Hello all, I am trying to upgrade flash player using the MSI but am getting error 2727. The directory entry Flash does not exist in the directory table. The applications previous install was done using SCCM with and MSI and MST. Now even a manual install gives off the same error. The exe works though
Please upload a verbose MSI install log file from an impacted system to cloud.acrobat.com using the instructions at How to share a document or some other file sharing service of your choice that doesn't require log-in access. Post the link to the uploaded files in your reply.
Is this an upgrade from a previous version to 21.0.0.182, or did you uninstall first and then attempt to install 21.0.0.182?
Thank you.
Maria
unfortunately the cloud.acrobat.com site is down. But I do have a log file below.
=== Verbose logging started: 3/15/2016 7:37:33 Build type: SHIP UNICODE 5.00.7601.00 Calling process: C:\WINDOWS\system32\msiexec.exe ===
MSI (c) (34:90) [07:37:33:942]: Font created. Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg
MSI (c) (34:CC) [07:37:33:951]: Resetting cached policy values
MSI (c) (34:CC) [07:37:33:951]: Machine policy value 'Debug' is 0
MSI (c) (34:CC) [07:37:33:951]: ******* RunEngine:
******* Product: C:\Users\jryan\Desktop\Flash 21\activex\install_flash_player_21_active_x.msi
******* Action:
******* CommandLine: **********
MSI (c) (34:CC) [07:37:33:955]: Machine policy value 'DisableUserInstalls' is 0
MSI (c) (34:CC) [07:37:33:959]: User policy value 'SearchOrder' is 'nmu'
MSI (c) (34:CC) [07:37:33:959]: User policy value 'DisableMedia' is 0
MSI (c) (34:CC) [07:37:33:959]: Machine policy value 'AllowLockdownMedia' is 0
MSI (c) (34:CC) [07:37:33:959]: SOURCEMGMT: Media enabled only if package is safe.
MSI (c) (34:CC) [07:37:33:959]: SOURCEMGMT: Looking for sourcelist for product {92C34178-B679-4C83-AC33-7EFCE6D36E01}
MSI (c) (34:CC) [07:37:33:959]: SOURCEMGMT: Adding {92C34178-B679-4C83-AC33-7EFCE6D36E01}; to potential sourcelist list (pcode;disk;relpath).
MSI (c) (34:CC) [07:37:33:959]: SOURCEMGMT: Now checking product {92C34178-B679-4C83-AC33-7EFCE6D36E01}
MSI (c) (34:CC) [07:37:33:959]: SOURCEMGMT: Media is enabled for product.
MSI (c) (34:CC) [07:37:33:959]: SOURCEMGMT: Attempting to use LastUsedSource from source list.
MSI (c) (34:CC) [07:37:33:959]: SOURCEMGMT: Trying source C:\WINDOWS\ccmcache\5b\.
MSI (c) (34:CC) [07:37:34:036]: Cloaking enabled.
MSI (c) (34:CC) [07:37:34:036]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (34:CC) [07:37:34:037]: Connected to service.
MSI (c) (34:CC) [07:37:34:038]: SOURCEMGMT: Resolved source to: 'C:\WINDOWS\ccmcache\5b\'
MSI (c) (34:CC) [07:37:34:039]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Users\jryan\Desktop\Flash 21\activex\install_flash_player_21_active_x.msi' against software restriction policy
MSI (c) (34:CC) [07:37:34:039]: SOFTWARE RESTRICTION POLICY: C:\Users\jryan\Desktop\Flash 21\activex\install_flash_player_21_active_x.msi has a digital signature
MSI (c) (34:CC) [07:37:34:149]: SOFTWARE RESTRICTION POLICY: C:\Users\jryan\Desktop\Flash 21\activex\install_flash_player_21_active_x.msi is permitted to run at the 'unrestricted' authorization level.
MSI (c) (34:CC) [07:37:34:149]: Cloaking enabled.
MSI (c) (34:CC) [07:37:34:149]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (34:CC) [07:37:34:149]: End dialog not enabled
MSI (c) (34:CC) [07:37:34:149]: Original package ==> C:\WINDOWS\ccmcache\5b\install_flash_player_21_active_x.msi
MSI (c) (34:CC) [07:37:34:149]: Package we're running from ==> C:\WINDOWS\ccmcache\5b\install_flash_player_21_active_x.msi
MSI (c) (34:CC) [07:37:34:150]: APPCOMPAT: looking for appcompat database entry with ProductCode '{92C34178-B679-4C83-AC33-7EFCE6D36E01}'.
MSI (c) (34:CC) [07:37:34:151]: APPCOMPAT: no matching ProductCode found in database.
MSI (c) (34:CC) [07:37:34:158]: MSCOREE not loaded loading copy from system32
MSI (c) (34:CC) [07:37:34:160]: Note: 1: 2205 2: 3: MsiFileHash
MSI (c) (34:CC) [07:37:34:160]: Machine policy value 'DisablePatch' is 0
MSI (c) (34:CC) [07:37:34:160]: Machine policy value 'AllowLockdownPatch' is 0
MSI (c) (34:CC) [07:37:34:160]: Machine policy value 'DisableLUAPatching' is 0
MSI (c) (34:CC) [07:37:34:160]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI (c) (34:CC) [07:37:34:160]: Looking for file transform: C:\WINDOWS\Installer\{92C34178-B679-4C83-AC33-7EFCE6D36E01}\active.mst
MSI (c) (34:CC) [07:37:34:160]: Original transform ==> C:\WINDOWS\Installer\{92C34178-B679-4C83-AC33-7EFCE6D36E01}\active.mst
MSI (c) (34:CC) [07:37:34:160]: Transform we're running from ==> C:\WINDOWS\Installer\{92C34178-B679-4C83-AC33-7EFCE6D36E01}\active.mst
MSI (c) (34:CC) [07:37:34:161]: SOFTWARE RESTRICTION POLICY: Verifying transform --> 'C:\WINDOWS\Installer\{92C34178-B679-4C83-AC33-7EFCE6D36E01}\active.mst' against software restriction policy
MSI (c) (34:CC) [07:37:34:161]: Note: 1: 2262 2: DigitalSignature 3: -2147287038
MSI (c) (34:CC) [07:37:34:161]: SOFTWARE RESTRICTION POLICY: C:\WINDOWS\Installer\{92C34178-B679-4C83-AC33-7EFCE6D36E01}\active.mst is not digitally signed
MSI (c) (34:CC) [07:37:34:162]: SOFTWARE RESTRICTION POLICY: C:\WINDOWS\Installer\{92C34178-B679-4C83-AC33-7EFCE6D36E01}\active.mst is permitted to run at the 'unrestricted' authorization level.
