                                                    0x7fff9b640000 -     0x7fff9b659ff7  com.apple.CFOpenDirectory (10.10 - 187) <F1805A0F-D5CC-35A8-9349-042D58D128B0> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                                                    0x7fff9b65a000 -     0x7fff9b665ff7  com.apple.CrashReporterSupport (10.10 - 631) <C44259AC-0A1C-3EC5-99AC-48CB520A709D> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
                                                    0x7fff9b666000 -     0x7fff9b6f7ff7  libCoreStorage.dylib (471.30.1) <9D95399F-1AC5-325F-8337-6E13AD99E44B> /usr/lib/libCoreStorage.dylib
                                                    0x7fff9b720000 -     0x7fff9b728fff  libMatch.1.dylib (24) <C917279D-33C2-38A8-9BDD-18F3B24E6FBD> /usr/lib/libMatch.1.dylib
                                                    0x7fff9b729000 -     0x7fff9b840fe7  libvDSP.dylib (516) <DFEDB210-49D1-3803-88A2-C61DB6A45C3D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                                                    0x7fff9b841000 -     0x7fff9bd31fff  com.apple.MediaToolbox (1.0 - 1562.240) <756EDFE0-6D9E-3482-AE40-6D2E6A7042F1> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
                                                    0x7fff9bd6b000 -     0x7fff9bd8fff7  com.apple.Sharing (328.17 - 328.17) <AD5E243A-B79F-3D7B-800B-A2C99A1CFEF1> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
                                                    0x7fff9bd90000 -     0x7fff9beb8ff7  com.apple.coreui (2.1 - 308.6) <9E0E9C6A-68F5-34C1-A17C-96226D401D4D> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                                                    0x7fff9bf5e000 -     0x7fff9bfa8fff  com.apple.HIServices (1.22 - 523) <E2F3C5FF-8C50-3E4F-BE63-77A700466663> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                                                    0x7fff9bfa9000 -     0x7fff9bfd4ff7  com.apple.DictionaryServices (1.2 - 229.1) <62EC3E1B-5A28-3252-90FF-C2E9999C2A2A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                                                    0x7fff9c0cd000 -     0x7fff9c14eff7  com.apple.CoreUtils (1.1 - 110.1) <3808CBC5-1DF1-3821-8AAE-57C30D4F514B> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
                                                    0x7fff9c14f000 -     0x7fff9c3c5fff  com.apple.security (7.0 - 57031.40.8) <FB238FFF-AA3B-3AB3-80F8-2DA8D2ADA15A> /System/Library/Frameworks/Security.framework/Versions/A/Security
                                                    0x7fff9c3d3000 -     0x7fff9c3dafff  com.apple.NetFS (6.0 - 4.0) <C263C8F8-F284-3101-AC82-A97A81716063> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                                                    0x7fff9c3f5000 -     0x7fff9c41fff7  libdispatch.dylib (442.50.1) <A61E703C-784A-3698-B513-75DD12AAD6DC> /usr/lib/system/libdispatch.dylib
                                                    0x7fff9c49e000 -     0x7fff9c4fbfff  com.apple.QuickLookFramework (5.0 - 675.43) <506D60B4-B188-3D0A-9187-0404A60A9B06> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
                                                    0x7fff9c4fc000 -     0x7fff9c535fff  com.apple.AirPlaySupport (2.0 - 215.18) <A7730005-A538-30E8-815B-727957D74C89> /System/Library/PrivateFrameworks/AirPlaySupport.framework/Versions/A/AirPlaySupport
                                                External Modification Summary:
                                                  Calls made by other processes targeting this process:
                                                    task_for_pid: 2
                                                    thread_create: 0
                                                    thread_set_state: 0
                                                  Calls made by this process:
                                                    task_for_pid: 0
                                                    thread_create: 0
                                                    thread_set_state: 0
                                                  Calls made by all processes on this machine:
                                                    task_for_pid: 13412
                                                    thread_create: 0
                                                    thread_set_state: 0
                                                VM Region Summary:
                                                ReadOnly portion of Libraries: Total=428.3M resident=184.4M(43%) swapped_out_or_unallocated=243.8M(57%)
                                                Writable regions: Total=2.7G written=771.2M(28%) resident=817.0M(30%) swapped_out=0K(0%) unallocated=1.9G(70%)
                                                REGION TYPE                      VIRTUAL
                                                CG backing stores                  8888K
                                                CG image                             68K
                                                CG shared images                    240K
                                                CoreImage                             8K
                                                CoreUI image data                    60K
                                                IOKit                              1116K
                                                Image IO                             40K
                                                Kernel Alloc Once                     8K
                                                MALLOC                            265.4M
                                                MALLOC (admin)                       32K
                                                MALLOC_LARGE (reserved)             196K        reserved VM address space (unallocated)
                                                Memory Tag 242                       12K
                                                OpenCL                               16K
                                                OpenGL GLSL                         256K
                                                STACK GUARD                        56.1M
                                                Stack                              20.8M
                                                VM_ALLOCATE                         2.4G
                                                __DATA                             36.9M
                                                __GLSLBUILTINS                     2588K
                                                __IMAGE                             528K
                                                __LINKEDIT                         95.2M
                                                __TEXT                            333.1M
                                                __UNICODE                           552K
                                                mapped file                        96.6M
                                                shared memory                        28K
                                                TOTAL                               3.3G
                                                TOTAL, minus reserved VM space      3.3G
                                                • 21. Re: Bridge CC keeps crashing when viewing folder
                                                  VikramSethi Adobe Employee
                                                  Thanks for sharing the crash stack. This crash is surely different than the one for which I suggested the workaround.
                                                  Are there some specific images/assets in the folders which result in crash when browsing? Based on the crash stack I am trying to isolate the problem.
                                                  Vikram Sethi
                                                  • 22. Re: Bridge CC keeps crashing when viewing folder
                                                    beni Level 1
                                                    no, just some collections of jpg or png or tif...
                                                    • 23. Re: Bridge CC keeps crashing when viewing folder
                                                      Rubicon04 Level 1
                                                      This problem started not long ago, maybe a month or so.  Same stack as other respondent.  Crashing on a folder full of nothing but small JPG's.  But it crashes everywhere else, too.  I'm on a Macbook Pro (late 2013) running ElCapitan latest version.
                                                      I've tried every suggestion made on this forum and others.  Nothing stops this crashing, and I now have to use Bridge CC on my Windows machine where it works just fine.  I see this thread going back awhile with absolutely zero value answers from Adobe. Must be using programmers from Fiji or something. Let's all remember the CC update killing off our files recently.
                                                      This is stupidity beyond belief... and I'm paying full retail for this every month.
                                                      • 24. Re: Bridge CC keeps crashing when viewing folder
                                                        beni Level 1
                                                        Rubicon, i bet your post will be deleted as well soon...
                                                        but please... Adobe staff...
                                                        i'm aware now that you can be fast to delete posts that say things you don't want people to read... but... can you provide as fast some solutions to our problems?
                                                        • 25. Re: Bridge CC keeps crashing when viewing folder
                                                          ShaneH Level 1
                                                          My bridge is crashing so much, I'm thinking of shelving it completely, in favor of just using the Mac OS. I have thousands of folders full of photography on a Windows server that I need to view. Almost every one crashes halfway through viewing.
                                                          Adobe needs to re-think the whole caching thing. The best search and viewing programs do not use caching at all, and are fast and reliable. Today's computers and networks are so fast, caches no longer serve any purpose — except to become corrupted and create bugs.
                                                          • 26. Re: Bridge CC keeps crashing when viewing folder
                                                            murphdawg13
                                                            I am also struggling with Bridge crashing over and over and over again. HELP
                                                            • 28. Re: Bridge CC keeps crashing when viewing folder
                                                              ronnyv54315134
                                                              hello,
                                                              we are having the same problem... Bridge keeps crashing.... sometimes every minute...
                                                              We need a solution.
                                                              • 29. Re: Bridge CC keeps crashing when viewing folder
        rossee66 Level 1
        We're having the same problem on all three machines in the studio.
        I just found this link which sounds promising Solution to fix Bridge CC 6.1.1 and 6.2 crashing on Mac OS X El Capitan
        • 30. Re: Bridge CC keeps crashing when viewing folder
        Bazzatee
        I am having the same problem on my IMAC but seems to be ok on my macbook pro. It is very frustrating and surely the bug should have been fixed by now. I have tried all the work arounds. Re-Install. Nothing works.
        • 31. Re: Bridge CC keeps crashing when viewing folder
        pulling fotograaf rudy
        I had the same problem with 1 particular folder.
        Then at a certain moment I have created a new folder and moved all files to that new folder and since then it seems Bridge is stable.
        But I do have another problem and I'm not sure if this is the correct place to ask/mention it.
        The last couple weeks/months Bridge is having a lot of trouble.
        My computer says a lot of times Bridge is not responding.
        This happens after I do a startup, but also when I am adding labels, ratings and keywords.
        To me it seems Bridge is having trouble with making the cache file.
        Are others having the same trouble?
        Oh forgot to mention I have this problem on my MacBook Pro and iMac.
        Both run on El Capitan with the latest updates.
        • 32. Re: Bridge CC keeps crashing when viewing folder
        Rob Walshe Level 1
        Just upgraded to Adobe CC. Bridge keeps crashing while it is populating folders containing only jpegs, eps and .pdfs. It seems to preview about 20-40 images before it crashes. When i reopen Bridge it continues to preview from the point it crashed, then crashes again. Tried a different folder, same issue.
        32gb RAM, 3.4ghz imac
        • 33. Re: Bridge CC keeps crashing when viewing folder
        Bazzatee Level 1
        Does anyone at Adobe have any idea why this is happening please. I have uninstalled everything and reinstalled but Bridge just crashes as soon as I try to access a folder. In case it is of any help this is the latest crash stack, which is sent to Apple every time it happens.
