dell precision t3500, win7 ultimate,using AFP 21.
Why do I have to always install AFP 21 everytime I browse the web? It is suppose to be a ONE-time INSTALL.
pls. help.
What browser is this on?
Maria
browser is IE 11
but when I use GOOGLE chrome, it has a built-in flash player & a built-in pdf viewer.
Pls. help me resolve this. I know I can always just use google chrome, but
at times I need to use IE 11
thanks for your reply.
Please ensure you have Flash Player enabled and ActiveX Filtering disabled. See Enable Flash Player for Internet Explorer and ActiveX Filtering in Internet Explorer.
If Flash Player is enabled and ActiveX Filter is disabled, please provide the FlashInstall.log file to troubleshoot further. The file is saved at the following location:
Upload the file(s) to cloud.acrobat.com using the instructions How to share a document or to some other file sharing service of your choice that doesn't require a log-in to access. Post the link to the uploaded file(s) in your reply.
Maria
flash player - enabled in IE
active x filtering - disabled in IE
I have taken a picture of the FLASH INSTALL.LOG in the locations
u have indicated namely in location system 32 & syswow64.
however, do u have an email so that I can attach the scanned PDF &
show you the contents of this 2 locations:
thanks.
<deleted email address>
While a screenshot of the directory is nice, I need the actual log files. Please upload the previously requested log files to cloud.acrobat.com using the instructions at How to share a document
Also, these are public forums, posting your personal email address is not advised as it'll welcome much unwanted spam, as such, I have removed your email address from your post.
Maria
I need the actual FlashInstall.log file to troubleshoot further. The directory screenshots do show Flash Player is installed, but the log files will indicate if it's installed successfully or not. I've highlighted the two log files in the screenshots you provided. Please upload these two log files to cloud.acrobat.com and post the link your reply.
Thank you.
Maria
hi, maria,
I'm getting ACCESS DENIED message after clicking & trying to open FLASHINSTALL in system 32 &
syswow64, how do I proceed
Do you have administrator rights on the computer? If not, you may need to ask for help from someone that does.
If you do, it sounds like the filesystem is corrupted, which would explain a lot about the weird behavior you're experiencing.
Before you mess with the filesystem, ensuring your backups are in order is wise. Disk corruption can often be an early warning sign of impending hardware failure, and giving the disk a good workout might push it over the edge. Better to be safe than sorry on that front.
Check your hard disk for errors - Windows 7:
https://support.microsoft.com/en-us/kb/2641432
Once you've repaired any problems with the disk, uninstall the player, download a fresh copy and then run the installer again.
Uninstall Flash Player - Windows:
https://helpx.adobe.com/flash-player/kb/uninstall-flash-player-windows.html
Download a new copy of the installer here:
hello Jerome,
yes, I do have admin rights to this PC?
In fact, that was the INITIAL step that I had to do bec.
I was likewise having admin problems w/ ADOBE acrobat pro.
but I will contact Dell again for this problem.
then will get back at you.
thanks.
martin
I have the logfile for the sys32, but then I still get a "access denied" message when trying to view the log file
in sysWOW64, I contacted dell for this.
so here it is.
=O====== M/11.0.1.152 2011-10-16+05-50-34.765 ========
0000 00000010 "C:\Users\LILLIAN'S MARTIN\AppData\Local\Temp\install_flash_player_ax_64bit.exe" -dlm -install
0001 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
0002 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0003 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0004 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0005 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
0006 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_0_1.ocx
0007 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_0_1_ActiveX.exe
0008 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_0_1_ActiveX.dll
0009 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0010 00000011 1
=X====== M/11.0.1.152 2011-10-16+05-50-37.940 ========
=O====== M/11.0.1.152 2011-10-25+17-39-09.011 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\BB92.dir\InstallFlashPlayer.exe" -iv 6
0001 00001039
=X====== M/11.0.1.152 2011-10-25+17-39-30.914 ========
=O====== M/11.1.102.55 2011-12-26+16-40-39.451 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\2B05.dir\InstallFlashPlayer.exe" -iv 6
0001 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0002 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_1_102.ocx
0003 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_1_102_ActiveX.exe
0004 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_1_102_ActiveX.dll
0005 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0006 00000011 1
=X====== M/11.1.102.55 2011-12-26+16-40-49.825 ========
=O====== M/11.1.102.55 2012-01-04+18-54-23.302 ========
0001 00001041
=X====== M/11.1.102.55 2012-01-04+18-54-23.421 ========
=O====== M/11.1.102.55 2012-01-04+18-54-36.067 ========
0003 00001024 C:\Windows\system32\Macromed\Flash\Flash64_11_1_102.ocx 183
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_1_102_ActiveX.exe
0005 00001024 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_1_102_ActiveX.exe 183
0006 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_1_102_ActiveX.dll
0007 00001024 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_1_102_ActiveX.dll 183
0008 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0009 00000011 1
=X====== M/11.1.102.55 2012-01-04+18-54-39.218 ========
=O====== M/11.1.102.55 2012-01-10+05-59-42.120 ========
0000 00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil64_11_1_102_ActiveX.exe" -maintain activex
0001 00001039
=X====== M/11.1.102.55 2012-01-10+05-59-48.704 ========
=O====== M/11.1.102.55 2012-01-10+06-00-35.815 ========
0001 00001041
=X====== M/11.1.102.55 2012-01-10+06-00-35.956 ========
=O====== M/11.1.102.55 2012-01-10+06-00-45.484 ========
0009 00000011 1
=X====== M/11.1.102.55 2012-01-10+06-00-48.208 ========
=O====== M/11.1.102.55 2012-01-10+06-04-37.890 ========
0001 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_1_102_ActiveX.exe 5
0002 00000018
0003 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_1_102_ActiveX.exe 5
0004 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
0005 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
0006 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
0007 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
0008 00001037 Software\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
0009 00001021
0010 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0011 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0012 00000011 1
0013 00000012
=X====== M/11.1.102.55 2012-01-10+06-04-44.817 ========
=O====== M/11.1.102.55 2012-01-10+06-10-08.956 ========
0001 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0002 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0003 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
0004 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_1_102.ocx
0005 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_1_102_ActiveX.exe
0007 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0008 00000011 1
=X====== M/11.1.102.55 2012-01-10+06-10-11.213 ========
=O====== M/11.1.102.55 2012-01-14+22-23-03.104 ========
0001 00001041
=X====== M/11.1.102.55 2012-01-14+22-23-03.227 ========
=O====== M/11.1.102.55 2012-01-14+22-23-12.032 ========
0009 00000011 1
=X====== M/11.1.102.55 2012-01-14+22-23-14.778 ========
=O====== M/11.1.102.55 2012-01-20+22-05-28.236 ========
0001 00001041
=X====== M/11.1.102.55 2012-01-20+22-05-28.384 ========
=O====== M/11.1.102.55 2012-01-20+22-05-30.604 ========
0001 00001041
=X====== M/11.1.102.55 2012-01-20+22-05-30.741 ========
=O====== M/11.1.102.55 2012-01-20+22-05-32.594 ========
0001 00001041
=X====== M/11.1.102.55 2012-01-20+22-05-32.754 ========
=O====== M/11.1.102.55 2012-01-20+22-05-37.290 ========
0009 00000011 1
=X====== M/11.1.102.55 2012-01-20+22-05-40.540 ========
=O====== M/11.1.102.55 2012-02-05+15-26-43.599 ========
0001 00001041
=X====== M/11.1.102.55 2012-02-05+15-26-43.715 ========
=O====== M/11.1.102.55 2012-02-05+15-26-58.222 ========
0009 00000011 1
=X====== M/11.1.102.55 2012-02-05+15-27-03.038 ========