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: Patch 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2205 2: 3: PatchPackage
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: _Tables 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: _Columns 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: TRANSFORM: 'PatchPackage' table is missing or empty. No pre-transform fixup necessary.
MSI (c) (34:CC) [07:37:34:162]: TRANSFORM: Applying regular transform to database.
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: ActionText 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: AdminExecuteSequence 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: AdminUISequence 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: AdvtExecuteSequence 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: AdvtUISequence 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: AppSearch 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: Feature 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: Binary 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: CheckBox 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: Icon 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: ComboBox 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: Directory 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: Control 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: Dialog 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: ControlCondition 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: ControlEvent 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: CreateFolder 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: Error 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: EventMapping 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: InstallExecuteSequence 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: InstallUISequence 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: LaunchCondition 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: ListBox 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: ListView 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: RadioButton 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: RegLocator 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: Signature 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: TextStyle 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: UIText 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: Upgrade 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: _Validation 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: ISComponentExtended 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: ISCustomActionReference 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: ISSetupFile 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: _MsiPatchTransformView 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: #_BaselineCost 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: #_BaselineFile 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: #_BaselineData 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: Note: 1: 2262 2: #_PatchCache 3: -2147287038
MSI (c) (34:CC) [07:37:34:162]: APPCOMPAT: looking for appcompat database entry with ProductCode '{92C34178-B679-4C83-AC33-7EFCE6D36E01}'.
MSI (c) (34:CC) [07:37:34:162]: APPCOMPAT: no matching ProductCode found in database.
MSI (c) (34:CC) [07:37:34:162]: Transforms are not secure.
MSI (c) (34:CC) [07:37:34:163]: Transforming table Property.
MSI (c) (34:CC) [07:37:34:163]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\jryan\Desktop\Flash 21\activex\msi.txt'.
MSI (c) (34:CC) [07:37:34:163]: Command Line: CURRENTDIRECTORY=C:\WINDOWS\system32 CLIENTUILEVEL=0 CLIENTPROCESSID=31796
MSI (c) (34:CC) [07:37:34:163]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{68B30DE0-0B6D-4EB9-BFC0-D3DC88FF7A37}'.
MSI (c) (34:CC) [07:37:34:163]: PROPERTY CHANGE: Adding TRANSFORMS property. Its value is 'C:\WINDOWS\Installer\{92C34178-B679-4C83-AC33-7EFCE6D36E01}\active.mst'.
MSI (c) (34:CC) [07:37:34:163]: Product Code passed to Engine.Initialize: '{92C34178-B679-4C83-AC33-7EFCE6D36E01}'
MSI (c) (34:CC) [07:37:34:163]: Product Code from property table before transforms: '{92C34178-B679-4C83-AC33-7EFCE6D36E01}'
MSI (c) (34:CC) [07:37:34:163]: Product Code from property table after transforms: '{92C34178-B679-4C83-AC33-7EFCE6D36E01}'
MSI (c) (34:CC) [07:37:34:163]: Product not registered: beginning first-time install
MSI (c) (34:CC) [07:37:34:163]: Determined that existing product (either this product or the product being upgraded with a patch) is installed per-machine.
MSI (c) (34:CC) [07:37:34:163]: PROPERTY CHANGE: Adding ProductState property. Its value is '1'.
MSI (c) (34:CC) [07:37:34:163]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI (c) (34:CC) [07:37:34:163]: Specifed source is already in a list.
MSI (c) (34:CC) [07:37:34:163]: User policy value 'SearchOrder' is 'nmu'
MSI (c) (34:CC) [07:37:34:163]: Machine policy value 'DisableBrowse' is 0
MSI (c) (34:CC) [07:37:34:163]: Machine policy value 'AllowLockdownBrowse' is 0
MSI (c) (34:CC) [07:37:34:163]: Adding new sources is allowed.
MSI (c) (34:CC) [07:37:34:163]: Package name retrieved from configuration data: 'install_flash_player_21_active_x.msi'
MSI (c) (34:CC) [07:37:34:164]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI (c) (34:CC) [07:37:34:164]: Machine policy value 'DisableMsi' is 0
MSI (c) (34:CC) [07:37:34:164]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (c) (34:CC) [07:37:34:164]: User policy value 'AlwaysInstallElevated' is 0
MSI (c) (34:CC) [07:37:34:164]: Product {92C34178-B679-4C83-AC33-7EFCE6D36E01} is admin assigned: LocalSystem owns the publish key.
MSI (c) (34:CC) [07:37:34:164]: Product {92C34178-B679-4C83-AC33-7EFCE6D36E01} is managed.
MSI (c) (34:CC) [07:37:34:164]: Running product '{92C34178-B679-4C83-AC33-7EFCE6D36E01}' with elevated privileges: Product is assigned.
MSI (c) (34:CC) [07:37:34:164]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\WINDOWS\system32'.
