Am shifting from a machine that had CF9 on it, then the Splendor Beta, now with CF11 and though I've re-installed CF11 multiple times and have tried various methods I've seen in other threads (including the passwordreset.bat and using localhost) no matter what when I go to the Configuration and Settings Migration Wizard after install to get things going I get "Invalid Password. Please try again." Very aggravating as I'm eager to get rolling with CF11 fully and this is such a goofy roadblock.
We apologize for inconvenience. Why are you still trying Splendor Beta? The full version is available at https://www.adobe.com/cfusion/tdrc/index.cfm?product=coldfusion Can you try that?
Anit Kumar
No, this is a problem I'm having with CF11 proper, didn't have any such problems with the Splendor Beta.
Here are possible workarounds, you may try:-
Note:- Enabling internal/built port would require a ColdFusion Application Server restart.
The possible reason of this behavior is the CFID and CFTOKEN getting changed from the request start to request end. To find the cause, you can try running Charles Tool and follow the below steps:-
Hope this helps
Anit Kumar
I tried with chrome from remote computer using the built in server on port and didn't work. I changed the port number and didn't work. CFID CFTOKEN behavior is normal, so that can't be it. I uninstalled and reinstalled and that didn't work either.
So as of right now, I can't setup my server. I'm going to try to reinstall using the default admin username and some easy password.
The issue is happening because of mime type (.air) entry specified in the web.config of the webroot. Can you try the following steps:-
Commenting out the .air type in site specific web.config file has resolved the issue.
Note:- This would work fine in all the browsers except Internet Explorer. This is because of the Internet Explorer's enhanced security mode. JavaScript gets executed only when the website is listed in trusted sites. Adding the ColdFusion website to the trusted sites list would let you login succesfully.
Anit Kumar
As a stop-gap, we were able to get in using the following method:
1. Go to ColdFusion11\cfusio\lib\neo-security.xml and set the admin.security.enabled variable to false
2. Restart the CF Service
3. Go back to CF Admin
Hope that helps.
Neal
This seemed to have resolve the issue in Windows 8.1:
1. Installed the platform installer for IIS
2. Installed the IIS static content component
Neal
This was driving me crazy. Installing IIS static content fixed it for me.
Thanks nealb‌ - installing IIS Static Content worked for me too. I should have realized when there were assets (images/css) missing from the CF login page.
Could you please go to cfusion >> lib folder and open the adminconfig.xml and change the value of <runsetupwizard> to false. Save the file and try login in the admin page again.