=O====== M/11.2.202.228 2012-03-30+22-32-30.626 ========
0000 00000010 "C:\Users\LILLIAN'S MARTIN\AppData\Local\Temp\install_flash_player_ax_64bit.exe" -iv 8 -install -au 0
0002 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_2_202_228.ocx
0003 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_2_202_228_ActiveX.exe
0004 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_2_202_228_ActiveX.dll
0006 00000011 1
0007 00000012
=X====== M/11.2.202.228 2012-03-30+22-32-37.154 ========
=O====== M/11.2.202.233 2012-04-14+00-55-07.168 ========
0000 00000010 FlashPlayerInstaller.exe -install -iv 9
0002 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_2_202_233.ocx
0003 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_2_202_233_ActiveX.exe
0004 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_2_202_233_ActiveX.dll
0006 00000011 1
0007 00000012
=X====== M/11.2.202.233 2012-04-14+00-55-14.874 ========
=O====== M/11.2.202.235 2012-05-13+15-55-14.078 ========
0002 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_2_202_235.ocx
0003 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_2_202_235_ActiveX.exe
0004 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_2_202_235_ActiveX.dll
0006 00000011 1
0007 00000012
=X====== M/11.2.202.235 2012-05-13+15-55-33.001 ========
=O====== M/11.2.202.235 2012-06-02+17-15-03.605 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{38D0F30A-272B-4E7D-8E19-4351214F06E7}\InstallFlashPlayer.exe" -iv 6
0006 00000011 1
0007 00000012
=X====== M/11.2.202.235 2012-06-02+17-16-01.185 ========
=O====== M/11.3.300.257 2012-06-28+12-34-17.034 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{F3B881F7-4445-468B-977C-7912CE448A6D}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 0
0002 00001037 SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options
FlashUtil64_11_2_202_235_ActiveX.exe/ 2
0003 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_3_300_257.ocx
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_257_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_257_ActiveX.dll
0006 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0007 00000012
=X====== M/11.3.300.257 2012-06-28+12-34-18.265 ========
=O====== M/11.3.300.257 2012-07-01+18-19-09.394 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{7B2F2D8B-722C-437C-A42E-82197129FA14}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 0
0002 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
0007 00000012
=X====== M/11.3.300.257 2012-07-01+18-19-10.551 ========
=O====== M/11.3.300.257 2012-07-01+18-20-42.990 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{514F27C7-0583-4957-BD7F-2119ABECE06D}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 0
0007 00000012
=X====== M/11.3.300.257 2012-07-01+18-20-43.799 ========
=O====== M/11.3.300.257 2012-07-01+18-25-33.196 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{3376822C-E59A-48E0-AFD1-8299078DE4DE}\InstallFlashPlayer.exe" -uninstall activex
0001 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
0002 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
0003 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
0004 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
0005 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
0006 00001037 Software\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
0007 00001021
0008 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0009 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0012 00001037 SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options
FlashPlayerApp.exe/ 2
0013 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
0014 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0015 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
=X====== M/11.3.300.257 2012-07-01+18-25-33.914 ========
=O====== M/11.3.300.257 2012-07-08+00-16-08.492 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{E2659F7E-C61B-4A44-B173-01613DAD2A1D}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 1
0003 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0004 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
0005 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_3_300_257.ocx
0006 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_257_ActiveX.exe
0007 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_257_ActiveX.dll
0009 00000012
=X====== M/11.3.300.257 2012-07-08+00-16-09.522 ========
=O====== M/11.3.300.262 2012-07-08+00-17-24.758 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{5C5B3A12-1411-4BE8-AD9C-A8909D3FCD72}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 1
0001 00001036 Software\Macromedia\FlashPlayerPlugin/Version 2
0002 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0004 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
0005 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
0006 00001036 Software\Mozilla\MaintenanceService\extensions/Plugins 2
0007 00001036 Software\Opera Software/Last CommandLine 2
0008 00001036 Software\Opera Software/Last CommandLine 2
0009 00001036 Software\Opera Software/Plugin Path 2
0010 00001036 Software\Opera Software/Plugin Path 2
0011 00000014 C:\Windows\system32\Macromed\Flash\NPSWF64_11_3_300_262.dll
0012 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_262_Plugin.exe
0013 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0014 00000012
=X====== M/11.3.300.262 2012-07-08+00-17-25.258 ========
=O====== M/11.5.502.146 2013-02-01+16-49-29.741 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{555F3A9A-915E-4315-AD03-1841AEA9AD51}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 0
0003 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_5_502_146.ocx
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_5_502_146_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_5_502_146_ActiveX.dll
0006 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0008 00000012
=X====== M/11.5.502.146 2013-02-01+16-49-31.558 ========
=O====== M/11.5.502.146 2013-02-01+16-58-55.641 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{D8FC21A7-620F-42C1-87AF-2EFD3B1FB997}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 6 -au 4294967295
0008 00000012
=X====== M/11.5.502.146 2013-02-01+16-58-59.183 ========
=O====== M/11.5.502.146 2013-02-01+17-02-19.005 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{3C188F34-7617-48A8-A724-9EBB0BBF8009}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 4294967295
0008 00000012
=X====== M/11.5.502.146 2013-02-01+17-02-21.061 ========
=O====== M/11.5.502.146 2013-02-01+17-03-20.400 ========
0000 00000010 "C:\Windows\TEMP\{A93E772F-71AA-4E5A-AE87-029CF9F78EA8}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0002 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
0003 00001036 Software\Mozilla\MaintenanceService\extensions/Plugins 2
0004 00001036 Software\Opera Software/Last CommandLine 2
0005 00001036 Software\Opera Software/Last CommandLine 2
0006 00001036 Software\Opera Software/Plugin Path 2
0007 00001036 Software\Opera Software/Plugin Path 2
0008 00000014 C:\Windows\system32\Macromed\Flash\NPSWF64_11_5_502_146.dll
0009 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_5_502_146_Plugin.exe
0010 00000024 C:\Windows\system32\Macromed\Flash\plugin.vch
0011 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0012 00000012
=X====== M/11.5.502.146 2013-02-01+17-03-24.288 ========
=O====== M/11.5.502.146 2013-02-07+07-50-40.861 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{A7797A90-0336-4EB8-9968-02E7923DE4C0}\InstallFlashPlayer.exe" -uninstall plugin
0001 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
0003 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
0006 00001021
0007 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0008 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0010 00001036 Software\Mozilla\MaintenanceService\extensions/Plugins 2
0011 00001036 Software\Opera Software/Last CommandLine 2
0012 00001036 Software\Opera Software/Last CommandLine 2
0013 00001036 Software\Opera Software/Plugin Path 2
0014 00001036 Software\Opera Software/Plugin Path 2
=X====== M/11.5.502.146 2013-02-07+07-50-41.111 ========
=O====== M/11.5.502.146 2013-02-07+07-50-55.633 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{A39272A3-6533-4C32-9A4B-1306A6668F0C}\InstallFlashPlayer.exe" -uninstall activex
0007 00001021
=X====== M/11.5.502.146 2013-02-07+07-50-55.727 ========
=O====== M/11.5.502.146 2013-02-07+15-49-33.535 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{AB030500-1613-48BB-BFCA-BEB15359EE5D}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 0