        1   com.adobe.bridge6             0x000000010dd89ca7 0x10dcd2000 + 752807
        2   com.adobe.bridge6             0x000000010e0ddb80 0x10dcd2000 + 4242304
        3   com.adobe.bridge6             0x000000010e0dd65e 0x10dcd2000 + 4240990
        4   libsystem_pthread.dylib       0x00007fff91ac799d _pthread_body + 131
        5   libsystem_pthread.dylib       0x00007fff91ac791a _pthread_start + 168
        6   libsystem_pthread.dylib       0x00007fff91ac5351 thread_start + 13
        Thread 20:
        0   libsystem_kernel.dylib         0x00007fff8b8db5e2 __workq_kernreturn + 10
        1   libsystem_pthread.dylib       0x00007fff91ac7578 _pthread_wqthread + 1283
        2   libsystem_pthread.dylib       0x00007fff91ac5341 start_wqthread + 13
        Thread 21:
        0   libsystem_kernel.dylib         0x00007fff8b8dadb6 __psynch_cvwait + 10
        1   libsystem_pthread.dylib       0x00007fff91ac875e _pthread_cond_wait + 821
        2   com.apple.CoreServices.CarbonCore 0x00007fff8ae98a93 TSWaitOnConditionTimedRelative + 147
        3   com.apple.CoreServices.CarbonCore 0x00007fff8ae71012 MPWaitOnQueue + 192
        4   com.adobe.dvacore.framework   0x00000001154151dc dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::auto_ptr<dvacore::threads::Al locatedFunctionT<boost::function<void ()> > >&, int) + 140
        5   com.adobe.dvacore.framework   0x00000001154131b0 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 144
        6   com.adobe.dvacore.framework   0x000000011540378c boost::function0<void>::operator()() const + 28
        7   com.adobe.dvacore.framework   0x0000000115410123 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()> const&, boost::function<void ()> const&) + 115
        8   com.adobe.boost_threads.framework 0x00000001151a9fc9 thread_proxy + 185
        9   libsystem_pthread.dylib       0x00007fff91ac799d _pthread_body + 131
        10  libsystem_pthread.dylib       0x00007fff91ac791a _pthread_start + 168
        11  libsystem_pthread.dylib       0x00007fff91ac5351 thread_start + 13
        Thread 22:
        1   libsystem_pthread.dylib       0x00007fff91ac8728 _pthread_cond_wait + 767
        2   com.apple.CoreServices.CarbonCore 0x00007fff8ae988ac TSWaitOnCondition + 108
        3   com.apple.CoreServices.CarbonCore 0x00007fff8ae98aab TSWaitOnConditionTimedRelative + 171
        4   com.apple.CoreServices.CarbonCore 0x00007fff8ae71012 MPWaitOnQueue + 192
        5   com.adobe.dvacore.framework   0x00000001154151dc dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::auto_ptr<dvacore::threads::Al locatedFunctionT<boost::function<void ()> > >&, int) + 140
        6   com.adobe.dvacore.framework   0x00000001154131b0 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 144
        7   com.adobe.dvacore.framework   0x000000011540378c boost::function0<void>::operator()() const + 28
        8   com.adobe.dvacore.framework   0x0000000115410123 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()> const&, boost::function<void ()> const&) + 115
        9   com.adobe.boost_threads.framework 0x00000001151a9fc9 thread_proxy + 185
        10  libsystem_pthread.dylib       0x00007fff91ac799d _pthread_body + 131
        11  libsystem_pthread.dylib       0x00007fff91ac791a _pthread_start + 168
        12  libsystem_pthread.dylib       0x00007fff91ac5351 thread_start + 13
        Thread 23:
        Thread 24:
        Thread 25:
        Thread 26:
        Thread 27:
        Thread 28:
        0   libsystem_kernel.dylib         0x00007fff8b8dbeca kevent + 10
        1   com.adobe.dvatransport.framework 0x0000000115b6304c boost::asio::detail::kqueue_reactor::run(bool, boost::asio::detail::op_queue<boost::asio::detail::task_io_service_operation>&) + 236
        2   com.adobe.dvatransport.framework 0x0000000115b62cf7 boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost:: asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 375
        3   com.adobe.dvatransport.framework 0x0000000115b62868 boost::asio::detail::task_io_service::run(boost::system::error_code&) + 568
        4   com.adobe.dvatransport.framework 0x0000000115b52067 SkyConnectionEnv::MainLoop() + 167
        5   com.adobe.dvatransport.framework 0x0000000115b51b19 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
        6   com.adobe.boost_threads.framework 0x00000001151a9fc9 thread_proxy + 185
        7   libsystem_pthread.dylib       0x00007fff91ac799d _pthread_body + 131
        8   libsystem_pthread.dylib       0x00007fff91ac791a _pthread_start + 168
        9   libsystem_pthread.dylib       0x00007fff91ac5351 thread_start + 13
        Thread 29:
        2   com.adobe.dvacore.framework   0x00000001153dc31b boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost:: asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 139
        3   com.adobe.dvacore.framework   0x00000001153dc098 boost::asio::detail::task_io_service::run(boost::system::error_code&) + 568
        4   com.adobe.dvacore.framework   0x00000001153dbe4a boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service_base::work_ io_service_runner>::run() + 42
        5   com.adobe.dvatransport.framework 0x0000000115b63703 boost_asio_detail_posix_thread_function + 19
        6   libsystem_pthread.dylib       0x00007fff91ac799d _pthread_body + 131
        7   libsystem_pthread.dylib       0x00007fff91ac791a _pthread_start + 168
        8   libsystem_pthread.dylib       0x00007fff91ac5351 thread_start + 13
        Thread 30:
        Thread 31:
        Thread 4 crashed with X86 Thread State (64-bit):
        rax: 0x00000000000001f4  rbx: 0x00000000000001f4  rcx: 0x00007f845f02b9f0  rdx: 0x0000000122ef7960
        rdi: 0x0000000122ef776c  rsi: 0x0000000122ef7578  rbp: 0x0000700000322530  rsp: 0x0000700000322230
        r8: 0x0000000122ef7b54   r9: 0x0000000122ef6f9c  r10: 0x0000000122ef7384  r11: 0x00000000000001f0
        r12: 0x0000000122ef7190  r13: 0x0000000122ef7d48  r14: 0x0000000000000000  r15: 0x0000000000000004
        rip: 0x000000011aecde20  rfl: 0x0000000000010246  cr2: 0x00000001151d9000
        Logical CPU:     0
        Error Code:      0x020000c5
        Trap Number:     133
        Binary Images:
        0x10dcd2000 -        0x10ebe7fff +com.adobe.bridge6 (6.2.0.179 - 6.2.0.179) <C63DEB1D-CFA0-336A-A386-62F1D980DF73> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/MacOS/Adobe Bridge CC
        0x10f119000 -        0x10f11dfff  com.apple.agl (3.3.1 - AGL-3.3.1) <9F89C357-50A4-3978-93AB-D2E68CCFA834> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
        0x10f129000 -        0x10f12efff  org.twain.dsm (1.9.5 - 1.9.5) <F7AA3C5E-4FB0-379D-8F79-AD06669D087E> /System/Library/Frameworks/TWAIN.framework/Versions/A/TWAIN
        0x10f139000 -        0x10f463fff +com.adobe.AGM (AdobeAGM 4.30.60.35269 - 4.30.60.35269) <7B00FE6F-5B1E-31C0-9ED0-599F1EC1EC37> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
        0x10f4d5000 -        0x10f89aff7 +com.adobe.MPS (AdobeMPS 5.8.1.35138 - 5.8.1.35138) <809BAAB6-9F24-39D8-9101-B6D65FB1F7FC> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
        0x10f90d000 -        0x10f949fff +com.adobe.ARE (AdobeARE 1.5.02.35269 - 1.5.02.35269) <54AA8EE4-A877-31A5-A089-835F4F144217> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
        0x10f957000 -        0x11069cfff +com.adobe.ICUData (4.0 - 3.61) <B9864D01-126E-3C56-B04C-993F9890F6AD> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData
        0x1106b6000 -        0x11075dff7 +com.adobe.AdobeExtendScript (ExtendScript 4.5.6 - 4.5.6.2) <EE4DF0D0-2670-38C9-B42A-8388F6F731DD> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
        0x1107ad000 -        0x110847ff7 +com.adobe.AdobeScCore (ScCore 4.5.6 - 4.5.6.2) <0A6A5E1D-4C34-3C52-B73B-394C25029ABE> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
        0x11088e000 -        0x110bebfff +com.adobe.CoolType (AdobeCoolType 5.15.00.35269 - 5.15.00.35269) <38CD3612-A57D-35E5-B5D8-CBD5F6DDC920> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
        0x110c39000 -        0x110d03ff7 +com.adobe.JP2K (1.2.2 - 1.2.2.35138) <4205548A-573A-364B-93D0-F61996DD723A> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
        0x110d4e000 -        0x113c62f7f +com.adobe.psl (AdobePSL 15.1.0.35674 - 15.1.0.35674) <DD3CB5C2-4A75-37CC-99C8-18292C8B3BB5> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
        0x11415c000 -        0x114297fff +com.adobe.ICUInternationalization (4.0 - 3.61) <CEAE369B-B601-30D5-9563-6C2AB781AF27> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/ICUInternationalization.framework/Versions/4.0/ICUInternationa lization
        0x114326000 -        0x114485ff7 +com.adobe.ACE (AdobeACE 2.20.02.35269 - 2.20.02.35269) <A8121E59-42A7-3F0E-9909-112A42DCDC64> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
        0x11449c000 -        0x11459fff7 +com.adobe.ICUUnicode (4.0 - 3.61) <CE487901-E84A-3E54-95AB-91F2EAF57F6A> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/ICUUnicode
        0x1145eb000 -        0x114722ff7 +com.winsoft.wrservices (WRServices 11.0.0 - 11.0.0) <A1AF94EB-8B13-305C-8B8C-8E420BA0DD0A> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/wrservices.framework/versions/a/WRServices
        0x114784000 -        0x11482dff7 +com.adobe.ICUConverter (4.0 - 3.61) <E20E390A-9BAF-3454-BA16-7B9CCD4CA8F0> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/ICUConverter
        0x114858000 -        0x11485bfff +com.adobe.AdobeCrashReporter (7.1 - 7.1.4) <A33546D9-3E26-38A2-88FE-C7C46B4CD989> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
