I am unable to see my book in Digital Editions after downloading from the library website. I receive: Error. Check Activation.
When I try to deauthorize and reauthorize, which previously reset Digital Editions, I receive an error Unable to deauthorize, please try again later after entering my password.
I only have 3 days to download this book before it expires, so urgent assistance is appreciated.
Windows:
Close all applications.
Choose Start > Run.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
Select the Adept key.
Choose File > Export.
In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
Right-click the Adept
...Copy link to clipboard
Same problem here too.
It started after I upgraded to the new version. I tried to re-install but keep getting the new version, so that was totally useless.
Please help book expires soon!
Windows:
Choose Start > Run.
Right-click the Adept key and choose Delete.
In the Confirm Key Delete dialog, click OK.
Close the Registry Editor.
Open Adobe Digital Editions and reauthorize.
Macintosh:
quit Adobe Digital Editions.
Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
I have a windows computer.
I tried to follow the steps you provided but in my registry editor there is no registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
Here is a screenshot of what shows up when I open the registry.
You have registry folder HKEY_CURRENT_USER no folder Software with folder Adobe and Folder Adept?
No I don't. All I can see is in that screen shot.
Try clicking on HKEY_CURRENT_USER and you should see the Adobe folder. I was able to complete the steps and successfully download my book. Good luck!
I did. But there is no Adobe Folder there...
Should I close all the programs except the Adobe Digital Editions?
because I didn't run that program as I was doing these steps...
Hi I am facing the same issue, where should i find " Enter a name and location for the backup registry key, and then click Save."
This did not work for me. Please advise!
My issue:
- Can download .asm file from library/overdrive
- Can transfer the book to my ereader via digital editions
- Both my Digital Editions and ereader (Kobo) are authorized with the same email address
- When I try and access the library book, the error says:
"Your eReader is not authorized to open this book. This book is protected by Adobe Digital Rights Management "DRM". Because you previouslydeuahtorized eReader, you need to re-import the book using Adobe Digital Editions":
- I spent 2 hours troubleshooting with Kobo and nothing worked.
Please help!
Just wondering if you found a solution? I am currently having this exact issue having been able to download books no issue for months. I've reset both ADE and the KOBO deleted ADE and redownloaded, nothing has helped.
same problem here
Any resolution other than trashing 2 month old $200 Kobo ?
Fixed it. Thanks a lot for the help!
You are welcome.
I had the same problem as well. It has been happening since I upgraded to Windows 10. This worked great. It was a little difficult to find the Adobe/Adept but I found it evenutally. Thanks.
