Robohelp 11 - not displaying toc or index when generating Webhelp
Guest
Apr 04, 2016 Apr 04, 2016
In Robo 11, when generating WebHelp, the toc and index are not accesible. The buttons are there, but they're not active.
991
Have you applied the patches?
Which browsers does this occur in?
@petergrainge
Guest
Hi Peter, no I haven't installed any patches. Where can I find them?
I installed RoboHelp 11 v11.0.0.179 last Friday.
The problems occur when I publish WebHelp to Firefox. Also happens when I
publish to my desktop.
Just a minute ago I noticed the Search function doesn't work when i publish
FlashHelp to Firefox.
Charles Bain
Contract Technical Writer
Revised Pay System for the Reserves (RPSR)
IBM Global Business Services
email: Removed by moderator
Go to Help > About.
Best not to include your email address in any forum posts.
____________________________________
Peter Grainge
http://www.grainge.org
Guest
Hi Peter, I downloaded the RH11.zip file, extracted the 3 files
(whibody.htm, whphost.js, whutils.js) and copied them to the ...WebHelp5Ext
\template_stock folder,
I restarted Robo11 & generated WebHelp, but the same problem remains - no
Contents, Search, Glossary or index buttons (the buttons are there, but are
inactive).
Next step?
Thanks, Chuck
Without checking, that sounds like a fix for a specific issue. You need
http://blogs.adobe.com/techcomm/2015/01/robohelp-11-update-released-rh-11-0-4.html
Guest
Apr 06, 2016 Apr 06, 2016
Hi Peter, found an interesting way to enable the Contents, Index & search
buttons:
Generate Webhelp to file system, (Contents, Index & search buttons are
inactive).
Copy the url in the above window into a newly-opened IE window.
All three buttons are now active.
I was having so many problems i de-installed v11 and installed it again.
I've noticed it now takes a much longer time (approx. 25 minutes) to
generate FlashHelp - no idea why.
Cheers, Chuck
Apr 11, 2016 Apr 11, 2016
That makes no sense but hey, if it works...
As to FlashHelp, I have not seen anything that would help explain why it is now taking so long to generate. I wonder if there is some common cause.
@petergrainge
Guest
Thanks Peter.
I will re-install v11 and see if it compiles FlshHelp any faster. Will let
you know what happens.
Thanks, Chuck
Aug 04, 2017 Aug 04, 2017
Peter,
I am having a similar issue with Firefox where the TOC, index and glossary do not display. I have updated, and am running RH 11.0.4.291.
I may have messed things up by doing some things out of order. I had already updated to 11.0.4 and then I replaced the whutils.js, whphost.js and whbody.htm. I generated the help and it worked great in Firefox and IE.
I made some changes yesterday and regenerated, but now Firefox is again not displaying the index, TOC or glossary.
I've tried reinstalling update 4 (thinking it would correct any mismatch with the files I mentioned earlier), and he installation is successful Upon regenerating, the TOC, index and glossary still do not display in Firefox (version 43 or 47).
Any thoughts you might have on correcting this are much appreciated. Thank you!
Given what you have changed, I think I would uninstall using something like
Revo Uninstaller and then reinstall.
First though, try one of the sample projects or a new simple project, just
two or three topics.
Thank you for your quick response, Peter. I didn't mention that I had tried a sample projects, but it had the same result.
I was hoping there would be a magical solution that would help me avoid a reinstall (our IT group has to do that), but I agree that seems like the next step.
Thanks again.
Aug 05, 2017 Aug 05, 2017
The fact you get the problem with the samples does sort of confirm it is an installation issue. Do get IT to make sure the RoboHelp folders are empty or non-existent after they remove the current installation.
See www.grainge.org for RoboHelp and Authoring information
@petergrainge
RoboHelp Documentation
Download Adobe RoboHelp
