Need help in invoking these webservices..
There are two webservices that I am trying to invoke one
after the other:-
1) first web service "setupwebsession" sets a session. Here I
have setup the session.webuserUI to a component.
2) second service tries to get a profile but displays an
error
Here is the webservice consuming:-
<cfinvoke webservice="
http://localhost:8050/WebServices.cfc?wsdl"
method="setUpWebUserSession"
returnVariable="soo">
<cfinvokeargument name="userName"
value="shafiatcc@gmail.com">
<cfinvokeargument name="applicationToLogIn"
value="atccWeb">
</cfinvoke>
<cfoutput> #soo# </cfoutput>
<cfdump var="#Session.SessionID#">
method="getProfileHTML" returnvariable="profilehtml">
</cfinvoke>
<cfoutput>#getProfileHTML#</cfoutput>
I am trying to consume both these webservices but it displays
a following error.
Cannot perform web service invocation getProfileHTML.
The fault returned when invoking the web service operation
is:
AxisFault
faultCode: {
http://schemas.xmlsoap.org/soap/envelope/}Server.userException
faultSubcode:
faultString:
[line 1, column 8] [--Catch Data--]
type: Application
tagname: CFOUTPUT
template:
C:/jboss-eap-4.3/jboss-as/server/atcc/tmp/deploy/tmp48291CTiWebServicesAPI.ear-contents/CTiWebServicesAPI-exp.war/CTiWebServicesAPI.cfc
Line: 75; Column: 3
ErrorCode:
message: session.WebUserUI.getWebProfileHTML() doesn't exist.
detail: Error at line 1, column 8
faultActor:
faultNode:
faultDetail:
http://xml.apache.org/axis/}hostname:124426-SECOM1
The error occurred in
C:\ColdFusion8\wwwroot\selfprojects\webservices1.cfm: line 10
8 : <cfdump var="#Session.SessionID#">
9 : <cfinvoke webservice="
http://localhost:8050/webervices.cfc?wsdl"
10 : method="getProfileHTML" returnvariable="profilehtml">
11 : </cfinvoke>
12 : <cfoutput>#getProfileHTML#</cfoutput>
Resources:
Check the ColdFusion documentation to verify that you are
using the correct syntax.
Search the Knowledge Base to find a solution to your problem.
Browser Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1;
.NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30; .NET
CLR 3.0.04506.648; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729)
Remote Address 127.0.0.1
Referrer
http://localhost:8500/selfprojects/
Date/Time 19-Mar-09 04:27 PM
Stack Trace (click to expand)
at
cfwebservices12ecfm1268558828.runPage(C:\ColdFusion8\wwwroot\selfprojects\webservices1.cfm:10)
coldfusion.xml.rpc.ServiceProxy$ServiceInvocationException:
at
coldfusion.xml.rpc.ServiceProxy.invokeImpl(ServiceProxy.java:230)
at
coldfusion.xml.rpc.ServiceProxy.invoke(ServiceProxy.java:143)
at coldfusion.runtime.CfJspPage._invoke(CfJspPage.java:2222)
at
coldfusion.tagext.lang.InvokeTag.doEndTag(InvokeTag.java:417)
at
at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:196)
at
coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:370)
at
coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:65)
at
coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:279)
at
coldfusion.filter.RequestMonitorFilter.invoke(RequestMonitorFilter.java:48)
at
coldfusion.filter.MonitoringFilter.invoke(MonitoringFilter.java:40)
at coldfusion.filter.PathFilter.invoke(PathFilter.java:86)
at
coldfusion.filter.LicenseFilter.invoke(LicenseFilter.java:27)
at
coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:70)
at
coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:28)
at
coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38)
at
coldfusion.filter.NoCacheFilter.invoke(NoCacheFilter.java:46)
at
coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38)
at
coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
at coldfusion.CfmServlet.service(CfmServlet.java:175)
at
coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:89)
at jrun.servlet.FilterChain.doFilter(FilterChain.java:86)
at
coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:42)
at
coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46)
at jrun.servlet.FilterChain.doFilter(FilterChain.java:94)
at jrun.servlet.FilterChain.service(FilterChain.java:101)
at
jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:106)
at
jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
at
jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:286)
at
jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:543)
at
jrun.servlet.http.WebService.invokeRunnable(WebService.java:172)
at
jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPool.java:320)
at
jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:428)
at
jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool.java:266)
at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
