Expression counter with commas and two decimal points
Apr 12, 2016 Apr 12, 2016
Hello all,
I'm trying to get an expression counter with commas and two decimal points. I have the comma taken care of, but I can't seem to get the two decimal points to work.
Here's my current expression. As you'll see, nothing in there about decimal points. Nothing I've tried has worked for me. Thoughts?
var num = effect("Slider Control")("Slider")
num = Comma(num);
[num]
function Comma(number)
number = '' + Math.round(number);
if (number.length > 3)
var mod = number.length % 3;
var output = (mod > 0 ? (number.substring(0,mod)) : '');
for (i=0 ; i < Math.floor(number.length / 3); i++)
if ((mod == 0) && (i == 0))
output += number.substring(mod+ 3 * i, mod + 3 * i + 3);
else
output+= ',' + number.substring(mod + 3 * i, mod + 3 * i + 3);
return (output);
else return number;
Expressions
15.3K
‌Try this: Dan Ebberts's Universal Timer
Or here is my preset for that kind of thing. It's Dan's timer on steroids. universalTimer.ffx
By the way, typing counter expression or count with decimals or even timer In the search help field would've taken you directly to Dan's universal timer.
Apr 13, 2016 Apr 13, 2016
Great! Worked like a charm. Thanks Rick! One other quick question...is there a way to force the dollar sign to be superscript? I've tried something simple like: string.sup()
But that didn't work. Thoughts?
May 24, 2017 May 24, 2017
You Can use a Scale+position Animator, and "lock" it to the dollar sign with the range selector (letter index and not percentage), if it's on the right side of the counter the start index should be 0 and the end index should be 1, if it's on the left side you will need an expression that "knows" where the dollar sign index is and set the start value to the dollar index and the end to the index-1.
You can also Skip the code and expressions and use this cool Counter Preset:
http://www.vdodna.com/products/counter-preset/
Cheers!
Oct 01, 2017 Oct 01, 2017
Very similar to the one that I shared for free... just saying
Sep 16, 2020 Sep 16, 2020
How to change the comma to a dot??
Look for the character you want to change in the expression. The comma will look like this "," or ','
Change the character.
May 27, 2021 May 27, 2021
If you guys are interested I have created a tutorial with a bunch of expression for countdown and counters, I have also included to after effects source file so you can add it to your own project.
https://blog.motionisland.com/after-effects-counter-templates-projects/
Hope it will help you
Best
Sep 28, 2023 Sep 28, 2023
Check out this helpful After Effects tutorial on countdowns and counters, along with free project files: [Link to Tutorial]. You can also find more free After Effects resources at https://riztagar.com/. Improve your skills with their easy-to-follow tutorials and project files!
riztagar