MSI (c) (34:CC) [07:37:34:164]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'.
MSI (c) (34:CC) [07:37:34:164]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '31796'.
MSI (c) (34:CC) [07:37:34:164]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI (c) (34:CC) [07:37:34:164]: TRANSFORMS property is now: C:\WINDOWS\Installer\{92C34178-B679-4C83-AC33-7EFCE6D36E01}\active.mst
MSI (c) (34:CC) [07:37:34:164]: PROPERTY CHANGE: Adding PRODUCTLANGUAGE property. Its value is '1033'.
MSI (c) (34:CC) [07:37:34:164]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '110'.
MSI (c) (34:CC) [07:37:34:164]: SHELL32::SHGetFolderPath returned: C:\Users\jryan-admin\AppData\Roaming
MSI (c) (34:CC) [07:37:34:164]: SHELL32::SHGetFolderPath returned: C:\Users\jryan-admin\Favorites
MSI (c) (34:CC) [07:37:34:165]: SHELL32::SHGetFolderPath returned: C:\Users\jryan-admin\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI (c) (34:CC) [07:37:34:165]: SHELL32::SHGetFolderPath returned: C:\Users\jryan-admin\Documents
MSI (c) (34:CC) [07:37:34:165]: SHELL32::SHGetFolderPath returned: C:\Users\jryan-admin\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI (c) (34:CC) [07:37:34:165]: SHELL32::SHGetFolderPath returned: C:\Users\jryan-admin\AppData\Roaming\Microsoft\Windows\Recent
MSI (c) (34:CC) [07:37:34:165]: SHELL32::SHGetFolderPath returned: C:\Users\jryan-admin\AppData\Roaming\Microsoft\Windows\SendTo
MSI (c) (34:CC) [07:37:34:165]: SHELL32::SHGetFolderPath returned: C:\Users\jryan-admin\AppData\Roaming\Microsoft\Windows\Templates
MSI (c) (34:CC) [07:37:34:165]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI (c) (34:CC) [07:37:34:166]: SHELL32::SHGetFolderPath returned: C:\Users\jryan-admin\AppData\Local
MSI (c) (34:CC) [07:37:34:166]: SHELL32::SHGetFolderPath returned: C:\Users\jryan-admin\Pictures
MSI (c) (34:CC) [07:37:34:166]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (c) (34:CC) [07:37:34:166]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI (c) (34:CC) [07:37:34:166]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI (c) (34:CC) [07:37:34:167]: SHELL32::SHGetFolderPath returned: C:\Users\jryan-admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (c) (34:CC) [07:37:34:167]: SHELL32::SHGetFolderPath returned: C:\Users\jryan-admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI (c) (34:CC) [07:37:34:167]: SHELL32::SHGetFolderPath returned: C:\Users\jryan-admin\Desktop
MSI (c) (34:CC) [07:37:34:168]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI (c) (34:CC) [07:37:34:168]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\Fonts
MSI (c) (34:CC) [07:37:34:168]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI (c) (34:CC) [07:37:34:172]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI (c) (34:CC) [07:37:34:172]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI (c) (34:CC) [07:37:34:172]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI (c) (34:CC) [07:37:34:172]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI (c) (34:CC) [07:37:34:172]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI (c) (34:CC) [07:37:34:172]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'Fortress Investment Group'.
MSI (c) (34:CC) [07:37:34:172]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Fortress Investment Group'.
MSI (c) (34:CC) [07:37:34:172]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\WINDOWS\ccmcache\5b\install_flash_player_21_active_x.msi'.
MSI (c) (34:CC) [07:37:34:172]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\WINDOWS\ccmcache\5b\install_flash_player_21_active_x.msi'.
MSI (c) (34:CC) [07:37:34:172]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI (c) (34:CC) [07:37:34:172]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'C:\WINDOWS\ccmcache\5b\'.
MSI (c) (34:CC) [07:37:34:172]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\WINDOWS\ccmcache\5b\'.
MSI (c) (34:90) [07:37:34:172]: PROPERTY CHANGE: Adding VersionHandler property. Its value is '5.00'.
=== Logging started: 3/15/2016 7:37:34 ===
MSI (c) (34:CC) [07:37:34:176]: Note: 1: 2205 2: 3: PatchPackage
MSI (c) (34:CC) [07:37:34:176]: Machine policy value 'DisableRollback' is 0
MSI (c) (34:CC) [07:37:34:176]: User policy value 'DisableRollback' is 0
MSI (c) (34:CC) [07:37:34:176]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
MSI (c) (34:CC) [07:37:34:176]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
MSI (c) (34:CC) [07:37:34:176]: Doing action: INSTALL
Action 7:37:34: INSTALL.
Action start 7:37:34: INSTALL.
MSI (c) (34:CC) [07:37:34:176]: UI Sequence table 'InstallUISequence' is present and populated.
MSI (c) (34:CC) [07:37:34:176]: Running UISequence
MSI (c) (34:CC) [07:37:34:176]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
MSI (c) (34:CC) [07:37:34:177]: Doing action: ISSetupFilesExtract
Action 7:37:34: ISSetupFilesExtract.
Action start 7:37:34: ISSetupFilesExtract.
MSI (c) (34:CC) [07:37:34:177]: Transforming table CustomAction.
MSI (c) (34:90) [07:37:34:179]: Invoking remote custom action. DLL: C:\Users\JRYAN-~1\AppData\Local\Temp\MSI3BAE.tmp, Entrypoint: SFStartupEx
MSI (c) (34:80) [07:37:34:180]: Cloaking enabled.
MSI (c) (34:80) [07:37:34:180]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (34:80) [07:37:34:180]: Connected to service for CA interface.
1: Starting to extract setup files
1: Getting SUPPORTDIR property :
1: Extracting SetupFiles to: C:\Users\JRYAN-~1\AppData\Local\Temp\{92C34178-B679-4C83-AC33-7EFCE6D36E01}
1: Getting ISSetupFile table view
1: Executing ISSetupFile table view
1: Extracting Setup File:
1: C:\Users\JRYAN-~1\AppData\Local\Temp\{92C34178-B679-4C83-AC33-7EFCE6D36E01}\IsIllegalUpgrade.vbs
1: Setting SUPPORTDIR property to: C:\Users\JRYAN-~1\AppData\Local\Temp\{92C34178-B679-4C83-AC33-7EFCE6D36E01}
MSI (c) (34!90) [07:37:34:269]: PROPERTY CHANGE: Adding SUPPORTDIR property. Its value is 'C:\Users\JRYAN-~1\AppData\Local\Temp\{92C34178-B679-4C83-AC33-7EFCE6D36E01}'.
MSI (c) (34!90) [07:37:34:269]: PROPERTY CHANGE: Adding ISSETUPFILESCOMPLETED property. Its value is 'Completed'.
1: Setting ISSETUPFILESCOMPLETED property
Action ended 7:37:34: ISSetupFilesExtract. Return value 1.
MSI (c) (34:CC) [07:37:34:272]: Doing action: ISSetAllUsers
Action 7:37:34: ISSetAllUsers.
Action start 7:37:34: ISSetAllUsers.
MSI (c) (34:CC) [07:37:34:272]: Transforming table CustomAction.
MSI (c) (34:18) [07:37:34:276]: Invoking remote custom action. DLL: C:\Users\JRYAN-~1\AppData\Local\Temp\MSI3C0D.tmp, Entrypoint: SetAllUsers
InstallShield 7:37:34: Begin SetAllUsers()
InstallShield 7:37:34: Getting records from Upgrade table
InstallShield 7:37:34: UpgradeCode: {42463807-970B-4257-BC95-5C348D61DF1C} MinVersion: 6.0.0.0 MaxVersion: 21.0.0.182 Language: Attributes: 769
InstallShield 7:37:34: Checking related product {92C34178-B679-4C83-AC33-7EFCE6D36E01}
InstallShield 7:37:34: Adobe Flash Player 21 ActiveX {92C34178-B679-4C83-AC33-7EFCE6D36E01} 1033 ***Related***
MSI (c) (34!C0) [07:37:34:285]: PROPERTY CHANGE: Adding IS_MAJOR_UPGRADE property. Its value is 'Yes'.
InstallShield 7:37:34: ALLUSERS of related product {92C34178-B679-4C83-AC33-7EFCE6D36E01} is = 1
InstallShield 7:37:34: End SetAllUsers()
Action ended 7:37:34: ISSetAllUsers. Return value 1.
MSI (c) (34:CC) [07:37:34:288]: Doing action: AppSearch
Action 7:37:34: AppSearch. Searching for installed applications
Action start 7:37:34: AppSearch.
AppSearch: Property: PREVIOUS_VERSION, Signature: NewSignature1
MSI (c) (34:CC) [07:37:34:289]: Note: 1: 2262 2: Signature 3: -2147287038
MSI (c) (34:CC) [07:37:34:289]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Macromedia\FlashPlayerActiveX 3: 2
Action ended 7:37:34: AppSearch. Return value 1.
MSI (c) (34:CC) [07:37:34:289]: Doing action: LaunchConditions
Action 7:37:34: LaunchConditions. Evaluating launch conditions
Action start 7:37:34: LaunchConditions.
Action ended 7:37:34: LaunchConditions. Return value 1.
MSI (c) (34:CC) [07:37:34:290]: Doing action: SetupInitialization
Action 7:37:34: SetupInitialization.
Action start 7:37:34: SetupInitialization.
MSI (c) (34:CC) [07:37:34:290]: Transforming table CustomAction.
Info 2898.For Tahoma8 textstyle, the system created a 'Tahoma' font, in 0 character set.
Info 2898.For TahomaBold10 textstyle, the system created a 'Tahoma' font, in 0 character set.
Action 7:37:34: SetupInitialization. Dialog created
Action ended 7:37:34: SetupInitialization. Return value 1.
MSI (c) (34:CC) [07:37:34:320]: Doing action: FindRelatedProducts
Action 7:37:34: FindRelatedProducts. Searching for related applications
Action start 7:37:34: FindRelatedProducts.
Action ended 7:37:34: FindRelatedProducts. Return value 1.
MSI (c) (34:CC) [07:37:34:322]: Skipping action: CCPSearch (condition is false)
MSI (c) (34:CC) [07:37:34:322]: Skipping action: RMCCPSearch (condition is false)
MSI (c) (34:CC) [07:37:34:322]: Doing action: ValidateProductID
Action 7:37:34: ValidateProductID.
Action start 7:37:34: ValidateProductID.
Action ended 7:37:34: ValidateProductID. Return value 1.
MSI (c) (34:CC) [07:37:34:323]: Doing action: CostInitialize
Action 7:37:34: CostInitialize. Computing space requirements
Action start 7:37:34: CostInitialize.
MSI (c) (34:CC) [07:37:34:324]: Machine policy value 'MaxPatchCacheSize' is 10
MSI (c) (34:CC) [07:37:34:325]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:\'.
MSI (c) (34:CC) [07:37:34:325]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
MSI (c) (34:CC) [07:37:34:325]: Transforming table FeatureComponents.
Action ended 7:37:34: CostInitialize. Return value 1.
MSI (c) (34:CC) [07:37:34:325]: Doing action: FileCost
Action 7:37:34: FileCost. Computing space requirements
Action start 7:37:34: FileCost.
MSI (c) (34:CC) [07:37:34:326]: Note: 1: 2205 2: 3: MsiAssembly
MSI (c) (34:CC) [07:37:34:326]: Note: 1: 2205 2: 3: Registry
MSI (c) (34:CC) [07:37:34:326]: Note: 1: 2205 2: 3: Class
MSI (c) (34:CC) [07:37:34:326]: Note: 1: 2205 2: 3: Extension
MSI (c) (34:CC) [07:37:34:326]: Note: 1: 2205 2: 3: TypeLib
Action ended 7:37:34: FileCost. Return value 1.
MSI (c) (34:CC) [07:37:34:326]: Doing action: IsolateComponents
Action 7:37:34: IsolateComponents.
Action start 7:37:34: IsolateComponents.
Action ended 7:37:34: IsolateComponents. Return value 0.
MSI (c) (34:CC) [07:37:34:327]: Doing action: setUserProfileNT
Action 7:37:34: setUserProfileNT.
Action start 7:37:34: setUserProfileNT.
MSI (c) (34:CC) [07:37:34:328]: Transforming table CustomAction.
MSI (c) (34:CC) [07:37:34:328]: PROPERTY CHANGE: Adding USERPROFILE property. Its value is 'C:\Users\jryan-admin'.
Action ended 7:37:34: setUserProfileNT. Return value 1.
MSI (c) (34:CC) [07:37:34:328]: Skipping action: SetAllUsersProfileNT (condition is false)
MSI (c) (34:CC) [07:37:34:328]: Doing action: setAllUsersProfile2K
Action 7:37:34: setAllUsersProfile2K.
Action start 7:37:34: setAllUsersProfile2K.
MSI (c) (34:CC) [07:37:34:328]: PROPERTY CHANGE: Adding ALLUSERSPROFILE property. Its value is 'C:\ProgramData'.
Action ended 7:37:34: setAllUsersProfile2K. Return value 1.
MSI (c) (34:CC) [07:37:34:329]: Doing action: ResolveSource
Action 7:37:34: ResolveSource.
Action start 7:37:34: ResolveSource.
MSI (c) (34:CC) [07:37:34:329]: Resolving source.
MSI (c) (34:CC) [07:37:34:329]: Resolving source to launched-from source.
MSI (c) (34:CC) [07:37:34:329]: Setting launched-from source as last-used.
MSI (c) (34:CC) [07:37:34:329]: PROPERTY CHANGE: Adding SourcedirProduct property. Its value is '{92C34178-B679-4C83-AC33-7EFCE6D36E01}'.
MSI (c) (34:CC) [07:37:34:329]: SOURCEDIR ==> C:\WINDOWS\ccmcache\5b\
MSI (c) (34:CC) [07:37:34:329]: SOURCEDIR product ==> {92C34178-B679-4C83-AC33-7EFCE6D36E01}
MSI (c) (34:CC) [07:37:34:329]: Determining source type
MSI (c) (34:CC) [07:37:34:330]: Source type from package 'install_flash_player_21_active_x.msi': 0
MSI (c) (34:CC) [07:37:34:331]: Source path resolution complete. Dumping Directory table...
MSI (c) (34:CC) [07:37:34:331]: Dir (source): Key: TARGETDIR , Object: C:\WINDOWS\ccmcache\5b\ , LongSubPath: , ShortSubPath:
MSI (c) (34:CC) [07:37:34:331]: Dir (source): Key: USERPROFILE , Object: C:\WINDOWS\ccmcache\5b\UserProfile\ , LongSubPath: UserProfile\ , ShortSubPath: USERPR~1\
MSI (c) (34:CC) [07:37:34:331]: Dir (source): Key: TempFolder , Object: C:\WINDOWS\ccmcache\5b\Temp\ , LongSubPath: Temp\ , ShortSubPath:
MSI (c) (34:CC) [07:37:34:331]: Dir (source): Key: SystemFolder , Object: C:\WINDOWS\ccmcache\5b\System32\ , LongSubPath: System32\ , ShortSubPath:
MSI (c) (34:CC) [07:37:34:331]: Dir (source): Key: MACROMED , Object: C:\WINDOWS\ccmcache\5b\System32\Macromed\ , LongSubPath: System32\Macromed\ , ShortSubPath:
MSI (c) (34:CC) [07:37:34:331]: Dir (source): Key: FLASH , Object: C:\WINDOWS\ccmcache\5b\System32\Macromed\Flash\ , LongSubPath: System32\Macromed\Flash\ , ShortSubPath:
MSI (c) (34:CC) [07:37:34:331]: Dir (source): Key: INSTALLDIR , Object: C:\WINDOWS\ccmcache\5b\System32\Macromed\Flash\ , LongSubPath: System32\Macromed\Flash\ , ShortSubPath:
MSI (c) (34:CC) [07:37:34:331]: Dir (source): Key: CommonFilesFolder , Object: C:\WINDOWS\ccmcache\5b\Common\ , LongSubPath: Common\ , ShortSubPath:
MSI (c) (34:CC) [07:37:34:331]: Dir (source): Key: ISCommonFilesFolder , Object: C:\WINDOWS\ccmcache\5b\Common\InstallShield\ , LongSubPath: Common\InstallShield\ , ShortSubPath: Common\Instal~1\
MSI (c) (34:CC) [07:37:34:331]: Dir (source): Key: ISUpdateServiceFolder , Object: C:\WINDOWS\ccmcache\5b\Common\InstallShield\UpdateService\ , LongSubPath: Common\InstallShield\UpdateService\ , ShortSubPath: Common\Instal~1\UPDATE~1\
MSI (c) (34:CC) [07:37:34:331]: Dir (source): Key: ALLUSERSPROFILE , Object: C:\WINDOWS\ccmcache\5b\All Users\ , LongSubPath: All Users\ , ShortSubPath: ALLUSE~1\
Action ended 7:37:34: ResolveSource. Return value 1.