0005 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_5_502_146.ocx
0006 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_5_502_146_ActiveX.exe
0007 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_5_502_146_ActiveX.dll
0008 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0010 00000012
=X====== M/11.5.502.146 2013-02-07+15-49-34.873 ========
=O====== M/11.5.502.149 2013-02-09+19-41-52.035 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{3242C4E4-8D14-4B51-86AF-ACB1CBD9D47C}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 4294967295
0003 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_5_502_149.ocx
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_5_502_149_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_5_502_149_ActiveX.dll
0008 00000012
=X====== M/11.5.502.149 2013-02-09+19-41-53.784 ========
=O====== M/11.5.502.149 2013-02-09+19-52-08.675 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{BD644D68-1FF7-40E7-A134-EB46BAF24550}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 4294967295
0008 00000012
=X====== M/11.5.502.149 2013-02-09+19-52-11.949 ========
=O====== M/11.5.502.149 2013-02-09+19-54-32.141 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{801B3856-B76C-48A3-B8BD-6285EDDF7290}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 0
0011 00000014 C:\Windows\system32\Macromed\Flash\NPSWF64_11_5_502_149.dll
0012 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_5_502_149_Plugin.exe
0013 00000024 C:\Windows\system32\Macromed\Flash\plugin.vch
0014 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0015 00000012
=X====== M/11.5.502.149 2013-02-09+19-54-33.140 ========
=O====== M/11.5.502.149 2013-02-10+22-59-39.833 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{ED34ECD6-884F-4AF0-AEF0-B85C7B9D1D2B}\InstallFlashPlayer.exe" -uninstall activex
0007 00001021
0009 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
=X====== M/11.5.502.149 2013-02-10+22-59-40.566 ========
=O====== M/11.6.602.168 2013-02-14+17-15-53.389 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{40C8612D-CD27-4C14-8FF0-0EB5311BCF38}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 0
0005 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_6_602_168.ocx
0006 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_168_ActiveX.exe
0007 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_168_ActiveX.dll
0010 00000012
=X====== M/11.6.602.168 2013-02-14+17-15-54.759 ========
=O====== M/11.6.602.168 2013-02-14+22-25-46.006 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{5BAF3D9D-9744-4478-9CA9-E4DB1D9EF193}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 4294967295
0003 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_6_602_168.ocx
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_168_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_168_ActiveX.dll
0008 00000012
=X====== M/11.6.602.168 2013-02-14+22-25-49.857 ========
=O====== M/11.6.602.168 2013-02-15+07-10-28.978 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{89ABFA42-B587-43F9-8FFF-846646812008}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 4294967295
0008 00000012
=X====== M/11.6.602.168 2013-02-15+07-10-31.490 ========
=O====== M/11.6.602.171 2013-02-27+00-54-26.639 ========
0000 00000010 "C:\Windows\TEMP\{E0780D22-7970-48EA-8139-679D1B422DAC}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0003 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_6_602_171.ocx
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_171_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_171_ActiveX.dll
0008 00000012
=X====== M/11.6.602.171 2013-02-27+00-54-36.265 ========
=O====== M/11.6.602.171 2013-02-28+19-58-17.047 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{032BACAE-EB22-4639-96F8-A9241E7887DD}\InstallFlashPlayer.exe" -uninstall activex
0007 00001021
=X====== M/11.6.602.171 2013-02-28+19-58-17.437 ========
=O====== M/11.6.602.171 2013-02-28+20-03-54.365 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{A8EB33F5-4775-42CF-8304-D3C2254A528D}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 1
0005 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_6_602_171.ocx
0006 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_171_ActiveX.exe
0007 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_171_ActiveX.dll
0010 00000012
=X====== M/11.6.602.171 2013-02-28+20-03-56.506 ========
=O====== M/11.6.602.171 2013-03-07+01-28-51.373 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{0F4FCE78-DBC8-463C-8F77-D056900ECAC6}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 0
0008 00000014 C:\Windows\system32\Macromed\Flash\NPSWF64_11_6_602_171.dll
0009 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_171_Plugin.exe
0012 00000012
=X====== M/11.6.602.171 2013-03-07+01-28-52.561 ========
=O====== M/11.6.602.171 2013-03-07+01-30-29.777 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{CE0D195E-DBA2-4CCE-9A4B-81EFE2E0C41A}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 4294967295
0012 00000012
=X====== M/11.6.602.171 2013-03-07+01-30-30.783 ========
=O====== M/11.6.602.180 2013-03-13+17-19-15.012 ========
0000 00000010 "C:\Windows\TEMP\{1984871F-95F5-491E-BB86-9A929AE8DD04}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0003 00001015 C:\Windows\system32\Macromed\Flash\Flash64_11_6_602_171.ocx 5
0004 00000018
0005 00001015 C:\Windows\system32\Macromed\Flash\Flash64_11_6_602_171.ocx 5
0006 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_6_602_180.ocx
0007 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_180_ActiveX.exe
0008 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_180_ActiveX.dll
0009 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0010 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0011 00000012
=X====== M/11.6.602.180 2013-03-13+17-19-16.806 ========
=O====== M/11.6.602.180 2013-03-14+01-19-09.789 ========
0000 00000010 "C:\Windows\TEMP\{8F0CC6D3-3897-4A0C-BEEE-CB73D1338064}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0008 00000014 C:\Windows\system32\Macromed\Flash\NPSWF64_11_6_602_180.dll
0009 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_180_Plugin.exe
0012 00000012
=X====== M/11.6.602.180 2013-03-14+01-19-11.068 ========
=O====== M/11.6.602.180 2013-03-29+17-36-52.210 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{57641B56-FA47-442F-9405-D05B0971D5CE}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 4294967295
0003 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_6_602_180.ocx
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_180_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_180_ActiveX.dll
0008 00000012
=X====== M/11.6.602.180 2013-03-29+17-36-53.565 ========
=O====== M/11.6.602.180 2013-04-03+23-45-09.408 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{E90DA7AD-4D95-48CA-B331-3BDE6A803006}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 4294967295
0008 00000012
=X====== M/11.6.602.180 2013-04-03+23-45-10.968 ========
=O====== M/11.7.700.169 2013-04-19+00-00-00.099 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{A55CA306-27A9-470D-9BB9-319776BE995A}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 4294967295
0003 00001015 C:\Windows\system32\Macromed\Flash\Flash64_11_6_602_180.ocx 5
0004 00000018
0005 00001015 C:\Windows\system32\Macromed\Flash\Flash64_11_6_602_180.ocx 5
0006 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_7_700_169.ocx
0007 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_169_ActiveX.exe
0008 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_169_ActiveX.dll
0011 00000012
=X====== M/11.7.700.169 2013-04-19+00-00-01.630 ========
=O====== M/11.7.700.169 2013-04-26+01-07-38.515 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{DB558C6D-C238-4B06-A41F-A3889DFAF6A2}\InstallFlashPlayer.exe" -uninstall activex
0007 00001021
=X====== M/11.7.700.169 2013-04-26+01-07-38.671 ========
=O====== M/11.6.602.180 2013-04-26+01-07-52.801 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{2F4BDB53-C3D6-49E3-A86A-AC6DBE1D74CC}\InstallFlashPlayer.exe" -uninstall plugin
0006 00001021
0007 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0010 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0011 00001037 SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options
0012 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
0013 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0014 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0015 00001036 Software\Mozilla\MaintenanceService\extensions/Plugins 2
0016 00001036 Software\Opera Software/Last CommandLine 2
0017 00001036 Software\Opera Software/Last CommandLine 2
0018 00001036 Software\Opera Software/Plugin Path 2
0019 00001036 Software\Opera Software/Plugin Path 2
=X====== M/11.6.602.180 2013-04-26+01-07-52.910 ========
=O====== M/11.7.700.169 2013-05-03+20-39-17.945 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{78BCC308-FA06-47BA-8DF1-CBE0B248E65C}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 0
0005 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_7_700_169.ocx
0006 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_169_ActiveX.exe
0007 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_169_ActiveX.dll
0010 00000012
=X====== M/11.7.700.169 2013-05-03+20-39-20.227 ========
=O====== M/11.7.700.169 2013-05-03+20-43-50.080 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{A861B639-8AFD-4440-8093-D003380F197E}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 4294967295
0003 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_7_700_169.ocx
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_169_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_169_ActiveX.dll
0008 00000012
=X====== M/11.7.700.169 2013-05-03+20-43-51.629 ========
=O====== M/11.7.700.169 2013-05-03+21-41-54.772 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{875BB304-18B0-4F9D-A7F2-AD4116CA73E4}\InstallFlashPlayer.exe" -uninstall activex
0007 00001021
=X====== M/11.7.700.169 2013-05-03+21-41-54.834 ========
=O====== M/11.7.700.169 2013-05-03+21-47-05.019 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{462E6F8B-3372-4555-A1F4-AF84CD38C6B1}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 0
0010 00000012
=X====== M/11.7.700.169 2013-05-03+21-47-06.518 ========
=O====== M/11.7.700.202 2013-05-15+15-09-05.703 ========
0000 00000010 "C:\Windows\TEMP\{AD0DC6EC-28C0-48F0-9A3A-BE16F0F5BDAA}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0003 00001015 C:\Windows\system32\Macromed\Flash\Flash64_11_7_700_169.ocx 5
0004 00000018
0005 00001015 C:\Windows\system32\Macromed\Flash\Flash64_11_7_700_169.ocx 5
0006 00000013 C:\Windows\TEMP\{7EE2CAB0-CC94-405C-B5EB-A530E891BD47}\Flash64_11_7_700_202.ocx
0007 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_202_ActiveX.exe
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_202_ActiveX.exe
0009 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_202_ActiveX.dll
0010 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0012 00000012
=X====== M/11.7.700.202 2013-05-15+15-09-11.080 ========
=O====== M/11.7.700.202 2013-05-17+00-25-03.479 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{CFEA60CB-E103-471A-8A2F-2ACCA47FA3A4}\InstallFlashPlayer.exe" -uninstall activex
0007 00001021
=X====== M/11.7.700.202 2013-05-17+00-25-03.604 ========
=O====== M/11.7.700.202 2013-05-17+00-32-01.173 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{251760CD-0598-43AA-B34B-9600F2EBC683}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 0
0005 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_7_700_202.ocx
0006 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_202_ActiveX.exe
0007 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_202_ActiveX.dll
0010 00000012
=X====== M/11.7.700.202 2013-05-17+00-32-03.001 ========
=O====== M/11.7.700.202 2013-05-27+18-54-33.838 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{B8FF65BC-362A-4BA8-B0FB-303D8561FD9F}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 4294967295
0003 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_7_700_202.ocx
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_202_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_202_ActiveX.dll
0008 00000012
=X====== M/11.7.700.202 2013-05-27+18-54-35.301 ========
=O====== M/11.7.700.202 2013-05-27+19-10-02.539 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{359653CE-2AAE-4C20-8841-2923072C207B}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 4294967295
0008 00000012
=X====== M/11.7.700.202 2013-05-27+19-10-04.084 ========
=O====== M/11.7.700.202 2013-05-27+19-11-38.482 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{B923EADD-9E71-44FB-BD29-7705EA27C346}\InstallFlashPlayer.exe" -uninstall activex
0007 00001021
=X====== M/11.7.700.202 2013-05-27+19-11-38.560 ========
=O====== M/11.7.700.202 2013-05-27+19-19-58.880 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{221FFD41-A318-4589-A5F5-01D5C5D6DE27}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 0
0010 00000012
=X====== M/11.7.700.202 2013-05-27+19-20-00.470 ========
=O====== M/11.7.700.202 2013-05-28+12-22-12.919 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{93AF455A-5B61-4AB4-A635-C98EA7D7E5A8}\InstallFlashPlayer.exe" -uninstall activex
0007 00001021
=X====== M/11.7.700.202 2013-05-28+12-22-13.029 ========
=O====== M/11.7.700.202 2013-05-28+12-34-26.110 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{5B6C193F-A864-4B2F-A132-72461251A9DB}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 1
0010 00000012
=X====== M/11.7.700.202 2013-05-28+12-34-27.714 ========
=O====== M/11.7.700.224 2013-06-19+03-19-30.950 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{780A1B64-7843-405E-8EB4-C46C2632B4BE}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 6 -au 4294967295
0003 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_7_700_224.ocx
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_224_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_224_ActiveX.dll
0008 00000012
=X====== M/11.7.700.224 2013-06-19+03-19-32.307 ========
=O====== M/11.7.700.224 2013-06-27+18-29-29.800 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{8D283969-8B94-474B-B4B9-DFE2BAD6A2FD}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 4294967295
0008 00000012
=X====== M/11.7.700.224 2013-06-27+18-29-32.103 ========
=O====== M/11.8.800.94 2013-07-11+20-02-33.825 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{D6FA2887-AB71-47F1-B13F-CFB954281789}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 4294967295
0003 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_8_800_94.ocx
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_94_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_94_ActiveX.dll
0008 00000012
=X====== M/11.8.800.94 2013-07-11+20-02-35.422 ========
=O====== M/11.8.800.94 2013-08-09+05-54-16.359 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{4CE454A2-3B18-4806-9A4E-4E86A09EF14A}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 4294967295
0008 00000012
=X====== M/11.8.800.94 2013-08-09+05-54-18.634 ========
=O====== M/11.8.800.94 2013-08-22+22-31-26.594 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{7B0AB83C-6053-4A49-8D1F-23D24DD6D0ED}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 4294967295
0008 00000012
=X====== M/11.8.800.94 2013-08-22+22-31-31.752 ========
=O====== M/11.8.800.94 2013-09-08+06-00-36.504 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{0FAD4ADB-F82F-4F54-916A-BA7F060E1359}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 6 -au 4294967295
0008 00000012
=X====== M/11.8.800.94 2013-09-08+06-00-39.530 ========
=O====== M/11.8.800.168 2013-09-11+14-09-04.089 ========
0000 00000010 "C:\Windows\TEMP\{7230A133-461B-413D-AA3A-81050E443231}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0003 00000013 C:\Windows\TEMP\{80119277-16B9-46AE-B69A-6E45C62E28C7}\Flash64_11_8_800_168.ocx
0004 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_168_ActiveX.exe
0005 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_168_ActiveX.exe
0006 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_168_ActiveX.dll
0007 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0009 00000012
=X====== M/11.8.800.168 2013-09-11+14-09-09.034 ========
=O====== M/11.8.800.174 2013-09-14+03-09-04.992 ========
0000 00000010 "C:\Windows\TEMP\{3E732C46-DB27-42FC-B4CD-0ADA04E5F580}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0003 00000013 C:\Windows\TEMP\{46DB2BCF-9294-4931-AF8D-64CA41D1E698}\Flash64_11_8_800_174.ocx
0004 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_174_ActiveX.exe
0005 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_174_ActiveX.exe
0006 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_174_ActiveX.dll
0009 00000012
=X====== M/11.8.800.174 2013-09-14+03-09-09.531 ========
=O====== M/11.8.800.174 2013-09-19+13-33-47.136 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{1A1928CF-2C8F-487B-9D9E-7B821AE08E21}\InstallFlashPlayer.exe" -uninstall activex
0007 00001021
=X====== M/11.8.800.174 2013-09-19+13-33-47.261 ========
=O====== M/11.8.800.174 2013-09-19+14-40-16.516 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{949D11FB-4AE0-4875-AD37-6E6D3CD7C34A}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 1
0005 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_8_800_174.ocx
0006 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_174_ActiveX.exe
0007 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_174_ActiveX.dll
0010 00000012
=X====== M/11.8.800.174 2013-09-19+14-40-18.452 ========
=O====== M/11.8.800.174 2013-09-19+15-47-03.889 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{5C67CDD1-63DE-45A5-8065-3529ACD15EDE}\InstallFlashPlayer.exe" -uninstall activex
0007 00001021
=X====== M/11.8.800.174 2013-09-19+15-47-04.809 ========
=O====== M/11.8.800.174 2013-09-19+15-54-41.091 ========
0000 00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil64_11_8_800_174_ActiveX.exe" -refreshIEElevationPolicies
=X====== M/11.8.800.174 2013-09-19+15-54-41.128 ========
=O====== M/11.8.800.174 2013-09-19+15-54-39.547 ========
0000 00000010 "C:\Users\ADMINI~1\AppData\Local\Temp\{A22C2AA1-F7A8-4110-97B2-5EDEF46EE12F}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 1
0010 00000012
=X====== M/11.8.800.174 2013-09-19+15-54-41.770 ========
=O====== M/11.9.900.117 2013-10-29+04-25-49.638 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{C7A64E9E-79DF-414E-BF71-4F6861E14B98}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 6 -au 4294967295
0003 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_9_900_117.ocx
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_117_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_117_ActiveX.dll
0008 00000012
=X====== M/11.9.900.117 2013-10-29+04-25-51.464 ========
=O====== M/11.9.900.152 2013-11-13+14-38-05.464 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{4104715C-7C04-4C16-87F1-BEB23699DA42}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 4294967295
0003 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_9_900_152.ocx
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_152_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_152_ActiveX.dll
0008 00000012
=X====== M/11.9.900.152 2013-11-13+14-38-07.416 ========
=O====== M/11.9.900.170 2013-12-13+18-28-08.403 ========
0000 00000010 "C:\Windows\TEMP\{3EB4EB8A-9880-466D-B5D1-647E871A32FD}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0003 00000013 C:\Windows\TEMP\{35D18599-A383-44DA-8ACE-FAD0CCB806FF}\Flash64_11_9_900_170.ocx
0004 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_170_ActiveX.exe
0005 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_170_ActiveX.exe
0006 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_170_ActiveX.dll
0009 00000012
=X====== M/11.9.900.170 2013-12-13+18-28-12.880 ========
=O====== M/11.9.900.170 2013-12-19+17-51-32.938 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{4FC0134D-57DC-42E5-9145-48B20C8364B0}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 4294967295
0003 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_9_900_170.ocx
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_170_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_170_ActiveX.dll
0008 00000012
=X====== M/11.9.900.170 2013-12-19+17-51-35.048 ========
=O====== M/12.0.0.44 2014-02-05+16-28-06.703 ========
0000 00000010 "C:\Windows\TEMP\{891A06DD-B58C-4959-8787-502CF4F2176C}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0001 00001036 Software\Macromedia\FlashPlayer\SafeVersions/12.0 2
0004 00000013 C:\Windows\TEMP\{C1CACE43-0771-40CD-A876-B67E9263DD96}\Flash64_12_0_0_44.ocx
0005 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_12_0_0_44_ActiveX.exe
0006 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_12_0_0_44_ActiveX.exe
0007 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_12_0_0_44_ActiveX.dll
0010 00000012
=X====== M/12.0.0.44 2014-02-05+16-28-10.384 ========
=O====== M/12.0.0.70 2014-02-21+17-28-24.083 ========
0000 00000010 "C:\Windows\TEMP\{557550D4-26F3-40DC-8926-482F5D066FEB}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0004 00000013 C:\Windows\TEMP\{4ACDF1B6-4957-4FE6-AD1C-5007BE7B03E5}\Flash64_12_0_0_70.ocx
0005 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_12_0_0_70_ActiveX.exe
0006 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_12_0_0_70_ActiveX.exe
0007 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_12_0_0_70_ActiveX.dll
0010 00000012
=X====== M/12.0.0.70 2014-02-21+17-28-29.652 ========
=O====== M/12.0.0.77 2014-03-12+20-28-03.471 ========
0000 00000010 "C:\Windows\TEMP\{44EFEC97-CC95-47F9-AA97-40F1E3320800}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0003 00000013 C:\Windows\TEMP\{1A14465B-289E-4FE6-ADED-DDE0ED576A8C}\Flash64_12_0_0_77.ocx
0004 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_12_0_0_77_ActiveX.exe
0005 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_12_0_0_77_ActiveX.exe
0006 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_12_0_0_77_ActiveX.dll
0009 00000012
=X====== M/12.0.0.77 2014-03-12+20-28-07.792 ========
=O====== M/13.0.0.206 2014-04-29+03-28-05.604 ========
0000 00000010 "C:\Windows\TEMP\{E406C5CE-37CE-46F1-BFDB-B63453FDE80F}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0001 00001036 Software\Macromedia\FlashPlayer\SafeVersions/13.0 2
0004 00000013 C:\Windows\system32\Macromed\Flash\Flash64_13_0_0_206.ocx
0005 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_13_0_0_206_ActiveX.exe
0006 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_13_0_0_206_ActiveX.dll
0009 00000012
=X====== M/13.0.0.206 2014-04-29+03-28-09.047 ========
=O====== M/13.0.0.206 2014-05-04+07-05-06.420 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{36E3B719-F4B3-4E17-A5DC-3820989F5F02}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 4294967295
0003 00000013 C:\Windows\system32\Macromed\Flash\Flash64_13_0_0_206.ocx
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_13_0_0_206_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_13_0_0_206_ActiveX.dll
0008 00000012
=X====== M/13.0.0.206 2014-05-04+07-05-08.925 ========
=O====== M/13.0.0.206 2014-05-12+16-20-07.626 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{D7479207-5625-4C35-8208-14FD271374B7}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 4294967295
0008 00000012
=X====== M/13.0.0.206 2014-05-12+16-20-10.469 ========
=O====== M/13.0.0.206 2014-05-12+17-19-33.415 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{87F37EAF-60A3-4E29-BA79-BE9C0034A1C9}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 4294967295
0008 00000012
=X====== M/13.0.0.206 2014-05-12+17-19-35.631 ========
=O====== M/13.0.0.214 2014-05-14+15-28-07.897 ========
0000 00000010 "C:\Windows\TEMP\{5DC33B8F-7037-4070-9262-E64A204A7958}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0003 00000013 C:\Windows\system32\Macromed\Flash\Flash64_13_0_0_214.ocx
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_13_0_0_214_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_13_0_0_214_ActiveX.dll
0008 00000012
=X====== M/13.0.0.214 2014-05-14+15-28-12.314 ========
=O====== M/13.0.0.214 2014-05-28+21-49-16.233 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{DDF957D2-A6E0-427C-973E-4F8414107693}\InstallFlashPlayer.exe" -uninstall activex
0007 00001021
=X====== M/13.0.0.214 2014-05-28+21-49-16.373 ========
=O====== M/13.0.0.214 2014-05-28+21-57-18.869 ========
0000 00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil64_13_0_0_214_ActiveX.exe" -refreshIEElevationPolicies
=X====== M/13.0.0.214 2014-05-28+21-57-18.993 ========
=O====== M/13.0.0.214 2014-05-28+21-57-17.100 ========
0000 00000010 "C:\Users\ADMINI~1\AppData\Local\Temp\{6195CE86-21C7-4A5D-8995-1529AC935D4B}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 0
0005 00000013 C:\Windows\system32\Macromed\Flash\Flash64_13_0_0_214.ocx
0006 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_13_0_0_214_ActiveX.exe
0007 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_13_0_0_214_ActiveX.dll
0010 00000012
=X====== M/13.0.0.214 2014-05-28+21-57-19.813 ========
=O====== M/14.0.0.145 2014-07-09+16-04-08.626 ========
0000 00000010 "C:\Windows\TEMP\{39DBFB32-3454-4654-997C-E2ED1928BAC9}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0001 00001036 Software\Macromedia\FlashPlayer\SafeVersions/14.0 2
0004 00000013
0005 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_14_0_0_145_ActiveX.exe
0006 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_14_0_0_145_ActiveX.exe
0007 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_14_0_0_145_ActiveX.dll
0010 00000012
=X====== M/14.0.0.145 2014-07-09+16-04-13.212 ========
=O====== M/14.0.0.145 2014-08-29+06-04-07.428 ========
0000 00000010 "C:\Windows\TEMP\{15263746-9117-4EF9-A7AE-E87BCD6FEF48}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0011 00000014
0012 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_14_0_0_145_Plugin.exe
0015 00000012
=X====== M/14.0.0.145 2014-08-29+06-04-12.728 ========
=O====== M/15.0.0.152 2014-09-10+16-04-10.970 ========
0000 00000010 "C:\Windows\TEMP\{71ACFEE5-7C4E-4615-8846-383A23C2C9EC}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0001 00001036 Software\Macromedia\FlashPlayer\SafeVersions/15.0 2
0004 00000013
0005 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_152_ActiveX.exe
0006 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_152_ActiveX.dll
0009 00000012
=X====== M/15.0.0.152 2014-09-10+16-04-16.102 ========
=O====== M/15.0.0.152 2014-09-10+17-04-09.537 ========
0000 00000010 "C:\Windows\TEMP\{77A229CE-48AF-462D-9105-33005646E5DC}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0008 00000014
0009 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_152_Plugin.exe
0012 00000012
=X====== M/15.0.0.152 2014-09-10+17-04-14.108 ========
=O====== M/15.0.0.167 2014-09-23+21-04-03.336 ========
0000 00000010 "C:\Windows\TEMP\{8310B800-1BA8-4DEF-81E8-1C6FA43380A7}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0003 00000013
0004 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_167_ActiveX.exe
0005 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_167_ActiveX.exe
0006 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_167_ActiveX.dll
0009 00000012
=X====== M/15.0.0.167 2014-09-23+21-04-08.437 ========
=O====== M/15.0.0.223 2014-11-13+23-04-16.688 ========
0000 00000010 "C:\Windows\TEMP\{DB86BC2A-F188-4BE1-9E1A-12A932575364}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0003 00000013
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_223_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_223_ActiveX.dll
0008 00000012
=X====== M/15.0.0.223 2014-11-13+23-04-21.010 ========
=O====== M/15.0.0.223 2014-11-14+00-04-12.588 ========
0000 00000010 "C:\Windows\TEMP\{529876E9-65BB-4C27-A1C9-DD718DC75398}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0008 00000014
0009 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_223_Plugin.exe
0012 00000012
=X====== M/15.0.0.223 2014-11-14+00-04-17.627 ========
=O====== M/15.0.0.239 2014-11-26+18-04-11.023 ========
0000 00000010 "C:\Windows\TEMP\{B3CD85FB-59D1-446A-A036-41D5124CF33D}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0003 00000013
0004 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_239_ActiveX.exe
0005 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_239_ActiveX.exe
0006 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_239_ActiveX.dll
0009 00000012
=X====== M/15.0.0.239 2014-11-26+18-04-16.427 ========
=O====== M/15.0.0.239 2014-11-27+01-04-07.819 ========
0000 00000010 "C:\Windows\TEMP\{22C5CB84-82CE-4323-B285-EA782AAAAD11}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0008 00000014
0009 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_239_Plugin.exe
0010 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_239_Plugin.exe
0011 00000024 C:\Windows\system32\Macromed\Flash\plugin.vch
0012 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0013 00000012
=X====== M/15.0.0.239 2014-11-27+01-04-11.969 ========
=O====== M/15.0.0.246 2014-12-10+16-04-03.459 ========
0000 00000010 "C:\Windows\TEMP\{38BAB7DB-A4D5-4103-B8EE-EC809CE94905}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0003 00000013
0004 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_246_ActiveX.exe
0005 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_246_ActiveX.exe
0006 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_246_ActiveX.dll
0009 00000012
=X====== M/15.0.0.246 2014-12-10+16-04-07.484 ========
=O====== M/15.0.0.246 2014-12-10+22-04-08.208 ========
0000 00000010 "C:\Windows\TEMP\{D241776F-A2DE-41F7-A2CF-4E49013B0976}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0008 00000014
0009 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_246_Plugin.exe
0010 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_15_0_0_246_Plugin.exe
0013 00000012
=X====== M/15.0.0.246 2014-12-10+22-04-09.909 ========
=O====== M/16.0.0.257 2015-01-13+20-04-03.951 ========
0000 00000010 "C:\Windows\TEMP\{A2A7D882-B856-4DDA-813E-18C1B8C4463D}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0001 00001036 Software\Macromedia\FlashPlayer\SafeVersions/16.0 2
0004 00000013
0005 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_257_ActiveX.exe
0006 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_257_ActiveX.exe
0007 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_257_ActiveX.dll
0010 00000012
=X====== M/16.0.0.257 2015-01-13+20-04-08.491 ========
=O====== M/16.0.0.257 2015-01-13+21-04-04.877 ========
0000 00000010 "C:\Windows\TEMP\{8C0DDDAC-9F6D-4030-8F9B-65E80EF079B7}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0002 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player NPAPI/ 2
0003 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
0004 00001036 Software\Mozilla\MaintenanceService\extensions/Plugins 2
0006 00001036 Software\Opera Software/Last CommandLine 2
0008 00001036 Software\Opera Software/Plugin Path 2
0009 00000014
0010 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_257_Plugin.exe
0011 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_257_Plugin.exe
0012 00000024 C:\Windows\system32\Macromed\Flash\plugin.vch
0014 00000012
=X====== M/16.0.0.257 2015-01-13+21-04-07.947 ========
=O====== M/16.0.0.287 2015-01-23+13-04-05.869 ========
0000 00000010 "C:\Windows\TEMP\{EA0D0964-1CC2-492F-8A7F-D566D2F78634}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0003 00000013
0004 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_287_ActiveX.exe
0005 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_287_ActiveX.exe
0006 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_287_ActiveX.dll
0009 00000012
=X====== M/16.0.0.287 2015-01-23+13-04-12.842 ========
=O====== M/16.0.0.287 2015-01-23+14-04-05.688 ========
0000 00000010 "C:\Windows\TEMP\{2E961659-0942-4FE5-BB2B-7E6D128CEEB0}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0009 00000014
0010 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_287_Plugin.exe
0011 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_287_Plugin.exe
0014 00000012
=X====== M/16.0.0.287 2015-01-23+14-04-08.208 ========
=O====== M/16.0.0.296 2015-01-24+23-04-06.477 ========
0000 00000010 "C:\Windows\TEMP\{8F40CC6C-F162-41EB-B2E4-E07D6B564303}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0003 00000013
0004 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_296_ActiveX.exe
0005 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_296_ActiveX.exe
0006 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_296_ActiveX.dll
0009 00000012
=X====== M/16.0.0.296 2015-01-24+23-04-12.826 ========
=O====== M/16.0.0.296 2015-01-25+00-04-05.294 ========
0000 00000010 "C:\Windows\TEMP\{CCC6767C-9C58-4E13-86E4-28A9916DB0B7}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0009 00000014
0010 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_296_Plugin.exe
0011 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_296_Plugin.exe
0014 00000012
=X====== M/16.0.0.296 2015-01-25+00-04-07.712 ========
=O====== M/16.0.0.305 2015-02-06+00-04-04.637 ========
0000 00000010 "C:\Windows\TEMP\{CF9C563E-EEAD-4B58-B5C5-5A2113179ECE}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0003 00000013
0004 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_305_ActiveX.exe
0005 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_305_ActiveX.exe
0006 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_305_ActiveX.dll
0009 00000012
=X====== M/16.0.0.305 2015-02-06+00-04-08.407 ========
=O====== M/16.0.0.305 2015-02-06+01-04-06.634 ========
0000 00000010 "C:\Windows\TEMP\{77C34F8E-B726-4677-A8FD-A7AB06475A82}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0009 00000014
0010 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_305_Plugin.exe
0011 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_16_0_0_305_Plugin.exe
0014 00000012
=X====== M/16.0.0.305 2015-02-06+01-04-08.414 ========
=O====== M/17.0.0.169 2015-04-14+18-04-49.141 ========
0000 00000010 "C:\Windows\TEMP\{83C36E48-DA45-4FD7-BEF4-BDC01EFE8073}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0001 00001036 Software\Macromedia\FlashPlayer\SafeVersions/17.0 2
