I cannot publish to HTML 5 or the "both" option. Also, It allows me to publish to SWF, and even though I check "view output after publishing", I can't. I'm on the Trial...so is this a limitation of the Trial?
Thank you!
The trial version is only limited to 30 days of functionality. All other features are fully functional.
You say you can't publish to HTML5 or both. What is preventing you from publishing to these outputs? Are they grayed out? Do you get an error?
You can't view SWF output. What happens when the presentation publishes as SWF and it attempts to launch in a web browser? Have you tried going to the published presentation's location and double clicking on the index.html file? Do you get any kind of error messages?
I finally got help from ADOBE...you apparently have to select a theme from
Adobe 10...and it gives me the HTML save option.
However, now, I cannot get a theme to save to my slide show.
Janice
Please make sure that you are not working in compatibility mode format PPT in powerpoint. You have to save your presentation in PPTX format and then you would be able to publish it in HTML5, SWF and both.
Rajeev .
I had this exact problem, plus the quiz radio buttons did not show in the published file and the preview button did not work. I read this and now it works perfectly - thanks!
I am having the same issue. I can't publish to HTML 5 or both. The options are disabled in the publish Window. What do I need to do to enable these features?
You will need to save your presentation as a PPTX file rather than a PPT file.
