Flex FTP and PHP
Avatar
Level 1
Hi Everyone,
As you can see by the title, I'm trying to use Flex to upload
a file, followed by having PHP FTP the file to the server.
I have been successful at having PHP move the file once Flex
uploads it, but that is using http and the client wants this to be
strictly ftp:
Here's the Flex code:
[code]
<?xml version="1.0" encoding="utf-8"?>
<mx:Application xmlns:mx="
http://www.adobe.com/2006/mxml"
layout="absolute" backgroundAlpha="0.0" backgroundColor="0x000000"
backgroundGradientColors="[#000000, #000000]" borderThickness="0"
height="220" width="616" paddingTop="0" paddingBottom="0"
paddingLeft="0" paddingRight="0" verticalAlign="top">
<fab:FABridge bridgeName="fab" id="fab"
xmlns:fab="bridge.*" />
<mx:Script>
<![CDATA[
import flash.net.URLRequest;
import flash.net.URLLoader;
private var file:FileReference = new FileReference();
private function init():void
file.addEventListener(Event.SELECT, selectHandler);
private function selectHandler(event:Event):void
private function browse(event:MouseEvent):void
var filefilter:FileFilter = new FileFilter("Video Files",
"*.mov;*.m2v;*.mp4;*.m4v;*.wmv;*.avi;*.swf;");
file.addEventListener(Event.SELECT, fileSelected);
file.addEventListener(Event.COMPLETE, uploadComplete);
file.addEventListener(DataEvent.UPLOAD_COMPLETE_DATA,
uploadDataComplete);
file.addEventListener(IOErrorEvent.IO_ERROR, handleError);
file.browse([filefilter]);
public function handleError(event:IOErrorEvent):void
status_txt.text = 'ERROR: ' + event.text + '\n';
public function fileSelected(event:Event):void
if (event.currentTarget.size<15800000)
_progressbar.visible=true;
file = FileReference(event.target);
txt_file.text = file.name;
status_txt.text = file.name + ' is uploading. \n';
file.addEventListener(ProgressEvent.PROGRESS,
progressHandler);
var Form:URLVariables = new URLVariables();
var request:URLRequest = new URLRequest();
Form.txt_file = txt_file.text;
request.data = Form;
request.url = 'ftp_test3.php';
file.upload(request);
else
mx.controls.Alert.show('Max File Size is: 15MB','File Too
Large',4,null).clipContent
public function uploadComplete(event:Event):void
status_txt.text += 'Upload complete' + '\n';
_progressbar.label = '';
_progressbar.visible=false;
private function progressbarInit():void
private function progressHandler(event:ProgressEvent):void
_progressbar.setProgress(50,100);
_progressbar.label = 'Uploading ' +
Math.round(event.bytesLoaded / 1024) + ' kb of ' +
Math.round(event.bytesTotal / 1024) + ' kb ' ;
public function uploadDataComplete(event:DataEvent):void
// used to send message via Javascript to let me know that
it actually completed
ExternalInterface.call('sendRequestPost_video', '3');
</mx:Script>
<mx:Panel backgroundColor="0x000000" color="0xFFFFFF"
borderThickness="0" paddingTop="0" paddingBottom="0"
paddingLeft="0" paddingRight="0" height="220" width="614">
<mx:Form>
<mx:TextInput id='txt_file' horizontalCenter='0' top='0'
color="0x000000" width="100" />
<mx:Button id="browse_button" label="Upload Video"
click="browse(event);" width="100" />
<mx:ProgressBar id='_progressbar' labelPlacement='center'
trackHeight='15' left='-2' right='2' top='60' height='20'
color="0x000000" width="300" />
</mx:Form>
<mx:Label id="status_txt" color="0xFFFFFF" width="589"
height="50" fontSize="16" />
</mx:Panel>
<mx:HTTPService id="userRequest" url="ftp_test3.php"
method="POST">
<mx:request>
<txt_file>txt_file.text</txt_file>
</mx:request>
</mx:HTTPService>
</mx:Application>
[/code]
And here's the PHP code that moves the file, which is
successful:
[code]
<?php
$upload_dir = $_SERVER['DOCUMENT_ROOT'] .
