We've been having a recurring problem where compiling the
master .chm in our group of help files somehow overwrites the
correct paths in the [MERGE FILES] section of the master's .hhp
file with incorrect paths.
Since the paths point to a "Recovery" copy of our help file
from an apparent crash (pre-dates me), my original assumption is
that, somehow, either a crash or user-error has resulted in
incorrect links being buried somewhere in the main project that
causes this phenomenon. So far, I've been unable to track down a
source.
After posting and reading similar topics, I found a solution
in compiling the main, correcting the now wrong .hhp, and
recompiling. It works, but why exactly the .hhp is overwritten the
first time but not the second is beyond my level of comprehension
(I assume some sort of change activity triggers RH's desire to
overwrite, but I haven't found the culprit).
Regardless, can anyone tell me exactly what or where in RH
this overwrite action is triggered? Or at least what action(s)
cause RH to think the .hhp file needs to be overwritten? Given the
nature of the link it's trying to point at, my assumption remains
that this is somehow still related to the aforementioned crash, and
that somehow an incorrect set of paths has been saved somewhere
and, for whatever reason, RH thinks these are the right paths and
overwrites what's in the existing .hhp file.
When I started here, we were on RH5, but have recently
upgraded and moved our help files to RH7. I've also deleted the
Recovery copy that the .hhp file gets re-pointed to. Neither has
altered this behavior.
