In Reading -> PDF View there is no selection for showing 2 pages simultaneously. Is it possible? If not, does anybody know if there are any plans for it?
To solved the Problem should ask in Adobe Reader or Acrobat Forum. This Forum only for Digital Edition.
As far as I can see, it is a problem with Adobe Digital Editions. When using Adobe Reader to look into normal pdf-files I have no problem at all showing 2 pages simultaneously. In Digital Editions choosing "Reading->PDF View" there is no such alternative. How come you think that I would get an answer from an Adobe Reader forum regarding menu selections in Digital Editions? Is there a way to switch from Digital Editions so that I can look into the book as if it is a pdf-file?
Digital Edition has no such a function.
I agree it is not currently available, the question is can this be changed? Is there a suggestion box for the product developers?
The only which i can found is Feature Request/Bug Report Form
Should check if you can a point for Digital Edition.
