I need to make context-sensitive help on the application level..I mean pressing F1 anywhere in the application to open the help file (showing all topics) as whole.
Participant ,
Mar 29, 2016 Mar 29, 2016
I can't do window-level help due to time limitation. Do I need to assign IDs in this case & how to link all topics?
491
Do you want to display a different topic each time you press F1 in the application? If so, then you need to do CSH & play with it so that it launches the full TOC, Search, etc; if not, then just launch the index page of your help output.
Participant ,
No, I don't need it for each topic. But, I need to make the Help file accessible by pressing F1 anywhere in the application. Please I don't get what do you mean by launching index page?
What kind of help output are you generating?
Participant ,
I have already generated Responsive HTML5 help file and published in the app, but I need to add F1 accessibility.
Apr 11, 2016 Apr 11, 2016
What you need, depends on how you want to get it done. The application can call topics directly, but if your topic is moved or renamed, the application will have to be updated. With map ID's, you avoid this issue by adding an extra layer that separates the CSH call from your topic structure.
Please see Context Sensitivity in Responsive and Multiscreen HTML5 | WvanWeelden.eu for more (technical) information on your options.
Participant ,
Apr 12, 2016 Apr 12, 2016
In this case, the application will recall by map file or by IDs? as we have no help on the window-level.
No, you just want to launch the index html page - when you generated your help, you indicated a start page - it's usually called index.htm. Just have your app invoke that URL. If you want fancier ways for your developer to call RH (C++, VB, .NET, etc.), see the CSH methods in your RH installation directory.
RoboHelp Documentation
Download Adobe RoboHelp
