Hi
I am trying to send data to Bugzilla from my Coldfusion
Application..and Bugzilla uses XML-RPC, i only worked with SOAP
before and havn't had any idea on XML-RPC and tried to browse thru
in google but unable to find the exact info. needed. of how to
connect to Bugzilla and Create a Bug using Bugzilla API.. from
Coldfusion.
here is my code below of how am using.
Bugzilla API Documentation is here
http://www.bugzilla.org/docs/tip/html/api/Bugzilla/WebService/Bug.html
I am using a
Create Method to Create a Bug.
<cfinvoke webservice="
http://157.238.223.201/bugzilla/xmlrpc.cgi"
method="create"
returnvariable="rpcCall"
data="#bugdata#"
type="responsefault">
<cfoutput>response is:
<strong>#rpcCall#</strong> <br>
did you see anything for now.. testing this script. thanks
</cfoutput>
when i execute the above code, i do get the error below.
Could not generate stub objects for web service invocation.
Name:
http://157.238.223.201/bugzilla/xmlrpc.cgi.
WSDL:
java.net.ConnectException: Connection timed out: connect It is
recommended that you use a web browser to retrieve and examine the
requested WSDL document for correctness. If the requested WSDL
document can't be retrieved or it is dynamically generated, it is
likely that the target web service has programming
errors.
