Hi Joel
As Matt indicated, merging is one approach. Before using this
approach, however, you should consider some things.
1. Ensure the image is large enough so that the Captivate
fits cleanly inside. Then resize Captivate to accommodate the image
and center the existing part of the project.
2. If using this approach, you would need to merge each and
every slide.
Another approach would be to simply insert the image on slide
1 and configure it to display for the rest of the project. Of
course, you would also want to make the inside part transparent so
the main part of your Captivate could "shine through" and be
visible.
Cheers... Rick
