Could anyone advise why the new version will not install.
I'm trying to install the MSI of either active x or NPAPI, I am licensed to re-distribute.
Regardless of what Windows OS I try it fails, we don't block msi installs so should allow any user to install however even with local admin or domain admin the install fails.
The error I get is "You must have administrative privileges to install flash player 21. please log on with administrative privileges and try again.
Below link might be helpful:
Adobe Flash Player Install for all versions
The Flash Player Admin Guide contains a chapter on distributing Flash Player within your organization. If you are distributing it to multiple computers you'll need to license Flash Player for distribution (free for most use cases) and you'll then receive an email with a link to download Flash Player for offline installation to the various systems. More information is available at http://www.adobe.com/products/players/flash-player-distribution.html and in the Flash Player Administrator's Guide
The article is very useful if you've never deployed Flash before.
The issue I find is that I've tried to deploy it and it fails, so I tried the installer locally to my machine and a few other test machines and the installer fails to install with the error mentioned previously. This indicates to me that there would be an issue with the installer itself but I'm not sure.
The .exe installers appear to work fine and extracting the .exe from the .msi also installs fine.
Anyone else had/having issues with the .msi installer.
It means you are not an administrator on the machine that is what 'You must have administrative privilege' means, its a straightforward error.
How about right click run as administrator.
Best Regards
As previously mentioned, I've tried to run it on my machine with local admin, this fails.
I've tried running as admin and entering domain admin details, this also fails.
a .msi installer shouldn't need admin in the first place if as an administrator you don't block .msi installers via group policy. So I shouldn't need to be admin.
This is the error I get when running local admin
Running domain admin
I get this error message.
Try using fix permissions here:
CS is correct. Users must have Administrator privileges for Flash Player to install. If the user's are Administrator's and the MSI is still failing, please provide the following log files for us to troubleshoot further:
Upload the log files to cloud.acrobat.com using the instructions at How to share a document and post the link to the uploaded log files in your reply.
Also, what version of Windows is this on?
Thank you.
Maria
I think he's already specified that this isn't an admin rights issue. I'm getting the same problem and I'm definitely, 100% an administrator on my laptop.
The error messages are incorrectly reporting that admin rights are required. If you right-click and hit "Run as administrator", the installation will succeed. The ActiveX installer fails, but the NPAPI installer succeeds without having to run as admin through the right-click menu.
If the OP can't access the C:\Windows\SysWOW64\Macromed\Flash directory there are permissions issues with that directory. The FAQ CS links to will assist with this. The tool in our FAQ is limited to files and registry items Flash Player writes to an/or modifies. However, sometimes, there are other file system and/or registry items that prevent installation. In these cases, Microsoft has resources for fixing file system and registry permissions issues. The OP hasn't replied and we don't know if the solution in the FAQ worked or not.
For your issue, please provide the following:
Thank you.
Maria
Windows 10, Firefox 45.0.2
No Flash player currently installed. I'm trying to install Flash Player 21. I just reapplied to distribute two days ago, so I'm assuming it's the latest one.
Here's the latest entry from FlashInstallLog.log:
=O====== M/21.0.0.213 2016-04-13+13-16-01.976 ========
0000 00000010 "C:\Users\username\AppData\Local\Temp\{E0C1144D-1178-4B3F-9FF6-7CE6B54017C0}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 2 -au 4294967295
0001
0002
0003
0004
0005
0006 00000018
0007
0008
0009
0010
0011
0012
0013 00000013
0014 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_21_0_0_213_ActiveX.exe
0015 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_21_0_0_213_ActiveX.dll
0016 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0017
=X====== M/21.0.0.213 2016-04-13+13-16-03.643 ========
I'm trying to install using SCCM 2012. My installation failed for only the .msi installer for the ActiveX version. The NPAPI version succeeded without any modifications to my test systems. When it failed on the SCCM console, I ran the installer by double-clicking on the client and I got a prompt saying that I need admin rights. Right-click>Run as Administrator... allowed the installation to go through. I definitely have admin rights on that machine.
Hi markc54951597,
You're situation for Flash Player ActiveX is completely different from the OP. As of Windows 8, Microsoft embeds Flash Player in Internet Explorer, and Edge in Windows 10 and all updates are distributed by Microsoft via Windows Update. Flash Player ActiveX installer will NOT install on these operating systems. To update Flash Player for IE/Edge on Windows 10, please run Windows Update.
We will be updating the text on the distribution page to indicate that the Flash Player ActiveX installers are only for Windows 7 and below.
Maria
Thank you for clarifying the requirements! I could swear I already knew that, but I've obviously forgotten. I'll update my testing scope to include only Windows 7 machines.
I'm curious to see if OP has tried Windows 7 ("Regardless of what Windows OS I try it fails")
