HI,
I have 2 computers but when I try to login with my adobe ID on the second, it says that my ID is already used. I thought we could use the same ID on several computers?
Windows:
Close all applications.
Choose Start > Run.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
Select the Adept key.
Choose File > Export.
In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
Right-click the Adept key and choose Delete.
In the Confirm Key Delete dialog, click OK.
Close the Registry Editor.
Open Adobe Digital Editions and reauthorize.
Macintosh:
quit Adobe Digital Editions.
Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
Hello, thanks for your detailed answer. I am not sure how this helps me ( I am not so so good with computers). On my second computers, I had not registered with any key, I had registered anonymously. So when i try the manipulation you mentioned, there is no key.
Has you make it on the device how you get the error?
you mean, when i try to authorise my computer? I get a message telling me that I cannot use an ID that i already used on another computer
No, i ask if you try the steps on the meschine how get the error.
