I can't do window-level help due to time limitation. Do I need to assign IDs in this case & how to link all topics?
Do you want to display a different topic each time you press F1 in the application? If so, then you need to do CSH & play with it so that it launches the full TOC, Search, etc; if not, then just launch the index page of your help output.
No, I don't need it for each topic. But, I need to make the Help file accessible by pressing F1 anywhere in the application. Please I don't get what do you mean by launching index page?
What kind of help output are you generating?
I have already generated Responsive HTML5 help file and published in the app, but I need to add F1 accessibility.
What you need, depends on how you want to get it done. The application can call topics directly, but if your topic is moved or renamed, the application will have to be updated. With map ID's, you avoid this issue by adding an extra layer that separates the CSH call from your topic structure.
Please see Context Sensitivity in Responsive and Multiscreen HTML5 | WvanWeelden.eu for more (technical) information on your options.
In this case, the application will recall by map file or by IDs? as we have no help on the window-level.
No, you just want to launch the index html page - when you generated your help, you indicated a start page - it's usually called index.htm. Just have your app invoke that URL. If you want fancier ways for your developer to call RH (C++, VB, .NET, etc.), see the CSH methods in your RH installation directory.
