1
Creative Cloud Desktop - Apps tab missing - mac
Mar 09, 2016 Mar 09, 2016
Hi All
I'm using OSX 10.11.3
I know this question has been asked a few times and I did find a solution, which was on another thread.
– Sign out of Creative Cloud desktop and then exit Creative Cloud desktop.
– Go to Macintosh HD/Library/Application Support/Adobe
– Find and delete the folders: AAM Updater, OOBE folder and Adobeapplication Manager folder
– Run CC cleaner tool found here > https://helpx.adobe.com/creative-cloud/kb/cc-cleaner-tool-installation-problems.html
– Select Creative Cloud Desktop and click clean up selected only
– Re-install Creative Cloud Desktop > https://creative.adobe.com/products/creative-cloud
– Log in and apps tab should be displaying with 2015 updates available
You may need to re-install the Adobe application manager found here > Adobe - Adobe Application Manager : For Macintosh : Adobe Application Manager
This worked but as soon as I restarted the apps tab disappeared again, anyone seen that happen? I really don't want to have to do this every time I restart.
Creative Cloud
35.6K
Adobe Employee , Mar 09, 2016 Mar 09, 2016
Please follow the below mentioned steps to fix the issue.
Steps to fix the issue  :
Go to location :
MAC:-  /Library/Application Support/Adobe/OOBE/Config
Windows:-  C:\Program Files (x86)\Common Files\Adobe\OOBE\Config
Open file “ServiceConfig.xml” with text edit/Notepad and make the following changes
<config>- <panel>  <name>Apps Panel</name> <visible>true</visible> </panel>  </config>
Save XML file (we need to change the False value to True).
If the issue is not fixe
Adobe Employee ,
Go to location :
If the issue is not fixed by above Solution then please rename the serviceconfig.xml file
Note:- Before performing these steps kindly close all the Adobe applications and sign out of Creative cloud desktop app.
Thank you.. That worked.
Adobe Employee ,
You are welcome.
Mar 14, 2016 Mar 14, 2016
My OOBE folder does not have a config folder or a service xml file... I am on Mac. I have uninstalled and reinstalled twice.
Adobe Employee ,
Hi Arjun,
Please try steps on following link for re installation as when you reinstall there are some folders which may not get updated due to which you get the issue back.
solution: Creative cloud CC app issues/download error on apps tab/Creative cloud spinning wheel issu...
Feb 11, 2017 Feb 11, 2017
I also have no Config file in OOBE. Is there anything else we can try?
Dec 01, 2017 Dec 01, 2017
What Link? There isn't anything posted to your comment to follow. I am also having trouble finding the file. There is no config folder...
Dec 26, 2017 Dec 26, 2017
POTENTIAL FIX FOR MAC USERS WHO CAN'T SEE 'CONFIG' FOLDER!!!
Macintosh ID (your hard drive) > Applications > Adobe Creative Cloud > Uninstall Adobe Creative Cloud
At this point it will ask for your Mac password. Once you've entered it, it will give you two options: 1. Go ahead with the uninstall, or 2. Let Adobe run a repair. Select the repair option.
Once it's complete, log back into your CC Desktop App and bada-bing... the Apps tab is back!!!!
Aug 04, 2017 Aug 04, 2017
On my Windows 10 PC the folder name is "Configs" not "Config", which means I cannot copy and paste the file path above into my File Explorer ... unless I paste it then edit it.
Also, there are some Adobe CC processes that need to be terminated BEFORE beginning the other steps listed above. To launch Task Manager as a computer Admin, press the Windows key on the keyboard, then type Task. When the search feature finds Task Manager, Press Ctrl + Shift + Esc while you click Task Manager. This launches the Task Manager as an Admin.
Go to the Processes tab, then look for and terminate these processes in the order listed:
CCLibraries
CCXProcess
Coresync
Creative Cloud
Adobe IPC Broker
PDApp.exe
AcroTray
AGSServices
Now you're ready to follow the other steps listed above.
