I have downloaded ADE but then used it without authorizing it, consequently I can't transfer an ebook onto my ereader. How do I go back and authorize my computer with my ID so I can transfer my ebook to my ereader?
Windows:
Close all applications.
Choose Start > Run.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
Select the Adept key.
Choose File > Export.
In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
Right-click the Adept
...Copy link to clipboard
Windows:
Choose Start > Run.
Right-click the Adept key and choose Delete.
In the Confirm Key Delete dialog, click OK.
Close the Registry Editor.
Open Adobe Digital Editions and reauthorize.
Macintosh:
quit Adobe Digital Editions.
Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
If you download the eBooks before you authorize the eBooks can read only on this system. If you move it to a reader you need a new download after authoirze and then can linked with your right Adobe ID.
That's brilliant thank you. I've managed to do it and can now transfer an ebook onto my device. Really chuffed.
I did all you explained
Inside regedit I had to go in "Device" to remove the key (inside device there was 3 other files)
Now I can't no more go on authorize
When I try to open the book I get an error
I can't remove Authorization
Really upset!
Please help because I am afrai I threw my money throw the window
Regards
Has you remove the complete folder HKEY_CURRENT_USER\Software\Adobe\Adept ?
I removed the complete folder as you said
Error disappeared when I try to open the book but it asks me always for ID and password.
The book is always locked
I try to give authorisation but always the same pb.
The book is over protected so I can't read it. Protection is really efficient!!!
Has you used the same Adobe ID as the fist download?
Where to and why. will I need it? I'm a complete neophyte with this.
Enter a name and location for the backup registry key, and then click Save.:
