I am deploying Flash Player 21 together with the uninstallation. Somehow, the silent command "-uninstall" no longer works. Any idea?
Can you share the following details:
1. Which OS you are running on.
2. Which player you are installing i.e. Activex/NPAPI/PPAPI.
3. What type of player you are using .pkg/.dmg in case of MAC and .exe or .msi in case of windows.
4. What version of the flash player is installed which you are trying to uninstall.
5. The file you are using to uninstall silently.
Ridhi
Hi Ridhi,
1. Windows 7 32-bit OS
2. Both ActiveX and PPAPI
3. I was running the uninstall.exe embedded in a vbs script.
4. Adobe Flash Player ver 21.0.0.182. I did not face any issue using when uninstalling previous versions of Flash Player
5. uninstall.exe downloaded from Uninstall Flash Player for Windows
Thanks.
Kath
I tested silent uninstall for all activex, NPAPI and PPAPI. It is working fine for 21.0.182.
Are you running the vbs script as admin?
Could you please share the FlashInstall.log file. The file is saved at the following location:
C:\Windows\System32\Macromed\Flash.
Ridhi
Hi Ridhin, Maria,
I tried running as admin, as well as System by using PSexec.
When running uninstall vbs script, a dialog box popped out:
The FlashInstall.log as below:
016-3-15+6-36-8.555 [error] 1226 1062
=O====== M/21.0.0.182 2016-03-15+06-35-24.527 ========
0000 00000010 "C:\Users\KATHER~1.NUI\AppData\Local\Temp\InstallPlugin_21_0_0_182.exe" -install -msi -prev 0
0001
0002
0003 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0004
0005
0006
0007
0008
0009
0010
0011
0012 00000014
0013 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_21_0_0_182_Plugin.exe
0014 00000024 C:\Windows\system32\Macromed\Flash\plugin.vch
0015 00000017 C:\Windows\system32\Macromed\Flash
0016 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_21_0_0_182.exe
0017 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0018
0019
0020 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0021
0022
0023
0024 00000012
=X====== M/21.0.0.182 2016-03-15+06-36-09.788 ========
Thank you so much.
Kath
The dialogue box in the image will only pop up if you are not executing the command with administrator privileges.
Try out the following:
1.run command prompt as administrator.
2.Execute the command uninstall_flash_player.exe -uninstall.
If the above works fine then your script is unable to execute the command as admin.
Ridhi
What is the exact command-line argument you have in your vbs script? There weren't any significant changes in the uninstaller from the previous version to the current version of the uninstaller (just adding MSI GUIDs for the MSI installer, which happens with every single release). Where there any other changes to your vbs script from the previous version to the current version?
the log file output you posted doesn't contain any uninstall attempt. Is that the contents of the entire FlashInstall.log file? If not, please provide the entire contents. If it's fairly large, upload it to cloud.acrobat.com as per my previous request.
Thank you.
Maria
Are you using Windows or Mac? The -uninstall command only works on Windows.
If you're using Windows, please provide the following:
Thank you.
Maria