        0x114867000 -        0x1148d8fe7 +com.adobe.FileInfo.framework (Adobe XMP FileInfo 5 . 3 . 0 . 0 -i 3 - 79.151561) <380981FE-6528-37CC-9159-AB1892803BD4> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
        0x1148f0000 -        0x114a66fff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 111 - 79.158366) <01F03185-A123-3511-B739-A135591052E1> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
        0x114b4c000 -        0x114c4efff +com.adobe.amtlib (9.0.0.89 - 9.0.0.89) <EBF9B7FD-5C40-31E1-976E-D5B5608080B9> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
        0x114c67000 -        0x114dc5ff7 +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.6 -f 170 - 79.158366) <110630F4-A885-32D1-9463-1907443AC676> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
        0x114e93000 -        0x114eb9fff +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.8.0.35348 - 3.8.0.35348) <A1F25502-8A55-3300-ACB8-66507CE1B6B9> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpat
        0x114ede000 -        0x114edeff7 +cl_kernels (???) <78569B1A-5084-494C-8B9C-2FEBCD01DD60> cl_kernels
        0x114ee4000 -        0x114ee8ff7 +com.adobe.ape.shim (3.4.0.29366 - 3.4.0.29366) <B9447EE8-6F91-9E85-C163-96600BF70764> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
        0x114ef6000 -        0x114f09ff7 +com.adobe.ahclientframework (1.8.0.31 - 1.8.0.31) <58BB943C-98EC-3812-AAAB-74F66630D1D4> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
        0x114f14000 -        0x114f35fff +com.adobe.BIB (AdobeBIB 1.2.03.35269 - 1.2.03.35269) <11EBACBD-C7F8-3E80-A2BF-E87543B5CE11> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
        0x114f42000 -        0x114f68ff7 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <6536192E-56D1-3EF0-97A9-04630B74CE0C> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
        0x114f75000 -        0x114fb5ff7 +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 9.0.0.15 - 9.0.0.15) <777D69DE-E701-3DAE-AF9C-7B7B48C0189C> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotifications
        0x114fd4000 -        0x1150c6fff +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.8.0.35348 - 3.8.0.35348) <E5D037D0-B4D5-33F5-BE74-650C392C6514> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
        0x115170000 -        0x11517cfff +com.adobe.boost_signals.framework (8.0.0 - 8.0.0.0) <A2F88487-E0D4-35EB-A539-1B489EFFCB0F> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
        0x115197000 -        0x115198fff  libCyrillicConverter.dylib (68) <79F5CFEF-92E4-30FE-A650-41F07B6D31B9> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
        0x11519d000 -        0x11519ffff +com.adobe.boost_system.framework (8.0.0 - 8.0.0.0) <02064CC7-B140-39BC-A327-63A16AC6C2A2> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
        0x1151a8000 -        0x1151b6fff +com.adobe.boost_threads.framework (8.0.0 - 8.0.0.0) <833CB2CE-B4A4-36D4-A5AB-EAE92D82C8B7> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
        0x1151da000 -        0x11526cfff +com.adobe.dvaaudiodevice.framework (8.0.0 - 8.0.0.0) <3E16D9CD-330C-33EC-9702-69A94D941426> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/dvaaudiodevice.framework/Versions/A/dvaaudiodevice
        0x115332000 -        0x1155c1fff +com.adobe.dvacore.framework (8.0.0 - 8.0.0.0) <3AAE70D1-F9C6-36B7-BB9A-47918646093D> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
        0x11581a000 -        0x115844fff +com.adobe.dvamarshal.framework (8.0.0 - 8.0.0.0) <761BE7FE-4D6C-3B7A-B516-DDC08E29BD43> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
        0x115886000 -        0x1158b5ff7 +com.adobe.dvamediatypes.framework (8.0.0 - 8.0.0.0) <4DD854D4-432C-3D79-92C2-282E66BF41D0> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
        0x1158ea000 -        0x1158f0ff7 +com.adobe.boost_date_time.framework (8.0.0 - 8.0.0.0) <3ED123F5-3173-3D7C-BC94-ECE0894CB193> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
        0x11590b000 -        0x1159c6fff +com.adobe.dvaplayer.framework (8.0.0 - 8.0.0.0) <5DB4EA3D-4A2A-3168-8907-CD02166AA792> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/dvaplayer.framework/Versions/A/dvaplayer
        0x115b3a000 -        0x115b9efff +com.adobe.dvatransport.framework (8.0.0 - 8.0.0.0) <2734D385-B67C-313D-A944-6B85B1DCCA05> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
        0x115c34000 -        0x115c57fff +com.adobe.dvaunittesting.framework (8.0.0 - 8.0.0.0) <46F0439B-7076-3603-B4E4-E998730529F2> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
        0x115c9f000 -        0x115ed7ff7 +com.adobe.dynamiclink.framework (8.0.0 - 8.0.0.0) <FB1BD993-11B4-308A-B0AE-1CCF810F5A97> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
        0x11614f000 -        0x11645aff7 +com.adobe.mediacoreif.framework (8.0.0 - 8.0.0.0) <7A399D0B-0C3D-3B1B-B277-85DD5038C71F> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/mediacoreif.framework/Versions/A/mediacoreif
        0x1167fd000 -        0x11683bfff +com.adobe.dvanet.framework (8.0.0 - 8.0.0.0) <8617818A-4402-33D5-9FD3-14725A148CB2> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/dvanet.framework/Versions/A/dvanet
        0x1168ad000 -        0x117630fdf +com.adobe.alignmentlib (Copyright © 2013 Adobe Systems Incorporated - Copyright © 2013 Adobe Systems Incorporated) <F5BFD9E3-646B-3FF4-81DC-D5439EC6CC54> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AlignmentLib.framework/Versions/A/AlignmentLib
        0x117749000 -        0x117891ff7 +com.adobe.AIDE (1.5.0 - 1.5.0.35630) <F1E51661-3983-3BD7-AA23-4C36976753B5> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE
        0x1178f4000 -        0x117920ff7 +libtbb.dylib (0) <64B7013E-D548-3F7B-A2FB-28B7B932275C> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/libtbb.dylib
        0x117940000 -        0x11795ffe7 +libtbbmalloc.dylib (0) <6887ED68-67ED-3748-82DA-B39A3EB210BB> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/libtbbmalloc.dylib
        0x117be0000 -        0x117be2ff7  com.apple.textencoding.unicode (3.0 - 3.0) <B8CEE380-5919-3519-8088-119C65562EE9> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
        0x11a270000 -        0x11a361fff +com.adobe.adobe_caps (adobe_caps 9.0.0.28 - 9.0.0.28) <5FA2F01A-0E75-3655-8CC0-C09088813A57> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
        0x11a371000 -        0x11a3edff7 +Photoshop Adapter (0) <54ABA913-022C-37B7-8CE2-8C00E1E74A87> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Required/Photoshop Adapter.plugin/Contents/MacOS/Photoshop Adapter
        0x11a54f000 -        0x11a5c6fff +MultiProcessor Support (16.1 - 16.1) <A11C3D38-1E91-3312-9DD2-B5C7023EC0F5> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Plug-Ins/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
        0x11ac73000 -        0x11ac8fff7  libJapaneseConverter.dylib (68) <D80D1583-1F6F-32A5-A683-F504A0DF973A> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
        0x11ac95000 -        0x11acb7ff7  libKoreanConverter.dylib (68) <F29010B7-FABC-3CDA-95F5-85DC12B6C91B> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
        0x11acbc000 -        0x11accbff7  libSimplifiedChineseConverter.dylib (68) <DCFEA0D3-593E-3E5C-B311-53B8ACF8A318> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
        0x11acd0000 -        0x11ace2fff  libTraditionalChineseConverter.dylib (68) <62CEE84C-366B-3E43-821B-EE072DBF33D7> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
        0x11aeac000 -        0x11aee0fff +MMXCore (16.1 - 16.1) <9B4CEE6E-B511-3889-AF71-F84BDD9BE716> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Plug-Ins/MMXCore.plugin/Contents/MacOS/MMXCore
        0x11af62000 -        0x11dfb4fff +com.adobe.CameraRaw (9.5 [585] - 9.5f585) <C38905A4-F6E0-3205-84CE-137F95204192> /Library/Application Support/Adobe/*/Camera Raw.plugin/Contents/MacOS/Camera Raw
        0x11e3d9000 -        0x11e64eff7  com.apple.ATIRadeonX2000GLDriver (10.0.40 - 10.0.0) <C74D6FB3-D541-3BE6-B14A-37F84791427D> /System/Library/Extensions/ATIRadeonX2000GLDriver.bundle/Contents/MacOS/ATIRadeonX2000GLD river
        0x11ecf6000 -        0x11ed9bfff  ColorSyncDeprecated.dylib (470.3) <A30CB963-667F-39D0-8537-66FCC820F5A6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/Resources/ColorSyncDeprecated.dylib
        0x120039000 -        0x120073fff +com.adobe.pip (7.3.1.70) <62832BC3-E82F-3648-B0D2-67EFD1263C89> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
        0x1216fc000 -        0x121889fef +com.adobe.switchboard-3.0 (SBCC 3.0.1 - 3.0.1.2) <5DAB4B93-55EC-A2FF-0F40-59D37ADE17F5> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/SwitchBoardClient.bundle/Contents/MacOS/SwitchBoardClient
        0x122b17000 -        0x122c56ff7 +com.adobe.headlights.LogSessionFramework (7.3.1.70) <408F19FE-B672-3E82-89B6-B782E000D2B0> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/LogSession.framework/LogSession
        0x122d0a000 -        0x122d33fff +libSLCacheWrapper.dylib (1) <AB5FD9B1-D26B-3599-820A-6E1238597C86> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/LogSession.framework/Libraries/libSLCacheWrapper.dylib
        0x122e94000 -        0x122e98fff  com.apple.audio.AppleHDAHALPlugIn (274.7 - 274.7) <2CEBD69A-DD77-3B0F-958B-72521D9E49D4> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
        0x124a1c000 -        0x124cf8fe7 +com.adobe.standard.multiplugin (16.1.1 - 16.1.1) <95945356-D5FF-32B6-BE25-D3AAEDECC8E9> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Plug-Ins/Standard Multiplugin.plugin/Contents/MacOS/Standard Multiplugin
