1. Re: Ray tracing on the CPU requires and approved NVIDIA graphic card and CUDA 5.0 or later. For now, ray-tracing will use the CPU.
mauricep27921461 Mar 23, 2016 2:11 PM (in response to Veryle Rupp)Hi Veryle Rupp,
you have a GPU that is not supported by the ray-traced 3D renderer of After Effects. Here's a list of supported GPUs:
» Supported GPUs for After Effects' ray-traced 3D renderer
However: inside AE, go to Edit > Preferences > Previews and select 'GPU Information'. Check the box that says
"Enable untested, unsupported GPU for CUDA acceleration of ray-traced 3D render." and set "Ray-tracing to GPU
(unsupported)"Kind Regards,
MauriceWas this answer helpful? Please consider marking it as "Helpful" and/or "Correct Answer" to help future customers with the same problem. Thank you!
3. Re: Ray tracing on the CPU requires and approved NVIDIA graphic card and CUDA 5.0 or later. For now, ray-tracing will use the CPU.
Szalam Mar 24, 2016 8:34 AM (in response to Veryle Rupp)1 person found this helpfulThat message is only letting you know that one (obsolete) effect will not be accelerated by your current hardware setup.
This is no big deal. You can feel free to tick the box that says not to show that message anymore. The ray-traced renderer was an old way to create 3d geometry inside of After Effects. We have a much more powerful option now.