0004 00000013
0005 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_17_0_0_169_ActiveX.exe
0006 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_17_0_0_169_ActiveX.dll
0009 00000012
=X====== M/17.0.0.169 2015-04-14+18-04-57.931 ========
=O====== M/17.0.0.169 2015-04-14+19-04-07.271 ========
0000 00000010 "C:\Windows\TEMP\{8B7526EF-300E-4773-8575-164F5C88FFBD}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0009 00000014
0010 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_17_0_0_169_Plugin.exe
0013 00000012
=X====== M/17.0.0.169 2015-04-14+19-04-09.091 ========
=O====== M/17.0.0.188 2015-06-09+22-04-08.261 ========
0000 00000010 "C:\Windows\TEMP\{51E1D723-A288-4AA6-B1A0-DFFDB8A8564E}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0003 00000013
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_17_0_0_188_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_17_0_0_188_ActiveX.dll
0008 00000012
=X====== M/17.0.0.188 2015-06-09+22-04-12.111 ========
=O====== M/17.0.0.188 2015-06-10+13-05-18.350 ========
0000 00000010 "C:\Windows\TEMP\{69B0FE01-440B-4158-9758-E7F0E45C4D96}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0009 00000014
0010 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_17_0_0_188_Plugin.exe
0013 00000012
=X====== M/17.0.0.188 2015-06-10+13-05-27.742 ========
=O====== M/17.0.0.190 2015-06-24+15-04-05.886 ========
0000 00000010 "C:\Windows\TEMP\{90E0BE4D-2285-4D36-A6B4-22865AB3461F}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0003 00000013
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_17_0_0_190_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_17_0_0_190_ActiveX.dll
0008 00000012
=X====== M/17.0.0.190 2015-06-24+15-04-09.480 ========
=O====== M/17.0.0.190 2015-06-24+16-04-13.341 ========
0000 00000010 "C:\Windows\TEMP\{654DFFC2-985D-453A-B462-3F00DBAFBA3D}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0009 00000014
0010 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_17_0_0_190_Plugin.exe
0013 00000012
=X====== M/17.0.0.190 2015-06-24+16-04-15.705 ========
=O====== M/17.0.0.190 2015-07-08+19-04-05.338 ========
0000 00000010 "C:\Windows\TEMP\{D385830E-49C6-4AC7-989F-63DE3F53E06F}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0003 00000013
0008 00000012
=X====== M/17.0.0.190 2015-07-08+19-04-08.888 ========
=O====== M/17.0.0.191 2015-07-08+20-04-11.869 ========
0000 00000010 "C:\Windows\TEMP\{CC5AB32E-2D1D-48BB-8442-C03A9E20E4F8}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0003 00000013
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_17_0_0_191_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_17_0_0_191_ActiveX.dll
0008 00000012
=X====== M/17.0.0.191 2015-07-08+20-04-20.249 ========
=O====== M/17.0.0.191 2015-07-08+21-04-15.637 ========
0000 00000010 "C:\Windows\TEMP\{BE3A59B8-09D1-47D6-8641-4214DA9B2680}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0009 00000014
0010 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_17_0_0_191_Plugin.exe
0013 00000012
=X====== M/17.0.0.191 2015-07-08+21-04-17.807 ========
=O====== M/18.0.0.209 2015-07-14+21-04-06.024 ========
0000 00000010 "C:\Windows\TEMP\{F97DA19A-C42F-4BAF-AED4-E92D3C71CDBF}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0001 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
0002 00001036 Software\Macromedia\FlashPlayer\SafeVersions/18.0 2
0005 00000013
0006 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_18_0_0_209_ActiveX.exe
0007 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_18_0_0_209_ActiveX.dll
0010 00000012
=X====== M/18.0.0.209 2015-07-14+21-04-11.110 ========
=O====== M/18.0.0.209 2015-07-14+22-04-12.567 ========
0000 00000010 "C:\Windows\TEMP\{D23D8E56-3834-4DC5-B464-503C5ECFBA54}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0003 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player NPAPI/ 2
0004 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
0005 00001036 Software\Mozilla\MaintenanceService\extensions/Plugins 2
0010 00000014
0011 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_18_0_0_209_Plugin.exe
0014 00000012
=X====== M/18.0.0.209 2015-07-14+22-04-18.760 ========
=O====== M/18.0.0.209 2015-07-19+14-40-30.643 ========
0000 00000010 "C:\Users\ADMINI~1\AppData\Local\Temp\{B487AB8C-3CA3-4026-93DF-3DD46B2AEF00}\InstallFlashPlayer.exe" -uninstall plugin
0001 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player NPAPI/ 2
0003 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
0004 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
0005 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
0006 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
0007 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
0008 00001021
0010 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
0012 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
0013 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0014 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
=X====== M/18.0.0.209 2015-07-19+14-40-30.767 ========
=O====== M/18.0.0.209 2015-07-19+14-40-41.734 ========
0000 00000010 "C:\Users\ADMINI~1\AppData\Local\Temp\{D9E1EE62-F196-4F3C-8688-EC373675CE44}\InstallFlashPlayer.exe" -uninstall activex
0007 00001021
0011 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0012 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0013 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
0014 00001037 SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options
0015 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
0016 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0017 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0018 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
=X====== M/18.0.0.209 2015-07-19+14-40-41.859 ========
=O====== M/18.0.0.209 2015-07-23+18-33-08.257 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{A5C027A3-7CA2-4510-A6E9-49CA99129A32}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 0
0001 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0003 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
0004 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0005 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0006 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
0007 00000013
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_18_0_0_209_ActiveX.exe
0009 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_18_0_0_209_ActiveX.dll
0012 00000012
=X====== M/18.0.0.209 2015-07-23+18-33-09.988 ========
=O====== M/18.0.0.232 2015-08-12+03-30-05.659 ========
0000 00000010 "C:\Windows\TEMP\{5D723855-4915-4403-9B1B-74E0B016BDC7}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0002 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
0005 00000013
0006 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_18_0_0_232_ActiveX.exe
0007 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_18_0_0_232_ActiveX.exe
0008 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_18_0_0_232_ActiveX.dll
0011 00000012
=X====== M/18.0.0.232 2015-08-12+03-30-07.916 ========
=O====== M/19.0.0.185 2015-09-21+21-30-04.740 ========
0000 00000010 "C:\Windows\TEMP\{7D883052-7624-43A4-A0FA-B53E3F658446}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0003 00001036 Software\Macromedia\FlashPlayer\SafeVersions/19.0 2
0006 00000013
0007 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_19_0_0_185_ActiveX.exe
0008 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_19_0_0_185_ActiveX.dll
0011 00000012
=X====== M/19.0.0.185 2015-09-21+21-30-07.002 ========
=O====== M/19.0.0.207 2015-10-15+15-30-03.370 ========
0000 00000010 "C:\Windows\TEMP\{819AB98A-6468-40D6-B738-14CEC6EC3235}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0005 00000013
0006 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_19_0_0_207_ActiveX.exe
0007 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_19_0_0_207_ActiveX.exe
0008 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_19_0_0_207_ActiveX.dll
0011 00000012
=X====== M/19.0.0.207 2015-10-15+15-30-05.507 ========
=O====== M/19.0.0.226 2015-10-16+20-30-02.863 ========
0000 00000010 "C:\Windows\TEMP\{A3695225-1861-4DCA-A9E5-9ADAA3E2B228}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0005 00000013
0006 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_19_0_0_226_ActiveX.exe
0007 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_19_0_0_226_ActiveX.exe
0008 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_19_0_0_226_ActiveX.dll
0011 00000012
=X====== M/19.0.0.226 2015-10-16+20-30-04.626 ========