        0x125d9f000 -        0x1265c6fff +com.adobe.PDFL (PROD_MAJOR.PROD_MINOR.PROD_STEP - 15.0.0.35285) <D2545866-EF7B-38A5-8D60-92391E83FA7F> /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/Frameworks/AdobePDFL.framework/AdobePDFL
        0x7fff62315000 -     0x7fff6234c0d7  dyld (360.21) <D9B236BC-4AC1-325F-B3EF-3F06DBDA7119> /usr/lib/dyld
        0x7fff869a0000 -     0x7fff869a2fff  libCVMSPluginSupport.dylib (12.0.40.6) <4AA6710A-6267-3062-BFF2-27DB5E6B5892> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
        0x7fff869a3000 -     0x7fff869f2ff7  com.apple.opencl (2.7.0 - 2.7.0) <307263BA-0368-38C9-A7FB-25920343D0DF> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
        0x7fff86a06000 -     0x7fff86b2bff7  com.apple.LaunchServices (728.8 - 728.8) <FDA38B17-82E2-322F-A008-B9207A6EA668> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
        0x7fff86b7c000 -     0x7fff86cfafff  com.apple.UIFoundation (1.0 - 436.1) <AABB5267-E7B7-3D75-B051-E665BDA8DEF4> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
        0x7fff86d9d000 -     0x7fff8725bfcf  com.apple.vImage (8.0 - 8.0) <85FB412E-EB30-3433-A79B-B3970FC83580> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
        0x7fff8725c000 -     0x7fff8725efff  com.apple.EFILogin (2.0 - 2) <38150198-DD7F-3C73-BCAA-C74BB376393A> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
        0x7fff87260000 -     0x7fff87276ff7  libLinearAlgebra.dylib (1162.2) <FFE54EDF-F06F-3C0A-864A-4CA7BBFD4B2D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLinearAlgebra.dylib
        0x7fff8731e000 -     0x7fff87326fff  libMatch.1.dylib (27) <3AC0BFB8-7E69-3DBE-A175-7F3946FC4554> /usr/lib/libMatch.1.dylib
        0x7fff87384000 -     0x7fff873adff7  libxslt.1.dylib (14.1) <27DE3F2E-CE96-3327-A563-788EE3E2775B> /usr/lib/libxslt.1.dylib
        0x7fff8746c000 -     0x7fff8746dffb  libremovefile.dylib (41) <552EF39E-14D7-363E-9059-4565AC2F894E> /usr/lib/system/libremovefile.dylib
        0x7fff874cf000 -     0x7fff87520ff7  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <3D62A9B3-67A8-3F8A-A102-05E310249075> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
        0x7fff87521000 -     0x7fff87523fff  libCGXType.A.dylib (957) <B901C222-E779-32EB-96C2-5A707A09FC5B> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
        0x7fff87592000 -     0x7fff875e3ff7  libcups.2.dylib (435.1) <4198A94D-A46C-39AA-92B6-83D0BA507D6C> /usr/lib/libcups.2.dylib
        0x7fff875e4000 -     0x7fff875e6ff7  libsystem_configuration.dylib (802.40.13) <3DEB7DF9-6804-37E1-BC83-0166882FF0FF> /usr/lib/system/libsystem_configuration.dylib
        0x7fff875e7000 -     0x7fff8764efff  com.apple.framework.CoreWiFi (11.0 - 1101.20) <993592F1-B3F1-3FAD-87BD-EA83C361BCCF> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
        0x7fff8764f000 -     0x7fff87659fff  com.apple.NetAuth (6.0 - 6.0) <D692B1EF-534F-3892-8E2F-2BBA7C8AFD74> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
        0x7fff8765a000 -     0x7fff876a0ff7  libauto.dylib (186) <999E610F-41FC-32A3-ADCA-5EC049B65DFB> /usr/lib/libauto.dylib
        0x7fff8773e000 -     0x7fff87743fff  com.apple.DiskArbitration (2.7 - 2.7) <F55902AA-5316-3255-A701-FDED5B553065> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
        0x7fff87744000 -     0x7fff87754fff  libbsm.0.dylib (34) <7E14504C-A8B0-3574-B6EB-5D5FABC72926> /usr/lib/libbsm.0.dylib
        0x7fff87755000 -     0x7fff877bbff7  libsystem_network.dylib (583.40.20) <269E5ADD-6922-31E2-8D55-7B777263AC0D> /usr/lib/system/libsystem_network.dylib
        0x7fff877c9000 -     0x7fff877cbfff  libsystem_coreservices.dylib (19.2) <1B3F5AFC-FFCD-3ECB-8B9A-5538366FB20D> /usr/lib/system/libsystem_coreservices.dylib
        0x7fff877cc000 -     0x7fff877d4fff  libcopyfile.dylib (127) <A48637BC-F3F2-34F2-BB68-4C65FD012832> /usr/lib/system/libcopyfile.dylib
        0x7fff87900000 -     0x7fff87b0bfff  libFosl_dynamic.dylib (16.24) <5F9DB82D-FD4B-3952-8531-CE020F93ED49> /usr/lib/libFosl_dynamic.dylib
        0x7fff87b0c000 -     0x7fff87b51ff7  com.apple.coreservices.SharedFileList (24.4 - 24.5) <1D2AD77B-778F-3253-A295-3D0A32A8121C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.fr amework/Versions/A/SharedFileList
        0x7fff87b54000 -     0x7fff87b66fff  libsasl2.2.dylib (209) <2F81C8C9-11A3-3581-B2C1-D8C03AB7D39C> /usr/lib/libsasl2.2.dylib
        0x7fff87b67000 -     0x7fff87b6cff7  com.apple.AssetCacheServices (14.1 - 14.1) <5F249F84-660A-3E94-B073-6729E7ED56D9> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServi ces
        0x7fff87c56000 -     0x7fff87d36ff7  unorm8_rgba.dylib (2.7.3) <9EB6C346-CFF6-32D7-B4A1-2409DFBCB216> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_rgba .dylib
        0x7fff87dd6000 -     0x7fff87e00ff7  GLRendererFloat (12.0.40.6) <4063015F-BC8F-308D-9065-685F89659F2C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/G LRendererFloat
        0x7fff87e01000 -     0x7fff87e01fff  libenergytrace.dylib (10.40.1) <0A491CA7-3451-3FD5-999A-58AB4362682B> /usr/lib/libenergytrace.dylib
        0x7fff87e02000 -     0x7fff87e11ffb  com.apple.LangAnalysis (1.7.0 - 1.7.0) <18D21123-A3E7-3851-974A-08E5D4540475> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
        0x7fff87e12000 -     0x7fff87e72fff  com.apple.QuickLookFramework (5.0 - 696.7) <ECD33169-5EB1-3783-AF9E-1AB9240F8358> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
        0x7fff87e73000 -     0x7fff87e73fff  com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <848125D3-AF14-3526-8745-FFCDB200CD76> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
        0x7fff87ed4000 -     0x7fff87ee4fff  libSparseBLAS.dylib (1162.2) <6F591A0F-80D0-384D-8304-B035C4ED1BBD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libSparseBLAS.dylib
        0x7fff87fe2000 -     0x7fff87fe4fff  com.apple.xpc.ServiceManagement (1.0 - 1) <F3E14561-5DF4-3429-98ED-8F27A87A343A> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
        0x7fff8806f000 -     0x7fff88077fff  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <CC53DC12-9231-3C4F-921B-9A770D463323> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
        0x7fff883ab000 -     0x7fff883c0ff3  libCGInterfaces.dylib (317.9) <473434E1-5269-3077-A047-D05E024AE631> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/Libraries/libCGInterfaces.dylib
        0x7fff883c1000 -     0x7fff883c6fff  com.apple.TCC (1.0 - 1) <50F7EC60-5B21-3B9B-BF2F-F037EA7B12FB> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
        0x7fff883c7000 -     0x7fff88424fff  com.apple.CoreServices.OSServices (728.8 - 728.8) <4CE49D8A-8304-3347-9379-6075CB906419> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
        0x7fff88425000 -     0x7fff88453ff7  libsandbox.1.dylib (460.40.33) <26158471-870A-3269-9E2B-7D7963B8E9F3> /usr/lib/libsandbox.1.dylib
        0x7fff885a7000 -     0x7fff885c0fff  com.apple.openscripting (1.7.1 - 169.1) <36EBF6A7-334A-3197-838F-E8C7B27FCDBB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
        0x7fff885c1000 -     0x7fff885c4fff  libspindump.dylib (197.1) <48F4C673-9F0C-38BE-B550-88241E812518> /usr/lib/libspindump.dylib
        0x7fff88618000 -     0x7fff88623ff7  libGPUSupport.dylib (12.0.40.6) <31FD7BC3-5205-3470-8CE0-7EA506F25EA0> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport .dylib
        0x7fff88e2d000 -     0x7fff88e3bfff  libxar.1.dylib (302) <03207F66-2C4A-3DBD-8D81-70F4C85903C4> /usr/lib/libxar.1.dylib
        0x7fff88e5a000 -     0x7fff88eeffff  com.apple.ink.framework (10.9 - 214) <1F76CF36-3F79-36B8-BC37-C540AF34B338> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
        0x7fff88fb4000 -     0x7fff88fb9fff  com.apple.ImageCapture (9.0 - 9.0) <ACECF0B7-7D92-3A22-BF47-E8FADF4C5378> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
        0x7fff88fba000 -     0x7fff88fbafff  com.apple.ApplicationServices (48 - 48) <ADD57D3A-142F-3EF5-BFD8-EACD82164884> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
        0x7fff88fbb000 -     0x7fff88fd1fff  com.apple.CoreMediaAuthoring (2.2 - 953) <06C2E0E2-BA5C-3BB1-8DD7-55613EDD654D> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
        0x7fff8912f000 -     0x7fff89132ff7  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <6932B5EC-0EA9-333D-BF7E-665047392FEC> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
        0x7fff89133000 -     0x7fff8913bfff  com.apple.AppleSRP (5.0 - 1) <840A5C20-6452-36BB-ACF7-29BA6CBF7C48> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
        0x7fff8913c000 -     0x7fff89174ff7  com.apple.RemoteViewServices (2.0 - 101) <B2881449-8CFE-3D1C-B4BF-155640392533> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
        0x7fff89be7000 -     0x7fff89c56fff  com.apple.datadetectorscore (7.0 - 460) <8EF4EECC-4FF1-36DF-84CF-65545555A225> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
        0x7fff89c57000 -     0x7fff89c79ff7  com.apple.Sharing (442.13.6 - 442.13.6) <DDD2811C-6ECB-32F2-8EE1-69BF9657B4A8> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
        0x7fff89c7a000 -     0x7fff89c91ff7  libsystem_asl.dylib (323.40.3) <007F9094-317A-33EA-AF62-BAEAAB48C0F7> /usr/lib/system/libsystem_asl.dylib
        0x7fff89c92000 -     0x7fff89c97fff  com.apple.MediaAccessibility (1.0 - 79) <C5E61B45-1967-3602-A48C-31E132B998B2> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
        0x7fff8a08b000 -     0x7fff8a312ff7  com.apple.CFNetwork (760.4.2 - 760.4.2) <24C4A390-3079-358A-8D51-75A3E818A6DF> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