MSI (c) (34:CC) [07:37:34:331]: Doing action: CostFinalize
Action 7:37:34: CostFinalize. Computing space requirements
Action start 7:37:34: CostFinalize.
MSI (c) (34:CC) [07:37:34:332]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI (c) (34:CC) [07:37:34:332]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI (c) (34:CC) [07:37:34:332]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI (c) (34:CC) [07:37:34:332]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI (c) (34:CC) [07:37:34:332]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI (c) (34:CC) [07:37:34:332]: Note: 1: 2262 2: Patch 3: -2147287038
MSI (c) (34:CC) [07:37:34:332]: Note: 1: 2205 2: 3: Condition
MSI (c) (34:CC) [07:37:34:332]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:\'.
MSI (c) (34:CC) [07:37:34:332]: PROPERTY CHANGE: Modifying USERPROFILE property. Its current value is 'C:\Users\jryan-admin'. Its new value: 'C:\Users\jryan-admin\'.
MSI (c) (34:CC) [07:37:34:332]: PROPERTY CHANGE: Adding MACROMED property. Its value is 'C:\WINDOWS\SysWOW64\Macromed\'.
MSI (c) (34:CC) [07:37:34:332]: PROPERTY CHANGE: Adding FLASH property. Its value is 'C:\WINDOWS\SysWOW64\Macromed\Flash\'.
MSI (c) (34:CC) [07:37:34:332]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\WINDOWS\SysWOW64\Macromed\Flash\'.
MSI (c) (34:CC) [07:37:34:332]: PROPERTY CHANGE: Adding ISCommonFilesFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\'.
MSI (c) (34:CC) [07:37:34:332]: PROPERTY CHANGE: Adding ISUpdateServiceFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\UpdateService\'.
MSI (c) (34:CC) [07:37:34:332]: PROPERTY CHANGE: Modifying ALLUSERSPROFILE property. Its current value is 'C:\ProgramData'. Its new value: 'C:\ProgramData\'.
MSI (c) (34:CC) [07:37:34:332]: Target path resolution complete. Dumping Directory table...
MSI (c) (34:CC) [07:37:34:332]: Note: target paths subject to change (via custom actions or browsing)
MSI (c) (34:CC) [07:37:34:332]: Dir (target): Key: TARGETDIR , Object: C:\
MSI (c) (34:CC) [07:37:34:332]: Dir (target): Key: USERPROFILE , Object: C:\Users\jryan-admin\
MSI (c) (34:CC) [07:37:34:332]: Dir (target): Key: TempFolder , Object: C:\Users\JRYAN-~1\AppData\Local\Temp\
MSI (c) (34:CC) [07:37:34:332]: Dir (target): Key: SystemFolder , Object: C:\WINDOWS\SysWOW64\
MSI (c) (34:CC) [07:37:34:332]: Dir (target): Key: MACROMED , Object: C:\WINDOWS\SysWOW64\Macromed\
MSI (c) (34:CC) [07:37:34:332]: Dir (target): Key: FLASH , Object: C:\WINDOWS\SysWOW64\Macromed\Flash\
MSI (c) (34:CC) [07:37:34:332]: Dir (target): Key: INSTALLDIR , Object: C:\WINDOWS\SysWOW64\Macromed\Flash\
MSI (c) (34:CC) [07:37:34:332]: Dir (target): Key: CommonFilesFolder , Object: C:\Program Files (x86)\Common Files\
MSI (c) (34:CC) [07:37:34:332]: Dir (target): Key: ISCommonFilesFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\
MSI (c) (34:CC) [07:37:34:332]: Dir (target): Key: ISUpdateServiceFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
MSI (c) (34:CC) [07:37:34:332]: Dir (target): Key: ALLUSERSPROFILE , Object: C:\ProgramData\
MSI (c) (34:CC) [07:37:34:332]: Note: 1: 2205 2: 3: MsiAssembly
MSI (c) (34:CC) [07:37:34:332]: Note: 1: 2228 2: 3: MsiAssembly 4: SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`, `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
MSI (c) (34:CC) [07:37:34:332]: Note: 1: 2727 2: Flash
Info 2835.The control ErrorIcon was not found on dialog SetupError.
Error 2727.The directory entry 'Flash' does not exist in the Directory table.
MSI (c) (34:CC) [07:37:39:113]: Product: Adobe Flash Player 21 ActiveX -- Error 2727.The directory entry 'Flash' does not exist in the Directory table.
Action ended 7:37:39: CostFinalize. Return value 3.
MSI (c) (34:CC) [07:37:39:114]: Doing action: SetupCompleteError
Action 7:37:39: SetupCompleteError.
Action start 7:37:39: SetupCompleteError.
MSI (c) (34:CC) [07:37:39:115]: Transforming table CustomAction.
Action 7:37:39: SetupCompleteError. Dialog created
MSI (c) (34:B0) [07:37:39:127]: Note: 1: 2731 2: 0
MSI (c) (34:90) [07:37:40:247]: Doing action: ISSetupFilesCleanup
Action 7:37:40: ISSetupFilesCleanup.
Action start 7:37:40: ISSetupFilesCleanup.
MSI (c) (34:90) [07:37:40:247]: Transforming table CustomAction.
MSI (c) (34:B8) [07:37:40:251]: Invoking remote custom action. DLL: C:\Users\JRYAN-~1\AppData\Local\Temp\MSI5365.tmp, Entrypoint: SFCleanupEx
Action ended 7:37:40: ISSetupFilesCleanup. Return value 1.
Action ended 7:37:40: SetupCompleteError. Return value 2.
Action ended 7:37:40: INSTALL. Return value 3.
MSI (c) (34:CC) [07:37:40:307]: Destroying RemoteAPI object.
