A few days ago the borrowed e-books in the adobe digital library suddenly disappeared. Since then, whenever I try to transfer an borrowed e-book to my kobo nothing happens. Everything freezes. I have to restart my pc after taking out the battery to be able to access other sites. What is happening?
I finally had ADE running by deleting every file connected to it and starting over. Thank you for your help.
Right Click on Digital Edition and Run as admin. Then try to move to the Reader.
Run as administrator did not work. The book that was in the bookshelf disappeared.
Error with different eBooks? If not know check it with this: http://www.adobe.com/solutions/ebook/digital-editions/sample-ebook-library.html
Adobe digital freezes with all books I try to transfer. The books appear on the bookshelf but it is as far I can go. I then have to restart the computer to close Adobe digital or else it will run indefinitely.
Have you check if your reader have enough space. Have the same error as my reader has no more space.
I am positive that I have enough space in my e-reader. I downloaded ADE on another computer and the screen was at it should be. Why is my computer not accepting ADE all of a sudden?
Can not say exactly. Try this:
Closed the Digital Edition. Disconnect the Reader.
Rename My Digital Edition under My Documents in My Digital Edition.old.
Restart your System.
Start Digital Edition.
Download the eBook new.
And connect the Reader with the Device.
Then try to move the file to the Reader.
You are welcome.