        0x7fff8a345000 -     0x7fff8a7e0ff3  com.apple.GeoServices (1.0 - 1151.47.0.1) <928294E7-6897-3D5B-9D2E-BC092B6C25DE> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
        0x7fff8a7e1000 -     0x7fff8abe3fff  libLAPACK.dylib (1162.2) <42238ED4-6B7A-39D0-BFF2-304A0C287213> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
        0x7fff8ac90000 -     0x7fff8acceff7  libGLImage.dylib (12.0.40.6) <734B133F-E789-3A25-9DE6-1CCBA4896D4D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
        0x7fff8ad50000 -     0x7fff8ad69fff  com.apple.CFOpenDirectory (10.11 - 194) <11F95672-55E0-3F9D-9171-5E8C56AEE948> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
        0x7fff8ad6a000 -     0x7fff8ad6afff  com.apple.Carbon (154 - 157) <8F6ED602-5943-3E29-A793-BC331E2C183D> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
        0x7fff8adf3000 -     0x7fff8b0d8ffb  com.apple.CoreServices.CarbonCore (1136.2 - 1136.2) <2DBAFC9A-6CD6-351D-B1F4-87D81AA6D640> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
        0x7fff8b0d9000 -     0x7fff8b0f5fff  com.apple.GenerationalStorage (2.0 - 239.1) <8C821448-4294-3736-9CEF-467C93785CB9> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
        0x7fff8b0f6000 -     0x7fff8b13bff3  libFontRegistry.dylib (155.1) <F3355C6E-ED33-3506-B10E-2F6995D34BC1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
        0x7fff8b1d8000 -     0x7fff8b212fff  com.apple.QD (3.12 - 302) <0FE53180-2895-3D14-A1E7-F82DE1D106E1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
        0x7fff8b213000 -     0x7fff8b8b2ff7  com.apple.JavaScriptCore (11601 - 11601.5.17) <E12A9CB4-C807-3602-8357-6037579F6A13> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
        0x7fff8b8c4000 -     0x7fff8b8e2ff7  libsystem_kernel.dylib (3248.40.184) <88C17B7F-1CD8-3979-A1A9-F7BDB4FCE789> /usr/lib/system/libsystem_kernel.dylib
        0x7fff8b940000 -     0x7fff8b941fff  com.apple.TrustEvaluationAgent (2.0 - 25) <0239494E-FEFE-39BC-9FC7-E251BA5128F1> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
        0x7fff8b96a000 -     0x7fff8b96cffb  libutil.dylib (43) <4C9BFE8B-563B-3EEA-A323-8F4F14E0A46C> /usr/lib/libutil.dylib
        0x7fff8b9bb000 -     0x7fff8b9bdff7  libquarantine.dylib (80) <0F4169F0-0C84-3A25-B3AE-E47B3586D908> /usr/lib/system/libquarantine.dylib
        0x7fff8b9be000 -     0x7fff8b9beff7  libunc.dylib (29) <DDB1E947-C775-33B8-B461-63E5EB698F0E> /usr/lib/system/libunc.dylib
        0x7fff8ba7c000 -     0x7fff8bb04fff  com.apple.CoreSymbolication (3.1 - 58048.1) <4730422E-4178-34F9-8550-BB92F2A4F44B> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
        0x7fff8bb05000 -     0x7fff8bb50ff7  com.apple.CoreMediaIO (703.0 - 4791) <B974A225-61C6-34DD-AC2A-495BD6A393B3> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
        0x7fff8bd11000 -     0x7fff8bd11fff  libmetal_timestamp.dylib (600.0.44.1) <6576F284-BACA-332A-A6E7-FA1C347636E3> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
        0x7fff8bd12000 -     0x7fff8bd65ff7  libc++.1.dylib (120.1) <8FC3D139-8055-3498-9AC5-6467CB7F4D14> /usr/lib/libc++.1.dylib
        0x7fff8bde9000 -     0x7fff8bed4ff7  com.apple.QuickLookUIFramework (5.0 - 696.7) <5A4AAFEC-D38C-3DA0-9361-CBF1D4C6B376> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
        0x7fff8c68e000 -     0x7fff8c77dffb  libxml2.2.dylib (29.5) <4096C2EA-6659-3F22-AC60-1E2F30BDD2B7> /usr/lib/libxml2.2.dylib
        0x7fff8c77e000 -     0x7fff8c780ff7  libRadiance.dylib (1444) <1B89630A-A096-39D8-BE4D-DF1596B368E0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
        0x7fff8c781000 -     0x7fff8c7b1ff3  com.apple.CoreAVCHD (5.8.0 - 5800.4.2) <4AAFB1C4-3708-30F9-ACFA-90564347204C> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
        0x7fff8c7bd000 -     0x7fff8c7e6ff7  libxpc.dylib (765.40.36) <2CC7CF36-66D4-301B-A6D8-EBAE7405B008> /usr/lib/system/libxpc.dylib
        0x7fff8c7e7000 -     0x7fff8c7e7fff  com.apple.Cocoa (6.11 - 22) <807787AB-D231-3F51-A99B-A9314623C571> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
        0x7fff8c7e8000 -     0x7fff8c88cfff  com.apple.Bluetooth (4.4.4 - 4.4.4f4) <BCF89EFE-853D-3AEA-AE31-DC8293C7284F> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
        0x7fff8c8b0000 -     0x7fff8c90efff  com.apple.SystemConfiguration (1.14 - 1.14) <10082F58-6190-3A7C-8B6C-C12B16DC793A> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
        0x7fff8c92f000 -     0x7fff8c981fff  com.apple.CloudDocs (1.0 - 383.12) <1388C0E5-9B2F-372B-A005-043EB049AAA3> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
        0x7fff8c982000 -     0x7fff8c9b1ffb  libsystem_m.dylib (3105) <08E1A4B2-6448-3DFE-A58C-ACC7335BE7E4> /usr/lib/system/libsystem_m.dylib
        0x7fff8c9b2000 -     0x7fff8ced4fff  com.apple.QuartzComposer (5.1 - 334) <80235264-CA1B-3E3F-96F7-5F6F52FDC5B6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
        0x7fff8ced5000 -     0x7fff8d0a3ff3  com.apple.QuartzCore (1.11 - 410.14) <0283748A-8318-36AC-8B30-8A951FEB305A> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
        0x7fff8d0a4000 -     0x7fff8d0cfffb  libarchive.2.dylib (33.20.2) <6C370A21-63FD-3A68-B4B3-5333F24B770B> /usr/lib/libarchive.2.dylib
        0x7fff8d0d3000 -     0x7fff8d0d5fff  com.apple.loginsupport (1.0 - 1) <9B2F5F9B-ED38-313F-B798-D2B667BCD6B5> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.fram ework/Versions/A/loginsupport
        0x7fff8d0ec000 -     0x7fff8d219ff3  com.apple.CoreText (352.0 - 494.11) <08E8640E-6602-3A00-BC28-94235FD311B4> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
        0x7fff8da79000 -     0x7fff8da95ff7  libsystem_malloc.dylib (67.40.1) <5748E8B2-F81C-34C6-8B13-456213127678> /usr/lib/system/libsystem_malloc.dylib
        0x7fff8da96000 -     0x7fff8daa7fff  libcmph.dylib (6) <BA4BF2C6-7F4E-33B8-9DD7-619C9EB83ECF> /usr/lib/libcmph.dylib
        0x7fff8daa8000 -     0x7fff8dab3ff7  libChineseTokenizer.dylib (16) <79B8C67A-3061-3C78-92CD-4650719E68D4> /usr/lib/libChineseTokenizer.dylib
        0x7fff8dab4000 -     0x7fff8dabcfff  libGFXShared.dylib (12.0.40.6) <1CDE5AEF-3E44-3547-879E-BB490EE7702C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
        0x7fff8dabf000 -     0x7fff8db0bffb  com.apple.HIServices (1.22 - 549) <E4E1BD10-F475-3E19-9E0B-A5071D158F47> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
        0x7fff8db0c000 -     0x7fff8db7bfff  com.apple.SearchKit (1.4.0 - 1.4.0) <F159A888-34CA-36F1-AC8E-EB1B38C9DFB3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
        0x7fff8db7c000 -     0x7fff8db7cff7  libkeymgr.dylib (28) <8371CE54-5FDD-3CE9-B3DF-E98C761B6FE0> /usr/lib/system/libkeymgr.dylib
        0x7fff8ddb7000 -     0x7fff8ddd2ff7  libCRFSuite.dylib (34) <078B4CD8-6A8C-3067-B2BA-0C2A0BAB8AC3> /usr/lib/libCRFSuite.dylib
        0x7fff8ddfc000 -     0x7fff8de08fff  com.apple.speech.synthesis.framework (5.4.12 - 5.4.12) <71DA00B8-5EA2-326B-8814-59DB25512F65> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
        0x7fff8de35000 -     0x7fff8de3aff7  libmacho.dylib (875.1) <318264FA-58F1-39D8-8285-1F6254EE410E> /usr/lib/system/libmacho.dylib
        0x7fff8de3b000 -     0x7fff8e18ffff  com.apple.Foundation (6.9 - 1258) <51833143-6CAE-3E1C-9FBA-BCDEB48D4ADF> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
        0x7fff8e190000 -     0x7fff8e196fff  com.apple.XPCService (2.0 - 1) <5E2122D6-FFA2-3552-BF16-9FD3F36B40DB> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
        0x7fff8e214000 -     0x7fff8e21dfff  com.apple.icloud.FindMyDevice (1.0 - 1) <B9C741F2-6FAC-3BA7-B6E0-9A910C6E8D4E> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
        0x7fff8e250000 -     0x7fff8e25bfff  libGL.dylib (12.0.40.6) <4FC6D3F9-6582-3E7D-A7D1-E035F0E26697> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
        0x7fff8e25c000 -     0x7fff8e25dfff  libsystem_secinit.dylib (20) <32B1A8C6-DC84-3F4F-B8CE-9A52B47C3E6B> /usr/lib/system/libsystem_secinit.dylib
        0x7fff8e2b6000 -     0x7fff8e2f8ff7  com.apple.Metal (56.6 - 56.6) <7DCBE573-B713-3C50-A16E-2F33A84C3CFB> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
        0x7fff8e2f9000 -     0x7fff8e2fcfff  com.apple.IOSurface (108.2.1 - 108.2.1) <A0037B0A-277A-393E-9BF6-688595BD564D> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
        0x7fff8e2fd000 -     0x7fff8e308fff  libcsfde.dylib (517.20.1) <6FFC376E-E141-37EE-800A-004080A50091> /usr/lib/libcsfde.dylib
        0x7fff8e8ec000 -     0x7fff8e95aff7  com.apple.ApplicationServices.ATS (377 - 394.3) <847DBFBA-8D6B-367B-99FD-C6CAA8C05C65> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
        0x7fff8e95b000 -     0x7fff8e977ff7  libextension.dylib (78) <FD952DA6-BBEC-3CB6-98B3-E1D111C5C54E> /usr/lib/libextension.dylib
        0x7fff8e978000 -     0x7fff8e986ff7  libbz2.1.0.dylib (38) <28E54258-C0FE-38D4-AB76-1734CACCB344> /usr/lib/libbz2.1.0.dylib
        0x7fff8eb29000 -     0x7fff8eb31fef  libsystem_platform.dylib (74.40.2) <29A905EF-6777-3C33-82B0-6C3A88C4BA15> /usr/lib/system/libsystem_platform.dylib
        0x7fff8eb32000 -     0x7fff8eb35fff  libCoreVMClient.dylib (119.5) <560D70FB-709F-3030-96C9-F249FCB7DA6D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
        0x7fff8ec20000 -     0x7fff8ec20fff  com.apple.audio.units.AudioUnit (1.13 - 1.13) <93C1D642-37D4-3692-AD35-DCAD04F9610B> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
        0x7fff8ec21000 -     0x7fff8ec45fff  com.apple.quartzfilters (1.10.0 - 1.10.0) <F5C482E2-5AFB-3959-8C01-C149D48E7583> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
