lose mapid when a file is imported
Mar 29, 2016 Mar 29, 2016
I'm breaking out a very large project into smaller projects. When I import files that have mapID's assigned they are all gone from the context sensitive help file. We have the clear cpd file enabled would that be causing any issues?
311
Mar 30, 2016 Mar 30, 2016
I'm not sure without checking that the map ids will import. However, I can say it will not be anything to do with deleting the CPD file.
@petergrainge
Apr 07, 2016 Apr 07, 2016
So there is nothing I can do to import the MapID's??? I have hundreds I would have to reassign!
Apr 08, 2016 Apr 08, 2016
It's worth noting that when you use the RoboHelp Edit Map IDs dialog to map topics, what you are actually doing is to modify the contents of a small text file that stores the association between the topic and the ID number. To my knowledge, nothing whatsoever is changed in the topic itself.
So if you take that topic and import it into a different project, how is the destination project supposed to be aware of the mapping?
Have you tried importing the Map file into the project? Perhaps that's your answer.
Cheers... Rick
Apr 11, 2016 Apr 11, 2016
And if your topic structure is the same, you can also overwrite the *.ali file in the project. That will restore the link between map numbers and topics.
RoboHelp Documentation
Download Adobe RoboHelp
