Good day,
I can't add some older books I have downloaded to ADE. It keeps on giving me an error which states the license is already fulfilled by another user. I am the only user using this Adobe ID. I have tried to un-authorize and then re-authorize, but it did not work. I have deleted the ADEPT regestry key and did the authorization again, it did not work. What can I do to solve this? I am working on Windows 10 pro if that helps you.
You can try to merge the read rights Join multiple user IDs !
I too am having the same problem, with the same equipment and windows 10 pro. Have you had any luck?
Reggie
The error say that the eBook are linked with a other adobe ID. Have you open this files with a other Adobe ID or before you authoirze Digital Edition?
I figured out that I have used my other adobe ID for the first few books. So it was another Adobe ID that was authorized to open these books, and then the new books by my other Adobe ID. This is sorted out thanks.
Thank you very much. This worked and was very helpful.
You are welcome.
