Locked
webApp search: current date
Participant ,
Apr 07, 2016 Apr 07, 2016
In the web app search field "Date" should be the current date.
Has anybody an idea how to manage this?
i try to customize the DataPicker but without successs.
Actually this is my Code:
<form name="catcustomcontentform24647" method="post" onsubmit="return checkWholeForm24647(this)" action="/Default.aspx?CCID=16168&FID=125881&ExcludeBoolFalse=True&PageID={module_oid}">
  <table class="webform" cellspacing="0" cellpadding="2" border="0">
    <tr>
      <td class="h4-texttitel"><select name="CAT_Custom_1" id="CAT_Custom_1" class="cat_dropdown">
          <option value="*">-- Alle Themen--</option>
          <option value="Gottesdienst">Gottesdienst</option>
          <option value="Konzerte">Konzerte</option>
          <option value="Konfprogramm">Konfprogramm</option>
          <option value="Mittagstisch">Mittagstisch</option>
          <option value="Jassnachmittage">Jassnachmittage</option>
          <option value="Gespräche">Gespräche</option>
          <option value="Erwachsenenbildung">Erwachsenenbildung</option>
          <option value="Spiritualität">Spiritualität</option>
          <option value="Kirchgemeindeversammlung">Kirchgemeindeversammlung</option>
        </select></td>
      <td><input type="text" name="CAT_Custom_2_Min" id="CAT_Custom_2_Min" class="cat_textbox" readonly style="background-color:#F0F0F0;" onfocus="displayDatePicker('CAT_Custom_2_Min');return false;"  placeholder="mm/dd/yyyy"/></td>
    </tr>
    <tr>
      <td><input class="cat_button" type="submit" value="Termine anzeigen" /></td>
    </tr>
  </table>
</form>
<script type="text/javascript" src="/CatalystScripts/ValidationFunctions.js?vs=b2004.r486545-phase1"></script>
<script type="text/javascript" src="/CatalystScripts/Java_DatePicker.js?vs=b2004.r486545-phase1"></script>
<script type="text/javascript">
    function checkWholeForm24647(theForm) {
        var why = "";
        if (theForm.CAT_Custom_2_Min)
            if (theForm.CAT_Custom_2_Min.value.length > 0) why += checkDate(theForm.CAT_Custom_2_Min.value, "Datum");
        if (theForm.CAT_Custom_2_Max)
            if (theForm.CAT_Custom_2_Max.value.length > 0) why += checkDate(theForm.CAT_Custom_2_Max.value, "Datum");
        if (why != "") {
            alert(why);
            return false;
        return true;
</script>
Thanks for helping
Web apps
738
Deleted User
Apr 08, 2016 Apr 08, 2016
I'm sure you still need this, but try to use global variables.
{% assign today= globals.site.dateNow | date -%}
and for the "CAT_Custom_2_Min" input add value={{today}}
Guest
Participant ,
‌this works fine. Do you have a tipp how to submit the form on load?
Guest
Apr 09, 2016 Apr 09, 2016
Web development is new to  me, I'm not sure I understand your question, you want to automatically submit the form on page load?
Participant ,
Apr 10, 2016 Apr 10, 2016
If somebody visit the site, the web app results with the current date should be shown.
This is the reason why the webforms should be submitted automatically with the current date.
You will need javascript to do that.
Participant ,
with the following javascript the web form submit automatically the fields.
<script language="JavaScript">document.forms[0].submit();</script>
But it loops the submit-process, because the webapp results are on the same site.
Participant ,
The approach is that: the standard web app with filter "latest" doesn’t show the current item on the top.
{module_webapps id="16169" filter="latest"}
The visitor should always see the most actuall item on the top.
Perhaps liquid is the right choice ?!