MSI (c) (34:80) [07:37:40:308]: Custom Action Manager thread ending.
Property(C): DiskPrompt = [1]
Property(C): UpgradeCode = {42463807-970B-4257-BC95-5C348D61DF1C}
Property(C): ProductCode = {92C34178-B679-4C83-AC33-7EFCE6D36E01}
Property(C): PrimaryVolumeSpaceRemaining = 0
Property(C): PrimaryVolumeSpaceRequired = 0
Property(C): PrimaryVolumeSpaceAvailable = 0
Property(C): OutOfNoRbDiskSpace = 0
Property(C): OutOfDiskSpace = 0
Property(C): SourcedirProduct = {92C34178-B679-4C83-AC33-7EFCE6D36E01}
Property(C): VersionNT = 601
Property(C): TARGETDIR = C:\
Property(C): ALLUSERSPROFILE = C:\ProgramData\
Property(C): CommonFilesFolder = C:\Program Files (x86)\Common Files\
Property(C): MACROMED = C:\WINDOWS\SysWOW64\Macromed\
Property(C): FLASH = C:\WINDOWS\SysWOW64\Macromed\Flash\
Property(C): INSTALLDIR = C:\WINDOWS\SysWOW64\Macromed\Flash\
Property(C): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
Property(C): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
Property(C): CostingComplete = 0
Property(C): SystemFolder = C:\WINDOWS\SysWOW64\
Property(C): ROOTDRIVE = C:\
Property(C): SourceDir = C:\WINDOWS\ccmcache\5b\
Property(C): TempFolder = C:\Users\JRYAN-~1\AppData\Local\Temp\
Property(C): USERPROFILE = C:\Users\jryan-admin\
Property(C): IS_MAJOR_UPGRADE = Yes
Property(C): ISSETUPFILESCOMPLETED = Completed
Property(C): EXECUTEACTION = INSTALL
Property(C): ACTION = INSTALL
Property(C): UILevel = 5
Property(C): VersionHandler = 5.00
Property(C): SOURCEDIR = C:\WINDOWS\ccmcache\5b\
Property(C): OriginalDatabase = C:\WINDOWS\ccmcache\5b\install_flash_player_21_active_x.msi
Property(C): DATABASE = C:\WINDOWS\ccmcache\5b\install_flash_player_21_active_x.msi
Property(C): Privileged = 1
Property(C): MsiRunningElevated = 1
Property(C): RedirectedDllSupport = 2
Property(C): MsiWin32AssemblySupport = 6.1.7601.17514
Property(C): MsiNetAssemblySupport = 4.0.30319.1
Property(C): Date = 3/15/2016
Property(C): Time = 7:37:40
Property(C): TTCSupport = 1
Property(C): ColorBits = 32
Property(C): TextInternalLeading = 3
Property(C): PREVIOUS_VERSION = 0
Property(C): ISCHECKFORPRODUCTUPDATES = 0
Property(C): ApplicationUsers = AllUsers
Property(C): AgreeToLicense = Yes
Property(C): _IsMaintenance = Change
Property(C): RestartManagerOption = CloseRestart
Property(C): IS_SQLSERVER_USERNAME = sa
Property(C): IS_SQLSERVER_AUTHENTICATION = 0
Property(C): SetupType = Typical
Property(C): _IsSetupTypeMin = Typical
Property(C): Display_IsBitmapDlg = 1
Property(C): ProductName = Adobe Flash Player 21 ActiveX
Property(C): ALLUSERS = 1
Property(C): ARPHELPLINK = http://www.adobe.com/go/flashplayer_support/
Property(C): ARPNOMODIFY = 1
Property(C): ARPPRODUCTICON = ARPPRODUCTICON.exe
Property(C): ARPURLINFOABOUT = http://www.adobe.com
Property(C): TextHeight = 16
Property(C): ARPURLUPDATEINFO = http://www.adobe.com/go/getflashplayer
Property(C): DWUSINTERVAL = 30
Property(C): DWUSLINK = CECCA75FE9CBA098D9ACE02FFEDB978FBEECA78F69BBE0B8CE8BA7CFE97CF0AFCEBCE08FD9AC
Property(C): DefaultUIFont = Tahoma8
Property(C): DialogCaption = InstallShield for Windows Installer
Property(C): DisplayNameCustom = Custom
Property(C): BorderSide = 1
Property(C): DisplayNameMinimal = Minimal
Property(C): DisplayNameTypical = Typical
Property(C): ErrorDialog = SetupError
Property(C): INSTALLLEVEL = 100
Property(C): ISSCRIPT_VERSION_MISSING = The InstallScript engine is missing from this machine. If available, please run ISScript.msi, or contact your support personnel for further assistance.
Property(C): ISVROOT_PORT_NO = 0
Property(C): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
Property(C): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
Property(C): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
Property(C): IS_PROGMSG_TEXTFILECHANGS_REPLACE = Replacing %s with %s in %s...
Property(C): IS_PROGMSG_XML_COSTING = Costing XML files...
Property(C): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
Property(C): IS_PROGMSG_XML_FILES = Performing XML file changes...
Property(C): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
Property(C): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
Property(C): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
Property(C): InstallChoice = AR
Property(C): Manufacturer = Adobe Systems Incorporated
Property(C): MsiLogging = voicewarmupx
Property(C): NewProperty2 = 0
Property(C): NewProperty3 = 0
Property(C): PIDTemplate = 12345<###-%%%%%%%>@@@@@
Property(C): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
Property(C): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
Property(C): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
Property(C): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
Property(C): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
Property(C): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
Property(C): PROGMSG_IIS_CREATEWEBSITE = Creating IIS website %s
Property(C): PROGMSG_IIS_CREATEWEBSITES = Creating IIS websites...