        0x7fff8ec46000 -     0x7fff8ec5ffe7  libcompression.dylib (28) <F83F421D-115D-3457-A9AA-1BEB5070A30B> /usr/lib/libcompression.dylib
        0x7fff8ec74000 -     0x7fff8ec98fff  com.apple.MultitouchSupport.framework (304.10.2 - 304.10.2) <CE75EDA3-2B22-3968-834E-550EA870ECC8> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
        0x7fff8ec99000 -     0x7fff8eca9ff3  com.apple.ProtocolBuffer (1 - 243) <BAE5E5C9-DD59-3BB8-9741-EEFC5E3046EE> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
        0x7fff8ecaa000 -     0x7fff8ece4ff7  com.apple.DebugSymbols (132 - 132) <23A42C53-B941-3871-9EE2-4C87A46005B5> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
        0x7fff8ece5000 -     0x7fff8ecf8fff  com.apple.CoreBluetooth (1.0 - 1) <E54CA9A2-A5C6-30C5-9D6E-8472DBA9371E> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
        0x7fff8edf1000 -     0x7fff8ee54fff  libAVFAudio.dylib (161.2) <1A98DBF3-490B-37FB-928A-AB1E36E6E5DD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
        0x7fff8ee55000 -     0x7fff8ef9afff  com.apple.QTKit (7.7.3 - 2943.3) <88AA19A7-7170-3798-8CBA-B1B8D4763ADB> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
        0x7fff8ef9b000 -     0x7fff8ef9dff7  com.apple.SafariServices.framework (11601 - 11601.5.17.1) <396E2233-E2DC-391C-84D2-991F636A941B> /System/Library/PrivateFrameworks/SafariServices.framework/Versions/A/SafariServices
        0x7fff8ef9e000 -     0x7fff8efa4ff7  com.apple.speech.recognition.framework (5.1.1 - 5.1.1) <9E5A980A-F455-32D5-BBEE-3BD6018CC45E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
        0x7fff8efa5000 -     0x7fff8f0efff7  com.apple.coreui (2.1 - 366.1) <A3868F31-ACF4-3EA5-9E75-79ED44FA7F06> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
        0x7fff8f0f0000 -     0x7fff8f386fff  libmecabra.dylib (696.5) <EF6C0BD4-5FE8-34FB-8ADF-69A53CEC97A9> /usr/lib/libmecabra.dylib
        0x7fff8f38a000 -     0x7fff8f3b7fff  libdispatch.dylib (501.40.12) <C7499857-61A5-3D7D-A5EA-65DCC8C3DF92> /usr/lib/system/libdispatch.dylib
        0x7fff8f3b8000 -     0x7fff8f3ecff7  com.apple.CoreVideo (1.8 - 191.3) <1AA24A1B-CB84-3F6B-B6DE-11494542649C> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
        0x7fff8f3ed000 -     0x7fff8f43bfff  libcurl.4.dylib (90) <12E01E4B-24C9-394C-9D2C-85CF85D5F459> /usr/lib/libcurl.4.dylib
        0x7fff8f43d000 -     0x7fff8f6cdff7  com.apple.RawCamera.bundle (6.19 - 844) <96617D7F-437C-31AB-B413-ADC079469054> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
        0x7fff8f6ce000 -     0x7fff8fa39657  libobjc.A.dylib (680) <D55D5807-1FBE-32A5-9105-44D7AFE68C27> /usr/lib/libobjc.A.dylib
        0x7fff8fa3a000 -     0x7fff90663fff  com.apple.AppKit (6.9 - 1404.46) <2492D315-76B6-320B-B542-231FCA44CA48> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
        0x7fff90668000 -     0x7fff90674ff7  com.apple.OpenDirectory (10.11 - 194) <31A67AD5-5CC2-350A-96D7-821DF4BC4196> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
        0x7fff90faa000 -     0x7fff90fd3fff  libc++abi.dylib (125) <DCCC8177-3D09-35BC-9784-2A04FEC4C71B> /usr/lib/libc++abi.dylib
        0x7fff90fd4000 -     0x7fff90fd4fff  com.apple.Accelerate (1.10 - Accelerate 1.10) <5831771A-C1C3-3625-9FE9-2CCB6B2E7EE1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
        0x7fff90fdb000 -     0x7fff90fdffff  libGIF.dylib (1444) <F1F581A7-AC59-3A82-9970-25F7F7C72ABD> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
        0x7fff90fe0000 -     0x7fff910d2ff7  libiconv.2.dylib (44) <F05A0A5A-92A9-3668-8F20-F27CBDA26BE9> /usr/lib/libiconv.2.dylib
        0x7fff910d3000 -     0x7fff911a9ffb  com.apple.DiskImagesFramework (10.11.3 - 417.2) <7412BC0B-A895-350D-B829-1E3A6FF5EC3F> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
        0x7fff912ab000 -     0x7fff912b3ffb  libsystem_dnssd.dylib (625.40.20) <86A05653-DCA0-3345-B29F-F320029AA05E> /usr/lib/system/libsystem_dnssd.dylib
        0x7fff912b4000 -     0x7fff913a6ff7  libJP2.dylib (1444) <D57AECF4-013C-3BCF-B6CE-3D033664419E> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
        0x7fff913a7000 -     0x7fff91460ff7  libvMisc.dylib (563.5) <BF612F7D-FA3B-3F9F-8BE7-8D1BCB21ECC5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
        0x7fff91461000 -     0x7fff917dcffb  com.apple.VideoToolbox (1.0 - 1731.15.202) <B839BE14-9503-3B5E-A54A-C7FCEED34EA3> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
        0x7fff9180f000 -     0x7fff9189eff7  libCoreStorage.dylib (517.20.1) <EC540EAA-089C-36D9-BBAA-0684EDE098AB> /usr/lib/libCoreStorage.dylib
        0x7fff918ae000 -     0x7fff918dffff  com.apple.GSS (4.0 - 2.0) <B490333A-3B3E-397A-AD75-68846E9A9140> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
        0x7fff91ab2000 -     0x7fff91ac3ff7  libsystem_trace.dylib (201.10.3) <25104542-5251-3E8D-B14A-9E37207218BC> /usr/lib/system/libsystem_trace.dylib
        0x7fff91ac4000 -     0x7fff91acdff7  libsystem_pthread.dylib (138.10.4) <3DD1EF4C-1D1B-3ABF-8CC6-B3B1CEEE9559> /usr/lib/system/libsystem_pthread.dylib
        0x7fff924e7000 -     0x7fff92574fff  libsystem_c.dylib (1082.20.4) <CDEBF2BB-A578-30F5-846F-96274951C3C5> /usr/lib/system/libsystem_c.dylib
        0x7fff92575000 -     0x7fff92578fff  com.apple.Mangrove (1.0 - 1) <2D86B3AD-64C3-3BB4-BC66-1CFD0C90E844> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
        0x7fff92579000 -     0x7fff92602ff7  com.apple.PerformanceAnalysis (1.0 - 1) <608E8C50-6F59-3FEB-B822-D9B02F328716> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
        0x7fff92613000 -     0x7fff92616ff7  com.apple.help (1.3.3 - 46) <35DA4D48-0BC2-35A1-8D7C-40905CDF4F64> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
        0x7fff92617000 -     0x7fff926adfff  com.apple.ColorSync (4.9.0 - 4.9.0) <8FC37E20-6579-3CB2-9D49-BC39FC38DF87> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
        0x7fff926b6000 -     0x7fff92a8efef  com.apple.CoreAUC (214.0.0 - 214.0.0) <F80C19CA-6CD0-3052-9C22-0288A257CCC8> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
        0x7fff92ac4000 -     0x7fff92afbff7  com.apple.LDAPFramework (2.4.28 - 194.5) <9AE33BF2-FB17-342D-8F1E-5F83C6E6EB69> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
        0x7fff92cbb000 -     0x7fff92ceaff7  com.apple.DictionaryServices (1.2 - 250.3) <30250542-CBAA-39C1-91AA-B57A5DE17594> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
        0x7fff92ceb000 -     0x7fff92f0cff7  com.apple.CoreImage (11.4.0 - 366.4.19) <6EE4A686-50C8-3D77-A036-BE8AA0F8A2FD> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
        0x7fff92f1d000 -     0x7fff92f1ffff  com.apple.CoreDuetDebugLogging (1.0 - 1) <7659CACF-3B08-3AF3-8FAC-24FAF18EF114> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebug Logging
        0x7fff93049000 -     0x7fff9308aff7  libGLU.dylib (12.0.40.6) <C56DDF90-CF6D-30D2-A3E6-89288BE69DCB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
        0x7fff9308b000 -     0x7fff9309ffff  com.apple.CoreDuetDaemonProtocol (1.0 - 1) <D0A5B9A7-A247-37CD-A8F7-64DC635F9C9B> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDae monProtocol
        0x7fff930a0000 -     0x7fff930c9ffb  libRIP.A.dylib (957) <5F18F20D-5921-3314-A9F8-F1B1CB62C83D> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
        0x7fff930d5000 -     0x7fff93175fff  com.apple.Metadata (10.7.0 - 972.29.1) <F19E0200-6937-3799-9C67-D26C2CE5AA5F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
        0x7fff93176000 -     0x7fff93192ff3  libresolv.9.dylib (60) <A650B5C8-1950-36A0-86D1-0B2465318BFA> /usr/lib/libresolv.9.dylib
        0x7fff931b6000 -     0x7fff931d0ff3  liblzma.5.dylib (10) <CC03591B-FA57-3CA5-AC81-0D76033AC0CE> /usr/lib/liblzma.5.dylib
        0x7fff931d1000 -     0x7fff932b7fef  unorm8_bgra.dylib (2.7.3) <B315AE9C-9E09-3D9F-9513-EC2195908516> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra .dylib
        0x7fff9357e000 -     0x7fff93582fff  libpam.2.dylib (20) <CFCD19BD-87BC-3F2B-BB1C-4C23E8E55F1A> /usr/lib/libpam.2.dylib
        0x7fff935b3000 -     0x7fff935b5fff  com.apple.SecCodeWrapper (4.0 - 261.40.2) <1F832591-59A8-3B3F-943F-D6D827463782> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
        0x7fff935b6000 -     0x7fff935befff  com.apple.NetFS (6.0 - 4.0) <842A5346-24C3-3F22-9ECF-E586A10EA1F2> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
        0x7fff9386f000 -     0x7fff93878ff3  libsystem_notify.dylib (150.40.1) <D48BDE34-0F7E-34CA-A0FF-C578E39987CC> /usr/lib/system/libsystem_notify.dylib
        0x7fff93879000 -     0x7fff9387eff7  libheimdal-asn1.dylib (453.40.10) <981DE40B-FA16-36F7-BE92-8C8A115D6CD9> /usr/lib/libheimdal-asn1.dylib
        0x7fff938b2000 -     0x7fff9390dff7  libTIFF.dylib (1444) <6DC2EAE6-0AF5-33CA-9037-38652B14D935> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
        0x7fff93914000 -     0x7fff9398bfeb  libcorecrypto.dylib (335.40.8) <9D300121-CAF8-3894-8774-DF38FA65F238> /usr/lib/system/libcorecrypto.dylib
        0x7fff93b26000 -     0x7fff93ce6ffb  libBLAS.dylib (1162.2) <B4C21826-5EB3-3C6D-B75D-CA4886E2B6A6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
        0x7fff93ce7000 -     0x7fff93d0efff  com.apple.ChunkingLibrary (167 - 167) <AD7F285C-005E-36BB-98A3-5826413533BE> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
        0x7fff9413a000 -     0x7fff9418cfff  com.apple.AppleVAFramework (5.0.32 - 5.0.32) <FC1AED2C-B3E2-31D9-B163-37989CD8A073> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