=O====== M/19.0.0.245 2015-11-11+19-30-04.668 ========
0000 00000010 "C:\Windows\TEMP\{EAF5BECB-3F0C-4B03-993F-7C54DD2BB7ED}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0005 00000013
0006 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_19_0_0_245_ActiveX.exe
0007 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_19_0_0_245_ActiveX.exe
0008 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_19_0_0_245_ActiveX.dll
0011 00000012
=X====== M/19.0.0.245 2015-11-11+19-30-07.070 ========
=O====== M/20.0.0.228 2015-12-09+04-30-03.388 ========
0000 00000010 "C:\Windows\TEMP\{559EAE24-E10C-4626-A9BE-A2DA0323CDAF}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0001 00001036 Software\Macromedia\FlashPlayer\SafeVersions/20.0 2
0004 00000013
0005 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_20_0_0_228_ActiveX.exe
0006 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_20_0_0_228_ActiveX.exe
0007 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_20_0_0_228_ActiveX.dll
0009 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0010 00000012
=X====== M/20.0.0.228 2015-12-09+04-30-05.556 ========
=O====== M/20.0.0.267 2015-12-29+17-30-12.017 ========
0000 00000010 "C:\Windows\TEMP\{E041F681-975C-4DE4-BAD4-ABB4955D4E62}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0001 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0003 00000013
0004 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_20_0_0_267_ActiveX.exe
0005 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_20_0_0_267_ActiveX.exe
0006 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_20_0_0_267_ActiveX.dll
0008 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0009 00000012
=X====== M/20.0.0.267 2015-12-29+17-30-14.127 ========
=O====== M/20.0.0.270 2016-01-02+11-30-15.841 ========
0000 00000010 "C:\Windows\TEMP\{300B52AB-2684-44C8-8434-D362F07B7C35}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0003 00000013
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_20_0_0_270_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_20_0_0_270_ActiveX.dll
0008 00000012
=X====== M/20.0.0.270 2016-01-02+11-30-19.148 ========
=O====== M/20.0.0.286 2016-01-19+22-30-04.965 ========
0000 00000010 "C:\Windows\TEMP\{6BDF4F82-5559-45FA-96FA-B54903AA3537}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0003 00000013
0004 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_20_0_0_286_ActiveX.exe
0005 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_20_0_0_286_ActiveX.exe
0006 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_20_0_0_286_ActiveX.dll
0009 00000012
=X====== M/20.0.0.286 2016-01-19+22-30-09.003 ========
=O====== M/20.0.0.306 2016-02-10+15-30-10.217 ========
0000 00000010 "C:\Windows\TEMP\{0050D7A2-3FEE-4036-9080-12F77E37D143}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0003 00000013
0004 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_20_0_0_306_ActiveX.exe
0005 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_20_0_0_306_ActiveX.exe
0006 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_20_0_0_306_ActiveX.dll
0009 00000012
=X====== M/20.0.0.306 2016-02-10+15-30-13.097 ========
=O====== M/21.0.0.182 2016-03-10+18-30-24.327 ========
0000 00000010 "C:\Windows\TEMP\{EE68BD9D-ACA1-4A65-83B2-E5A869973EE8}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0001 00001036 Software\Macromedia\FlashPlayer\SafeVersions/21.0 2
0002 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0003 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
0004 00000013
0005 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_21_0_0_182_ActiveX.exe
0006 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_21_0_0_182_ActiveX.exe
0007 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_21_0_0_182_ActiveX.dll
0010 00000012
=X====== M/21.0.0.182 2016-03-10+18-31-54.354 ========
=O====== M/21.0.0.197 2016-03-24+16-30-02.452 ========
0000 00000010 "C:\Windows\TEMP\{A3A36CF7-B1DC-42EC-BA76-164EC0095892}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0003 00000013
0004 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil64_21_0_0_197_ActiveX.exe
0005 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_21_0_0_197_ActiveX.exe
0006 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_21_0_0_197_ActiveX.dll
0009 00000012
=X====== M/21.0.0.197 2016-03-24+16-30-03.950 ========
=O====== M/21.0.0.197 2016-03-29+22-49-32.048 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{48BDBA3A-469C-4762-85E7-4CE89995B0C2}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 0
0003 00000013
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_21_0_0_197_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_21_0_0_197_ActiveX.dll
0007 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0008 00000012
=X====== M/21.0.0.197 2016-03-29+22-49-37.461 ========
=O====== M/21.0.0.197 2016-03-30+00-39-32.936 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{208A64A9-3C26-4353-836E-1DF8726DC3C4}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 0
0003 00001015 C:\Windows\system32\Macromed\Flash\Flash64_21_0_0_197.ocx 5
0004 00000018
0005 00001015 C:\Windows\system32\Macromed\Flash\Flash64_21_0_0_197.ocx 5
0006 00000013
0007 00001024 C:\Windows\system32\Macromed\Flash\Flash64_21_0_0_197.ocx 183
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_21_0_0_197_ActiveX.exe
0009 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_21_0_0_197_ActiveX.dll
0012 00000012
=X====== M/21.0.0.197 2016-03-30+00-39-35.135 ========
=O====== M/21.0.0.197 2016-03-30+14-20-07.235 ========
0000 00000010 "C:\Users\LILLIA~1\AppData\Local\Temp\{ADDED4C9-1E56-4728-A015-44BBD39192E9}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 0
0003 00000013
0008 00000012
=X====== M/21.0.0.197 2016-03-30+14-20-09.918 ========
I'm not seeing any obvious errors in the log file. I would recommend performing a clean install. See How do I do a clean install of Flash Player? for instructions.
Maria
maria,
I have followed & did the clean install, after doing the uninstall.
but when I went into the work schedule website,
it is showing me again:
NEED ADOBE FLASH PLAYER. should I still send the logfile for sysWOW64 when dell helps me fix & view it? or are the sys32 file same as the sysWOW 64 file?
If you go here in IE11, do you see the animation?
Sorry, I missed the your comment "...but then I still get a "access denied" message when trying to view the log file in sysWOW64, I contacted dell for this."
and missed that this file was from the system32 location. The file in the sysWOW64 location will have more information than this file. If you can get into that location to get the file it'd be great.
On a 64-bit OS, Flash Player installs to C:\Windows\System32\Macromed\Flash and C:\Windows\SysWOW64\Macromed\Flash. If you can't access this directory it's possible Flash Player can't either, but if that was the case I would expect Flash Player installation to fail due to Access Denied error. Please try the following:
After Windows Explorer launches as Administrator try to navigate to the C:\Windows\SysWOW64\Macromed\Flash directory. If you can, post the contents of the FlashInstall.log file.
Thank you.
Maria
hello maria, what does "ORB" mean in start orbthanks.
The Start button, as show in the screenshot. The steps in the screenshot correspond with the steps in the instructions.
Maria
yes, still getting the access denied message for syswow64, even after following your
steps clearly. I had referred the problem to dell and the technician pro-support likewise
tried it and they were getting the same "access denied" message after trying to access
the logfile of syswow64.
any other solutions?
thanks for your patience, ms. maria
martin
I wasn't sure if the suggestion would work, and unfortunately, it didn't.
Since this is a Windows file system issue it's beyond the scope of assistance we can provide on the Adobe forums. I recommend contacting Microsoft support at support.microsoft.com or seeking assistance at the Microsoft community forums at answers.microsoft.com for assistance. This Microsoft tech note may also be of assistance https://support.microsoft.com/en-us/mats/windows_file_and_folder_diag.
Once you resolve the issue with the Windows file system it'll most likely resolve the issues you're having with Flash Player.
Maria
You could try and Fix Permissions for what its worth, and i did not see that you attempted to do a check desk for errors as mentioned earlier?
How do I fix Windows permission problems with Flash Player?
Best Regards
