If you right-click the WebHelp layout (or double-click it)
you get screens that have options. In these options you are able to
choose a skin from the Gallery.
Rick Different skins appear under Skins in the project set-up
pod. When I go into edit mode, and then try to save the skin, there
is no option to use that skin in the output, which is contrary to
what Help says. Is there another way to select a skin for use in
the output?
You should note that there are actually two different types
of skins. One type applies to WebHelp and has an icon resembling a
diamond with a large S superimposed. The other type applies to
FlashHelp and is a circle with a large F superimposed.
Your post seems to imply that you are expecting to see both
types in your choices?
