Projects that opened and functioned just fine in RHX5 no
longer work properly in RH 7. The project opens with no errors but
when I double click a topic to view or edit it, the program is
non-responsive and hangs. The topic is not displayed. No matter how
long you wait, nothing happens and I eventually have to end the
program. The size of the project doesn't seem to matter as this
problem occurs across all my projects, large and small.
Occasionally, I manage to edit a topic but 90% of the time the
program hangs. Does anyone have any suggestions?
I, too, am experiencing significant hang issues with RH 7. I
updated an RH 5 project into RH 7. It is a large project. Could it
be a memory issue? I have 1 gig of RAM. The small supplied projects
work better, although still a bit slow. RH 7 ends up not responding
and has to be killed through Task Manager.
One cause of slowness in RoboHelp 7 is having a large number
of fonts installed. I just read on the Adobe Technical
Communication blog that a patch has been made available that is
supposed to fix this situation. You may wish to give it a try.
Rick, thanks for the link--I didn't know about that blog.
Looks like a great way to keep up to speed and see what the product
managers are thinking and recommending. It could also be a good way
for RoboHelp users to communicate directly with the product
managers through comments.
So I have 3 Font Sets: Arial, Microsoft Sans Serif, and Times
New Roman.
If all my documentation is created with Arial, should I just
go ahead and delete Microsoft Sans Serif and Times New Roman font
sets from all of my projects and this should speed things up after
I replace the .dll?