Property(C): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
Property(C): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
Property(C): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
Property(C): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
Property(C): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
Property(C): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
Property(C): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
Property(C): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
Property(C): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
Property(C): PROGMSG_IIS_REMOVEWEBSITES = Removing IIS websites...
Property(C): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
Property(C): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
Property(C): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
Property(C): ProductID = none
Property(C): ProductLanguage = 1033
Property(C): ProductVersion = 21.0.0.182
Property(C): ProgressType0 = install
Property(C): ProgressType1 = Installing
Property(C): ProgressType2 = installed
Property(C): ProgressType3 = installs
Property(C): RebootYesNo = No
Property(C): ReinstallModeText = omus
Property(C): SHOWLAUNCHPROGRAM = 0
Property(C): SecureCustomProperties = INSTALLDIR;ISACTIONPROP1;ISACTIONPROP2;ISACTIONPROP3;PREVIOUS_VERSION;SUPPORTDIR
Property(C): UNINSTALLER_EXE = [SystemFolder]\Macromed\Flash\uninstall_activeX.exe
Property(C): SETUPEXENAME = setup.exe
Property(C): SUPPORTDIR = C:\Users\JRYAN-~1\AppData\Local\Temp\{92C34178-B679-4C83-AC33-7EFCE6D36E01}
Property(C): BorderTop = 1
Property(C): CaptionHeight = 22
Property(C): ScreenY = 1050
Property(C): AdminUser = 1
Property(C): ScreenX = 1680
Property(C): SystemLanguageID = 1033
Property(C): ComputerName = NYCWKSJRYAN2
Property(C): UserLanguageID = 1033
Property(C): UserSID = S-1-5-21-342624433-1998880279-1947940980-44069
Property(C): LogonUser = jryan-admin
Property(C): MsiTrueAdminUser = 1
Property(C): VirtualMemory = 27181
Property(C): PhysicalMemory = 16341
Property(C): Intel = 6
Property(C): Msix64 = 6
Property(C): MsiAMD64 = 6
Property(C): ShellAdvtSupport = 1
Property(C): OLEAdvtSupport = 1
Property(C): GPTSupport = 1
Property(C): FontsFolder = C:\WINDOWS\Fonts\
Property(C): DesktopFolder = C:\Users\Public\Desktop\
Property(C): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
Property(C): COMPANYNAME = Fortress Investment Group
Property(C): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
Property(C): USERNAME = Fortress Investment Group
Property(C): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
Property(C): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
Property(C): MyPicturesFolder = C:\Users\jryan-admin\Pictures\
Property(C): LocalAppDataFolder = C:\Users\jryan-admin\AppData\Local\
Property(C): CommonAppDataFolder = C:\ProgramData\
Property(C): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
Property(C): SendToFolder = C:\Users\jryan-admin\AppData\Roaming\Microsoft\Windows\SendTo\
Property(C): RecentFolder = C:\Users\jryan-admin\AppData\Roaming\Microsoft\Windows\Recent\
Property(C): PrintHoodFolder = C:\Users\jryan-admin\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
Property(C): PersonalFolder = C:\Users\jryan-admin\Documents\
Property(C): NetHoodFolder = C:\Users\jryan-admin\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
Property(C): FavoritesFolder = C:\Users\jryan-admin\Favorites\
Property(C): AppDataFolder = C:\Users\jryan-admin\AppData\Roaming\
Property(C): CommonFiles64Folder = C:\Program Files\Common Files\
Property(C): ProgramFiles64Folder = C:\Program Files\
Property(C): ProgramFilesFolder = C:\Program Files (x86)\
Property(C): RemoteAdminTS = 1
Property(C): System64Folder = C:\WINDOWS\system32\
Property(C): WindowsVolume = C:\
Property(C): WindowsFolder = C:\WINDOWS\
Property(C): MsiNTProductType = 1
Property(C): ServicePackLevelMinor = 0
Property(C): ServicePackLevel = 1
Property(C): WindowsBuild = 7601
Property(C): VersionNT64 = 601
Property(C): VersionMsi = 5.00
Property(C): VersionDatabase = 110
Property(C): PRODUCTLANGUAGE = 1033
Property(C): MsiSystemRebootPending = 1
Property(C): CLIENTUILEVEL = 0
Property(C): CLIENTPROCESSID = 31796
Property(C): ProductState = 1
Property(C): TRANSFORMS = C:\WINDOWS\Installer\{92C34178-B679-4C83-AC33-7EFCE6D36E01}\active.mst
Property(C): PackageCode = {68B30DE0-0B6D-4EB9-BFC0-D3DC88FF7A37}
Property(C): CURRENTDIRECTORY = C:\WINDOWS\system32
Property(C): MsiLogFileLocation = C:\Users\jryan\Desktop\Flash 21\activex\msi.txt
=== Logging stopped: 3/15/2016 7:37:40 ===
MSI (c) (34:CC) [07:37:40:323]: Grabbed execution mutex.
MSI (c) (34:CC) [07:37:40:323]: Cleaning up uninstalled install packages, if any exist
MSI (c) (34:CC) [07:37:40:325]: MainEngineThread is returning 1603
=== Verbose logging stopped: 3/15/2016 7:37:40 ===
Hello, I realized the MST that was created with the MSI had a mistake in the component table, the row i had added had an incorrect Directory, changed from Flash to 1. I created a new MST, and any PC not touched by the previous MST works well. The only place it doesn't work is the PC that it was tested at, for that PC I ran the EXE but going forward hopefully I find out how that PC can be corrected.
Just to confirm, this is a MST that you created that resulted in the error, yes?
Maria
Yes, it would appear that way but the 2 PCs that i did push that MST to now cannot update using an msi so that "bad" mst somehow corrupted any future msi installs for Flash. The EXE worked ok.