        0x7fff9418d000 -     0x7fff941dffff  com.apple.ImageCaptureCore (7.0 - 7.0) <9F3123D8-29D2-332F-AD6B-AB9BF1A58022> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
        0x7fff941f0000 -     0x7fff9439bffb  GLEngine (12.0.40.6) <32029589-A64E-3E6B-A024-F985765766A2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
        0x7fff9466d000 -     0x7fff94671fff  libcache.dylib (75) <9548AAE9-2AB7-3525-9ECE-A2A7C4688447> /usr/lib/system/libcache.dylib
        0x7fff94672000 -     0x7fff94697ff7  libPng.dylib (1444) <2D5C0007-DC24-3846-AE75-525D461FF3E6> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
        0x7fff94698000 -     0x7fff94748fff  com.apple.backup.framework (1.7.4 - 1.7.4) <F304E9D1-991A-379E-9659-BF85C35B4808> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
        0x7fff94749000 -     0x7fff94754ff7  libcommonCrypto.dylib (60075.40.2) <B9D08EB8-FB35-3F7B-8A1C-6FCE3F07B7E7> /usr/lib/system/libcommonCrypto.dylib
        0x7fff94b41000 -     0x7fff94bb8ff7  com.apple.MMCS (1.3 - 357.1) <549FBEFC-55F7-3101-BF51-A0B1F7CF2B46> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
        0x7fff94bbf000 -     0x7fff94c0fff7  com.apple.Symbolication (1.4 - 58044) <F70BF765-FBE9-3F1E-85CA-BB2F8E53E8C2> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
        0x7fff94c11000 -     0x7fff94c85ff7  com.apple.Heimdal (4.0 - 2.0) <5D365381-8B5E-3259-8867-FC4A7D307BDE> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
        0x7fff94c86000 -     0x7fff94cf1ff7  com.apple.framework.CoreWLAN (11.0 - 1101.20) <3B35C543-7FCE-333F-80C1-432FA41DDCDE> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
        0x7fff94d39000 -     0x7fff94d85ff7  com.apple.corelocation (1486.17 - 1615.38) <6336CFC5-9D7D-3B76-B263-56DD6EBD0B8D> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
        0x7fff94d86000 -     0x7fff94da0fff  com.apple.Kerberos (3.0 - 1) <1B4744BF-E5AE-38E2-AA56-E22D3270F2E8> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
        0x7fff94da4000 -     0x7fff94ec1fff  libsqlite3.dylib (216.4) <DC3D59E7-91A3-374F-957C-6699729CD82B> /usr/lib/libsqlite3.dylib
        0x7fff94ec2000 -     0x7fff94f7bff7  com.apple.cloudkit.CloudKit (482.29 - 482.29) <E235B37E-1491-3857-BDE8-38450D4FE8D0> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
        0x7fff9505f000 -     0x7fff95062ffb  libdyld.dylib (360.21) <8390E026-F7DE-3C32-9486-3DFF6BD131B0> /usr/lib/system/libdyld.dylib
        0x7fff95063000 -     0x7fff95066ffb  libScreenReader.dylib (426.42) <16FC79D1-4573-3E90-945F-CBA22D5185FD> /usr/lib/libScreenReader.dylib
        0x7fff96234000 -     0x7fff96346fef  libvDSP.dylib (563.5) <5702650E-DF08-3D58-B16F-9EF0A28702B3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
        0x7fff96347000 -     0x7fff9637aff7  com.apple.MediaKit (16 - 809) <BF8032FE-6645-37F6-A622-BC7EEE3EAABF> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
        0x7fff963c0000 -     0x7fff963ccfff  com.apple.SpeechRecognitionCore (2.2.7 - 2.2.7) <6BA06290-D4A3-351C-87F9-B61EF61FF055> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecogn itionCore
        0x7fff963ce000 -     0x7fff963d4fff  com.apple.IOAccelerator (205.3 - 205.3) <851B6BF8-5B7F-3FB5-9E45-10AAE3BF7438> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
        0x7fff963d5000 -     0x7fff96803fff  com.apple.vision.FaceCore (3.3.1 - 3.3.1) <E54028EA-4217-3078-A2B1-C52E4214D59E> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
        0x7fff96a52000 -     0x7fff96a55fff  libsystem_sandbox.dylib (460.40.33) <30671DCC-265F-325A-B33D-11CD336B3DA3> /usr/lib/system/libsystem_sandbox.dylib
        0x7fff96a59000 -     0x7fff96a70fff  libmarisa.dylib (4) <E4919B03-D9BD-3AF8-B436-C415C98E3F0A> /usr/lib/libmarisa.dylib
        0x7fff96a77000 -     0x7fff96b5dff7  libcrypto.0.9.8.dylib (59.40.2) <2486D801-C756-3488-B519-1AA6807E8948> /usr/lib/libcrypto.0.9.8.dylib
        0x7fff96b5e000 -     0x7fff96bedfff  com.apple.CorePDF (4.0 - 4) <849BBFF6-0700-3ED1-98DF-A6E93B9B707F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
        0x7fff96c76000 -     0x7fff96d72ff7  libFontParser.dylib (158.5) <62796E99-36B7-36B6-8D33-5349F88014C3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
        0x7fff96d98000 -     0x7fff96e71fff  com.apple.CoreMedia (1.0 - 1731.15.202) <D2A49E52-9D26-35A8-BDDC-3BCDBEC5A19E> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
        0x7fff96ee7000 -     0x7fff96f06ff7  com.apple.framework.Apple80211 (11.0 - 1121.34) <AE7795B8-4590-3714-999D-3FBFF6BF5D93> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
        0x7fff96f73000 -     0x7fff96f84ff7  libz.1.dylib (61.20.1) <B3EBB42F-48E3-3287-9F0D-308E04D407AC> /usr/lib/libz.1.dylib
        0x7fff96f85000 -     0x7fff981edffb  com.apple.CoreGraphics (1.600.0 - 957) <C403FF5C-1B6F-3810-90B1-F5477828A701> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
        0x7fff981ee000 -     0x7fff982a8fff  com.apple.DiscRecording (9.0.1 - 9010.4.3) <540853B2-B123-3560-8023-C92EE229051A> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
        0x7fff982a9000 -     0x7fff982a9fff  com.apple.CoreServices (728.9 - 728.9) <78CB3EAC-A66E-3FD9-A1DF-A9CF227ED3C3> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
        0x7fff9835c000 -     0x7fff983b1fff  com.apple.AE (701 - 701) <AD492742-F884-386B-A450-FAC281B9FFA4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
        0x7fff983b2000 -     0x7fff983b2fff  libOpenScriptingUtil.dylib (169.1) <AD0DAC8A-9849-3077-999F-9AEC6112BDAB> /usr/lib/libOpenScriptingUtil.dylib
        0x7fff985ee000 -     0x7fff988e3fff  com.apple.HIToolbox (2.1.1 - 807.2) <871E5223-5D03-3649-98AF-9CCA3B41E307> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
        0x7fff98ab8000 -     0x7fff98ac6fff  com.apple.opengl (12.0.40 - 12.0.40) <AEA28993-BA3E-3E0F-A2F5-88C312ABB634> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
        0x7fff98ac7000 -     0x7fff98b72fff  com.apple.PDFKit (3.1 - 3.1) <27AF3C85-1C0B-389C-856C-2E527620C195> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
        0x7fff98b73000 -     0x7fff98c1afff  com.apple.LanguageModeling (1.0 - 1) <58C18A47-BDE7-3CBE-81C0-797029D170A1> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
        0x7fff98c1b000 -     0x7fff98c26fff  libkxld.dylib (3248.40.184) <6F776D34-D06C-3C48-B753-D0FB375A4A8A> /usr/lib/system/libkxld.dylib
        0x7fff98ffd000 -     0x7fff98fffff7  com.apple.securityhi (9.0 - 55006) <A4CEFD45-C51C-381C-A57B-FF75D90C680F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
        0x7fff99000000 -     0x7fff991c9ff7  com.apple.ImageIO.framework (3.3.0 - 1444) <6A50AFBF-60BE-3845-AE29-843BD8238F17> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
        0x7fff9945b000 -     0x7fff996c8fff  com.apple.imageKit (2.6 - 932) <FAE317B8-DF15-3096-AFAC-464913BF2F3B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
        0x7fff996c9000 -     0x7fff996caff3  com.apple.print.framework.Print (10.0 - 266) <3E85F70C-D7D4-34E1-B88A-C1F503F99CDA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
        0x7fff996cb000 -     0x7fff996d0ff3  libunwind.dylib (35.3) <F6EB48E5-4D12-359A-AB54-C937FBBE9043> /usr/lib/system/libunwind.dylib
        0x7fff996d1000 -     0x7fff996e6fff  com.apple.AppContainer (4.0 - 261.40.2) <F220E702-1C00-3BD2-9943-C7E75C3B4418> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
        0x7fff996fe000 -     0x7fff99c56ff7  com.apple.MediaToolbox (1.0 - 1731.15.202) <A19F9D25-5333-3AA0-90FB-97F3F420A7EA> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
        0x7fff99c57000 -     0x7fff99c62fff  com.apple.AppSandbox (4.0 - 261.40.2) <52766210-B6EB-3B73-AB1B-42E0A9AD2EE8> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
        0x7fff99c6e000 -     0x7fff99d26ff7  com.apple.CoreDuet (1.0 - 1) <058EAEDE-156F-309C-AB61-34C61B93D967> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
        0x7fff99d27000 -     0x7fff99d44ff7  com.apple.AppleVPAFramework (2.1.2 - 2.1.2) <F4AF2363-B28E-3097-AB1E-FDA1C92F8F56> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
        0x7fff99d77000 -     0x7fff99decfff  com.apple.framework.IOKit (2.0.2 - 1179.40.20) <FB2AD43B-905D-3BD0-BE17-ACE7D4D13E24> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
        0x7fff99e13000 -     0x7fff99e14fff  libDiagnosticMessagesClient.dylib (100) <4243B6B4-21E9-355B-9C5A-95A216233B96> /usr/lib/libDiagnosticMessagesClient.dylib
        0x7fff99e15000 -     0x7fff99e3efff  libsystem_info.dylib (477.40.5) <6B01C09E-A3E5-3C71-B370-D0CABD11A436> /usr/lib/system/libsystem_info.dylib
        0x7fff99e6d000 -     0x7fff9a019fff  com.apple.avfoundation (2.0 - 1046.9.11) <DE524245-B7EF-3E9D-8AA1-3D99A3304EF4> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
        0x7fff9a094000 -     0x7fff9a095ffb  libSystem.B.dylib (1226.10.1) <CD307E99-FC5C-3575-BCCE-0C861AA63124> /usr/lib/libSystem.B.dylib
        0x7fff9a0fe000 -     0x7fff9a0fefff  com.apple.quartzframework (1.5 - 21) <5DC3D0D9-9E3F-3AA5-92F1-F229907A49B9> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
        0x7fff9a0ff000 -     0x7fff9a30cfff  libicucore.A.dylib (551.51) <35315A29-E21C-3CC5-8BD6-E07A3AE8FC0D> /usr/lib/libicucore.A.dylib
        0x7fff9a3b0000 -     0x7fff9a3bbfff  com.apple.CrashReporterSupport (10.11 - 717) <474544AD-1199-3ECC-90E5-071847BA72C6> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
        0x7fff9a3bc000 -     0x7fff9a3c5ff7  com.apple.DisplayServicesFW (3.0 - 378) <45BE1B99-8E10-32F0-A180-A6B6CB5883AE> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
