I migrated my project to Robohelp 2015 from version 9, In PDF generated files Images are truncating , Please help ?
Not sure but first does this also occur if you only generate to Word and do not create a PDF as well?
If that is OK, then try generating the PDF from the Word document. OK then?
Hi Peter,
This problem coming in Word too, I recently migrated to latest Robo help version and since then I am blocked, can not do anything furthur
Deep S.
Please recreate the problem in a one or two topic demo project. See the Contact page on my site and send the project as instructed there. Do make sure you include a link to this thread and please do not email the project direct.
Hey
Sorry for this trivial question, Where do I find the demo project, I am new to this world so not really aware of
Thanks in Advance
Deep S.
Go to File / Open and see Samples on the left.
Hi Peter,
Deep S.
Is it possible for you to provide files so that we can try replicating the issue at our end?
~Abhishek
HI All
Thanks for your input, I have created a demo project but still struggling to send , I am posting the images , Please see, If that helps in understanding the question
Below is the Sample Project, I have created in Robo Help 2015
From above Project, when I generated PDF File, Image and text is Truncating as seen in below images, Same is happening in Word File
The reason is quite simple and I'm sorry I didn't pick up on it sooner.
For printed documents (Word or PDF) you must limit your image size to the width of a piece of paper as the image will not be scaled down. Scalle them to about 7.5 inches to allow for margins and try again.
There are two ways in RoboHelp.
SnagIt is a third party tool and considered the best by many. That enables you scale and also remove blank space from an image both vertically and horizontally. That way you avoid resizing text and other parts of an image, you just lose the blank space.
Has my reply above resolved the matter for you?
See www.grainge.org for RoboHelp and Authoring information
Hi Peter
Thanks for the reply, I got the partial resolution of the problem, I have 500 + pages and more then 1000 images which used to work correctly on Robo Help 9
Resizing the image on 500 + pages is going to be a big task
Could there be any other way around where I do not need to resize the images after migration to Robo Help 2015
Deep S.
No answer that I am aware of without hacking around. You are saying that these wide images printed OK in Word before RoboHelp 2015, correct? I'm surprised as it's a problem I have experienced with all versions.