Apr 22, 2018 Apr 22, 2018
I have the same issue, did you ever find a solution? I tried everything and I don't have the config folder or the serviceconfig.xml either. Someone please help!
Apr 23, 2018 Apr 23, 2018
Adobe's customer service for this issue and others hasn't been all that great. They get stuck on saying that a file should exist and if it doesn't, then you did something wrong or aren't looking in the right place. I've had several machines that don't have the file and a few that I have been able to change successfully, but then they revert back to the missing apps tab later on.
Here is what I send my customers and these steps seem to work 90-95% of the time.  The other times, I just end up having the user uninstall Adobe completely from their machine and reinstall it, or in some rare instances, re-image the machine.
Missing Apps tab
  1. Quit application
  2. Navigate to the following location
    1. (Windows): C:/Program Files(x86)/Common Files/Adobe/OOBE/Configs/
    2. (macOS): /Library/Application Support/Adobe/OOBE/Configs/
  3. Locate and open the serviceconfig.xml file in Notepad (Windows) or TextEdit (macOS).
  4. In the serviceeconfig.xml file, change the value of AppsPanel from false to true.
  5. Save and close serviceconfig.xml.
  6. Restart your system and launch the Creative Cloud desktop app.
  7. If you do not have the serviceconfig.xml file or it doesn't seem to want to stay permanently fixed, download and run the Limited Access repair tool from:  https://helpx.adobe.com/creative-cloud/kb/limited_access_repair_tool.html
Thanks, but I didn't have the Configs folder in OOBE, meaning I had no way to fix the issue this way. However I rang up Adobe yesterday and they fixed it for me within 20 mins and now it works perfectly fine.
Thanks again for your reply : )
Aug 14, 2018 Aug 14, 2018
what did they do?
Aug 16, 2018 Aug 16, 2018
They probably remote logged on the machine and fixed the config.
ABAMBO | Hard- and Software Engineer | Photographer
May 31, 2018 May 31, 2018
Hello,
I too had same issues on missing config folder and missing serviceconfig.xml.
I tried below steps and able to find the Folder + File and it worked.
For MAC only
Before you follow the below steps close all your abobe applications
1. Open FINDER
2. Press SHIFT+COMMAND+C
3. Click on MACINTOSH HD
4. Click Applications-> Library->Application Support->Adobe->OOBE->Configs
5. Under Config you will see serviceconfig.xml file
6. Copy serviceconfig.xml file to desktop
7. Make the following changes <config>- <panel>  <name>Apps Panel</name> <visible>true</visible> </panel> </config> (You are changing False to True)
8.
Save the XML file
9. Save the file to its original location
10. Login to Creative cloud
11. BINGO! Apps tab is there.
Jun 21, 2018 Jun 21, 2018
Tranks bro work fine
Jul 15, 2018 Jul 15, 2018
WHat if you dont have an OOBE folder?
Apr 25, 2016 Apr 25, 2016
Couldn't locate the ServiceConfig.xml in the OOBE or any other folder.
Someone please help..
May 02, 2016 May 02, 2016
This is the case on my machine also. It looks like the folder Config has been removed to prevent tampering with the .xml file. We need a new workaround!!
Jul 13, 2016 Jul 13, 2016
I'm in the same boat as the other people that the config file location has moved. Any update on this?
Jan 25, 2019 Jan 25, 2019
​me too
Sep 24, 2016 Sep 24, 2016
Thanks for the solution. I am trying to get mine resolved. Where do I find this library folder to being with in a Mac?
Dec 08, 2016 Dec 08, 2016
re:
Open finder and at top select Go, then hold the option key down and Library will pop up.
Mar 29, 2017 Mar 29, 2017
I also don't have the: /Library/Application Support/Adobe/OOBE/Config on my Mac. Is there anything else we can do? I am trying to get the Adobe Experience Design app installed and the site directs me to the Creative Cloud app, but as I do not have an Apps tab, it makes the installation impossible. Any additional help would be appreciated.
