      • Espaรฑol
      • Franรงais
      • Portuguรชs
  • ๆ—ฅๆœฌ่ชžใ‚ณใƒŸใƒฅใƒ‹ใƒ†ใ‚ฃ
  • ํ•œ๊ตญ ์ปค๋ฎค๋‹ˆํ‹ฐ
Errore del server
Mar 04, 2016 Mar 04, 2016
Ho scaricato un ebook con il mio iMac 24 dal sito IBS, precisando nella richiesta il formato PDF, che difatti appare nell'icona iniziale.
Poi mi arriva il formato acsm e non si apre per un "errore del server". Mi รจ stato suggerito di "disautorizzare" l'account per ripristinarlo, ma mi si dice che la cosa "e' impossibile".
Come debbo comportarmi?
Grazie e cordialitร .
353
LEGEND , Mar 14, 2016 Mar 14, 2016
Have you check the steps of this Access hidden Mac OS library files?
Mar 05, 2016 Mar 05, 2016
Windows:
  1. Close all applications.
  2. Choose Start > Run.
  3. In the Open text box, type regedit and then press Enter. The Registry Editor opens.
  4. In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
  5. Select the Adept key.
  6. Choose File > Export.
  7. In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
  8. Right-click the Adept key and choose Delete.
  9. In the Confirm Key Delete dialog, click OK.
  10. Close the Registry Editor.
  11. Open Adobe Digital Editions and reauthorize.
Macintosh:
  1. quit Adobe Digital Editions.
  2. Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
    If you are using 10.7, see Access hidden library files | Mac OS 10.7 and later.
  3. Open Adobe Digital Editions and reauthorize.
Ho seguito le indicazioni ricevute, compresa la ricerca del support nascosto,
ma non ho trovato quello riferito ad Adobe Digital Editions con il file da trascinare nel cestino.
Dove ho sbagliato?
Mar 08, 2016 Mar 08, 2016
Do are used Macintosh? If yes do not found the activation.dat? Have you found the folder /Users//Library/Application Support/Adobe/Digital Editions?
Mar 12, 2016 Mar 12, 2016
Uso Macintosh,
NON trovo activation.dat dell'Application support/Adobe/Digitale Edition,
e neanche Digital Edition.
Perchรฉ?
Mar 17, 2016 Mar 17, 2016
HO SEGUITO LE DISPOSIZIONI E HO RISOLTO IL MIO PROBLEMA.
RINGRAZIO SENTITAMENTE.
You are welcome.