dirname($_SERVER['PHP_SELF']) . '/'."movies/";
$upload_url = "
http://".$_SERVER['HTTP_HOST'
$message ="";
$temp_name = $_FILES['Filedata']['tmp_name'];
$file_name = $_FILES['Filedata']['name'];
$file_name = str_replace("\\","",$file_name);
$file_name = str_replace("'","",$file_name);
$file_path = $upload_dir.$file_name;
$result = move_uploaded_file($temp_name, $file_path);
chmod("movies/".$file_name, 0777);
chown("movies/".$file_name, www);
if ($result)
$message =
"<result><status>OK</status><message>$file_name
uploaded successfully.</message></result>";
else
$message =
"<result><status>Error</status><message>Somthing
is wrong with uploading a file.</message></result>";
echo $message;
[/code]
The above code works fine, but it's not FTP.
So, I use the same concept but with ftp, which BTW, the below
FTP PHP scripts works on it's own to upload a file via FTP. It
appears as though Flex is not communicating with the PHP file.
[code]
<?php
//-- SMTP Mail Function By Aditya Bhatt
if(isset($_POST['SubmitFile'])){
$myFile = $_FILES['txt_file']['tmp_name']; // This will make
an array out of the file information that was stored.
$myFileName = basename($_FILES['txt_file']['name']);
//Retrieve filename out of file path
$destination_file = $_REQUEST['filepath'].$myFileName;
#"/developers/uploadftp/aditya/".$myFileName; //where you
want to throw the file on the webserver (relative to your login
dir)
// connection settings
$ftp_server = 'someIPnumber'; //address of ftp server.
$ftp_user_name = 'username'; // Username
$ftp_user_pass = 'password'; // Password
$conn_id = ftp_connect($ftp_server) or die("<span
style='color:#FF0000'><h2>Couldn't connect to
$ftp_server</h2></span>"); // set up basic connection
#print_r($conn_id);
$login_result = ftp_login($conn_id, $ftp_user_name,
$ftp_user_pass) or die("<span
style='color:#FF0000'><h2>You do not have access to this
ftp server!</h2></span>"); // login with username and
password, or give invalid user message
if ((!$conn_id) || (!$login_result)) { // check connection
echo "<span style='color:#FF0000'><h2>FTP
connection has failed! <br />";
echo "Attempted to connect to $ftp_server for user
$ftp_user_name</h2></span>";
exit;
} else {
// echo "Connected to $ftp_server, for user $ftp_user_name
<br />";
$upload = ftp_put($conn_id, $destination_file, $myFile,
FTP_BINARY); // upload the file
if (!$upload) { // check upload status
echo "<span style='color:#FF0000'><h2>FTP upload
of $myFileName has failed!</h2></span> <br />";
} else {
echo "<span style='color:#339900'><h2>Uploading
$myFileName Completed Successfully!</h2></span><br
/><br />";
ftp_close($conn_id); // close the FTP stream
<html>
<head></head>
<body>
<form enctype="multipart/form-data" action="<?php echo
$_SERVER['PHP_SELF'];?>" method="POST" id="myForm">
Please choose a file: <input name="txt_file" type="file"
id="txt_file" tabindex="1" size="35"
onChange="txt_fileName.value=txt_file.value"
/><br><br>
<input name="txt_fileName" type="hidden"
id="txt_fileName" tabindex="99" size="1" />
<input type="submit" name="SubmitFile" value="Upload
File" accesskey="ENTER" tabindex="2" />
</form>
</body>
</html>
[/code]
THanks in advance and if there are any articles or tutorials
for this concept, let me know -- I have read the chapter in the
source book, but it sends the uploaded file to a cfm page and I
need it to work with PHP.
1 Reply
Avatar
Level 1
I found the issue and corrected it:
I had to remove the "if the form was submitted conditional"
[code]
[/code]
Because the php form would never be submitted via Flex
and I changed the following code from txt_file to Filedata
[code]
$myFile = $_FILES['Filedata']['tmp_name']; // This will make
// $file = $myFile['tmp_name']; //Converts the array into a
new string containing the path name on the server where your file
is.
$myFileName = basename($_FILES['Filedata']['name']);
[/code]
THe only thing that I have to figure out now, is that the
files are being uploaded to the root directory of the user logging
in, but other than that, it works :-)