        0x7fff9a3c6000 -     0x7fff9a3c9ff7  libCoreFSCache.dylib (119.5) <2389D7DA-B8EF-3EB4-AAAF-FBEDE01CDECA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
        0x7fff9a3ca000 -     0x7fff9a3d2fff  com.apple.CoreServices.FSEvents (1223.10.1 - 1223.10.1) <7F5B7A23-BC1D-3FA9-A9B8-D534F1E1979A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framewor k/Versions/A/FSEvents
        0x7fff9a468000 -     0x7fff9a4b6ff7  libstdc++.6.dylib (104.1) <76E2AFB1-07E5-3F19-B692-F6E21B7E470D> /usr/lib/libstdc++.6.dylib
        0x7fff9a4eb000 -     0x7fff9a691ff7  com.apple.audio.toolbox.AudioToolbox (1.13 - 1.13) <082319FC-59F2-3D36-AC9B-94759724E302> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
        0x7fff9a692000 -     0x7fff9a92cfff  com.apple.security (7.0 - 57337.40.85) <7C5B8DEF-3D02-3410-9BD3-2B1251F84D4B> /System/Library/Frameworks/Security.framework/Versions/A/Security
        0x7fff9a932000 -     0x7fff9a9bfdd7  com.apple.AppleJPEG (1.0 - 1) <558ACADA-C41F-3EEF-82A0-C2D7B13C5428> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
        0x7fff9a9c9000 -     0x7fff9a9d0ff7  libcompiler_rt.dylib (62) <A13ECF69-F59F-38AE-8609-7B731450FBCD> /usr/lib/system/libcompiler_rt.dylib
        0x7fff9a9d1000 -     0x7fff9a9d9fff  libsystem_networkextension.dylib (385.40.36) <66095DC7-6539-38F2-95EE-458F15F6D014> /usr/lib/system/libsystem_networkextension.dylib
        0x7fff9a9da000 -     0x7fff9a9feff7  libJPEG.dylib (1444) <BECAD377-4E20-37BE-BEC2-0A1D33497496> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
        0x7fff9aa49000 -     0x7fff9aa95fff  com.apple.print.framework.PrintCore (11.2 - 472.2) <5AE8AA6B-CE09-397D-B0D4-0F9CCBF1F77D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
        0x7fff9ac15000 -     0x7fff9ac3efff  com.apple.ProtectedCloudStorage (1.0 - 1) <4850F751-E61B-30C0-B89A-B313601D3DB5> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedClo udStorage
        0x7fff9b22c000 -     0x7fff9b33aff3  com.apple.desktopservices (1.10.3 - 1.10.3) <3A6906D4-C0B8-30D1-B589-0466E5E42B69> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
        0x7fff9b686000 -     0x7fff9bafcfff  com.apple.CoreFoundation (6.9 - 1258.1) <943A1383-DA6A-3DC0-ABCD-D9AEB3D0D34D> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
        0x7fff9cc71000 -     0x7fff9cc9fff7  com.apple.CoreServicesInternal (248.2 - 248.2) <6E111F0A-D7F1-3738-ADE7-CF983BD4EC8B> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
        0x7fff9ccf9000 -     0x7fff9cd01fef  libcldcpuengine.dylib (2.7.3) <B385841A-B573-3A91-9BEB-CC89CB2716B3> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
        0x7fff9cd87000 -     0x7fff9cdfbff3  com.apple.securityfoundation (6.0 - 55126) <1F6BDF18-3CF0-3E85-8D9B-0663599B9949> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
        0x7fff9ce05000 -     0x7fff9ce05ff7  liblaunch.dylib (765.40.36) <1CD7619D-AF2E-34D1-8EC6-8021CF473D9B> /usr/lib/system/liblaunch.dylib
        0x7fff9ce65000 -     0x7fff9ce66fff  libsystem_blocks.dylib (65) <1244D9D5-F6AA-35BB-B307-86851C24B8E5> /usr/lib/system/libsystem_blocks.dylib
        0x7fff9ce67000 -     0x7fff9d10dff7  com.apple.CoreData (120 - 641.3) <A29A5491-6169-372B-828F-84EE0CFD4BC4> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
        0x7fff9d10e000 -     0x7fff9d112fff  com.apple.CommonPanels (1.2.6 - 96) <4AE7E5AE-55B3-37FA-9BDE-B23147ADA2E9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
        0x7fff9d113000 -     0x7fff9d12aff7  libsystem_coretls.dylib (83.40.5) <C90DAE38-4082-381C-A185-2A6A8B677628> /usr/lib/system/libsystem_coretls.dylib
        0x7fff9d12b000 -     0x7fff9d134ff7  com.apple.CommonAuth (4.0 - 2.0) <4B8673E1-3697-3FE2-8D30-AC7AC5D4F8BF> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
        0x7fff9d13a000 -     0x7fff9d15cfff  com.apple.IconServices (68.1 - 68.1) <CDEEDBE6-F53B-3BA1-82D4-23BCA3DD8949> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
        0x7fff9d15d000 -     0x7fff9d2e9ff7  libGLProgrammability.dylib (12.0.40.6) <F5AE40EB-A28B-3F3B-8E4C-0C0D73E47EDB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
        0x7fff9d2ea000 -     0x7fff9d2ebfff  liblangid.dylib (122) <9CC4F0D1-5C51-3B69-BC8F-EE3A51FD0822> /usr/lib/liblangid.dylib
        External Modification Summary:
        Calls made by other processes targeting this process:
        task_for_pid: 2
        thread_create: 0
        thread_set_state: 0
        Calls made by this process:
        task_for_pid: 0
        thread_create: 0
        thread_set_state: 0
        Calls made by all processes on this machine:
        task_for_pid: 93116
        thread_create: 0
        thread_set_state: 0
        VM Region Summary:
        ReadOnly portion of Libraries: Total=487.5M resident=0K(0%) swapped_out_or_unallocated=487.5M(100%)
        Writable regions: Total=177.0M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=177.0M(100%)
        VIRTUAL   REGION
        REGION TYPE                        SIZE    COUNT (non-coalesced)
        Accelerate.framework               256K        3
        Activity Tracing                  2048K        2
        CG backing stores                 7268K        4
        CG image                           152K       13
        CG shared images                   240K        7
        CoreAnimation                       28K        5
        CoreUI image data                  696K        7
        CoreUI image file                  192K        4
        Dispatch continuations            4096K        2
        Image IO                           100K       11
        Kernel Alloc Once                    8K        3
        MALLOC                            88.3M      102
        MALLOC guard page                   32K        7
        Memory Tag 242                      12K        2
        OpenCL                               8K        2
        OpenGL GLSL                        384K        6
        Process Corpse Info               2048K        2
        STACK GUARD                       56.1M       33
        Stack                             23.3M       33
        VM_ALLOCATE                       27.2M       14
        __DATA                            43.9M      347
        __GLSLBUILTINS                    2588K        2
        __IMAGE                            528K        2
        __LINKEDIT                       118.4M       71
        __TEXT                           369.1M      325
        __UNICODE                          552K        2
        mapped file                       51.5M       34
        shared memory                     16.3M       12
        TOTAL                            814.9M     1029
        Model: iMac7,1, BootROM IM71.007A.B03, 2 processors, Intel Core 2 Duo, 2.4 GHz, 4 GB, SMC 1.21f4
        Graphics: ATI Radeon HD 2600 Pro, ATI,RadeonHD2600, PCIe, 256 MB
        Memory Module: BANK 0/DIMM0, 2 GB, DDR2 SDRAM, 667 MHz, 0x7F7F7F7F7F7F7F45, 0x484D444E323032475536343844363635432D
        Memory Module: BANK 1/DIMM1, 2 GB, DDR2 SDRAM, 667 MHz, 0x7F7F7F7F7F7F7F45, 0x484D444E323032475536343844363635432D
        AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x88), Broadcom BCM43xx 1.0 (5.10.131.36.16)
        Bluetooth: Version 4.4.4f4 17685, 3 services, 26 devices, 1 incoming serial ports
        Network Service: Ethernet, Ethernet, en0
        Serial ATA Device: WDC WD3200AAJS-40VWA0, 320.07 GB
        Parallel ATA Device: MATSHITADVD-R   UJ-875
        USB Device: USB 2.0 Bus
        USB Device: Built-in iSight
        USB Device: Keyboard Hub
        USB Device: PTK-640
        USB Device: Apple Keyboard
        USB Device: USB Bus
        USB Device: Bluetooth HCI
        USB Device: USB Bus
        USB Device: USB Bus
        USB Device: USB Bus
        USB Device: IR Receiver
        USB Device: USB Bus
        Thunderbolt Bus:
        • 34. Re: Bridge CC keeps crashing when viewing folder
        Bazzatee Level 1
        The problem on the IMac was solved by unchecking the "Displays have separate spaces" in System preferences - Mission control.
        • 35. Re: Bridge CC keeps crashing when viewing folder
        ShaneH Level 1
        This problem has come back after months of reprieve. Crashes over and over again for no good reason, since minor update to Mac OS 10.11.6 (15G31).
        The problem is that Adobe is relying too much on caching. Today's computers and networks are fast enough that caching is rarely necessary. All the best search and browsing tools have eliminated caching from their programming (i.e., EasyFind by Devon Technologies).
        I guess I'll try resetting Bridge. >:-(
        • 36. Re: Bridge CC keeps crashing when viewing folder
        neilm75711079
        Ive tried to no avail...
        • 37. Re: Bridge CC keeps crashing when viewing folder
        GautamBahl Adobe Employee
        Hi Shane and Neil,
        Have you installed Bridge CC 2015 version released on 19th July 2016.
        If yes, please share the crash report.
        Gautam
        • 38. Re: Bridge CC keeps crashing when viewing folder
        ShaneH Level 1
        Affirmative. I reset everything in bridge and started from scratch. It was OK for a while and now it is just crashing over and over again. I don't understand how a minor OS update would cause an application to go so haywire.
        • 39. Re: Bridge CC keeps crashing when viewing folder
        ShaneH Level 1
        Strike that. I just saw that there is a brand new update for Bridge. Will try it and let you know.
        1 2 Previous Next
